T912
T912
    RHOPOINT
    T912 - Precision Resistor Network - RHOPOINT COMPONENTS
T912 数据手册
Type T912 and T914 Precision Resistor Networks Type T912 and T914 Precision Resistor Networks and T914 Precision Resistor Networks Type MG Precision High Voltage Resistors Type MG Precision High Voltage Resistors ® Caddock MG stability required by highly accurate amplifier circuits, ratio performance Caddock Tetrinox resistance films to achieve the precise ratio performance and 650 Tetrinox® resistance films to achievethe source ofvoltage reference C stability required ® esistance films are the precise Micronox andaddock's required by rhighly accurate amplifier circuits, voltage Preconditioning for Power and Voltage Ratings and stability with Extendedaccurate amplifierRange voltagereference by highly Resistance circuits, reference M Type Now circuits and precision bridge circuits. the G 655 and precision bridge circuits. Resistors' outstandingto 10,000 power ratings and maximum operating voltage ratings Voltage All Megohms and Additional Models circuits MG Precision Highcircuits. circuits and precisionfrom features: bridge are for continuous duty. These ratings are based on precombination of Coefficient0.1% to 0.01%. ppm/°C, Combined with Excellent Long-Term Stability and Precision Tolerances. performance tight as 80 ••MG 660 Tolerance -- from 0.1% to 0.01%. Ratio Tolerance Temperature as Ratio •SRatio Temperaturefrom 0.1% as 0.01%. °C, 5 ppm/ or ppm/°C. •••Mingle-resistor valuesCoefficient --10,000 Megohms. °°Cor 22ppm/°stress voltage levels applied during the manufacturing as high to 10 ppm/ Ratio Tolerance - Coefficient 10 ppm/°C, 5 ppm/ C G 680 C. Caddock's Micronox® resistance 0 ppm/ high as are process to provide for stable Voltage Ratings even •MRatio Temperature operating voltages5 ppm/theppm/°C of Ratio °C. •••MG 710 Temperature Coefficient - 1films as°C,°°C. sourceor 2 ppm/Preconditioning for Power and resistor performanceratings aximum continuous Absolute Temperature Coefficient 25 ppm/ 5 theAbsolute Temperature Coefficient --Resistors' outstanding Type volts ("-15" ratings). Voltage 2 MG Precision High All power ratings and maximum operating voltage C. under momentary overload conditions. • MG 712 Absolute Temperature Coefficient 25 ppm/° •48,000Stability of Resistance at Full- Load for C. Ratio Full within 0.01%. are Maximum operating for combination of performance features: Load for 2,000 hours -within 0.01%.continuous duty. These ratings are than the values higher based • •• Ratio Stability of Resistance at of standardfor2,000 hours - - within 0.01%. table may voltages 60% by adding "-15"on preORatio Stability of Resistance at Full Load working hours vervoltage capabilities of 150% 2,000 stress the listed involtage levels applied during the manufacturing be specified to the Shelf for all values as high for 10,000 Megohms. 0.005%. •••MG 714 Life Stability of and values, Months -- within 0.005%. SShelf Life Stability of Ratio for 6 Months "-15" ratings). ingle-resistor models Ratio as 6 (except within process •voltagesthecontinuousof Ratio for 6 available high as 0.005%.resistancevaluesto provide for stable resistor Note that overload Shelf Life T912 and the T914 are available -in ithin Stability operating voltages as w 14 standard Months model number (Example: MG750-15). performance even Both the • Resistance T912 and from ±1.0% to Maximum Both T914 are in standard resistance values •between the Tolerancesthe 1 Megohm. ±0.1%. in14 high thru-put manufacturing under momentary overload not apply and overvoltage ratings do conditions. to the "-15" resistors. Both T912 and the MG 715 Caddock's high 48,000 1,000 ohms and T914 are available ratings). between 1,000 ohms and forMegohm. resistance14 standard resistance values operating voltages 60% higher than •capabilityvolts ("-15"that prototype and large-volumehighthru-put manufacturing ranges for "-15" resistors shown in thethe values Temperature Coefficient, 1 Megohm. large-volume production quantities are standard Caddock's range,thru-put manufacturing Maximum Resistance table are between 1,000 ohms andof 150% and Caddock's production