T1090
T1090
    PULSECORE(普思)
    脉冲变压器
T1090 数据手册
T1/CEPT/ISDN-PRI TRANSFORMERS Dual Surface Mount, 1500Vrms, Extended and Standard Temperature Range Dual SMT package contains both transmit and receive transformers Models matched to leading transceiver ICs Isolation voltage: 1500Vrms UL recognized RoHS compliant versions available Electrical Specifications @ 25°C Turns Ratio B (Pri:Sec ± 2%) Part Number OCL @ 25°C (mH MIN) LL (µH MAX) CW/W (pF MAX) DCR Pri (Ω MAX) DCR Sec (Ω MAX) Package/ Schematic Primary Pins EXTENDED TEMPERATURE RANGE MODELS1 – OPERATING TEMPERATURE -40°C TO +85°C PE-68841 1CT:2CT & 1CT:2CT 1.20 & 1.20 0.80 & 0.80 50 & 50 1.00 & 1.00 1.70 & 1.70 AN/2 12-10, 4-6 PE-68822 1CT:2CT & 1:1.36CT 1.60 & 1.60 1.00 & 0.80 60 & 55 1.70 & 1.70 2.00 & 1.70 AN/1 12-10, 4-6 PE-68825 1:1.15CT & 1CT:2CT 1.60 & 1.60 0.80 & 0.80 60 & 50 1.00 & 1.00 1.20 & 2.00 AN/4 12-10, 4-6 PE-68826 E 1:1/1.26 & 1:2CT 1.20 & 1.20 0.80 & 0.80 50 & 60 1.00 & 1.00 1.10 & 1.70 AN/5 12-10, 4-6 PE-68827 1:1CT & 2:1 1.60 & 1.60 1.30 & 1.30 55 & 40 1.10 & 1.10 1.10 & 0.70 AN/6 1-3, 4-6 PE-68828 1CT:1CT & 1CT:1CT 1.20 & 1.20 0.80 & 0.80 50 & 50 1.00 & 1.00 1.00 & 1.00 AN/2 1-3, 4-6 PE-68874 1CT:1.15CT & 1CT:1.15CT 1.20 & 1.20 0.80 & 0.80 50 & 50 1.20 & 1.20 1.40 & 1.40 AN/2 1-3, 4-6 PE-68877 1CT:1CT & 1CT:2CT 1.20 & 1.20 0.80 & 0.80 50 & 50 1.00 & 1.00 1.00 & 1.80 AN/2 1-3, 4-6 PE-68882 1CT:1.15CT & 1CT:1CT 1.60 & 1.60 0.80 & 0.80 60 & 60 1.20 & 1.20 1.40 & 1.20 AN/2 12-10, 4-6 PE-68884 1CT:1.36CT & 1CT:1.36CT 1.20 & 1.20 0.80 & 0.80 50 & 50 1.20 & 1.20 1.40 & 1.40 AN/2 1-3, 4-6 PE-68887 1CT:1.41CT & 1CT:1.41CT 1.20 & 1.20 0.80 & 0.80 50 & 50 1.40 & 1.40 1.20 & 1.20 AN/2 12-10, 9-7 PE-68881 1CT:2.3CT & 1CT:2CT 1.20 & 1.20 0.80 & 0.80 60 & 50 1.20 & 1.20 2.10 & 2.10 AN/2 10-12, 4-6 TX1277 1CT:1CT & 1CT:2CT 1.20 & 1.20 0.80 & 0.80 50 & 50 1.00 & 1.00 1.00 & 1.80 AN/2 1-3, 4-6 STANDARD TEMPERATURE RANGE MODELS – OPERATING TEMPERATURE 0°C TO +70°C T1131 I 1CT:1 & 1:1.36CT 0.70 & 0.70 0.70 & 0.70 20 & 20 0.25 & 0.50 0.80 & 0.40 AN/7 1-3, 9-7 PE-68861 1CT:2CT & 1CT:2CT 1.20 & 1.20 0.60 & 0.60 35 & 35 0.70 & 0.70 1.20 & 1.20 AN/2 12-10, 4-6 PE-68862 1CT:2CT & 1:1.36CT 1.20 & 1.20 0.60 & 0.80 35 & 37 0.70 & 0.70 1.20 & 0.90 AN/1 12-10, 4-6 PE-68863 1:2CT & 1:1.14CT 1.20 & 1.20 0.55 & 0.80 40 & 35 0.70 & 0.70 1.20 & 0.90 AN/5 12-10, 4-6 PE-68864 A 1CT:2CT & 1:1 1.20 & 1.20 0.30-0.55 & 0.80 30 & 30 0.70 & 0.70 1.20 & 0.70 AN/3 1-3, 5-6 PE-68865 1:1.15CT & 1CT:2CT 1.50 & 1.20 0.80 & 0.60 35 & 35 0.70 & 0.70 0.90 & 1.20 AN/4 12-10, 4-6 PE-68866 E 1:1/1.26 & 1:2CT 1.50 & 1.20 0.40 & 0.50 40 & 40 0.70 & 0.70 0.90 & 1.20 AN/5 12-10, 4-6 PE-68869 1CT:2CT & 1:1.08CT 1.20 & 1.20 0.60 & 0.60 40 & 30 0.70 & 0.70 1.10 & 0.90 AN/1 12-10, 4-6 PE-68836 E 1:1/1.26 & 1:1/1.26 1.50 & 1.50 0.40 & 0 .40 45 & 45 0.80 & 0.80 1.00 & 1.00 AN/7 12-10, 9-7 Note: RoHS-6 compliant parts can be ordered by adding an “NL” suffix to the part number (i.e. PE-68841 becomes PE-68841NL). (See Pages 6 and 7 for Table Notes) Mechanical Schematics AN .120 3,05 .675 MAX 17,15 12X 12 .600 MAX 15,24 1 .085 2,16 2 12 11 10 9 1 4 8 7 3 12 11 10 9 8 7 1 4 5 6 12 11 10 8 7 1 5 6 .030 0,76 7 PE-XXXXX DATE CODE 1 .050 TYP 1,27 .456 MAX 11,58 .640 16,26 .400 10,16 .500 12,70 2 3 6 4 6 12 2 3 5 10 9 8 7 12 6 1 10 2 3 6 9 8 7 7 12 11 10 9 7 12 6 1 6 1 10 9 7 .100 TYP 2,54 .100 2,54 SUGGESTED PAD LAYOUT 1 .340 MAX 8,64 .004/0,10 MAX .010 / .020 0,25 / 0,51 2 3 4 5 2 3 4 3 4 2 3 4 5 6 0°-8° Weight . . . . . . . . . . . . . .4.0 grams Tape & Reel . . . . . . . . . . . .250/reel Tube . . . . . . . . . . . . . . . . . .30/tube .040 / .050 1,02 / 1,27 Dimensions: Inches mm Unless otherwise specified, all tolerances are ± .010 0,25 USA 858 674 8100 • Germany 49 7032 7806 0 • Singapore 65 6287 8998 • Shanghai 86 21 32181071 • China 86 755 33966678 • Taiwan 886 3 4643715 www.pulseeng.com 1 T608.S (4/08) T1/CEPT/ISDN-PRI TRANSFORMERS Dual Surface Mount, 1500Vrms, Small Package Dual SMT package contains both transmit and receive transformers Models matched to leading transceiver ICs UL recognized (some parts pending