XS5P-T427-5
XS5P-T427-5
    OMRON(欧姆龙)
    CONN ETHERNET M12 PANEL MNT
XS5P-T427-5 数据手册
Industrial Ethernet Cables XS5/XS6 Cables and Connectors for EtherCAT® and Other Industrial Ethernet Networks CAT6a Ethernet patch cables • For in-cabinet use • LSZH with standard RJ45 plugs CAT5e Ethernet patch cables • For out-of-cabinet use • PUR with standard RJ45 plugs • PVC with rugged RJ45 plugs • PVC with M12 SmartClick plugs ■ Connection Examples ADR ADR ADR Control panel Ideal for in-cabinet XS6W-6LSZH Ideal for out-of-cabinet XS5 XS6W-5PUR Standard Connectors Standard Connectors Rugged Connectors XS6 Rugged Assembly Connectors XS5 M12 Connectors 1 XS5/XS6 Industrial Ethernet Cables ■ Features Cables with Standard RJ45 Connectors Refer to page 4 for details. • The lineup features LSZH cables* for in-panel wiring and PUR cables for wiring outside of panels. • The Standard RJ45 Connectors reduce cable routing space. - Outer diameter: 5.8 mm - 4-pair AWG27 (LSZH) or AWG26 (PUR) • Cable colors include blue, yellow, or green. • LSZH cables are available in 12 lengths from 0.2 to 20 m and PUR cables are available in 10 lengths from 0.5 to 20 m. • Double-shielded cables with overall braiding and individual foil shield on each wire pair to reduce EMC interference in industrial environments. * Low-smoke zero-halogen cables. Shape of RJ45 Connector LSZH Cable with Double Shield Overall braiding and individual foil shield on each wire pair Cables with Rugged RJ45 Connectors Refer to page 7 for details. • Tough latches and RJ45 connectors with strong cable holding strength are used to enable connections outside of control panels. • Quad AWG22 cable with PVC cover of 6.5 mm outer diameter. • Double-shielded cables with overall braiding and individual foil shield to reduce EMC interference in industrial environments. Shape of RJ45 Connector Tough latch PVC Cable with Double Shield Overall braiding and individual foil shield Assembly Connectors You can easily assemble Ethernet cables onsite without crimping tools or other special tools. Refer to page 14 for the assembly procedure. ● Cable Extension Length Standard Connectors (RJ45 Connectors) 58 mm Minimum cable bending radius: 25 mm 2 Rugged Connectors (RJ45 Connectors) 89 mm Minimum cable bending radius: 40 mm XS5/XS6 Industrial Ethernet Cables Cables with M12 Connectors • • • • Refer to page 7 for details. Resistance to harsh environments with IP67 protection. SmartClick Connectors that provide one-step (1/8th turn) connection are used (compatible with standard M12 screw connectors). A wide range of variations, such as cables with right-angle connectors and PCB connectors. Cables with sockets and robot cables were added to the series. Shape of M12 Connector PVC Cable with Double Shield Overall braiding and individual foil shield Shield structure Shield Effectiveness Data for Rugged RJ45 Connectors and Waterproof M12 Connectors The following data is the results of OMRON testing. Shield effectiveness may vary for your environment and application conditions. ● Comparison of Shield Effectiveness with Product without a Double Shield The following table shows the differences with a structure without a double shield. Higher numeric values show greater shield effectiveness. Shield structure Frequency (MHz) 0.5 1 5 10 30 Product with single shield 53 dB 49 dB 35 dB 25 dB 17 dB Product with a double shield (XS5@-T, Category 5E) 61 dB 58 dB 43 dB 31 dB 27 dB • SmartClick is registered trademark of OMRON Corporation. • EtherCAT® is a registered trademark and patented technology, licensed by Beckhoff Automation GmbH, Germany. 3 XS5/XS6 Industrial Ethernet Cables Cables with Standard RJ45 Connectors ■ Model Number Legend Use this legend when determining the product specifications from the model number. Choose from the model numbers listed in Ordering Information when ordering. X S6 W -@ @ @ @@ 8 S S @ @ @ @ C M -@ A B C D ATransmission Characteristics 5: Category 5 6: Category 6A E BSheath Material LSZH: LSZH PUR: PUR CNumber of Pins 8: 8 pins DCable Attachment Direction SS: Straight/Straight ECable Length* 20: 0.2 m 30: 0.3 m 50: 0.5 m 100: 1 m 150: 1.5 m 200: 2 m 300: 3 m 500: 5 m 750: 7.5 m 1000: 10 m 1500: 15 m 2000: 20 m FSheath Color B: Blue Y: Yellow G: Green * PUR cables are not available for 0.2-m and 0.3-m cables. 