quantities are 1 assures that prototype of standard working of • capability assures Overvoltage MG 716 80 ppm/°C incapabilities as listed in Min." capability either from stock with resistance tolerancesproduction assures that and within 6 weeks after receipt of order. from "-15 the to may be Max." available eithercombinationor values,6(except after receipt of order. quantities are table"Standard specified by adding "-15" to the weeks "-15" ratings). available for all from voltages±0.1%. models prototype and large-volume tight as model number (Example: MG750-15). Note that overload available either from stock or within 6 weeks after receipt of order. Non-Inductive Performance MG 720 • Type MG Tolerances demonstrated stability Resistance Non-inductive performance andMovervoltage ratings do not apply to the "-15" resistors. •Standard resistors havefrom ±1.0% to ±0.1%. of 0.01% ost are manufactured with Caddock's T914 Precision Resistor Networks models with Caddock's exclusive design shown in the table are Standard hours in extended standard testing of standardof Specifications: Specifications: MG 1,000 Type T912 •Standard Type T912 and Type T914 Precision Resistor Networks Temperature Coefficient, for load life resistance range, Resistance ranges for "-15" resistors a serpentine resistive per 725 Non-Inductive Design which uses Type T912 and Type T914 Precision Resistor Networks Specifications: 80In addition to the 14 standard eresistance models of the Type T912 pattern that provides for neighboring lines to carry current in ppm/°Crange values. with qual value tolerancesthe Type T912 and T914, into the 14 combination as from "-15 qual value models of resistance In addition and T914, Min." to "Standard Max." MG 717 Absolute Tolerance: ±0.1% all Absolute Tolerance: ±0.1% for for all resistors. tight as T912 can also theTIn addition to the 14 standard equal value models ofthrough T912 and T914, with theTypeexceptionalalso be ordered has -been proven the Type Type T912 can performance with his ±0.1%. Non-InductiveMost models achieving 0.1% for resistors. Performance opposite directions, thereby are available withall resistors. Absolute Tolerance: ± maximum cancellation the Type T912 can Ratio forderedthat •••Type Resistance Ratio -demonstrated-stability the highest many yearsresistorsalsoequipment inwith demandsof 0.01% M ost models the Temperature Coefficient:resistor. °C of flux fields over Non-inductive Serpentine Pattern ppm/°C Absolute entire length Coefficient: Caddock's Absolute manufactured with ± ppm/ This 10:1MG of use in be or use amplifier gain-setting. Resistance have Caddock's are Temperature of the ±25 25 10:1 amplifier gain-setting. MG 1,000 hours in extended load of standard reliability and stability, -including life testinggain-setting. TWT amplifiers, X-ray Non-Inductive referenced which C, C,R R a accomplishedresistive Design toTemperature taken 0°C °C and +70°C. Absolute +25° ° ∆ •per721 Resistance Ratio f use in voltage reference dividers. 10:1Resistance efficient non-inductive construction∆takenserpentine+70without at at 0 and °C. referenced to +25usesis Coefficient: ±25 ppm/°C 9:1 ••resistance rangeRatio - foror use in amplifier 9:1 Resistance Ratio voltage reference dividers. values. referenced to +25°C, ∆ taken systems, geophysical instruments, and medical electronics. pattern of provides for neighboringRlines at 0°C and +70°C. deratingthatany performance advantages. to carry current in • MG his exceptional performance has been proven dividers. 9:1 Resistance Ratio - for use in voltage reference Voltage Rating: 3 03 0 volts DC or RMS AC volts DC or RMS AC Voltage Rating: T730 through opposite directions, thereby achieving maximum cancellation Ordering Information: T912 - A 10K -- 010 --02 A 10K 010 02 Ordering Information: applied to R R1, 2R2,3 a 3 nd volts Voltage entire R a many years Information: in equipment that - Resistance Ratio highest Track °C totofluxC): (millimeters)applied to 1Rating:R3nd0R4.R4. DC or RMS AC of +70and the , R , length Dimensions in +70° ° T912 010 - 02 Ratio Temperature Ordering of useOverload Dielect. - A 10Kdemands the Temperature