approval) RoHS compliant versions available upon request Electrical Specifications @ 25°C Part # (STD temp.) Turns Ratio B (Pri:Sec ±5%) Part # (EXT temp.) OCL (mH MIN) CW/W (pF MAX) LL (µH MAX) DCR Pri (Ω MAX) Package/ Schematic Primary Pins PE-65861 PE-65862 PE-65865 PE-65866 E PE-65870 T1022 PE-68678 PE-68786 T1023 — — T1136 T1121 T1122 T1021 I T1075 I T1190 T1137 T1090 1CT:2CT & 1CT:2CT 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/1 16-14, 6-8 T1091 1CT:2CT & 1:1.36CT 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/2 16-14, 6-8 T1076 1:1.15CT & 1CT:2CT 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/3 16-14, 6-8 T1092 E 1:1/1.26 & 1CT:2CT 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/3 16-14, 6-8 T1093 1CT:1.15CT & 1CT:1.15CT 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/1 1-3, 6-8 T1077 1CT:1CT & 1CT:1.5CT 1.20 & 1.20 30 & 30 .80 & .80 0.70 & 0.70 BH/1 16-14, 6-8 T1094 1CT:1CT & 1CT:2CT 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/1 16-14, 6-8 T1095 1CT:1.41CT & 1CT:1.41CT 1.00 & 1.00 30 & 30 .60 & .60 0.70 & 0.70 BH/1 16-14, 11-9 T1096 1CT:1.41CT & 1CT:1.41CT 1.00 & 1.00 30 & 30 .60 & .60 0.70 & 0.70 BH/1 1-3, 11-9 T1144 1CT:1CT & 1CT:2.4CT 1.00 & 1.00 30 & 30 .80 & .80 0.85 & 0.85 BH/1 9-11, 1-3 T1097 1CT:1CT & 1CT:1.67CT 1.00 & 1.00 25 & 25 .80 & .80 0.80 & 0.80 BH/1 6-8, 14-16 — 1CT:1CT & 1CT:1.36CT 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/1 6-8, 1-3 — 1CT:1.5CT & 1CT:1.5CT 1.50 & 1.50 40 & 40 .80 & .80 0.70 & 0.70 BH/1 1-3, 6-8 — 1CT:2CT & 1CT:2.3CT 1.20 & 1.20 30 & 30 .80 & .80 0.90 & 0.90 BH/1 6-8, 14-16 — 2CT:1/1.26 & 2CT:1/1.26 1.50 & 1.50 40 & 40 .50 & .50 0.70 & 0.70 BH/1 1-3, 11-9 — 2CS:1.57/2 & 2CS:1.57/2 1.50 & 1.50 40 & 40 .50 & .50 0.70 & 0.70 BH/4 1-2, 5-6 — 1CT:1CT & 1CT:1.36CT 1.20 & 1.20 30 & 30 .60 & 60 0.70 & 0.70 BH/1 16-14, 6-8 TX1287 1CT:2.42CT & 1CT:2.42CT 1.20 & 1.20 25 & 25 .60 & .60 0.70 & 0.70 BH/1 1-3, 6-8 T1146 1:2/2.4 & 1:0.79/1 1.00 & 1.00 35 & 35 1.00 & 1.00 0.80 & 0.80 BH/5 1-3, 6-8 — T1286 — 1CT:2.4CT & 1CT:2.4CT 1.20 & 1.20 15 & 15 .30 & .30 0.30 & 0.30 BH/1 1-3, 6-8 TX1317 1:2CT & 1:2CS 1.20 & 1.20 35 & 35 .50 & 1.00 1.00 & 1.00 BH/6 1-3, 11-9 — TX1189 1:1.36CT & 1:2CT 1.20 & 1.20 30 & 30 .60 & .60 1.00 & 1.00 BH/7 16-14, 6-8 — TX1188 1CT:2CT & 1CT:2CT 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/1 1-3, 6-8 — TX1187 1CT:2CT & 1:1 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/8 1-3, 6-8 — TX1088 1CT:2CT & 1CT:2.42CT 1.20 & 1.20 35 & 35 .80 & .80 1.00 & 1.00 BH/1 1-3, 6-8 — TX1089 1CT:1CT & 1CT:1CT 1.20 & 1.20 30 & 30 .80 & .80 0.70 & 0.70 BH/1 1-3, 6-8 — TX1098 1CT:1:26CT & 1CT:1:26CT 1.20 & 1.20 30 & 30 .60 & .60 0.70 & 0.70 BH/1 1-3, 6-8 — TX1099 1CT:1:0.8 & 1CT:1:0.8 1.20 & 1.20 30 & 30 .80 & .80 1.00 & 1.00 BH/4 16-14, 11-9 — TX1186 1CT:1.58:2 & 1:1.65:2 1.20 & 1.20 30 & 30 .80 & .80 1.00 & 1.00 BH/9 2-4, 6-7 — TX1467 1CT:1:1 & 1CT:1:1 1.20 & 1.20 30 & 30 .80 & .80 1.00 & 1.00 BH/4 16-14, 11-9 — NOTE: Standard (STD) operating temperature range is 0°C to 70°C. Extended (EXT) operating temperature range is -40°C to +85°C. RoHS-6 compliant parts can be ordered by adding an (See Pages 6 and 7 for Table Notes) “NL” suffix to the part number (i.e. PE-65861 becomes PE-65861NL). Mechanical BH .505 MAX 12,83 .375 9,53 MAX .050 1,27 PE-6XXXX T1XXX/TX1XXX (Date Code) (Country of Origin) .350 8,89 .280 MAX 7,11 .350 8,89 .328 8,33 Schematics 1 .075 1,91 2 3 16 15 14 11 10 9 16 15 14 11 1 2 6 7 8 1 2 6 10 9 16 8 1 4 14 11 10 9 16 15 14 11 10 9 3 6 7 8 1 2 3 6 7 8 .050 1,27 ± .001 16X .029 0,74 ± 0,03 3 5 SUGGESTED PAD LAYOUT 3 6 16 15 14 11 1 3 10 9 1 8 16 3 5 6 7 2 7 8 16 9 1 14 11 4 5 8 10 9 9 16 15 14 11 9 16 15 14 13 12 11 10 9 8 1 2 8 2 .010 0,25 .245 6,22 MAX .004/0,10 ± .002 16X .018 0,46 ± 0,05 16 SURFACES 0°– 8° Weight . . . . . . . . .1.0 grams Tape & Reel . . . . . . .600/reel Tube . . . . . . . . . . . . .40/tube 6 15 14 11 Dimensions: Inches mm 2 3 6 3 6 3 4 6 Unless otherwise specified, all tolerances are ± .010 0,25 USA 858 674 8100 • Germany 49 7032 7806 0 • Singapore 65 6287 8998 • Shanghai 86 21 32181071 • China 