PLR0521-T710
PLR0521-T710
    PROTEC(普罗太克)
    DFN2
    超低电容电视阵列
PLR0521-T710 数据手册
05338 PLR0521 Only One Name Means ProTek’Tion™ ULTRA LOW CAPACITANCE TVS ARRAY DESCRIPTION The PLR0521 is an ultra low capacitance transient voltage suppressor array, designed to protect computing applications from the damaging effects of Electrostatic Discharge and Electrical Fast Transients. The PLR0521 meets IEC 61000-4-2 (ESD) and IEC 61000-4-4 (EFT) requirements. At higher operating frequencies or faster edge rates, insertion loss and signal integrity are a major concern. This device offers an ultra low capacitance and low leakage current in a miniature DFN-2-0402 package. DFN-2 PACKAGE FEATURES APPLICATIONS • Compatible with IEC 61000-4-2 (ESD): Air 15kV, Contact 8kV • Compatible with IEC 61000-4-4 (EFT) • Compatible with IEC 61000-4-5 (Surge) • 80 Watts Peak Pulse Power per Line (tp = 8/20µs) • ESD Protection • Low Clamping Voltage • Protects One Bidirectional Line • Ultra Low Capacitance: 0.4 pF (Typical) • RoHS Compliant • REACH Compliant • Ethernet 10/100/1000 Base T • FireWire • Wireless Communications • USB 1.0, USB 2.0 & USB 3.0 • HDMI 1.4 & 2.0 Interfaces MECHANICAL CHARACTERISTICS • Molded JEDEC DFN-2-0402 Package • Approximate Weight: 2 milligrams • Lead-Free Ni/Pd/Au Plating • Solder Reflow Temperature: Pure-Tin - Sn, 100: 260-270°C • 8mm Tape and Reel Per EIA Standard 481 • Flammability Rating UL 94V-0 PIN CONFIGURATION 1 2 05338.R9 1/16 Page 1 www.protekdevices.com 05338 PLR0521 Only One Name Means ProTek’Tion™ TYPICAL DEVICE CHARACTERISTICS MAXIMUM RATINGS @ 25°C Unless Otherwise Specified PARAMETER SYMBOL VALUE UNITS PPP 80 Watts Operating Temperature TA -55 to 150 °C Storage Temperature TSTG -55 to 150 °C Peak Pulse Power (tp = 8/20µs) - See Figure 1 ELECTRICAL CHARACTERISTICS PER LINE @ 25°C Unless Otherwise Specified PART NUMBER DEVICE MARKING PLR0521 H RATED STAND-OFF VOLTAGE MINIMUM BREAKDOWN VOLTAGE MAXIMUM CLAMPING VOLTAGE (Fig. 2) MAXIMUM CLAMPING VOLTAGE (Fig. 2) MAXIMUM LEAKAGE CURRENT TYPICAL CAPACITANCE VWM VOLTS @ 1mA V(BR) VOLTS @I P = 1A VC VOLTS @ 8/20µS V C @ IPP @V WM ID µA @0V, 1MHz CJ pF 5.0 6.0 14.0 20.0V @ 4.0A 1 0.4 FIGURE 1 PEAK PULSE POWER VS PULSE TIME PPP - Peak Pulse Power - Watts 1,000 10 1 0.1 05338.R9 1/16 80W, 8/20µs Waveform 100 1 10 100 td - Pulse Duration - µs Page 2 1,000 10,000 www.protekdevices.com 05338 PLR0521 Only One Name Means ProTek’Tion™ TYPICAL DEVICE CHARACTERISTICS FIGURE 2 PULSE WAVE FORM IPP - Peak Pulse Current - % of IPP 120 tf 100 TEST WAVEFORM PARAMETERS tf = 8µs td = 20µs Peak Value IPP 80 e-t 60 40 td = t/(IPP/2) 20 0 0 5 10 15 t - Time - µs 20 25 30 FIGURE 3 TLP WAVEFORM 05338.R9 1/16 Page 3 www.protekdevices.com 05338 PLR0521 Only One Name Means ProTek’Tion™ TYPICAL DEVICE CHARACTERISTICS FIGURE 4 INSERTION LOSS 10 db per Division 3db Frequency 7.4GHz 1.6GHz per Divison Indicative Representation of Insertion Loss 05338.R9 1/16 Page 4 www.protekdevices.com 05338 PLR0521 Only One Name Means ProTek’Tion™ DFN-2-0402 PACKAGE INFORMATION L1 OUTLINE DIMENSIONS DIM MILLIMETERS INCHES MIN MAX MIN MAX A 0.914 1.06 0.036 0.042 B 0.533 0.660 0.021 0.026 C 0.435 0.565 0.017 0.022 H 0~0.10 0~0.10 0~0.004 0~0.004 L1 0.254 0.355 0.010 0.014 L2 0.279 0.406 0.011 0.016 L4 0.660 BSC BOTTOM VIEW L4 C H A TOP VIEW L2 0.026 BSC NOTES B 1. Dimensioning and tolerances per ANSI Y14.M, 1985. 2. Controlling dimension: inches. 