ALUMINUM ELECTROLYTIC CAPACITORS
UHE
Miniature Sized, Low Impedance,
High Reliability
Approved by Reliability Center for Electronic
Component, Japan-Certification No. RCJ-03-23C
Low impedance and high reliability withstanding 4000 hours to 10000 hours.
Compliant to the RoHS directive (2011/65/EU,(EU)2015/863).
UHE
UHD
Long Life
Specifications
Performance Characteristics
ltem
Category Temperature Range
–40 to +105˚C
Rated Voltage Range
6.3 to 100V
Rated Capacitance Range
2.2 to 18000µF
Capacitance Tolerance
± 20% at 120Hz, 20˚C
Leakage Current
After 2 minutes' application of rated voltage at 20°C, leakage current is not more than 0.01CV or 3 (µA), whichever is greater.
Rated voltage (V)
6.3
10
16
25
35
50
63
100
120Hz
tan δ (MAX.)
0.22
0.19
0.16
0.14
0.12
0.10
0.09
0.08
20˚C
120Hz
Tangent of loss angle (tan δ)
For capacitance of more than 1000µF, add 0.02 for every increase of 1000µF.
Rated voltage (V)
Stability at Low Temperature
Impedance ratio
(MAX.)
6.3
10
16
25
35
50
63
100
Z–25˚C / Z+20˚C
4
3
2
2
2
2
2
2
Z–40˚C / Z+20˚C
8
6
4
3
3
3
3
3
The following specifications shall be met when the capacitors are restored to 20˚C after D.C. bias plus rated ripple current is
applied at 105˚C , the peak voltage shall not exceed the rated voltage.
φD <
= 6.3
φD = 8 , 10
6.3 to 10V
4000 hours
6000 hours
8000 hours
16 to 100V
5000 hours
7000 hours
10000 hours
Case size
Rated voltage
Endurance
φD >
= 12.5
Capacitance change
Within ± 25% of the initial capacitance value
tan δ
200% or less than the initial specified value
Leakage current
Less than or equal to the initial specified value
Printed with white color letter on black sleeve.
Marking
Radial Lead Type
Type numbering system (Example : 10V 1000µF)
φd
Sleeve (P.E.T.)
1
2
3
4
5
6
7
8
9
10 11
12
U HE 1 A 1 0 2 M PD
P±0.5
φD+0.5 MAX.
Size code
Configuration
Capacitance tolerance ( ±20%)
L+
15MIN
MAX.
Rated capacitance (1000µF)
4MIN
Rated voltage (10V)
Pressurerelief vent
(φ6.3up)
Series name
(mm)
(L < 20) 1.5
(L 20) 2.0
φD
5
6.3
8
10
12.5
16
18
P
2.0
2.5
3.5
5.0
5.0
7.5
7.5
φd
0.5
0.5
0.6
0.6
0.6
0.8
0.8
Type
Configuration
φD
In case L > 25 for the φ12.5 dia. unit, lead dia. φd = 0.8mm
Please refer to the Guidelines for Aluminum Electrolytic Capacitors
for end seal configuration information.
Pb-free leadwire
Pb-free PET sleeve
5
DD
6.3
8 · 10
12.5 to 18
ED
PD
HD
Frequency coefficient of rated ripple current
Frequency
50Hz
120Hz
300Hz
1kHz
10kHz or more
2.2 to 33
0.45
0.55
0.70
0.90
1.00
39 to 330
0.60
0.70
0.85
0.95
1.00
390 to 1000
0.65
0.75
0.90
0.98
1.00
1200 to 18000
0.75
0.80
0.95
1.00
1.00
Cap. (µF)
Dimension table in next page.
CAT.8100K
UHE
Dimensions
Rated Voltage
(V)
(code)
6.3
(0J)
10
(1A)
Rated
Capacitance
(µF)
Case Size
φD×L(mm)
tan δ
150
5× 11
0.22
330
6.3×11
0.22
Leakage Current
(µA)
at 20℃ after
2 minutes
Impedance(Ω)
MAX.
