BA033CC0FP-E2
BA033CC0FP-E2
    ROHM(罗姆)
    TO-252(DPAK)
    PMIC - 稳压器 - 线性 正 固定 1 输出 1A TO-252 Vo=3.3V
BA033CC0FP-E2 数据手册
Datasheet 2A/1A Fixed Output LDO Regulators BAxxDD0T Series BAxxCC0T Series BAxxCC0FP Series 2A/1A Fixed Output LDO Regulators With Shutdown Swicth BAxxDD0WT Series BAxxDD0HFP Series BAxxCC0WT Series BAxxCC0WFP Series ●General Description Standard Fixed Output LDO Regulators are low-saturation regulators, available for output s up to 2A / 1A. ROHM has a wide output voltage range and package lineup with and without shutdown switches. This IC has a built-in over-current protection circuit that prevents the destruction of the IC due to output short circuits, a thermal shut-down circuit that protects the IC from damage due to overloading and an over-voltage protection circuit that protects the IC from surges generated in the power supply line of the IC. ●Features „ ±1% highly accurate output voltage (BAxxDD0xx) „ Low saturation with PNP output „ Built-in over-current protection circuit that prevents the destruction of the IC due to output short circuits „ Built-in thermal shutdown circuit for protecting the IC from damage due to overloading „ Built-in over- voltage protection circuit that prevents the destruction of the IC due to power supply surges ●Packages HRP5 TO252-3 TO252-5 TO220FP-3 TO220FP-5 ●Key Specification „ Input Power Supply Voltage: 25V (Max.) „ Output voltage type: Fixed „ Output current: BAxxDD0xx series 2A (Max.) BAxxCC0xx series 1A (Max.) „ Shutdown current: 0μA(Typ.) „ Operating temperature range: -40℃ to +125℃ W (Typ.) x D (Typ.) x H (Max.) 9.395mm x 10.54mm x 2.005mm 6.50 mm x 9.50mm x 2.50 mm 6.50 mm x 9.50mm x 2.50 mm 10.00 mm x 30.50mm x 4.60 mm 10.00 mm x 30.50mm x 4.60 mm TO252-3 HRP5 TO252-5 ●Applications Used in DSP power supplies for DVD and CD players, FPDs, televisions, personal computers or any other consumer device TO220FP-3 ●Lineup matrix ■1A output BAxxCC0xx Series Part Number TO220FP-5 Output voltage (V) Package 3.0 3.3 5.0 6.0 7.0 8.0 9.0 10.0 12.0 15.0 BAxxCC0WT ○ ○ ○ - ○ ○ ○ ○ ○ - TO220FP-5 BAxxCC0WFP - ○ ○ ○ ○ ○ ○ - ○ - TO252-5 BAxxCC0T ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ TO220FP-3 ○ ○ ○ ○ ○ ○ ○ ○ ○ TO252-3 BAxxCC0FP ○ ■2A output BAxxDD0xx Series Part Number Output voltage (V) Package 1.5 1.8 2.5 3.0 3.3 5.0 9.0 12.0 16.0 BAxxDD0WT ○ ○ ○ ○ ○ ○ ○ ○ ○ TO220FP-5 BAxxDD0WHFP ○ ○ ○ ○ ○ ○ ○ ○ ○ HRP5 BAxxDD0T ○ ○ ○ ○ ○ ○ ○ ○ ○ TO220FP-3 ○Product structure : Silicon monolithic integrated circuit ○This product is not designed protection against radioactive rays. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・14・001 1/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Ordering Information B A Part Number x x x Output voltage x Output Current CC0 : 1A 0 x x x Shutdown Switch Package W : Includes switch None: without switch HFP : HRP5 FP : TO252-5 T : TO252-3 : TO220FP-5 : TO220FP-3 DD0 : 2A ●Lineup ■1A output - x xx Packaging and forming specification TR: Embossed tape and reel (HRP5) E2: Embossed tape and reel (TO252-3,TO252-5) None : Container Tube (TO220FP-3,TO220FP-5) BAxxCC0xx Series Maximum output current (Max.) Shutdown Switch Output voltage(Typ.) Package TO252-5 Reel of 2000 With Switch TO220FP-5 Tube