BD7757MWX-E2
BD7757MWX-E2
    ROHM(罗姆)
    UFDFN14
    BD7757MWX-E2
BD7757MWX-E2 数据手册
Datasheet 1.5A LED Camera Flash Driver Synchronous Rectification Step-Up DC/DC BD7757MWX Key Specifications  Input Voltage Range :  LED current (FLASH):  LED current (TORCH):  Switching Frequency :  Pch FET On Resistance :  Nch FET On Resistance :  Standby Current at shut down :  Operating Temperature Range: General Description The BD7757MWX is a 1.5A Flash LED Driver with Synchronous rectification step up DC/DC converter that can drive 1LED. The LED current, timer, and UVLO threshold can be varied by using UPIC++ (Uni-Port Interface Control ++). Features Synchronous rectification step-up DC/DC converter. Control of registers via Uni-Port Interface Control ++ (UPIC) Maximum current of 1.5A in Flash mode (Low side LED Driver). Lighting Mode Setup Flash Mode…1.5A (Max) Torch Mode…450mA (Max) Variable LED current Protection Circuit: Over Current Protection Circuit (OCP) Over Voltage Protection Circuit (OVP) VOUT – GND Short Protection Circuit LED Short / Open Protection Circuit Under Voltage Lock Out Circuit (UVLO) Thermal Shut Down Circuit (TSD) Battery Drop Protection Circuit Flash Timer Protection Circuit Package USON014X3020 2.7V to 5.0V 1.5A (Max) 450mA (Max) 2MHz (Typ) 150mΩ (Typ) 100mΩ (Typ) 0μA (Typ) -30℃ to +85℃ W(Typ.) x D(Typ.) x H(Max.) 3.00mm x 2.00mm x 0.60mm Pin Configuration Applications Flash LED Driver for camera and smart phone DSC, DVC Video Lighting for Digital Video Applications Amusement accessory Figure 2. Pin Configuration Typical Application Circuit Figure 1. Application Circuit ○Product structure:Silicon monolithic integrated circuit .www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・14・001 ○This product is not designed for protection against radioactive rays 1/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Pin Description Terminal No. Pin Name ESD Diode In/ Out For Power Function For GND 1 AGND - - - 2 CONTROL1 In - GND UPIC++ control input GND Flash/Torch current output 3 FL Out - 4 CONTROL2 In - GND - Ground Flash ON/OFF terminal. (Compulsive lighting, even if control1=Low state. Output flash current set with initial state at control1=Low state.) 5 AGND - - 6 IN In - GND Power supply 7 PGND - - - Power ground 8 OUT Out - GND - - Ground DCDC output voltage 9 NC - 10 SW In - GND No connection 11 CONTROL3 In - GND 12 NC - - - No connection - Power ground GND Switching output Flash ON/OFF terminal. (Compulsive lighting, even if control1=Low state. Output flash current set with initial state at control1=Low state.) 13 PGND - - 14 RSET Out - The resistor connection terminal of output LED current setting. Block Diagram Figure 3. Block Diagram www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 2/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Absolute Maximum Ratings Parameter Input voltage [All Terminal] Power Dissipation Operating Temperature Range Storage Temperature Symbol VMAX Pd Topr Tstg Limit 7 1.75 (*1) -30 to +85 -55 to +150 Unit V W o C o C Limit 2.7 to 5.0 1.5 450 Unit V A mA *1 Derate by 14mW/°C when operating above 25°C (Mount on 2-layer board) Recommended Operating Conditions Parameter Supply Voltage Maximum Output Current in Flash Mode Maximum Output Current in Torch Mode Symbol VIN IFLED_MAX ITLED_MAX o Electrical Characteristics (Unless otherwise specified, Ta = +25 C, VBAT=3.6V) Parameter Symbol Min. Typ. Max. Unit Conditions Low Threshold Voltage VIL -0.3 - 0.4 V CONTROL1,2,3 High Threshold Voltage VIH 1.4 - 5.2 V CONTROL1,2,3 CONTROLx=High Input Current IFH - 36 70 µA CONTROL1,2,3=3.6V CONTROLx=Low Input Current IFL -1 0 1 µA CONTROL1,2,3=0V Control1 High Time tHI 1 - 100 µs Control1 Low Time tLO 1 - 100 µs Access Available Time tACC - - 500 µs Control1 Off Timeout tOFF - - 500 µs Latch Time tLAT - - 1 ms IQ - 0.1 2.0 μA Current Consumption IDD1 - 3.0 - mA ILED=100mA SW NMOS On Resistance RONN - 0.10 - Ω VIN=3.6V, at 200mA SW PMOS On Resistance RONP - 0.15 - Ω Inductor Current Limit ICOIL - 3 - A VOUT=3.6V at 200mA This parameter is tested in dc measurement. Switching Frequency fSW 1.6 2 2.4 MHz Duty 50 80 - % Vo - - 5.1 V Over Voltage Protection Limit VOVP - 5.4 5.7 V LED Short Threshold Voltage VSTV 1.5 1.7 1.9 V LED Test Current during LED Short Protect ITLED 1 2 3 mA Headroom Voltage VHR 0.18 0.23 0.28 V At step up condition Torch LED Current Accuracy IT-DIFF -10 0 10 % ILED=100mA Flash LED Current Accuracy IF-DIFF1 -10 0 10 % ILED=1.0A UVLO Cancel Voltage VUVLO 2.4 2.5 2.6 V VIN Sweep Up VUVLO_HYS 0.2 0.3 0.4 V VIN Sweep Down Logic controller Others Quiescent Current Duty Cycle Limit Output Voltage Range UVLO Hysteresis Voltage www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 3/24 VHR=0.0V VHR=0.0V (VOUT-VFL) =SWEEP UP VFL=2V TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Typical Performance Curves 100 100 95 95 