Track (0(0°CinchesC):*fields over Specifications:of 4.the resistor. This Max. Model Model Model Number Watt- Continuous applied construction ais accomplished to R1, 3 nd R -10 5 reliability Number stability, including TWT amplifiers,=Temperature A -05 =efficient *non-inductive Rating:R2, Rwatt applied to R1,RR,2,without and Standard Ratio =X-ray°C Track (0=Cppm/°C°°C Extendedppm/°C -15 -10 10 ppm/ 10 -05 ° 5 ppm/ C): No. 735age Code Letter: B to +70 MG Ratio Oper. Volt. Rating Strength Min. 2 Power 0.10 * C Power Rating: 0.10 watt applied to 1 RR,3 R3 Resistance Tolerance: Model -02 = 2 ppm/°C Max. Max. Min. Ratio Number Letter: * ° -10 = 10 -02 = 2 ppm/=C5 ppm/°C of anyand R4 (not to exceed rated voltage). -05derating systems, - Code with R :*R where R = 10R performance advantages. voltage). A geophysical instruments, and medical electronics.ppm/°C T912 A -T912 with R : R where R = 10R and R4 Rating: 0.10 watt Ratio Tolerance: -100 = 0.1% �.020 .094 �.015 .025 �.002Power (not to exceed rated applied to R1, R2, R3 -020 = 0.02% .313 Type T912 and T914 Precision Resistor Networks are constructed with Page 1 of 2 Temperature Coefficient as tight asResistor Networks are ratio performance Long-Term Stability and Precision Tolerances. Type T912 and T914 Precision 80 ppm/°C, Type T912 and T914 Precision Resistor theCombined with Excellent Caddock Tetrinox® resistance films to achieveNetworks areconstructed with precise constructed with Resistor Pairs and Quads with Ratio Characteristics for Precision Analog Circuits Resistor Extended Resistance Range to 10,000 Megohms and Additional Models Now with Pairs and Quads with Ratio Characteristics for Precision Analog Circuits Resistor Pairs and Quads with Ratio Characteristics for Precision Analog Circuits Resistance Range Tolerance Ratio eg = 0.1% ppm/°C 10K:100K 40K:400K 0.5 Code Letter: 5 MTolerance: -100 -02 = 2 .51) -020 = 0.02% (.64 �.05) N/A 750 N/A Type MG650 Ratio 11K:10K 60010K:100K 1 40K:400K 200 � K:10K �.38) (7.95 -050 = 0.05%� -010 (2.39 0.01% = 0.01% T912 with R1: R2 where R2 = 10R1 and R4 (not to exceed rated voltage). -010 = 0.02% MG 745 A -2K:20K 2K:20K 20K:200K 50K:500K Ratio Tolerance: -050 = 0.05% -100 = 0.1% -020 = 20K:200K 50K:500K Package Power Rating: Type �T912,�0.25%, �0.1% 1K:10K 10K:100K 40K:400K .109 0.01% .025 �.002 Package Standard Rating:�1%, 0.5%, 0.20 watt. Power Type T912, 0.20 watt. .313 �.030 -010 = �.025 (millimeters) Resistance 5K:50K 25K:250K Dimensions Standard Resistance Values:-050(R1)0.05% in inches and ) Type 100K:1 Meg 0.5 5K:50KMax. 25K:250K 1 100K:1 Meg 200 � 750 8 Meg N/A MG655 WattStandard Resistance N/A Values: (R1= Overload Dielect. Model 2K:20K 600 20K:200K (7.95 �.76) (2.77 �.64) (.64 �.05)Type T914, 0.40 watt. Type T914, 0.40 watt. Continuous Rating 50K:500K 10K 40K Package Power Rating: Type T912, 0.20 watt. -15 1K Standard Extended 200K A 500K 1K 10K 500K B - T912 with R1: R2 where R = Strength 9 R1 No. age5K:50K R125K:250K R 2 100K:1 Meg Min. B C St'd with "-15" �1% Standard Resistance40K Values: 200K) (R B1 Oper. : R Resistance rating 20K 50K Meg Max. Max. 250K 1500 1 .030 .094 �.015 .025 �.002Type T914, 0.40Tolerance: . � 1 Meg Min.2K MG 731 0.6 T912 with Volt. 2 where 1 2 = 9 R750 1K:9K 10K:90K 40K:360K 2K 50K 250K watt. Type Meg N/ N/A 5K MG660 1K 10 20K 10K 100KA 40K 200K 500K (2.39 �.38) 1T912 1,00010K:90K K:9K with R1: R2 where R2 40K:360K 400 � 25K 400K (12.70 �.020 .094 �.015 .025 �.05) (.64 �.002 °C. Storage Extended Range -55°C °to +105�1%°C. Temperature: B - 2K:18K = 9 R1 20K:180K 50K:450K 5K 25K 100K 400K313 �.76) . +105 Storage Temperature: -55 C to Tolerance Resistance Range 2K 50K 1 Meg 50K:450K � 5 20K Meg N/ are 250K 750 Type MG650 0.52K:18K 60020K:180K 1 100K:900K 200 SpecialN/Amixed resistance valuesA available as custom networks. 1K:9K 10K:90K 40K:360K or .094 �.38) 5K:45K 25K:225K (7.95 .51) (2.39 �.015 (.64 �.05) .750 custom networks. 