4 F XS5/XS6 Industrial Ethernet Cables ■ Ordering Information Appearance Type Category Cable sheath material Cable color Cable length (m) Blue Cat.6a LSZH Yellow Cable with Connectors on Both Ends (RJ45/RJ45) Green Cat.5 PUR Green Model 0.2 XS6W-6LSZH8SS20CM-B 0.3 XS6W-6LSZH8SS30CM-B 0.5 XS6W-6LSZH8SS50CM-B 1 XS6W-6LSZH8SS100CM-B 1.5 XS6W-6LSZH8SS150CM-B 2 XS6W-6LSZH8SS200CM-B 3 XS6W-6LSZH8SS300CM-B 5 XS6W-6LSZH8SS500CM-B 7.5 XS6W-6LSZH8SS750CM-B 10 XS6W-6LSZH8SS1000CM-B 15 XS6W-6LSZH8SS1500CM-B 20 XS6W-6LSZH8SS2000CM-B 0.2 XS6W-6LSZH8SS20CM-Y 0.3 XS6W-6LSZH8SS30CM-Y 0.5 XS6W-6LSZH8SS50CM-Y 1 XS6W-6LSZH8SS100CM-Y 1.5 XS6W-6LSZH8SS150CM-Y 2 XS6W-6LSZH8SS200CM-Y 3 XS6W-6LSZH8SS300CM-Y 5 XS6W-6LSZH8SS500CM-Y 7.5 XS6W-6LSZH8SS750CM-Y 10 XS6W-6LSZH8SS1000CM-Y 15 XS6W-6LSZH8SS1500CM-Y 20 XS6W-6LSZH8SS2000CM-Y 0.2 XS6W-6LSZH8SS20CM-G 0.3 XS6W-6LSZH8SS30CM-G 0.5 XS6W-6LSZH8SS50CM-G 1 XS6W-6LSZH8SS100CM-G 1.5 XS6W-6LSZH8SS150CM-G 2 XS6W-6LSZH8SS200CM-G 3 XS6W-6LSZH8SS300CM-G 5 XS6W-6LSZH8SS500CM-G 7.5 XS6W-6LSZH8SS750CM-G 10 XS6W-6LSZH8SS1000CM-G 15 XS6W-6LSZH8SS1500CM-G 20 XS6W-6LSZH8SS2000CM-G 0.5 XS6W-5PUR8SS50CM-G 1 XS6W-5PUR8SS100CM-G 1.5 XS6W-5PUR8SS150CM-G 2 XS6W-5PUR8SS200CM-G 3 XS6W-5PUR8SS300CM-G 5 XS6W-5PUR8SS500CM-G 7.5 XS6W-5PUR8SS750CM-G 10 XS6W-5PUR8SS1000CM-G 15 XS6W-5PUR8SS1500CM-G 20 XS6W-5PUR8SS2000CM-G 5 XS5/XS6 Industrial Ethernet Cables ■ Specifications Type Item Cable with Connectors on Both Ends (RJ45/RJ45)/LSZH Cable with Connectors on Both Ends (RJ45/RJ45)/PUR XS6W-6LSZH8SS@@@@CM-@ XS6W-5PUR8SS@@@@CM-G Model Rated current 1 A (at 50°C) Withstand voltage 1,000 VDC for 60 s (leakage current: 1 mA max.) Ambient operating temperature −20 to 60°C −40 to 85°C Ambient storage tempera−20 to 60°C ture −40 to 85°C Ambient installation temperature 0 to 50°C −10 to 60°C Protective structure IP20 ■ Materials and Finish ● Connectors Type Item Cable with Connectors on Both Ends (RJ45/RJ45)/LSZH Cable with Connectors on Both Ends (RJ45/RJ45)/PUR XS6W-6LSZH8SS@@@@CM-@ XS6W-5PUR8SS@@@@CM-G Model Connector housing PC resin (UL94V-0)/transparent Contacts Phosphor bronze/nickel base, gold plated (0.8 μm) Shield Brass/nickel plated Cover (structured to prevent the tab from breaking) LSZH: Blue, yellow, or green Marking tube PVC resin (UL94V-0)/transparent PUR: Green ● Cables Type Item Cable with Connectors on Both Ends (RJ45/RJ45)/LSZH Cable with Connectors on Both Ends (RJ45/RJ45)/PUR XS6W-6LSZH8SS@@@@CM-@ XS6W-5PUR8SS@@@@CM-G Model Compliant standard IEC 60332-1 /UL1581 FT2 IEC 60332-1 /UL1581 FT2 Number of cores/gauge 4 × 2 × AWG27 0.1 mm2 4 × 2 × AWG26 0.13 mm2 Outer diameter*1 5.8 mm Sheath color*2 Blue, yellow, or green Sheath material LSZH PUR Shield structure Double shield S/FTP Double shield SF/UTP *2. Sheath. Green *1. Outer diameter. ■ Dimensions (Unit: mm) ● Cable with Connectors on Both Ends (RJ45/RJ45) XS6W-6LSZH8SS@@@@CM-@ XS6W-5PUR8SS@@@@CM-G Wiring RJ45 1 2 3 4 5 6 7 8 Shield RJ45 1 2 3 4 5 6 7 8 Shield L (cable length) (14) 13.2 38.5 18 38.5 18 Marking tube Note. External dimensions are the same for all cable materials. 6 XS5/XS6 Industrial Ethernet Cables Cables with Rugged RJ45 Connectors and Cables with M12 Connectors ■ Model Number Legend Use this legend when determining the product specifications from the model number. Choose from the model numbers listed in Ordering Information when ordering. ● Cable with Connectors ● RJ45 Assembly Connectors XS 5@ -T 4 2 @- @ M@ - @ @ A BCD E F G XS6G-T 4 2 1-1 H ABCD E AConnector Shape H: Cable with plug on one end W: Cable with connectors on both ends AType T: Ethernet BType T: Ethernet (mating part: M12 D coding) 4: 4 pins CNumber of Pins 4: 4 pins 2: Gold plating, 0.4 µm DContact Plating Specification 2: Gold plating, 0.4 µm 1: Straight ECable Attachment Direction (M12 Connectors) 1: Straight 2: Right angle FCable Length A: 0.3 m B: 0.5 m C: 1 m D: 2 m E: 3 m G: 5 m J: 10 m K: 15 m GConnector Shape 0: M12 plug on one end 1: Connectors on both ends: M12 socket/M12 plug 2: Connectors on both ends: M12 plug/M12 plug C: Connectors on both ends: M12 plug/RJ45 plug D: Connectors on both ends: RJ45 plug/RJ45 plug E: Connectors on both ends: M12 socket/RJ45 plug HCable Specification K: Standard cable KR: Robot cable BNumber of Pins CContact Plating Specification DCable Attachment Direction EDegree of Protection 1: IP20 ● M12 Connectors for Panel Mounting X S 5 P - T 4 2 @ -@ ABCD E AType T: Ethernet (mating part: M12 D coding) BNumber of Pins 4: 4 pins CPlating Specification 2: Gold plating, 0.4 µm DMounting Method 6: Rear lockingt 7: Front locking ETerminal Shape 1: DIP terminalst 5: Cable with loose wires (0.5 m) 7 XS5/XS6 Industrial Ethernet Cables ■ Ordering Information Appearance Cable type Type Cable with Plug on One End (M12 Straight) Cable with Plugs on Both Ends (M12 Straight/M12 Straight) Cable with Plugs on Both Ends (M12 Straight/RJ45) Cable with Plug on One End (M12 Right-angle) Standard Cables Cable with