FLASH0.75A (A2D16) FLASH1.0A (A2D11) 90 85 85 80 80 Effeciency [%] Effeciency [%] 90 75 FLASH1.5A (A2D1) 70 75 70 TORCH=150mA (A3D11) 65 65 TORCH=200mA (A3D9) 60 60 55 55 50 2.7 TORCH=300mA (A3D6) TORCH=450mA (A3D1) 50 2.9 3.1 3.3 3.5 3.7 3.9 4.1 4.3 4.5 2.7 2.9 3.1 3.3 IN Voltage [V] 3.5 3.7 4.1 4.3 4.5 Figure 5. Efficiency [%] vs. IN Voltage [V] (Torch Mode) Figure 4. Efficiency [%] vs. IN Voltage [V] (Flash Mode) 400 3 RSET=90kohm 2.8 2.6 IN=5.0V 300 IN=3.6V 2.4 UVLO Detect RSET Voltage [mV] Circuit current [mA] 3.9 IN Voltage [V] 2.2 2 IN=2.7V 1.8 RSET=90kΩ IFL=100mA VFL=0.6V TORCH MODE 1.6 1.4 UVLO Cancel 200 100 1.2 0 1 -40.0 -20.0 0.0 20.0 40.0 60.0 1.5 80.0 Figure 6. Circuit Current [mA] vs. Temperature [℃] www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 1.7 1.9 2.1 2.3 2.5 2.7 2.9 IN Voltage [V] Temp [℃] 4/24 Figure 7. RSET Voltage [V] vs. IN Voltage [V] TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Typical Performance Curves - continued 2.4 160 VBAT=3.6V RSET=90kohm TORCH MODE 140 VBAT=3.6V OUT=3.6V RSET=90kohm 2.2 100 SW Frequency [MHz] FL output current [mA] 120 OVP Detect 80 OVP Cancel 60 2 1.8 40 20 1.6 0 5.0 5.1 5.2 5.3 5.4 -40.0 5.5 -20.0 0.0 Figure 8. FL output current [A] vs. OUT Voltage [V] 40.0 60.0 80.0 Figure 9. SW Frequency [MHz] vs. Temperature [°C] 1.10 110.0 VBAT=3.6V VFL=0.6V RSET=90kohm TORCH MODE 108.0 106.0 VBAT=3.6V VFL=0.6V RSET=90kohm FLASH MODE 1.08 1.06 1.04 FL output current [A] 104.0 FL output current [mA] 20.0 Temperature [°C] OUT Voltage [V] 102.0 100.0 98.0 1.02 1.00 0.98 96.0 0.96 94.0 0.94 92.0 0.92 90.0 0.90 -40 -20 0 20 40 60 80 Temperature [°C] -20 0 20 40 60 80 Temperature [°C] Figure 10. FL output current [mA] vs. Temperature [°C] at TORCH 100mA www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 -40 5/24 Figure 11. FL output current [A] vs. Temperature [°C] at FLASH 1.0A TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Functional Description 1. Maximum Flash Current setup The maximum Flash current can be set by varying the value of RSET which is connected to RSET-GND terminal. The resistor value can be calculated using the equation: Flash current = 1.0 A×90 kΩ RSET 1-1 Maximum Flash Current Setup RSET Flash Current 60 kΩ ILED = 1.5A 75 kΩ ILED = 1.2A 90 kΩ ILED = 1.0A If RSET is set less than 36kΩ (typ.), the LED current is stopped by internal ISET short limit circuit. 2. Register control Flash-to-Torch ratio can be controlled by the 16-data register. The on/off control of LED current, the Flash timer, the LED current threshold at timer start and the low battery detect can also be set through the register. Register Map is as follows; (N: number of edges) 2-1 Address Map (Initial Address = 1) N Address Addressed register Select Torch/FLASH mode. 1 1 Select Inhibit/AUX 2 2 FLASH current setting 3 3 TORCH current setting 4 4 LED timer setting 5 5 LED current threshold at timer start 6 6 Low Battery detection setting Data 1-3 4- 5 1-16 1-16 1-16 1-8 1-10 Initial Data 1 (POFF) 1 (1.0A at RSET=90k) 11 (100mAat RSET=90k) 10 (1000ms) 6 (300mA) 10 (No detect) 2-2 Address Description Address 1 : LED Mode N Data Symbol Mode Description 13 14 15 16 17 1* 2 3 4 5 POFF TON FON FINH AUX Power OFF Torch ON Flash ON Inhibit ON AUX ON Address 2, : Flash Current Ratio Flash current = Maximum Flash current ×Fratio (n≥18, NOP) POFF…STOP LED and DCDC output. FINH…Mode changes to torch mode correspondingly AUX…Flash mode turns ON compulsorily with initial data (data=1) * Initial Data = 1 N Data 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 1* 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Fratio RSET =60kΩ RSET =90kΩ 100.0% 96.7% 93.3% 90.0% 86.7% 83.3% 80.0% 76.7% 73.3% 70.0% 66.7% 63.3% 60.0% 56.7% 53.3% 50.0% 1500mA 1450mA 1400mA 1350mA 1300mA 1250mA 1200mA 1150mA 1100mA 1050mA 1000mA 950mA 900mA 850mA 800mA 750mA 1000mA 967mA 933mA 900mA 867mA 833mA 800mA 767mA 733mA 700mA 667mA 633mA 600mA 567mA 533mA 500mA (n≥29, NOP) * Initial Data = 1 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 6/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Functional Description – continued Address 4 : Flash Timer Address 3 : Torch Current Ratio Torch current =Maximum Torch current×Tratio N Data Tratio RSET =60kΩ RSET =90kΩ 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 1 2 3 4 5 6 7 8 9 10 11 * 12 13 14 15 16 100.0% 93.3% 86.7% 80.0% 73.3% 66.7% 60.0% 53.3% 46.7% 40.0% 33.3% 26.7% 20.0% 13.3% 6.7% 0% 450mA 420mA 390mA 360mA 330mA 300mA 270mA 240mA 210mA 180mA 150mA 120mA 90mA 60mA 30mA 0.0mA 300mA 280mA 260mA 240mA 220mA 200mA 180mA 160mA 140mA 120mA 100mA 80mA 60mA 40mA 20mA 0.0mA N Data Flash Timer 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 1 2 3 4 5 6 7 8 9 10 * 11 12 13 14 15 16 20ms 40ms 60ms 80ms 100ms 200ms 400ms 600ms 800ms 1000ms 1200ms 1400ms 1600ms 1800ms 2000ms Timer off (n≥29, NOP) * Initial Data = 10 (n≥29, NOP) * Initial Data = 11 Address 5: LED Current Threshold at Timer Start N Data 13 14 15 16 17 18 19 20 1 2 3* 4 5 6 7 8 Address 6: Low Battery Detection LED current threshold at timer start N 400mA 350mA 300mA 250mA 200mA 150mA 100mA 50mA 13 14 15 16 17 18 19 20 21 22 (n≥21, NOP) * Initial Data = 3 Data 1 2 3 4 5 6 7 8 9 10 * Battery voltage 3.8 3.7 3.6 3.5 3.4 3.3 3.2 3.0 2.8 No detect (n≥23, NOP) * Initial Data = 10 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 7/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Functional Description – continued 3. Register Access Control Protocol LED current is controlled through the Control1 terminal whose input is from the uni-Port interface. The register can be accessed by using the protocol below. (The first rising edge to Control1 from the time of shutdown is not included in address and data assignment.) ○Address / Data Selection Waveform Control1 tHI tLO Figure 13. Control1 Signal Timing Diagram item High input time ( tHI ) Low input time ( tLO ) MIN 1us 1us MAX 100us 100us ○Example:Address = 3・Data = 8 (changes FLASH current to 53.3%) This edge is not counted for “n”. n= 1 17 18 2 19 tACC Start 3 edges 20 tLAT tLAT 20 edges N = 20, Data = 8 Address Register applies Address 1 Data 1 . 3 8 Figure 14. Example of Control1 Signal After the UVLO circuit is triggered, all register settings are reset. Hence, the registers has to be set again once UVLO circuit is cancelled (VBAT>2.5V) *. *Please refer to “Electrical Characteristics” on P.3 for the specification on each symbol. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 8/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX 4. Startup and Shut Down Sequence ○Example of FLASH action using control1. 1. After power up of IN terminal, input signal to control1. 2. If none of the protection circuit is enabled, VOUT starts charging after sending the Flash or Torch lighting signal. 3. Test current (2mA, typ.) is loaded from FL current when it reaches VOUT>VIN-0.25V. At that time, output FL current, if STV is not detected yet, Soft Start (SS:IC built-in circuit) starts to charger.. 4. DCDC completes boost up and LED current is stable. 5. Setting Control1=L turns off the IC after tOFF time. 1 5 2 4 3 Figure 15. Startup and Shut down Sequence using Control1 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 9/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX ○FLASH Action using Control2 or Control3 1. After power up of IN terminal, input signal to control1 and next input control2 or control3. Set condition by Control1, before input control2 or control3. 2. If none of the protection circuit is enabled, VOUT starts charging. 3. Test current (2mA, typ.) is loaded from FL current when it reaches VOUT>VIN-0.25V. At that time, output FL current, if STV is not detected yet, Soft Start (SS:IC built-in circuit) starts to charger.. 4. DCDC completes boost up and LED current is stable. 5. Setting Control2,3=L turns off the IC after tOFF Time 1 VIN 5 tOFF Control2,3 IC State ACT(FLASH ON BY CONTROL2,3) SHUTDOWN Control1 SHUTDOWN Initial Setting VIN-0.25V UVLO/Low BAT UVLO/OVP/RSET SHORT/SCP NO detect Condition FL VOUT/FL 2 OUT STV No detection 4 IFL 3 Output SS(internal IC) SW Figure 16. Startup and Shut Down Sequence using Control2 or Control3 *Startup in Flash operation by Control2 or 3=H and Control1=Low state, Control1 cannot receive signal. Therefore, when setting change is assumed during the compulsive flash operation by control2 or 3, first of all, please input anything signal into control1 ( for keeping control1=H state). And control1 becomes possible receiving the signal also during the compulsive FLASH operation by setting control2 or 3=High state. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 10/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX 5. Flash or Torch Mode Selection Switching between Flash and Torch mode can be done using Control1, 2 or 3 Control terminal name Input signal Function A1/D1 LED/DCDC=OFF A1/D2 Torch Mode A1/D3 Flash Mode Control1 A1/D4 Forcibly changes to Torch Mode (FINH) A1/D5 FLASH turn ON forcibly with initial data (AUX) Forced Flash lighting (output in address/data assigned current) Control2* High Forced Flash even when Control1=Low state Forced Flash lighting (output in address/data assigned current) Control3* High Forced Flash even when Control1=Low state ※Control2,3 are the same function ○Priority number of FLASH/TORCH selection Priority 1 Priority 2 Priority 3 Control2 Control1:A1/D4 (FINH) Control1:A1/D5 (AUX) Compulsive FLASH operation Compulsive TORCH Compulsive FLASH operation with Control3 operation initial condition data Compulsive FLASH operation For example, when specifying A1/D4 by Control1 and switching to TORCH mode, TORCH state is continued even if Control3=High www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 