BD5427MUV_10
BD5427MUV_10
    ROHM(罗姆)
    BD5427MUV_10 - Analog Input / BTL Output Class-D Speaker Amplifier - Rohm
BD5427MUV_10 数据手册
Middle Power Class-D Speaker Amplifiers Analog Input / BTL Output Class-D Speaker Amplifier BD5427MUV No.10075EBT07 ●Description BD5427MUV is a 7W + 7W stereo class-D power amplifier IC, developed for space-saving and low heat-generation applications such as low-profile TV sets. The IC employs state-of-the-art Bipolar, CMOS, and DMOS (BCD) process technology that eliminates turn-on resistance in the output power stage and internal loss due to line resistances up to an ultimate level. With this technology, the IC has achieved high efficiency of 80% (7W + 7W output with 8Ω load), which is the top class in the industry. The IC, in addition, employs a compact back-surface heat radiation type power package to achieve low power consumption and low heat generation and eliminates necessity of installing an external radiator, up to a total output of 14W. This product satisfies both needs for drastic downsizing, low-profile structures and powerful, high-quality playback of the sound system. ●Features 1) A high efficiency of 80% (7W + 7W output with 8Ω load), which is the highest grade in the industry and low heat-generation. 2) Driving a lowest rating load of 6Ω is allowed. 3) Pop noise upon turning power on/off and power interruption has been reduced. 4) High-quality audio muting is implemented by soft-switching technology. 5) High-reliability design provided with built-in protection circuits against high temperatures, against VCC shorting and GND shorting, against reduced-voltage, and against applying DC voltage to speaker. 6) A master/slave function allowing synchronization of multiple devices reduces beat noises. 7) Adjustment of internal PWM sampling clock frequencies (250kHz to 400kHz) allows easy protective measures against unwanted radio emission to AM radio band. 8) A compact back-surface heat radiation type power package is employed. VQFN048V7070 7.0mm × 7.0mm × 1.0mm, pitch 0.5mm ●Absolute Maximum Ratings A circuit must be designed and evaluated not to exceed absolute maximum rating in any cases and even momentarily, to prevent reduction in functional performances and thermal destruction of a semiconductor product and secure useful life and reliability. The following values assume Ta =25℃. For latest values, refer to delivery specifications. Parameter Supply voltage Power dissipation Input voltage for signal pin Input voltage for control pin Input voltage for clock pin Operating temperature range Storage temperature range Maximum junction temperature Symbol VCC Pd VIN VCONT VOSC Topr Tstg Tjmax Rating +20 3.28 4.8 -0.2 ~ +7.2 -0.2 ~ Vcc+0.2 -0.2 ~ +7.2 -40 ~ +85 -55 ~ +150 +150 Unit V W W V V V ℃ ℃ ℃ Conditions Pin 2, 14, 15, 22, 23, 38, 39, 46, 47 (Note 1, 2) (Note 3) (Note 4) Pin 6, 7 (Note 1) Pin 28, 32 (Note 1) Pin 31 (Note 1) (Note 1) A voltage that can be applied with reference to GND (pins 5, 18, 19, 42, and 43) (Note 2) Pd and Tjmax=150℃ must not be exceeded. (Note 3) 114.3mm × 76.2mm × 1.6mm FR4 2-layer glass epoxy board (Copper Area 5505mm2) installed. If used under Ta=25℃ or higher, reduce 26.2mW for increase of every 1℃. The board is provided with thermal via. (Note 4) 114.3mm × 76.2mm × 1.6mm FR4 4-layer glass epoxy board (Copper Area 5505mm2) installed. If used under Ta=25℃ or higher, reduce 38.4mW for increase of every 1℃. The board is provided with thermal via. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 1/15 2010.05 - Rev.B BD5427MUV ●Operating Conditions The following values assume Ta =25℃. Check for latest values in delivery specifications. Parameter Supply voltage Load resistance (Note 5) Pd should not be exceeded. Technical Note Symbol VCC RL Rating +10 ~ +16.5 6 ~ 16 Unit V Ω Conditions Pin 2, 14, 15, 22, 23, 38, 39, 46, 47 (Note 5) ●Electrical Characteristics Except otherwise specified Ta = 25℃, VCC = 12V, fIN = 1kHz, Rg = 0Ω, RL = 8Ω、MUTEX="H", MS="L" For latest values, refer to delivery specifications. Parameter Whole circuit Circuit current 1 (Sampling mode) Circuit current 2 (Muting mode) Control circuit “H” level input voltage “L” level input voltage Audio circuit Voltage gain Maximum output power (Note 6) Total harmonic distortion (Note 6) Crosstalk Output noise voltage (Sampling mode) Residual noise voltage (Muting mode) Internal sampling clock frequency GV PO THD CT VNO VNOM FOSC 28 7 0.1 85 80 1 250 dB W % dB µVrms µVrms kHz PO = 1W THD+N = 10% PO = 1W, BW=20Hz ~ 20kHz PO = 1W, Rg = 0Ω, BW = IHF-A Rg = 0Ω, BW = IHF-A Rg = 0Ω, BW = IHF-A, MUTEX = “L” MS = “L” (In master operation) VIH VIL 2.3 ~ 12 0 ~ 0.8 V V MUTEX, MS MUTEX, MS ICC1 ICC2 25 10 mA mA With no signal MUTEX = “L” Symbol Limits Unit Conditions (Note 6) The rated values of items above indicate average performances of the device, which largely depend on circuit layouts, components, and power supplies. The reference values are those applicable to the device and components directly installed on a board specified by us. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 2/15 2010.05 - Rev.B BD5427MUV ●Electrical characteristic curves (Reference data) (1) Under Stereo Operation(RL=8Ω) Technical Note 100 Vcc=12V RL=8Ω BW=20~20kHz 6kHz 100 10 THD+N (%) 1 0.1 100Hz 10 THD+N (%) Vcc=12V RL=8Ω Po=1W BW=20~20kHz 1 1kHz 0.1 0.01 100 0.01 0.001 0.01 0.1 1 OUTPUT POWER (W) 10 10 100 1000 10000 100000 FREQUENCY (Hz) Fig. 2 THD+N - Frequency Fig. 1 THD+N - Output power 40 35 VOLTAGE GAIN (dB) 25 20 15 10 5 0 10 100 1000 FREQUENCY (Hz) 10000 100000 CROSSTALK (dB) 30 Vcc=12V RL=8Ω Po=1W L=33µH C=0.47µF Cg=0.1µF 0 -20 -40 -60 -80 -100 10 100 1000 FREQUENCY (Hz) 10000 100000 Vcc=12V RL=8Ω Po=1W BW=20~20kHz Fig. 3 Voltage gain - Frequency Fig. 4 Crosstalk - Frequency 0 CROSSTALK (dB) -20 -40 -60 -80 -100 0.001 20 Vcc=12V RL=8Ω fin=1kHz BW=20~20kHz OUTPUT POWER (W) 15 10 5 0 8 RL=8Ω fin=1kHz THD=10% 0.01 0.1 1 10 100 10 OUTPUT POWER (W) Fig. 5 Crosstalk - Output power 12 14 VCC (V) 16 18 Fig. 6 Output power - Power supply voltage www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 3/15 2010.05 - Rev.B BD5427MUV ●Electrical characteristic curves (Reference data) – Continued Technical Note 100 90 80 70 60 50 40 30 20 10 0 0 Vcc=10V RL=8Ω fin=1kHz 100 90 80 70 60 50 40 30 20 10 0 0 EFFICIENCY (%) EFFICIENCY (%) Vcc=12V RL=8Ω fin=1kHz 