WRE2405P-3W
WRE2405P-3W
    MORNSUN(金升阳)
    WRE2405P-3W - SINGLE/DUAL OUTPUT DIP DC-DC CONVERTER - MORNSUN Science& Technology Ltd.
WRE2405P-3W 数据手册
WRE_P-3W & WRF_P-3W Series 3W, WIDE INPUT, ISOLATED & REGULATED SINGLE/DUAL OUTPUT DIP DC-DC CONVERTER m ulti-country patent protection RoHS FEATURES Efficiency Up To 82% Operating Temperature: -40°C to +85°C 3KVDC Isolation Short circuit protection(automatic recovery) No external component required Internal SMD construction Industry standard pinout MTBF>1,000,000 hours UL94-V0 Package RoHS Compliance PRODUCT PROGRAM Input Part Number W RE1205P-3W W RE1209P-3W W RE1212P-3W W RE1215P-3W W RF1205P-3W W RF1209P-3W W RF1212P-3W W RF1215P-3W W RE2405P-3W 12 9-18 22 Voltage (VDC) N ominal R ange Max* Voltage (VDC) ±5 ±9 ±12 ±15 5 9 12 15 ±5 ±9 ±12 24 18-36 40 ±15 5 9 12 15 Output Current (mA) Max ±300 ±167 ±125 ±100 600 333 250 200 ±300 ±167 ±125 ±100 600 333 250 200 Min ±30 ±16 ±12 ±10 60 33 25 20 ±30 ±16 ±12 ±10 60 33 25 20 74 76 78 79 74 76 78 79 78 80 82 81 78 80 82 81 Efficiency (%, Typ) APPLICATIONS The WRE_P-3W & WRF_P-3W Series are specially designed for applications where a wide range input voltage power supplies are isolated from the input power supply in a distributed power supply system on a circuit board. These products apply to: 1) Where the voltage of the input power supply is wide range (voltage range≤2:1); 2) Where isolation is necessary between input and output(Isolation Voltage≤3000VDC); 3) Where the regulation of the output voltage and the output ripple noise are demanded. W RE2409P-3W W RE2412P-3W W RE2415P-3W W RF2405P-3W W RF2409P-3W W RF2412P-3W W RF2415P-3W *Input voltage can’t exceed this value, or will cause the permanent damage. Note:The load shouldn't be less than 10%,otherwise ripple will increase dramatically. Operation under 10% load will not damage the converter; However, they may not meet all specification listed. ISOLATION SPECIFICATIONS Item Isolation voltage Isolation resistance Test Conditions Tested for 1 minute and 1mA max Test at 500VDC Min Typ Max Units 3000 1000 VDC MΩ APPLICATIONS WRE1205P-3W Rated Power Package Style Outp ut Voltage Input Volta ge Produ ct Series OUTPUT SPECIFICATIONS Item Output power Positive voltage accuracy Test Conditions See below products program R efer to recommended circuit Min 0.3 ±1 ±3 ±0.5 ±0.2 Typ Max 3 ±3 ±5 ±1* ±0.5 ±0.03 50 300 100 %/℃ mVp-p KHz % Units W N egative voltage accuracy R efer to recommended circuit Load regulation From 10% To 100% load Line regulation(at full load) Input voltage from low to high Temperature Drift(Vout) M ORNSUN Science & Technology co.,Ltd. Address: 2th floor 6th building, Huangzhou Industrial District, Guangzhou, China Tel: 86-20-38601850 Fax: 86-20-38601272 Http://www.mornsun-power.com Ripple & Noise ** Switching frequency Refer to recommended circuit 20MHz bandwidth 100% load, nominal Input voltage * Dual output models unbalanced load: ±5%. **Test ripple and noise by “parallel cable” method. See detailed operation instructions at Testing of Power Converter section, application notes. Note: 1. All specifications measured at TA=25°C, humidity
WRE2405P-3W 价格&库存
很抱歉,暂时无法提供与“WRE2405P-3W”相匹配的价格&库存,您可以联系我们找货
