BD80GA5WEFJ-E2
BD80GA5WEFJ-E2
    ROHM(罗姆)
    HTSOP-J8_4.9X3.9MM-EP
    IC REG LINEAR 8V 500MA 8HTSOP
BD80GA5WEFJ-E2 数据手册
Datasheet 500mA Variable / Fixed Output LDO Regulators BDxxGA5WEFJ ●General Description BDxxGA5WEFJ series devices are LDO regulators with an output current of 0.5A. The output accuracy is ±1% of the output voltage. Both fixed and variable output voltage devices are available. The output voltage of the variable output voltage device can be varied from 1.5 to 13.0V using external resistors. Various fixed output voltage devices that do not use external resistors are also available. It can be used for a wide range of digital appliance applications. It has a small package type: HTSOP-J8 (4.90mm x 6.00mm x 1.00mm). These devices have built in over current protection to protect the device when output is shorted, 0µA shutdown mode and thermal shutdown circuit to protect the device during over load conditions. These LDO regulators are usable with ceramic capacitors that enable a smaller layout and longer life. ●Features „ +/-1% output voltage accuracy „ Built-in Over Current Protection circuit (OCP) „ Built-in Thermal Shut Down circuit (TSD) „ Zero µA shutdown mode ●Package HTSOP-J8 (Typ.) (Typ.) (Max.) 4.90mm x 6.00mm x 1.00mm ●Key Specification „ Input Power Supply Voltage range: 4.5V to 14.0V „ Output voltage range(Variable type): 1.5V to 13.0V „ Output voltage(Fixed type): 1.5V/1.8V/2.5V/3.0V/3.3V 5.0V/6.0V/7.0V/8.0V/9.0V/10V/12V „ Output current: 0.5A(Max.) „ Shutdown current: 0μA(Typ.) „ Operating temperature range: -25℃ to +85℃ HTSOP-J8 ●Typical Application Circuit VCC VO CIN VCC R1 COUT FB EN GND FIN VO_S COUT EN R2 GND CIN,COUT : Ceramic Capacitor ○Product structure:Silicon monolithic integrated circuit FIN CIN,COUT : Ceramic Capacitor Fixed output voltage type Variable output voltage type www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・14・001 VO CIN ○This product is not designed protection against radioactive rays. 1/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Ordering Information B D x x Part Output Number voltage 00:Variable 15:1.5V 18:1.8V 25:2.5V 30:3.0V 33:3.3V 50:5.0V 60:6.0V 70:7.0V 80:8.0V 90:9.0V J0:10.0V J2:12.0V G A 5 W E J - Input voltage range Output Current G:15V A5:0.5A “W”:included EFJ:HTSOP-J8 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Shutdown mode F Package 2/19 E2 Packaging and forming specification E2:Emboss tape reel TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Block Diagram BD00GA5WEFJ(Variable output voltage type) VCC SOFT START VO Fig.1 Block Diagram ●Pin Configuration TOP VIEW VO VCC FB N.C. GND N.C. N.C. EN ●Pin Description Pin No. Pin name 1 VO 2 FB 3 GND 4 N.C. 5 EN 6 N.C. 7 N.C. 8 VCC Reverse FIN Pin Function Output pin Feedback pin GND pin No Connect (Connect to GND or leave OPEN) Enable pin No Connect (Connect to GND or leave OPEN) No Connect (Connect to GND or leave OPEN) Input pin Substrate(Connect to GND) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 3/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Block Diagram BDxxGA5WEFJ(Fixed output voltage type) VCC OCP SOFT START VO EN TSD VO_S GND Fig.2 Block Diagram ●Pin Configuration TOP VIEW VO VCC VO_S N.C. GND N.C. N.C. EN ●Pin Description Pin No. 1 2 3 4 5 6 7 8 Reverse Pin name VO VO_S GND N.C. EN N.C. N.C. VCC FIN Pin Function Output pin Output voltage monitor pin GND pin No Connect (Connect to GND or leave OPEN) Enable pin No Connect (Connect to GND or leave OPEN) No Connect (Connect to GND or leave OPEN) Input pin Substrate(Connect to GND) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 4/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Absolute Maximum Ratings (Ta=25℃) Parameter Power supply voltage EN voltage Power dissipation HTSOP-J8 Operating Temperature Range Storage Temperature Range Junction Temperature Symbol VCC VEN Ratings 15.0 *1 15.0 Unit V V Pd*2 2110 *2 mW Topr Tstg Tjmax -25 to +85 -55 to +150 +150 ℃ ℃ ℃ *1 Not to exceed Pd *2 Reduced by 16.9mW/℃ for each increase in Ta of 