NCP1030GEVB
NCP1030GEVB
    ONSEMI(安森美)
    NCP1030GEVB
NCP1030GEVB 数据手册
DATA SHEET www.onsemi.com Integrated DC-DC Converter - Power over Ethernet and Telecom MARKING DIAGRAMS 8 Micro8 DM SUFFIX CASE 846A 8 1 NCP1030, NCP1031 1030 AYWG G 1 8 The NCP1030 and NCP1031 are a family of miniature high−voltage monolithic switching regulators with on−chip Power Switch and Startup Circuits. The NCP103x family incorporates in a single IC all the active power, control logic and protection circuitry required to implement, with minimal external components, several switching regulator applications, such as a secondary side bias supply or a low power dc−dc converter. This controller family is ideally suited for 48 V telecom, 42 V automotive and 12 V input applications. The NCP103x can be configured in any single−ended topology such as forward or flyback. The NCP1030 is targeted for applications requiring up to 3 W, and the NCP1031 is targeted for applications requiring up to 6 W. The internal error amplifier allows the NCP103x family to be easily configured for secondary or primary side regulation operation in isolated and non−isolated configurations. The fixed frequency oscillator is optimized for operation up to 1 MHz and is capable of external frequency synchronization, providing additional design flexibility. In addition, the NCP103x incorporates individual line undervoltage and overvoltage detectors, cycle by cycle current limit and thermal shutdown to protect the controller under fault conditions. The preset current limit thresholds eliminate the need for external sensing components. 1 On Chip High 200 V Power Switch Circuit and Startup Circuit Internal Startup Regulator with Auxiliary Winding Override Operation up to 1 MHz External Frequency Synchronization Capability Frequency Fold−down Under Fault Conditions Trimmed ±2% Internal Reference Line Undervoltage and Overvoltage Detectors Cycle by Cycle Current Limit Using SENSEFET® Active LEB Circuit Overtemperature Protection Internal Error Amplifier Pb−Free Packages are Available N1031 ALYW G 1 NCP 1031 ALYW G G DFN−8 MN SUFFIX CASE 488AF 1 A = Assembly Location L = Wafer Lot Y = Year W = Work Week G = Pb−Free Package (Note: Microdot may be in either location) PIN CONNECTIONS GND CT VFB COMP Features • • • • • • • • • • • • SO−8 D SUFFIX CASE 751 8 1 8 2 7 3 6 4 5 VDRAIN VCC UV OV (Top View) GND CT VFB COMP Ç Ç Ç Ç ÇÇ ÇÇ ÇÇ ÇÇ VDRAIN EP Flag VCC UV OV (Top View) ORDERING INFORMATION See detailed ordering and shipping information in the package dimensions section on page 19 of this data sheet. Typical Applications • • • • • POE (Power Over Ethernet)/PD. Refer to Application Note AND8247. Secondary Side Bias Supply for Isolated dc−dc Converters Stand Alone Low Power dc−dc Converter Low Power Bias Supply Low Power Boost Converter © Semiconductor Components Industries, LLC, 2014 August, 2021 − Rev. 12 1 Publication Order Number: NCP1030/D NCP1030, NCP1031 RSENSE GND VDRAIN Disable I1 + − CT Ramp CT LEB ISTART VCC Thermal Shutdown + 50 mV − S Reset Dominant Q Latch R 10 V + 3.0 V/3.5 V − 10 V + − Internal Bias + 7.5 V/10 V − − + Current Limit Comparator I2 = 3I1 10 V + S Reset Q Dominant R Latch − + − + 2.5 V − + − VFB Error Amplifier + − One Shot I Pulse O PWM Latch PWM Comparator + 2.5 V − 16 V + − + 6.5 V − UV 10 V OV 10 V 4.5 V COMP 2 kW 10 V Figure 1. NCP1030/31 Functional Block Diagram FUNCTIONAL PIN DESCRIPTION Pin Name Function Description 1 GND Ground 2 CT Oscillator Frequency Selection 3 VFB Feedback Input 4 COMP Error Amplifier Compensation Requires external compensation network between COMP and VFB pins. This pin is effectively grounded if faults are present. 5 OV Line Overvoltage Shutdown Line voltage (Vin) is scaled down using an external resistor divider such that the OV voltage reaches 2.5 V when line voltage reaches its maximum operating voltage. 6 UV Line Undervoltage Shutdown Line voltage is scaled down using an external resistor divider such that the UV voltage reaches 2.5 V when line voltage reaches its minimum operating voltage. 7 VCC Supply Voltage 8 VDRAIN Power Switch and Startup Circuits Ground reference pin for the circuit. An external capacitor connected to this pin sets the oscillator frequency up to 1 MHz. The oscillator can be synchronized to a higher frequency by charging or discharging CT to trip the internal 3.0 V/3.5 V comparator. If a fault condition exists, the power switch is disabled and the frequency is reduced by a factor of 7. The regulated voltage is scaled down to 2.5 V by means of a resistor divider. Regulation is achieved by comparing the scaled voltage to an internal 2.5 V reference. This pin is connected to an external capacitor for energy storage. During Turn−On, the startup circuit sources current to charge the capacitor connected to this pin. When the supply voltage reaches VCC(on), the startup circuit turns OFF and the power switch is enabled if no faults are present. An external winding is used to supply power after initial startup to reduce power dissipation. VCC should not exceed 16 V. This pin directly connects the Power Switch and Startup Circuits to one of the transformer windings. The internal High Voltage Power Switch Circuit is connected between this pin and ground. VDRAIN should not exceed 200 V. www.onsemi.com 2 NCP1030, NCP1031 COMP Voltage CT Ramp CT Charge Signal PWM Comparator Output Current Limit Propagation Delay PWM Latch Output Power Switch Circuit Gate Drive Current Limit Threshold Leading Edge Blanking Output Normal PWM Operating Range Output Overload Figure 2. Pulse Width Modulation Timing Diagram VCC(on) VCC(off) VCC(reset) 0V ISTART 0 mA 3.0 V VUV 0V 2.5 V VFB 0V VDRAIN 0V Power−up & standby Operation Normal Operation Output Overload Figure 3. Auxiliary Winding Operation with Output Overload Timing Diagram www.onsemi.com 3 NCP1030, NCP1031 MAXIMUM RATINGS Symbol Value Unit Power Switch and Startup Circuits Voltage Rating VDRAIN −0.3 to 200 V Power Switch and Startup Circuits Input Current − NCP1030 − NCP1031 IDRAIN 1.0 2.0 A VCC Voltage Range VCC −0.3 to 16 V All Other Inputs/Outputs Voltage Range VIO −0.3 to 10 V VCC and All