Rated Ripple
(mArms)
(105℃/100kHz)
Part Number
20℃/
100kHz
-10℃/
100kHz
9.45
0.58
2.30
210
UHE0J151MDD
20.79
0.22
0.87
340
UHE0J331MED
680
8× 11.5
0.22
42.84
0.13
0.52
640
UHE0J681MPD
820
10× 12.5
0.22
51.66
0.080
0.32
865
UHE0J821MPD
1000
8× 15
0.22
63
0.087
0.35
840
UHE0J102MPD
1200
8× 20
0.22
75.6
0.069
0.27
1050
UHE0J122MPD
1200
10× 16
0.22
75.6
0.060
0.24
1210
UHE0J122MPD6
1500
10× 20
0.22
94.5
0.046
0.18
1400
UHE0J152MPD
1800
12.5× 15
0.22
113.4
0.049
0.16
1450
UHE0J182MHD
2200
10× 25
0.24
138.6
0.042
0.17
1650
UHE0J222MPD
2700
10× 31.5
0.24
170.1
0.031
0.12
1910
UHE0J272MPD6
2700
16× 15
0.24
170.1
0.042
0.12
1940
UHE0J272MHD
3300
12.5× 20
0.26
207.9
0.035
0.12
1900
UHE0J332MHD
3900
12.5× 25
0.26
245.7
0.027
0.089
2230
UHE0J392MHD
3900
18× 15
0.26
245.7
0.043
0.11
2210
UHE0J392MHD6
4700
12.5× 31.5
0.28
296.1
0.024
0.078
2650
UHE0J472MHD
5600
12.5× 35.5
0.30
352.8
0.020
0.065
2880
UHE0J562MHD
5600
16× 20
0.30
352.8
0.027
0.078
2530
UHE0J562MHD6
6800
12.5× 40
0.32
428.4
0.017
0.056
3350
UHE0J682MHD
6800
16× 25
0.32
428.4
0.021
0.060
2930
UHE0J682MHD6
6800
18× 20
0.32
428.4
0.026
0.067
2860
UHE0J682MHD3
8200
16× 31.5
0.36
516.6
0.017
0.050
3450
UHE0J822MHD
10000
16× 35.5
0.40
630
0.015
0.044
3610
UHE0J103MHD
10000
18× 25
0.40
630
0.019
0.049
3140
UHE0J103MHD6
12000
16× 40
0.44
756
0.013
0.038
4080
UHE0J123MHD
12000
18× 31.5
0.44
756
0.015
0.040
4170
UHE0J123MHD6
15000
18× 35.5
0.50
945
0.014
0.038
4220
UHE0J153MHD
18000
18× 40
0.56
1134
0.012
0.032
4280
UHE0J183MHD
100
5× 11
0.19
10
0.58
2.30
210
UHE1A101MDD
220
6.3× 11
0.19
22
0.22
0.87
340
UHE1A221MED
470
8× 11.5
0.19
47
0.13
0.52
640
UHE1A471MPD
680
8× 15
0.19
68
0.087
0.35
840
UHE1A681MPD
680
10× 12.5
0.19
68
0.080
0.32
865
UHE1A681MPD6
1000
8× 20
0.19
100
0.069
0.27
1050
UHE1A102MPD
1000
10× 16
0.19
100
0.060
0.24
1210
UHE1A102MPD6
1200
10× 20
0.19
120
0.046
0.18
1400
UHE1A122MPD
1500
10× 25
0.19
150
0.042
0.17
1650
UHE1A152MPD
1500
12.5×15
0.19
150
0.049
0.16
1450
UHE1A152MHD6
2200
0.21
220
0.031
0.12
1910
UHE1A222MPD
2200
12.5×20
10 ×31.5
0.21
220
0.035
0.12
1900
UHE1A222MHD6
2200
16 ×15
0.21
220
0.042
0.12
1940
UHE1A222MHD3
2700
18 ×15
0.21
270
0.043
0.11
2210
UHE1A272MHD
3300
12.5×25
0.23
330
0.027
0.089
2230
UHE1A332MHD
3900
12.5× 31.5
0.23
390
0.024
0.078
2650
UHE1A392MHD
UHE1A392MHD6
3900
16 × 20
0.23
390
0.027
0.078
2530
4700
12.5× 35.5
0.25
470
0.020
0.065
2880
UHE1A472MHD
5600
12.5× 40
0.27
560
0.017
0.056
3350
UHE1A562MHD
5600
16× 25
0.27
560
0.021
0.060
2930
UHE1A562MHD6
For cut leads, formed leads or taped parts, please add the appropriate code after the size code (12th digit ).