Plugs on Both Ends (M12 Right-angle/M12 Right-angle) Cable with Plugs on Both Ends (M12 Right-angle/RJ45) Cable with Plugs on Both Ends (RJ45/RJ45) Cable with Plug on One End and Socket on Other End (M12 Straight/M12 Straight) Cable with Plug on One End and Socket on Other End (M12 Straight/RJ45) 8 Cable length (m) 0.5 1 2 3 5 10 Model XS5H-T421-BM0-K XS5H-T421-CM0-K XS5H-T421-DM0-K XS5H-T421-EM0-K XS5H-T421-GM0-K XS5H-T421-JM0-K 15 XS5H-T421-KM0-K 0.5 1 2 3 5 10 XS5W-T421-BM2-K XS5W-T421-CM2-K XS5W-T421-DM2-K XS5W-T421-EM2-K XS5W-T421-GM2-K XS5W-T421-JM2-K 15 XS5W-T421-KM2-K 0.3 0.5 1 2 3 5 10 15 0.5 1 2 3 5 10 XS5W-T421-AMC-K XS5W-T421-BMC-K XS5W-T421-CMC-K XS5W-T421-DMC-K XS5W-T421-EMC-K XS5W-T421-GMC-K XS5W-T421-JMC-K XS5W-T421-KMC-K XS5H-T422-BM0-K XS5H-T422-CM0-K XS5H-T422-DM0-K XS5H-T422-EM0-K XS5H-T422-GM0-K XS5H-T422-JM0-K 15 XS5H-T422-KM0-K 0.5 1 2 3 5 10 XS5W-T422-BM2-K XS5W-T422-CM2-K XS5W-T422-DM2-K XS5W-T422-EM2-K XS5W-T422-GM2-K XS5W-T422-JM2-K 15 XS5W-T422-KM2-K 0.3 0.5 1 2 3 5 10 15 0.3 0.5 1 2 3 5 10 15 0.5 1 2 3 5 10 15 0.5 1 2 3 5 10 15 XS5W-T422-AMC-K XS5W-T422-BMC-K XS5W-T422-CMC-K XS5W-T422-DMC-K XS5W-T422-EMC-K XS5W-T422-GMC-K XS5W-T422-JMC-K XS5W-T422-KMC-K XS5W-T421-AMD-K XS5W-T421-BMD-K XS5W-T421-CMD-K XS5W-T421-DMD-K XS5W-T421-EMD-K XS5W-T421-GMD-K XS5W-T421-JMD-K XS5W-T421-KMD-K XS5W-T421-BM1-K XS5W-T421-CM1-K XS5W-T421-DM1-K XS5W-T421-EM1-K XS5W-T421-GM1-K XS5W-T421-JM1-K XS5W-T421-KM1-K XS5W-T421-BME-K XS5W-T421-CME-K XS5W-T421-DME-K XS5W-T421-EME-K XS5W-T421-GME-K XS5W-T421-JME-K XS5W-T421-KME-K XS5/XS6 Industrial Ethernet Cables Appearance Cable type Type Cable length (m) 0.5 1 2 3 5 10 15 0.5 1 2 3 5 10 15 0.5 1 2 3 5 10 15 0.5 1 2 3 5 10 15 Model XS5W-T421-BM1-KR XS5W-T421-CM1-KR XS5W-T421-DM1-KR XS5W-T421-EM1-KR XS5W-T421-GM1-KR XS5W-T421-JM1-KR XS5W-T421-KM1-KR XS5W-T421-BM2-KR XS5W-T421-CM2-KR XS5W-T421-DM2-KR XS5W-T421-EM2-KR XS5W-T421-GM2-KR XS5W-T421-JM2-KR XS5W-T421-KM2-KR XS5W-T421-BMC-KR XS5W-T421-CMC-KR XS5W-T421-DMC-KR XS5W-T421-EMC-KR XS5W-T421-GMC-KR XS5W-T421-JMC-KR XS5W-T421-KMC-KR XS5W-T421-BMD-KR XS5W-T421-CMD-KR XS5W-T421-DMD-KR XS5W-T421-EMD-KR XS5W-T421-GMD-KR XS5W-T421-JMD-KR XS5W-T421-KMD-KR --- XS6G-T421-1 Rear locking 0.5 XS5P-T426-5 Front locking 0.5 XS5P-T427-5 --- XS5P-T426-1 Cable with Plug on One End and Socket on Other End (M12 Straight/M12 Straight) Cable with Plugs on Both Ends (M12 Straight/M12 Straight) Robot Cables Cable with Plugs on Both Ends (M12 Straight/RJ45) Cable with Plugs on Both Ends (RJ45/RJ45) RJ45 Assembly Connector Standard Cables M12 Connector for Panel Mounting M12 Panel-mounting PCB Straight Terminals ●Cable Bending Data for Robot Cables (XS5W-T421-@M@-KR) The following data is the results of OMRON testing for cable bending test conditions. The number of bends may vary for your environment and application conditions. Cableveyor Test 90° Bending Test Number of bends: 20 million min. Number of bends: 6 million min. Travel distance Cable secured to end Cableveyor Cable secured to end Roller Travel speed: Approx. 120 m/min Travel distance: 1 m Cableveyor radius: 75 mm Cable Bending angle: ±90° Speed: Approx. 30 bends/min Roller radius: 60 mm Weight: 500 g Weight 9 XS5/XS6 Industrial Ethernet Cables ■ Specifications Cable with Type Plug on One End (M12) Item Model XS5H -T42@-@M0-K Cable with Plugs on Both Ends (M12/M12) Cable with Plug on One End and Socket on Other End (M12/M12) Cable with Plugs on Both Ends (M12/RJ45) XS5W -T42@-@M2-K, -KR XS5W -T42@-@M1-K, -KR XS5W -T42@-@MC-K, -KR Rated current 3A Rated voltage 30 V Contact resistance 40 mΩ max. Insulation resistance 1,000 MΩ min. Withstand voltage 1,000 VAC for 60 s (leakage current: 1 mA max.) Ambient operating temperature −25 to 70°C Ambient storage temperature −25 to 70°C Protective structure M12: IEC IP67, RJ45: IEC IP20 Cable with Plug on One End and Socket on Other End (M12/RJ45) XS5W -T421-@ME-K Cable with M12 ConnecPlugs on Both RJ45 Assembly tor for Panel Ends Connector Mounting (RJ45/RJ45) XS5W -T421-@MD-K, -KR XS6G -T421-1 2.5 A M12 Panelmounting PCB Straight Terminals XS5P-T42@-5 XS5P -T426-1 4A 125 VDC 500 MΩ min. 1,000 MΩ min. 1,500 VAC for 60 s (leakage current: 1 mA max.) ■ Materials and Finish ● Connectors Model M12 Item XS5H and XS5W Contact blocks Contacts RJ45 XS5P-T42@-5 XS5P-T426-1 XS5W and XS6G PBT resin (UL94V-0)/light gray PA resin (UL94V-0)/black PA resin (UL94V-0)/black Phosphor bronze/nickel base, gold plated (0.4 μm) Brass/nickel base, gold plated (0.4 μm) Phosphor bronze/nickel base, gold plated (1.4 μm) Anchors Zinc diecast/nickel plating Anchors (tabs) SUS --- Cover Straight connector: Soft PBT resin (UL94V-0)/black Right-angle connector: TPC resin/black --- Sealing resin --- Epoxy resin O-rings Rubber Grounding fixture --- Anchor cover --- Nuts --- --- ----Phosphor bronze/nickel base, tin plated (2.0 μm) --- SUS --- Brass/nickel plated --- ● Cables Model Standard Cables Item Compliant standard Robot Cables UL CM Category Category 5e Number of cores/gauge 4 × AWG22 0.3 mm2 (7/0.26) Outer diameter*1 6.5 dia. Sheath color*2 Light blue Sheath material PVC Shield structure Double shield SF/UTP 4 × AWG22 0.3 mm2 (7/24/0.05) Note. For the XS5H and XS5W, cables are available only with connectors attached. 