of 500 1A TO252-3 Reel of 2000 No switch TO220FP-3 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Tube of 500 2/20 Orderable Part Number 3.3V BA033CC0WFP-E2 5.0V BA05CC0WFP-E2 6.0V BA06CC0WFP-E2 7.0V BA07CC0WFP-E2 8.0V BA08CC0WFP-E2 9.0V BA09CC0WFP-E2 12.0V BAJ2CC0WFP-E2 3.0V BA03CC0WT 3.3V BA033CC0WT 5.0V BA05CC0WT 7.0V BA07CC0WT 8.0V BA08CC0WT 9.0V BA09CC0WT 10.0V BAJ0CC0WT 12.0V BAJ2CC0WT 3.0V BA03CC0FP-E2 3.3V BA033CC0FP-E2 5.0V BA05CC0FP-E2 6.0V BA06CC0FP-E2 7.0V BA07CC0FP-E2 8.0V BA08CC0FP-E2 9.0V BA09CC0FP-E2 10.0V BAJ0CC0FP-E2 12.0V BAJ2CC0FP-E2 15.0V BAJ5CC0FP-E2 3.0V BA03CC0T 3.3V BA033CC0T 5.0V BA05CC0T 6.0V BA06CC0T 7.0V BA07CC0T 8.0V BA08CC0T 9.0V BA09CC0T 10.0V BAJ0CC0T 12.0V BAJ2CC0T 15.0V BAJ5CC0T TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ■2A output BAxxDD0xx Series Maximum output current (Max.) Shutdown Switch Output voltage(Typ.) Package TO220FP-5 Tube of 500 With Switch 2A HRP5 No switch www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 TO220FP-3 Reel of 2000 Tube of 500 3/20 Orderable Part Number 1.5V BA15DD0WT 1.8V BA18DD0WT 2.5V BA25DD0WT 3.0V BA30DD0WT 3.3V BA33DD0WT 5.0V BA50DD0WT 9.0V BA90DD0WT 12.0V BAJ2DD0WT 16.0V BAJ6DD0WT 1.5V BA15DD0WHFP-TR 1.8V BA18DD0WHFP-TR 2.5V BA25DD0WHFP-TR 3.0V BA30DD0WHFP-TR 3.3V BA33DD0WHFP-TR 5.0V BA50DD0WHFP-TR 9.0V BA90DD0WHFP-TR 12.0V BAJ2DD0WHFP-TR 16.0V BAJ6DD0WHFP-TR 1.5V BA15DD0T 1.8V BA18DD0T 2.5V BA25DD0T 3.0V BA30DD0T 3.3V BA33DD0T 5.0V BA50DD0T 9.0V BA90DD0T 12.0V BAJ2DD0T 16.0V BAJ6DD0T TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Block Diagrams / Pin Configurations / Pin Descriptions BAxxCC0WFP/ BAxxDD0WHFP/ BAxxCC0WT/ BAxxDD0WT GND(TO252-5・HRP5) Fin Vcc Driver Vref R2 OVP TSD R1 OCP 1 2 3 4 5 CTL Vcc N.C. OUT N.C. (TO252-5) GND (TO220FP-5,HRP5) Fig.1 PIN No. Pin Name TOP VIEW FIN CTL Output voltage ON/OFF control 2 Vcc Power supply voltage input 3 1 2 3 45 1 2 3 45 TO252-5 HRP5 N.C./GND Unconnected terminal/GND*1 4 1 2 3 45 Function 1 OUT Voltage output 5 N.C. Unconnected terminal Fin GND GND*2 TO220FP-5 1 * 2 * TO252-5=N.C.,TO220FP-5,HRP5=GND TO252-5,HRP5 only BAxxCC0T/ BAxxCC0FP/ BAxxDD0T GND(TO252-3) Fin Vcc Driver Vref R2 OVP 1 TSD 3 2 OUT N.C. Vcc R1 OCP (TO252-3) GND (TO220FP-3) Fig.2 TOP VIEW PIN No. Pin Name 1 FIN 2 1 2 Vcc Function Power supply voltage input N.C./GND Unconnected terminal/GND*1 3 OUT Voltage output Fi GND GND*2 3 1 TO252-3 1 2 3 TO220FP-3 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 * 2 * TO252-3=N.C.,TO220FP-3=GND TO252-3 only 4/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Absolute Maximum Ratings (Ta=25℃) Parameter Input Power Supply Voltage*1 Symbol Ratings Unit VCC -0.3 to +35 V 2300(HRP5) Power Dissipation*2 1300(TO252-5) Pd mW 1200(TO252-3) 2000(TO220FP-3,5) Operating Temperature Range Ambient Storage Temperature Junction Temperature Output Control Terminal Voltage*3 Voltage Applied to the Tip *4 Topr -40 to +125 ℃ Tstg -55 to +150 ℃ TjMAX. +150 ℃ Vctl -0.3 to +Vcc V VCC peak +50 V *1 Must not exceed Pd *2 HRP5 : In cases in which Ta≧25℃ when a 70mm×70mm×1.6mm glass epoxy board is used, the power is reduced by 18.4 mW/℃. TO252FP-3 : In cases in which Ta≧25℃ when a 70mm×70mm×1.6mm glass epoxy board is used, the power is reduced by 