5 10 OUTPUT POWER (W/ch) 15 5 10 OUTPUT POWER (W/ch) 15 Fig. 7 Efficiency - Output power Fig. 8 Efficiency - Output power 100 90 80 70 60 50 40 30 20 10 0 0 5 10 3 Vcc=16.5V 2 ICC (A) Vcc=10V 1 RL=8Ω fin=1kHz 0 15 0 5 10 15 20 25 30 35 40 OUTPUT POWER (W/ch) TOTAL OUTPUT POWER (W) Vcc=12V EFFICIENCY (%) Vcc=16.5V RL=8Ω fin=1kHz Fig. 9 Efficiency - Output power Fig. 10 Current consumption - Output power 100 90 80 70 60 50 40 30 20 10 0 8 0 RL=8Ω 無信号時 Without signal -20 NOISE FFT (dBV) -40 -60 -80 -100 -120 -140 10 100 ICC (mA) Vcc=12V RL=8Ω Without signal 無信号時 BW=20~ 20kHz Sampling Mute 10 12 14 VCC (V) 16 18 1000 10000 100000 FREQUENCY (Hz) Fig. 12 FFT of Output Noise Voltage Fig. 11 Current consumption - Power supply voltage www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 4/15 2010.05 - Rev.B BD5427MUV ●Electrical characteristic curves (Reference data) – Continued Technical Note M UTEX Pin 28 10V/div TM Pin 34 5V/div M UTEX Vcc=12V Pin 28 RL =8 Ω Po=500m W fin=500Hz TM Pin 34 10V/div 5V/div Vcc=12V RL =8 Ω Po=500mW fin=500Hz Speaker output 2V/div 10msec/div Speaker output 2V/div 10msec/div Fig. 13 Wave form when Releasing Soft-mute Fig. 14 Wave form when Activating Soft-mute V CCA VHOLD Pin 35 TM Pin 34 5V/div V CCA Vcc=12V RL =8 Ω Po=500mW TM fin=3kHz Pin 34 VHOLD Pin 35 5V/div Vcc=12V RL =8 Ω Po=500mW fin=3kHz 5V/div 5V/div Speaker output 2V/div Speaker output 2msec/div 2V/div 20msec/div Fig. 15 Wave form on Instantaneous Power Interruption (20msec / div) Fig. 16 Wave form on Instantaneous Power Interruption (2msec / div) www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 5/15 2010.05 - Rev.B BD5427MUV ●Electrical characteristic curves (Reference data) (2) Under Stereo Operation (RL=6Ω) Technical Note 25 20 15 10 5 0 8 10 12 14 VCC (V) 16 18 RL=6Ω fin=1kHz THD=10% OUTPUT POWER (W) Fig. 17 Output power - Power supply voltage 100 90 80 70 60 50 40 30 20 10 0 0 Vcc=10V RL=6Ω fin=1kHz 100 90 80 70 60 50 40 30 20 10 0 0 EFFICIENCY (%) EFFICIENCY (%) Vcc=12V RL=6Ω fin=1kHz 5 10 15 OUTPUT POWER (W/ch) Fig. 18 Efficiency - Output power 20 5 10 15 OUTPUT POWER (W/ch) Fig. 19 Efficiency - Output power 20 100 90 80 70 60 50 40 30 20 10 0 0 4 3 Vcc=12V ICC (A) 2 1 0 5 10 15 OUTPUT POWER (W/ch) Fig. 20 Efficiency - Output power Vcc=16.5V RL=6Ω fin=1kHz EFFICIENCY (%) Vcc=16.5V Vcc=10V RL=6Ω fin=1kHz 0 5 10 15 20 25 30 35 40 20 TOTAL OUTPUT POWER (W) Fig. 21 Current consumption - Output power Dotted lines of the graphs indicate continuous output power to be obtained on musical signal source or by installing additional heat sinks. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 6/15 2010.05 - Rev.B BD5427MUV ●Pin Assignment Technical Note Top View BSP1P N.C. N.C. BSP2P 1 GNDA VCCA 2 VCCA N.C. FILA 4 FILA 12 11 N.C. 10 N.C. 9 N.C. 8 N.C. 7 6 GNDA 5 Power Limit N.C. 13 N.C. VCCP1P VCCP1P OUT1P OUT1P 14 15 16 17 DRIVER 1P FILP FILP 3 N.C. IN1 IN2 N.C. 48 N.C. 47 VCCP2P PWM1 PWM2 46 VCCP2P DRIVER 2P 45 OUT2P 44 OUT2P 43 GNDP2 42 GNDP2 GNDP1 18 GNDP1 19 OUT1N OUT1N VCCP1N VCCP1N N.C. 20 21 22 23 WARNING ERROR DRIVER 1N Protections & Logic Under Voltage Protection High Temperature Protection Output Short Protection Output DC