If there is no size code in the part number, please add size code “1” and then add the appropriate code.
CAT.8100K
UHE
Dimensions
Rated Voltage
(V)
(code)
10
(1A)
16
(1C)
25
(1E)
Rated
Capacitance
(µF)
Case Size
φD×L(mm)
tan δ
Leakage Current
(µA)
at 20℃ after
2 minutes
Impedance(Ω)
MAX.
20℃/
100kHz
-10℃/
100kHz
Rated Ripple
(mArms)
(105℃/100kHz)
Part Number
5600
18× 20
0.27
560
0.026
0.067
2860
UHE1A562MHD3
6800
16× 31.5
0.29
680
0.017
0.050
3450
UHE1A682MHD
6800
18× 25
0.29
680
0.019
0.049
3140
UHE1A682MHD6
8200
16× 35.5
0.33
820
0.015
0.044
3610
UHE1A822MHD
8200
18× 31.5
0.33
820
0.015
0.040
4170
UHE1A822MHD6
10000
16× 40
0.37
1000
0.013
0.038
4080
UHE1A103MHD
10000
18× 35.5
0.37
1000
0.014
0.038
4220
UHE1A103MHD6
12000
18× 40
0.41
1200
0.012
0.032
4280
UHE1A123MHD
56
5× 11
0.16
0.58
2.30
210
UHE1C560MDD
120
6.3×11
0.16
19.2
0.22
0.87
340
UHE1C121MED
8.96
330
8× 11.5
0.16
52.8
0.13
0.52
640
UHE1C331MPD
470
8× 15
0.16
75.2
0.087
0.35
840
UHE1C471MPD
470
10× 12.5
0.16
75.2
0.080
0.32
865
UHE1C471MPD6
680
8× 20
0.16
108.8
0.069
0.27
1050
UHE1C681MPD
680
10× 16
0.16
108.8
0.060
0.24
1210
UHE1C681MPD6
1000
10× 20
0.16
160
0.046
0.18
1400
UHE1C102MPD
1000
12.5× 15
0.16
160
0.049
0.16
1450
UHE1C102MHD6
1200
10× 25
0.16
192
0.042
0.17
1650
UHE1C122MPD
1500
10× 31.5
0.16
240
0.031
0.12
1910
UHE1C152MPD
1500
12.5× 20
0.16
240
0.035
0.12
1900
UHE1C152MHD6
1500
16× 15
0.16
240
0.042
0.12
1940
UHE1C152MHD3
2200
12.5× 25
0.18
352
0.027
0.089
2230
UHE1C222MHD
2200
18× 15
0.18
352
0.043
0.11
2210
UHE1C222MHD6
2700
12.5× 31.5
0.18
432
0.024
0.078
2650
UHE1C272MHD
2700
16× 20
0.18
432
0.027
0.078
2530
UHE1C272MHD6
3300
12.5× 35.5
0.20
528
0.020
0.065
2880
UHE1C332MHD
3900
12.5× 40
0.20
624
0.017
0.056
3350
UHE1C392MHD
3900
16× 25
0.20
624
0.021
0.060
2930
UHE1C392MHD6
3900
16× 20
0.20
624
0.026
0.067
2860
UHE1C392MHD3
4700
16× 31.5
0.22
752
0.017
0.050
3450
UHE1C472MHD
4700
18× 25
0.22
752
0.019
0.049
3140
UHE1C472MHD6
5600
16× 35.5
0.24
896
0.015
0.044
3610
UHE1C562MHD
5600
18× 31.5
0.24
896
0.015
0.040
4170