400K Special or mixed resistance 100K available �.030 2,00025K:225K 1 100K:900K 600 See the custom section at thevalues are this(19.05as.76) (2.39 �.38) .025 �.002Storage Temperature: -55°C to +105°C. 750 Meg N/A � N/A 5K 20 25K MG680 0.8 5K:45K Type 2K:18K 20K:180K 50K:450K bottom of page. � (.64 �.05) Insulation Resistance Between0.5%, �0.25%, �0.1% Standard �1%, No Letter - T912 with R1 = R2 Temperature Coefficient:� Isolated Pins: .313 as custom networks. � See the custom section at the bottom of this page. .030 .109 �.025 .025 �.002 Insulation Resistance Between Isolated Pins: Special or mixed resistance values are R1 = 1 750 N/A MG655 No Letter --T912 with TypeR2 = R3 = R4 MG 740 0.5 5K:45K 600 25K:225K R2 100K:900K 200 � (This information 8 Meg on N/Aback available ��network)094 �.015 .025 �.002 No Letter T914 with R1 = . appears the side(7.95 .040 of the (.64 �.05) 2 to Pin 3, Pin 4 to Pin 5, or Pin 6 to Pin 7, 1.000 .76) (2.77 �.64) Pin See the custom section at the N/A bottom of side of the 1.0 Letter -- T914 with R11 = 1 750 800 � (This information appears on the backthis page. network) �.38) 50 Meg N/A MG710 No Letter 4,000 with Type R22 = R3 = R4 Insulation Resistance Pin 5, or �1% Isolated Pins: St'd with "-15" rating No T912 R =R to Pin e 1.02) .094 (25.40 ��.030 (2.39 �.015 .025 �.05)Pin 2 Resistanc3, Pin 4 to Between Pin 6 to Pin 7, (.64 �.002 .500 TC 1,000 Megohms, minimum. Pin Specifications No - T914 R1 = 1 750 400 � (ThisA 10 Meg N/A N/ information appears on the back side of the network) �.030 MG660 0.6 Letter1,000 with Type R2 = R3 = R4 Range to Pin 3, Pin Pin .140 1,000 Extended Range 4 to (12.70��.76) (2.39 �.38) .025 �.002Pin 2 Megohms, minimum. 5, or �1% 6 to Pin 7, (.64 �.05) .400 .060 Type 2 1,000 750 800 � 20 Meg N/A N/A MG712 0.6 (10.16 .152) .094 �.015 (.64 Type T912 Type T914750��.030 (3.56 �.76) .025 �.05) 1,000 Megohms, minimum. Isolated Pins: Standard and . MG 750 Dielectric Strength Between �C from -15�C to +105�C, Type T912 Type T914 �.76) (2.39 �.38) (.64 �.002 80 ppm/ 600 � 2,000 750 20 Meg N/A N/A MG680 0.8 .150 �.05) St'd with "-15" Dielectric Strength �Between Isolated Pins: Ratios Available: 1:1, Type 1 9:1, 10:1 and Custom. .562 .060 Ratios Available: 1:1(19.05�Custom. �.030 .032 �.002 and 1.0 1,000 20 Meg N/A MG714 Type9:1, 10:1 and Custom. 6.5 Meg Ratios Available: 1:1 and1.52) (3.81 �.76) (.81 �.05) volts RMS g T912 750 200 � Type T914 � .040 .094 �.015 .025 �.002 Temperature Coefficient: Isolated Pins: Ratios Available: 1:1, Type 2 50Dielectric Strengthreferenced to +25�C. Custom. (14.27 � (2.41) ratin AC. 1.000 .095 50 volts RMS eAC. Between .020 1.0 4,000 .020 9:1,.095 (2.41) 800 � 50 Meg .900 ±N/A 1 MAX. and MG710 .500 Ratios Available: ±1:1, Type.095 (2.41)750 Custom. N/A 10:1 Ratios Available: 1:1 and Custom.�.030 .025 �.002 MAX. Resistanc �1.02) .140 (25.40.095 (2.41) (2.39 �.38) (.64 �.05) .750 �.060 (22.86 ±.51) .900 ±.020 (12.70 .020 .500 50 Stability Under Load: Specifications +105� 2,000±±.51) Type 2 MAX. 750 400 � 26 Meg 50 Meg (22.86N/.51) MG715 1.0 MAX. �C Ratiovolts RMS AC. �80 ppm/TC from atio�Cchange C, R +25 to MG 780 ±A Range (19.05 �1.52) (3.56 �.76) (.64 �.05) (12.70 ±.51) .095 (2.41) .400 .095 (2.41) .140 �.030 .025 �.002 �.060 .900 ±.020 Ratio Extended Stability Under Load: +50 ppm/ Cchange R atio from .500 -200 1,000 ±.020 Type 2 MAX. 750 800 � 20 Meg (22.86N/.51) N/A MG712 0.6 MAX. (3.56 �.030 ±A .140 �.76) .025 �.002 between any two resistorsppm/�C�to network �under in theC. Range (10.16 �.060 (.64 �.05) (12.70 ±.51) 1.000 �.152) Standard and Under toLoad: CADDOCK Type 2 ±.020 750 .500 ±.020 -15�C +25from -15�C to +105�C, 1 of 2 600 � 70 Meg 1.5 4,000 75 Meg CADDOCK N/A MG716 Ratio Stability resistors �in the network under R atio change .500 any2,000 �80 ppm/at +70 ° C, 0.01% two hours C Page T914 (.64 �.05)between with "-15" (25.40 �1.52) (3.56 �.76) T912 CADDOCK (12.70 �.060 ±.51) CADDOCK (12.70 ±.020 .500 St'd .562 ±.020 .150 �.030 .032 �.002 load for full .500 ±.51) 0102 T914 1.0 1,000 200 � 6.5 Meg 20 Meg 0129 N/A MG714 Type 2 ±.51) 750 referenced +25 T912 (12.701.52) .240 �.76) (12.70 full Insulation 2,000 hours to the� network under load for � ±.020 (14.27500±.51) (3.81 �.030 .040 �.002between any two resistors in0,000C. ° C, 0.01% (.81 �.05) .710. �.050 0129 MG 785 1.5 CADDOCK Type500 ±.020 750 0102 Megohms, min. .2 maximum. rating