T1/CEPT/ISDN-PRI TRANSFORMER
Quad Port SMT Transformer Module
with Line Side Protection
Four transmit transformers, four receive transformers and
line side protection circuit in a surface mount package
Matched to Level One’s LXT384LE/BE Octal T1/E1 Transceiver
Extended temperature range
Patented “Interlock Base” construction for high reliability
IC grade transfer-molded package withstands 235°C IR
reflow temperature
Minimum Isolation voltage: 1500 Vrms
UL 1950 recognized
Electrical Specifications @ 25°C — Operating Temperature -40°C to +85°C
Part
Number
T9030
1
Turns Ratio
(Pri:Sec ±2%)
Transmit Receive
1CT:2
OCL
Line Side
(mH MIN)
CW/W
(pF MAX)
LL
(µH MAX)
Package/
Schematic
1.2
35 & 35
.50 & .80
BRT
1CT:1
Primary Pins
Transmit
Receive
4-6, 10-12, 16-18, 22-24
48-46, 42-40, 36-34, 30-28
1
For receive channel, to make a 1:2 ratio from a 1CT:1, use only one-half of the primary (1CT) winding.
NOTE: For extended temperature range transformers, OCL (Open Circuit Inductance for the primary winding) is specified at both -40°C and +25°C.
At -40°C, OCL is 600 µH minimum. All other parameters are specified at +25°C.
Schematic
BRT
1
CH1 RX
3
.575
14,61
1.255
31,88
.712 .852
18,08 21,64
48
Surge
Suppressor
4
CH1 TX
T9030
2
.401
10,19
.894
22,71
6
CH2 RX
8
9
.052
1,32
SUGGESTED PAD LAYOUT
CHIP SIDE
.030
0,76
CH2 TX
12
Surge
Suppressor
CH3 RX
14
15
Surge
Suppressor
.020
MIN
0,51
CH3 TX
17
18
Surge
Suppressor
Weight ...............9.2 grams
Tape & Reel..........150/reel
Tube ......................15/tube
Dimensions: Inches
mm
Unless otherwise specified, all tolerances are ± .010
0,25
Surge
Suppressor
23
24
For More Information:
Pulse Worldwide
Headquarters
Pulse
Northern Europe
Pulse
Southern Europe
Pulse
Pulse North China
China Headquarters Room 1503
12220 World Trade Drive
San Diego, CA 92128
U.S.A.
www.pulseeng.com
TEL: 858 674 8100
FAX: 858 674 8262
3 Huxley Road
Surrey Research Park
Guildford, Surrey GU2 5RE
United Kingdom
TEL: 44 1483 401700
FAX: 44 1483 401701
Zone Industrielle
F-39270
Orgelet
France
TEL: 33 3 84 35 04 04
FAX: 33 3 84 25 46 41
No. 1
Industrial District
Changan, Dongguan
China
TEL: 86 769 85538070
FAX: 86 769 85538870
XinYin Building
No. 888 YiShan Road
Shanghai 200233
China
TEL: 86 21 54643211/2
FAX: 86 21 54643210
38
37
35
34
32
31
30
Surge
Suppressor
22
CH4 TX
40
33
19
CH4 RX
41
36
16
.004/0,10
48 Surfaces
43
39
13
.305
7,75
.008
0,20
11
44
42
10
46X .050
1,27
1.150
29,21
46
45
Surge
Suppressor
7
.092
2,34
DATE CODE
COUNTRY OF ORIGIN
5
47
LINE SIDE
Mechanical
29
28
27
Surge
Suppressor
26
25
Pulse South Asia
Pulse North Asia
150 Kampong Ampat
#07-01/02
KA Centre
Singapore 368324
No. 26
Kao Ching Road
Yang Mei Chen
Taoyuan Hsien
Taiwan, R. O. C.
TEL: 886 3 4641811
FAX: 886 3 4641911
TEL: 65 6287 8998
FAX: 65 6280 0080
Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product
names mentioned herein may be trademarks or registered trademarks of their respective owners.
© Copyright, 2006. Pulse Engineering, Inc. All rights reserved.
www.pulseeng.com
T656.A (5/06)
很抱歉,暂时无法提供与“T9030”相匹配的价格&库存,您可以联系我们找货