Voltage Protection Ramp Generator Power-Off Detector DRIVER 2N 41 OUT2N 40 OUT2N 39 VCCP2N 38 VCCP2N Clock Control Mute Control SOFT MUTE 24 N.C. N.C. 37 N.C. N.C. N.C. 25 BSP1N 26 WARNING 27 ERROR 28 MUTEX 29 N.C. 30 N.C. 31 OSC 32 MS 33 ROSC 34 TM 35 VHOLD 36 BSP2N Fig. 22 Pin Assignment Diagram ●Outer Dimensions and Inscriptions TYPE BD5427 1PIN MARK Lot No. Fig. 23 Outer Dimensions and Inscriptions of VQFN048V7070 Package www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 7/15 2010.05 - Rev.B BD5427MUV ●Explanation of Pin Functions (Provided pin voltages are typical values.) No. Symbol Pin voltage Pin description Technical Note Internal equalizing circuit 2 VCCA Vcc Analog system power pin 2 3 FILP Vcc+35 12 PWM system bias pin 3 Connect a capacitor. 5 2 Analog signal system bias pin 4 FILA 3.5V Connect a capacitor. 4 5 5 GNDA 0V Analog system GND pin 2 6 7 IN2 IN1 3.5V ch2 Analog signal input pin ch1 Analog signal input pin Input audio signal via a capacitor. 6/7 20k 5 www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 8/15 2010.05 - Rev.B BD5427MUV ●Explanation of Pin Functions - Continued No. Symbol Pin voltage Pin description ch1 positive bootstrap pin Connect a capacitor. Technical Note Internal equalizing circuit 1 4,1 5 12 BSP1P - 12 14, 15 VCCP1P Vcc ch1 positive power system power supply pin 1 6,1 7 16, 17 OUT1P Vcc ~ 0V ch1 positive PWM signal output pin Connect with output LPF. 1 8 ,1 9 18, 19 GNDP1 0V ch1 power system GND pin 2 2 ,2 3 20, 21 OUT1N Vcc ~ 0V ch1 negative PWM signal output pin Connect with output LPF. 25 2 0 ,2 1 22, 23 VCCP1N Vcc ch1 negative power system power supply pin 25 BSP1N - ch1 negative bootstrap pin Connect a capacitor 1 8 ,1 9 2 Warning output pin 26 WARNING H: 5V L: 0V Pin to notify operation warning. H: Under warning L: Normal operation Connect a resister. 5 26 2k 2 Error output pin 27 ERROR H: 5V L: 0V A pin for notifying operation errors. H: Error L: Normal operation Connect a resister. 5 2k 27 www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 9/15 2010.05 - Rev.B BD5427MUV ●Explanation of Pin Functions - Continued No. Symbol Pin voltage Pin description Technical Note Internal equalizing circuit 2 Audio mute control pin 28 MUTEX H: Mute off L: Mute on 28 120k 5 8, 9 10, 11 13, 24 29, 30 37, 48 N.C. - N.C. pin Nothing is connected with IC internal circuit. Sampling clock signal input/output pin 31 OSC When using two or more sampling clocks, connect via a capacitor. 2 Master/Slave switching pin 32 MS Switching of master/slave functions on a sampling clock signal. H: Slave operation L: Master operation 32 120k 5 2 Internal PWM sampling clock frequency setting pin 33 ROSC 5.6V Usually the pin is used open. To adjust an internal sampling clock frequency, connect a resister. 6/7 20k 5 www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 10/15 2010.05 - Rev.B 80k 80k BD5427MUV ●Explanation of Pin Functions - Continued No. Symbol Pin voltage Pin description Technical Note Internal equalizing circuit 2 Audio muting constant setting pin 34 TM 0 ~ 5V Connect a capacitor. 34 5 2 Instantaneous power interruption detecting voltage setting pin 35 VHOLD 0.68×Vcc 35 Connect a capacitor. To adjust a detecting voltage, connect a resister. 