86 755 33966678 • Taiwan 886 3 4643715 www.pulseeng.com 2 T608.S (4/08) 7 T1/CEPT/ISDN-PRI TRANSFORMERS Single Reinforced Insulation, 3KVrms D ORCE REINFLATION! INSU Certified for reinforced insulation per UL For T1/CEPT line interfaces Matched to leading transceiver ICs Designed to meet ITU-T G.703 RoHS compliant versions available upon request Electrical Specifications @ 25°C — Operating Temperature 0°C to 70°C (Unless Otherwise Noted) Part Number Turns Ratio B (± 5%) OCL B (mH MIN) CW/W (pF MAX) LL (µH MAX) DCR Pri (Ω MAX) DCR Sec (Ω MAX) Safety Agency Recognition 10 Package/ Schematic PE-65830 1.27CS:1 .800 15 0.70 0.50 0.35 C,T,U,B IS/3 PE-65831 1CS:1 .800 15 0.70 0.50 0.45 C,T,U,B IS/3 1-5 PE-65832 1:1.36CT 1.20 35 0.60 0.70 0.90 C,T,U,B IS/4 10-6 PE-65833 A 1CT:2CT 1.20 20 0.30-0.55 0.50 0.90 C,T,U,B IS/1 1-5 1:1 1.20 20 0.50 0.50 0.50 C,T,U,B IS/2 1-5 PE-65835 1CT:2CT 1.20 15 0.80 0.70 1.10 C,T,U,B IS/1 1-5 PE-65836 1CT:3CT:1 .600 30 0.80 0.70 1.70 C,T,U,B IS/5 1-3 PE-65834 PE-65837 E Primary Pins 1-5 1:1.08/1.36 1.50 20 0.60 0.70 0.90 C,T,U,B IS/4 10-6 PE-65838 1:1.14CT 1.50 30 1.00 0.70 0.90 C,T,U,B IS/4 10-6 PE-65839 E 1:1/1.26 1.50 35 0.60 0.70 1.10 C,T,U,B IS/4 10-6 PE-68646 E 1:1.58/2 1.50 20 0.70 0.70 1.20 C,T,U,B IS/4 10-6 1CT:1.41CT 1.20 20 0.80 0.60 0.80 T,U,B IS/1 10-6 PE-68788 (See Pages 6 and 7 for Table Notes) NOTE: RoHS-6 compliant parts can be ordered by adding an “NL” suffix to the part number (i.e. PE-65830 becomes PE-65830NL). Schematics Mechanical IS .560 MAX 14,22 1 10 2 9 3 PE-XXXXX 8 4 7 5 DATE CODE 6 1 .560 MAX 14,22 .400 10,20 1 10 1 3 8 3 5 6 5 2 .100 TYP 2,54 .400 MAX 10,20 Notes: Leads are 22 AWG solderable. Unused pins not provided. .130 3,30 1 6 1 6 1 10 2 8 3 4 6 5 3 Dimensions: Inches mm Unless otherwise specified, all tolerances are ± .010 0,25 10 5 10 5 Weight . . . . . . . . . . 4 grams Tube . . . . . . . . . . . . .35/tube .400 10,20 4 10 2 4 5 6 USA 858 674 8100 • Germany 49 7032 7806 0 • Singapore 65 6287 8998 • Shanghai 86 21 32181071 • China 86 755 33966678 • Taiwan 886 3 4643715 www.pulseeng.com 3 T608.S (4/08) T1/CEPT/ISDN-PRI TRANSFORMERS Single Through Hole, 1500Vrms Extended and standard temperature range Dual and single through hole models available Models matched to leading transceiver ICs UL recognized Isolation Voltage: 1500Vrms MIN RoHS compliant versions available upon request Electrical Specifications @ 25°C Turns Ratio B OCL @ 25°C CW/W LL DCR Pri (Pri:Sec ±5%) (mH MIN) (pF MAX) (µH MAX) (Ω MAX) STANDARD TEMPERATURE RANGE SINGLE TRANSFORMERS – OPERATING TEMPERATURE 0°C TO +70°C PE-64931 1:1:1 (1:2CS) 1.20 25 0.50 0.70 PE-64933 1CT:3CT 1.20 30 0.50 0.70 PE-64934 1:1 1.20 25 0.50 0.70 PE-64936 1CT:1 1.20 25 0.80 0.70 PE-64937 1:1.36 1.20 35 0.80 0.70 PE-64940 1.26CS:1 (1:1:1.58) 0.30 30 0.60 0.80 PE-64941 D 1CS:1 0.80 30 0.60 0.80 PE-64942 1CS:1.31 0.80 30 0.40 0.80 PE-64943 A 1CT:2CT 1.20 30 0.30-0.55 0.70 PE-65351 1:2CT 1.20 40 0.50 0.70 PE-65363 1:4CT 0.50 40 1.00 0.50 PE-65379 1:1.14CT 1.20 35 0.80 0.70 PE-65388 1:1.15CT 1.50 35 0.60 0.70 PE-65389 E 1:1/1.26 1.50 40 0.40 0.70 PE-65415 1CT:2CT 1.20 30 0.50 0.70 PE-65558 1:2.3CT 1.20 35 0.80 0.70 PE-65586 1:1.36CT 1.20 35 0.80 0.70 PE-65755 1CT:1CT 1.20 25 0.80 0.80 PE-68644 1CT:1 0.70 20 0.70 0.20 PE-68645 1:1.36CT 0.70 20 0.70 0.50 T1054 1:1.5CT 1.20 30 0.60 0.70 T1249 1:1.26CT 1.20 60 0.80 0.90 EXTENDED TEMPERATURE RANGE SINGLE TRANSFORMERS 1 – OPERATING TEMPERATURE -40°C TO +85°C PE-65340 1:1.36 1.20 35 0.80 0.90 PE-65770 1:1.15CT 1.50 40 0.80 0.90 PE-65771 1CT:2CT 1.20 50 0.60 1.00 PE-65778 1CT:1CT 1.20 40 1.00 1.00 PE-68600 1CT:3CT 1.20 60 0.80 0.90 PE-68664 E 1:1/1.26 1.50 50 0.80 0.90 TX1252 1CT:1 1.20 40 1.00 1.00 Part Number DCR Sec (Ω MAX) Package/ Schematic Primary Pins 0.70 & 0.70 1.60 0.70 0.70 0.80 0.60 0.60 0.60 1.20 1.30 1.50 0.80 0.90 0.90 1.20 1.40 0.90 0.80 0.80 0.40 1.00 1.00 HC/2 HC/4 HC/1 HC/3 HC/1 HC/2 HC/2 HC/2 HC/4 HC/3 HC/5 HC/5 HC/3 HC/3 HC/4 HC/5 HC/5 HC/4 HC/3 HC/5 HC/3 HC/4 1-2 1-5 1-2 1-5 5-6 1-4 1-4 1-4 1-5 2-6 1-5 1-5 2-6 2-6 1-5 1-5 1-5 1-5 1-5 1-5 2-6 2-6 1.20 1.00 2.00 1.00 2.70 1.10 1.00 HC/1 HC/3 HC/4 HC/4 HC/4 HC/3 HC/3 5-6 2-6 2-6 1-5 1-5 2-6 1-5 (See Pages 6 and 7 for Table Notes) NOTE: RoHS-6 compliant parts can be ordered by adding an “NL” suffix to the part number (i.e. PE-64931 becomes PE-64931NL). Schematics Mechanical HC .500 MAX 12,70 5 6 3 PE-6XXXX 4 Date Code 1 2 .100 2,54 .250 MAX 6,35 2 1 4 32 1 1 6 5 6 2 3 5 1 3 5 1 6 2 4 6 2 5 .350 MAX 8,89 .130 3,30 .200 5,08 1 Weight . . . . . . . . . 