Other Inputs/Outputs Current IIO 100 mA Operating Junction Temperature TJ −40 to 150 °C Storage Temperature Tstg −55 to 150 °C Power Dissipation (TJ = 25°C, 2.0 Oz., 1.0 Sq Inch Printed Circuit Copper Clad) DM Suffix, Plastic Package Case 846A D Suffix, Plastic Package Case 751 MN Suffix, Plastic Package Case 488AF Thermal Resistance, Junction to Air (2.0 Oz., 1.0 Sq Inch Printed Circuit Copper Clad) DM Suffix, Plastic Package Case 846A D Suffix, Plastic Package Case 751 MN Suffix, Plastic Package Case 488AF 0.582 0.893 1.453 RqJA 172 112 69 W °C/W Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected. A. This device contains ESD protection circuitry and exceeds the following tests: Pins 1−7: Human Body Model 2000V per MIL−STD−883, Method 3015. Pins 1−7: Machine Model Method 200 V. Pin 8 is connected to the High Voltage Startup and Power Switch Circuits and rated only to the maximum voltage rating of the part, or 200 V. B. This device contains Latchup protection and exceeds $100 mA per JEDEC Standard JESD78. www.onsemi.com 4 NCP1030, NCP1031 DC ELECTRICAL CHARACTERISTICS (VDRAIN = 48 V, VCC = 12 V, CT = 560 pF, VUV = 3 V, VOV = 2 V, VFB = 2.3 V, VCOMP = 2.5 V, TJ = −40°C to 125°C, typical values shown are for TJ = 25°C unless otherwise noted.) (Note 1) Symbol Characteristics Min Typ Max Unit STARTUP CONTROL Startup Circuit Output Current (VFB = VCOMP) NCP1030 TJ = 25°C VCC = 0 V VCC = VCC(on) − 0.2 V TJ = −40°C to 125°C VCC = 0 V VCC = VCC(on) − 0.2 V NCP1031 TJ = 25°C VCC = 0 V VCC = VCC(on) − 0.2 V TJ = −40°C to 125°C VCC = 0 V VCC = VCC(on) − 0.2 V ISTART mA 10 6.0 12.5 8.6 15 12 8.0 2.0 − − 16 13 13 8.0 16 12 19 16 11 4.0 − − 21 18 VCC Supply Monitor (VFB = 2.7 V) Startup Threshold Voltage (VCC Increasing) Minimum Operating VCC After Turn−on (VCC Increasing) Hysteresis Voltage VCC(on) VCC(off) VCC(hys) 9.6 7.0 − 10.2 7.6 2.6 10.6 8.0 − Undervoltage Lockout Threshold Voltage, VCC Decreasing (VFB = VCOMP) VCC(reset) 6.0 6.6 7.0 − 16.8 18.5 2.45 2.40 2.5 2.5 2.55 2.60 REGLINE − 1.0 5.0 mV Input Bias Current (VFB = 2.3 V) IVFB − 0.1 1.0 mA COMP Source Current ISRC 80 110 140 mA Minimum Startup Voltage (Pin 8) ISTART = 0.5 mA, VCC =VCC(on) − 0.2 V VSTART(min) V V V ERROR AMPLIFIER Reference Voltage (VCOMP = VFB, Follower Mode) TJ = 25°C TJ = −40°C to 125°C VREF Line Regulation (VCC = 8 V to 16 V, TJ = 25°C) COMP Sink Current (VFB = 2.7 V) V ISNK 200 550 900 mA COMP Maximum Voltage (ISRC = 0 mA) VC(max) 4.5 − − V COMP Minimum Voltage (ISNK = 0 mA, VFB = 2.7 V) VC(min) − − 1.0 V Open Loop Voltage Gain AVOL − 80 − dB Gain Bandwidth Product GBW − 1.0 − MHz Undervoltage Lockout (VFB = VCOMP) Voltage Threshold (Vin Increasing) Voltage Hysteresis Input Bias Current VUV VUV(hys) IUV 2.400 0.075 − 2.550 0.175 0 2.700 0.275 1.0 V V mA Overvoltage Lockout (VFB = VCOMP) Voltage Threshold (Vin Increasing) Voltage Hysteresis Input Bias Current VOV VOV(hys) IOV 2.400 0.075 − 2.550 0.175 0 2.700 0.275 1.0 V V mA LINE UNDER/OVERVOLTAGE DETECTOR Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 1. Production testing for NCP1030DMR2 is performed at 25°C only; limits at −40°C and 125°C are guaranteed by design. www.onsemi.com 5 NCP1030, NCP1031 DC ELECTRICAL CHARACTERISTICS (VDRAIN = 48 V, VCC = 12 V, CT = 560 pF, VUV = 3 V, VOV = 2 V, VFB = 2.3 V, VCOMP = 2.5 V, TJ = −40°C to 125°C, typical values shown are for TJ = 25°C unless otherwise noted.) (Note 2) Symbol Characteristics Min Typ Max 275 260 300 − 325 325 Unit OSCILLATOR Frequency (CT = 560 pF, Note 3) TJ = 25°C TJ = −40°C to 125°C fOSC1 kHz Frequency (CT = 100 pF) fOSC2 − 800 − kHz Charge Current (VCT = 3.25 V) ICT(C) − 215 − mA Discharge Current (VCT = 3.25 V) ICT(D) − 645 − mA Oscillator Ramp Peak Valley Vrpk Vrvly − − 3.5 3.0 − − DCMAX 70 75 80 V PWM COMPARATOR Maximum Duty Cycle % POWER SWITCH CIRCUIT Power Switch Circuit On−State Resistance (ID = 100 mA) NCP1030 TJ = 25°C TJ = 125°C NCP1031 TJ = 25°C TJ = 125°C RDS(on) Power Switch Circuit and Startup Circuit Breakdown Voltage (ID = 100 mA, TJ = 25°C) V(BR)DS Power Switch Circuit and Startup Circuit Off−State Leakage Current (VDRAIN = 200 V, VUV = 2.0 V) TJ = 25°C TJ = −40 to 125°C Switching Characteristics (VDS = 48 V, RL = 100 W) Rise Time Fall Time W − − 4.1 6.0 7.0 12 − − 2.1 3.5 3.0 6.0 200 − − IDS(off) mA − − 13 − 25 50 − − 22 24 − − 350 700 515 1050 680 1360 − 100 − TSHDN THYS − − 150 45 − − ICC1 2.0 3.0 4.0 ICC2 ICC3 − − 1.5 0.65 2.0 1.2 tr tf V ns CURRENT LIMIT AND OVER TEMPERATURE PROTECTION Current Limit Threshold (TJ = 25°C) NCP1030 (di/dt = 0.5 A/ms) NCP1031 (di/dt = 1.0 A/ms) ILIM Propagation Delay, Current Limit Threshold to Power Switch Circuit Output (Leading Edge Blanking plus Current Limit Delay) tPLH Thermal Protection (Note 4) Shutdown Threshold (TJ Increasing) Hysteresis mA ns °C TOTAL DEVICE Supply Current After UV Turn−On Power Switch Enabled Power Switch Disabled Non−Fault condition (VFB = 2.7 V) Fault Condition (VFB = 2.7 V, VUV = 2.0 V) 2. Production testing for NCP1030DMR2 is performed at 25°C only; limits at −40°C and 125°C are guaranteed by design. 3. Oscillator frequency can be externally synchronized to the maximum frequency of the device. 4. Guaranteed by design only. www.onsemi.com 6 mA NCP1030, NCP1031 TYPICAL CHARACTERISTICS 20 NCP1030 VDRAIN = 48 V TJ = 25°C 12.5 12.0 ISTART, STARTUP CURRENT (mA) ISTART, STARTUP CURRENT (mA) 13.0 11.5 11.0 10.5 10.0 9.5 9.0 8.5 8.0 0 2 4 6 8 13 12 11 0 2 4 6 8 20 ISTART, STARTUP CURRENT (mA) NCP1030 VDRAIN = 48 V 14 12 VCC = 0 V 10 8 6 VCC = VCC(on) − 0.2 V 4 2 −25 0 25 50 75 100 125 10 NCP1031 VDRAIN = 48 V 18 VCC = 0 V 16 14 12 10 VCC = VCC(on) − 0.2 V 8 6 4 2 0 −50 150 −25 0 25 50 75 100 125 TJ, JUNCTION TEMPERATURE (°C) TJ, JUNCTION TEMPERATURE (°C) Figure 6. NCP1030 Startup Current vs. Junction Temperature Figure 7. NCP1031 Startup Current vs. Junction Temperature 20 NCP1030 ISTART, STARTUP CURRENT (mA) ISTART, STARTUP CURRENT (mA) 14 Figure 5. NCP1031 Startup Current vs. Supply Voltage 0 −50 ISTART, STARTUP CURRENT (mA) 15 Figure 4. NCP1030 Startup Current vs. Supply Voltage 16 TJ = −40°C 10 8 TJ = 25°C 6 TJ = 125°C 4 2 VCC = VCC(on) − 0.2 V 0 16 VCC, SUPPLY