ALUMINUM ELECTROLYTIC CAPACITORS
Miniature Sized, Low Impedance,
High Reliability
UHE
Approved by Reliability Center for Electronic
Component, Japan-Certification No. RCJ-03-23C
Low impedance and high reliability withstanding 4000 hours to 10000 hours.
Compliant to the RoHS directive (2011/65/EU).
Values marked with an in the dimension table
are scheduled to be discontinued and are not
recommended for new designs.
UHE
UHD
Long Life
Specifications
Performance Characteristics
ltem
Category Temperature Range
–40 to +105˚C
Rated Voltage Range
6.3 to 100V
Rated Capacitance Range
0.47 to 18000µF
Capacitance Tolerance
± 20% at 120Hz, 20˚C
Leakage Current
After 2 minutes' application of rated voltage at 20°C, leakage current is not more than 0.01CV or 3 (µA), whichever is greater.
Rated voltage (V)
6.3
10
16
25
35
50
63
100
120Hz
tan δ (MAX.)
0.22
0.19
0.16
0.14
0.12
0.10
0.09
0.08
20˚C
120Hz
Tangent of loss angle (tan δ)
For capacitance of more than 1000µF, add 0.02 for every increase of 1000µF.
6.3
10
16
25
35
50
63
100
Z–25˚C / Z+20˚C
4
3
2
2
2
2
2
2
Z–40˚C / Z+20˚C
8
6
4
3
3
3
3
3
Rated voltage (V)
Stability at Low Temperature
Impedance ratio
ZT / Z20 (MAX.)
The following specifications shall be met when the capacitors are restored to 20˚C after D.C. bias plus rated ripple current is
applied at 105˚C , the peak voltage shall not exceed the rated voltage.
φD <
= 6.3
φD = 8 , 10
6.3 to 10WV
4000 hours
6000 hours
8000 hours
16 to 100WV
5000 hours
7000 hours
10000 hours
Case size
Rated voltage
(V)
Endurance
φD >
= 12.5
Capacitance change
Within ± 25% of the initial capacitance value
tan δ
200% or less than the initial specified value
Leakage current
Less than or equal to the initial specified value
Printed with white color letter on black sleeve.
Marking
Radial Lead Type
Type numbering system (Example : 10V 1000µF)
φd
1
Sleeve (P.E.T.)
2
3
4
5
6
7
8
9
10 11
12
U HE 1 A 1 0 2 M PD
P±0.5
φD+0.5 MAX.
Size code
Configuration
Capacitance tolerance ( ±20%)
L+
Rated capacitance (1000µF)
15MIN
MAX.
4MIN
Rated voltage (10V)
Pressurerelief vent
(φ6.3up)
Series name
(mm)
(L < 20) 1.5
(L 20) 2.0
φD
5
6.3
8
10
12.5
16
18
P
2.0
2.5
3.5
5.0
5.0
7.5
7.5
φd
0.5
0.5
0.6
0.6
0.6
0.8
0.8
Type
Configuration
φD
In case L > 25 for the φ12.5 dia. unit, lead dia. φd = 0.8mm
• Please refer to page 20 about the end seal configuration.
Frequency coefficient of rated ripple current
Frequency
50Hz
120Hz
300Hz
1kHz
10kHz or more
0.45
0.55
0.70
0.90
1.00
39 to 330
0.60
0.70
0.85
0.95
1.00
390 to 1000
0.65
0.75
0.90
0.98
1.00
1200 to 18000
0.75
0.80
0.95
1.00
1.00
Cap. (µF)
0.47 to 33
Pb-free leadwire
Pb-free PET sleeve
5
DD
6.3
8 · 10
12.5 to 18
ED
PD
HD
Please refer to page 20, 21, 22 about the formed or taped product spec.
Please refer to page 4 for the minimum order quantity.
Dimension table in next page.
215
CAT.8100F
UHE
Standard Ratings
V (Code)
Item
Cap.(µF)
Code
100
101
150
151
220
221
330
331
470
471
680
681
6.3 (0J)
Case size
φD × L
(mm)
5 × 11
6.3 × 11
8 × 11.5
10 (1A)
Rated ripple
Impedance (Ω) MAX.