1.2 grams Tube . . . . . . . . . . . . .60/tube .400 10,16 Dimensions: Inches mm Notes: Leads are 24 AWG solderable. Unused pins not provided. 5 2 3 4 4 6 5 Unless otherwise specified, all tolerances are ± .010 0,25 USA 858 674 8100 • Germany 49 7032 7806 0 • Singapore 65 6287 8998 • Shanghai 86 21 32181071 • China 86 755 33966678 • Taiwan 886 3 4643715 www.pulseeng.com 4 T608.S (4/08) T1/CEPT/ISDN-PRI TRANSFORMERS Dual Through Hole, 1500Vrms Electrical Specifications @ 25°C Turns Ratio B (Pri:Sec ±5%) Part Number OCL @ 25°C (mH MIN) CW/W (pF MAX) LL (µH MAX) DCR Pri (Ω MAX) DCR Sec (Ω MAX) Package/ Schematic Primary Pins 1.20 & 1.20 1.20 & 1.00 2.00 & 2.00 1.20 & 0.70 0.70 & 0.30 0.50 & 0.20 0.50 & 0.30 1.10 & 1.30 0.90 & 1.30 HD/1 HD/2 HD/3 HD/4 HD/5 HD/5 HD/5 TD/1 TD/1 14-12, 5-7 14-12, 5-7 14-12, 10-8 1-3, 5-7 1-3, 5-7 1-3, 5-7 1-3, 5-7 14-12, 5-7 14-12, 5-7 1.00 & 1.70 1.00 & 1.70 1.70 & 1.20 1.00 & 1.20 1.00 & 2.00 TD/1 TD/1 TD/7 BD/6 BD/6 14-12, 5-7 14-12, 5-7 14-12, 5-7 1-3, 11-9 1-3, 4-6 STANDARD TEMPERATURE RANGE DUAL TRANSFORMERS – OPERATING TEMPERATURE 0°C TO +70°C PE-64951 1:2CT & 1:2CT 1.20 & 1.20 35 & 35 0.50 & 0.50 0.70 & 0.70 PE-64952 1:2CT & 1:1.36 1.20 & 1.20 35 & 35 0.50 & 0.80 0.80 & 0.80 PE-64953 1:2CT & 1:2CT 2.00 & 2.00 50 & 50 0.60 & 0.60 1.00 & 1.00 PE-64954 A 1CT:2CT & 1:1 1.20 & 1.20 30 & 30 0.30-0.55 & 0.50 0.70 & 0.70 PE-64955 1:1.26CT & 1.58:1 0.80 & 0.80 30 & 30 0.50 & 0.50 0.60 & 0.60 PE-64956 1:1CT & 2:1 0.80 & 0.80 30 & 30 0.60 & 0.60 0.50 & 0.50 PE-64957 1CT:1.31 & 2.62:1 1.20 & 1.20 30 & 30 0.80 & 0.80 0.60 & 0.60 PE-65565 1:1.15CT & 1:2CT 1.50 & 1.20 35 & 40 0.60 & 0.50 0.70 & 0.70 PE-65566 E 1:1/1.26 & 1:2CT 1.50 & 1.20 40 & 40 0.50 & 0.40 0.70 & 0.70 EXTENDED TEMPERATURE RANGE DUAL TRANSFORMERS 1 – OPERATING TEMPERATURE -40°C TO +85°C PE-65567 1:1.15CT & 1:2CT 1.50 & 1.20 40 & 60 0.80 & 0.80 0.90 & 0.90 PE-65568 E 1:1/1.26 & 1:2CT 1.50 & 1.20 50 & 60 0.80 & 0.80 0.90 & 0.90 PE-65774 1CT:2CT & 1:1.36CT 1.20 & 1.20 50 & 50 0.96 & 0.80 1.00 & 1.00 PE-68618 G 1CT:1CT & 3CT:1CT:.25 1.20 & 32.0 40 & 65 0.80 & 0.80 1.00 & 3.00 PE-64950 G 1CT:1CT & 1CT:3CT:1 1.20 & 0.60 50 & 50 0.80 & 0.80 1.00 & 0.80 (See Pages 6 and 7 for Table Notes) Mechanicals .800 MAX 20,32 TD DUAL 1.00 TYP 2,54 14 13 12 11 10 9 8 PE-XXXXX DATE CODE 1 2 3 4 5 6 7 DUAL 14 13 12 11 10 9 8 PE-XXXXX DATE CODE 1 2 3 4 5 6 7 DUAL 1.00 TYP 2,54 .130 3,30 .250 MAX 6,35 16 Weight . . . . . . . . . 2.3 grams Tube . . . . . . . . . . . . .25/tube .300 7,62 .385 MAX 9,80 1.00 MAX 25,40 BD .130 3,30 .290 MAX 7,37 .800 20,32 MAX HD Weight . . . . . . . . . 2.6 grams Tube . . . . . . . . . . . . .25/tube .300 7,62 .385 MAX 9,80 1.00 TYP 2,54 9 PE-XXXXX DATE CODE 1 Weight . . . . . . . . . 3.1 grams Tube . . . . . . . . . . . . .25/tube .300 7,62 .385 9,80 MAX 8 .130 3,30 .290 MAX 7,37 Note: Leads are 24 AWG solderable. Dimensions: Inches mm Unless otherwise specified all tolerances are ± .010 0,25 Schematics 14 1 12 2 10 3 9 5 8 14 7 1 12 2 1 3 10 8 14 5 7 1 12 2 2 14 13 12 1 3 5 10 8 5 7 10 3 5 8 6 14 13 12 7 1 2 3 3 16 15 14 1 2 11 10 9 4 6 7 3 6 5 8 5 7 4 14 13 12 8 10 1 2 10 3 5 9 8 7 7 USA 858 674 8100 • Germany 49 7032 7806 0 • Singapore 65 6287 8998 • Shanghai 86 21 32181071 • China 86 755 33966678 • Taiwan 886 3 4643715 www.pulseeng.com 5 T608.S (4/08) T1/CEPT/ISDN-PRI TRANSFORMERS Transformer Selection Guide IC Manufacturer IC Part Number Comments Dual SMT (BH pkg.) Std Temp Ext Temp Dual SMT (AN pkg.) Std Temp Ext Temp Single Through Hole Standard Temp Extended Temp Dual Through Hole Std Temp Ext Temp Reinforced 3 kVrms Single Through Hole TX & RX TX & RX TX & RX TX & RX TX RX TX RX TX & RX TX & RX TX RX MINDSPEED (CONEXANT) BT8510 T1/E1 PE-65866 T1092 PE-68866 PE-68826 PE-65389 PE-65351 PE-68664 PE-65771 PE-65566 PE-65568 PE-65839 PE-65835 BT8510 T1/E1 T1021 T1092 T1021 PE-68826 PE-65389 PE-65351 PE-68664 PE-65771 PE-65566 PE-65568 PE-65839 PE-65835 BT8370/5/6 BETTER RL T1190 T1091 PE-68862 PE-68822 PE-64937 PE-64936 PE-65340 PE-65771 PE-64952 PE-65774 PE-65832 PE-65834 BT8370/5/6 LOW POWER PE-65865 T1076 PE-68868 PE-68825 PE-65388 PE-64936 PE-65770 PE-65771 PE-65565 PE-65567 PE-65838 PE-65834 CIRRUS LOGIC (CRYSTAL) 61318 120 E1 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-65778 PE-64951 PE-65568 PE-65835 PE-65835 61318 75 E1 T1229 PE-64936 T1229 PE-65778 PE-68646 PE-65835 61577 T1 & E1 PE-65861 T1090 PE-68861 PE-68841 PE-65351 PE-65351 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 61304A/5A/535A/574A,/75 T1 PE-65865 T1076 PE-68865 PE-68825 PE-65388 PE-65351 PE-65770 PE-65771 PE-65565 PE-65567 PE-65838 PE-65835 61304A/5A/535A/574A,/75 75 E1 PE-65866 T1092 PE-65866 PE-68826 PE-65389 PE-65351 PE-68664 PE-65771 PE-65566 PE-65568 PE-65839 PE-65835 61304A/5A/535A/574A,/75 120 E1 PE-65866 T1092 PE-65866 PE-68826 PE-65389 PE-65351 PE-68664 PE-65771 PE-65566 PE-65568 PE-65839 PE-65835 61582, 61583 PE-65870 T1093 PE-68874 PE-68874 PE-65388 PE-65388 PE-65770 PE-65770 PE-65838 PE-65838 61310, 61581 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-68778 PE-64951 PE-65568 PE-65835 PE-65835 61310, 61581 HOST T1022 T1077 T1022 PE-65351 PE-65351 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 61881 PE-65865 T1076 PE-68865 PE-68825 PE-65388 PE-65351 PE-65770 PE-65771 PE-65565 PE-65567 PE-65838 PE-65835 61584/84A IQ3 PE-65861 T1090 PE-68861 PE-68841 PE-65351 PE-65351 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 61584/82/83/A IQ5 PE-65870 T1093 PE-68874 PE-68874 PE-65388 PE-65388 PE-65770 PE-65770 PE-65838 PE-65838 MAXIM (DALLAS) DS2196 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-65778 PE-64951 PE-65568 PE-65838 PE-65838 DS2151/2152/2153/2154 PE-65865 T1076 PE-68865 PE-68825 PE-65388 PE-64936 PE-65770 PE-65778 PE-65565 PE-65567 PE-65838 PE-65834 DS2151/2152/2153/2154 T1136 T1091 PE-68862 PE-68822 PE-65586 PE-64936 PE-65340 PE-65778 PE-64952 PE-65774 PE-65832 PE-65834 DS2148/Q48 3V PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-65778 PE-64951 PE-65568 PE-65838 PE-65838 DS2148/Q48 5V T1136 T1091 PE-68862 PE-68822 PE-65586 PE-64936 PE-65340 PE-65778 PE-64952 PE-65774 PE-65832 PE-65834 DS21352/Q352,DS21354/Q354 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-65778 PE-64951 PE-65568 PE-65838 PE-65838 DS21552/Q552,DS21554/Q554 PE-65865 T1076 PE-68865 PE-68825 PE-65388 PE-64936 PE-65770 PE-65778 PE-65565 PE-65567 PE-65838 PE-65834 DS21552/Q552,DS21554/Q554 T1136 T1091 PE-68862 PE-68822 PE-65586 PE-64936 PE-65340 PE-65778 PE-64952 PE-65774 PE-65832 PE-65834 EXAR T5683A, 59L91 PE-65861 T1090 PE-68861 PE-68841 PE-65415 PE-65415 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 T5894,T5897,T5997 PE-65861 T1090 PE-65861 PE-68841 PE-65415 PE-65415 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 T5791/93/94/95 PE-65866 T1092 PE-68866 PE-68826 PE-65389 PE-64934 PE-68664 PE-65778 PE-65566 PE-65568 PE-65839 PE-65834 81L27,82L24,82D20 PE-65862 T1091 PE-68862 PE-68822 PE-64937 PE-65415 PE-65340 PE-65771 PE-64952 PE-65774 PE-65832 PE-65835 83L30/34/38 PE-65861 T1090 PE-65861 PE-68841 PE-65415 PE-65415 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 82L34/38 T5684,T7288,82D20 PE-65862 T1091 PE-68862 PE-68822 PE-64937 PE-65351 PE-65340 PE-65771 PE-64952 PE-65774 PE-65837 PE-65835 INFINEON TECHNOLOGIES (SIEMENS) PEB 2254/55 E1/T1 & J1 PE-68786 T1095 PE-68887 PE-68887 PE-68788 PE-68788 PEB 2254/55 E1/T1 & J1 T1023 T1096 PE-68887 PE-68887 PEB 22504 3.3V T1144 T1144 PEB22554 3.3V T1144 T1144 PEB2256 3.3 V E1/T1/J1 T1144 T1144 INTEL (LEVEL ONE) LXT 300/301 PE-65861 T1090 PE-68861 PE-68841 PE-65351 PE-65351 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 LXT 304/305/307 T1,E1 PE-65861 T1090 PE-68861 PE-68841 PE-65351 PE-65351 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 LXT 304/305/307 T1 PE-65865 