Resistance: 1 at +70 2,000 600 � 17 Meg 75 Meg CADDOCK 225 M MG717 T914 T912 (18.03 �1.27) (6.10 �.76) (1.02 �.05)maximum. for 2,000 hours at +70 ° C, 0.01% (12.70 ±.51) .140 �.030 (12.70 ±.51) full load .025 �.002 .750 �.060 .020 0129 PIN .020 0102 PIN 750 400 � 26 Meg 1 50 Meg N/A MG715 1.0 1 2,000 Type 2 �80 ppm/ from +25 rated power (.51) Overload/Overvoltage:�C 5 times�C to +105�C, (.51) (19.05 �.080 (3.56 �.030 .025 �.002maximum. (.64 �.05) .020 1.500 �1.52) .140 �.76) PIN 1 Extended .020 2 .010 Shelf Stability of Ratio: ppm/�C months at�C from Type ±.040 750 .0101 K 0.100 N/A N/A .100 150 Meg MG720 2.PIN 1 6,000 (.51) ±.040 -200 to +50 1.5 shelf .150 �2.03) (3.56 �.76) (.51) .150 (.64 �.002 (38.10 ±1.02) (.26).030 with Range applied of Ratio:Six exceed ppm/ at shelf (2.54) 1 .140 .010 � (.26) (2.54) .020 .025 �.05)Shelf Stability voltage �not to Six months times max1.000 �.060 (3.81 ±.040 .100 PIN .020 (3.81 ±1.02) .010 PIN .150 -15 C to Type ±.040 5 600 MG716 1..100 1 4,000 .150 (.51) conditions, 50 ppm maximum. +25�C. (.51) �.76) .040 �.002 MG 810 (2.54) .100 (2.54) CENTERS 2±1.02) 750 (.26) � 70 Meg PINS 75 Meg (2.54) N/A (2.54) ON .100 8 CENTERS (25.40 �.050 (.64 �.05) 1.000 �1.52) (3.56 (.26) 4 PINS ON (3.81 ±1.02) .240 �.030 imum continuousmaximum.voltage for 5 at shelf . operatingSix months seconds (3.81 .010 Shelf Stability of 2.0 4,000 200 1 300 M MG721 .100 Type 2 ±.040 750 .010 � 51 Meg8.100 00 Meg (2.54) CENTERS(25.40 �1.27) (6.10 �.76) (1.02 �.05)conditions, 50 ppm Ratio: .150 ±.040 .150 PINS (.26) (2.54) ON .100 R1 4 PINS ON .100 (2.54) CENTERS R2 R3 R (.26) (2.54) .710 �.050 4 .240 �.030 .040 �.002 (3.81 ±1.02) R2 Insulation Resistance: 10,000 Megohms, min. (3.81 Type 1: DC Voltage 1.5 R1 2,000 600 � 17 Meg 7 Meg 225 Type 2 ±1.02) 750 MG717 .140 �.76) .025 �.05)conditions, 50 and Voltage PINS ON .100 source of R �1.27)R4(6.10 �.030 (1.02 �.002 Caddock's (2.54) CENTERS 2 ® resistance films 8are5 Meg (2.54) CENTERS(18.033�.080 Preconditioning for Power ppm maximum. Ratings Micronox the R1N/AM R2 2.000 4 PINSR1 .100 R2 2.5 ON 10,000 750 1.5 K 200 N/A MG725 Type Type 2: DC Voltage or VrmsAC times rated power Overload/Overvoltage: 5 (.64 �.002 � .080 4 .140 �.030 .025 �.05) (50.80 3 2.03) R(3.56 �.76) R1 R2 1.500 the Type R1MG RPrecision High Voltage N/AINCHES 50 Megoutstanding R6� 7 8(3.56 �.76) All power ratings and maximum operating voltage ratings 2 Type 2 6,000 750 DIMENSIONSResistors' 1 1K 1 N/ MG720 2.0 MG 815 1 IN 2 A3 4 (38.10 �.080 5 (.64 �.05) 2.03) .240 �.030 .040 �.002 23 4 ResistanceThese ratings are based on preOverload/Overvoltage, �R 1,000 DIMENSIONS IN INCHES Meg 1 750 1 = R2 41.500 �R4 7 are for continuous with applied voltage not to exceed 1.5 times max500 � 77 Meg 250 M3 6,000 MG730 3.0 AND (MILLIMETERS) Type 2 duty. Range combination of performance features: 2 5 R =1.000 �6 R3 = .050 (38.10 �2.03) (6.10 �.76) (1.02 �.05) 1 23 4 .8 �.030 .040 �.002 240 imum continuous operating voltage for 5 seconds. AND (MILLIMETERS) 2.0 4,000 750 DIMENSIONS IN INCHES Meg 1 300 M 3 R24 = 5 3 �1.27)stress voltage levels Standard 200 � 51 Meg 100 MG721 Type 2 R R applied during the manufacturing 0.5% max. 21= 8 .315 �.76) .040 �.05) (25.40 �.0607 (6.10 �.030 (1.02 �.002 1.000 =6R4 1 2 4,000 values2as 1,000 3 4 Single-resistor high as 10,000 Megohms. M 40 Meg 1 2.6 200 �(MILLIMETERS) 50 Meg 750 Type MG731 Type 1: DC Voltage Page 1 of 2 AND (25.40 �1.52) .140 �.030 .025 �.002 R1 = R2 2.000 �= R4 (8.00 �.76) (1.02 �.05) = R3 .080 St'd with stable resistor performance even "-15" rating 750 K 10,000 N/ MG725 2.5 Type Maximum continuous 2operating 1.5coveredAbyas200or more N/A voltages one Meg as patents,(50.80 �.080 process to provide for DC Voltage or VrmsAC N/A high Type 2: (3.56 � .76) .240 � (.64 �.05) 2.000 �2.03)also patents .040 �.002 Certain3.6 products shownType 2 catalog are � 178 Meg 300 Meg 1,000 M in this 1,000 there are under.030 pending. overload conditions. momentary Extended Range 10,000 MG735 0.8% max. 48,000 volts ("-15"Type 2 1,000 750 � 77 Meg 250 Meg 750 M (50.80 �2.03) (6.10 �.76) (1.02 �.05) ratings). .240 �.030 .040 �.002 1.500 �.080 Call Resistance