VOLTAGE (V) 18 0 17 VCC, SUPPLY VOLTAGE (V) 20 12 18 10 10 NCP1031 VDRAIN = 48 V TJ = 25°C 19 25 50 75 100 125 150 175 NCP1031 18 TJ = −40°C 16 14 TJ = 25°C 12 10 TJ = 125°C 8 6 4 2 0 200 VCC = VCC(on) − 0.2 V 0 25 50 75 100 125 150 175 VDRAIN, DRAIN VOLTAGE (V) VDRAIN, DRAIN VOLTAGE (V) Figure 8. NCP1030 Startup Current vs. Drain Voltage Figure 9. NCP1031 Startup Current vs. Drain Voltage www.onsemi.com 7 150 200 NCP1030, NCP1031 TYPICAL CHARACTERISTICS 10.0 9.5 9.0 8.5 8.0 VSTART(min), MINIMUM STARTUP VOLTAGE (V) Minimum Operating Threshold 7.5 7.0 6.5 6.0 −50 −25 0 25 50 75 100 125 150 6.75 6.70 6.65 6.60 6.55 6.50 6.45 6.40 6.35 6.30 −50 0 25 50 75 100 125 TJ, JUNCTION TEMPERATURE (°C) Figure 10. Supply Voltage Thresholds vs. Junction Temperature Figure 11. Undervoltage Lockout Threshold vs. Junction Temperature 150 2.70 VCC = VCC(on) − 0.2 V ISTART = 0.5 mA 19.5 19.0 18.5 18.0 17.5 17.0 16.5 16.0 0 −25 25 50 75 100 125 150 2.65 VCC = 12 V 2.60 2.55 2.50 2.45 2.40 2.35 2.30 2.25 2.20 −50 −25 0 25 50 75 100 125 TJ, JUNCTION TEMPERATURE (°C) TJ, JUNCTION TEMPERATURE (°C) Figure 12. Minimum Startup Voltage vs. Junction Temperature Figure 13. Reference Voltage vs. Junction Temperature 150 840 145 VCC = 12 V VCOMP = 2.5 V VFB = 2.3 V 140 135 130 125 120 115 110 105 100 95 −50 −25 TJ, JUNCTION TEMPERATURE (°C) 20.0 15.5 15.0 −50 6.80 ISNK, COMP SINK CURRENT (mA) ISRC, COMP SOURCE CURRENT (mA) Startup Threshold VREF, REFERENCE VOLTAGE (V) VCC, SUPPLY VOLTAGE (V) 10.5 VCC(reset), UNDERVOLTAGE LOCKOUT THRESHOLD (V) 11.0 −25 0 25 50 75 100 740 690 640 590 540 490 440 390 340 −50 125 150 VCC = 12 V VCOMP = 2.5 V VFB = 2.7 V 790 TJ, JUNCTION TEMPERATURE (°C) −25 0 25 50 75 100 125 150 TJ, JUNCTION TEMPERATURE (°C) Figure 14. COMP Source Current vs. Junction Temperature Figure 15. COMP Sink Current vs. Junction Temperature www.onsemi.com 8 NCP1030, NCP1031 TYPICAL CHARACTERISTICS 220 VUV/OV(hys), UNDER/OVERVOLTAGE HYSTERESIS (mV) VUV/OV, LINE UNDER/OVERVOLTAGE THRESHOLDS (V) 2.600 2.575 2.550 2.525 2.500 2.475 2.450 2.425 2.400 2.375 2.350 −50 −25 0 25 50 75 100 125 150 200 190 180 170 160 150 140 130 120 −50 −25 TJ, JUNCTION TEMPERATURE (°C) Figure 16. Line Under/Overvoltage Thresholds vs. Junction Temperature fOSC, OSCILLATOR FREQUENCY (kHz) VCC = 12 V TJ = 25°C 900 800 700 600 500 400 300 200 100 0 0 200 400 600 800 1000 VCC = 12 V CT = 47 pF 900 800 700 600 CT = 220 pF 500 400 300 CT = 1000 pF 200 100 −50 −25 RDS(on), POWER SWITCH CIRCUIT ON RESISTANCE (W) DCMAX, MAXIMUM DUTY CYCLE (%) 75.0 74.5 fOSC = 1000 kHz 74.0 73.5 73.0 72.5 72.0 −50 −25 50 75 100 125 150 8 fOSC = 200 kHz 75.5 25 Figure 19. Oscillator Frequency vs. Junction Temperature VCC = 12 V 76.0 0 TJ, JUNCTION TEMPERATURE (°C) Figure 18. Oscillator Frequency vs. Timing Capacitor 76.5 150 1100 1000 CT, TIMING CAPACITOR (pF) 77.0 0 25 50 75 100 125 TJ, JUNCTION TEMPERATURE (°C) Figure 17. Line Under/Overvoltage Hysteresis vs. Junction Temperature 1000 fOSC, OSCILLATOR FREQUENCY (kHz) 210 100 125 0 25 50 75 TJ, JUNCTION TEMPERATURE (°C) 150 Figure 20. Maximum Duty Cycle vs. Junction Temperature VCC = 12 V ID = 100 mA 7 NCP1030 6 5 4 3 NCP1031 2 1 0 −50 −25 100 125 0 25 50 75 TJ, JUNCTION TEMPERATURE (°C) 150 Figure 21. Power Switch Circuit On Resistance vs. Junction Temperature www.onsemi.com 9 NCP1030, NCP1031 TYPICAL CHARACTERISTICS 40 IDS(off), POWER SWITCH AND STARTUP CIRCUITS LEAKAGE CURRENT (mA) COUT, OUTPUT CAPACITANCE (pF) 1000 NCP1031 100 NCP1030 10 0 40 80 120 160 VDRAIN, DRAIN VOLTAGE (V) 200 VCC = 12 V 35 30 25 TJ = −40°C 20 15 TJ = 25°C 10 TJ = 125°C 5 0 0 600 575 NCP1030 Current Slew Rate = 500 mA/ms 550 525 500 475 450 425 400 375 350 −50 −25 0 25 50 75 100 125 150 1150 NCP1031 Current Slew Rate = 1 A/ms 1100 1050 1000 950 900 850 800 750 700 −50 −25 0 25 50 75 100 125 150 TJ, JUNCTION TEMPERATURE (°C) Figure 24. NCP1030 Current Limit Threshold vs. Junction Temperature Figure 25. NCP1031 Current Limit Threshold vs. Junction Temperature 600 1200 575 NCP1030 TJ = 25°C 550 525 ILIM, CURRENT LIMIT THRESHOLD (mA) ILIM, CURRENT LIMIT THRESHOLD (mA) 300 1200 TJ, JUNCTION TEMPERATURE (°C) TJ = 25°C 1150 NCP1031 1100 1050 500 1000 475 450 425 400 375 350 250 Figure 23. Power Switch Circuit and Startup Circuit Leakage Current vs. Drain Voltage ILIM, CURRENT LIMIT THRESHOLD (mA) ILIM, CURRENT LIMIT THRESHOLD (mA) Figure 22. Power Switch Circuit Output Capacitance vs. Drain Voltage 200 100 150 VDRAIN, DRAIN VOLTAGE (V) 50 375 400 425 450 475 500 950 900 850 800 750 700 750 CURRENT SLEW RATE (mA/mS) 800 850 900 950 1000 CURRENT SLEW RATE (mA/mS) Figure 26. NCP1030 Current Limit Threshold vs. Current Slew Rate Figure 27. NCP1031 Current Limit Threshold vs. Current Slew Rate www.onsemi.com 10 NCP1030, NCP1031 3.9 3.7 4.0 VDRAIN = 48 V TJ = 25°C CT = 560 pF ICC, SUPPLY CURRENT (mA) 4.1 3.5 3.3 3.1 2.9 2.7 2.5 10 11 12 13 14 15 3.0 2.5 VUV = 3.0 V, VFB = 2.3 V 2.0 1.5 VUV = 3.0 V, VFB = 2.7 V 1.0 0.5 0 −50 16 VCC = 12 V CT = 560 pF 3.5 VUV = 2.0 V −25 VCC, SUPPLY VOLTAGE (V) 0 25 TJ = 25 °C 9 8 7 6 5 NCP1031 4 NCP1030 3 300 75 100 125 Figure 29. Supply Current vs. Junction Temperature 10 2 200 50 TJ, JUNCTION TEMPERATURE (°C) Figure 28. Operating Supply Current vs. Supply Voltage ICC, POWER SUPPLY CURRENT (mA) ICC1, OPERATING SUPPLY CURRENT (mA) TYPICAL CHARACTERISTICS 400 500 600 700 800 900 fOSC, OSCILLATOR FREQUENCY (kHz) Figure 30. Operating Supply Current vs. Oscillator Frequency www.onsemi.com 11 1000 150 NCP1030, NCP1031 + Vout − + Vin − SECONDARY SIDE CONTROL NCP103x GND VDRAIN CT VCC VFB UV COMP OV VBIAS GND Figure 31. Secondary Side Bias Supply Configuration VCC + Vin − NCP103x GND VDRAIN VCC CT VFB UV COMP OV VCC + Vout − Figure 32. Boost Circuit Configuration www.onsemi.com 12 NCP1030, NCP1031 OPERATING DESCRIPTION Introduction Forward: The NCP1030 and NCP1031 are a family of miniature monolithic voltage−mode switching regulators designed for isolated and non−isolated bias supply applications. The internal startup circuit and the MOSFET are rated at 200 V, making them ideal for 48 V telecom and 42 V automotive applications. In addition, the NCP103x family can operate from an