UHE1C562MHD6
6800
16× 40
0.26
1088
0.013
0.038
4080
UHE1C682MHD
8200
18× 35.5
0.30
1312
0.014
0.038
4220
UHE1C822MHD
1600
10000
18× 40
0.34
0.012
0.032
4280
UHE1C103MHD
47
5× 11
0.14
11.75
0.58
2.30
210
UHE1E470MDD
100
6.3× 11
0.14
25
0.22
0.87
340
UHE1E101MED
220
8× 11.5
0.14
55
0.13
0.52
640
UHE1E221MPD
330
8× 15
0.14
82.5
0.087
0.35
840
UHE1E331MPD
330
10× 12.5
0.14
82.5
0.080
0.32
865
UHE1E331MPD6
470
8× 20
0.14
117.5
0.069
0.27
1050
UHE1E471MPD
470
10× 16
0.14
117.5
0.060
0.24
1210
UHE1E471MPD6
680
10× 20
0.14
170
0.046
0.18
1400
UHE1E681MPD
680
12.5× 15
0.14
170
0.049
0.16
1450
UHE1E681MHD6
820
10× 25
0.14
205
0.042
0.17
1650
UHE1E821MPD
10× 31.5
0.14
250
0.031
0.12
1910
UHE1E102MPD
0.14
250
0.035
0.12
1900
UHE1E102MHD6
1000
1000
12.5× 20
CAT.8100K
UHE
Dimensions
Rated Voltage
(V)
(code)
25
(1E)
Rated
Capacitance
(µF)
50
(1H)
tan δ
Leakage Current
(µA)
at 20℃ after
2 minutes
Impedance(Ω)
MAX.
20℃/
100kHz
-10℃/
100kHz
Rated Ripple
(mArms)
(105℃/100kHz)
Part Number
1000
16× 15
0.14
250
0.042
0.12
1940
UHE1E102MHD3
1200
18× 15
0.14
300
0.043
0.11
2210
UHE1E122MHD
1500
12.5× 25
0.14
375
0.027
0.089
2230
UHE1E152MHD
1800
12.5× 31.5
0.14
450
0.024
0.078
2650
UHE1E182MHD
1800
16× 20
0.14
450
0.027
0.078
2530
UHE1E182MHD6
2200
12.5× 35.5
0.16
550
0.020
0.065
2880
UHE1E222MHD
2200
18× 20
0.16
550
0.026
0.067
2860
UHE1E222MHD6
2700
12.5× 40
0.16
675
0.017
0.056
3350
UHE1E272MHD
2700
16× 25
0.16
675
0.021
0.060
2930
UHE1E272MHD6
3300
16× 31.5
0.18
825
0.017
0.050
3450
UHE1E332MHD
3300
18× 25
0.18
825
0.019
0.049
3140
UHE1E332MHD6
3900
16× 35.5
0.18
975
0.015
0.044
3610
UHE1E392MHD
3900
18× 31.5
0.18
975
0.015
0.040
4170
UHE1E392MHD6
4700
16× 40
0.20
1175
0.013
0.038
4080
UHE1E472MHD
4700
18× 35.5
0.20
1175
0.014
0.038
4220
UHE1E472MHD6
5600
18× 40
0.22
1400
0.012
0.032
4280
UHE1E562MHD
33
5× 11
0.12
0.58
2.30
210
UHE1V330MDD
11.55
47
6.3×11
0.12
16.45
0.22
0.87
250
UHE1V470MED
56
6.3×11
0.12
19.6
0.22
0.87
340
UHE1V560MED
100
8× 11.5
0.12
35
0.13
0.52
640
UHE1V101MPD
150
8× 11.5
0.12
52.5
0.13
0.52
640
UHE1V151MPD
