UHE1A152MPD
UHE1A152MPD
    NICHICON(尼吉康)
    插件,D10xL25mm
UHE1A152MPD 数据手册
ALUMINUM ELECTROLYTIC CAPACITORS UHE Miniature Sized, Low Impedance, High Reliability Approved by Reliability Center for Electronic Component, Japan-Certification No. RCJ-03-23C Low impedance and high reliability withstanding 4000 hours to 10000 hours. Compliant to the RoHS directive (2011/65/EU,(EU)2015/863). UHE UHD Long Life Specifications Performance Characteristics ltem Category Temperature Range –40 to +105˚C Rated Voltage Range 6.3 to 100V Rated Capacitance Range 2.2 to 18000µF Capacitance Tolerance ± 20% at 120Hz, 20˚C Leakage Current After 2 minutes' application of rated voltage at 20°C, leakage current is not more than 0.01CV or 3 (µA), whichever is greater. Rated voltage (V) 6.3 10 16 25 35 50 63 100 120Hz tan δ (MAX.) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.08 20˚C 120Hz Tangent of loss angle (tan δ) For capacitance of more than 1000µF, add 0.02 for every increase of 1000µF. Rated voltage (V) Stability at Low Temperature Impedance ratio (MAX.) 6.3 10 16 25 35 50 63 100 Z–25˚C / Z+20˚C 4 3 2 2 2 2 2 2 Z–40˚C / Z+20˚C 8 6 4 3 3 3 3 3 The following specifications shall be met when the capacitors are restored to 20˚C after D.C. bias plus rated ripple current is applied at 105˚C , the peak voltage shall not exceed the rated voltage. φD < = 6.3 φD = 8 , 10 6.3 to 10V 4000 hours 6000 hours 8000 hours 16 to 100V 5000 hours 7000 hours 10000 hours Case size Rated voltage Endurance φD > = 12.5 Capacitance change Within ± 25% of the initial capacitance value tan δ 200% or less than the initial specified value Leakage current Less than or equal to the initial specified value Printed with white color letter on black sleeve. Marking Radial Lead Type Type numbering system (Example : 10V 1000µF) φd Sleeve (P.E.T.) 1 2 3 4 5 6 7 8 9 10 11 12 U HE 1 A 1 0 2 M PD P±0.5 φD+0.5 MAX. Size code Configuration Capacitance tolerance ( ±20%) L+ 15MIN MAX. Rated capacitance (1000µF) 4MIN Rated voltage (10V) Pressurerelief vent (φ6.3up) Series name (mm) (L < 20) 1.5 (L 20) 2.0 φD 5 6.3 8 10 12.5 16 18 P 2.0 2.5 3.5 5.0 5.0 7.5 7.5 φd 0.5 0.5 0.6 0.6 0.6 0.8 0.8 Type Configuration φD In case L > 25 for the φ12.5 dia. unit, lead dia. φd = 0.8mm Please refer to the Guidelines for Aluminum Electrolytic Capacitors for end seal configuration information. Pb-free leadwire Pb-free PET sleeve 5 DD 6.3 8 · 10 12.5 to 18 ED PD HD Frequency coefficient of rated ripple current Frequency 50Hz 120Hz 300Hz 1kHz 10kHz or more 2.2 to 33 0.45 0.55 0.70 0.90 1.00 39 to 330 0.60 0.70 