10 *2. Sheath. *1. Outer diameter. XS5/XS6 Industrial Ethernet Cables ■ Dimensions (Unit: mm) ● Cable with Plug on One End (M12 Straight) XS5H-T421-@M0-K Wiring Terminal No. Color 1 Yellow 2 White 3 Orange 4 Blue L (cable length) 44.7 2 1 2 1 3 14.9 dia. 4 3 4 M12 × 1 (Plug) ● Cable with Plugs on Both End (M12 Straight/M12 Straight) XS5W-T421-@M2-K XS5W-T421-@M2-KR Wiring M12 straight 1 2 3 4 Shield M12 straight 1 2 3 4 Shield L (cable length) 44.7 44.7 1 4 3 4 3 14.9 dia. 14.9 dia. 1 1 2 2 3 2 4 3 4 1 M12 × 1 (Plug) M12 × 1 ● Cable with Plugs on Both Ends (M12 Straight/RJ45) XS5W-T421-@MC-K XS5W-T421-@MC-KR 2 (Plug) Wiring M12 straight 1 2 3 4 Shield RJ45 1 3 2 6 Shield L (cable length) 44.7 2 54.7 1 2 1 3 14.9 dia. 4 3 4 M12 × 1 (Plug) RJ45 ● Cable with Plug on One End and Socket on Other End (M12 Straight/M12 Straight) XS5W-T421-@M1-K XS5W-T421-@M1-KR Wiring M12 straight 1 2 3 4 Shield M12 straight 1 2 3 4 Shield L (cable length) 44.7 2 50.7 1 3 4 4 3 14.9 dia. 3 14.9 dia. 2 1 1 2 4 3 4 2 M12 × 1 (Plug) M12×1 ● Cable with Plug on One End and Socket on Other End (M12 Straight/RJ45) XS5W-T421-@ME-K 1 (Socket) Wiring M12 straight 1 2 3 4 Shield RJ45 1 3 2 6 Shield L (cable length) 50.7 1 14.9 dia. 2 1 4 4 54.7 2 3 3 (Socket) M12 × 1 RJ45 11 XS5/XS6 Industrial Ethernet Cables ● Cable with Plug One End (M12 Right-angle) XS5H-T422-@M0-K Wiring Terminal No. Color 1 Yellow L (cable length) 2 White 3 Orange 4 Blue 22.5 32.3 14.9 dia. M12 × 1 4 3 2 4 1 1 3 2 (Plug) ● Cable with Plugs on Both Ends (M12 Right-angle/M12 Right-angle) XS5W-T422-@M2-K Wiring M12 right angle 1 2 3 4 Shield L (cable length) 22.5 22.5 32.3 M12 right angle 1 2 3 4 Shield 32.3 14.9 dia. 1 M12 × 1 M12 × 1 3 3 4 14.9 dia. 2 1 3 4 2 1 3 2 4 4 2 1 (Plug) (Plug) ● Cable with Plugs on Both Ends (M12 Right-angle/RJ45) XS5W-T422-@MC-K L (cable length) 54.7 22.5 32.3 RJ45 14.9 dia. M12 × 1 Wiring 4 M12 right angle 1 2 3 4 Shield 4 3 2 1 1 3 2 (Plug) ● Cable with Plugs on Both Ends (RJ45/RJ45) XS5W-T421-@MD-K XS5W-T421-@MD-KR Wiring RJ45 1 2 3 6 Shield L (cable length) 54.7 54.7 RJ45 12 RJ45 1 3 2 6 Shield RJ45 RJ45 1 2 3 6 Shield XS5/XS6 Industrial Ethernet Cables ● RJ45 Assembly Connector XS6G-T421-1 52.6 11.8 11.3 8.1 Contact 6 Contact 1 Contact 2 Contact 3 Applicable wires Sheath outer diameter: 6.1 to 6.9 mm Core size: AWG22 to AWG24 (stranded wires) AWG22 to AWG23 (solid wires) Insulation outer diameter: 1.6 mm max. ● M12 Connector for Panel Mounting XS5P-T42@-5 XS5P-T426-5 (Rear Locking) M12 × 1 PG9 2.8 17 18 Wiring Color 1 Yellow 18 Orange 500 White 14.6 dia. 2 White 3 Orange 4 Blue 20 10±3 2.5 (Socket) Terminal No. (20) Yellow Blue Panel Cutout Dimension 11.9 22.1 15.3 +0.1 0 dia. XS5P-T427-5 (Front Locking) M12 × 1 Panel thickness t = 1 to 4 2.8 18 17 PG9 20 500 Orange White 10±3 (Socket) 10.5 22.1 (20) Blue Yellow 2.5 ● M12 Panel-mounting PCB Straight Terminals XS5P-T426-1 Mounting Hole Dimensions (D Cut Structure) 14 M12×1 B 2.5 5.3 +0.1 0 15 A (Socket) Mounting Hole Dimensions 10.6 +0.2 0 19.9 10.4 Pin No. Note 1: The panel cutout dimension is the same for Front-locking and Rearlocking Connectors. Note 2: Rotational positioning is not possible for connector rotation. 18 13.9 dia. C A C B 2.5 0.5 min. 1.2±0.04 dia. × 45° 1.2±0.04 dia. × 45° 2 to 3 2 to 3 16.5 dia. 14.6 dia. 3 12.2±0.05 dia. 12.2±0.05 dia. Cross-section Diagram A-A Cross-section Diagram C-C 0.5 min. Cross-section Diagram B-B Panel Processing Dimensions 5±0.05 dia. 45°±1° 5±0.05 Four, 1.2 +0.1 0 dia. Three, 1.4 +0.1 0 dia. 1 +0.1 0 dia. 7.05±0.05 4.5±0.05 8.5±0.05 13 XS5/XS6 Industrial Ethernet Cables ■ Assembly Procedure ● RJ45 Assembly Connectors XS6G-T421-1 1. 2. ● M12 Panel-mounting PCB Straight Terminals XS5P-T426-1 Confirming the Number of Parts Pass the cable through the cable clamp and the connector housing Strip the cable sheath and ground braiding to the correct lengths. 3. Follow the color codes and prepare to insert the wires into the splice piece. 4. Insert the wires into the splice piece for the length of the splice piece. 