T1076 PE-68865 PE-68825 PE-65388 PE-65351 PE-65770 PE-65771 PE-65565 PE-65567 PE-65838 PE-65835 LXT 304/305/307 75E1,120E1 PE-65866 T1092 PE-68866 PE-68826 PE-65389 PE-65351 PE-68664 PE-65771 PE-65566 PE-65568 PE-65839 PE-65835 LX T 304/305/307 DSX-1, D4 T1122 PE-68881 PE-68881 PE-65558 PE-65351 LXT 310/317/318 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-65778 PE-64954 PE-65835 PE-65834 LXT 312/ 313/ 315 PE-64933 PE-64936 PE-68600 PE-65778 PE-64950 PE-65836 PE-65834 LXT 331 T1,E1 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-65778 PE-64954 PE-65835 PE-65834 LXT 331, LXT 332 PE-65861 T1090 PE-68861 PE-68841 PE-65351 PE-65351 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 LXT 331, LXT 332 T1122 PE-68881 PE-65558 PE-65351 LXT 331, LXT 332 PE-65865 T1076 PE-68865 PE-68825 PE-65388 PE-65351 PE-65770 PE-65771 PE-65565 PE-65567 PE-65838 PE-65835 LXT 334, LXT 335 T1/E1 PE-65861 T1090 PE-68861 PE-68841 PE-65351 PE-65351 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 LXT 334, LXT 335 120/75 E1 PE-65862 T1091 PE-68862 PE-68822 PE-65586 PE-65351 PE-65340 PE-65771 PE-64952 PE-65771 PE-65832 PE-65835 LXT 334, LXT 335 75 E1 PE-65866 T1092 PE-68866 PE-68826 PE-65389 PE-65351 PE-68664 PE-65771 PE-65566 PE-65568 PE-65839 PE-65835 LXT 334, LXT 335 T1022 T1077 T1054 PE-64936 LXT 336 PE-65861 T1090 PE-68828 PE-68828 PE-65351 PE-65778 PE-64951 PE-65835 LXT 350, LXT 351, LXT 359 T1,E1 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-65778 PE-64954 PE-65835 PE-65834 LXT 350, LXT 351 PE-65865 T1076 PE-68865 PE-68825 PE-65388 PE-65351 PE-65770 PE-65771 PE-65565 PE-65567 PE-65838 PE-65835 LXT 350, LXT 351 120 E1 T1122 PE-68881 PE-65558 PE-65351 LXT 360/361/362/363 T1,E1 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-65778 PE-64954 PE-65835 PE-65834 LXT 360/361/362/363 PE-65865 T1076 PE-68865 PE-68825 PE-65388 PE-65351 PE-65770 PE-65771 PE-65565 PE-65567 PE-65838 PE-65835 LXT 360, LXT361 120 E1 T1122 PE-68881 PE-65558 PE-65351 LXT 380/381/384/386/388 T1/E1 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64936 PE-65771 PE-65778 PE-64954 PE-65835 PE-65834 LXT 380/381/384/386/388 T1/E1 PE-65861 T1090 PE-68861 PE-68841 PE-65351 PE-65351 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 LXT 3104, LXT 3108 PE-65861 T1090 PE-68861 PE-68841 PE-64936 PE-64936 PE-65778 PE-65778 PE-64951 PE-65835 PE-65835 LXT 3104, LXT 3108 TX1099 TX1099 LUCENT TECHNOLOGIES T7288, T290A CEPT PE-65862 T1091 PE-68862 PE-68822 PE-65586 PE-65415 PE-65340 PE-65771 PE-64952 PE-65774 PE-65832 PE-65835 T7289A DS1 PE-65865 T1076 PE-68865 PE-68825 PE-65379 PE-65351 PE-65770 PE-65771 PE-65565 PE-65567 PE-65838 PE-65835 T7688, T7690, T7698 CEPT PE-68884 PE-68884 PE-65586 PE-65586 PE-65340 PE-65340 PE-65832 PE-65832 T7689, T7690, T7698 DS1 PE-65870 T1093 PE-68874 PE-68874 PE-65379 PE-65379 PE-65770 PE-65770 PE-65838 PE-65838 T7693,T7697 CEPT T1137 TX1287 TLIU04C1 DS1 PE-65870 T1093 PE-68874 PE-68874 PE-65379 PE-65379 PE-65770 PE-65770 PE-65838 PE-65838 TLIU04C1 CEPT PE-68884 PE-68884 PE-65586 PE-65586 PE-65340 PE-65340 PE-65832 PE-65832 ZARLINK (MITEL) MT9071, MT9076 T1137 TX1287 MT9076, MT9075 T1144 T1144 MT9074, MT9075 PE-68678 T1094 PE-68877 PE-68877 PE-65351 PE-64934 PE-65771 PE-65778 PE-64954 PE-65568 PE-65835 PE-65834 PMC-SIERRA PM4341/6341/4314 PE-65862 T1091 PE-68862 PE-68822 PE-64937 PE-65351 PE-65340 PE-65771 PE-64952 PE-65774 PE-65832 PE-65835 PM4318 PE-65861 T1090 PE-68861 PE-68841 PE-65351 PE-65351 PE-65771 PE-65771 PE-64951 PE-65835 PE-65835 PM4351/4354 COMET T1137 TX1287 NOTE: For Quad Port Transceiver products, refer to data sheet T620. For Reinforced Insulation Models, refer to data sheet T617. For Octal Surface Mount packages, refer to data sheet T622. USA 858 674 8100 • Germany 49 7032 7806 0 • Singapore 65 6287 8998 • Shanghai 86 21 32181071 • China 86 755 33966678 • Taiwan 886 3 4643715 www.pulseeng.com 6 T608.S (4/08) T1/CEPT/ISDN-PRI TRANSFORMERS Application Notes 8. Surge Voltage Capability – All transformers and chokes meet surge voltage tests according to the most stringent regulatory documents when system designs include the proper voltage and current suppression devices: 1. Extended Temperature Range Models — For extended temperature range transformers (-40°C to +85°C operating temperature range), OCL (Open Circuit Inductance for the primary winding) is specified at both -40°C and +25°C. At -40°C, OCL is 600 µH minimum for all low temperature models with the exception of PE-68827 which is 800 µH minimum and PE-65836 which is 300 µH minimum. All other parameters are specified at +25°C only. Standard temperature range is 0°C to +70°C. Metallic Voltage: Longitudinal Voltage: 9. 