existing 12 V supply. This controller family is optimized for operation up to 1 MHz. The NCP103x family incorporates in a single IC all the active power, control logic and protection circuitry required to implement, with a minimum of external components, several switching regulator applications, such as a secondary side bias supply or a low power dc−dc converter. The NCP1030 is available in the space saving Micro8t package and is targeted for applications requiring up to 3 W. The NCP1031 is targeted for applications up to 6 W and is available in the SO−8 package. The NCP103x includes an extensive set of features including over temperature protection, cycle by cycle current limit, individual line under and overvoltage detection comparators with hysteresis, and regulator output undervoltage lockout with hysteresis, providing full protection during fault conditions. A description of each of the functional blocks is given below, and the representative block diagram is shown in Figure 2. OUT@ P Ǔ cos −1 ǒ1 * DC@V @N V CCC + N in S 2.6 ǸL C OUT OUT @ Ibias (eq. 1) where, Ibias is the bias current supplied by the VCC capacitor including the IC bias current (ICC1) and any additional current used to bias the feedback resistors (if used). After initial startup, the VCC pin should be biased above VCC(off) using an auxiliary winding. This will prevent the startup regulator from turning ON and reduce power dissipation. Also, the load should not be directly connected to the VCC capacitor. Otherwise, the load may override the startup circuit. Figure 33 shows the recommended configuration for a non−isolated flyback converter. + Vout − + Vin − NCP103x GND VDRAIN CT VCC VFB UV COMP OV Startup Circuit and Undervoltage Lockout The NCP103x contains an internal 200 V startup regulator that eliminates the need for external startup components. The startup regulator consists of a constant current source that supplies current from the input line (Vin) to the capacitor on the VCC pin (CCC). Once the VCC voltage reaches approximately 10 V, the startup circuit is disabled and the Power Switch Circuit is enabled if no faults are present. During this self−bias mode, power to the NCP103x is supplied by the VCC capacitor. The startup regulator turns ON again once VCC reaches 7.5 V. This “7.5−10” mode of operation is known as Dynamic Self Supply (DSS). The NCP1030 and NCP1031 startup currents are 12 mA and 16 mA, respectively. If VCC falls below 7.5 V, the device enters a re−start mode. While in the re−start mode, the VCC capacitor is allowed to discharge to 6.5 V while the Power Switch is enabled. Once the 6.5 V threshold is reached, the Power Switch Circuit is disabled and the startup regulator is enabled to charge the VCC capacitor. The Power Switch is enabled again once the VCC voltage reaches 10 V. Therefore, the external VCC capacitor must be sized such that a voltage greater than 7.5 V is maintained on the VCC capacitor while the converter output reaches regulation. Otherwise, the converter will enter the re−start mode. Equation (1) provides a guideline for the selection of the VCC capacitor for a forward converter; Figure 33. Non−Isolated Bias Supply Configuration The maximum voltage rating of the startup circuit is 200 V. Power dissipation should be observed to avoid exceeding the maximum power dissipation of the package. Error Amplifier The internal error amplifier (EA) regulates the output voltage of the bias supply. It compares a scaled output voltage signal to an internal 2.5 V reference (VREF) connected to its non−inverting input. The scaled signal is fed into the feedback pin (VFB) which is the inverting input of the error amplifier. The output of the error amplifier is available for frequency compensation and connection to the PWM comparator through the COMP pin. To insure normal operation, the EA compensation should be selected such that the EA frequency response crosses 0 dB below 80 kHz. The error amplifier input bias current is less than 1 mA over the operating range. The output source and sink currents are typically 110 mA and 550 mA, respectively. Under load transient conditions, COMP may need to move from the bottom to the top of the CT Ramp. A large current is required to complete the COMP swing if small resistors or large capacitors are used to implement the compensation network. In which case, the COMP swing will www.onsemi.com 13 NCP1030, NCP1031 be limited by the EA sink current, typically 110 mA. Optimum transient response is obtained if the compensation components allow COMP to swing across its operating range in 1 cycle. is discharging, guaranteeing a maximum duty cycle of 75 % as shown in Figure 35. COMP CT Ramp Line Under and Overvoltage Detector The NCP103x incorporates individual line undervoltage (UV) and overvoltage (OV) shutdown circuits. The UV and OV thresholds are 2.5 V. A fault is present if the UV is below 2.5 V or if the OV voltage is above 2.5 V. The UV/OV detectors incorporate 175 mV hysteresis to prevent noise from triggering the shutdown circuits. The UV/OV circuits can be biased using an external resistor divider from the input line as shown in Figure 34. The UV/OV pins should be bypassed using a capacitor to prevent triggering the UV or OV circuits during normal switching operation. Power Switch Enabled CT Charge Signal Figure 35. Maximum Duty Cycle vs COMP Figure 18 shows the relationship between the operating frequency and CT. If an UV fault is present, both ICT(C) and ICT(D) are reduced by a factor of 7, thus reducing the operating frequency by the same factor. The oscillator can be synchronized to a higher frequency by capacitively coupling a synchronization pulse into the CT pin. In sync mode, the voltage on the CT pin needs to be driven above 3.5 V to trigger the internal comparator and complete the CT charging period. However, pulsing the CT pin before it reaches 3.5 V will reduce the p−p amplitude of the CT Ramp as shown in Figure 36. R1 + R2 R3 75% 25 % Vin + VOV − Max Duty Cycle VUV − 3.0 V/3.5 V Comparator Reset Sync Pulse Figure 34. UV/OV Resistor Divider from the Input Line T2 (f2) 3.5 V The resistor divider