9.6 mW/℃. TO252FP-5 : In cases in which Ta≧25℃ when a 70mm×70mm×1.6mm glass epoxy board is used, the power is reduced by 10.4 mW/℃. TO220FP-5 : No heat sink. When Ta≧25℃, the power is reduced by 16 mW/℃. *3 Only for models with shutdown switches. *4 Applied voltage : 200msec or less (tr≥1msec) tr≧1msec 50V 35V MAX200msec (Voltage Supply more than 35V) 0V ●Recommended Operating Ratings (Ta=25℃) Parameter Input Power Supply Voltage Output Current BAxxCC0xx BAxxDD0xx BAxxCC0xx BAxxDD0xx Output Control Terminal Voltage www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Symbol VCC Io Vctl Min. 4.0 Ratings Typ. ― Max. 25.0 3.0 ― 25.0 Unit V V ― ― 1 A ― ― 2 A 0 ― VCC V 5/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Electrical Characteristics BAxxCC0 Series (Unless otherwise specified, Ta=25℃, VCTL=5V, Io=500mA Setting *5) Limit Parameter Symbol Unit Conditions Min. Typ. Max. Vo(T)× Vo(T)× Output Voltage *6 Vo Vo(T) V 0.98 1.02 Shut Down Current Isd - 0 10 μA VCTL=0V - Bias Current Ib 2.5 5.0 mA VCTL=2V, Io=0mA Dropout Voltage ΔVd - 0.3 0.5 V Vcc=Vo×0.95 - - Peak Output Current Io 1.0 A *7 f=120Hz, ein =1Vrms, Ripple Rejection R.R. 45 55 - dB Io=100mA - Line Regulation Reg.I 20 100 mV Vcc=Vo(T)+1→25V Load Regulation Reg.L - 50 150 mV Io=5mA→1A Temperature Coefficient of - ±0.02 - %/℃ Io=5mA,Tj=0 to 125℃ Tcvo Output Voltage *8 Output Short Current Ios - 0.40 - A Vcc=25V - - ON Mode Voltage VthH 2.0 V ACTIVE MODE, Io=0mA OFF Mode Voltage VthL - - 0.8 V OFF MODE, Io=0mA Input High Current ICTL 100 200 300 μA VCTL=5V, Io=0mA BAxxDD0 series (Unless otherwise specified, Ta=25℃, VCTL=3V, Vcc=VCCT*9) Parameter Shut Down Current Bias Current Output Voltage *10 Dropout Voltage 1 Dropout Voltage 2 *11 Ripple Rejection Line Regulation Load Regulation Temperature Coefficient of *8 Output Voltage CTL ON Mode Voltage CTL OFF Mode Voltage Limit Unit Conditions Min. Typ. Max. 0 0.9 0.3 0.45 - 55 15 50 10 2.0 Votyp× 1.01 0.5 0.7 - - 50 200 μA mA ΔVd1 ΔVd2 Io R.R. Reg.I Reg.L - - Votyp× 0.99 - - 2.0 - - - V V A dB mV mV Vcc=0.95×Vo, Io=1A Vcc=0.95×Vo, Io=2A Tcvo - ±0.02 - %/℃ Io=5mA, Tj=0 to 125℃ Von Voff ICTL 2.0 - - - - 60 Vcc 0.8 120 V V μA Isd Ib Vo *11 Peak Output Current CTL Input Current Symbol Votyp V VCTL=0V, Io=0mA Io=0mA Io=200mA f=120Hz, ein*7=-20dBV, Io=100mA *9 Vcc=VCCT V→25V, Io=200mA Io=0mA→2A ACTIVE MODE, Io=0mA OFF MODE, Io=0mA VCTL=3V, Io=0mA *5 Vo=3.0V:Vcc=8.0V, 3.3V:Vcc=8.3V, Vo=5V:Vcc=10V, Vo=6V:Vcc=11V, Vo=7V:Vcc=12V, Vo=8V:Vcc=13V, Vo=9V:Vcc=14V, Vo=12V:Vcc=17V, Vo=15V:Vcc=20V *6 Vo(T)=3.0, 3.3, 5.0, 6.0, 7.0, 8.0, 9.0,12, 15V *7 ein : Input Voltage Ripple *8 Not 100% tested *9 Vo=1.5V,1.8V,2.5V,3.0V:VCCT =4.0V、Vo=3.3V,5.0V:VCCT =7.0V、Vo=9V:VCCT =12.0V、Vo=12V:VCCT =14.0V、Vo=16V:VCCT =18.0V) *10 Votyp=1.5V,1.8V,2.5V,3.0V,3.3V,5.0V,9.0V,12.0V,16.0V * 11 Vo≧3.0V www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 6/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Typical Performance Curves (Unless specified otherwise, Vcc=8.3V, Vo=3.3V, VCTL=5.0V, and Io=0mA) BAxxCC0xx (BA33CC0WT) Fig.4 Input Stability Fig.3 Circuit current Fig.5 Input Stability (Io=500mA) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Fig.6 Load Stability 7/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Typical