WRE4809CKS-1W
WRE4809CKS-1W
    MORNSUN(金升阳)
    WRE4809CKS-1W - DUAL/SINGLE OUTPUT SIP DC-DC CONVERTER - MORNSUN Science& Technology Ltd.
WRE4809CKS-1W 数据手册
WRE_CKS-1W & WRF_CKS-1W Series 1W, WIDE INPUT, ISOLATED & REGULATED DUAL/SINGLE OUTPUT SIP DC-DC CONVERTER m ulti-country patent protection RoHS FEATURES Efficiency up to 81% Wide (2:1) Input Range I/O Isolation 3000VDC Short circuit protection(automatic recovery) External On/Off control Internal SMD construction Operating Temperature: -40°C to +85°C UL94-V0 Package RoHS Compliance PRODUCT PROGRAM Part Number W RE0505CKS-1W * W RE0509CKS-1W * W RE0512CKS-1W * W RE0515CKS-1W * W RF0505CKS-1W * W RF0509CKS-1W * W RF0512CKS-1W * W RF0515CKS-1W * W RE1205CKS-1W W RE1209CKS-1W W RE1212CKS-1W W RE1215CKS-1W W RF1205CKS-1W W RF1209CKS-1W W RF1212CKS-1W W RF1215CKS-1W W RE2405CKS-1W W RE2409CKS-1W W RE2412CKS-1W W RE2415CKS-1W W RF2405CKS-1W W RF2409CKS-1W W RF2412CKS-1W W RF2415CKS-1W W RE4805CKS-1W * W RE4809CKS-1W * W RE4812CKS-1W * W RE4815CKS-1W * W RF4805CKS-1W * 48 36-72 80 24 18-36 40 5 4.5-9.0 11 Input Voltage (VDC) Nominal R ange Max** Voltage (VDC) ±5 ±9 ±12 ±15 5 9 12 15 ±5 ±9 ±12 ±15 5 9 12 15 ±5 ±9 ±12 ±15 5 9 12 15 ±5 ±9 ±12 ±15 5 9 12 15 Output Current (mA) Max Min ±100 ±55 ±42 ±33 200 111 83 67 ±100 ±55 ±42 ±33 200 111 83 67 ±100 ±55 ±42 ±33 200 111 83 67 ±100 ±55 ±42 ±33 200 111 83 67 ±10 ±6 ±4 ±3 20 11 8 7 ±10 ±6 ±4 ±3 20 11 8 7 ±10 ±6 ±4 ±3 20 11 8 7 ±10 ±6 ±4 ±3 20 11 8 7 Efficiency (%, Typ) 72 74 76 75 72 74 76 75 76 78 80 80 76 78 80 80 78 79 81 81 76 78 81 81 76 78 80 80 76 78 80 80 APPLICATIONS The WRE_CKS-1W & WRF_CKS-1W Series are specially designed for applications where a wide range input voltage power supplies are isolated from the input power supply in a distributed power supply system on a circuit board. These products apply to: 1) Where the voltage of the input power supply is wide range (voltage range≤ 2:1); 2) Where isolation is necessary between input and output(isolation voltage≤3000VDC); 3) Where the regulation of the output voltage and the output ripple noise are demanded. 12 9.0-18 22 MODEL SELECTION WRE2412CKS-1W Rated Power Package Style Output Voltage Input Voltage Product Series W RF4809CKS-1W * W RF4812CKS-1W * W RF4815CKS-1W * * Designing. **Input voltage can’t exceed this value, or will cause the permanent damage. Note: The load shouldn't be less than 10%, otherwise ripple will increase dramatically. Operation under 10% load will not damage the converter; However, they may not meet all specification listed. OUTPUT SPECIFICATIONS Item Output power Positive voltage accuracy N egative voltage accuracy R efer To Recommended Circuit R efer To Recommended Circuit 10% to 100% load(WRF_CKS-1W) 10% to 100% load(WRE_CKS-1W) * Input voltage from Low To high Refer to recommended circuit 20MHz Bandwidth Input voltage range 100% load Test Conditions Min 0.1 ±1 ±3 ±0.5 ±0.75 ±0.2 25 300 Typ Max 1 ±3 ±5 ±0.75 ±1.0 ±0.5 ±0.03 75 % Units W M ORNSUN Science & Technology co.,Ltd. Address: 2th floor 6th building, Huangzhou Industrial District, Guangzhou, China Tel: 86-20-38601850 Fax:86-20-38601272 Http://www.mornsun-power.com Load Regulation Line Regulation Temperature Drift (Vout) Ripple & Noise** Switching Frequency %/°C mVp-p KHz * Dual output models unbalanced load(25/100%): ±5%Max. **Test ripple and noise by “parallel cable” method. See detailed operation instructions at Testing of Power Converter section, application notes. MORNSUN reserves the copyright Specifications subject to change without notice. WRE_CKS-1W & WRF_CKS-1W A/0-2008 Page 1 of 2 COMMON SPECIFICATION Item Storage Humidity Operating Temperature Storage Temperature Temp. Rise at Full Load Lead Temperature Isolation voltage Isolation resistance Isolation Capacitance N o-load power consumption C ooling Short Circuit Protection C ase Material MTBF W eight 1000 5 1.5mm from case for 10 seconds Tested for 1 minute and 1mA max Test at 500VDC 100KHz,1V 3000 1000 35 120 Free Air Convection Continuous, Automatic recovery Plastic(UL94-V0) K hours g -40 -55 15 300 VDC MΩ PF mW Test Conditions Min Typ Max 95 85 125 °C Units % APPLICATION NOTE Recommended circuit If you want to further decrease the input/output ripple, an “ LC” filtering network may be connected to the input and output ends of the DC/DC converter, see (Figure 1). Single Output Vc Vi n Cin G ND 1 7 D1 Ic R Lin 2 3 6 8 Cs Co ut 0V + Vo Dual Output Vc V in C in 7 D1 I c R Lin 2 3 6 Lout Cout + Vo 0V Cout -Vo G ND 1 8 Lout Note: 1. All specifications measured at TA=25°C, humidity
WRE4809CKS-1W 价格&库存
很抱歉,暂时无法提供与“WRE4809CKS-1W”相匹配的价格&库存,您可以联系我们找货
