BD10IA5MEFJ-LBH2
BD10IA5MEFJ-LBH2
    ROHM(罗姆)
    SOIC8_150MIL_EP
    PMIC - 稳压器 - 线性 正 固定 1 输出 500mA 8-HTSOP-J
BD10IA5MEFJ-LBH2 数据手册
Datasheet 0.5A Variable Output Industrial LDO Regulator BDxxIA5MEFJ-LB General Description This is the product guarantees long time support in Industrial market. BDxxIA5MEFJ-LB is a LDO regulator with output current 0.5A. The output accuracy is ±1% of output voltage. With external resistance, it is available to set the output voltage at random (from 0.8V to 4.5V).It has package type: HTSOP-J8. Over current protection (for protecting the IC destruction by output short circuit), circuit current ON/OFF switch (for setting the circuit 0μA at shutdown mode), and thermal shutdown circuit (for protecting IC from heat destruction by over load condition) are all built in. It is usable for ceramic capacitor and enables to improve smaller set and long-life. Package Features „ Long Time Support a Product for Industrial Applications. „ High accuracy reference voltage circuit „ Built-in Over Current Protection circuit (OCP) „ Built-in Thermal Shut Down circuit (TSD) „ With shut down switch (Typ.) (Typ.) (Max.) 4.90mm x 6.00mm x 1.00mm HTSOP-J8 Applications Industrial Equipment Key Specifications „ Input power supply voltage range: 2.5V to 5.5V „ Output voltage range(Variable type): 0.8V to 4.5V „ Output voltage(Fixed type): 1.0V/1.2V1.5V/1.8V/2.5V /3.0V/3.3V „ Output current: 0.5A (Max.) „ Shutdown current: 0μA(Typ.) „ Operating temperature range: -40℃ to +105℃ HTSOP-J8 Typical Application Circuit VCC VO CIN VCC R1 COUT FB EN GND FIN VO_S COUT EN R2 GND CIN,COUT : Ceramic Capacitor ○Product structure:Silicon monolithic integrated circuit www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・14・001 VO CIN FIN CIN,COUT : Ceramic Capacitor ○This product has no designed protection against radioactive rays. 1/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Ordering Information B D x x Part Output Number voltage 00:Variable 10:1.0V 12:1.2V 15:1.5V 18:1.8V 25:2.5V 30:3.0V 33:3.3V I A 5 Voltage Output resistance current I:7V A5:0.5A www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 M E High Reliability Grade F J - Package LBH2 Product class LB for Industrial applications EFJ:HTSOP-J8 Packaging and forming specification “M”:Mseries H2:Emboss tape reel 2/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Block Diagram BD00IA5MEFJ-LB GND VCC 8 3 Ceramic ≧ 1.0μF Capacitor OCP FIN SOFT START (VO+0.60) to 5.5V Body di 0.8V to 4.5V Vo 1 Ceramic Capacitor ≧ 1.0μF R1 2 EN 5 FB R2 VCC 2.4V~5.5V TSD Figure 1. Block Diagram BDxxIA5MEFJ-LB (Fixed type) GND 8 3 Ceramic ≧ 1.0μF Capacitor OCP FIN SOFT START Body di Vo 1 Ceramic ≧ 1.0μF Capacitor 2 EN 5 Vo_s TSD Figure 2. Block Diagram (Fixed type) Pin Configuration TOP VIEW VO VCC FB/Vo_s N.C. GND N.C. N.C. EN Pin Description Pin No. 1 2 3 4 5 6 7 8 Reverse Pin name VO FB/Vo_s GND N.C. EN N.C. N.C. VCC FIN Pin Function Output pin Feedback pin (Used to connect Vo) GND pin Non Connection (Used to connect GND or OPEN state.) Enable pin Non Connection (Used to connect GND or OPEN state.) Non Connection (Used to connect GND or OPEN state.) Input pin Substrate(Connect to GND) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 3/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Absolute Maximum Ratings (Ta=25℃) Parameter Power supply voltage EN voltage Power dissipation HTSOP-J8 Operating Temperature Range Storage Temperature Range Junction Temperature Symbol VCC VEN Limits -0.3 to +7.0 *1 7.0 Unit V V Pd*2 2110 *2 mW Topr Tstg Tjmax -40 to +105 -55 to +150 +150 ℃ ℃ ℃ *1 Not to exceed Pd *2 Reduced by 16.9mW/℃ for each increase in Ta of 1℃ over 25℃. (when mounted on a board 70mm×70mm×1.6mm glass-epoxy board, two layer) Recommended Operating Ratings (Ta=25℃) Parameter Input power supply voltage