BD52011NVX-E2
BD52011NVX-E2
    ROHM(罗姆)
    BD52011NVX-E2 - Omnipolar Detection Hall ICs - Rohm
BD52011NVX-E2 数据手册
Hall IC Series Omnipolar Detection Hall ICs BU52001GUL, BU52011HFV, BU52021HFV, BU52015GUL, BU52025G, BU52051NVX, BD7411G No.10045ECT02 ●Description The bipolar Hall ICs are magnetic switches that can operate both S-and N-pole , upon which the output goes from Hi to Low. In addition to regular single-output Hall ICs, We offers a line up of dual-output units with a reverse output terminal (active High). ●Features 1) Omnipolar detection 2) Micropower operation (small current using intermittent operation method)(BD7411G is excluded.) 3) Ultra-compact CSP package (BU52001GUL,BU52015GUL) 4) Ultra-Small outline package HVSOF5 (BU52011HFV,BU52021HFV) 5) Ultra-Small outline package SSON004X1216 (BU52051NVXV) 6) Small outline package (BU52025G,BD7411G) 7) Line up of supply voltage For 1.8V Power supply voltage(BU52011HFV,BU52015GUL,BU52051NVX) For 3.0V Power supply voltage (BU52001GUL) For 3.3V Power supply voltage (BU52021HFV,BU52025G) For 5.0V Power supply voltage (BD7411G) 8) Dual output type (BU52015GUL) 9) High ESD resistance 8kV(HBM) ●Applications Mobile phones, notebook computers, digital video camera, digital still camera, white goods etc. ●Product Lineup Product name BU52001GUL BU52015GUL BU52051NVX BU52011HFV BU52021HFV BU52025G BD7411G Supply voltage (V) 2.40~3.30 1.65~3.30 1.65~3.30 1.65~3.30 2.40~3.60 2.40~3.60 4.50~5.50 Operate point (mT) +/-3.7※ +/-3.0※ +/-3.0※ +/-3.0※ +/-3.7※ +/-3.7※ +/-3.4※ Hysteresis (mT) 0.8 0.9 0.9 0.9 0.8 0.8 0.4 Period (ms) 50 50 50 50 50 50 Supply current (AVG) (A) 8.0μ 5.0μ 5.0μ 5.0μ 8.0μ 8.0μ 2.0m Output type CMOS CMOS CMOS CMOS CMOS CMOS CMOS Package VCSP50L1 VCSP50L1 SSON004X1216 HVSOF5 HVSOF5 SSOP5 SSOP5 ※Plus is expressed on the S-pole; minus on the N-pole www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 1/19 2010.01 - Rev.C BU52001GUL,BU52011HFV,BU52021HFV, BU52015GUL,BU52025G,BU52051NVX, BD7411G ●Absolute Maximum Ratings BU52001GUL (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range Technical Note SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5※1 ±1 420 ※2 UNIT V mA mW ℃ ℃ -40~+85 -40~+125 ※1. Not to exceed Pd ※2. Reduced by 4.20mW for each increase in Ta of 1℃ over 25℃ (mounted on 50mm×58mm Glass-epoxy PCB) BU52015GUL (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5※3 ±0.5 420 ※4 UNIT V mA mW ℃ ℃ -40~+85 -40~+125 ※3. Not to exceed Pd ※4. Reduced by 4.20mW for each increase in Ta of 1℃ over 25℃ (mounted on 50mm×58mm Glass-epoxy PCB) BU52051NVX (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5※5 ±0.5 2049※6 -40~+85 -40~+125 UNIT V mA mW ℃ ℃ ※5. Not to exceed Pd ※6. Reduced by 20.49mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) BU52011HFV (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5 ±0.5 536※8 -40~+85 -40~+125 ※7 UNIT V mA mW ℃ ℃ ※7. Not to exceed Pd ※8. Reduced by 5.36mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 2/19 2010.01 - Rev.C BU52001GUL,BU52011HFV,BU52021HFV, BU52015GUL,BU52025G,BU52051NVX, BD7411G BU52021NVX (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range Technical Note SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5 ±1 536※10 -40~+85 -40~+125 ※9 UNIT V mA mW ℃ ℃ ※9. Not to exceed Pd ※10. Reduced by5.36mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) BU52025G (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5 ±1 540※12 -40~+85 -40~+125 ※11 UNIT V mA mW ℃ ℃ ※11. Not to exceed Pd ※12. Reduced by 5.40mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) BD7411G (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.3~+7.0 ±1 540※14 -40~+85 -55~+150 ※13 UNIT V mA mW ℃ ℃ ※13. Not to exceed Pd ※14. Reduced by 5.40mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 3/19 2010.01 - Rev.C BU52001GUL,BU52011HFV,BU52021HFV, BU52015GUL,BU52025G,BU52051NVX, BD7411G ●Magnetic, Electrical Characteristics BU52001GUL (Unless otherwise specified, VDD=3.0V, Ta=25℃) LIMIT PARAMETERS SYMBOL MIN TYP Power Supply Voltage Operate Point Release Point Hysteresis Period Output High Voltage Output Low Voltage Supply Current Supply Current During Startup Time Supply CurrentDuring Standby Time VDD BopS BopN BrpS BrpN BhysS BhysN Tp VOH VOL IDD(AVG) IDD (EN) IDD (DIS) 2.4 -5.5 0.8 VDD -0.4 3.0 3.7 -3.7 2.9 -2.9 0.8 0.8 50 8 4.7 3.8 Technical Note MAX 3.3 5.5 -0.8 100 0.4 12 - UNIT V mT mT mT ms V V μA mA μA CONDITIONS BrpN
BD52011NVX-E2 价格&库存
很抱歉,暂时无法提供与“BD52011NVX-E2”相匹配的价格&库存,您可以联系我们找货