220
8× 15
0.12
77
0.087
0.35
840
UHE1V221MPD
220
10× 12.5
0.12
77
0.080
0.32
865
UHE1V221MPD6
270
8× 20
0.12
94.5
0.069
0.27
1050
UHE1V271MPD
330
10× 16
0.12
115.5
0.060
0.24
1210
UHE1V331MPD
UHE1V471MPD
470
10× 20
0.12
164.5
0.046
0.18
1400
470
12.5×15
0.12
164.5
0.049
0.16
1450
UHE1V471MHD6
560
10× 25
0.12
196
0.042
0.17
1650
UHE1V561MPD
10× 31.5
680
35
(1V)
Case Size
φD×L(mm)
0.12
238
0.031
0.12
1910
UHE1V681MPD
680
12.5× 20
0.12
238
0.035
0.12
1900
UHE1V681MHD6
680
16× 15
0.12
238
0.042
0.12
1940
UHE1V681MHD3
1000
12.5× 25
0.12
350
0.027
0.089
2230
UHE1V102MHD
1000
18× 15
0.12
350
0.043
0.11
2210
UHE1V102MHD6
1200
12.5× 31.5
0.12
420
0.024
0.078
2650
UHE1V122MHD
1200
16× 20
0.12
420
0.027
0.078
2530
UHE1V122MHD6
1500
12.5× 35.5
0.12
525
0.020
0.065
2880
UHE1V152MHD
1800
12.5× 40
0.12
630
0.017
0.056
3350
UHE1V182MHD
1800
16 ×25
0.12
630
0.021
0.060
2930
UHE1V182MHD6
1800
18 ×20
0.12
630
0.026
0.067
2860
UHE1V182MHD3
2200
16 ×31.5
0.14
770
0.017
0.050
3450
UHE1V222MHD
2200
18 ×25
0.14
770
0.019
0.049
3140
UHE1V222MHD6
2700
16 ×35.5
0.14
945
0.015
0.044
3610
UHE1V272MHD
2700
18 ×31.5
0.14
945
0.015
0.040
4170
UHE1V272MHD6
3300
16 ×40
0.16
1155
0.013
0.038
4080
UHE1V332MHD
3300
18 ×35.5
0.16
1155
0.014
0.038
4220
UHE1V332MHD6
3900
18 ×40
0.16
1365
0.012
0.032
4280
UHE1V392MHD
2.2
5×11
0.10
3
2.50
10.00
43
UHE1H2R2MDD
3.3
5×11
0.10
3
2.20
8.80
53
UHE1H3R3MDD
CAT.8100K
UHE
Dimensions
Rated Voltage
(V)
(code)
Rated
Capacitance
(µF)
4.7
10
63
(1J)
tan δ
Leakage Current
(µA)
at 20℃ after
2 minutes
Impedance(Ω)
MAX.
20℃/
100kHz
-10℃/
100kHz
Rated Ripple
(mArms)
(105℃/100kHz)
Part Number
5× 11
0.10
3
1.90
7.60
88
UHE1H4R7MDD
5× 11
0.10
5
1.50
6.00
100
UHE1H100MDD
22
5× 11
0.10
11
0.70
2.80
180
UHE1H220MDD
33
6.3× 11
0.10
16.5
0.30
1.20
295
UHE1H330MED
47
6.3× 11
0.10
23.5
0.30
1.20
295
UHE1H470MED
56
6.3× 11
0.10
28
0.30
1.20
295
UHE1H560MED
8× 11.5
0.10
50
0.17
0.68
555
UHE1H101MPD
120
8× 15
0.10
60
0.12
0.48
730
UHE1H121MPD
150
10× 12.5
0.10
75
0.12
0.48
760
UHE1H151MPD
180
8× 20
0.10
90
0.091
0.36