Performance Curves - continued Fig.7 Input/Output Voltage Difference Io-△Vd Characteristics (Vcc=2.95V) Fig.8 Ripple Rejection Characteristics (Io=100mA) Fig.9 Output Voltage Temperature Characteristics Fig.10 Circuit Current by load Level (IOUT=0mA→1A) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 8/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Typical Performance Curves - continued Fig.11 CTL Voltage vs. CTL Current Fig.12 CTL Voltage vs. Output Voltage Fig.13 Overvoltage Operating Characteristics (Io=200mA) Fig.14 Thermal Shutdown Circuit Characteristics www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 9/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Typical Performance Curves - continued (Unless specified otherwise, Vcc=7.0V, Vo=5.0V, VCTL=3.0V, and Io=0mA) BAxxDD0xx (BA50DD0WT) Fig.15 Circuit Current Fig.16 Input Stability (Io=0mA) Fig.18 Load Stability Fig.17 Input Stability (Io=2A) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 10/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Typical Performance Curves - continued Fig.19 Input/Output Voltage Difference Fig.20 Ripple Rejection Characteristics Fig.21 Temperature Characteristics Fig.22 Circuit Current by Load Level (lout=0mA→2A) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 11/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Typical Performance Curves - continued [V] [BA50DD0WT] Fig.24 CTL Voltage vs. Output Voltage Fig.23 CTL Voltage vs. CTL Current Fig.26 Thermal Shutdown Circuit Characteristics Fig.25 Overvoltage Operating (lo=200mA) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 12/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●I/O equivalence circuit Vcc Vcc 10kΩ Vcc 25kΩ OUT 39kΩ R2 2kΩ CTL OUT 25kΩ CTL 10kΩ R2 31kΩ R1 R1 Fig.28 Fig.27 ●Power Dissipation TO220FP-5 HRP-5 25 10 7 20 (1)20.0 Power Dissipation:Pd(W) 8 Power Dissipation:Pd(W) When using a maximum heat sick : θj-c=6.25(℃/W) When using an IC alone : θj-6=62.5(℃/W) 3 Board size : 70×70×1.6 ㎜ (board contains a thermal via) 2 Board front copper foil area : 10.5×10.5 ㎜ 2 ①2-layer board (back surface copper foil area :15×15 ㎜ ) 2 ②2-layer board (back surface copper foil area :70×70 ㎜ ) 2 ③4-layer board (back surface copper foil area :70×70 ㎜ ) 9 ③7.3W 6 5 ②5.5W 4 15 10 3 5 2 ①2.3W (2)2.0 1 0 0 0 25 50 75 100 Ambient temperature:Ta(℃) 125 0 150 25 50 75 100 Ambient temperature:Ta(℃) 125 150 Fig.30 Fig.29 TO252-5 2.0 Mounted on a Rohm standard board Board size : 70×70×1.6 ㎜ Copper foil area :7×7 ㎜ TO252-5θja=96.2(℃/W) Power Dissipation:Pd(W) 1.6 1.30 1.2 0.8 0.4 0.0 0 25 50 75 100 125 Ambient temperature:Ta(℃) 150 Fig.31 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 13/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx When using at temperatures over Ta=25℃, please refer to the heat reducing characteristics shown in Fig.29 through 31. The IC characteristics are closely related to the temperature at which the IC is used and if the temperature exceeds the maximum junction temperature TjMAX., the elements may be damaged or destroyed. From the standpoints of instantaneous destruction and long-term operating reliability, it is necessary give sufficient consideration to IC