EN voltage Output voltage setting range Output current Symbol VCC VEN VO IO Min. 2.4 0.0 0.8 0.0 Max. 5.5 5.5 4.5 0.5 Unit V V V A Electrical Characteristics (Unless otherwise noted, EN=3V, Vcc=3.3V, R1=16kΩ, R2=7.5kΩ) Parameter Symbol Temp Min. Typ. Max. Unit Conditions Circuit current at shutdown mode ISD 25℃ -40~105℃ - 0 - 5 5 μA EN=0V, OFF mode Bias current ICC 25℃ -40~105℃ - 250 - 500 700 μA Line regulation Reg.I 25℃ -40~105℃ -1.0 -1.0 - 1.0 1.0 % VCC =( Vo+0.6V )→5.5V Load regulation Reg IO 25℃ -40~105℃ -1.5 -1.5 - 1.5 1.5 % IO=0→0.5A Minimum dropout Voltage VCO 25℃ -40~105℃ - 0.1 - 0.15 0.23 V VCC=3.3V, IO=125mA Minimum dropout Voltage VCO 25℃ -40~105℃ - 0.2 - 0.30 0.45 V VCC=3.3V, IO=250mA Minimum dropout Voltage VCO 25℃ -40~105℃ - 0.3 - 0.45 0.68 V VCC=3.3V, IO=375mA Minimum dropout Voltage VCO 25℃ -40~105℃ - 0.4 - 0.60 0.9 V VCC=3.3V, IO=500mA Output reference voltage (Variable type) VFB 25℃ -40~105℃ 0.792 0.776 0.800 - 0.808 0.824 V IO=0mA Output voltage(Fixed type) VO 25℃ -40~105℃ Vo×0.99 Vo×0.97 Vo Vo Vo×1.01 Vo×1.03 V IO=0mA EN Low voltage VEN(Low) 25℃ -40~105℃ 0 0 - 0.8 0.8 V EN High voltage VEN(High) 25℃ -40~105℃ 2.4 2.4 - 5.5 5.5 V EN Bias current IEN 25℃ -40~105℃ 1 - 3 - 9 9 µA www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 4/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Typical Performance Curves (Unless otherwise noted, EN=3V, VCC=3.3V, R1=16kΩ, R2=7.5kΩ) VO 100mV/div VO 100mV/div IO 200mA/div IO 200mA/div 10usec/div 10usec/div Figure 4. Transient Response (0→0.5A) Co=1µF,Ta=25℃ Figure 3. Transient Response (0→0.5A) Co=1µF,Ta=-40℃ VO 100mV/div VO 100mV/div IO 200mA/div IO 200mA/div 10usec/div 10usec/div Figure 5. Transient Response (0→0.5A) Co=1µF,Ta=105℃ www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 6. Transient Response (0.5→0A) Co=1µF,Ta=-40℃ 5/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB VO 100mV/div VO 100mV/div IO 200mA/div IO 200mA/div 10usec/div 10usec/div Figure 8. Transient Response (0.5→0A) Co=1µF,Ta=105℃ Figure 7. Transient Response (0.5→0A) Co=1µF,Ta=25℃ VEN 2V/div VEN 2V/div VCC 2V/div VCC 2V/div VO 2V/div VO 2V/div 1msec/div 1msec/div Figure 10. Input sequence 1 Co=1µF,Ta=25℃ Figure 9. Input sequence 1 Co=1µF,Ta=-40℃ www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 6/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB VEN 2V/div VEN 2V/div VCC 2V/div VCC 2V/div VO 2V/div VO 2V/div 20msec/div 1msec/div Figure 12. OFF sequence 1 Co=1µF,Ta=-40℃ Figure 11. Input sequence 1 Co=1µF,Ta=105℃ VEN 2V/div VEN 2V/div VCC 2V/div VCC 2V/div VO 2V/div VO 2V/div 20msec/div 20msec/div Figure 13. OFF sequence 1 Co=1µF,Ta=25℃ www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 14. OFF sequence 1 Co=1µF,Ta=105℃ 7/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB VEN 2V/div VEN 2V/div VCC 2V/div VCC 2V/div VO 2V/div VO 2V/div 400µsec/div 400µsec/div Figure 16. Input sequence 2 Co=1µF,Ta=25℃ Figure 15. Input sequence 2 Co=1µF,Ta=-40℃ VEN 2V/div VEN 2V/div VCC 2V/div VCC 2V/div VO 2V/div VO 2V/div 40msec/div 400µsec/div Figure 17. Input sequence 2 Co=1µF,Ta=105℃ www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 18. OFF sequence 2 Co=1µF,Ta=-40℃ 8/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB VEN 2V/div VEN 2V/div VCC 2V/div VCC 2V/div VO 2V/div VO 2V/div 40msec/div 40msec/div Figure 20. OFF sequence 2 Co=1µF, Ta=105℃ 2.7 450 2.6 350 Icc [uA] Vo [V] Figure 19. OFF sequence 2 Co=1µF, Ta=25℃ 2.5 150 2.4 2.3 -40 250 -15 10 35 60 85 50 -40 105 -15 10 35 Ta [°C] Ta [°C] Figure 21. Ta-Vo (IO=0mA) Figure 22. Ta-Icc www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 9/21 60 85 105 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB 5.0 8.0 VCC=3.3V EN=3V EN=0V 4.0 3.0 IEN [uA] ISD [uA] 6.0 2.0 4.0 2.0 1.0 0.0 0.0 -40 -15 10 35 60 85 -40 105 -15 10 35 60 Ta [°C] Ta [°C] Figure 23. Ta-ISD (VEN=0V) Figure 24. Ta-IEN 85 105 5.0 2.7 4.0 ISD [µA] VoVO[V] [V] 2.6 2.5 3.0 2.0 2.4 Temp=-40°C Temp=25°C Temp=105°C 1.0 0.0 2.3 0 0.1 0.2 0.3 0.4 0.5 0 1 2 3 IIo O [A] [A] VCC [V] Figure 25. IO-VO Figure 26. VCC-ISD (VEN=0V) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 10/21 4 5 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB 4.0 EN=3V VO[V] VO [V] 3.0 2.0 Temp=-40°C Temp=25°C Temp=105°C 1.0 0.0 0 1 2 3 4 5 VCC [V] Ta[℃] Figure 28. TSD Figure 27. VCC-VO (IO=0mA) 400.0 3.0 Temp=-40°C Temp=25°C Temp=105°C Temp=-40°C Temp=25°C Temp=105°C Icc [uA] VO [V] 300.0 2.0 200.0 1.0 100.0 VCC=3.3V EN=3V 0.0 0.0 0 0.2 0.4 0.6 0.8 1 VCC=3.3V EN=3V 0 0.1 0.2 0.3 0.4 0.5 IO [A] Io [A] Figure 29. OCP www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 30. IO-ICC 11/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Figure 32. PSRR (IO=0mA) Figure 31. ESR safety area 0.6 0.6 0.5 VCC=2.4V Vcc=2.4V EN=3V EN=3V 0.4 Vdrop [V] Vdrop [V] 0.5 0.3 0.2 0.4 Temp=-40°C Temp=-40°C Temp=25°C Temp=25°C Temp=105°C 0.1 0.3 -40 Temp=105°C 0.0 -15 10 35 60 85 0 105 Ta [°C] 0.2 0.3 0.4 0.5 Io[A] Figure 33. Ta-Vdrop Vcc=3.3V, Io=0.5A www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 0.1 Figure 34. Minimum dropout Voltage 1 (VCC=2.4V) 12/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB 0.6 0.6 Vcc=3.3V VCC=3.3V EN=3V 0.5 EN=3V 0.5 0.4 Vdrop [V] 0.4 Vdrop [V] Vcc=4.0V V CC=4.0V EN=3V EN=3V 0.3 0.3 0.2 0.2 Temp=-40°C Temp=-40°C Temp=25°C Temp=25°C Temp=105°C 0.1 Temp=105°C 0.0 0 0.1 0.2 0.3 0.4 Temp=-40°C Temp=-40°C Temp=25°C Temp=25°C Temp=105°C 0.1 Temp=105°C 0.0 0 0.5 0.1 0.2 0.3 0.4 Io[A] Io [A] Figure 35. Minimum dropout Voltage 2 (VCC=3.3V) Figure 36. Minimum dropout Voltage 3 (VCC=4.0V) 0.5 0.6 Vcc=5.5V VCC=5.5V EN=3V 0.5 EN=3V Vdrop [V] 0.4 0.3 0.2 Temp=-40°C Temp=-40°C Temp=25°C Temp=25°C Temp=105°C 0.1 Temp=105°C 0.0 0 0.1 0.2 0.3 0.4 0.5 Io [A] Figure 37. Minimum dropout Voltage 4 (VCC=5.5V) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 13/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Power Dissipation ◎HTSOP-J8 4.0 Power Dissipation :Pd [W] ⑤3.76W Measure condition: mounted on a ROHM board, and IC Substrate size: 70mm × 70mm × 1.6mm (Substrate with thermal via) ・ Solder the substrate and package reverse exposure heat radiation part 3.0 ④2.11W ① IC only θj-a=249.5℃/W ② 1-layer(copper foil are :0mm×0mm) θj-a=153.2℃/W ③ 2-layer(copper foil are :15mm×15mm) θj-a=113.6℃/W ④ 2-layer(copper foil are :70mm×70mm) θj-a=59.2℃/W ⑤ 4-layer(copper foil are :70mm×70mm) θj-a=33.3℃/W 2.0 ③1.10W 1.0 ②0.82W ①0.50W 0 0 25 50 75 100 125 150 Ambient 周囲温度:Ta Temperature [℃] :Ta [℃] Thermal design should allow operation within the following conditions. Note that the temperatures listed are the allowed temperature limits, and thermal design should allow sufficient margin from the limits. 1. Ambient temperature Ta can be no higher than 105℃. 2. Chip junction temperature (Tj) can be no higher than 150℃. Chip junction temperature can be determined as follows: Calculation based on ambient temperature (Ta) Tj=Ta+θj-a×W <Reference values> θj-a: HTSOP-J8 153.2℃/W 1-layer substrate (copper foil density 0mm×0mm) 113.6℃/W 2-layer substrate (copper foil density 15mm×15mm) 59.2℃/W 2-layer substrate (copper foil density 70mm×70mm) 4-layer substrate (copper foil density 70mm×70mm) 33.3℃/W Substrate size: 70mm×70mm×1.6mm (substrate with thermal via) Most of the heat loss that occurs in the BDxxIA5MEFJ-LB is generated from the output Pch FET. Power loss is determined by the total VCC-VO voltage and output current. Be sure to confirm the system input and output voltage and the output current conditions in relation to the heat dissipation characteristics of the VCC and VO in the design. Bearing in mind that heat dissipation may vary substantially depending on