BA2901YFV-C
BA2901YFV-C
    ROHM(罗姆)
    BA2901YFV-C - Automotive Comparators:Ground Sense - Rohm
BA2901YFV-C 数据手册
Operational Amplifiers / Comparators Automotive Comparators: Ground Sense BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Description Automotive series BA2903Y family and BA2901Y family, integrate one, two or four independent high gain voltage comparator. Some features are the wide operating voltage that is 2 to 36[V] and low supply current. Therefore, this series is suitable for any application ●Features 1) Operable with a signal power supply 2) Wide operating supply voltage +2.0[V]~+36.0[V] (single supply) ±1.0[V]~±18.0[V] (split supply) 3) Standard comparator pin-assignments 4) Input and output are operable ground sense 5) Internal ESD protection Human body model (HBM) ± 5000 [V](Typ.) 6) Wide temperature range -40[℃]~+125[℃] ●Pin Assignment OUT2 OUT1 1 CH1 No.11049EBT24 Automotive Series Dual Quad BA2903Y family BA2901Y family 1 14 13 12 CH1 CH4 OUT3 OUT4 VEE +IN4 - IN4 +IN3 - IN3 8 VCC OUT1 2 VCC - IN1 3 4 5 6 7 SOP14 CH2 CH3 - IN1 2 7 OUT2 11 10 9 8 +IN1 3 CH2 6 - IN2 +IN1 - IN2 VEE 4 5 + IN2 +IN2 SOP8 MSOP8 SSOP-B14 BA2903YF-C BA2903YFVM-C BA2901YF-C BA2901YFV-C www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 1/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Absolute Maximum Ratings (Ta=25[℃]) ○BA2903Y family , BA2901Y family Parameter Supply Voltage Differential Input Voltage (*1) Input Common-mode Voltage Range Operating Temperature Range Storage Temperature Range Maximum junction Temperature Symbol VCC-VEE Vid Vicm Topr Tstg Tjmax Ratings BA2903Y family , BA2901Y family +36 36 (VEE-0.3)~(VEE+36) -40~+125 -55~+150 +150 Technical Note Unit V V V ℃ ℃ ℃ Note : Absolute maximum rating item indicates the condition which must not be exceeded. Application if voltage in excess of absolute maximum rating or use out of absolute maximum rated temperature environment may cause deterioration of characteristics. (*1) The voltage difference between inverting input and non-inverting input is the differential input voltage. Then input terminal voltage is set to more than VEE. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 2/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Electric Characteristics ○BA2903Y family (Unless otherwise specified VCC=+5[V], VEE=0[V]) Parameter Symbol Temperature range 25℃ Vio Full range 25℃ Iio Full range 25℃ Ib Full range Input Common-mode Voltage Range 25℃ Vicm Full range 25℃ Large Signal Voltage Gain AV Full range 25℃ Supply Current ICC Full range Output Sink Current (*3) 2.5 74 0.6 1 mA 0 88 100 VCC-2.0 dB 0 500 VCC-1.5 V 50 200 250 nA VOUT=1.4[V] 5 15 50 nA VOUT=1.4[V] Limits Unit Min. Typ. 2 Max. 5 mV VOUT=1.4[V] Technical Note Conditions Input Offset Voltage (*2) VCC=5~36[V],VOUT=1.4[V] Input Offset Current (*2) Input Bias Current (*2) - VCC=15[V], VOUT=1.4~11.4[V] RL=15[kΩ], VRL=15[V] VOUT=open VOUT=open, VCC=36[V] VIN+=0[V], VIN-=1[V], VOL=1.5[V] IOL 25℃ 6 16 - mA Output Saturation Voltage (Low level output voltage) 25℃ VOL Full range 25℃ Ileak Full range - 150 0.1 - 400 mV 700 μA 1 VIN+=0[V], VIN-=1[V], IOL=4[mA] VIN+=1[V], VIN-=0[V], VOH=5[V] VIN+=1[V], VIN-=0[V], VOH=36[V] VCC=5[V], RL=2[kΩ], VIN+=1.5[V], VIN-=5[Vp-p] (Duty 50% Rectangular Pulse) Output Leakage Current (High level output voltage) Operable Frequency (*2) (*3) Fopr 25℃ 100 - - kHz Absolute value Under high temperatures, please consider the power dissipation when selecting the output current. When the output terminal is continuously shorted the output current reduces the internal temperature by flushing. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 3/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ○BA2901Y family (Unless otherwise specified VCC=+5[V], VEE=0[V]) Parameter Symbol Temperature range 25℃ Vio Full range 25℃ Iio Full range 25℃ Ib Full range Input Common-mode Voltage Range 25℃ Vicm Full range 25℃ Large Signal Voltage Gain AV Full range 25℃ Supply Current ICC Full range Output Sink Current (*5) 2.5 74 0.8 2 mA 0 88 100 VCC-2.0 dB 0 500 VCC-1.5 V 50 200 250 nA VOUT=1.4[V] 5 15 50 nA VOUT=1.4[V] Limits Unit Min. Typ. 2 Max. 5 mV VOUT=1.4[V] Technical Note Conditions Input Offset Voltage (*4) VCC=5~36[V], VOUT=1.4[V] Input Offset Current (*4) Input Bias Current (*4) - VCC=15[V], VOUT=1.4~11.4[V] RL=15[kΩ], VRL=15[V] VOUT=open VOUT=open, VCC=36[V] VIN+=0[V], VIN-=1[V], VOL=1.5[V] IOL 25℃ 6 16 - mA Output Saturation Voltage (Low level output voltage) 25℃ VOL Full range 25℃ Ileak Full range - 150 0.1 - 400 mV 700 μA 1 VIN+=0[V], VIN-=1[V], IOL=4[mA] VIN+=1[V], VIN-=0[V], VOH=5[V] VIN+=1[V], VIN-=0[V], VOH=36[V] VCC=5[V], RL=2[kΩ], VIN+=1.5[V], VIN-=5[Vp-p] (Duty 50% Rectangular Pulse) Output Leakage Current (High level output voltage) Operable Frequency (*4) (*5) Fopr 25℃ 100 - - kHz Absolute value Under high temperatures, please consider the power dissipation when selecting the output current. When the output terminal is continuously shorted the output current reduces the internal temperature by flushing. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 4/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Reference Data 1000 Technical Note BA2903Y family BA2903Y family 1.6 BA2903Y family 1.6 BA2903Y family POWER DISSIPATION [mW] SUPPLY CURRENT [mA] 800 BA2903YF-C 1.2 1.0 -40℃ SUPPLY CURRENT [mA] 1.4 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 2V 5V 36V 600 BA2903YFVM-C 0.8 0.6 0.4 0.2 0.0 125℃ 25℃ 400 200 0 0 25 50 75 100 125 150 0 10 20 30 40 -50 -25 0 25 50 75 100 125 150 AMBIENT TEMPERATURE [ ℃] SUPPLY VOLTAGE [V] AMBIENT TEMPERATURE [ ℃] Fig.1 Derating Curve Fig.2 Supply Current – Supply Voltage MAXIMUM OUTPUT VOLTAGE [mV] , 200 BA2903Y family Fig.3 Supply Current – Ambient Temperature 2 1.8 BA2903Y family 200 BA2903Y family MAXIMUM OUTPUT VOLTAGE [mV] , OUTPUT VOLTAGE [V] 150 150 2V 1.6 1.4 1.2 1 0.8 0.6 0.4 0.2 -40℃ 25℃ 125℃ 125℃ 100 25℃ 100 5V 50 -40℃ 50 36V 0 0 10 20 30 40 0 -50 -25 0 25 50 75 100 125 150 0 0 2 4 6 8 10 12 14 16 18 20 Fig.4 Maximum Output Voltage – Supply Voltage (IOL=4[mA]) BA2903Y family SUPPLY VOLTAGE [V] Fig.5 Maximum Output Voltage – Ambient Temperature (IOL=4[mA]) 8 BA2903Y family SUPPLY VOLTAGE [V] Fig.6 Output Voltage – Output Sink Current (VCC=5[V]) 8 BA2903Y family OUTPUT SINK CURRENT [mA] 40 INPUT OFFSET VOLTAGE [mV] OUTPUT SINK CURRENT [mA] 6 4 2 0 -2 -4 -6 -8 25℃ 125℃ -40℃ INPUT OFFSET VOLTAGE [mV] 6 4 2V 30 36V 5V 2 0 5V 20 2V -2 -4 -6 -8 -50 -25 36V 10 0 -50 -25 0 25 50 75 100 125 150 0 10 20 30 40 0 25 50 75 100 125 150 AMBIENT TEMPERATURE [ ℃] SUPPLY VOLTAGE [V] Fig.7 Output Sink Current – Ambient Temperature (VOUT=1.5[V]) 160 BA2903Y family Fig.8 Input Offset Voltage – Supply Voltage 160 BA2903Y family AMBIENT TEMPERATURE [ ℃] Fig.9 Input Offset Voltage – Ambient Temperature 50 BA2903Y family INPUT OFFSET CURRENT[nA] INPUT BIAS CURRENT [nA] INPUT BIAS CURRENT [nA] 140 120 100 80 60 40 20 0 0 5 10 15 20 25 30 35 125℃ -40℃ 25℃ 140 120 100 80 60 40 20 0 -50 -25 2V 5V 36V 40 30 20 10 0 -10 -20 -30 -40 -50 0 10 20 30 40 125℃ -40℃ 25℃ 0 25 50 75 100 125 150 Fig.10 Input Bias Current – Supply Voltage SUPPLY VOLTAGE [V] Fig.11 Input Bias Current – Ambient Temperature AMBIENT TEMPERATURE [ ℃] Fig.12 Input Offset Current – Supply Voltage SUPPLY VOLTAGE [V] (*)The data above is ability value of sample, it is not guaranteed. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 5/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C 50 Technical Note LARGE SINGAL VOLTAGE GAIN [dB] , 140 130 120 110 100 90 80 70 60 -50 -25 5V 15V 36V BA2903Y family BA2903Y family 140 BA2903Y family INPUT OFFSET CURRENT [nA] 40 30 20 10 0 -10 -20 -30 -40 -50 -50 -25 0 25 50 75 100 125 150 36V 2V 5V LARGE SINGAL VOLTAGE GAIN [dB] , 130 120 110 100 -40℃ 125℃ 90 80 70 60 0 10 25℃ 20 30 40 0 25 50 75 100 125 150 AMBIENT TEMPERATURE [ ℃] SUPPLY VOLTAGE [V] COMMON MODE REJECTION RATIO [dB] COMMON MODE REJECTION RATIO [dB] , ,, Fig.13 Input Offset Current – Ambient Temperature Fig.14 Large Signal Voltage Gain – Supply Voltage 150 125 36V BA2903Y family AMBIENT TEMPERATURE [ ℃] Fig.15 Large Signal Voltage Gain – Ambient Temperature -40℃ 25℃ 160 140 120 100 80 60 40 0 10 20 BA2903Y family 6 BA2903Y family INPUT OFFSET VOLTAGE [mV] 4 2 0 125℃ 100 75 2V 5V 125℃ -40℃ 25℃ 50 25 0 -50 -25 -2 -4 -6 -1 0 1 2 3 4 5 30 40 0 25 50 75 100 125 150 Fig.16 Common Mode Rejection Ratio – Supply Voltage POWER SUPPLY REJECTION RATIO [dB] RESPONSE TIME (LOW TO HIGH)[us] 200 180 160 140 120 100 80 60 -50 -25 BA2903Y family SUPPLY VOLTAGE [V] AMBIENT TEMPERATURE [ ℃] Fig.17 Common Mode Rejection Ratio – Ambient Temperature RESPONSE TIME (LOW TO HIGH)[us] 5 BA2903Y family Fig.18 Input Offset Voltage – Input Voltage (VCC=5V) INPUT VOLTAGE [V] 5 BA2903Y family 4 4 5mV overdrive 20mV overdrive 3 3 2 -40℃ 25℃ 125℃ 2 100mV overdrive 1 1 0 25 50 75 100 125 150 0 -100 -80 -60 -40 -20 0 0 -50 -25 0 25 50 75 100 125 150 Fig.19 Power Supply Rejection Ratio – Ambient Temperature RESPONSE TIME (HIGH TO LOW)[us] , 10 BA2903Y family AMBIENT TEMPERATURE [ ℃] OVER DRIVE VOLTAGE [V] Fig.20 Response Time (Low to High) – Over Drive Voltage (VCC=5[V],VRL=5[V],RL=5.1[kΩ]) Fig.21 Response Time (Low to High) – Ambient Temperature (VCC=5[V],VRL=5[V],RL=5.1[kΩ]) AMBIENT TEMPERATURE [ ℃] 8 RESPONSE TIME (HIGH TO LOW)[us] 10 BA2903Y family 8 5mV overdrive 6 6 20mV overdrive 100mV overdrive 4 125℃ 4 25℃ -40℃ 2 2 0 0 20 40 60 80 100 0 -50 -25 0 25 50 75 100 125 150 OVER DRIVE VOLTAGE [V] Fig.22 Response Time (High to Low) – Over Drive Voltage (VCC=5[V],VRL=5[V],RL=5.1[kΩ]) Fig.23 Response Time (High to Low) – Ambient Temperature (VCC=5[V],VRL=5[V],RL=5.1[kΩ]) AMBIENT TEMPERATURE [ ℃] (*)The data above is ability value of sample, it is not guaranteed. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 6/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Reference Data 1000 BA2901YFV-C Technical Note BA2901Y family BA2901Y family 2.0 1.8 BA2901Y family 2.0 1.8 BA2901Y family POWER DISSIPATION [mW] SUPPLY CURRENT [mA] SUPPLY CURRENT [mA] 800 BA2901YF-C 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 25℃ -40℃ 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 2V 36V 5V 600 400 200 125℃ 0 0 25 50 75 100 125 150 0.0 0 10 20 30 40 0.0 -50 -25 0 25 50 75 100 125 150 AMBIENT TEMPERATURE [ ℃] Fig.24 Derating Curve MAXIMUM OUTPUT VOLTAGE [mV] , 200 BA2901Y family Fig.25 Supply Current – Supply Voltage 200 BA2901Y family SUPPLY VOLTAGE [V] Fig.26 Supply Current – Ambient Temperature 2 1.8 BA2901Y family AMBIENT TEMPERATURE [ ℃] MAXIMUM OUTPUT VOLTAGE [mV] , OUTPUT VOLTAGE [V] 150 150 2V 1.6 1.4 1.2 1 0.8 0.6 0.4 0.2 25℃ -40℃ 125℃ 125℃ 100 25℃ 100 5V 50 -40℃ 50 36V 0 0 10 20 30 40 0 -50 -25 0 25 50 75 100 125 150 0 0 2 4 6 8 10 12 14 16 18 20 SUPPLY VOLTAGE [V] SUPPLY VOLTAGE [V] OUTPUT SINK CURRENT [mA] Fig.27 Maximum Output Voltage – Supply