910
UHE1H181MPD
220
10× 16
0.10
110
0.084
0.34
1050
UHE1H221MPD
270
10× 20
0.10
135
0.060
0.24
1220
UHE1H271MPD
270
12.5× 15
0.10
135
0.061
0.20
1260
UHE1H271MHD6
330
10× 25
0.10
165
0.055
0.22
1440
UHE1H331MPD
330
10× 20
0.10
165
0.060
0.24
1220
UHE1H331MPD6
470
10× 31.5
0.10
235
0.043
0.17
1690
UHE1H471MPD
100
50
(1H)
Case Size
φD×L(mm)
470
12.5×20
0.10
235
0.045
0.15
1660
UHE1H471MHD6
470
16× 15
0.10
235
0.055
0.17
1690
UHE1H471MHD3
560
12.5× 25
0.10
280
0.034
0.11
1950
UHE1H561MHD
560
18× 15
0.10
280
0.054
0.15
1930
UHE1H561MHD6
680
12.5× 31.5
0.10
340
0.030
0.10
2310
UHE1H681MHD
820
12.5× 35.5
0.10
410
0.025
0.083
2510
UHE1H821MHD
820
16× 20
0.10
410
0.034
0.10
2210
UHE1H821MHD6
1000
12.5× 40
0.10
500
0.021
0.069
2920
UHE1H102MHD
1000
16× 25
0.10
500
0.025
0.075
2555
UHE1H102MHD6
1000
18× 20
0.10
500
0.036
0.097
2490
UHE1H102MHD3
1200
16× 31.5
0.10
600
0.022
0.066
3010
UHE1H122MHD
1200
18× 25
0.10
600
0.026
0.070
2740
UHE1H122MHD6
1500
16× 35.5
0.10
750
0.019
0.057
3150
UHE1H152MHD
1800
16× 40
0.10
900
0.016
0.048
3710
UHE1H182MHD
1800
18× 31.5
0.10
900
0.021
0.057
3635
UHE1H182MHD6
2200
18× 35.5
0.12
1100
0.017
0.046
3680
UHE1H222MHD6
2700
18× 40
0.12
1350
0.014
0.038
3800
UHE1H272MHD
15
5× 11
0.09
9.45
2.30
9.30
62
UHE1J150MDD
33
6.3× 11
0.09
20.79
1.20
5.00
126
UHE1J330MED
UHE1J470MPD
47
8×11.5
0.09
29.61
0.63
2.80
260
56
8× 11.5
0.09
35.28
0.63
2.80
260
UHE1J560MPD
82
8×15
0.09
51.66
0.45
2.10
335
UHE1J820MPD
82
10 ×12.5
0.09
51.66
0.43
1.80
325
UHE1J820MPD6
120
8×20
0.09
75.6
0.33
1.60
408
UHE1J121MPD
120
10 ×16
0.09
75.6
0.31
1.50
400
UHE1J121MPD6
180
10 ×20
0.09
113.4
0.21
0.94
518
UHE1J181MPD
180
12.5×15
0.09
113.4
0.23
1.10
527
UHE1J181MHD6
220
10 ×25
0.09
138.6
0.20
0.84
595
UHE1J221MPD
270
10 ×31.5
0.09
170.1
0.15
0.71
740
UHE1J271MPD
270
12.5×20
0.09
170.1
0.16
0.64
765
UHE1J271MHD6
270
16 ×15
0.09
170.1
0.14
0.66
895
UHE1J271MHD3
330
12.5×25
0.09
207.9
0.12
0.45
875
UHE1J331MHD
CAT.8100K
UHE
Dimensions
Rated Voltage
(V)
(code)
63
(1J)
Rated
Capacitance
(µF)
tan δ
Impedance(Ω)
MAX.