0.85 0.95 1.00 390 to 1000 0.65 0.75 0.90 0.98 1.00 1200 to 18000 0.75 0.80 0.95 1.00 1.00 Cap. (µF) Dimension table in next page. CAT.8100K ALUMINUM ELECTROLYTIC CAPACITORS UHE Dimensions Rated Voltage (V) (code) 6.3 (0J) 10 (1A) Rated Capacitance (µF) Case Size φD×L(mm) tan δ 150 5× 11 0.22 330 6.3×11 0.22 Leakage Current (µA) at 20℃ after 2 minutes Impedance(Ω) MAX. Rated Ripple (mArms) (105℃/100kHz) Part Number 20℃/ 100kHz -10℃/ 100kHz 9.45 0.58 2.30 210 UHE0J151MDD 20.79 0.22 0.87 340 UHE0J331MED ( ) 680 8× 11.5 0.22 42.84 0.13 0.52 640 UHE0J681MPD 820 10× 12.5 0.22 51.66 0.080 0.32 865 UHE0J821MPD 1000 8× 15 0.22 63 0.087 0.35 840 UHE0J102MPD 1200 8× 20 0.22 75.6 0.069 0.27 1050 UHE0J122MPD 1200 10× 16 0.22 75.6 0.060 0.24 1210 UHE0J122MPD6 1500 10× 20 0.22 94.5 0.046 0.18 1400 UHE0J152MPD 1800 12.5× 15 0.22 113.4 0.049 0.16 1450 UHE0J182MHD 2200 10× 25 0.24 138.6 0.042 0.17 1650 UHE0J222MPD 2700 10× 31.5 0.24 170.1 0.031 0.12 1910 UHE0J272MPD6 2700 16× 15 0.24 170.1 0.042 0.12 1940 UHE0J272MHD 3300 12.5× 20 0.26 207.9 0.035 0.12 1900 UHE0J332MHD 3900 12.5× 25 0.26 245.7 0.027 0.089 2230 UHE0J392MHD 3900 18× 15 0.26 245.7 0.043 0.11 2210 UHE0J392MHD6 4700 12.5× 31.5 0.28 296.1 0.024 0.078 2650 UHE0J472MHD 5600 12.5× 35.5 0.30 352.8 0.020 0.065 2880 UHE0J562MHD 5600 16× 20 0.30 352.8 0.027 0.078 2530 UHE0J562MHD6 6800 12.5× 40 0.32 428.4 0.017 0.056 3350 UHE0J682MHD 6800 16× 25 0.32 428.4 0.021 0.060 2930 UHE0J682MHD6 6800 18× 20 0.32 428.4 0.026 0.067 2860 UHE0J682MHD3 8200 16× 31.5 0.36 516.6 0.017 0.050 3450 UHE0J822MHD 10000 16× 35.5 0.40 630 0.015 0.044 3610 UHE0J103MHD 10000 18× 25 0.40 630 0.019 0.049 3140 UHE0J103MHD6 12000 16× 40 0.44 756 0.013 0.038 4080 UHE0J123MHD 12000 18× 31.5 0.44 756 0.015 0.040 4170 UHE0J123MHD6 15000 18× 35.5 0.50 945 0.014 0.038 4220 UHE0J153MHD 18000 18× 40 0.56 1134 0.012 0.032 4280 UHE0J183MHD 100 5× 11 0.19 10 0.58 2.30 210 UHE1A101MDD 220 6.3× 11 0.19 22 0.22 0.87 340 UHE1A221MED 470 8× 11.5 0.19 47 0.13 0.52 640 UHE1A471MPD 680 8× 15 0.19 68 0.087 0.35 840 UHE1A681MPD 680 10× 12.5 0.19 68 0.080 0.32 865 UHE1A681MPD6 1000 8× 20 0.19 100 0.069 0.27 1050 UHE1A102MPD 1000 10× 16 0.19 100 0.060 0.24 1210 UHE1A102MPD6 1200 10× 20 0.19 120 0.046 0.18 1400 UHE1A122MPD 1500 10× 25 0.19 150 0.042 0.17 1650 UHE1A152MPD 1500 12.5×15 0.19 150 0.049 0.16 1450 UHE1A152MHD6 2200 0.21 220 0.031 0.12 1910 UHE1A222MPD 2200 12.5×20 10 ×31.5 0.21 220 0.035 0.12 1900 UHE1A222MHD6 2200 16 ×15 0.21 220 0.042 0.12 1940 UHE1A222MHD3 2700 18 ×15 0.21 270 0.043 0.11 2210 UHE1A272MHD 3300 12.5×25 0.23 330 0.027 