Voltage (IOL=4[mA]) 40 BA2901Y family Fig.28 Maximum Output Voltage – Supply Voltage (IOL=4[mA]) 8 BA2901Y family Fig.29 Output Voltage – Output Sink Current (VCC=5[V]) 8 BA2901Y family INPUT OFFSET VOLTAGE [mV] OUTPUT SINK CURRENT [mA] 6 4 -40℃ INPUT OFFSET VOLTAGE [mV] 6 4 2V 30 36V 2 0 -2 -4 -6 -8 25℃ 125℃ 2 0 5V 36V 20 2V 5V -2 -4 -6 -8 -50 -25 10 0 -50 -25 0 25 50 75 100 125 150 0 10 20 30 40 0 25 50 75 100 125 150 AMBIENT TEMPERATURE [ ℃] SUPPLY VOLTAGE [V] Fig.30 Output Sink Current – Ambient Temperature (VOUT=1.5[V]) 160 BA2901Y family Fig.31 Input Offset Voltage – Supply Voltage 160 BA2901Y family Fig.32 Input Offset Voltage – Ambient Temperature BA2901Y family AMBIENT TEMPERATURE [ ℃] 50 INPUT OFFSET CURRENT[nA] INPUT BIAS CURRENT [nA] INPUT BIAS CURRENT [nA] 140 120 100 80 60 40 20 0 0 5 10 15 20 25 30 35 125℃ -40℃ 25℃ 140 120 100 80 5V 32V 40 30 20 10 0 -10 -20 -30 -40 -50 0 10 20 30 40 125℃ -40℃ 25℃ 60 40 20 0 -50 -25 3V 0 25 50 75 100 125 150 Fig.33 Input Bias Current – Supply Voltage SUPPLY VOLTAGE [V] Fig.34 Input Bias Current – Ambient Temperature AMBIENT TEMPERATURE [ ℃] SUPPLY VOLTAGE [V] Fig.35 Input Offset Current – Supply Voltage (*)The data above is ability value of sample, it is not guaranteed. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 7/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C Technical Note 50 140 BA2901Y family LARGE SINGAL VOLTAGE GAIN [dB] , BA2901Y family 140 130 120 110 100 90 80 70 60 -50 -25 5V 36V BA2901Y family INPUT OFFSET CURRENT [nA] 40 30 20 10 0 -10 -20 -30 -40 -50 -50 -25 0 25 50 75 100 125 150 32V 2V 5V LARGE SINGAL VOLTAGE GAIN [dB] , 130 125℃ 120 110 100 90 80 70 60 0 10 20 30 40 -40℃ 25℃ 15V 0 25 50 75 100 125 150 AMBIENT TEMPERATURE [ ℃] COMMON MODE REJECTION RATIO [dB] , ,, Fig.36 Input Offset Current – Ambient Temperature Fig.37 Large Signal Voltage Gain – Supply Voltage 150 125 100 75 2V BA2901Y family SUPPLY VOLTAGE [V] AMBIENT TEMPERATURE [ ℃] Fig.38 Large Signal Voltage Gain – Ambient Temperature COMMON MODE REJECTION RATIO [dB] 160 140 120 125℃ BA2901Y family 6 BA2901Y family INPUT OFFSET VOLTAGE [mV] 36V 4 2 0 -2 -4 -6 -1 0 1 -40℃ 25℃ 100 80 60 40 0 10 20 30 40 5V -40℃ 25℃ 50 25 0 -50 -25 125℃ 0 25 50 75 100 125 150 2 3 4 5 SUPPLY VOLTAGE [V] AMBIENT TEMPERATURE [ ℃] Fig.39 Common Mode Rejection Ratio – Supply Voltage POWER SUPPLY REJECTION RATIO [dB] RESPONSE TIME (LOW TO HIGH)[us] 200 180 160 140 120 100 80 60 -50 -25 5V 3V BA2901Y family Fig.40 Power Supply Rejection Ratio – Ambient Temperature RESPONSE TIME (LOW TO HIGH)[us] 5 BA2901Y family INPUT VOLTAGE [V] Fig.41 Input Offset Voltage – Input Voltage (VCC=5[V]) 5 BA2901Y family 4 4 5mV overdrive 3 3 20mV overdrive 100mV overdrive 2 -40℃ 25℃ 125℃ 2 32V 1 1 0 25 50 75 100 125 150 0 -100 -80 -60 -40 -20 0 0 -50 -25 0 25 50 75 100 125 150 AMBIENT TEMPERATURE [ ℃] OVER DRIVE VOLTAGE [V] AMBIENT TEMPERATURE [ ℃] Fig.42 Power Supply Rejection Ratio – Ambient Temperature RESPONSE TIME (HIGH TO LOW)[us] , 10 BA2901Y family Fig.43 Response Time (Low to High)– Over Drive Voltage (VCC=5[V],VRL=5[V],RL=5.1[kΩ]) Fig.44 Response Time (Low to High) – Ambient Temperature (VCC=5[V],VRL=5[V],RL=5.1[kΩ]) 8 RESPONSE TIME (HIGH TO LOW)[us] 10 BA2901Y family 8 6 6 5mV overdrive 20mV overdrive 4 125℃ 25℃ -40℃ 4 100mV overdrive 2 2 0 0 20 40 60 80 100 0 -50 -25 0 25 50 75 100 125 150 OVER DRIVE VOLTAGE [V] Fig.45 Response Time (High to Low) – Over Drive Voltage (VCC=5[V],VRL=5[V],RL=5.1[kΩ]) Fig.46 Response Time (High to Low) – Ambient Temperature (VCC=5[V],VRL=5[V],RL=5.1[kΩ]) AMBIENT TEMPERATURE [ ℃] (*)The data above is ability value of sample, it is not guaranteed. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 8/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Circuit Diagram VCC Technical Note VOUT +IN -IN VEE BA2903Y / BA2901Y Schematic Diagram Fig.47 Schematic Diagram (one channel only ) ●Test Circuit 1 Null Method VCC,VEE,EK,Vicm Unit:[V] BA2903Y family BA2901Y family Vcc Input Offset Voltage Input Offset Current Input Bias Current Large Signal Voltage Gain VF1 VF2 VF3 VF4 VF5 VF6 ON OFF OFF ON ON ON OFF ON OFF ON ON ON ON ON 5~36 5 5 5 15 15 VEE 0 0 0 0 0 0 EK -1.4 -1.4 -1.4 -1.4 -1.4 -11.4 Vicm 0 0 0 0 0 0 1 2 3 4 Parameter VF S1 S2 S3 Calculation - Calculation 1. Input Offset Voltage (Vio) Vio = | VF1 | 1 + Rf / Rs [V] 2. Input Offset Current (Iio) Iio = | VF2-VF1 | Ri ×(1 + Rf / Rs) [A] 3. Input Bias Current (Ib) Ib = | VF4-VF3 | 2×Ri× (1 + Rf / Rs) [A] 4. Large Signal Voltage Gain (AV) Av = 20×Log ΔEK×(1+Rf /Rs) |VF5-VF6| [dB] Fig.48 Test circuit1 (one channel only) www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 9/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Test Circuit 2: Switch Condition SW No. Supply Current Output Sink Current Saturation Voltage Output Leakage Current Response Time VOL=1.5[V] IOL=4[mA] VOH=36[V] RL=5.1[kΩ], VRL=5[V] SW 1 OFF OFF OFF OFF ON SW 2 OFF ON ON ON OFF SW 3 OFF ON ON ON ON SW 4 OFF OFF OFF OFF ON SW 5 OFF OFF ON OFF OFF Technical Note SW 6 OFF OFF ON OFF OFF SW 7 OFF ON OFF ON OFF VCC A - + SW1 SW2 SW3 SW4 SW5 RL SW6 SW7 VEE V VRL A VOL/VOH VIN- VIN+ Fig.49 Test Circuit 2 (one channel only) VIN +100mV Input wave Input wave 入力電圧波形 VIN 0V 入力電圧波形 overdrive voltage overdrive voltage 0V -100mV VOUT VCC 出力電圧波形 Output wave VOUT VCC Output wave 出力電圧波形 VCC/2 0V Tre (LOW to HIGH) 0V VCC/2 Tre (HIGH to LOW) Fig.50 Response Time www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 10/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Example of circuit ○Reference voltage is VinVCC Voltage Technical Note 電圧 Vin Reference voltage + - Vout Reference 基準電圧 voltage VEE Voltage Time 時間 Input voltage wave 入力電圧波形 電圧 High While input voltage is bigger than reference voltage, output voltage is high. While input voltage is smaller than reference voltage, output voltage is low. Low Time Output voltage wave 出力電圧波形 ○Reference voltage is Vin+ Voltage 電圧 VCC Reference voltage Reference 基準電圧voltage + Vin - Vout Time 時間 VEE Voltage Input voltage wave 入力電圧波形 High While input voltage is smaller than reference voltage, output voltage is high. While input voltage is bigger than reference voltage, output voltage is low. Low Time Output voltage wave www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 11/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C Technical Note ●Derating curves Power dissipation(total loss) indicates the power that can be consumed by IC at Ta=25℃(normal temperature).IC is heated when it consumed power, and the temperature of IC chip becomes higher than ambient temperature. The temperature that can be accepted by IC chip depends on circuit configuration, manufacturing process, and consumable power is limited. Power dissipation is determined by the temperature allowed in IC chip (maximum junction temperature) and thermal resistance of package (heat dissipation capability). The maximum junction temperature is typically equal to the maximum value in the storage temperature range. Heat generated by consumed power of IC radiates from the mold resin or lead frame of the package. The parameter which indicates this heat dissipation capability(hardness of heat release)is called thermal resistance, represented by the symbol θja[℃/W].The