5 36 BSP2N - ch2 negative bootstrap pin Connect a capacitor. 3 8 ,3 9 36 38, 39 VCCP2N Vcc ch2 negative power system power supply pin 4 0 ,4 1 40, 41 OUT2N Vcc ~ 0V ch2 negative PWM signal output pin Connect an output LPF. 4 2 ,4 3 42, 43 GNDP2 0V cch2 power system GND pin 4 6 ,4 7 44, 45 OUT2P Vcc ~ 0V ch2 positive PWM signal output pin Connect an output LPF. 1 4 4 ,4 5 46, 47 VCCP2P Vcc ch2 positive power system power supply pin 1 BSP2P - ch2 positive bootstrap pin Connect a capacitor. 4 2 ,4 3 www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 390k 180k 11/15 2010.05 - Rev.B BD5427MUV ●Application Circuit Diagram ・Vcc=10V ~ 16.5V SP IN PU T 1ch SP IN PU T 2ch Technical Note GND A 2.2 μ F 2.2 μ F C2 10 μ F C5 C7 C6 12 11 N.C. 10 N.C. 9 N.C. 8 N.C. 7 6 GND A 5 C4 10μF 4 FIL P C3 1μF N.C. N.C. N.C. N.C. 3 VCCA 0.1 μ F + VCCA 2 1 VCCP1 0. 1 C 62 μF 8 N.C. FIL A 13 N.C. 14 N.C. 48 47 PWM 1 PWM 2 N.C. C1 6 0. μ F 8 VCCP2 1 1C 5 μF + 0 1 3L 6 μH 3 1 C 6 0.1 μ F 15 1 C 4 0.1 μ F 16 17 18 46 45 44 43 42 4 C 0.1 μ6 F DRIVER 1P DRIVER 2P 4 3L 4 μH 3 4 C 4 0.1 μ F 3 +C9 1 μF 0 1 C4 0. 7 μ F 7 SP 1 ch (8 Ω ) GNDP 1 0. 4 C 0 0.1 μ F 3 μH 3L 4 0 4 4C 1 μF 7 SP 2 ch (8 Ω ) 2 C 0 0.1 μ F 3 μH 32 L 0 19 20 21 2 C 2 0.1 μ F 22 23 WARNING ERROR GNDP 2 DRIVER 1N Protections & Logic Under Voltage Protection High Temperature Protection Output Short Protection Output DC Voltage Protection Ramp Generator DRIVER 2N 41 40 39 38 3 C6 0. 6 μ F 8 3 C 8 0.1 μ F N.C. 24 Power-Off Detector Clo ck Con t rol Mute Control SOFT MUTE 2 6C 5 0. μ F 8 N.C. N.C. 37 N.C. N.C. 28 29 N.C. N.C. 30 N.C. 25 26 R26 100kΩ 27 R27 100kΩ 31 0.1 μ F 32 33 OPEN 34 35 36 C31 0.1 μ F GNDD WARNING OU T PU T GNDD GND D ERROR OU TPU T Fig. 24 Circuit Diagram of Stereo Operation with 8Ω Load www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. C AREER I / O MU T EX M A S TER S L A VE 3.3 μ F C35 C34 12/15 2010.05 - Rev.B BD5427MUV Table 1 BOM List of Stereo Operation with 8Ω Load No. Item Part Number Vendor Configuration mm inch Value Rated voltage 25V 50V 50V 25V 50V 25V 25V 16V 16V 25V 50V Tolerance Temperature characteristics ±10% ±15% ±10% ±5% ±5% ±10% ±10% ±10% ±10% ±25% ±200ppm/℃ Quantity Technical Note Reference 1 2 3 4 5 6 7 8 9 10 11 12 IC C C C C C C C C C C R BD5427MUV GRM219B31E684KA88 GRM188R11H104KA93 GRM21BB11H104KA01 25ST225M3225 50ST474M3225 GRM21BB31E335KA75 GRM188B11E104KA01 GRM21BB11C105KA01 GRM21BB31C106KE15 25SVPD10M MCR01MZPF1003 ROHM MURATA MURATA MURATA Rubycon Rubycon MURATA MURATA MURATA MURATA SANYO ROHM VQFN048V7070 2012 1608 2012 3225 3225 2012 1608 2012 2012 6666 1005 0805 0603 0805 1210 1210 0805 0603 0805 0805 2626 0402 0.68µF 0.1µF 0.1µF 2.2µF 0.47µF 3.3µF 0.1µF 1µF 10µF 10µF 100kΩ ±10% ±15% ±10% ±20% ±20% ±10% ±10% ±10% ±10% ±20% ±1% 1 4 5 4 2 2 1 2 1 1 3 2 IC1 C1, C12, C25, C36 C5, C14, C22, C38, C46 C16, C20, C40, C44 C6, C7 C17, C41 C35 C31, C34 C3 C4 C2, C15, C39 R26, R27 No. Item Part Number Vendor Configuration mm 10×9×10 Value Tolerance DC Resistance 52mΩmax. Rated DC Current 2.0A max. Quantity Reference 13 L 7G09B-330M SAGAMI 33µH×2 ±20% 2 L16, L20, L40, L44 