(mArms)
20˚C / 100kHz –10˚C / 100kHz 105˚C / 100kHz
0.58
0.22
0.13
2.3
0.87
0.52
640
10 × 12.5
0.080
0.32
865
1000
102
8 × 15
0.087
0.35
840
8 × 20
0.069
0.27
1050
10 × 16
0.060
0.24
1210
10 × 20
0.046
0.18
1400
122
152
5 × 11
0.58
2.3
210
6.3 × 11
0.22
0.87
340
8 × 11.5
0.13
0.52
640
8 × 15
0.087
0.35
840
10 × 12.5
0.080
0.32
865
8 × 20
0.069
0.27
1050
10 × 16
0.060
0.24
1210
10 × 20
0.046
0.18
1400
10 × 25
0.042
0.17
1650
12.5 × 15
0.049
0.16
1450
340
821
1500
1800
182
12.5 × 15
0.049
0.16
1450
2200
222
10 × 25
0.042
0.17
1650
0.031
0.12
1910
12.5 × 20
0.035
0.12
1900
16 × 15
0.042
0.12
1940
18 × 15
0.043
0.11
2210
10 × 31.5
2700
332
3900
392
4700
5600
6800
8200
10000
12000
10 × 31.5
0.031
0.12
1910
16 × 15
0.042
0.12
1940
12.5 × 20
0.035
0.12
1900
12.5 × 25
0.027
0.089
2230
12.5 × 25
0.027
0.089
2230
12.5 × 31.5
0.024
0.078
2650
18 × 15
0.043
0.11
2210
16 × 20
0.027
0.078
2530
12.5 × 31.5
0.024
0.078
2650
12.5 × 35.5
0.020
0.065
2880
12.5 × 35.5
0.020
0.065
2880
12.5 × 40
0.017
0.056
3350
0.060
2930
0.027
0.078
2530
16 × 25
0.021
16 × 20
18 × 20
0.026
0.067
2860
16 × 31.5
0.017
0.050
3450
18 × 25
0.019
0.049
3140
16 × 35.5
0.015
0.044
3610
272
3300
472
562
682
822
Rated ripple
(mArms)
Impedance (Ω) MAX.
210
820
1200
Case size
φD × L
(mm)
12.5 × 40
0.017
0.056
3350
16 × 25
0.021
0.060
2930
18 × 20
0.026
0.067
2860
16 × 31.5
0.017
0.050
3450
18 × 31.5
0.015
0.040
4170
16 × 35.5
0.015
0.044
3610
16 × 40
0.013
0.038
4080
18 × 25
0.019
0.049
3140
18 × 35.5
0.014
0.038
4220
16 × 40
0.013
0.038
4080
18 × 40
0.012
0.032
4280
18 × 31.5
0.015
0.040
4170
103
123
15000
153
18 × 35.5
0.014
0.038
4220
18000
183
18 × 40
0.012
0.032
4280
: In this case, 6 will be put at 12th digit of type numbering system.
: In this case, 3 will be put at 12th digit of type numbering system.
216
CAT.8100F
UHE
Standard Ratings
V (Code)
Item
Cap.(µF)
Code
47
470
56
560
100
101
120
121
220
221
330
331
470
680
820
1000
1200
1500
1800
2200
2700
3300
3900
4700
5600
16 (1C)
Case size
φD × L
(mm)
5 × 11
6.3 × 11
8 × 11.5
25 (1E)
Rated ripple
Impedance (Ω) MAX.
(mArms)
0.58
0.22
0.13
2.3
0.87
0.52
Case size
φD × L
(mm)
Rated ripple
(mArms)
Impedance (Ω) MAX.