temperature of IC inside the package can be estimated by this thermal resistance. Fig.51(a) shows the model of thermal resistance of the package. Thermal resistance θja, ambient temperature Ta, junction temperature Tj, and power dissipation Pd can be calculated by the equation below θja = (Tj-Ta) / Pd [℃/W] ・・・・・ (Ⅰ) Derating curve in Fig.51(b) indicates power that can be consumed by IC with reference to ambient temperature. Power that can be consumed by IC begins to attenuate at certain ambient temperature. This gradient is determined by thermal resistance θja. Thermal resistance θja depends on chip size, power consumption, package, ambient temperature, package condition, wind velocity, etc even when the same of package is used. Thermal reduction curve indicates a reference value measured at a specified condition. Fig.52(c),(d) show a derating curve for an example of BA2903Y, BA2901Y. Power dissipation of LSI [ W] LSI の 消 費 電 力 θja = ( Tj ー Ta ) / Pd [℃/W] 周囲温度 Ambient temperature Ta [℃] Pd (max) P2 θja2 < θja1 P1 θ' ja2 θ ja2 Tj ' (max) Tj (max) θ' ja1 Chip surface temperature Tj [℃] チップ 表面温度 Power dissipation P [W] 消費電力 θ ja1 125 150 0 25 50 75 100 周囲温度 Ambient temperature Ta [ ℃ ] (a) Thermal resistance (b) Derating curve Fig.51 Thermal resistance and derating curve 1000 1000 870mW(*8) POWER DISSIPATION [mW] POWER DISSIPATION [mW] 800 780mW(*6) BA2903YF-C 590mW(*7) 800 610mW(*9) BA2901YFV-C 600 BA2903YFVM-C 600 BA2901YF-C 400 400 200 200 0 0 25 50 75 100 125 150 0 0 25 50 75 100 125 150 AMBIENT TEMPERATURE [ ℃] AMBIENT TEMPERATURE [ ℃] (c) BA2903Y family (*6) 6.2 (*7) 4.8 (*8) 7.0 (*9) 4.9 Unit [mW/℃] (d) BA2901Y family When using the unit above Ta=25[℃], subtract the value above per degree[℃]. Permissible dissipation is the value when FR4 glass epoxy board 70[mm]×70[mm]×1.6[mm](cooper foil area below 3[%]) is mounted. Fig. 52 Derating curve www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 12/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C Technical Note ●Description of electrical characteristics Described below are descriptions of the relevant electrical terms. Please note that item names, symbols, and their meanings may differ from those on another manufacturer’s documents. 1.Absolute maximum ratings The absolute maximum ratings are values that should never be exceeded, since doing so may result in deterioration of electrical characteristics or damage to the part itself as well as peripheral components. 1.1 Power supply voltage (VCC/VEE) Expresses the maximum voltage that can be supplied between the positive and negative power supply terminals without causing deterioration of the electrical characteristics or destruction of the internal circuitry. 1.2 Differential input voltage (Vid) Indicates the maximum voltage that can be supplied between the non-inverting and inverting terminals without damaging the IC. 1.3 Input common-mode voltage range (Vicm) Signifies the maximum voltage that can be supplied to non-inverting and inverting terminals without causing deterioration of the electrical characteristics or damage to the IC itself. Normal operation is not guaranteed within the input common-mode voltage range of the maximum ratings – use within the input common-mode voltage range of the electric characteristics instead. 1.4 Operating and storage temperature ranges (Topr, Tstg) The operating temperature range indicates the temperature range within which the IC can operate. The higher the ambient temperature, the lower the power consumption of the IC. The storage temperature range denotes the range of temperatures the IC can be stored under without causing excessive deterioration of the electrical characteristics. 