NCP5005GEVB
NCP5005GEVB
    ONSEMI(安森美)
NCP5005GEVB 数据手册
ON Semiconductor Is Now To learn more about onsemi™, please visit our website at www.onsemi.com onsemi and       and other names, marks, and brands are registered and/or common law trademarks of Semiconductor Components Industries, LLC dba “onsemi” or its affiliates and/or subsidiaries in the United States and/or other countries. onsemi owns the rights to a number of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of onsemi product/patent coverage may be accessed at www.onsemi.com/site/pdf/Patent-Marking.pdf. onsemi reserves the right to make changes at any time to any products or information herein, without notice. The information herein is provided “as-is” and onsemi makes no warranty, representation or guarantee regarding the accuracy of the information, product features, availability, functionality, or suitability of its products for any particular purpose, nor does onsemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Buyer is responsible for its products and applications using onsemi products, including compliance with all laws, regulations and safety requirements or standards, regardless of any support or applications information provided by onsemi. “Typical” parameters which may be provided in onsemi data sheets and/ or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. onsemi does not convey any license under any of its intellectual property rights nor the rights of others. onsemi products are not designed, intended, or authorized for use as a critical component in life support systems or any FDA Class 3 medical devices or medical devices with a same or similar classification in a foreign jurisdiction or any devices intended for implantation in the human body. Should Buyer purchase or use onsemi products for any such unintended or unauthorized application, Buyer shall indemnify and hold onsemi and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that onsemi was negligent regarding the design or manufacture of the part. onsemi is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner. Other names and brands may be claimed as the property of others. NCP5005 Compact Backlight LED Boost Driver The NCP5005 is a high efficiency boost converter operating in current loop, based on a PFM mode, to drive White LED. The current mode regulation allows a uniform brightness of the LEDs. The chip has been optimized for small ceramic capacitors, capable to supply up to 1.0 W output power. www.onsemi.com MARKING DIAGRAM Features • 2.7 to 5.5 V Input Voltage Range • Vout to 24 V Output Compliance Allows up to 5 LEDs Drive in • • • • • • • • • • • • Series Built−in Overvoltage Protection Full EMI Immunity Inductor Based Converter brings up to 90% Efficiency Constant Output Current Regulation 0.3 mA Standby Quiescent Current Includes Dimming Function (PWM) Enable Function Driven Directly from Low Battery Voltage Source Automatic LEDs Current Matching Thermal Shutdown Protection All Pins are Fully ESD Protected Low EMI Radiation Pb−Free Package is Available 5 TSOP−5 SN SUFFIX CASE 483 5 1 DBNAYWG G 1 DBN = Device Code A = Assembly Location Y = Year W = Work Week G = Pb−Free Package (Note: Microdot may be in either location) PIN CONNECTIONS Vout 1 GND 2 FB 3 Typical Applications 5 Vbat 4 EN (Top View) • LED Display Back Light Control • Keyboard Back Light • High Efficiency Step Up Converter ORDERING INFORMATION Device Package Shipping† NCP5005SNT1G TSOP−5 (Pb−Free) 3000 Tape & Reel †For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specifications Brochure, BRD8011/D. © Semiconductor Components Industries, LLC, 2005 November, 2005 − Rev. 1 1 Publication Order Number: NCP5005/D NCP5005 Vbat Vbat U1 4 EN Vbat C1 5 4.7 mF L1 22 mH 2 GND GND 3 Vout FB GND D1 1 MBR0530 NCP5005 R1 GND D6 C2 1.0 mF D5 D4 D3 D2 15 W LWT67C LWT67C LWT67C LWT67C LWT67C GND Figure 1. Typical Application Thermal Shutdown Current Sense Vbat 5 Vbat CONTROLLER Vsense EN 4 100 k GND FB 3 300 k 1 Vout Q1 2 GND + GND +200 mV Band Gap Figure 2. Block Diagram www.onsemi.com 2 NCP5005 PIN FUNCTION DESCRIPTION Pin Pin Name Type Description 1 Vout POWER This pin is the power side of the external inductor and must be connected to the external Schottky diode. It provides the output current to the load. Since the boost converter operates in a current loop mode, the output voltage can range up to +24 V but shall not extend this limit. However, if the voltage on this pin is higher than the Over Voltage Protection threshold (OVP) the device comes back to shutdown mode. To restart the chip, one must either send a Low to High sequence on Pin EN, or switch off the Vbat supply. A capacitor must be used on the output voltage to avoid false triggering of the OVP circuit. This capacitor should be 1.0 mF minimum. Ceramic type, (ESR
NCP5005GEVB 价格&库存
很抱歉,暂时无法提供与“NCP5005GEVB”相匹配的价格&库存,您可以联系我们找货