Leakage Current
(µA)
at 20℃ after
2 minutes
20℃/
100kHz
-10℃/
100kHz
Rated Ripple
(mArms)
(105℃/100kHz)
Part Number
390
18× 15
0.09
245.7
0.12
0.50
1030
UHE1J391MHD
470
12.5× 31.5
0.09
296.1
0.10
0.42
1010
UHE1J471MHD
470
16×20
0.09
296.1
0.091
0.38
1130
UHE1J471MHD6
560
12.5× 35.5
0.09
352.8
0.083
0.35
1140
UHE1J561MHD
560
16× 25
0.09
352.8
0.073
0.27
1350
UHE1J561MHD6
680
12.5× 40
0.09
428.4
0.071
0.30
1280
UHE1J681MHD
680
18× 20
0.09
428.4
0.080
0.30
1300
UHE1J681MHD6
820
16× 31.5
0.09
516.6
0.054
0.20
1650
UHE1J821MHD
820
18× 25
0.09
516.6
0.057
0.21
1560
UHE1J821MHD6
1000
16× 35.5
0.09
630
0.045
0.17
1900
UHE1J102MHD
1000
18× 31.5
0.09
630
0.047
0.17
1720
UHE1J102MHD6
1200
16× 40
0.09
756
0.040
0.15
2130
UHE1J122MHD
1200
18× 35.5
0.09
756
0.040
0.15
1890
UHE1J122MHD6
1500
18× 40
0.09
945
0.036
0.13
2470
UHE1J152MHD
6.8
15
5× 11
0.08
6.3×11
0.08
6.8
15
2.30
9.30
62
UHE2A6R8MDD
1.20
5.00
126
UHE2A150MED
27
8× 11.5
0.08
27
0.63
2.80
260
UHE2A270MPD
39
8× 15
0.08
39
0.45
2.10
335
UHE2A390MPD
47
10× 12.5
0.08
47
0.43
1.80
325
UHE2A470MPD
56
8×20
0.08
56
0.33
1.60
408
UHE2A560MPD
68
10× 16
0.08
68
0.31
1.50
400
UHE2A680MPD
82
10× 20
0.08
82
0.21
0.94
518
UHE2A820MPD
82
12.5× 15
0.08
82
0.23
1.10
527
UHE2A820MHD6
100
10× 25
0.08
100
0.20
0.84
595
UHE2A101MPD
100
12.5× 20
0.08
100
0.20
0.84
740
UHE2A101MHD6
0.08
120
0.15
0.71
740
UHE2A121MPD
120
100
(2A)
Case Size
φD×L(mm)
10× 31.5
120
12.5× 20
0.08
120
0.16
0.64
765
UHE2A121MHD6
150
16× 15
0.08
150
0.14
0.66
895
UHE2A151MHD
180
12.5×25
0.08
180
0.12
0.45
875
UHE2A181MHD
180
18× 15
0.08
180
0.12
0.50
1030
UHE2A181MHD6
220
12.5× 31.5
0.08
220
0.10
0.42
1010
UHE2A221MHD
220
16× 20
0.08
220
0.091
0.38
1130
UHE2A221MHD6
270
12.5× 35.5
0.08
270
0.083
0.35
1140
UHE2A271MHD
270
16× 25
0.08
270
0.073
0.27
1350
UHE2A271MHD6
330
12.5× 40
0.08
330
0.071
0.30
1280
UHE2A331MHD
330
18× 20
0.08
330
0.080
0.30
1300
UHE2A331MHD6
390
16× 31.5
0.08
390
0.054
0.20
1650
UHE2A391MHD
390
18 ×25
0.08
390
0.057
0.21
1560
UHE2A391MHD6
470
16 ×35.5
0.08
470
0.045
0.17
1900
UHE2A471MHD
470
18 ×31.5
0.08
470
0.047
0.17
1720
UHE2A471MHD6
560
16 ×40
0.08
560
0.040
0.15
2130
UHE2A561MHD
680
18 ×35.5
0.08
680
0.040
0.15
1890
UHE2A681MHD
820
18 ×40
0.08
820
0.036
0.13
2470
UHE2A821MHD
For formed lead or taped product specifications and minimum order quantity,
please refer to the Guidelines for Aluminum Electrolytic Capacitors.
CAT.8100K
很抱歉,暂时无法提供与“UHE2A121MPD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+5.26541
- 10+4.23694
- 50+3.71831
- 100+3.27000
- 200+3.12936
- 500+2.95355
- 1000+2.80412
- 国内价格 香港价格
- 50+1.7803750+0.21494
- 150+1.77205150+0.21394
- 500+1.77201500+0.21393
- 1500+1.771971500+0.21393
- 5000+1.771935000+0.21392