0.089 2230 UHE1A332MHD 3900 12.5× 31.5 0.23 390 0.024 0.078 2650 UHE1A392MHD UHE1A392MHD6 3900 16 × 20 0.23 390 0.027 0.078 2530 4700 12.5× 35.5 0.25 470 0.020 0.065 2880 UHE1A472MHD 5600 12.5× 40 0.27 560 0.017 0.056 3350 UHE1A562MHD 5600 16× 25 0.27 560 0.021 0.060 2930 UHE1A562MHD6 For cut leads, formed leads or taped parts, please add the appropriate code after the size code (12th digit ). If there is no size code in the part number, please add size code “1” and then add the appropriate code. CAT.8100K ALUMINUM ELECTROLYTIC CAPACITORS UHE Dimensions Rated Voltage (V) (code) 10 (1A) 16 (1C) 25 (1E) Rated Capacitance (µF) Case Size φD×L(mm) tan δ Leakage Current (µA) at 20℃ after 2 minutes ( ) Impedance(Ω) MAX. 20℃/ 100kHz -10℃/ 100kHz Rated Ripple (mArms) (105℃/100kHz) Part Number 5600 18× 20 0.27 560 0.026 0.067 2860 UHE1A562MHD3 6800 16× 31.5 0.29 680 0.017 0.050 3450 UHE1A682MHD 6800 18× 25 0.29 680 0.019 0.049 3140 UHE1A682MHD6 8200 16× 35.5 0.33 820 0.015 0.044 3610 UHE1A822MHD 8200 18× 31.5 0.33 820 0.015 0.040 4170 UHE1A822MHD6 10000 16× 40 0.37 1000 0.013 0.038 4080 UHE1A103MHD 10000 18× 35.5 0.37 1000 0.014 0.038 4220 UHE1A103MHD6 12000 18× 40 0.41 1200 0.012 0.032 4280 UHE1A123MHD 56 5× 11 0.16 0.58 2.30 210 UHE1C560MDD 120 6.3×11 0.16 19.2 0.22 0.87 340 UHE1C121MED 8.96 330 8× 11.5 0.16 52.8 0.13 0.52 640 UHE1C331MPD 470 8× 15 0.16 75.2 0.087 0.35 840 UHE1C471MPD 470 10× 12.5 0.16 75.2 0.080 0.32 865 UHE1C471MPD6 680 8× 20 0.16 108.8 0.069 0.27 1050 UHE1C681MPD 680 10× 16 0.16 108.8 0.060 0.24 1210 UHE1C681MPD6 1000 10× 20 0.16 160 0.046 0.18 1400 UHE1C102MPD 1000 12.5× 15 0.16 160 0.049 0.16 1450 UHE1C102MHD6 1200 10× 25 0.16 192 0.042 0.17 1650 UHE1C122MPD 1500 10× 31.5 0.16 240 0.031 0.12 1910 UHE1C152MPD 1500 12.5× 20 0.16 240 0.035 0.12 1900 UHE1C152MHD6 1500 16× 15 0.16 240 0.042 0.12 1940 UHE1C152MHD3 2200 12.5× 25 0.18 352 0.027 0.089 2230 UHE1C222MHD 2200 18× 15 0.18 352 0.043 0.11 2210 UHE1C222MHD6 2700 12.5× 31.5 0.18 432 0.024 0.078 2650 UHE1C272MHD 2700 16× 20 0.18 432 0.027 0.078 2530 UHE1C272MHD6 3300 12.5× 35.5 0.20 528 0.020 0.065 2880 UHE1C332MHD 3900 12.5× 40 0.20 624 0.017 0.056 3350 UHE1C392MHD 3900 16× 25 0.20 624 0.021 0.060 2930 UHE1C392MHD6 3900 16× 20 0.20 624 0.026 0.067 2860 UHE1C392MHD3 4700 16× 31.5 0.22 752 0.017 0.050 3450 UHE1C472MHD 4700 18× 25 0.22 752 0.019 0.049 3140 UHE1C472MHD6 5600 16× 35.5 0.24 896 0.015 0.044 3610 UHE1C562MHD 5600 18× 31.5 0.24 896 0.015 0.040 4170 UHE1C562MHD6 6800 16× 40 0.26 1088 0.013 0.038 4080 UHE1C682MHD 8200 18× 35.5 0.30 1312 0.014 0.038 4220 UHE1C822MHD 