the substrate employed (due to the power package incorporated in the BDxxIA5MEFJ-LB make certain to factor conditions such as substrate size into the thermal design. Power consumption[W] = Input voltage (VCC) - Output voltage (VO) ×IO(Ave) Example) Where VCC=5.0V, VO=3.3V, IO(Ave) = 0.1A, Power consumption[W] = 5.0V - 3.3V ×0.1A =0.17W www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 14/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Input-to-Output Capacitor It is recommended that a capacitor is placed nearby pin between Input pin and GND, output pin and GND. A capacitor, between input pin and GND, is valid when the power supply impedance is high or drawing is long. Also as for a capacitor, between output pin and GND, the greater the capacity, more sustainable the line regulation and it makes improvement of characteristics by load change. However, please check by mounted on a board for the actual application. Ceramic capacitor usually has difference, thermal characteristics and series bias characteristics, and moreover capacity decreases gradually by using conditions. For more detail, please be sure to inquire the manufacturer, and select the best ceramic capacitor. 10 Rated Voltage:10V B1 characteristics Rated Voltage:10V B characteristics 0 Capacitance Change [%] -10 Rated Voltage:6.3V B characteristics -20 -30 -40 -50 Rated Voltage:10V F characteristics -60 Rated Voltage:4V X6S characteristics -70 -80 -90 -100 0 1 2 3 4 DC Bias Voltage [V] Ceramic capacitor capacity – DC bias characteristics (Characteristics example) Equivalent Series Resistance ESR (ceramic capacitor etc.) 10.00 1.00 Safety Area ESR [Ω] Please attach an anti-oscillation capacitor between VO and GND. Capacitor usually has ESR(Equivalent Series Resistance), and operates stable in ESR-IO range, showed right. Generally, ESR of ceramic, tantalum and electronic capacitor etc. is different for each, so please be sure to check a capacitor which is going to use, and use it inside the stable operating region, showed right. Then, please evaluate for the actual application. 0.10 0.01 0 0.1 0.2 0.3 0.4 0.5 Io [A] ESR – IO characteristics www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 15/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Evaluation Board Circuit C3 C7 1 VCC VO 8 C2 C6 R1 C5 2 FB N.C 7 GND N.C 6 R2 C1 VCC GND 3 U1 SW1 VO 4 N.C. EN 5 EN FIN Evaluation Board Parts List Designation R1 R2 R3 R4 R5 R6 C1 C2 C3 Value 43kΩ 8.2kΩ ‐ ‐ ‐ ‐ 1µF ‐ ‐ Part No. MCR01PZPZF4302 MCR01PZPZF8201 ‐ ‐ ‐ ‐ CM105B105K16A ‐ ‐ Company Designation Value ROHM C4 ‐ ROHM C5 1µF ‐ C6 ‐ C7 ‐ ‐ C8 ‐ ‐ C9 ‐ KYOCERA C10 ‐ U1 ‐ U2 ‐ Board Layout Part No. ‐ CM105X7R105K16AB Company ‐ KYOCERA ‐ ‐ ‐ ‐ BD00IA5MEFJ-LB ‐ ‐ ‐ ‐ ‐ ROHM ‐ EN GND CIN VCC ( VIN ) R1 R2 COUT VO ・Input capacitor CIN of VCC (VIN) should be placed very close to VCC(VIN) pin as possible, and used broad wiring pattern. Output capacitor COUT also should be placed close to IC pin as possible. In case connected to inner layer GND plane, please use several through hole. ・FB pin has comparatively high impedance, and is apt to be effected by noise, so floating capacity should be minimum as possible. Please be careful in wiring drawing ・Please take GND pattern space widely, and design layout to be able to increase radiation efficiency. ・For output voltage setting Output voltage can be set by FB pin voltage(0.800V typ.)and external resistance R1, R2. R1+R2 R2 (The use of resistors with R1+R2=1k to 90kΩ is recommended) VO = VFB× www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 16/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB I/O Equivalent Circuits (Output Voltage Vairable type) 8pin(VCC) / 1pin(VO) 8pin(VCC) 2pin(FB) 5pin(EN) 2pin(FB) 5pin (EN ) 520kΩ 1pn(VO) 480kΩ I/O Equivalent Circuits (Output Voltage Fixed type) 