Range 60% Overload/Overvoltage, � 500 6,000 MG730 3.0 Maximum operating voltages or write our ApplicationsR higher than the values For applications requiring non-standard .315 �.76) .040 �.05) (38.10 �2.03) (6.10 �.030 (1.02 �.002 1.500 Overvoltage capabilities of 150% � standard working M (38.10 �.060 (8.00 �.76) (1.02 �.05) Thermal Shock: orMil-Std-202,max. 3.6 6,000 1,000 300 of 64 Meg 300 Meg 1,500 Type 2 MG740 write performance,to Engineering for our Applicationsthe �1.52) listed .030 the �table mayStandard Call 0.5% For2.6 values, the T912 and T914 custom applications Type 2 1,000 B 200 C 40 Meg requiring non-standard be specified by adding Method 107, "-15" resistance.125 1.000 �.060 .315 � in .040 .002 A � MG731 1.500 ± for4,000 models and values, (except 150 Meg ratings). (25.40 �1.52) (8.00 �.030 (1.02 �.05) Call voltages± .18)all Engineering for performance, .240 �.76) .040 �.002 price or availabilityApplications of 0.25% write ourN/A these Cond. C, MG750-15). (38.10 3.000 For applicationsType 2 these T914288 Meg "-15" 750 M requiring resistance 3values, the T912 and special features: custom configurations can include 1,000non-standard 500 Meg 1,500 M (76.20 �.100 model number (Example: ΔRratingand max. Note that overload 15,000 1K MG745 5.0 St'd with "-15" �2.54) (6.10 �.76) (1.02 �.05) Engineering for performance, .240 �.030 .040 �.002 2.000 �.080 price and availability Method RMixed6 resistance values with a maximum are esistance10,000 Tolerances 1,000 T914178 Meg 3 resistance values, the T912 and 750 � films ratio Moisture and Voltage the "-15" these MG735addock's can include rthese special ±0.1%. Meg 1,000 M Type 2 configurations Micronox®from ±1.0% tocustom 00 the source of �.060 Preconditioning for Extendeddeveloping Low 0.8% max.of resistors. features: C 3. esistance Power notcustom resistor networks. 106, (6.10 �.76) .040 .05) .315 overvoltage (50.80 �2.03) engineering �.002 ratings do Range apply to RatingsTC these For immediate and �.030 (1.02 �assistance in Resistance: Mil-Std-202,networks. Ratio 2.125 price and availability of matched 500 10,000 MG750 5.0IN INCHESCoefficient, 1,000 Type 2 (8.00 ll.030 (1.02 �.05) configurations (Example: 1.0 Megohm 128 Meg ratioMeg range, of (53.98 �1.52) Resistance or writeRour Applications Engineering andratings these 400 � special features: 2,500 M Tof 250-to-1. can(MILLIMETERS) DIMENSIONS resistance include with Voltage Resistors' outstanding "-15" resistors shown voltage we Mixed MG AND values for a 300 � and 4 K)00 Meg 1,500 M maximum 3 theemperature Precision High standard64resistancehigh voltage resistor.315 �.76) callranges Δfor0.4% max. custom resistorthe table are Type A � power �ratings and maximum operating in networks. will .040 .002 1.500 �.060 sets, Meg 3.6 6,000 1,000 Type 2 MG740 custom resistor Method rated (8.00 �.030 (1.02 �.05) Thermal Shock: .315 �.76) Min." (38.10 3.125 80 ppm/°C15,000 low as 15 ppm/resistance K) be pleased to�1.52)fromfor continuous"Standardour1,000 Mil-Std-202, in combination Megohm Mixed of 7.5 resistance values 1,000 a °C. duty. precombination TC performance with 600 � 192 Meg ratioMeg 3,750as (79.38 �.060 are the best �solution from These ratings are +125°C on 107, MG780250-to-1. (Example: 1.0 features: and 4 tolerances M Absolute of as Type 2 with maximum 750 offer �"-15 .040 �.002to Load Life: Max." hours at resistoratproduct high voltage based (8.00 .76) Cond. C, Δ .040 .002 3.000 �1.52) .240 �.030 (1.02 �.05) tight as TC as 100 2 1,000 voltage, not to during Derating 5.0 ±0.1%. low as 1.0 ppm/°C. 288 Meg K) Meg 1,500 M (76.20 �.100stress voltage PerformanceR 0.25% max.the manufacturing Curve: of 15,000 MG745250-to-1. (Example: 15 Megohm and 4 500 capabilities. Type on-Inductive Absolute 20,000 values 2as 1,000 as1 K� 320 MegMegohms. M 4.000 �.120 N(6.10 �.030 (1.02 �.002 levels applied exceed rated power. .315 �.76) .040 �.05) �2.54) SRatio TC as low as 2 ppm/°C. 80010,000 1,000 Meg 5,000 ingle-resistor high MG785 8.0 Type Moisture Resistance: Mil-Std-202, Caddock's Type MG resistors have demonstrated stability of 0.01% (101.60 �3.05) (8.00 �.76) (1.02provide are stable for manufactured Load Life, Method 106, .315 �.030 .040 �.05) Absolute continuous operating °C. as 80 M ost with �R Range �.002 2.125 �.060 Maximum TC low inTypeas 15 ppm/voltages as 500 Meg as M (53.98 �.120 process tomodels ΔResistancemax. resistor performance even Ratio RATED POWER ORlow 2 2ppm/° load 128 Meg high 2,500 TC 10,000 MG750 5.0 voltage ratings. 