5. 6. 7. The following four parts are included in the package when it is delivered. 24 mm 13 mm Panel-mounting Parts 1. Anchor 2. O-Ring 3. Nut PCB-mounting Part 4. Connector Assembly Procedure 1. Mount the connector to the PCB. 2. Attach the anchor to the panel with the nut. Place the splice piece into the RJ45 data module and engage it. Mounting the Connector to the PCB Place the data module and the splice piece on the IDC assembly housing. Mounting the Anchor to the Panel Anchor PCB *Tightening torque: 1 N·m Press the data module and the IDC assembly housing together and use pliers or a similar device to make the insulation displacement contact. 8. Remove the data module from the IDC assembly housing. 9. Place the upper screen plate on the data module and press it over the ground braiding of the cable. Panel Nut 3. Attach the connector that you mounted to the PCB to the panel. * Make sure that the connector and anchor are oriented correctly. Attachment 5 mm 10. Place the lower screen plate on the bottom of the data module, align it with the upper screen place, and latch it until you hear it click into place. Align the flat surface on the anchor with the grounding fixture terminal. 4. Temporarily mount the O-ring to the top of the connector at the mating surface. Temporary Mounting of the O-Ring 11. Slide the housing that you placed around the cable in step 1 up to the data module and latch it until you hear it click into place. O-ring 12. Tighten the cable clamp. Pin Assignments Pin Assignments for Fast Ethernet 10/100 Mbps Wire color Function/Signal Transmission Data+/TD+ Industrial Ethernet EIA/TIA 568A EIA/TIA 568B Pin No. YE WH/GN WH/OG 1 5. Mate the Connector Waterproof Cover (XS2Z-22, sold separately) or the Partner Connector Plug (XS5H-T42@-@M0-K, sold separately) and press the O-ring to the O-ring position after mounting. Mounting the O-Ring Transmission Data-/TD− OG GN OG 2 Receiver Data/RD+ WH WH/OG WH 3 Receiver Data/RD− BU OG GN 6 O-Ring Position after Mounting ● Connector Waterproof Cover (Sold Separately) XS2Z-22 * Tightening torque: 0.39 to 0.49 N·m 14 XS5/XS6 Industrial Ethernet Cables ■ Safety Precautions Precautions for Correct Use Do not use the Connectors in an atmosphere or environment that exceeds the specifications. ● Connector Connection and Disconnection • When connecting or disconnecting Connectors, be sure to hold the Connectors. • Do not hold the cable when disconnecting Connectors. • When joining Connectors, be sure to insert the plug all the way to the back of the socket before attempting to lock the Connectors. • Do not use tools of any sort to join the Connectors. Always use your hands. Pliers or other tools may damage the Connectors. ● Handling Precautions • Do not pull on the Connectors or cables with excessive force. Do not install the Connectors with a load placed directly on the joint or at the point where the wires connect to the Connector. The Connector may be damaged or the wires in the cable may be disconnected. • Lay the cable where it will not be stepped on to prevent the wires in the cable from being disconnected and to protect the Connectors from being damaged. If the cable must be placed where it will be stepped on, install a protective cover. • When bending cables, do not exceed the cable specifications. ● Wiring Lay the cables so that external force is not applied to the Connectors. Otherwise, the degree of protection (IP67) may not be achieved. ● Degree of Protection for M12/Smartclick Connectors • The degree of protection of Connectors (IP67) is not for a fully watertight structure. Do not use the Connectors underwater. • Do not step on or place any objects on the Connectors. Doing so may damage the Connectors. 15 Terms and Conditions of Sale 1. Offer; Acceptance. These terms and conditions (these "Terms") are deemed part of all quotes, agreements, purchase orders, acknowledgments, price lists, catalogs, manuals, brochures and other documents, whether electronic or in writing, relating to the sale of products or services (collectively, the "Products") by Omron Electronics LLC and its subsidiary companies (“Omron”). Omron objects to any terms or conditions proposed in Buyer’s purchase order or other documents which are inconsistent with, or in addition to, these Terms. 2. Prices; Payment Terms. All prices stated are current, subject to change without notice by Omron. Omron reserves the right to increase or decrease prices on any unshipped portions of outstanding orders. Payments for Products are due net 30 days unless otherwise stated in the invoice. 