NCP3011GEVB
NCP3011GEVB
    ONSEMI(安森美)
    NCP3011 - DC/DC, Step Down 1, Non-Isolated Outputs Evaluation Board
NCP3011GEVB 数据手册
NCP3011GEVB: PWM Device Evaluation Board Evaluation Board Description The NCP3011 is a PWM device designed to operate from a wide input range and is capable of producing an output voltage as low as 0.8 V. The NCP3011 provides a 1.0 A gate driver and an internally set 400 kHz oscillator. The NCP3011 has an externally compensated transconductance error amplifier with an internally fixed soft-start. The NCP3011 incorporates output voltage monitoring with a PowerGood pin to indicate that the system is in regulation. The dual function SYNC pin synchronizes the device to a higher frequency (Slave Mode) or outputs a 180° out-ofphase clock signal to drive another NCP3011 (Master Mode). Protection features include lossless current limit and short circuit protection, output overvoltage and undervoltage protection, and input undervoltage lockout. Features and Applications Features Input voltage range from 9 V to 18 V PowerGood output pin Enable/Disable pin Evaluation Board Information Evaluation Status Compliance Short Board Description NCP3011GEVB Active Pb-free PWM Device Evaluation Board Parts Used Action NCP3011DTBR2G Technical Documents Type Document Title Document ID/Size Eval Board: BOM NCP3011GEVB Bill of Materials ROHS Compliant NCP3011GEVB_BOM_ROHS.PDF - 97.0 3 KB Rev Eval Board: Gerber NCP3011GEVB Gerber Layout Files (Zip Format) NCP3011GEVB_GERBER.ZIP - 142.0 KB 0 Eval Board: Schematic NCP3011GEVB Schematic NCP3011GEVB_SCHEMATIC.PDF 21.0 KB 3 Eval Board: Test Procedure NCP3011GEVB Test Procedure NCP3011GEVB_TEST_PROCEDURE.PDF 0 - 127.0 KB Privacy Policy | Terms of Use | Site Map | Careers | Contact Us | Terms and Conditions | Mobile Portal | Mobile App Copyright © 1999-2014 ON Semiconductor http://www.onsemi.com/PowerSolutions/evalBoard.do?id=NCP3011GEVB[2/27/2014 1:34:20 PM] Follow Us
NCP3011GEVB 价格&库存
很抱歉,暂时无法提供与“NCP3011GEVB”相匹配的价格&库存,您可以联系我们找货