1600 10000 18× 40 0.34 0.012 0.032 4280 UHE1C103MHD 47 5× 11 0.14 11.75 0.58 2.30 210 UHE1E470MDD 100 6.3× 11 0.14 25 0.22 0.87 340 UHE1E101MED 220 8× 11.5 0.14 55 0.13 0.52 640 UHE1E221MPD 330 8× 15 0.14 82.5 0.087 0.35 840 UHE1E331MPD 330 10× 12.5 0.14 82.5 0.080 0.32 865 UHE1E331MPD6 470 8× 20 0.14 117.5 0.069 0.27 1050 UHE1E471MPD 470 10× 16 0.14 117.5 0.060 0.24 1210 UHE1E471MPD6 680 10× 20 0.14 170 0.046 0.18 1400 UHE1E681MPD 680 12.5× 15 0.14 170 0.049 0.16 1450 UHE1E681MHD6 820 10× 25 0.14 205 0.042 0.17 1650 UHE1E821MPD 10× 31.5 0.14 250 0.031 0.12 1910 UHE1E102MPD 0.14 250 0.035 0.12 1900 UHE1E102MHD6 1000 1000 12.5× 20 For cut leads, formed leads or taped parts, please add the appropriate code after the size code (12th digit ). If there is no size code in the part number, please add size code “1” and then add the appropriate code. CAT.8100K ALUMINUM ELECTROLYTIC CAPACITORS UHE Dimensions Rated Voltage (V) (code) 25 (1E) Rated Capacitance (µF) 50 (1H) tan δ Leakage Current (µA) at 20℃ after 2 minutes ( ) Impedance(Ω) MAX. 20℃/ 100kHz -10℃/ 100kHz Rated Ripple (mArms) (105℃/100kHz) Part Number 1000 16× 15 0.14 250 0.042 0.12 1940 UHE1E102MHD3 1200 18× 15 0.14 300 0.043 0.11 2210 UHE1E122MHD 1500 12.5× 25 0.14 375 0.027 0.089 2230 UHE1E152MHD 1800 12.5× 31.5 0.14 450 0.024 0.078 2650 UHE1E182MHD 1800 16× 20 0.14 450 0.027 0.078 2530 UHE1E182MHD6 2200 12.5× 35.5 0.16 550 0.020 0.065 2880 UHE1E222MHD 2200 18× 20 0.16 550 0.026 0.067 2860 UHE1E222MHD6 2700 12.5× 40 0.16 675 0.017 0.056 3350 UHE1E272MHD 2700 16× 25 0.16 675 0.021 0.060 2930 UHE1E272MHD6 3300 16× 31.5 0.18 825 0.017 0.050 3450 UHE1E332MHD 3300 18× 25 0.18 825 0.019 0.049 3140 UHE1E332MHD6 3900 16× 35.5 0.18 975 0.015 0.044 3610 UHE1E392MHD 3900 18× 31.5 0.18 975 0.015 0.040 4170 UHE1E392MHD6 4700 16× 40 0.20 1175 0.013 0.038 4080 UHE1E472MHD 4700 18× 35.5 0.20 1175 0.014 0.038 4220 UHE1E472MHD6 5600 18× 40 0.22 1400 0.012 0.032 4280 UHE1E562MHD 33 5× 11 0.12 0.58 2.30 210 UHE1V330MDD 11.55 47 6.3×11 0.12 16.45 0.22 0.87 250 UHE1V470MED 56 6.3×11 0.12 19.6 0.22 0.87 340 UHE1V560MED 100 8× 11.5 0.12 35 0.13 0.52 640 UHE1V101MPD 150 8× 11.5 0.12 52.5 0.13 0.52 640 UHE1V151MPD 220 8× 15 0.12 77 0.087 0.35 840 UHE1V221MPD 220 10× 12.5 0.12 77 0.080 0.32 865 UHE1V221MPD6 270 8× 20 0.12 94.5 0.069 0.27 1050 UHE1V271MPD 330 10× 16 0.12 115.5 0.060 0.24 1210 UHE1V331MPD UHE1V471MPD 470 10× 20 0.12 164.5 0.046 0.18 1400 470 12.5×15 0.12 164.5 0.049 0.16 1450 UHE1V471MHD6 560 10× 25 0.12 196 0.042 0.17 1650 UHE1V561MPD 10× 31.5 680 35 (1V) Case Size φD×L(mm) 0.12 238 