3. Discounts. Cash discounts, if any, will apply only on the net amount of invoices sent to Buyer after deducting transportation charges, taxes and duties, and will be allowed only if (i) the invoice is paid according to Omron’s payment terms and (ii) Buyer has no past due amounts. 4. Interest. Omron, at its option, may charge Buyer 1-1/2% interest per month or the maximum legal rate, whichever is less, on any balance not paid within the stated terms. 5. Orders. Omron will accept no order less than $200 net billing. 6. Governmental Approvals. Buyer shall be responsible for, and shall bear all costs involved in, obtaining any government approvals required for the importation or sale of the Products. 7. Taxes. All taxes, duties and other governmental charges (other than general real property and income taxes), including any interest or penalties thereon, imposed directly or indirectly on Omron or required to be collected directly or indirectly by Omron for the manufacture, production, sale, delivery, importation, consumption or use of the Products sold hereunder (including customs duties and sales, excise, use, turnover and license taxes) shall be charged to and remitted by Buyer to Omron. 8. Financial. If the financial position of Buyer at any time becomes unsatisfactory to Omron, Omron reserves the right to stop shipments or require satisfactory security or payment in advance. If Buyer fails to make payment or otherwise comply with these Terms or any related agreement, Omron may (without liability and in addition to other remedies) cancel any unshipped portion of Products sold hereunder and stop any Products in transit until Buyer pays all amounts, including amounts payable hereunder, whether or not then due, which are owing to it by Buyer. Buyer shall in any event remain liable for all unpaid accounts. 9. Cancellation; Etc. Orders are not subject to rescheduling or cancellation unless Buyer indemnifies Omron against all related costs or expenses. 10. Force Majeure. Omron shall not be liable for any delay or failure in delivery resulting from causes beyond its control, including earthquakes, fires, floods, strikes or other labor disputes, shortage of labor or materials, accidents to machinery, acts of sabotage, riots, delay in or lack of transportation or the requirements of any government authority. 11. Shipping; Delivery. Unless otherwise expressly agreed in writing by Omron: a. Shipments shall be by a carrier selected by Omron; Omron will not drop ship except in “break down” situations. b. Such carrier shall act as the agent of Buyer and delivery to such carrier shall constitute delivery to Buyer; c. All sales and shipments of Products shall be FOB shipping point (unless otherwise stated in writing by Omron), at which point title and risk of loss shall pass from Omron to Buyer; provided that Omron shall retain a security interest in the Products until the full purchase price is paid; d. Delivery and shipping dates are estimates only; and e. Omron will package Products as it deems proper for protection against normal handling and extra charges apply to special conditions. 12. Claims. Any claim by Buyer against Omron for shortage or damage to the Products occurring before delivery to the carrier must be presented in writing to Omron within 30 days of receipt of shipment and include the original transportation bill signed by the carrier noting that the carrier received the Products from Omron in the condition claimed. 13. Warranties. (a) Exclusive Warranty. Omron’s exclusive warranty is that the Products will be free from defects in materials and workmanship for a period of twelve months from the date of sale by Omron (or such other period expressed in writing by Omron). Omron disclaims all other warranties, express or implied. (b) Limitations. OMRON MAKES NO WARRANTY OR REPRESENTATION, EXPRESS OR IMPLIED, ABOUT NON-INFRINGEMENT, MERCHANTABIL- 14. 15. 16. 17. 18. ITY OR FITNESS FOR A PARTICULAR PURPOSE OF THE PRODUCTS. BUYER ACKNOWLEDGES THAT IT ALONE HAS DETERMINED THAT THE PRODUCTS WILL SUITABLY MEET THE REQUIREMENTS OF THEIR INTENDED USE. Omron further disclaims all warranties and responsibility of any type for claims or expenses based on infringement by the Products or otherwise of any intellectual property right. (c) Buyer Remedy. Omron’s sole obligation hereunder shall be, at Omron’s election, to (i) replace (in the form originally shipped with Buyer responsible for labor charges for removal or replacement thereof) the non-complying Product, (ii) repair the non-complying Product, or (iii) repay or credit Buyer an amount equal to the purchase price of the non-complying Product; provided