heat. In order to protect the IC from thermal damage, it is necessary to operate it at temperatures lower than the maximum junction temperature TjMAX of the IC. Fig.30 shows the acceptable loss and heat reducing characteristics of the TO220FP package The portion shown by the diagonal line is the acceptable loss range that can be used with the IC alone. Even when the ambient temperature Ta is a normal temperature (25℃), the chip (junction) temperature Tj may be quite high so please operate the IC at temperatures less than the acceptable loss Pd. The method of calculating the power consumption Pc (W) is as follows. Vcc:Input voltage Vo:Output voltage Io:Load current Vcca:Circuit current Pc = (Vcc-Vo) × Io + Vcc × Icca Acceptable loss Pd≦Pc Solving this for load current IO in order to operate within the acceptable loss: Io≦ Pd – Vcc×Icca Vcc-Vo (Please refer to Fig.10 and 22 for Icca.) It is then possible to find the maximum load current IoMAX with respect to the applied voltage Vcc at the time of thermal design. ・Calculation Example Example 1) When Ta=85℃, Vcc=8.3V, Vo=3.3V, BA33DD0WT 1.04-8.3×Icca Io≦ 5 Io≦200mA (Icca : 2mA) With the IC alone : θja=62.5℃/W → -16mW/℃ 25℃=2000mW → 85℃=1040mW Please refer to the above information and keep thermal designs within the scope of acceptable loss for all operating temperature ranges. The power consumption Pc of the IC when there is a short circuit (short between Vo and GND) is: Pc=Vcc×(Icca+Ishort) *Ishort: Short circuit current ●Peripheral Circuit Considerations ・Vcc Terminal Please attach a capacitor (greater than 0.33µF) between the Vcc and GND. The capacitance values will differ depending on the application, so please take this into account when configuring the terminal. ・GND Terminal Please be sure to keep the set ground and IC ground at the same potential level so that a potential difference does not arise between them. If a potential difference arises between the set ground and the IC ground, the preset voltage will not be outputted, causing the system to become unstable. Therefore, please reduce the impedance by making the ground patterns as wide as possible and by reducing the distance between the set ground and the IC ground as much as possible. ・CTL Terminal The CTL terminal is turned ON at 2.0V and higher and OFF at 0.8V and lower within the operating power supply voltage range. CC0xx series, the power supply and the CTL terminal in any order without problems. ●Vo Terminal 100 IC 22μF Fig.32 Output Equivalent Circuit EFFECTIVE SERIES RESISTANCE:ESR [Ω] OUT EFFECTIVE SERIES RESISTANCE:ESR [Ω] 100 Unstable operating region 10 Stable operating region 1 Unstable operating region 0.1 0 600 800 400 OUTPUT CURRENT:lo(mA) 200 1000 Fig.33 ESR-Io Characteristics (BAxxCC0) Unstable operating region 10 Stable operating region 1 0.1 Unstable operating region 1 1 100 10 OUTPUT 1000 10000 CURRENT:lo(mA) Fig.34 ESR vs. Io Characteristics (BAxxDD0) Please attach an anti-oscillation capacitor between Vo and GND. The capacitance of the capacitor may significantly change due to factors such as temperature changes, making it impossible to completely stop oscillations. Please use a tantalum capacitor or aluminum electrolysis capacitor with favorable characteristics and small internal series resistance (ESR) even at low temperatures. The output fluctuates regardless of whether the ESR is large or small. Please use the IC within the stable operating region while referring to the ESR characteristics reference data shown in Fig.32 through 34. In applications where there are sudden load fluctuations, the use of a capacitor with large capacitance is recommended. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 14/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Operational Notes 1) Protection Circuits Over-current Protection Circuit A built-in over-current protection circuit corresponding to the current capacity prevents the destruction of the IC when there are load shorts. This protection circuit is a “7”-shaped current control circuit that is designed such that the current is restricted and does not latch even when a large current momentarily flows through the system with a high-capacitance capacitor. However, while this protection circuit is effective for the prevention of destruction due to unexpected accidents, it is not suitable for continuous operation or transient use. Please be aware when creating thermal designs that the overcurrent protection circuit has negative current capacity characteristics with regard to temperature (Refer to Fig.6 and 18). Thermal Shutdown Circuit (Thermal Protection) This system has a built-in temperature protection circuit for the purpose of protecting the IC from thermal damage. As shown above, this must be used within the range of acceptable loss, but if the acceptable loss happens to be continuously exceeded, the chip temperature Tj increases, causing the temperature protection circuit to operate. When the thermal shutdown circuit operates, the operation of the circuit is suspended. The circuit resumes operation immediately after the chip temperature Tj decreases, so the output repeats the ON and OFF states (Please refer to Fig.14 and 26 for the temperatures at which the temperature protection circuit operates). There are cases in which the IC is destroyed due to thermal runaway when it is left in the overloaded state. Be sure to avoid leaving the IC in the overloaded state. Reverse Current In order to prevent the destruction of the IC when a reverse current flows through the IC, it is recommended that a diode be placed between the Vcc and Vo and a pathway be created so that the current can escape (Refer to Fig.35). Reverse current Vcc CTL OUT GND Fig.35 Bypass diode 2) This IC is bipolar IC that has a P-board (substrate) and P+ isolation layer between each devise, as shown in Fig.36. A P-N junction is formed between this P-layer and the N-layer of each device, and the P-N junction operates as a parasitic diode when the electric potential relationship is GND> Pin A, GND> Pin B, while it operates as a parasitic transistor when the electric potential relationship is Pin B GND> Pin A. Parasitic devices are structurally inevitable in the IC. The operation of parasitic devices induces mutual interference between circuits, causing malfunctions and eventually the destruction of the IC. It is necessary to be careful not to use the IC in ways that would cause parasitic elements to operate. For