8pin(VCC) / 1pin(VO) 2pin(VO_S) 5pin(EN) 8pin(VCC) 2pin(VO_S) 5pin(EN) 520kΩ 480kΩ 1pin(VO) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 17/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Operational Notes (1). Absolute maximum ratings An excess in the absolute maximum ratings, such as supply voltage, temperature range of operating conditions, etc., can break down the devices, thus making impossible to identify breaking mode, such as a short circuit or an open circuit. If any over rated values will expect to exceed the absolute maximum ratings, consider adding circuit protection devices, such as fuses. (2). Connecting the power supply connector backward Connecting of the power supply in reverse polarity can damage IC. Take precautions when connecting the power supply lines. An external direction diode can be added. (3). Power supply lines Design PCB layout pattern to provide low impedance GND and supply lines. To obtain a low noise ground and supply line, separate the ground section and supply lines of the digital and analog blocks. Furthermore, for all power supply terminals to ICs, connect a capacitor between the power supply and the GND terminal. When applying electrolytic capacitors in the circuit, not that capacitance characteristic values are reduced at low temperatures. (4). GND voltage The potential of GND pin must be minimum potential in all operating conditions. (5). Thermal design Use a thermal design that allows for a sufficient margin in light of the power dissipation (Pd) in actual operating conditions. (6). Inter-pin shorts and mounting errors Use caution when positioning the IC for mounting on printed circuit boards. The IC may be damaged if there is any connection error or if pins are shorted together. (7). Actions in strong electromagnetic field Use caution when using the IC in the presence of a strong electromagnetic field as doing so may cause the IC to malfunction. (8). ASO When using the IC, set the output transistor so that it does not exceed absolute maximum ratings or ASO. (9). Thermal shutdown circuit The IC incorporates a built-in thermal shutdown circuit (TSD circuit). The thermal shutdown circuit (TSD circuit) is designed only to shut the IC off to prevent thermal runaway. It is not designed to protect the IC or guarantee its operation. Do not continue to use the IC after operating this circuit or use the IC in an environment where the operation of this circuit is assumed. BDxxIA5MEFJ-LB TSD ON Temperature[℃] (typ.) 175 Hysteresis Temperature [℃] 15 (typ.) (10). Testing on application boards When testing the IC on an application board, connecting a capacitor to a pin with low impedance subjects the IC to stress. Always discharge capacitors after each process or step. Always turn the IC’s power supply off before connecting it to or removing it from a jig or fixture during the inspection process. Ground the IC during assembly steps as an antistatic measure. Use similar precaution when transporting or storing the IC. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 18/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB (11). Regarding input pin of the IC This monolithic IC contains P+ isolation and P substrate layers between adjacent elements in order to keep them isolated. P-N junctions are formed at the intersection of these P layers with the N layers of other elements, creating a parasitic diode or transistor. For example, the relation between each potential is as follows: When GND > Pin A and GND > Pin B, the P-N junction operates as a parasitic diode. When GND > Pin B, the P-N junction operates as a parasitic transistor. Parasitic diodes can occur inevitable in the structure of the IC. The operation of parasitic diodes can result in mutual interference among circuits, operational faults, or physical