that in no event shall Omron be responsible for warranty, repair, indemnity or any other claims or expenses regarding the Products unless Omron’s analysis confirms that the Products were properly handled, stored, installed and maintained and not subject to contamination, abuse, misuse or inappropriate modification. Return of any Products by Buyer must be approved in writing by Omron before shipment. Omron Companies shall not be liable for the suitability or unsuitability or the results from the use of Products in combination with any electrical or electronic components, circuits, system assemblies or any other materials or substances or environments. Any advice, recommendations or information given orally or in writing, are not to be construed as an amendment or addition to the above warranty. See http://www.omron247.com or contact your Omron representative for published information. Limitation on Liability; Etc. OMRON COMPANIES SHALL NOT BE LIABLE FOR SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, LOSS OF PROFITS OR PRODUCTION OR COMMERCIAL LOSS IN ANY WAY CONNECTED WITH THE PRODUCTS, WHETHER SUCH CLAIM IS BASED IN CONTRACT, WARRANTY, NEGLIGENCE OR STRICT LIABILITY. Further, in no event shall liability of Omron Companies exceed the individual price of the Product on which liability is asserted. Indemnities. Buyer shall indemnify and hold harmless Omron Companies and their employees from and against all liabilities, losses, claims, costs and expenses (including attorney's fees and expenses) related to any claim, investigation, litigation or proceeding (whether or not Omron is a party) which arises or is alleged to arise from Buyer's acts or omissions under these Terms or in any way with respect to the Products. Without limiting the foregoing, Buyer (at its own expense) shall indemnify and hold harmless Omron and defend or settle any action brought against such Companies to the extent based on a claim that any Product made to Buyer specifications infringed intellectual property rights of another party. Property; Confidentiality. Any intellectual property in the Products is the exclusive property of Omron Companies and Buyer shall not attempt to duplicate it in any way without the written permission of Omron. Notwithstanding any charges to Buyer for engineering or tooling, all engineering and tooling shall remain the exclusive property of Omron. All information and materials supplied by Omron to Buyer relating to the Products are confidential and proprietary, and Buyer shall limit distribution thereof to its trusted employees and strictly prevent disclosure to any third party. Export Controls. Buyer shall comply with all applicable laws, regulations and licenses regarding (i) export of products or information; (iii) sale of products to “forbidden” or other proscribed persons; and (ii) disclosure to non-citizens of regulated technology or information. Miscellaneous. (a) Waiver. No failure or delay by Omron in exercising any right and no course of dealing between Buyer and Omron shall operate as a waiver of rights by Omron. (b) Assignment. Buyer may not assign its rights hereunder without Omron's written consent. (c) Law. These Terms are governed by the law of the jurisdiction of the home office of the Omron company from which Buyer is purchasing the Products (without regard to conflict of law principles). (d) Amendment. These Terms constitute the entire agreement between Buyer and Omron relating to the Products, and no provision may be changed or waived unless in writing signed by the parties. (e) Severability. If any provision hereof is rendered ineffective or invalid, such provision shall not invalidate any other provision. (f) Setoff. Buyer shall have no right to set off any amounts against the amount owing in respect of this invoice. (g) Definitions. As used herein, “including” means “including without limitation”; and “Omron Companies” (or similar words) mean Omron Corporation and any direct or indirect subsidiary or affiliate thereof. Certain Precautions on Specifications and Use 1. Suitability of Use. Omron Companies shall not be responsible for conformity with any standards, codes or regulations which apply to the combination of the Product in the Buyer’s application or use of the Product. At Buyer’s request, Omron will provide applicable third party certification documents identifying ratings and limitations of use which apply to the Product. This information by itself is not sufficient for a complete determination of the suitability of the Product in combination with the end product, machine, system, or other application or use. Buyer shall be