must be sized to enable the controller once Vin is within the required operating range. While a UV or OV fault is present, switching is not allowed and the COMP pin is effectively grounded. Either of these comparators can be used for a different function if UV or OV functions are not needed. For example, the UV/OV detectors can be used to implement an enable or disable function. If positive logic is used, the enable signal is applied to the UV pin while the OV pin is grounded. If negative logic is used, the disable signal is applied to the OV pin while biasing the UV pin from VCC using a resistor divider. CT Ramp 3.0 V T1 (f1) T2 (f2) Free Running Mode CT Voltage Range in Sync Sync Mode Figure 36. External Frequency Synchronization Waveforms The oscillator frequency should be set no more that 25% below the target sync frequency to maintain an adequate voltage range and provide good noise immunity. A possible circuit to synchronize the oscillator is shown in Figure 37. Oscillator The oscillator is optimized for operation up to 1 MHz and its frequency is set by the external timing capacitor (CT) connected to the CT pin. The oscillator has two modes of operation, free running and synchronized (sync). While in free running mode, an internal current source sequentially charges and discharges CT generating a voltage ramp between 3.0 V and 3.5 V. Under normal operating conditions, the charge (ICT(C)) and discharge (ICT(D)) currents are typically 215 mA and 645 mA, respectively. The charge:discharge current ratio of 1:3 discharges CT in 25 % of the total period. The Power Switch is disabled while CT 5V CT CT R1 C1 2 R2 Figure 37. External Frequency Synchronization Circuit. www.onsemi.com 14 NCP1030, NCP1031 PWM Comparator and Latch provides better current limit control compared to a fixed blanking period. The current limit propagation delay time is typically 100 ns. This time is measured from when an overcurrent fault appears at the Power Switch Circuit drain, to the start of the turn−off transition. Propagation delay must be factored in the transformer design to avoid transformer saturation. The Pulse Width Modulator (PWM) Comparator compares the error amplifier output (COMP) to the CT Ramp and generates a proportional duty cycle. The Power Switch is enabled while the CT Ramp is below COMP as shown in Figure 35. Once the CT Ramp reaches COMP, the Power Switch is disabled. If COMP is at the bottom of the CT Ramp, the converter operates at minimum duty cycle. While COMP increases, the duty cycle increases, until COMP reaches the peak of the CT Ramp, at which point the controller operates at maximum duty cycle. The CT Charge Signal is filtered through a One Shot Pulse Generator to set the PWM Latch and enable switching at the beginning of each period. Switching is allowed while the CT Ramp is below COMP and a current limit fault is not present. The PWM Latch and Comparator propagation delay is typically 150 ns. If the system is designed to operate with a minimum ON time less than 150 ns, the converter will skip pulses. Skipping pulses is usually not a problem, unless operating at a frequency close to the audible range. Skipping pulses is more likely when operating at high frequencies during high line and minimum load condition. A series resistor is included for ESD protection between the EA output and the COMP pin. Under normal operation, a 220 mV offset is observed between the CT Ramp and the COMP crossing points. This is not a problem as the series resistor does not interact with the error amplifier transfer function. Thermal Shutdown Internal Thermal Shutdown circuitry is provided to protect the integrated circuit in the event the maximum junction temperature is exceeded. When activated, typically at 150_C, the Power Switch Circuit is disabled. Once the junction temperature falls below 105_C, the NCP103x is allowed to resume normal operation. This feature is provided to prevent catastrophic failures from accidental device overheating. It is not intended to be used as a substitute for proper heatsinking. Application Considerations A 2 W bias supply for a 48 V telecom system was designed using the NCP1030. The bias supply generates an isolated 12 V output. The circuit schematic is shown in Figure 38. Application Note AND8119/D describes the design of the bias supply. 1:2.78 MBRA160T3 + 35−76V − The NCP103x monolithically integrates a 200 V Power Switch Circuit with control logic circuitry. The Power Switch Circuit is designed to directly drive the converter transformer. The characteristics of the Power Switch Circuit are well known. Therefore, the gate drive is tailored to control switching transitions and help limit electromagnetic interference (EMI). The Power Switch Circuit is capable of switching 200 V. The Power Switch Circuit incorporates SENSEFET™ technology to monitor the drain current. A sense voltage is generated by driving a sense element, RSENSE, with a current proportional to the drain current. The sense voltage is compared to an internal reference voltage on the non−inverting input of the Current Limit Comparator. If the sense voltage exceeds the reference level, the comparator resets the PWM Latch and switching is terminated. The NCP1030 and NCP1031 drain current limit thresholds are 0.5 A and 1.0 A, respectively. Each time the Power Switch Circuit turns ON, a narrow voltage spike appears across RSENSE. The spike is due to the Power Switch Circuit gate to source capacitance, transformer interwinding capacitance, and output rectifier recovery time. This spike can cause a premature reset of the PWM Latch. A proprietary active Leading Edge Blanking (LEB) Circuit masks the current signal to prevent the voltage spike from resetting the PWM Latch. The active LEB masks the current signal until the Power Switch turn ON transition is complete. The adaptive LEB period 2.2 0.022 680p 499 22 NCP1030 GND VDRAIN VCC CT UV VFB OV COMP 2.2 680p 10 4k99 45k3 0.01 0.01 + 12V − MBRA160T3 1M 100 p Current Limit Comparator and Power Switch Circuit MURA110T3 2.2 1k30 34k 0.033 10k Figure 38. 