www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 13/15 2010.05 - Rev.B BD5427MUV Technical Note ●Ordering part number 1. About absolute maximum ratings If an applied voltage or an operating temperature exceeds an absolute maximum rating, it may cause destruction of a device. A result of destruction, whether it is short mode or open mode, is not predictable. Therefore, provide a physical safety measure such as fuse, against a special mode that may violate conditions of absolute maximum ratings. 2. About power supply line As return of current regenerated by back EMF of output coil happens, take steps such as putting capacitor between power supply and GND as a electric pathway for the regenerated current. Be sure that there is no problem with each property such as emptied capacity at lower temperature regarding electrolytic capacitor to decide capacity value. If the connected power supply does not have sufficient current absorption capacity, regenerative current will cause the voltage on the power supply line to rise, which combined with the product and its peripheral circuitry may exceed the absolute maximum ratings. It is recommended to implement a physical safety measure such as the insertion of a voltage clamp diode between the power supply and GND pins. 3. Potential of GND (5, 18, 39, 42, and 43 pins) Potential of the GND terminal must be the lowest under any operating conditions. 4. About thermal design Perform thermal design with sufficient margins, in consideration of maximum power dissipation Pd under actual operating conditions. This product has an exposed frame on the back of the package, and it is assumed that the frame is used with measures to improve efficiency of heat dissipation. In addition to front surface of board, provide a heat dissipation pattern as widely as possible on the back also. A class-D power amplifier has heat dissipation efficiency far higher than that of conventional analog power amplifier and generates less heat. However, extra attention must be paid in thermal design so that a power dissipation Pdiss should not exceed the maximum power dissipation Pd. T jmax - Ta Tjmax: Maximum temperature junction = 150[℃] Pd  〔W〕 Maximum power dissipation Ta: Operating ambient temperature [℃] θja θja: Package thermal resistance [℃/W]    1 Po: Output power [W] Pdiss  PO  - 1  〔W〕 Power dissipation  η   η: Efficiency 5. About operations in strong electric field Note that the device may malfunction in a strong electric field. 6. Thermal shutdown (TSD) circuit This product is provided with a built-in thermal shutdown circuit. When the thermal shutdown circuit operates, the output transistors are placed under open status. The thermal shutdown circuit is primarily intended to shut down the IC avoiding thermal runaway under abnormal conditions with a chip temperature exceeding Tjmax = 150℃, and is not intended to protect and secure an electrical appliance. Accordingly, do not use this circuit function to protect a customer's electrical appliance. 