example, applying a voltage that is lower than the GND (P-board) to the input terminal. Transistor (NPN) Resistor (Pin B) (Pin A) C B (Pin B) E B E GND P+ P+ P N P+ N P GND P+ N N P N GND Parasitic element or transistor Parasitic element or transistor N N P Parasitic element C GND (Pin A) Parasitic element GND Fig.36 Example of the basic structure of a bipolar IC Status of this document The Japanese version of this document is formal specification. A customer may use this translation version only for a reference to help reading the formal version. If there are any differences in translation version of this document formal version takes priority. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 15/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Physical Dimension Tape and Reel Information HRP5 8.82 ± 0.1 (6.5) 0.08±0.05 1.2575 1 2 3 4 0.835±0.2 1.523±0.15 8.0±0.13 (7.49) 1.905±0.1 10.54±0.13 1.017±0.2 9.395±0.125 (MAX 9.745 include BURR) Tape Embossed carrier tape Quantity 2000pcs Direction of feed TR direction is the 1pin of product is at the upper right when you hold ( The ) reel on the left hand and you pull out the tape on the right hand 1pin 5 +5.5° 4.5°−4.5° +0.1 0.27 −0.05 S 0.73±0.1 0.08 S 1.72 Direction of feed Reel (Unit : mm) ∗ Order quantity needs to be multiple of the minimum quantity. TO252-3 6.5±0.2 C0.5 1.5±0.2 +0.2 5.1 -0.1 Tape Embossed carrier tape Quantity 2000pcs 2.3±0.2 0.5±0.1 Direction of feed 1.5 2 3 0.8 1 0.65 E2 The direction is the 1pin of product is at the lower left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 2.5 9.5±0.5 5.5±0.2 FIN 0.65 0.5±0.1 0.75 2.3±0.2 1.0±0.2 2.3±0.2 1pin Reel (Unit : mm) Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. TO252-5 2.3±0.2 6.5±0.2 1.5±0.2 Embossed carrier tape Quantity 2000pcs 0.5±0.1 C0.5 +0.2 5.1 -0.1 Tape Direction of feed The direction is the 1pin of product is at the lower left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 1.5 4 5 0.8 1 2 3 2.5 9.5±0.5 5.5±0.2 FIN E2 0.5±0.1 0.5 1.27 1.0±0.2 1pin Reel (Unit : mm) Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. TO220FP-3 +0.3 4.5 −0.1 φ3.2±0.1 +0.2 2.8 −0.1 Container Tube Quantity 500pcs Direction of feed Direction of products is fixed in a container tube 8.0±0.2 12.0±0.2 7.0 +0.3 −0.1 5.0±0.2 13.5Min. +0.4 17.0 −0.2 1.8±0.2 +0.3 10.0 −0.1 1.3 0.8 2.54±0.5 2.54±0.5 1 2 0.55 +0.1 −0.05 2.6±0.5 3 ∗ Order quantity needs to be multiple of the minimum quantity. (Unit : mm) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 16/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx +0.3 4.5 −0.1 +0.2 2.8 −0.1 φ3.2±0.1 Container Tube Quantity 500pcs Direction of feed Direction of products is fixed in a container tube 8.0±0.2 0.7 12.0±0.2 +0.3 10.0−0.1 +0.3 7.0 −0.1 13.5Min. +0.4 17.0 −0.2 1.8±0.2 TO220FP-5 1.2 0.8 1.778 0.5±0.1 2.85 1 2 3 4 5 ∗ Order quantity needs to be multiple of the minimum quantity. (Unit : mm) ●Marking Diagrams HRP5 (TOP VIEW) Part Number Marking LOT Number 1PIN MARK TO252-3 (TOP VIEW) TO252-5 (TOP VIEW) Part Number Marking Part Number Marking LOT Number LOT Number TO220FP-3 (TOP VIEW) TO220FP-5 (TOP VIEW) Part Number Marking Part Number Marking LOT Number LOT Number www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 