damage. Accordingly, methods by which parasitic diodes operate, such as applying a voltage that is lower than the GND(P substrate) voltage to an input pin, should not be used. Transistor (NPN) Resistor Pin A Pin B C B Pin B E Pin A N N P+ N P+ P N Parasitic element P+ P substrate Parasitic element GND B N P+ P N C E P substrate Parasitic element GND GND GND Parasitic element Other adjacent elements (12). Ground Wiring Pattern. When using both small signal and large current GND patterns, it is recommended to isolate the two ground patterns, placing a single ground point at the ground potential of application so that the pattern wiring resistance and voltage variations caused by large currents do not cause variations in the small signal ground voltage. Be careful not to change the GND wiring pattern of any external components, either. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 19/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Physical Dimension Tape and Reel Information Package Name www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 HTSOP-J8 20/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet BDxxIA5MEFJ-LB Revision History Date Revision 10.Dec.2013 001 21.Feb.2014 002 Changes New Release Delete sentence “and log life cycle” in General Description and Futures (page 1). Add “Industrial Equipment” in Applications (page 1). Applied new style (change of the size of the title). www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 21/21 TSZ02201-0R6R0AZ00580-1-2 21.Feb.2014 Rev.002 Datasheet Notice Precaution on using ROHM Products 1. If you intend to use our Products in devices requiring extremely high reliability (such as medical equipment (Note 1), aircraft/spacecraft, nuclear power controllers, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are not designed under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation (Pd) depending on Ambient temperature (Ta). When used in sealed area, confirm the actual ambient temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice - SS © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label QR code printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act, please consult with ROHM representative in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. ROHM shall not be in any way responsible or liable for infringement of any intellectual property rights or other damages arising from use of such information or data.: 2. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the information contained in this document. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice - SS © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet General Precaution 1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents. ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s representative. 3. The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or concerning such information. Notice – WE © 2014 ROHM Co., Ltd. All rights reserved. Rev.001
BD10IA5MEFJ-LBH2 价格&库存
很抱歉,暂时无法提供与“BD10IA5MEFJ-LBH2”相匹配的价格&库存,您可以联系我们找货
BD10IA5MEFJ-LBH2
  • 1+15.409921+1.98303
  • 10+11.2725610+1.45062
  • 25+10.2512725+1.31919
  • 100+9.12114100+1.17376
库存:239
BD10IA5MEFJ-LBH2
  • 250+8.33333250+1.07238
  • 500+8.01823500+1.03183
  • 750+7.86058750+1.01154
  • 1250+7.685791250+0.98905
  • 1750+7.583611750+0.97590
  • 2500+7.485312500+0.96325
  • 6250+7.273776250+0.93603
库存:239
BD10IA5MEFJ-LBH2
  • 1+14.973291+1.92684
  • 10+10.9466910+1.40868
  • 25+9.9518125+1.28065
  • 100+8.85607100+1.13965
库存:239
BD10IA5MEFJ-LBH2
    • 1+2.894701+0.37251
    • 10+2.8112810+0.36177
    • 50+2.7612350+0.35533
    • 100+2.70283100+0.34782
    • 500+2.69449500+0.34674
    • 1000+2.686151000+0.34567
    • 2000+2.686152000+0.34567
    库存:250
    BD10IA5MEFJ-LBH2
    • 1+5.52010
    • 250+4.60010
    • 500+3.68000
    • 1000+3.06670