1.5 Power dissipation (Pd) Indicates the power that can be consumed by a particular mounted board at ambient temperature (25℃). For packaged products, Pd is determined by maximum junction temperature and the thermal resistance. 2.Electrical characteristics 2.1 Input offset voltage (Vio) Signifies the voltage difference between the non-inverting and inverting terminals. It can be thought of as the input voltage difference required for setting the output voltage to 0V. 2.2 Input offset current (Iio) Indicates the difference of the input bias current between the non-inverting and inverting terminals. 2.3 Input bias current (Ib) Denotes the current that flows into or out of the input terminal, it is defined by the average of the input bias current at the non-inverting terminal and the input bias current at the inverting terminal. 2.4 Input common-mode voltage range (Vicm) Indicates the input voltage range under which the IC operates normally. 2.5 Large signal voltage gain (AV) The amplifying rate (gain) of the output voltage against the voltage difference between the non-inverting and inverting terminals, it is (normally) the amplifying rate (gain) with respect to DC voltage. AV = (output voltage fluctuation) / (input offset fluctuation) 2.6 Circuit current (ICC) Indicates the current of the IC itself that flows under specific conditions and during no-load steady state. 2.7 Output sink current (IOL) Denotes the maximum current that can be output under specific output conditions. 2.8 Output saturation voltage low level output voltage (VOL) Signifies the voltage range that can be output under specific output conditions. 2.9 Output leakage current, High level output current (Ileak) Indicates the current that flows into the IC under specific input and output conditions. 2.10 Response time (Tre) The interval between the application of input and output conditions. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 13/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Notes for use 1) Unused circuits When there are unused circuits it is recommended that they be connected as in Fig.53, setting the non-inverting input terminal to a potential within the in-phase input voltage range (VICR). 2) Input terminal voltage Applying VEE + 36V to the input terminal is possible without causing deterioration of the electrical characteristics or destruction, irrespective of the supply voltage. However, this does not ensure normal circuit operation. Please note that the circuit operates normally only when the input voltage is within the common mode input voltage range of the electric characteristics. Please keep this potential in Vicm Technical Note VCC + - VEE OPEN (Vicm>VEE) Fig. 53 Disable circuit example 3) Power supply (signal / dual) The op-amp operates when the specified voltage supplied is between VCC and VEE. Therefore, the signal supply op-amp can be used as a dual supply op-amp as well. 4) Power dissipation Pd Using the unit in excess of the rated power dissipation may cause deterioration in electrical characteristics due to a rise in chip temperature, including reduced current capability. Therefore, please take into consideration the power dissipation (Pd) under actual operating conditions and apply a sufficient margin in thermal design. Refer to the thermal derating curves for more information. 5) Short-circuit between pins and erroneous mounting Incorrect mounting may damage the IC. In addition, the presence of foreign particles between the outputs, the output and the power supply, or the output and GND may result in IC destruction. 