BD52051NVX-E2
BD52051NVX-E2
    ROHM(罗姆)
    BD52051NVX-E2 - Omnipolar Detection Hall ICs - Rohm
BD52051NVX-E2 数据手册
Hall IC Series Omnipolar Detection Hall ICs BU52001GUL, BU52011HFV, BU52021HFV, BU52015GUL, BU52025G, BU52051NVX, BD7411G No.10045ECT02 ●Description The bipolar Hall ICs are magnetic switches that can operate both S-and N-pole , upon which the output goes from Hi to Low. In addition to regular single-output Hall ICs, We offers a line up of dual-output units with a reverse output terminal (active High). ●Features 1) Omnipolar detection 2) Micropower operation (small current using intermittent operation method)(BD7411G is excluded.) 3) Ultra-compact CSP package (BU52001GUL,BU52015GUL) 4) Ultra-Small outline package HVSOF5 (BU52011HFV,BU52021HFV) 5) Ultra-Small outline package SSON004X1216 (BU52051NVXV) 6) Small outline package (BU52025G,BD7411G) 7) Line up of supply voltage For 1.8V Power supply voltage(BU52011HFV,BU52015GUL,BU52051NVX) For 3.0V Power supply voltage (BU52001GUL) For 3.3V Power supply voltage (BU52021HFV,BU52025G) For 5.0V Power supply voltage (BD7411G) 8) Dual output type (BU52015GUL) 9) High ESD resistance 8kV(HBM) ●Applications Mobile phones, notebook computers, digital video camera, digital still camera, white goods etc. ●Product Lineup Product name BU52001GUL BU52015GUL BU52051NVX BU52011HFV BU52021HFV BU52025G BD7411G Supply voltage (V) 2.40~3.30 1.65~3.30 1.65~3.30 1.65~3.30 2.40~3.60 2.40~3.60 4.50~5.50 Operate point (mT) +/-3.7※ +/-3.0※ +/-3.0※ +/-3.0※ +/-3.7※ +/-3.7※ +/-3.4※ Hysteresis (mT) 0.8 0.9 0.9 0.9 0.8 0.8 0.4 Period (ms) 50 50 50 50 50 50 Supply current (AVG) (A) 8.0μ 5.0μ 5.0μ 5.0μ 8.0μ 8.0μ 2.0m Output type CMOS CMOS CMOS CMOS CMOS CMOS CMOS Package VCSP50L1 VCSP50L1 SSON004X1216 HVSOF5 HVSOF5 SSOP5 SSOP5 ※Plus is expressed on the S-pole; minus on the N-pole www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 1/19 2010.01 - Rev.C BU52001GUL,BU52011HFV,BU52021HFV, BU52015GUL,BU52025G,BU52051NVX, BD7411G ●Absolute Maximum Ratings BU52001GUL (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range Technical Note SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5※1 ±1 420 ※2 UNIT V mA mW ℃ ℃ -40~+85 -40~+125 ※1. Not to exceed Pd ※2. Reduced by 4.20mW for each increase in Ta of 1℃ over 25℃ (mounted on 50mm×58mm Glass-epoxy PCB) BU52015GUL (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5※3 ±0.5 420 ※4 UNIT V mA mW ℃ ℃ -40~+85 -40~+125 ※3. Not to exceed Pd ※4. Reduced by 4.20mW for each increase in Ta of 1℃ over 25℃ (mounted on 50mm×58mm Glass-epoxy PCB) BU52051NVX (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5※5 ±0.5 2049※6 -40~+85 -40~+125 UNIT V mA mW ℃ ℃ ※5. Not to exceed Pd ※6. Reduced by 20.49mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) BU52011HFV (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5 ±0.5 536※8 -40~+85 -40~+125 ※7 UNIT V mA mW ℃ ℃ ※7. Not to exceed Pd ※8. Reduced by 5.36mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 2/19 2010.01 - Rev.C BU52001GUL,BU52011HFV,BU52021HFV, BU52015GUL,BU52025G,BU52051NVX, BD7411G BU52021NVX (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range Technical Note SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5 ±1 536※10 -40~+85 -40~+125 ※9 UNIT V mA mW ℃ ℃ ※9. Not to exceed Pd ※10. Reduced by5.36mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) BU52025G (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.1~+4.5 ±1 540※12 -40~+85 -40~+125 ※11 UNIT V mA mW ℃ ℃ ※11. Not to exceed Pd ※12. Reduced by 5.40mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) BD7411G (Ta=25℃) PARAMETERS Power Supply Voltage Output Current Power Dissipation Operating Temperature Range Storage Temperature Range SYMBOL VDD IOUT Pd Topr Tstg LIMIT -0.3~+7.0 ±1 540※14 -40~+85 -55~+150 ※13 UNIT V mA mW ℃ ℃ ※13. Not to exceed Pd ※14. Reduced by 5.40mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 3/19 2010.01 - Rev.C BU52001GUL,BU52011HFV,BU52021HFV, BU52015GUL,BU52025G,BU52051NVX, BD7411G ●Magnetic, Electrical Characteristics BU52001GUL (Unless otherwise specified, VDD=3.0V, Ta=25℃) LIMIT PARAMETERS SYMBOL MIN TYP Power Supply Voltage Operate Point Release Point Hysteresis Period Output High Voltage Output Low Voltage Supply Current Supply Current During Startup Time Supply CurrentDuring Standby Time VDD BopS BopN BrpS BrpN BhysS BhysN Tp VOH VOL IDD(AVG) IDD (EN) IDD (DIS) 2.4 -5.5 0.8 VDD -0.4 3.0 3.7 -3.7 2.9 -2.9 0.8 0.8 50 8 4.7 3.8 Technical Note MAX 3.3 5.5 -0.8 100 0.4 12 - UNIT V mT mT mT ms V V μA mA μA CONDITIONS BrpN
BD52051NVX-E2
物料型号: - BU52001GUL - BU52011HFV - BU52021HFV - BU52015GUL - BU52025G - BU52051NVX - BD7411G
器件简介: 该系列为全极性检测霍尔IC,能够感应S极和N极的磁场。除了常规的单输出霍尔IC外,还提供具有反向输出端(高电平有效)的双输出单元。
引脚分配: - BU52001GUL: - A1:VDD(电源) - A2:GND(地) - B1:OUT(输出) - B2:N.C.(不用则开路或接地) - BU52015GUL: - A1:OUT1(输出端,低电平有效) - A2:OUT2(输出端,高电平有效) - B1:GND(地) - B2:VDD(电源) - BU52051NVX: - 1:OUT(输出) - 2:GND(地) - 3:N.C.(不用则开路或接地) - 4:VDD(电源)
参数特性: - 供电电压范围:1.65V至5.5V不等,具体取决于型号。 - 工作点(Bop):±3.7米Tesla至±3.4米Tesla不等。 - 滞后性(Hysteresis):0.4至0.9米Tesla不等。 - 周期(Period):50毫秒。 - 电源电流(AVG):2至8微安不等,具体取决于型号。
功能详解: 这些霍尔IC采用间歇工作方式以节省能源。在启动时,霍尔元件、放大器、比较器等检测电路上电并开始磁检测。在待机期间,检测电路断电,从而降低电流消耗。检测结果在待机期间保持,并随后输出。
应用信息: 适用于移动电话、笔记本电脑、数字摄像机、数字照相机、白色家电等。
封装信息: - VCSP50L1 - SSOP5 - SSON004X1216 - HVSOF5
BD52051NVX-E2 价格&库存
很抱歉,暂时无法提供与“BD52051NVX-E2”相匹配的价格&库存,您可以联系我们找货