7. About shorting between pins and installation failure Be careful about direction and displacement of an LSI when installing it onto the board. Faulty installation may destroy the LSI when the device is energized. In addition, a foreign matter getting in between LSI pins, pins and power supply, and pins and GND may cause shorting and destruction of the LSI. 8. About power supply startup and shutdown When starting up a power supply, be sure to place the MUTEX pin (pin 28) at “L” level. When shutting down a power supply also, be sure to place the pin at “L” level. Those processes reduce pop noises generated upon turning on and off the power supply. In addition, all power supply pins must be started up and shut down at the same time. 9. About WARNING output pin (pin 26) and ERROR output pin (pin 27) A WARNING flag is output from the WARNING output pin upon operation of the high-temperature protection function and under-voltage protection function. And an ERROR flag is output from the ERROR output pin upon operation of VCC/GND shorting protection function and speaker DC voltage applying protection function. These flags are the function which the condition of this product is shown in. The use which aimed at the protection except for this product is prohibition. 10. About N.C. pins (pins 8, 9, 10, 11, 13, 24, 29, 30, 37, and 48) The N.C. (Non connection) pins are not connected with an internal circuit. Leave the pins open or connect them to GND. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 14/15 2010.05 - Rev.B BD5427MUV ●Ordering part number Technical Note B Part No D 5 Part No. 4 2 7 M U V - E 2 Package MUV: VQFN048V7070 Packaging and forming specification E2: Embossed tape and reel VQFN048V7070 7.0 ± 0.1 Tape Quantity Embossed carrier tape 1500pcs E2 The direction is the 1pin of product is at the upper left when you hold 7.0 ± 0.1 1PIN MARK 1.0MAX Direction of feed S ( reel on the left hand and you pull out the tape on the right hand ) 0.08 S C0.2 1 48 4.7 ± 0.1 12 13 0.4 ± 0.1 37 36 25 24 4.7 ± 0.1 +0.03 0.02 -0.02 (0.22) 0.75 0.5 +0.05 0.25 -0.04 1pin (Unit : mm) Reel Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 15/15 2010.05 - Rev.B Notice Notes No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuelcontroller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. R1010A
BD5427MUV_10
物料型号: - 型号:BD5427MUV - 制造商:ROHM - 封装:VQFN048V7070
器件简介: BD5427MUV是一款7W + 7W立体声D类功率放大器IC,采用BCD工艺技术,具有高效率(80%)和低热生成,适用于需要空间节省和低热生成的应用,如低矮型电视机。该IC还采用了紧凑的背面表面散热型功率封装,无需外装散热器即可实现高达14W的总输出,满足小型化和高音质播放的需求。
引脚分配: - 引脚2:VCCA,供电电压 - 引脚3:FILP,PWM系统偏置引脚 - 引脚4:FILA,模拟信号系统偏置引脚 - 引脚5:GNDA,模拟系统地引脚 - 引脚6、7:IN2、IN1,模拟信号输入引脚 - 引脚12:BSP1P,通道1正bootstrap引脚 - 引脚14、15:VCCP1P,通道1正电源引脚 - 引脚16、17:OUT1P,通道1正PWM信号输出引脚 - 引脚18、19:GNDP1,通道1地引脚 - 引脚20、21:OUT1N,通道1负PWM信号输出引脚 - 引脚22、23:VCCP1N,通道1负电源引脚 - 引脚25:BSP1N,通道1负bootstrap引脚 - 引脚26:WARNING,警告输出引脚 - 引脚27:ERROR,错误输出引脚 - 引脚28:MUTEX,音频静音控制引脚 - 引脚31:OSC,采样时钟信号输入/输出引脚 - 引脚32:MS,主/从切换引脚 - 引脚33:ROSC,内部PWM采样时钟频率设置引脚
参数特性: - 供电电压:+10~+16.5V - 负载电阻:6~16Ω - 效率:80%(7W + 7W输出,8Ω负载) - 驱动最低额定负载:6Ω - 音频静音实现:通过软开关技术 - 内部PWM采样时钟频率可调:250kHz至400kHz
功能详解: BD5427MUV具有高效率、低热生成、低负载驱动能力、减少开关噪声、高质量音频静音、高可靠性设计(包括过热保护、短路保护等)、主从功能减少拍频噪声等特性。
应用信息: 提供了一个立体声操作的应用电路图,其中负载为8Ω,包括了电路图和BOM(物料清单)。
封装信息: - 封装类型:VQFN048V7070 - 尺寸:7.0mm × 7.0mm × 1.0mm,引脚间距0.5mm
BD5427MUV_10 价格&库存
很抱歉,暂时无法提供与“BD5427MUV_10”相匹配的价格&库存,您可以联系我们找货