6) Terminal short-circuits When the output and VCC terminals are shorted, excessive output current may flow, resulting in undue heat generation and, subsequently, destruction. 7) Operation in a strong electromagnetic field Operation in a strong electromagnetic field may cause malfunctions. 8) Radiation This IC is not designed to withstand radiation. 9) IC handing Applying mechanical stress to the IC by deflecting or bending the board may cause fluctuations in the electrical characteristics due to piezoelectric (piezo) effects. 10) Board inspection Connecting a capacitor to a pin with low impedance may stress the IC. Therefore, discharging the capacitor after every process is recommended. In addition, when attaching and detaching the jig during the inspection phase, ensure that the power is turned off before inspection and removal. Furthermore, please take measures against ESD in the assembly process as well as during transportation and storage www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 14/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C ●Ordering part number Technical Note B Part No. A 2 Part No. 2903Y 2901Y 9 0 1 Y F V - C E 2 Package F : SOP8 SOP14 FV : SSOP-B14 FVM : MSOP8 Automotive Packaging and forming specification series E2: Embossed tape and reel (SOP8/SOP14/ SSOP-B14) TR: Embossed tape and reel (MSOP8) SOP8 5.0±0.2 (MAX 5.35 include BURR) 8 7 6 5 +6° 4° −4° 0.9±0.15 0.3MIN Tape Quantity Direction of feed Embossed carrier tape 2500pcs E2 The direction is the 1pin of product is at the upper left when you hold 6.2±0.3 4.4±0.2 ( reel on the left hand and you pull out the tape on the right hand ) 12 3 4 0.595 1.5±0.1 +0.1 0.17 -0.05 S 0.1 0.11 S 1.27 0.42±0.1 1pin Direction of feed (Unit : mm) Reel ∗ Order quantity needs to be multiple of the minimum quantity. SOP14 8.7 ± 0.2 (MAX 9.05 include BURR) 14 8 Tape Quantity Direction of feed 0.3MIN Embossed carrier tape 2500pcs E2 The direction is the 1pin of product is at the upper left when you hold 4.4 ± 0.2 6.2 ± 0.3 ( reel on the left hand and you pull out the tape on the right hand ) 1 7 0.15 ± 0.1 1.5 ± 0.1 0.11 1.27 0.4 ± 0.1 0.1 1pin (Unit : mm) Direction of feed Reel ∗ Order quantity needs to be multiple of the minimum quantity. SSOP-B14 5.0 ± 0.2 14 8 Tape Quantity 0.3Min. Embossed carrier tape 2500pcs E2 The direction is the 1pin of product is at the upper left when you hold 6.4 ± 0.3 4.4 ± 0.2 Direction of feed ( reel on the left hand and you pull out the tape on the right hand ) 1 7 0.15 ± 0.1 1.15 ± 0.1 0.10 0.65 0.1 0.22 ± 0.1 1pin (Unit : mm) Direction of feed Reel ∗ Order quantity needs to be multiple of the minimum quantity. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 15/16 2011.08 - Rev.B BA2903YF-C,BA2903YFVM-C,BA2901YF-C,BA2901YFV-C Technical Note MSOP8 2.9±0.1 (MAX 3.25 include BURR) 8765 Tape 0.29±0.15 0.6±0.2 Embossed carrier tape 3000pcs TR The direction is the 1pin of product is at the upper right when you hold +6° 4° −4° Quantity Direction of feed 4.0±0.2 2.8±0.1 ( reel on the left hand and you pull out the tape on the right hand 1pin ) 1 234 1PIN MARK 0.475 0.9MAX +0.05 0.145 −0.03 S 0.75±0.05 0.08±0.05 +0.05 0.22 −0.04 0.08 S 0.65 Direction of feed (Unit : mm) Reel ∗ Order quantity needs to be multiple of the minimum quantity. www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 16/16 2011.08 - Rev.B Notice Notes No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuelcontroller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. R1120A
BA2901YFV-C 价格&库存
很抱歉,暂时无法提供与“BA2901YFV-C”相匹配的价格&库存,您可以联系我们找货