solely responsible for determining appropriateness of the particular Product with respect to Buyer’s application, product or system. Buyer shall take application responsibility in all cases but the following is a non-exhaustive list of applications for which particular attention must be given: (i) Outdoor use, uses involving potential chemical contamination or electrical interference, or conditions or uses not described in this document. (ii) Use in consumer products or any use in significant quantities. (iii) Energy control systems, combustion systems, railroad systems, aviation systems, medical equipment, amusement machines, vehicles, safety equipment, and installations subject to separate industry or government regulations. (iv) Systems, machines and equipment that could present a risk to life or property. Please know and observe all prohibitions of use applicable to this Product. NEVER USE THE PRODUCT FOR AN APPLICATION INVOLVING SERIOUS RISK TO LIFE OR PROPERTY OR IN LARGE QUANTITIES WITHOUT ENSURING THAT THE SYSTEM AS A WHOLE HAS BEEN DESIGNED TO 2. 3. 4. 5. ADDRESS THE RISKS, AND THAT THE OMRON’S PRODUCT IS PROPERLY RATED AND INSTALLED FOR THE INTENDED USE WITHIN THE OVERALL EQUIPMENT OR SYSTEM. Programmable Products. Omron Companies shall not be responsible for the user’s programming of a programmable Product, or any consequence thereof. Performance Data. Data presented in Omron Company websites, catalogs and other materials is provided as a guide for the user in determining suitability and does not constitute a warranty. It may represent the result of Omron’s test conditions, and the user must correlate it to actual application requirements. Actual performance is subject to the Omron’s Warranty and Limitations of Liability. Change in Specifications. Product specifications and accessories may be changed at any time based on improvements and other reasons. It is our practice to change part numbers when published ratings or features are changed, or when significant construction changes are made. However, some specifications of the Product may be changed without any notice. When in doubt, special part numbers may be assigned to fix or establish key specifications for your application. Please consult with your Omron’s representative at any time to confirm actual specifications of purchased Product. Errors and Omissions. Information presented by Omron Companies has been checked and is believed to be accurate; however, no responsibility is assumed for clerical, typographical or proofreading errors or omissions. OMRON AUTOMATION AND SAFETY • THE AMERICAS HEADQUARTERS • Chicago, IL USA • 847.843.7900 • 800.556.6766 • www.omron247.com OMRON CANADA, INC. • HEAD OFFICE Toronto, ON, Canada • 416.286.6465 • 866.986.6766 • www.omron247.com OMRON ARGENTINA • SALES OFFICE Cono Sur • 54.11.4783.5300 OMRON ELECTRONICS DE MEXICO • HEAD OFFICE México DF • 52.55.59.01.43.00 • 01-800-226-6766 • mela@omron.com OMRON CHILE • SALES OFFICE Santiago • 56.9.9917.3920 OMRON ELECTRONICS DE MEXICO • SALES OFFICE Apodaca, N.L. • 52.81.11.56.99.20 • 01-800-226-6766 • mela@omron.com OTHER OMRON LATIN AMERICA SALES 54.11.4783.5300 OMRON ELETRÔNICA DO BRASIL LTDA • HEAD OFFICE São Paulo, SP, Brasil • 55.11.2101.6300 • www.omron.com.br OMRON EUROPE B.V. • Wegalaan 67-69, NL-2132 JD, Hoofddorp, The Netherlands. • +31 (0) 23 568 13 00 • www.industrial.omron.eu Authorized Distributor: Automation Control Systems • Machine Automation Controllers (MAC) • Programmable Controllers (PLC) • Operator interfaces (HMI) • Distributed I/O • Software Drives & Motion Controls • Servo & AC Drives • Motion Controllers & Encoders Temperature & Process Controllers • Single and Multi-loop Controllers Sensors & Vision • Proximity Sensors • Photoelectric Sensors • Fiber-Optic Sensors • Amplified Photomicrosensors • Measurement Sensors • Ultrasonic Sensors • Vision Sensors Industrial Components • RFID/Code Readers • Relays • Pushbuttons & Indicators • Limit and Basic Switches • Timers • Counters • Metering Devices • Power Supplies Safety • Laser Scanners • Safety Mats • Edges and Bumpers • Programmable Safety Controllers • Light Curtains • Safety Relays • Safety Interlock Switches (& 0/14 Note: Specifications are subject to change. Printed on recycled paper. © 2014 Omron Electronics LLC Printed in U.S.A.
XS5P-T427-5 价格&库存
很抱歉,暂时无法提供与“XS5P-T427-5”相匹配的价格&库存,您可以联系我们找货
XS5P-T427-5
  • 1+478.235501+61.98843
  • 10+406.4985810+52.68996
  • 25+381.0600425+49.39264
  • 50+362.8845150+47.03675
  • 100+345.58497100+44.79439
库存:1
XS5P-T427-5
  • 1+390.385551+50.60140
  • 5+364.319175+47.22270
  • 10+338.3399610+43.85530