0.031 0.12 1910 UHE1V681MPD 680 12.5× 20 0.12 238 0.035 0.12 1900 UHE1V681MHD6 680 16× 15 0.12 238 0.042 0.12 1940 UHE1V681MHD3 1000 12.5× 25 0.12 350 0.027 0.089 2230 UHE1V102MHD 1000 18× 15 0.12 350 0.043 0.11 2210 UHE1V102MHD6 1200 12.5× 31.5 0.12 420 0.024 0.078 2650 UHE1V122MHD 1200 16× 20 0.12 420 0.027 0.078 2530 UHE1V122MHD6 1500 12.5× 35.5 0.12 525 0.020 0.065 2880 UHE1V152MHD 1800 12.5× 40 0.12 630 0.017 0.056 3350 UHE1V182MHD 1800 16 ×25 0.12 630 0.021 0.060 2930 UHE1V182MHD6 1800 18 ×20 0.12 630 0.026 0.067 2860 UHE1V182MHD3 2200 16 ×31.5 0.14 770 0.017 0.050 3450 UHE1V222MHD 2200 18 ×25 0.14 770 0.019 0.049 3140 UHE1V222MHD6 2700 16 ×35.5 0.14 945 0.015 0.044 3610 UHE1V272MHD 2700 18 ×31.5 0.14 945 0.015 0.040 4170 UHE1V272MHD6 3300 16 ×40 0.16 1155 0.013 0.038 4080 UHE1V332MHD 3300 18 ×35.5 0.16 1155 0.014 0.038 4220 UHE1V332MHD6 3900 18 ×40 0.16 1365 0.012 0.032 4280 UHE1V392MHD 2.2 5×11 0.10 3 2.50 10.00 43 UHE1H2R2MDD 3.3 5×11 0.10 3 2.20 8.80 53 UHE1H3R3MDD For cut leads, formed leads or taped parts, please add the appropriate code after the size code (12th digit ). If there is no size code in the part number, please add size code “1” and then add the appropriate code. CAT.8100K ALUMINUM ELECTROLYTIC CAPACITORS UHE Dimensions Rated Voltage (V) (code) Rated Capacitance (µF) 4.7 10 63 (1J) tan δ Leakage Current (µA) at 20℃ after 2 minutes ( ) Impedance(Ω) MAX. 20℃/ 100kHz -10℃/ 100kHz Rated Ripple (mArms) (105℃/100kHz) Part Number 5× 11 0.10 3 1.90 7.60 88 UHE1H4R7MDD 5× 11 0.10 5 1.50 6.00 100 UHE1H100MDD 22 5× 11 0.10 11 0.70 2.80 180 UHE1H220MDD 33 6.3× 11 0.10 16.5 0.30 1.20 295 UHE1H330MED 47 6.3× 11 0.10 23.5 0.30 1.20 295 UHE1H470MED 56 6.3× 11 0.10 28 0.30 1.20 295 UHE1H560MED 8× 11.5 0.10 50 0.17 0.68 555 UHE1H101MPD 120 8× 15 0.10 60 0.12 0.48 730 UHE1H121MPD 150 10× 12.5 0.10 75 0.12 0.48 760 UHE1H151MPD 180 8× 20 0.10 90 0.091 0.36 910 UHE1H181MPD 220 10× 16 0.10 110 0.084 0.34 1050 UHE1H221MPD 270 10× 20 0.10 135 0.060 0.24 1220 UHE1H271MPD 270 12.5× 15 0.10 135 0.061 0.20 1260 UHE1H271MHD6 330 10× 25 0.10 165 0.055 0.22 1440 UHE1H331MPD 330 10× 20 0.10 165 0.060 0.24 1220 UHE1H331MPD6 470 10× 31.5 0.10 235 0.043 0.17 1690 UHE1H471MPD 100 50 (1H) Case Size φD×L(mm) 470 12.5×20 0.10 235 0.045 0.15 1660 UHE1H471MHD6 470 16× 15 0.10 235 0.055 0.17 1690 UHE1H471MHD3 560 12.5× 25 0.10 280 0.034 0.11 1950 UHE1H561MHD 560 18× 15 0.10 280 0.054 0.15 1930 UHE1H561MHD6 680 12.5× 31.5 0.10 340 0.030 0.10 2310 UHE1H681MHD 820 12.5× 35.5 0.10 410 0.025 0.083 2510 UHE1H821MHD 820 16× 20 0.10 410 0.034 0.10 2210 