11/24 Priority 4 Control1:A1/D2 (TORCH operation) Control1:A1/D3 (FLASH operation) TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX 6. Regarding LED output current ○FLASH Control When the setting changes to Flash mode, the maximum output current can be set up to 1.5A The control method for setting FLASH mode Control terminal name Input signal Control Function A1/D3 FLASH mode Control1 A1/D5 FLASH turn ON forcibly with initial data (AUX) Forced Flash lighting (output in address/data assigned current) Control2 High Forced Flash even when Control1=Low state Forced Flash lighting (output in address/data assigned current) Control3 High Forced Flash even when Control1=Low state If the setting continues to send high current to the LED for an extended period of time, it will generate heat to the IC and will cause lower luminance. In order to prevent this, FLASH TIMER function is built in and that time can be changed by setting the register (Typ 1.0s). Please refer to the maximum LED current specification (p.6) and set up LED timer (p.7). ○LED Timer Function LED current threshold at timer start This setting can be set by register 5 50mA~400mA (Initial setting=300mA) ・LED Timer This setting can be set by register 4 20ms~2000ms NO TIMER can also be selected (Initial setting=1000ms) Figure 17. Timer Operation 1 By setting the register, BD7757MWX can change the LED current threshold at timer start and the LED timer. Timer operation is applicable in both Flash and Torch mode. When the light on the LED’s turn off because the timer finished, the following sequences are required in order to make the light re-switch back on. ・Re-lighting by control1 1. Input Address=1/Data=1 -> turn off LED/DCDC operation. -> Input Re-lighting signal. 2. Control1= Low during TOFF -> input re-start signal ・Re-lighting by control2 or control3 1. Control2 or control3=Low -> Input Control2 or control3=Low→High. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 12/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Counter is reset when LED current crosses the threshold during a timer count. While, when LED current goes over the LED current threshold,it counts back from the start. LED current threshold at timer start Figure 18. Timer Operation 2 Moreover, Counter is reset when LED current is set to turn off by control1,2 or 3 during a count. ○Forced Flash (Control2,3) Flash is turned on forcibly by sending a high signal to Control2 or Control3(Control2 and control3 are of the same function). During Flash mode, LED’s can be turned off by control2 or control3 by ・Control2 or control3=Low ・Timer END The sequence of FLASH operation by control2 or control 3 is shown below. TORCH⇒Control2,3=ON⇒Control2,3=OFF OFF⇒Control2,3=ON⇒Control2,3=OFF TORCH⇒Control2,3=ON⇒Timer END⇒Control2,3=OFF Timmer OFF⇒Control2,3=ON⇒Timer END⇒Control2,3=OFF Timmer Timer Count Control2 or 3 Control2 or 3 IFL IFL Timer Count FLASH 0A 0A Figure 19. LED Current Operation by Control2, 3 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 13/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX ○Forced Torch (FINH) Setting address=1 and data=4 through control1, LED current will enter Torch mode correspondingly This mode has the highest priority, and makes the light switch on in TORCH mode even in lighting state at all times. Compulsorily TORCH ON FLASH ON FLASH ON Figure 20. LED current operation by FINH (A1/D4) Therefore, even if the mode is set Flash mode by Control2 or 3, the output remains at Torch mode. Startup in compulsive Flash operation by Control2 or 3=H and Control1=Low state, Control1 cannot receive signal while Control2 or 3=H. Therefore, when FINH setting is assumed during the compulsive flash operation by control2 or 3, first of all, please input anything signal into control1 ( for keeping control1=H state). And control1 becomes possible receiving the FINH signal also during the compulsive FLASH operation by setting control2 or 3=High state. ○Torch mode To go to Torch mode, Control1 sets data=2 in address 1. TORCH current can be set by 0% to 100% with 16steps. In addition, sending Address=1 and data=4 through Control1, IC goes to Torch mode forcibly (Please refer to [forced TORCH]) Control2,3 A1/D4 Control1 TACC Forced TORCH ON FLASH current does not flow for forced TORCH mode. IFL TORCH TORCH ON OFF A1/D1 A1/D2 Control1 IFL TORCH Figure 21. LED Current Operation (Torch Mode) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 14/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX 7. Protect function Condition for releasing latch FAILURE MODE DETECTION MODE LED Current DCDC Action After Release Failure Register State LED Open OVP Detect Stop Stop Auto return Keep LED Short LED Short Detect Stop Stop Latch Keep RSET Short COUT Short High Temperature Low Battery Low Battery ISET Short Detect Output Short Detect Stop