1,000 Custom hours 60 (8.00 �.030 (1.02 �.002 R 0.4% .315 �.76) .040 �.05) overload conditions. per 10.0 as low asextendedC. 400 � 400 Meg 1,250 Meg 6,250 M 5.000 �1.52)Non-Inductive : momentary MG750 -100M - a which Type 25,000 1,000 RATED as MG810 1,000 VOLTAGE, % as 22 ppm/°C. 1 K life testing of standard (127.00 �3.05)under.76) (1.02 �.05) Design Standard uses 1% serpentine resistive 40ratings). Ratio volts ("-15" (8.00 � .030 0.5% max. 48,000TC resistors of any special value .315 � Custom voltage ratings. 1,000 600 � 192 Meg 750 Meg 3,750 M .040 3.125 �.060 Matched range 20 2 resistance 15,000 values. Type 7.5 Maximum �.002 Load voltages ,000 hours at +125°C at rated operating Life: 1 60% higher carry current in MG780 (79.38 �.120 pattern that provides for neighboring lines to than the values 6.000 �1.52) (8.00�.040 (1.02 �.002 .350 �.76) Obetween resistors Type any 1,000 vervoltage capabilities special value of Model Number:.040 �.05) Tolerance Custom 30,000 St'd with rating MG815 15.0 voltage ratings. of 150% K 384 Meg 2,000working M (152.40 �3.05)listed 1.02) the �.05) 2 voltage, "-15" to exceed maximum "-15" to the power. 0 Megohms. Matched 1 K and 2 performance1175 standardproven through �.120 opposite (1.02 �.002 may benotachieving rated 0.8% max. of 25 75 125 has been Meg 10,000 (8.89 � .030 directions, therebyspecified by adding cancellation This exceptional .315 � in .040 table 4.000 225 275 voltages 120,000 MG785 8.0 for all models and values, (except "-15" ratings). (101.60 (8.00 � number Matched K use in AMBIENT TEMPERATURE, ° demands 5,000 M special Extended Range 0.8% max. between of and Type 2 Megohms. that many yearsresistors2of any 1,000 800valueCMeg 1,000 Megthe highest �3.05)model.76) fields�.05)(Example: MG750-15). of Note resistor. This equipment � 320 Load that of Resistor (1.02 over Resistance Range flux Value: the entire length the Life, �Roverload Models Tolerances .315 �.030 .040 �.002 RHOPOINT COMPONENTS LTDconstruction are Meg 1,250 areas. 5.000 �.120 efficient non-inductive Resistance25,000low Type 2 from between with 2 Megohms. 1 K 400 in shaded do not reliability and andinductance1,000±1.0% to ±0.1%. Meg 6,250 M (127.00 �3.05)and overvoltage ratingsconstruction is to the "-15" resistors. Solderable Leads MG810 10.0 1 K stability, including TWT amplifiers, X-ray (8.00 �.76) (1.02 �.05) Standard apply accomplished without 0.5% max. Holland Road, Hurst Green, Temperature Coefficient as tight as 80 ppm/°C, Combined with Excellent Long-Term Stability and Precision Tolerances. Now with Extended Resistance Range to 10,000 Megohms and Additional Models • • Custom Model T912 and T914 Precision Resistor Networks Now with Extended Resistance Range to 10,000 •Custom Model T912 and T914 Precision Resistor Networks inMegohms and Additional Models with Design Assistance Developing High Voltage Resistor Sets Temperature Coefficient as tight as 80 ppm/°C, Combined with Excellent Long-Term Stability and Precision Tolerances. Low TC Tracking. Custom Model T912 and T914 Precision Resistor Networks RHOPOINT 0 COMPONENTS LTD with resistance tolerances as St'd with "-15" rating 0.8% (0)1883 717988 1 K 384 Meg 2,000 Meg 10,000 M (152.40 �3.05) MG815 Road, Hurst Type Tel: +44max. Holland 15. COMPONENTS LTD. 1,000 RHOPOINT 30,000 Green, 2 80 ppm/°C in combination (8.89 "-15 Min." to from �1.02) (1.02 �.05) "Standard Max." web: www.rhopointcomponents.com Phone: +44 Holland Road(0) 1883 717988 Fax: +44max. (0)1883 712938 RHOPOINT COMPONENTS LTD e-mail: sales@rhopointcomponents.com Oxted, Surrey, RH8 9AX Hollandas ±0.1%. Green, Road, Hurst Extended Range 0.8% Applications Engineering Sales and Corporate Office tight Fax: +44 (0) Hurst Green 1883 712938 Resistance DimensionsNon-Inductive Performance in inches and (millimeters) e-mail: sales@rhopointcomponents.com Specifications: 1717 Chicago Avenue Max. web: www.rhopointcomponents.com Phone: Surrey, with 9AX +44 Umpqua Hwy. Model Surrey, RH8 717988 Watt- Continuous Overload Dielect. Oxted, Models 1883 9AX are in shaded areas. 