1℃ over 25℃. (when mounted on a board 70mm×70mm×1.6mm glass-epoxy board, two layer) ●Recommended Operating Ratings (Ta=25℃) Parameter Input power supply voltage EN voltage Output voltage setting range Output current Symbol VCC VEN VO IO Ratings Min. 4.5 0.0 1.5 0.0 Unit Max. 14.0 14.0 13.0 0.5 V V V A ●Electrical Characteristics (Unless otherwise noted, Ta=25℃, EN=3V, VCC=6V, R1=43kΩ, R2=8.2kΩ) Parameter Symbol Circuit current at shutdown mode Bias current Line regulation Load regulation Minimum dropout voltage1 Minimum dropout voltage2 Minimum dropout voltage3 Minimum dropout voltage4 Output reference voltage(Variable type) Output voltage(Fixed type) EN Low voltage EN High voltage EN Bias current ISD ICC Reg.I Reg IO VCO1 VCO2 VCO3 VCO4 VFB VO VEN (Low) VEN (High) IEN www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Min. Limits Typ. Max. -1 -1.5 0.792 VO×0.99 0 2.4 1 0 600 0.24 0.36 0.48 0.60 0.800 VO 3 5 900 1 1.5 0.36 0.54 0.72 0.90 0.808 VO×1.01 0.8 14.0 9 5/19 Unit µA µA % % V V V V V V V V µA Conditions VEN=0V, OFF mode VCC=( VO+0.9V )→14.0V IO=0→0.5A VCC=5V, IO=200mA VCC=5V, IO=300mA VCC=5V, IO=400mA VCC=5V, IO=500mA IO=0A IO=0A TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Typical Performance Curves (Unless otherwise noted, Ta=25℃, EN=3V, VCC=6V, R1=43kΩ, R2=8.2kΩ) VO VO IO IO Fig.3 Transient Response (0→0.5A) Co=1µF Fig.4 Transient Response (0.5→0A) Co=1µF VEN VEN VCC VCC VO VO Fig.5 Input sequence 1 Co=1µF www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Fig.6 OFF sequence 1 Co=1µF 6/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ VEN VEN VCC VCC VO VO Fig.8 OFF sequence 2 Co=1µF VO[V] ICC[µA] Fig.7 Input sequence 2 Co=1µF Ta[℃] Ta[℃] Fig.9 Ta-VO (IO=0mA) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Fig.10 Ta-Icc 7/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet IEN[µA] ISD [µA] BDxxGA5WEFJ Ta[℃] Ta[℃] Fig.11 Ta-ISD (VEN=0V) VO[V] ISD[µA] Fig.12 Ta-IEN IO[A] VCC [V] Fig.13 IO-VO Fig.14 VCC-ISD (VEN=0V) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 8/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet VO[V] VO[V] BDxxGA5WEFJ VCC[V] Ta[℃] Fig.15 VCC-VO (IO=0mA) VVo[V] O[V] Fig.16 TSD (IO=0mA) IO[A] Ta[℃] Fig.17 OCP www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Fig.18 Minimum dropout Voltage1 (VCC=5V、IO=-0.5A) 9/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ 900 800 ICC [µA] 700 600 500 400 0 0.1 0.2 0.3 0.4 0.5 IO [A] IO[A] Fig.20 IO-ICC PSRR[dB] Vdrop[V] Fig.19 ESR condencer IO[A] Fig.22 Minimum dropout Voltage 2 (VCC=4.5V、Ta=25℃) Fig.21 PSRR (IO=0mA) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 10/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet Vdrop[V] Vdrop[V] BDxxGA5WEFJ IO[A] IO[A] Fig.24 Minimum dropout Voltage 4 (VCC=8V、Ta=25℃) Vdrop[V] Vdrop[V] Fig.23 Minimum dropout Voltage 3 (VCC=6V、Ta=25℃) IO[A] IO[A] Fig.26 Minimum dropout Voltage 6 (VCC=12V、Ta=25℃) Fig.25 Minimum dropout Voltage 5 (VCC=10V、Ta=25℃) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 11/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Power Dissipation ◎HTSOP-J8 4.0 Power Dissipation :Pd [W] ⑤3.76W Measurement condition: mounted on a ROHM board Substrate size: 70mm × 70mm × 1.6mm (Substrate with thermal via) ・Solder the thermal pad to Ground 3.0 ① IC only θj-a=249.5℃/W ② 1-layer (copper foil are :0mm×0mm) θj-a=153.2℃/W ③ 2-layer (copper foil are :15mm×15m) θj-a=113.6℃/W ④ 2-layer (copper foil are :70mm×70mm) θj-a=59.2℃/W ⑤ 4-layer (copper foil are :70mm×70m) θj-a=33.3℃/W ④2.11W 2.0 ③1.10W 1.0 ②0.82W ①0.50W 0 0 25 50 75 100 125 150 Ambient 周囲温度:Ta Temperature [℃] :Ta [℃] Thermal design should ensure operation within the following conditions. Note that the temperatures listed are the allowed temperature limits and thermal design should allow sufficient margin beyond these limits. 1. Ambient temperature Ta can be no higher than 85℃. 