2. ET Product — All coils have an ET product of 10 V-µsec minimum. 800V peak, 10/560µsec 2,400V peak, 10/700µsec Isolation Voltage — 100% of transformers are tested during production to the specified isolation voltage level. 3. Flammability — Materials used in the products are recognized as UL94-VO approved. Products meet the requirements of IEC 695-2-2 (Needle Flame Test). 10. Safety Agency Recognition — Parts listed as "Recognized" or "Certified" meet Underwriter Laboratories, UL 1459 and UL 1950 per file E133523 (S). 4. Balance Characteristics — The transformers meet the requirements for longitudinal balance of FCC part 68. Transformers with Reinforced Insulation according to IEC950 series PE-68630—PE-68788 (pg. 3) are certified by the following organizations: 5. Common Mode Rejection Ratio — the CMRR for all transformers is better than 50 dB at 1 MHz. A typical test circuit is shown below. Code HP-8751A XFMR 100:50 BALUN U UL 1459/UL1950, File E133523 (S), reinforced insulation. 12. Common Mode Chokes — The “high-frequency” 4-lines common mode chokes shown in this data sheet provide an effective means of compliance with national and international regulations on EMI. They are designed to be used in conjunction with Pulse’s T1/CEPT transformers as shown in the typical application below. Crosstalk is typically -70dB at 1MHz and -55dB at 10MHz. 6. Crosstalk Attenuation — In the dual packages, which contain transmit and receive transformers side by side, sufficient crosstalk attenuation is achieved by the inherent characteristics of the toroid cores as well as by their proper positioning. The crosstalk attenuation is typically50 dB or better from 100kHz to 10MHz. This result was established with the test circuit shown below. HP-8751A TÜV, EN 60 950/EN 41003, Cert. R9371358, reinforced insulation. 11. General Information — The transformers are specifically designed for use in 1.544 Mbps (T1), 2.048 Mbps (CEPT) and ISDN Primary rate (PRI) interface applications. They are matched to the majority of the line interface transceiver ICs currently available. Use of the proper transformer allows the interface circuit to comply with ITU-T G.703 and other standards regarding pulse waveform, return loss, and balance. P1 P2 50:100 BALUN Typical Application 50:100 BALUN P1 P2 IC RCVE IC XMiT 100 XFMR 100:50 BALUN 7. Return Loss — ITU-T G.703 and European national regulatory documents specify minimum return loss levels. The transformers will allow these limits to be complied within the situations where they are applicable. 50-100kHz Transformer Transformer 100 Frequency Certificate Information T 100kHz-2 MHz Choke RCVE Choke XMIT 2-3MHz Return Loss XMIT 9 dB 15dB 11dB REC 12 dB 18dB 14dB NOTES FROM TABLES (pages 1 through 6): A. B. C. D. E. Part Turns Secondary Turns Secondary G. PE-68618 and PE-64950: The fault locate winding is (7-8). Number Ratio 1 Pins Ratio 2 Pins H. Safety Agency approvals pending. Toleranced leakage inductance: .30µH min to .55µH MAX. PE-65837 1:1.08 3-5 1:1.36 1 - 5 I. The turns ratio of these devices have been designed, in OCL (primary inductance) and LL (leakage inductance) are PE-65839 1:1 3-5 1:1.26 1 - 5 conjunction with semiconductor vendor recommendations, measured at the primary winding. Turns ratio is specified PE-65866 1:1 2-3 1:1.26 1 - 3 to allow connections to various terminations (e.g. 75 or primary: secondary. (CT = Center Tap; CS = Split Center PE-68646 1:1.58 3-5 1:2 1 - 5 120Ω with the same transformer). For example T1075 can Tap). PE-65389 1:1 3-5 1:1.26 1 - 5 be used with the Siemens PEB 2235 to achieve connection PE-65566 1:1 2-3 1:1.26 1 3 To make a 1CT:1 ratio from a 1CT:2CT ratio, use only one to the 75 or 120Ω cable. For 75 Ω termination, the PEB PE-65568 1:1 2-3 1:1.26 1 3 half of the secondary (2CT) winding. 