Stop Stop Stop Auto return Auto return Keep Keep TSD Detect Stop Stop Latch Reset UVLO Detect Low Battery Detect Stop Stop Stop Stop Auto return Auto return Reset Reset by Control1,2,3 or UVLO Reset by Control1 or UVLO - Keep - ○ Over Voltage Protection (OVP) / LED Open Protection (LOP) Whenever the LED is not connected to FL or OUT terminal, FL terminal voltage becomes Low. Therefore, DC/DC voltage will increase drastically and the VOUT terminal voltage will detect OVP. Then, LED and DCDC driver will stop and output voltage will decrease by discharging. When the output voltage reaches under the OVP hysteresis, DCDC will boost up again and will detect OVP. The over voltage during LED open mode is protected by this operation. Figure 22. OVP and LOP Operation ○Output Short Protection When OUT pin voltage becomes 1.0V or less, the DCDC/LED driver stops and flowing of large current can be prevented in breakdown caused by short mode of output capacitance. This time, constant current of 100mA from OUT pin is sourced. This returns to normal, if short mode is released. ○LED Short protection At start up timing, VOUT is charged until VOUT=VIN state, and LED / DCDC driver starts operating. A test current (2mA typ.) flows from FL terminal before it supplies the LED current. LED is short at this time, If the voltage between FL-OUT pins becomes 1.7V or less, then it becomes latch stop. To release the latch, in the case of lighting by Control1, input Control1=Low or POFF (Address 1 / Data1). In the case of lighting byControl2 or 3, set Control2 or 3 to low ○Thermal shutdown If the chip temperature amounts to 155°C or more, thermal shutdown circuit will be enabled and latched. To release the latch, in the case of lighting by Control1, input Control1=Low or POFF (Address 1 / Data1). In the case of lighting byControl2 or 3, set Control2 or 3 to low. ○Under Voltage Lock Out (UVLO) If the VIN voltage decreases under 2.2V, UVLO circuit will be enabled. Only when VIN voltage increases over 2.5V will UVLO be cancelled. When the UVLO circuit is enabled, all the systems and register setup will also be reset. ○Low Battery UVLO Low Battery UVLO can set the threshold from 2.8V to 3.8V using the register. In addition, It can be set to no detect mode. The registers are not reset when the protection circuit is triggered. When IN voltage increases to more than the hysteresis level (0.1V typ.), it will re-start. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 15/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Application Circuit Figure 23. Application Circuit ※It is recommended to connect the R_RSET resistance, which sets up the LED current between pin14:RSET and pin1:AGND. Moreover, do not connect pin1 to GND of the DUT board. (Pin1 AGND and pin5 AGND is shorted inside the IC) Selection of Components Externally Connected Parts Name Input Capacitor Inductor Output Capacitor LED Current Setting Resistor Symbol CIN L COUT MIN 1.0 1.8 R_RSET 60 Value TYP 2.2 1.0 4.7 - MAX - Unit Product Number μF μH μF MURATA : GRM188B31A225KE33 TDK : VLF403210MT-1R0N MURATA : GRM188B30J475KE18 kΩ (60kΩ) ROHM : MCR006YZPD1203 //2 120 ○Inductor As an important characteristic of an inductor, it increases the allowable current and serial resistive components. The step up ratio is high. Thus, when the output LED current is high, the current which flows into the inductor becomes very high. Therefore, it is necessary to select an inductor with high maximum allowable current. Moreover, efficiency is affected by the series resistance components. Therefore, it is recommended that there is a margin to the maximum allowable current. Selecting the inductor with a small series resistance value is also suggested. ・Inductor Current Calculation The current which flows into the inductor is determined by the following conditions: Output voltage=VOUT [V] LED current=ILED [A] Input voltage=VIN [V] PMOS ONR=PONR[Ω] Feed Back voltage=VFB[V] Inductor series resistance value=RL[Ω] efficiency=η [%] The average current needed for the application is called for using the formula. IIN[ A]  ( VOUT[ V]  PONR  ILED  VFB  RL[]  ILED)  ILED[ A] VIN[ V]  [%] In the driver operation with DCDC switching frequency=fsw[Hz], The ripple current⊿IL[A] which occurs in inductor L [H] is described by the formula: Δ IL  ( VOUT [ V ]  VIN [ V ])  VIN [ V ] L[H]  VOUT [ V ]  f SW [Hz ] [A ] Therefore, the peak current of the inductor becomes, Ipeak  I IN [ A]  IL[ A] 2 Figure 24. Inductor current [ A] (1) (1) Formula of the inductor current at DCDC operation. The inductor current DCDC stops, becomes the current running through the LED. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 16/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX ・Example computation Output voltage=4V LED current=1.0 [A] Input voltage=3.6 [V] Efficiency=85 [%] L=1.0[μH] Freq=2[MHz] PMOS ONR=0.15[Ω] Feed Back voltage=0.23[V] Inductor series resistor value=0.05[Ω] The peak current of the inductor in this condition is computed. IIN[ A]  Δ IL  (4[ V]  0.15[]  1.0[ A]  0.23[ V]  0.05[]  1.0[ A])  1.0[ A]  1.17[ A]  3.6[ V]  85[%] ( 4 .0[ V ]  3 .6[ V ])  3 .6[ V ]  0 .18 1 .0E  6 [H]  4 .0[ V ]  2E 6 [Hz ] Ipeak  1 .17 [ A ]  0 .18 [ A ]  1 .26 2 [A] [A] ○Input /Output Capacitor High current is charged and discharged to the input / output capacitor at that time of DCDC switching operation. Therefore, if a capacitor of high ESR is used, ripple will occur and efficiency will get worse. It is recommended to use a ceramic capacitor of small ESR. ○Resistor for LED current LED current is set by the resistor which is connecting RSET and AGND terminal. Since the temperature characteristics and variation of the resistance influences the LED current directly, It is recommend to use a resistance of low temperature characteristics and variation. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 17/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Power Dissipation 2.4 Pd=1.75W at 25℃ 2.2 2 Board material: grass epoxy Layer: 2 layers Power dissipation [W] 1.8 1.6 1.4 1.2 1 0.8 0.6 0.4 0.2 0 0 25 50 75 100 125 150 Temperature [℃] Figure 25. Power Dissipation [W] vs. Temperature [℃] www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 18/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX I/O Equivalent Circuits 1.AGND / 5.AGND / 6.IN / 7.PGND 8.OUT / 10.SW / 13.PGND 2.Control1 / 4.Control2 / 11.Control3 3.FL www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 R14.SET 19/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Notice for PCB layout Since high current flows into the DUT during FLASH lighting, the ground voltage is changed by the very small impedance of the PCB pattern. Moreover, PCB layout is very important because it changes with PCB patterns. The voltage drop across the pattern also affects the efficiency and ripple. D D A C B B D Figure 26. Application Circuit for PCB ○Power GND wire “A” line is Power GND wire. High current flows through this wire from 7Pin-PGND and 13Pin-PGND. Therefore, by wiring it shortly and as thickly as possible, the potential difference across the wiring will not affect the operation. Please short the patterns of the following pin directly 5Pin: AGND, 7Pin: PGND, 13Pin: PGND. Addition of a heat sink to this GND pattern is also recommended. The heat dissipation of IC is high thus wiring area has to be large. ○LED wire The LED current flows through the “B” line. Since a high current (LED maximum current is 1.5A ) flows into this line, it is necessary to make it as thick as possible. The impedance across the line will cause a decrease in efficiency. ○DCDC wire “C” line is a course which the current passes through the inductor. Since the high current of LED current and DCDC step-up current flows into this line, it is necessary to make it as thick as possible. The impedance across the line will cause a decrease in efficiency. ○Analog wire “D” line is an analog line. Since high current does not flow into this wiring, it is acceptable to use thin wiring. However, since RSET terminal is very weak to a switching noise, Precautions must be taken to avoid crosstalk with SW terminal. As a recommendation, R_RSET has to be placed immediately near the terminal. By shortening distance between resistance R_RSET and RSET terminal (about under 5mm), crosstalk can be avoided. ○Regarding capacitor Output capacitor has to be placed near the OUT terminal and connect GND to Power GND. Input capacitor has to be place near the inductor and connect GND to Power GND. If the wiring impedance against the capacitance serially attaches, it becomes ripple factors of VIN voltage and OUT voltage. It also causes a decrease in efficiency. The example of a layout of ROHM evaluation board (2 layers) is shown as reference below. 1st Layer 2nd Layer SILK Figure 27. Example of PCB www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 20/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Operational Notes 1. Reverse Connection of Power Supply Connecting the power supply in reverse polarity can damage the IC. Take precautions against reverse polarity when connecting the power supply, such as mounting an external diode between the power supply and the IC’s power supply pins. 2. Power Supply Lines Design the PCB layout pattern to provide low impedance supply lines. Separate the ground and supply lines of the digital and analog blocks to prevent noise in the ground and supply lines of the digital block from affecting the analog block. Furthermore, connect a capacitor to ground at all power supply pins. Consider the effect of temperature and aging on the capacitance value when using electrolytic capacitors. 3. Ground Voltage Ensure that no pins are at a voltage below that of the ground pin at any time, even during transient condition. 