3. Dimensions are exclusive of mold flash and metal burrs. SIDE VIEW PAD LAYOUT DIMENSIONS DIM MILLIMETERS INCHES MIN MAX MIN MAX A 1.16 1.27 0.046 0.050 B 0.41 0.51 0.016 0.020 C 0.41 0.51 0.016 0.020 D 0.30 C D A 0.012 NOTES 1. Controlling dimension: inches. B 05338.R9 1/16 Page 5 www.protekdevices.com 05338 PLR0521 Only One Name Means ProTek’Tion™ TAPE AND REEL D T P2 Top Cover Tape 10 Pitches Cumulative Tolerance on tape ± 0.2 E P0 F A0 K0 W B0 P User Direction of Feed SPECIFICATIONS REEL DIA. TAPE WIDTH 178mm (7”) 8mm A0 B0 K0 D E F W P0 P2 P 0.70 ± 0.05 1.15 ± 0.10 0.56 ± 0.05 1.55 ± 0.10 1.75 ± 0.10 3.50 ± 0.05 8.00 ± 0.30 4.00 ± 0.10 2.00 ± 0.05 2.00 ± 0.05 tmax 0.25 NOTES 1. 2. 3. 4. Dimensions are in millimeters. Surface mount product is taped and reeled in accordance with EIA-481. Suffix - T710 = 7” Reel - 10,000 pieces per 8mm tape. Marking on Part - marking code (see page 2). ORDERING INFORMATION BASE PART NUMBER LEADFREE SUFFIX TAPE SUFFIX QTY/REEL REEL SIZE TUBE QTY PLR0521 n/a -T710 10,000 7” n/a This device is only available in a Lead-Free configuration. 05338.R9 1/16 Page 6 www.protekdevices.com 05338 PLR0521 Only One Name Means ProTek’Tion™ COMPANY INFORMATION COMPANY PROFILE In business more than 20 years, ProTek Devices™ is a privately held semiconductor company. The company offers a product line of overvoltage protection and overcurrent protection components. These include transient voltage suppressor array (TVS arrays) avalanche breakdown diode, steering diode TVS array and electronics SMD chip fuses. These components deliver circuit protection in electronic systems from numerous overvoltage and overcurrent events. They include lightning; electrostatic discharge (ESD); nuclear electromagnetic pulses (NEMP); inductive switching; and electromagnetic interference (EMI) / radio frequency interference (RFI). ProTek Devices also offers high performance interface and linear products. They include analog switches; multiplexers; LED drivers; LED wafer die for ESD protection; audio control ICs; RF and related high frequency products. CONTACT US Corporate Headquarters 2929 South Fair Lane Tempe, Arizona 85282 USA By Telephone General: 602-431-8101 Sales: & Marketing: 602-414-5109 Customer Service: 602-414-5114 Product Technical Support: 602-414-5107 By Fax General: 602-431-2288 By E-mail: Asia Sales: asiasales@protekdevices.com Europe Sales: europesales@protekdevices.com U.S. Sales: ussales@protekdevices.com Distributor Sales: distysales@protekdevices.com Customer Service: service@protekdevices.com Technical Support: support@protekdevices.com ProTek Devices (Asia Pacific) Pte. Ltd. 8 Ubi Road 2, #06-19 Zervex Singapore - 408538 Tel: +65-67488312 Fax: +65-67488313 Web www.protekdevices.com COPYRIGHT © ProTek Devices 2011 - This literature is subject to all applicable copyright laws and is not for resale in any manner. SPECIFICATIONS: ProTek reserves the right to change the electrical and or mechanical characteristics described herein without notice. DESIGN CHANGES: ProTek reserves the right to discontinue product lines without notice and that the final judgement concerning selection and specifications is the buyer’s and that in furnishing engineering and technical assistance. ProTek assumes no responsibility with respect to the selection or specifications of such products. ProTek makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ProTek assume any liability arising out of the application or use of any product or circuit and specifically disclaims any and all liability without limitation special, consequential or incidental damages. LIFE SUPPORT POLICY: ProTek Devices products are not authorized for use in life support systems without written consent from the factory. 05338.R9 1/16 Page 7 www.protekdevices.com
PLR0521-T710 价格&库存
很抱歉,暂时无法提供与“PLR0521-T710”相匹配的价格&库存,您可以联系我们找货
PLR0521-T710
    • 10+0.45533
    • 100+0.33714
    • 300+0.26409
    • 1000+0.23673
    • 5000+0.20723
    • 10000+0.19634
    库存:2738
    PLR0521-T710
    • 1+0.21780
    • 10000+0.19800
    库存:89964