5 × 11
0.58
2.3
210
6.3 × 11
0.22
0.87
340
8 × 11.5
0.13
0.52
640
8 × 15
0.087
0.35
840
10 × 12.5
0.080
0.32
865
210
340
640
8 × 15
0.087
0.35
840
8 × 20
0.069
0.27
1050
10 × 12.5
0.080
0.32
865
10 × 16
0.06
0.24
1210
8 × 20
0.069
0.27
1050
10 × 20
0.046
0.18
1400
10 × 16
0.060
0.24
1210
12.5 × 15
0.049
0.16
1450
10 × 25
0.042
0.17
1650
10 × 20
0.046
0.18
1400
10 × 31.5
0.031
0.12
1910
12.5 × 20
0.035
0.12
1900
12.5 × 15
0.049
0.16
1450
16 × 15
0.042
0.12
1940
18 × 15
0.043
0.11
2210
12.5 × 25
0.027
0.089
2230
12.5 × 31.5
0.024
0.078
2650
16 × 20
0.027
0.078
2530
471
681
821
102
122
152
10 × 25
0.042
0.17
1650
10 × 31.5
0.031
0.12
1910
12.5 × 20
0.035
0.12
1900
16 × 15
0.042
0.12
1940
182
12.5 × 25
0.027
0.089
2230
12.5 × 35.5
0.020
0.065
2880
18 × 15
0.043
0.11
2210
18 × 20
0.026
0.067
2860
12.5 × 31.5
0.024
0.078
2650
12.5 × 40
0.017
0.056
3350
16 × 20
0.027
0.078
2530
16 × 25
0.021
0.060
2930
16 × 31.5
0.017
0.050
3450
12.5 × 35.5
0.020
0.065
2880
18 × 25
0.019
0.049
3140
16 × 35.5
0.015
0.044
3610
222
272
332
392
12.5 × 40
0.017
0.056
3350
16 × 25
0.021
0.060
2930
16 × 20
0.026
0.067
2860
18 × 31.5
0.015
0.040
4170
16 × 31.5
0.017
0.050
3450
16 × 40
0.013
0.038
4080
18 × 25
0.019
0.049
3140
18 × 35.5
0.014
0.038
4220
16 × 35.5
0.015
0.044
3610
18 × 40
0.012
0.032
4280
18 × 31.5
0.015
0.040
4170
472
562
6800
682
16 × 40
0.013
0.038
4080
8200
822
18 × 35.5
0.014
0.038
4220
10000
103
18 × 40
0.012
0.032
4280
217
CAT.8100F
UHE
Standard Ratings
V (Code)
Item
Cap.(µF)
Code
35 (1V)
Case size
φD × L
(mm)
50 (1H)
Rated ripple
Impedance (Ω) MAX.
(mArms)
Case size
φD × L
(mm)
Rated ripple
(mArms)
Impedance (Ω) MAX.
0.47
R47
5 × 11
5.5
22
17
1
010
5 × 11
4
16
30
2.2
2R2
5 × 11
2.5
10
43
3.3
3R3
5 × 11
2.2
8.8
4.7
4R7
5 × 11
1.9
7.6
10
100
5 × 11
1.5
6
100
22
220
5 × 11
0.70
2.8
180
33
330
5 × 11
0.58
2.3
210
6.3 × 11
0.30
1.2
295
47
470
6.3 × 11
0.22
0.87
250
6.3 × 11
0.30
1.2
295
56
560
6.3 × 11
0.30
1.2
295
100
101
8 × 11.5
0.17
0.68
555
120
121
8 × 15
0.12
0.48
730
150
151
10 × 12.5
0.12
0.48
760
180
181
8 × 20
0.091
0.36
910
220
221
10 × 16
0.084
0.34
1050
270
271
330
331
6.3 × 11
8 × 11.5
8 × 11.5
560
680
820
471
561
681
1200
340
0.13
0.52
640
0.13
0.52
640
8 × 15
0.087
0.35
840
0.080
0.32
865
10 × 20
0.060
0.24
1220
8 × 20
0.069
0.27
1050
12.5 × 15
0.061
0.20
1260
10 × 16
0.060
0.24
1210
10 × 25
0.055
0.22
1440
10 × 20
0.060
0.24
1220
10 × 31.5
0.043
0.17
1690
12.5 × 20
0.045
0.15
1660
16 × 15
0.055
0.17
1690
12.5 × 25
0.034
0.11
1950
18 × 15
0.054
0.15
1930
12.5 × 31.5
0.030
0.10
2310
12.5 × 35.5
0.025
0.083
2510
16 × 20
0.034
0.10
2210
2230
12.5 × 40
0.021
0.069
2920
16 × 25
0.025
0.075
2555
0.046
0.18
1400
12.5 × 15
0.049
0.16
1450
10 × 25
0.042
0.17
1650
10 × 31.5
0.031
0.12
1910
12.5 × 20
0.035
0.12
1900
16 × 15
0.042
0.12
1940
821
12.5 × 25
1000
0.87
102
122
1500
152
1800
182
2200
222
2700
272
3300
332
3900
392
88
10 × 12.5
10 × 20
470
0.22
53
0.027
0.089
18 × 15
0.043
0.11
2210
18 × 20
0.036
0.097
2490
12.5 × 31.5
0.024
0.078
2650
16 × 31.5
0.022
0.066
3010
16 × 20
0.027
0.078
2530
18 × 25
0.026
0.070
2740
16 × 35.5
0.019
0.057
3150
16 × 40
0.016
0.048
3710
18 × 31.5
0.021
0.057
3635
18 × 35.5
0.017
0.046
3680
18 × 40
0.014
0.038
3800
12.5 × 35.5
0.020
0.065
2880
12.5 × 40
0.017
0.056
3350
16 × 25
0.021
0.060
2930
18 × 20
0.026
0.067
2860
16 × 31.5
0.017
0.050
3450
18 × 25
0.019
0.049
3140
16 × 35.5
0.015
0.044
3610
18 × 31.5
0.015
0.040
4170
16 × 40
0.013
0.038
4080
18 × 35.5
0.014
0.038
4220
18 × 40
0.012
0.032
4280
218
CAT.8100F
UHE
Standard Ratings
V (Code)
Item
Cap.(µF)
Code
6.8
6R8
15
150
27
270
33
330
39
390
47
470
56
560
68
680
82
820
100
120
5 × 11
6.3 × 11
180
181
390
470
560
680
820
1000
1200
1500
9.3
62
Rated ripple
(mArms)
Impedance (Ω) MAX.