2235 requires the following turns ratio: 1:1.57 (Tx) and PE-68866 1:1 2-3 1:1.26 1 3 1:1.26 (Rx) which can be achieved using pins (1-2):(15-16) For Reinforced 3kVrms Dual SMT Transformers, refer to PE-68826 1:1 2-3 1:1.26 1 3 for Tx and (10-11):(5-8) for Rx. For 120Ω, the following data sheet T617. For Quad SMT Transformers refer to data PE-68664 1:1 3-5 1:1.26 1 5 turns ratio are required: 1:2 (Tx) and 1:1 (Rx), which are sheet T615. For Octal SMT Transformers refer to data pins (1-2):(16-14) for Tx and (9-11):(5-8) for Rx on the PE-68836 1:1 2-3/5-6 1:1.26 1-3/4-6 sheet T622. T1075. Dual Ratio Transformers — These transformers have F. Standard packaging for surface mount “AN” and “LA” packages is anti-static tubes. Optional Tape & Reel packaging tapped secondary windings to provide two turns ratios can be ordered by adding “T” suffix to the part number, (T/R). Use the entire primary winding and connect the sec(i.e. PE-65857T). ondary pins listed below to obtain the desired turns ratio: USA 858 674 8100 • Germany 49 7032 7806 0 • Singapore 65 6287 8998 • Shanghai 86 21 32181071 • China 86 755 33966678 • Taiwan 886 3 4643715 www.pulseeng.com 7 T608.S (4/08) COMMON MODE CHOKES FOR TELECOM APPLICATIONS For EMI Reduction Electrical Specifications @ 25°C — Operating Temperature 0°C to 70°C Pulse Part Number Turns Ratio (±5%) OCL (µH MIN) Package/ Schematic HIGH FREQUENCY COMMON MODE CHOKES, 4-LINES PE-65554 1:1:1:1 24.0 IN/1 (Through Hole) PE-65555 1:1:1:1 8.0 IN/1 (Through Hole) PE-65854 1:1:1:1 47.0 SH/1 (Surface Mount) PE-65857 1:1:1:1 24.0 LA/2 (Surface Mount) NOTE: For additional Common Mode Chokes, refer to data sheet G002. Schematics Attenuation (dB) 0 -5 -10 PE-65554/65857 -15 -20 1 Typical common mode attenuation for high frequency common mode chokes based on a 100 Ω system. PE-65555 PE-65854 -25 -30 1 MHz 10 MHz Frequency 100 MHz 2 4 5 3 6 2 7 1 8 8 7 6 5 1 2 3 4 Mechanicals SH LA .360 9,14 MAX .100 8X.050 2,54 1,27 8 .475 MAX 12,07 .300 7,62 8 5 .050 1,27 .100 2,54 .340 MAX 8,64 PE-XXXXX .070 1,78 .300 7,62 5 PE-XXXXX Date Code Country ofOrigin 1 .270 6,86 Date Code Country of Origin 1 .600 15,24MAX .120 3,05 .030 0,76 .475 MAX 12,07 .050 1,27 TYP .640 .400 16,26 10,16 .100 2,54 TYP 4 .100 2,54 .085 2,16 SUGGESTED PAD LAYOUT 4 SUGGESTED PAD LAYOUT .340 8,64 MAX .010 / .020 0,25 / 0,51 .098 MAX 2,49 .004/0,10 .040 / .050 1,02 / 1,27 .004/0,10 IN .300 7,62 MAX .595 MAX 15,11 8 7 6 5 .480 MAX 12,19 PE-XXXXX Date Code Country of Origin 1 2 SH LA IN Weight . . . . .0.3 grams . . . . . 2 grams . . . 2.5 grams Tape & Reel . .1500/reel . . . . . .250/reel . . . . . . .(N/A) Tube . . . . . . . . .25/tube . . . . . .30/tube . . . . . .35/tube .100 2,54 3 .300 7,62 CL 4 .130 ± .010 3,30 ± 0,25 CL Dimensions: Inches mm Unless otherwise specified all tolerances are ± .010 0,25 For More Information: Pulse Worldwide Headquarters Pulse European Headquarters Pulse China Headquarters 12220 World Trade Dr. San Diego, CA 92128 U.S.A. www.pulseeng.com Einsteinstrasse 1 D-71083 Herrenberg Germany TEL: 858 674 8100 FAX: 858 674 8262 TEL: 49 7032 7806 0 FAX: 49 7032 7806 12 B402, Shenzhen Academy of Aerospace Technology Bldg. 10th Kejinan Rd. High-Tech Zone Nanshan District Shenzen, PR China 518057 TEL: 86 755 33966678 FAX: 86 755 33966700 Pulse North China Pulse South Asia Pulse North Asia Room 1503 XinYin Building No. 888 YiShan Rd. Shanghai 200233 China 150 Kampong Ampat #07-01/02 KA Centre Singapore 368324 No. 26 Kao Ching Rd. Yang Mei Chen Taoyuan Hsien Taiwan, R. O. C. 32667 TEL: 86 21 32181071 FAX: 86 21 32181396 TEL: 65 6287 8998 FAX: 65 6280 0080 TEL: 886 3 4643715 FAX: 886 3 4641911 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2008. Pulse Engineering, Inc. All rights reserved. www.pulseeng.com 8 T608.S (4/08)
T1090 价格&库存
很抱歉,暂时无法提供与“T1090”相匹配的价格&库存,您可以联系我们找货