2. Chip junction temperature (Tj) can be no higher than 150℃. Chip junction temperature can be determined as follows: Calculation based on ambient temperature (Ta) Tj=Ta+θj-a×W <Reference values> θj-a: HTSOP-J8 153.2℃/W 1-layer substrate (copper foil density 0mm×0mm) 113.6℃/W 2-layer substrate (copper foil density 15mm×15mm) 59.2℃/W 2-layer substrate (copper foil density 70mm×70mm) 4-layer substrate (copper foil density 70mm×70mm) 33.3℃/W Substrate size: 70mm×70mm×1.6mm (substrate with thermal Most of the heat loss that occurs in the BDxxGA5WEFJ series is generated from the output Pch FET. Power loss is determined by the total VCC-VO voltage and output current. Be sure to confirm the system input and output voltage and the output current conditions in relation to the heat dissipation characteristics of the VCC and VO in the design. Bearing in mind that heat dissipation may vary substantially depending on the substrate employed (due to the power package incorporated in the BDxxGA5WEFJ make certain to factor conditions such as substrate size into the thermal design. Power consumption [W] = Input voltage (VCC) - Output voltage (VO) ×IO (Ave) Example) Where VCC=5.0V, VO=3.3V, IO(Ave) = 0.1A, Power consumption [W] = 5.0V - 3.3V ×0.1A =0.17[W] www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 12/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Input-to-Output Capacitor It is recommended that a capacitor (over 1uF) is placed near pins between the input pin and GND as well as the output pin and GND. A capacitor, between input pin and GND, is valid when the power supply impedance is high or trace is long. Also, as for the capacitor between the output pin and GND, the greater the capacitance, the more sustainable the line regulation will be and the capacitor will make improvements of characteristics depending on the load. However, please check the actual functionality of this part by mounting it on a board for the actual application. Ceramic capacitors usually have different, thermal and equivalent series resistance characteristics, and moreover capacitance decreases gradually in use. For additional details, please check with the manufacturer, and select the best ceramic capacitor for your application. 10 Rated Voltage:10V B1 characteristics Rated Voltage:10V B characteristics 0 Capacitance Change [%] -10 Rated Voltage:6.3V B characteristics -20 -30 -40 -50 Rated Voltage:10V F characteristics -60 Rated Voltage:4V X6S characteristics -70 -80 -90 -100 0 1 2 3 4 DC Bias Voltage [V] Ceramic capacitor capacity – DC bias characteristics (Characteristics example) ●Equivalent Series Resistance ESR (ceramic capacitor etc.) 10.00 1.00 Safety Area ESR [Ω] To prevent oscillations, please attach a capacitor between VO and GND. Capacitors usually have ESR (Equivalent Series Resistance). Operation will be stable in the ESR-IO range shown to the right. Ceramic, tantalum and electrolytic Capacitors have different ESR values, so please ensure that you are using a capacitor that operates in the stable operating region shown on the right. Finally, please evaluate in the actual application. 0.10 CO=1μF 0.01 0 0.1 0.2 0.3 0.4 0.5 Io [A] ESR – IO characteristics www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 13/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Evaluation Board Circuit U1 C3 C7 1 VCC VO 8 C2 C6 R1 C5 2 FB N.C 7 GND N.C 6 C1 R2 Vcc GND 3 SW1 VO 4 N.C. EN EN 5 FIN ●Evaluation Board Parts List Designation R1 R2 R3 R4 R5 R6 C1 C2 C3 Value 43kΩ 8.2kΩ ‐ ‐ ‐ ‐ 1μF ‐ ‐ Part No. MCR01PZPZF4302 MCR01PZPZF8201 ‐ ‐ ‐ ‐ CM105B105K16A ‐ ‐ Company ROHM ROHM ‐ ‐ ‐ ‐ KYOCERA Designation C4 C5 C6 C7 C8 C9 C10 U1 U2 Value ‐ 1μF Part No. ‐ CM105B105K16A Company ‐ KYOCERA ‐ ‐ ‐ ‐ ‐ ‐ ‐ ‐ ‐ ‐ BD00GA5WEFJ ‐ ‐ ‐ ‐ ‐ ROHM ‐ ●Board Layout EN GND CIN VCC ( VIN ) R1 R2 COUT VO PCB layout considerations: ・Input capacitor CIN connected to VCC (Vin) should be placed as close to VCC(VIN) pin as possible. Output capacitor COUT also should be placed as close to IC pin as possible. In case the part is connected to inner layer GND plane, please use several through holes. ・FB pin has comparatively high impedance and can be