UHE1H821MHD6 1000 12.5× 40 0.10 500 0.021 0.069 2920 UHE1H102MHD 1000 16× 25 0.10 500 0.025 0.075 2555 UHE1H102MHD6 1000 18× 20 0.10 500 0.036 0.097 2490 UHE1H102MHD3 1200 16× 31.5 0.10 600 0.022 0.066 3010 UHE1H122MHD 1200 18× 25 0.10 600 0.026 0.070 2740 UHE1H122MHD6 1500 16× 35.5 0.10 750 0.019 0.057 3150 UHE1H152MHD 1800 16× 40 0.10 900 0.016 0.048 3710 UHE1H182MHD 1800 18× 31.5 0.10 900 0.021 0.057 3635 UHE1H182MHD6 2200 18× 35.5 0.12 1100 0.017 0.046 3680 UHE1H222MHD6 2700 18× 40 0.12 1350 0.014 0.038 3800 UHE1H272MHD 15 5× 11 0.09 9.45 2.30 9.30 62 UHE1J150MDD 33 6.3× 11 0.09 20.79 1.20 5.00 126 UHE1J330MED UHE1J470MPD 47 8×11.5 0.09 29.61 0.63 2.80 260 56 8× 11.5 0.09 35.28 0.63 2.80 260 UHE1J560MPD 82 8×15 0.09 51.66 0.45 2.10 335 UHE1J820MPD 82 10 ×12.5 0.09 51.66 0.43 1.80 325 UHE1J820MPD6 120 8×20 0.09 75.6 0.33 1.60 408 UHE1J121MPD 120 10 ×16 0.09 75.6 0.31 1.50 400 UHE1J121MPD6 180 10 ×20 0.09 113.4 0.21 0.94 518 UHE1J181MPD 180 12.5×15 0.09 113.4 0.23 1.10 527 UHE1J181MHD6 220 10 ×25 0.09 138.6 0.20 0.84 595 UHE1J221MPD 270 10 ×31.5 0.09 170.1 0.15 0.71 740 UHE1J271MPD 270 12.5×20 0.09 170.1 0.16 0.64 765 UHE1J271MHD6 270 16 ×15 0.09 170.1 0.14 0.66 895 UHE1J271MHD3 330 12.5×25 0.09 207.9 0.12 0.45 875 UHE1J331MHD For cut leads, formed leads or taped parts, please add the appropriate code after the size code (12th digit ). If there is no size code in the part number, please add size code “1” and then add the appropriate code. CAT.8100K ALUMINUM ELECTROLYTIC CAPACITORS UHE Dimensions Rated Voltage (V) (code) 63 (1J) Rated Capacitance (µF) tan δ Impedance(Ω) MAX. Leakage Current (µA) at 20℃ after 2 minutes 20℃/ 100kHz -10℃/ 100kHz ( ) Rated Ripple (mArms) (105℃/100kHz) Part Number 390 18× 15 0.09 245.7 0.12 0.50 1030 UHE1J391MHD 470 12.5× 31.5 0.09 296.1 0.10 0.42 1010 UHE1J471MHD 470 16×20 0.09 296.1 0.091 0.38 1130 UHE1J471MHD6 560 12.5× 35.5 0.09 352.8 0.083 0.35 1140 UHE1J561MHD 560 16× 25 0.09 352.8 0.073 0.27 1350 UHE1J561MHD6 680 12.5× 40 0.09 428.4 0.071 0.30 1280 UHE1J681MHD 680 18× 20 0.09 428.4 0.080 0.30 1300 UHE1J681MHD6 820 16× 31.5 0.09 516.6 0.054 0.20 1650 UHE1J821MHD 820 18× 25 0.09 516.6 0.057 0.21 1560 UHE1J821MHD6 1000 16× 35.5 0.09 630 0.045 0.17 1900 UHE1J102MHD 1000 18× 31.5 0.09 630 0.047 0.17 1720 UHE1J102MHD6 1200 16× 40 0.09 756 0.040 0.15 2130 UHE1J122MHD 1200 18× 35.5 0.09 756 0.040 0.15 1890 UHE1J122MHD6 1500 18× 40 0.09 945 0.036 0.13 2470 UHE1J152MHD 6.8 15 5× 11 0.08 6.3×11 0.08 6.8 15 2.30 9.30 62 UHE2A6R8MDD 1.20 5.00 126 UHE2A150MED 27 8× 11.5 0.08 27 0.63 2.80 260 UHE2A270MPD 39 8× 15 