2 W Isolated Bias Supply Schematic VCC Excursion and Compensation Some applications may regulate nodes that are not directly connected to VCC, such as the secondary or AUX1 shown in Figure 39. The regulation of another node can result in loose regulation of VCC. The result of loose regulation is that VCC can rise to unacceptable levels when a heavy load is applied to the regulated node and a relatively light load is applied to the VCC pin. The large voltage can lead to damage of the NCP1030/31 or other downstream parts. www.onsemi.com 15 NCP1030, NCP1031 Cin Lsec To reduce the problem, a series resistance can be added to allow the part to clamp VCC with the characteristic current draw of the regulator as the voltage increases. The resistor value required is such that it will not implead normal operation but will prevent damage to the device during transients, startup, current limits, and over loads. The proper sizing of the series resistance starts with an examination of the current draw by the NCP1031 at the desired operating frequency as shown in Figure 40. The resistor value should be such that it does not exceed the VCC maximum voltage of 16 V during the worst case overshoot. Further, the voltage must not fall below the VCC minimum operating voltage of 7 V during heavy loading, transients, or line disturbances. A series resistance calculated example of operation at 310 kHz is shown in Equation 2. In this case, a 1.96 kW resistor can be used to make the VCC node more robust. COUT D1 D2 Lpri CAUX1 Lbias D2 CAUX2 RC UV R4 VDRAIN R3 VCC OV CVCC CC CT GND NCP1032 COMP RC R1 CP VFB NCP1030/31 CCT Calculation of RC R2 16 V w V OUTaux * I C_current @ RC w 7.0 V (eq. 2) V OUTaux * 16 V + RC I C_current Figure 39. Typical Application with the Series Resistance Added to Control VCC 24 V * 16 V + 1.96 kW 4.075 mA 12.5 V * 7.0 V + 2.07 kW 2.65 mA 11 VCC Current Draw (mA) 10 560 pF 310kHz 470 pF 350kHz 390 pF 390kHz 330 pF 450kHz 270 pF 500kHz 220 pF 573kHz 180 pF 635 kHz 150 pF 702kHz 100 pF 905kHz 82 pF 1MHz 9 8 7 6 5 4 18 17 16 15 14 13 12 11 10 9 8 2 7 3 VCC Voltage (V) Figure 40. NCP1031 Current Draw vs. Frequency and VCC Voltage cannot eliminate the possibility completely. A zener diode can be added along with the series resistance value calculated from Equation 2 which can be split into RC1 and RC2 as shown in Figure 41. If the OV pin is not used, it can be connected to the VCC node to monitor the voltage and suspend switching if the voltage exceeds a predefined level. The addition of the ROV1 and ROV2 will add a current draw from VAUX and will increase the voltage drop across RC. The series resistor needs to be coupled with proper sizing of the auxiliary winding and VCC capacitance. The CAUX1 and CAUX2 should be approximately the same size where the CVCC should be between 1/10 to 1/100 the value of CAUX2. The smaller size of CVCC serves to reduce the amount of energy available to the internal clamping structures in the event of a large unforeseen over voltage. Proper sizing of capacitance and adding a series resistance can reduce the likelihood of an over voltage on the VCC, but www.onsemi.com 16 NCP1030, NCP1031 Lbias D2 CAUX1 CAUX2 D2 D2 Lbias CAUX1 CAUX2 D2 RC1 RC RC2 NCP1030/31 NCP1030/31 VCC VCC CVCC CVCC GND ROV1 OV ROV2 GND Figure 41. Zener Clamp or OV Protection The compensation of the NCP1031/30 should be completed with the loop response, the transient response, and the amplifier in mind. The amplifier can source 110 mA and sink 550 mA typical. Internally the current sink that pulls down the amplifier has an on resistance of 2.45 kW and an ESD resistance of 1.74 kW as shown in Figure 42. The two resistances combine to create a maximum pull down current that changes with comp voltage as shown in Figure 43 and Figure 44. 3.5 VOUT 3.0 R1 R2 C1 C2 COMP 5V Rail Rf FB RESD 1.74 kW EA 2.5V COMP VOLTAGE (V) C3 R3 5V Rail PWM COMP 2.45 kW 2.5 2.0 1.5 1.0 0.5 0 −25 75 Figure 42. Internal Error Amplifier Structure 175 275 375 SINK CURRENT (mA) 475 700 600 500 400 300 200 100 0 -100 -200 4.5V 3.5V 2.5V 1.5V 2.6 2.59 2.58 2.57 2.56 2.55 VFB(V) 2.54 2.53 2.52 2.51 2.5 2.49 2.48 2.47 2.46 1.0V 2.45 Amplifier Current (uA) Figure 43. Sink Current vs. Comp Voltage 0.5V Figure 44. Amplifier Sink Current with Comp at Steady Voltage vs Feedback Voltage www.onsemi.com 17 575 NCP1030, NCP1031 One source of overshoot in the system can occur during startup where the reference voltage starts at 2.5 V and the system PWM regulates to the desired output voltage. The power is limited to the system by the internally set current limit. Since the voltage feedback loop sees the output voltage is lower than it should be, the COMP voltage slews up to increase the duty cycle, but the duty cycle is controlled by the pulse by pulse current limit. Once regulated output voltage is reached, the current loop will maintain control for the time it takes the COMP pin to slew from 5 V to 3.25 V where the voltage loop takes control and the pulse by pulse current limit is no longer limiting the system. The same is true for an overload or current limit. If the COMP voltage has reached a steady state value of 5 V, the required compensation value needed to slew from 5 V to 3.25 V is shown in Equation 3. Equation 3 is true if the feedback node has very low impedance at 2.5 V. For comparison, the decay from 5 V to 3.25 V in network A occurs in 259 ns and network B occurs in 12.2 ms although they have a very similar frequency response. RC1 + CP 100 pF I PULL_DOWN 5 V * 3.25 V 500 mA VAUX R1 VFB A R2 CC 820 pF NCP1030/31 RC1 432 W CP 18 nF COMP GND V COMP_INIT * V COMP_FINAL 300 ns + 100 pF @ RC1 2.5 kW (eq. 3) 5 V * 3.25 V 500 mA Time + CP @ COMP GND I PULL_DOWN 3.5 kW + CC 22 nF NCP1030/31 V COMP_INIT * V COMP_FINAL VAUX CF 1.5 nF R1 VFB B RF 215 W R2 Figure 45. Compensation for Good Transient Response When considering compensation and overshoot, the designer should follow a few rules for a better result. 1. If the current flowing through R1 and R2 is 10X larger than 620 mA then the RF and CF contribution to the large signal is small. a.) If RF is small (1 W -100 W) there is only a small DC shift from RC1. b.) To create a large DC shift down, increase RF (1 kW -10 kW). 