affected by noise, so stray capacitance should be as small as possible. Please take care of this during layout. ・Please make GND pattern wide enough to handle thermal dissipation. ・For output voltage setting (BD00GA5WEFJ) Output voltage can be set by FB pin voltage(0.800V typ.)and external resistance R1, R2. VO = VFB× R1+R2 R2 (The use of resistors with R1+R2=1k to 90k is recommended) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 14/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●I/O Equivalent Circuits (Vairable type) 8pin (VCC) / 1pin (VO) 8pin (VCC) 2pin (FB) 5pin (EN) 2pin (FB) 5pin (EN) 2MΩ 1MΩ 1pin (VO) ●I/O Equivalent Circuits (Fixed type) 8pin (VCC) / 1pin (VO) 2pin (VO_S) 5pin (EN) 8pin (VCC) 5pin (EN) 2pin (VO_S) 2MΩ 1MΩ 1pin (VO) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 15/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Operational Notes (1) Absolute maximum ratings An excess in the absolute maximum ratings, such as supply voltage, temperature range of operating conditions, etc., can break down the device, thus making it impossible to identify the damage mode, such as a short circuit or an open circuit. If there is any possibility of exposure over the rated values, please consider adding circuit protection devices such as fuses. (2) Connecting the power supply connector backward Connecting of the power supply in reverse polarity can damage the IC. Take precautions when connecting the power supply lines. An external direction diode can be added. (3) Power supply lines Design the PCB layout pattern to provide low impedance GND and supply lines. To obtain a low noise ground and supply line, separate the ground section and supply lines of the digital and analog blocks. Furthermore, for all power supply terminals to ICs, connect a capacitor between the power supply and GND terminal. When using electrolytic capacitors in a circuit, note that capacitance values are reduced at low temperatures and over time. (4) GND voltage The potential of the GND pin must be minimum potential under all operating conditions. (5) Thermal design Use a thermal design that allows for a sufficient margin in light of the power dissipation (Pd) in actual operating conditions. (6). Inter-pin shorts and mounting errors Use caution when positioning the IC for mounting on printed circuit boards. The IC may be damaged if there is any connection error or if pins are shorted together. (7). Actions in strong electromagnetic field Use caution when using the IC in the presence of a strong electromagnetic field as doing so may cause the IC to malfunction. (8). ASO When using the IC, set the output transistor so that it does not exceed absolute maximum ratings or ASO. (9). Thermal shutdown circuit The IC incorporates a built-in thermal shutdown circuit (TSD circuit). The thermal shutdown circuit (TSD circuit) is designed only to shut the IC off to prevent thermal runaway. It is not designed to protect the IC or guarantee its operation. Do not continue to use the IC after operating this circuit or use the IC in an environment where the operation of this circuit is assumed. BDxxGA5WEFJ TSD ON Temperature[℃] (typ.) 175 Hysteresis Temperature [℃] 15 (typ.) (10). Testing on application boards When testing the IC on an application board, connecting a capacitor to a pin with low impedance subjects the IC to stress. Always discharge capacitors after each process or step. Always turn the IC’s power supply off before connecting it to or removing it from a jig or fixture during the inspection process. Ground the IC during assembly steps as an antistatic measure. Use similar precaution when transporting or storing the IC. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 16/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ (11). Regarding input pin of the IC This monolithic IC contains P+ isolation and P substrate layers between adjacent elements in order to keep them isolated.P-N junctions are formed at the intersection of these P layers with the N layers of other elements, creating a parasitic diode or transistor. For example, the relation between each potential is as follows: When GND > Pin A and GND > Pin B, the P-N junction operates as a parasitic diode. When GND > Pin B, the P-N junction operates as a parasitic transistor. Parasitic diodes can occur inevitable in the structure of the IC. The operation of parasitic diodes can result in mutual interference among circuits, operational faults, or physical damage. Accordingly, methods by which parasitic diodes operate, such as applying a voltage that is lower than the GND (P substrate) voltage to an input pin, should not be used. Resistor Transistor (NPN) Pin A Pin B C B Pin B E Pin A N N P + N P P + N P + P Parasitic element P substrate Parasitic element GND B N P N P substrate Parasitic element GND C + GND E Parasitic element Other adjacent elements GND (12). Ground Wiring Pattern. When using both small signal and large current GND patterns, it is recommended to isolate the two ground patterns, placing a single ground point at the ground potential of application so that the pattern wiring resistance and voltage variations caused by large currents do not cause variations in the small signal ground voltage. Be careful not to change the GND wiring pattern of any external components, either. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 17/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Physical Dimension Tape and Reel Information HTSOP-J8 +6° 4° −4° (2.4) 3.9±0.1 6.0±0.2 8 7 6 5 1 1.05±0.2 (3.2) 0.65±0.15 4.9±0.1 (MAX 5.25 include BURR) Tape Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 2 3 4 1PIN MARK +0.05 0.17 -0.03 1.0MAX 0.545 S 0.08±0.08 0.85±0.05 1.27 +0.05 0.42 -0.04 0.08 M 0.08 S 1pin (Unit : mm) Reel Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. ●Marking Diagram HTSOP-J8 (TOP VIEW) Part Number Marking x x G A 5 W LOT Number 1PIN MARK www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 18/19 xx 00 15 18 25 30 33 50 60 70 80 90 J0 J2 Product Name BD00GA5WEFJ BD15GA5WEFJ BD18GA5WEFJ BD25GA5WEFJ BD30GA5WEFJ BD33GA5WEFJ BD50GA5WEFJ BD60GA5WEFJ BD70GA5WEFJ BD80GA5WEFJ BD90GA5WEFJ BDJ0GA5WEFJ BDJ2GA5WEFJ TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet BDxxGA5WEFJ ●Revision History Date Revision 23.July.2012 7.Feb.2013 001 002 Changes New Release The description was modified. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 19/19 TSZ02201-0R6R0A600190-1-2 7.Feb.2013 Rev.002 Datasheet Notice Precaution on using ROHM Products 1. Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you (Note 1) , transport intend to use our Products in devices requiring extremely high reliability (such as medical equipment equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation (Pd) depending on Ambient temperature (Ta). When used in sealed area, confirm the actual ambient temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label QR code printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act, please consult with ROHM representative in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. ROHM shall not be in any way responsible or liable for infringement of any intellectual property rights or other damages arising from use of such information or data.: 2. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the information contained in this document. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet General Precaution 1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents. ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s representative. 3. The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or concerning such information. Notice – WE © 2014 ROHM Co., Ltd. All rights reserved. Rev.001
BD80GA5WEFJ-E2 价格&库存
很抱歉,暂时无法提供与“BD80GA5WEFJ-E2”相匹配的价格&库存,您可以联系我们找货
BD80GA5WEFJ-E2
    • 1+1.257191+0.15190
    • 10+1.2247410+0.14798
    • 50+1.2004150+0.14504
    • 100+1.17608100+0.14210
    • 500+1.17608500+0.14210
    • 1000+1.167971000+0.14112
    • 2000+1.167972000+0.14112
    • 4000+1.167974000+0.14112
    库存:95