4. Ground Wiring Pattern When using both small-signal and large-current ground traces, the two ground traces should be routed separately but connected to a single ground at the reference point of the application board to avoid fluctuations in the small-signal ground caused by large currents. Also ensure that the ground traces of external components do not cause variations on the ground voltage. The ground lines must be as short and thick as possible to reduce line impedance. 5. Thermal Consideration Should by any chance the power dissipation rating be exceeded the rise in temperature of the chip may result in deterioration of the properties of the chip. The absolute maximum rating of the Pd stated in this specification is when the IC is mounted on a 70mm x 70mm x 1.6mm glass epoxy board. In case of exceeding this absolute maximum rating, increase the board size and copper area to prevent exceeding the Pd rating. 6. Recommended Operating Conditions These conditions represent a range within which the expected characteristics of the IC can be approximately obtained. The electrical characteristics are guaranteed under the conditions of each parameter. 7. Inrush Current When power is first supplied to the IC, it is possible that the internal logic may be unstable and inrush current may flow instantaneously due to the internal powering sequence and delays, especially if the IC has more than one power supply. Therefore, give special consideration to power coupling capacitance, power wiring, width of ground wiring, and routing of connections. 8. Operation Under Strong Electromagnetic Field Operating the IC in the presence of a strong electromagnetic field may cause the IC to malfunction. 9. Testing on Application Boards When testing the IC on an application board, connecting a capacitor directly to a low-impedance output pin may subject the IC to stress. Always discharge capacitors completely after each process or step. The IC’s power supply should always be turned off completely before connecting or removing it from the test setup during the inspection process. To prevent damage from static discharge, ground the IC during assembly and use similar precautions during transport and storage. 10. Inter-pin Short and Mounting Errors Ensure that the direction and position are correct when mounting the IC on the PCB. Incorrect mounting may result in damaging the IC. Avoid nearby pins being shorted to each other especially to ground, power supply and output pin. Inter-pin shorts could be due to many reasons such as metal particles, water droplets (in very humid environment) and unintentional solder bridge deposited in between pins during assembly to name a few. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 21/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX Operational Notes – continued 11. Unused Input Pins Input pins of an IC are often connected to the gate of a MOS transistor. The gate has extremely high impedance and extremely low capacitance. If left unconnected, the electric field from the outside can easily charge it. The small charge acquired in this way is enough to produce a significant effect on the conduction through the transistor and cause unexpected operation of the IC. So unless otherwise specified, unused input pins should be connected to the power supply or ground line. 12. Regarding the Input Pin of the IC This monolithic IC contains P+ isolation and P substrate layers between adjacent elements in order to keep them isolated. P-N junctions are formed at the intersection of the P layers with the N layers of other elements, creating a parasitic diode or transistor. For example (refer to figure below): When GND > Pin A and GND > Pin B, the P-N junction operates as a parasitic diode. When GND > Pin B, the P-N junction operates as a parasitic transistor. Parasitic diodes inevitably occur in the structure of the IC. The operation of parasitic diodes can result in mutual interference among circuits, operational faults, or physical damage. Therefore, conditions that cause these diodes to operate, such as applying a voltage lower than the GND voltage to an input pin (and thus to the P substrate) should be avoided. Figure 28. Example of monolithic IC structure 13. Ceramic Capacitor When using a ceramic capacitor, determine the dielectric constant considering the change of capacitance with temperature and the decrease in nominal capacitance due to DC bias and others. 14. Area of Safe Operation (ASO) Operate the IC such that the output voltage, output current, and power dissipation are all within the Area of Safe Operation (ASO). 