2. Keep CP small (CP < 1 nF) or it will slow the large signal response of the converter. 3. CF should be less than 22 nF. 4. RC1 should be 2.7 k < RC1 < 100 k. www.onsemi.com 18 NCP1030, NCP1031 ORDERING INFORMATION Package Shipping† Micro8 4000 / Tape & Reel Micro8 (Pb−Free) 4000 / Tape & Reel SOIC−8 2500 / Tape & Reel NCP1031DR2G SOIC−8 (Pb−Free) 2500 / Tape & Reel NCP1031MNTXG DFN8 (Pb−Free) 4000 / Tape & Reel Device NCP1030DMR2 NCP1030DMR2G NCP1031DR2 †For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specifications Brochure, BRD8011/D. SENSEFET is a registered trademark of Semiconductor Components Industries, LLC dba “onsemi” or its affiliates and/or subsidiaries in the United States and/or other countries. www.onsemi.com 19 MECHANICAL CASE OUTLINE PACKAGE DIMENSIONS DFN8, 4x4 CASE 488AF−01 ISSUE C 1 SCALE 2:1 A B D PIN ONE REFERENCE 2X 0.15 C 2X 0.15 C 0.10 C 8X ÉÉ ÉÉ ÉÉ 0.08 C DETAIL A E OPTIONAL CONSTRUCTIONS EXPOSED Cu DETAIL B ÇÇÇÇ (A3) A A1 C D2 ÇÇÇÇ e 8X SEATING PLANE ÉÉÉ ÉÉÉ ÇÇÇ A3 A1 ALTERNATE CONSTRUCTIONS 8X MILLIMETERS MIN MAX 0.80 1.00 0.00 0.05 0.20 REF 0.25 0.35 4.00 BSC 1.91 2.21 4.00 BSC 2.09 2.39 0.80 BSC 0.20 −−− 0.30 0.50 −−− 0.15 XXXXXX XXXXXX ALYWG G E2 5 DIM A A1 A3 b D D2 E E2 e K L L1 GENERIC MARKING DIAGRAM* L 4 ÇÇÇÇ 8 MOLD CMPD DETAIL B SIDE VIEW K ÇÇÇ ÇÇÇ ÉÉÉ TOP VIEW 1 NOTES: 1. DIMENSIONS AND TOLERANCING PER ASME Y14.5M, 1994. 2. CONTROLLING DIMENSION: MILLIMETERS. 3. DIMENSION b APPLIES TO PLATED TERMINAL AND IS MEASURED BETWEEN 0.15 AND 0.30MM FROM TERMINAL TIP. 4. COPLANARITY APPLIES TO THE EXPOSED PAD AS WELL AS THE TERMINALS. 5. DETAILS A AND B SHOW OPTIONAL CONSTRUCTIONS FOR TERMINALS. L L L1 NOTE 4 DETAIL A DATE 15 JAN 2009 b XXXX = Specific Device Code A = Assembly Location L = Wafer Lot Y = Year W = Work Week G = Pb−Free Package (Note: Microdot may be in either location) 0.10 C A B 0.05 C NOTE 3 BOTTOM VIEW SOLDERING FOOTPRINT* 2.21 8X *This information is generic. Please refer to device data sheet for actual part marking. Pb−Free indicator, “G” or microdot “ G”, may or may not be present. 0.63 4.30 2.39 PACKAGE OUTLINE 8X 0.35 0.80 PITCH DIMENSIONS: MILLIMETERS *For additional information on our Pb−Free strategy and soldering details, please download the ON Semiconductor Soldering and Mounting Techniques Reference Manual, SOLDERRM/D. DOCUMENT NUMBER: DESCRIPTION: 98AON15232D DFN8, 4X4, 0.8P Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red. PAGE 1 OF 1 ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. ON Semiconductor does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com MECHANICAL CASE OUTLINE PACKAGE DIMENSIONS SOIC−8 NB CASE 751−07 ISSUE AK 8 1 SCALE 1:1 −X− DATE 16 FEB 2011 NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. 3. DIMENSION A AND B DO NOT INCLUDE MOLD PROTRUSION. 4. MAXIMUM MOLD PROTRUSION 0.15 (0.006) PER SIDE. 5. DIMENSION D DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE DAMBAR PROTRUSION SHALL BE 0.127 (0.005) TOTAL IN EXCESS OF THE D DIMENSION AT MAXIMUM MATERIAL CONDITION. 6. 751−01 THRU 751−06 ARE OBSOLETE. NEW STANDARD IS 751−07. A 8 5 S B 0.25 (0.010) M Y M 1 4 −Y− K G C N X 45 _ SEATING PLANE −Z− 0.10 (0.004) H M D 0.25 (0.010) M Z Y S X J S 8 8 1 1 IC 4.0 0.155 XXXXX A L Y W G IC (Pb−Free) = Specific Device Code = Assembly Location = Wafer Lot = Year = Work Week = Pb−Free Package XXXXXX AYWW 1 1 Discrete XXXXXX AYWW G Discrete (Pb−Free) XXXXXX = Specific Device Code A = Assembly Location Y = Year WW = Work Week G = Pb−Free Package *This information is generic. Please refer to device data sheet for actual part marking. Pb−Free indicator, “G” or microdot “G”, may or may not be present. Some products may not follow the Generic Marking. 1.270 0.050 SCALE 6:1 INCHES MIN MAX 0.189 0.197 0.150 0.157 0.053 0.069 0.013 0.020 0.050 BSC 0.004 0.010 0.007 0.010 0.016 0.050 0 _ 8 _ 0.010 0.020 0.228 0.244 8 8 XXXXX ALYWX G XXXXX ALYWX 1.52 0.060 0.6 0.024 MILLIMETERS MIN MAX 4.80 5.00 3.80 4.00 1.35 1.75 0.33 0.51 1.27 BSC 0.10 0.25 0.19 0.25 0.40 1.27 0_ 8_ 0.25 0.50 5.80 6.20 GENERIC MARKING DIAGRAM* SOLDERING FOOTPRINT* 7.0 0.275 DIM A B C D G H J K M N S mm Ǔ ǒinches *For additional information on our Pb−Free strategy and soldering details, please download the ON Semiconductor Soldering and Mounting Techniques Reference Manual, SOLDERRM/D. STYLES ON PAGE 2 DOCUMENT NUMBER: DESCRIPTION: 98ASB42564B SOIC−8 NB Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red. PAGE 1 OF 2 onsemi and are trademarks of Semiconductor Components Industries, LLC dba onsemi or its subsidiaries in the United States and/or other countries. onsemi reserves the right to make changes without further notice to any products herein. onsemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does onsemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. onsemi does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com SOIC−8 NB CASE 751−07 ISSUE AK DATE 16 FEB 2011 STYLE 1: PIN 1. EMITTER 2. COLLECTOR 3. COLLECTOR 4. EMITTER 5. EMITTER 6. BASE 7. BASE 8. EMITTER STYLE 2: PIN 1. COLLECTOR, DIE, #1 2. COLLECTOR, #1 3. COLLECTOR, #2 4. COLLECTOR, #2 5. BASE, #2 6. EMITTER, #2 7. BASE, #1 8. EMITTER, #1 STYLE 3: PIN 1. DRAIN, DIE #1 2. DRAIN, #1 3. DRAIN, #2 4. DRAIN, #2 5. GATE, #2 6. SOURCE, #2 7. GATE, #1 8. SOURCE, #1 STYLE 4: PIN 1. ANODE 2. ANODE 3. ANODE 4. ANODE 5. ANODE 6. ANODE 7. ANODE 8. COMMON CATHODE STYLE 5: PIN 1. DRAIN 2. DRAIN 3. DRAIN 4. DRAIN 5. GATE 6. GATE 7. SOURCE 8. SOURCE STYLE 6: PIN 1. SOURCE 2. DRAIN 3. DRAIN 4. SOURCE 5. SOURCE 6. GATE 7. GATE 8. SOURCE STYLE 7: PIN 1. INPUT 2. EXTERNAL BYPASS 3. THIRD STAGE SOURCE 4. GROUND 5. DRAIN 6. GATE 3 7. SECOND STAGE Vd 8. FIRST STAGE Vd STYLE 8: PIN 1. COLLECTOR, DIE #1 2. BASE, #1 3. BASE, #2 4. COLLECTOR, #2 5. COLLECTOR, #2 6. EMITTER, #2 7. EMITTER, #1 8. COLLECTOR, #1 STYLE 9: PIN 1. EMITTER, COMMON 2. COLLECTOR, DIE #1 3. COLLECTOR, DIE #2 4. EMITTER, COMMON 5. EMITTER, COMMON 6. BASE, DIE #2 7. BASE, DIE #1 8. EMITTER, COMMON STYLE 10: PIN 1. GROUND 2. BIAS 1 3. OUTPUT 4. GROUND 5. GROUND 6. BIAS 2 7. INPUT 8. GROUND STYLE 11: PIN 1. SOURCE 1 2. GATE 1 3. SOURCE 