17/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ■1A output BAxxCC0xx Series Orderable Part Number Package Part Number Marking BA033CC0WFP-E2 033CC0W BA05CC0WFP-E2 05CC0W BA06CC0WFP-E2 BA07CC0WFP-E2 06CC0W TO252-5 BA08CC0WFP-E2 07CC0W 08CC0W BA09CC0WFP-E2 09CC0W BAJ2CC0WFP-E2 J2CC0W BA03CC0WT 03CC0W BA033CC0WT 033CC0W BA05CC0WT 05CC0W BA07CC0WT BA08CC0WT TO220FP-5 07CC0W 08CC0W BA09CC0WT 09CC0W BAJ0CC0WT J0CC0W BAJ2CC0WT J2CC0W BA03CC0FP-E2 03CC0 BA033CC0FP-E2 033CC0 BA05CC0FP-E2 05CC0 BA06CC0FP-E2 06CC0 BA07CC0FP-E2 BA08CC0FP-E2 TO252-3 07CC0 08CC0 BA09CC0FP-E2 09CC0 BAJ0CC0FP-E2 J0CC0 BAJ2CC0FP-E2 J2CC0 BAJ5CC0FP-E2 J5CC0 BA03CC0T 03CC0 BA033CC0T 033CC0 BA05CC0T 05CC0 BA06CC0T 06CC0 BA07CC0T BA08CC0T TO220FP-3 07CC0 08CC0 BA09CC0T 09CC0 BAJ0CC0T J0CC0 BAJ2CC0T J2CC0 BAJ5CC0T J5CC0 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 18/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ■2A output BAxxDD0xx Series Orderable Part Number Package Part Number Marking BA15DD0WT 15DD0W BA18DD0WT 18DD0W BA25DD0WT 25DD0W BA30DD0WT 30DD0W BA33DD0WT TO220FP-5 33DD0W BA50DD0WT 50DD0W BA90DD0WT 90DD0W BAJ2DD0WT J2DD0W BAJ6DD0WT J6DD0W BA15DD0WHFP-TR 15DD0W BA18DD0WHFP-TR 18DD0W BA25DD0WHFP-TR 25DD0W BA30DD0WHFP-TR 30DD0W BA33DD0WHFP-TR HRP5 33DD0W BA50DD0WHFP-TR 50DD0W BA90DD0WHFP-TR 90DD0W BAJ2DD0WHFP-TR J2DD0W BAJ6DD0WHFP-TR J6DD0W BA15DD0T 15DD0 BA18DD0T 18DD0 BA25DD0T 25DD0 BA30DD0T 30DD0 BA33DD0T TO220FP-3 33DD0 BA50DD0T 50DD0 BA90DD0T 90DD0 BAJ2DD0T J2DD0 BAJ6DD0T J6DD0 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 19/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet BAxxDD0xx BAxxCC0xx ●Revision History Date Revision 26.Jun.2012 25.July.2013 001 002 9.Aug.2013 003 Changes New Release Page-14 Changed CTL terminal description Page-6 Added comment “Vo=3.0C:Vcc=8.0V”, “Vo=15V:Vcc=20V” in *5 Page-6 Added comment “3”,“15V” in *6 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 20/20 TSZ02201-0R6R0A600130-1-2 9.Aug.2013 Rev.003 Datasheet Notice Precaution on using ROHM Products 1. Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you (Note 1) , transport intend to use our Products in devices requiring extremely high reliability (such as medical equipment equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation (Pd) depending on Ambient temperature (Ta). When used in sealed area, confirm the actual ambient temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label QR code printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act, please consult with ROHM representative in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. ROHM shall not be in any way responsible or liable for infringement of any intellectual property rights or other damages arising from use of such information or data.: 2. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the information contained in this document. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet General Precaution 1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents. ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s representative. 3. The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or concerning such information. Notice – WE © 2014 ROHM Co., Ltd. All rights reserved. Rev.001