15. Thermal Shutdown Circuit(TSD) This IC has a built-in thermal shutdown circuit that prevents heat damage to the IC. Normal operation should always be within the IC’s power dissipation rating. If however the rating is exceeded for a continued period, the junction temperature (Tj) will rise which will activate the TSD circuit that will turn OFF all output pins and latch. Note that the TSD circuit operates in a situation that exceeds the absolute maximum ratings and therefore, under no circumstances, should the TSD circuit be used in a set design or for any purpose other than protecting the IC from heat damage. 16. Over Current Protection Circuit (OCP) This IC incorporates an integrated overcurrent protection circuit that is activated when the load is shorted. This protection circuit is effective in preventing damage due to sudden and unexpected incidents. However, the IC should not be used in applications characterized by continuous operation or transitioning of the protection circuit. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 22/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX ●Ordering Information B D 7 7 5 Part Number 7 M W X - Package MWX : USON014X3020 E2 Packaging and forming specification E2: Embossed tape and reel ●Physical Dimension Tape and Reel Information ●Marking Diagram USON014X3020 (TOP VIEW) 1PIN MARK LOT Number Part Number Marking 1 2 3 4 5 6 7 8 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 23/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Datasheet BD7757MWX ●Revision History Date Revision Changes OCT.25.2013 NOV.07.2013 NOV.07.2013 NOV.07.2013 NOV.07.2013 NOV.07.2013 NOV.07.2013 NOV.07.2013 NOV.07.2013 NOV.07.2013 DEC.03.2014 DEC.03.2014 DEC.03.2014 DEC.03.2014 002 003 003 003 003 003 003 003 003 003 004 004 004 004 P14 / Modify Indication of FINH data A1D5->A1D4 P3 P8 P9 P12 /Modify Symbol P3 /Modify MIN Limit of MAX DUTY P10 /Modify the instruction of startup and shut down sequence P11 /Delete the (data=1) comment in table P12 / Delete the (data=1) comment in table P14 /Modify the instruction of Forced Torch (FINH) P15 /Modify the instruction of LED Short Protection, Thermal shutdown, and Battery UVLO P20 /Modify the instruction of Analog wire P21,22 /Modify Operation Notes P2 /Modify the instruction of Control2 and Control3 P10 /Modify the instruction of FLASH Action using Control2 or Control3 P16 /Modify Selection of Components Externally Connected Limit. P1 /Modify Operating Temperature Range www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 24/24 TSZ02201-00F1FC200020-1-2 03.DEC.2014 Rev.004 Notice Precaution on using ROHM Products 1. Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you (Note 1) intend to use our Products in devices requiring extremely high reliability (such as medical equipment , transport equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation depending on ambient temperature. When used in sealed area, confirm that it is the use in the range that does not exceed the maximum junction temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used on a surface-mount products, the flow soldering method must be used on a through hole mount products. If the flow soldering method is preferred on a surface-mount products, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice-PGA-E © 2015 ROHM Co., Ltd. All rights reserved. Rev.003 Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label A two-dimensional barcode printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since concerned goods might be fallen under listed items of export control prescribed by Foreign exchange and Foreign trade act, please consult with ROHM in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. 2. ROHM shall not have any obligations where the claims, actions or demands arising from the combination of the Products with other articles such as components, circuits, systems or external equipment (including software). 3. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the Products or the information contained in this document. Provided, however, that ROHM will not assert its intellectual property rights or other rights against you or your customers to the extent necessary to manufacture or sell products containing the Products, subject to the terms and conditions herein. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice-PGA-E © 2015 ROHM Co., Ltd. All rights reserved. Rev.003 Datasheet General Precaution 1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents. ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s representative. 3. The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or concerning such information. Notice – WE © 2015 ROHM Co., Ltd. All rights reserved. Rev.001
BD7757MWX-E2 价格&库存
很抱歉,暂时无法提供与“BD7757MWX-E2”相匹配的价格&库存,您可以联系我们找货
BD7757MWX-E2
    • 1+4.822331+0.62585
    • 50+3.9869150+0.51743
    • 100+3.47407100+0.45087
    • 300+3.12666300+0.40579
    • 500+3.06049500+0.39720
    • 1000+3.002591000+0.38968
    • 4000+2.969504000+0.38539
    库存:800
    BD7757MWX-E2
      库存:360