2 4. GATE 2 5. DRAIN 2 6. DRAIN 2 7. DRAIN 1 8. DRAIN 1 STYLE 12: PIN 1. SOURCE 2. SOURCE 3. SOURCE 4. GATE 5. DRAIN 6. DRAIN 7. DRAIN 8. DRAIN STYLE 13: PIN 1. N.C. 2. SOURCE 3. SOURCE 4. GATE 5. DRAIN 6. DRAIN 7. DRAIN 8. DRAIN STYLE 14: PIN 1. N−SOURCE 2. N−GATE 3. P−SOURCE 4. P−GATE 5. P−DRAIN 6. P−DRAIN 7. N−DRAIN 8. N−DRAIN STYLE 15: PIN 1. ANODE 1 2. ANODE 1 3. ANODE 1 4. ANODE 1 5. CATHODE, COMMON 6. CATHODE, COMMON 7. CATHODE, COMMON 8. CATHODE, COMMON STYLE 16: PIN 1. EMITTER, DIE #1 2. BASE, DIE #1 3. EMITTER, DIE #2 4. BASE, DIE #2 5. COLLECTOR, DIE #2 6. COLLECTOR, DIE #2 7. COLLECTOR, DIE #1 8. COLLECTOR, DIE #1 STYLE 17: PIN 1. VCC 2. V2OUT 3. V1OUT 4. TXE 5. RXE 6. VEE 7. GND 8. ACC STYLE 18: PIN 1. ANODE 2. ANODE 3. SOURCE 4. GATE 5. DRAIN 6. DRAIN 7. CATHODE 8. CATHODE STYLE 19: PIN 1. SOURCE 1 2. GATE 1 3. SOURCE 2 4. GATE 2 5. DRAIN 2 6. MIRROR 2 7. DRAIN 1 8. MIRROR 1 STYLE 20: PIN 1. SOURCE (N) 2. GATE (N) 3. SOURCE (P) 4. GATE (P) 5. DRAIN 6. DRAIN 7. DRAIN 8. DRAIN STYLE 21: PIN 1. CATHODE 1 2. CATHODE 2 3. CATHODE 3 4. CATHODE 4 5. CATHODE 5 6. COMMON ANODE 7. COMMON ANODE 8. CATHODE 6 STYLE 22: PIN 1. I/O LINE 1 2. COMMON CATHODE/VCC 3. COMMON CATHODE/VCC 4. I/O LINE 3 5. COMMON ANODE/GND 6. I/O LINE 4 7. I/O LINE 5 8. COMMON ANODE/GND STYLE 23: PIN 1. LINE 1 IN 2. COMMON ANODE/GND 3. COMMON ANODE/GND 4. LINE 2 IN 5. LINE 2 OUT 6. COMMON ANODE/GND 7. COMMON ANODE/GND 8. LINE 1 OUT STYLE 24: PIN 1. BASE 2. EMITTER 3. COLLECTOR/ANODE 4. COLLECTOR/ANODE 5. CATHODE 6. CATHODE 7. COLLECTOR/ANODE 8. COLLECTOR/ANODE STYLE 25: PIN 1. VIN 2. N/C 3. REXT 4. GND 5. IOUT 6. IOUT 7. IOUT 8. IOUT STYLE 26: PIN 1. GND 2. dv/dt 3. ENABLE 4. ILIMIT 5. SOURCE 6. SOURCE 7. SOURCE 8. VCC STYLE 29: PIN 1. BASE, DIE #1 2. EMITTER, #1 3. BASE, #2 4. EMITTER, #2 5. COLLECTOR, #2 6. COLLECTOR, #2 7. COLLECTOR, #1 8. COLLECTOR, #1 STYLE 30: PIN 1. DRAIN 1 2. DRAIN 1 3. GATE 2 4. SOURCE 2 5. SOURCE 1/DRAIN 2 6. SOURCE 1/DRAIN 2 7. SOURCE 1/DRAIN 2 8. GATE 1 DOCUMENT NUMBER: DESCRIPTION: 98ASB42564B SOIC−8 NB STYLE 27: PIN 1. ILIMIT 2. OVLO 3. UVLO 4. INPUT+ 5. SOURCE 6. SOURCE 7. SOURCE 8. DRAIN STYLE 28: PIN 1. SW_TO_GND 2. DASIC_OFF 3. DASIC_SW_DET 4. GND 5. V_MON 6. VBULK 7. VBULK 8. VIN Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red. PAGE 2 OF 2 onsemi and are trademarks of Semiconductor Components Industries, LLC dba onsemi or its subsidiaries in the United States and/or other countries. onsemi reserves the right to make changes without further notice to any products herein. onsemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does onsemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. onsemi does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com MECHANICAL CASE OUTLINE PACKAGE DIMENSIONS Micro8 CASE 846A−02 ISSUE K DATE 16 JUL 2020 SCALE 2:1 GENERIC MARKING DIAGRAM* 8 XXXX AYWG G 1 XXXX A Y W G = Specific Device Code = Assembly Location = Year = Work Week = Pb−Free Package (Note: Microdot may be in either location) *This information is generic. Please refer to device data sheet for actual part marking. Pb−Free indicator, “G” or microdot “G”, may or may not be present. Some products may not follow the Generic Marking. DOCUMENT NUMBER: DESCRIPTION: 98ASB14087C MICRO8 STYLE 1: PIN 1. 2. 3. 4. 5. 6. 7. 8. SOURCE SOURCE SOURCE GATE DRAIN DRAIN DRAIN DRAIN STYLE 2: PIN 1. 2. 3. 4. 5. 6. 7. 8. SOURCE 1 GATE 1 SOURCE 2 GATE 2 DRAIN 2 DRAIN 2 DRAIN 1 DRAIN 1 STYLE 3: PIN 1. 2. 3. 4. 5. 6. 7. 8. N-SOURCE N-GATE P-SOURCE P-GATE P-DRAIN P-DRAIN N-DRAIN N-DRAIN Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red. PAGE 1 OF 1 ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. ON Semiconductor does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2019 www.onsemi.com onsemi, , and other names, marks, and brands are registered and/or common law trademarks of Semiconductor Components Industries, LLC dba “onsemi” or its affiliates and/or subsidiaries in the United States and/or other countries. onsemi owns the rights to a number of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of onsemi’s product/patent coverage may be accessed at www.onsemi.com/site/pdf/Patent−Marking.pdf. onsemi reserves the right to make changes at any time to any products or information herein, without notice. The information herein is provided “as−is” and onsemi makes no warranty, representation or guarantee regarding the accuracy of the information, product features, availability, functionality, or suitability of its products for any particular purpose, nor does onsemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Buyer is responsible for its products and applications using onsemi products, including compliance with all laws, regulations and safety requirements or standards, regardless of any support or applications information provided by onsemi. “Typical” parameters which may be provided in onsemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. onsemi does not convey any license under any of its intellectual property rights nor the rights of others. onsemi products are not designed, intended, or authorized for use as a critical component in life support systems or any FDA Class 3 medical devices or medical devices with a same or similar classification in a foreign jurisdiction or any devices intended for implantation in the human body. Should Buyer purchase or use onsemi products for any such unintended or unauthorized application, Buyer shall indemnify and hold onsemi and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that onsemi was negligent regarding the design or manufacture of the part. onsemi is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner. PUBLICATION ORDERING INFORMATION LITERATURE FULFILLMENT: Email Requests to: orderlit@onsemi.com onsemi Website: www.onsemi.com ◊ TECHNICAL SUPPORT North American Technical Support: Voice Mail: 1 800−282−9855 Toll Free USA/Canada Phone: 011 421 33 790 2910 Europe, Middle East and Africa Technical Support: Phone: 00421 33 790 2910 For additional information, please contact your local Sales Representative
NCP1030GEVB 价格&库存
很抱歉,暂时无法提供与“NCP1030GEVB”相匹配的价格&库存,您可以联系我们找货