0.08 39 0.45 2.10 335 UHE2A390MPD 47 10× 12.5 0.08 47 0.43 1.80 325 UHE2A470MPD 56 8×20 0.08 56 0.33 1.60 408 UHE2A560MPD 68 10× 16 0.08 68 0.31 1.50 400 UHE2A680MPD 82 10× 20 0.08 82 0.21 0.94 518 UHE2A820MPD 82 12.5× 15 0.08 82 0.23 1.10 527 UHE2A820MHD6 100 10× 25 0.08 100 0.20 0.84 595 UHE2A101MPD 100 12.5× 20 0.08 100 0.20 0.84 740 UHE2A101MHD6 0.08 120 0.15 0.71 740 UHE2A121MPD 120 100 (2A) Case Size φD×L(mm) 10× 31.5 120 12.5× 20 0.08 120 0.16 0.64 765 UHE2A121MHD6 150 16× 15 0.08 150 0.14 0.66 895 UHE2A151MHD 180 12.5×25 0.08 180 0.12 0.45 875 UHE2A181MHD 180 18× 15 0.08 180 0.12 0.50 1030 UHE2A181MHD6 220 12.5× 31.5 0.08 220 0.10 0.42 1010 UHE2A221MHD 220 16× 20 0.08 220 0.091 0.38 1130 UHE2A221MHD6 270 12.5× 35.5 0.08 270 0.083 0.35 1140 UHE2A271MHD 270 16× 25 0.08 270 0.073 0.27 1350 UHE2A271MHD6 330 12.5× 40 0.08 330 0.071 0.30 1280 UHE2A331MHD 330 18× 20 0.08 330 0.080 0.30 1300 UHE2A331MHD6 390 16× 31.5 0.08 390 0.054 0.20 1650 UHE2A391MHD 390 18 ×25 0.08 390 0.057 0.21 1560 UHE2A391MHD6 470 16 ×35.5 0.08 470 0.045 0.17 1900 UHE2A471MHD 470 18 ×31.5 0.08 470 0.047 0.17 1720 UHE2A471MHD6 560 16 ×40 0.08 560 0.040 0.15 2130 UHE2A561MHD 680 18 ×35.5 0.08 680 0.040 0.15 1890 UHE2A681MHD 820 18 ×40 0.08 820 0.036 0.13 2470 UHE2A821MHD For cut leads, formed leads or taped parts, please add the appropriate code after the size code (12th digit ). If there is no size code in the part number, please add size code “1” and then add the appropriate code. For formed lead or taped product specifications and minimum order quantity, please refer to the Guidelines for Aluminum Electrolytic Capacitors. CAT.8100K
UHE1A152MPD
物料型号:nichicon UHE系列铝电解电容器
器件简介:这是一款小型化、低阻抗、高可靠性的铝电解电容器,能够承受4000到10000小时的工作时长,符合RoHS指令要求。
引脚分配:文档中未明确提供引脚分配信息,但提供了径向引线类型的型编号系统示例,例如10V 1000μF的电容器。
参数特性: - 工作温度范围:-40至+105°C - 额定电压范围:6.3至100V - 额定电容范围:2.2至18000μF - 电容公差:在120Hz、20°C时为+20% - 漏电流:在20°C下,额定电压施加2分钟后,漏电流不超过0.01CV或3μA(取较大者)
功能详解:电容器在105°C下施加直流偏置和额定纹波电流后,恢复至20°C时,峰值电压不应超过额定电压。电容器的容量变化在初始电容值的25%以内,损耗角的正切值不超过初始规定值的200%,漏电流不超过初始规定值。
应用信息:文档中未提供具体的应用信息,但根据其特性,这类电容器通常用于电源滤波、信号耦合等场合。
封装信息:提供了详细的尺寸表,包括额定电压、额定电容、外壳尺寸、损耗角的正切值、漏电流、阻抗比、额定纹波电流等参数,以及部件编号。
UHE1A152MPD 价格&库存
很抱歉,暂时无法提供与“UHE1A152MPD”相匹配的价格&库存,您可以联系我们找货
UHE1A152MPD
  • 1+8.193611+1.06147
  • 10+5.1633610+0.66891
  • 50+3.8982050+0.50501
  • 100+3.49907100+0.45330
  • 500+2.81038500+0.36408
  • 1200+2.542591200+0.32939
  • 3600+2.283893600+0.29588
  • 6000+2.187216000+0.28335
库存:1046
UHE1A152MPD
    • 5+6.945425+0.90607
    • 10+2.8338010+0.36968
    • 50+2.7468750+0.35834
    • 100+2.67733100+0.34927
    库存:786