5 × 11
2.3
9.3
62
6.3 × 11
1.2
5.0
126
8 × 11.5
0.63
2.8
260
1.2
5.0
126
8 × 15
0.45
2.1
335
8 × 11.5
0.63
2.8
260
10 × 12.5
0.43
1.8
325
8 × 11.5
0.63
2.8
260
8 × 20
0.33
1.6
408
10 × 16
0.31
1.5
400
8 × 15
0.45
2.1
335
10 × 20
0.21
0.94
518
10 × 12.5
0.43
1.8
325
12.5 × 15
0.23
1.1
527
10 × 25
0.20
0.84
595
12.5 × 20
0.20
0.84
740
8 × 20
0.33
1.6
408
10 × 16
0.31
1.5
400
221
10 × 20
0.21
0.94
518
12.5 × 15
0.23
1.1
527
10 × 25
10 × 31.5
330
2.3
Case size
φD × L
(mm)
0.15
0.71
740
12.5 × 20
0.16
0.64
765
16 × 15
0.14
0.66
895
12.5 × 25
0.12
0.45
875
10 × 31.5
121
151
270
100 (2A)
Rated ripple
Impedance (Ω) MAX.
(mArms)
101
150
220
63 (1J)
Case size
φD × L
(mm)
271
331
391
0.20
0.84
0.71
740
12.5 × 20
0.16
0.64
765
16 × 15
0.14
0.66
895
12.5 × 25
0.12
0.45
875
0.12
0.50
0.12
0.50
1030
0.10
0.42
1010
16 × 20
0.091
0.38
1130
12.5 × 35.5
0.083
0.35
1140
16 × 25
0.073
0.27
1350
12.5 × 40
0.071
0.30
1280
18 × 20
0.080
0.30
1300
595
0.15
18 × 15
18 × 15
12.5 × 31.5
16 × 31.5
0.054
0.20
1650
18 × 25
0.057
0.21
1560
1030
12.5 × 31.5
0.10
0.42
1010
16 × 35.5
0.045
0.17
1900
16 × 20
0.091
0.38
1130
18 × 31.5
0.047
0.17
1720
12.5 × 35.5
0.083
0.35
1140
16 × 40
0.040
0.15
2130
16 × 25
0.073
0.27
1350
12.5 × 40
0.071
0.30
1280
18 × 35.5
0.040
0.15
1890
18 × 20
0.080
0.30
1300
16 × 31.5
0.054
0.20
1650
18 × 40
0.036
0.13
2470
18 × 25
0.057
0.21
1560
16 × 35.5
0.045
0.17
1900
18 × 31.5
0.047
0.17
1720
16 × 40
0.040
0.15
2130
18 × 35.5
0.040
0.15
1890
18 × 40
0.036
0.13
2470
471
561
681
821
102
122
152
219
CAT.8100F
很抱歉,暂时无法提供与“UHE2A270MPD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.97200
- 50+0.77310
- 150+0.67560
- 500+0.60310
- 国内价格
- 5+0.98475
- 50+0.78776
- 150+0.68926
- 500+0.61539