17271 North (0)RH8low inductance constructionRHOPOINT COMPONENTS LTD web: www.rhopointcomponents.com RHOPOINT 0.01% Oxted, MG resistors Rating demonstrated -15 •Phone: +44 1883 712938have Strength Min. stability ofCOMPONENTSmodels Solderable Leadswww.rhopointcomponents.com Type Standard Extended No. A C MB ost LTD. Resistance web: are manufactured CaliforniaIL117.0802 27.1 92507-2364 Fax: +44age Oper. 97470-9422 e-mail: sales@rhopointcomponents.com Tolerance: with Caddock's Roseburg,(0) (0) withVolt. Oregon Caddock's Riverside, Max. Max. Min. Models 1883 717988 Non-Inductive Resistance Pattern are in non-shaded areas. per (541) hours Fax: +44 (0) 496-0700in extended load life testing of standard High e-mail: sales@rhopointcomponents.com Non-Inductive�.002 E Resistance Range a serpentine Conformal. e-mail: caddock@caddock.com • web: www.caddock.comncapsulation:uses Temperature Silicone resistive Phone: 1,0001883 712938 Phone: (951)IL117.0802 .313 �.020 .094 �.015 .025 Design which Tolerance 788-1700 27.1 IL-110.019 600 200 � 5 Meg N/A 750 N/A MG650 0.5 Type 1 •• •• •• •• • •• ••• Ordering Information • •• •• • • • • Oxted, Models with Caddock's LTD standard medical electronics. 6.000 �.120 Resistance any performance resistors shown in the table are Temperature Coefficient, for RHOPOINT COMPONENTS Non-Inductive Resistance Pattern are in non-shaded areas..350 �.040 of ranges Encapsulation: High Temperature Silicone Conformal. systems, geophysical instruments, and resistance range,COMPONENTS LTD"-15" advantages. derating .040 �.002 for RHOPOINT of Surrey, RH8 9AX resistance range (2.39 � that provides for neighboring lines to carry current in (7.95 �.51)see caddock.com/contact/dist.html For Caddock Distributors listed by countrypattern.38) (.64 �.05) Fax: (541) 496-0408 values. Fax: (951)IL117.0802 369-1151 27.1 Applications Engineering Standard �1%, �0.5%, cancellation .109 �.025 This0.5 exceptional Type performance200 � been proven through .313 �.030 (2.77 �.64) directions, thereby achievingSales and Corporate 0.1% has N/A opposite .025 �.002 maximum�0.25%, � Office 600 750 8 Meg N/A MG655North Umpqua Hwy. 1 17271 1717 • R 28_IL110.1004 Chicago • UK (7.95 �.76) (.64 �.05) © 2004 Caddock Electronics, Inc. HurstgGreen • the resistor. Avenue Surrey �1%H8 9AX This many years of use in equipment that demands the highest .500 �.030 .094 �.015 .025 �.002 the with "-15" length of California 92507-2364 of flux fields over St'd entire ratin Roseburg, Oregon 97470-9422 Riverside, 1,000 750 400 � 1 N/A N/A MG660 0.6 Email • reliability 496-0700 Type 1 (12.70 �.76) web: www.caddock.com construction is accomplished 788-1700 e-mail: 0 Meg caddock@caddock.com efficient non-inductive Extended Range sales@rhopointcomponents.com • (2.39 �.38) (.64 �.05) Phone: (541) and stability, including TWT amplifiers, X-ray Phone: 1% � (951) without For Caddock Distributors N/A listed see (0) of any performance Web • www.rhopointcomponents.com .750Tel: +44caddock.com/contact/dist.html advantages. �.030 .094 �.015 .025 .002 Fax: (541) 496-0408 Fax: (951) 369-1151 systems, 8geophysical instruments, and medical20electronics. by countryderating870 608�1188 600 � 2,000 750 Meg N/A MG680 0. Type 1 UK & Ireland Distributors © 2004 Caddock Electronics, Inc. 1.0 4,000 Type 1 MG710 Max. Overload Model Watt- Type MG Precision High Voltage Resistors Page 2 of 2 Type MG Precision High Voltage Resistors Page 2 of 2 Page 1 of 2 N 1 1 * 2 2 2 2 1 1 ** * ** * Specifications: * * * Type MG Precision High Voltage Resistors Type MG Precision High Voltage Resistors CADDOCK CADDOCK 800 � 50 Meg N/A Resistance N/A 750 Dielect. (19.05 �.76) (2.39 �.38) (.64 �.05) .094 �.015 .025 �.002 1.000 �.040 Dimensions in inches �.38)(millimeters) (25.40 �1.02) (2.39 and (.64 �.05) Resistance Specifications: Range Temperature Coefficient: 28_IL110.1004 TC Specifications
很抱歉,暂时无法提供与“T912”相匹配的价格&库存,您可以联系我们找货
