Datasheet
Automotive IPD Series
8ch Low Side Switch
BD8LD650EFV-C
General Description
Key Specifications
BD8LD650EFV-C is an 8-channel SPI-input low side
switch for automotive and industrial application. It has
built-in open load detection function, short ground
detection function, over current protection function,
thermal shutdown function, and active clamp function.
Features
Input Voltage Range VDD:
4.0 V to 5.5 V
Input Voltage Range VDDIO:
3.0 V to 5.5 V
On State Resistance:
650 mΩ (Typ)
Over Current Threshold Value:
0.5 A/1.0 A (Min)
Active Clamp Energy:
125 mJ
Operating Temperature Range Tj:-40 °C to +150 °C
Package
◼ AEC-Q100 Qualified(Note 1)
◼ Monolithic Power Management IC with Control Block
(CMOS) and a Power MOSFET Mounted on a Single
Chip
◼ Channel Control/error can be Detected by 16 bit SPI
Commands.
◼ Built-in Open Load Detection Function (OLD)
◼ Built-in Short Ground Detection Function (SGD)
◼ Built-in Over Current Protection Function (OCP)
◼ Built-in Thermal Shutdown Function(TSD)
◼ Built-in Active Clamp Function
◼ Built-in Synchro Mode
◼ Built-in Limp Home Mode
◼ Surface-mount HTSSOP-B20 Packaging
W (Typ) x D (Typ) x H (Max)
6.5 mm x 6.4 mm x 1.0 mm
HTSSOP-B20
HTSSOP-B20
(Note 1) Grade1
Application
◼ Driving Resistive and Inductive Load
Typical Application Circuit
VDDIO
VDD
Load8
Load7
Load6
Load5
Load4
VDD
Load3
VDDIO
Load2
CVDD
Load1
CVDDIO
VBAT
OUT1
RIDLE
IDLE
RIN21
IN21
I/O
OUT2
Control Logic
OUT3
RIN43
RIN65
IN43
IN65
OUT4
UVLO
I/O
(IDLE, IN,
Limp Home)
OUT5
Mode
Control
OUT6
Limp
Home
MCU
RCSB
Input
Register
CSB
Control,
Diagnostic
and
protective
Functions
OUT7
OCP
OUT8
TSD
UVLO
RSCLK
RSI
RSO
SCLK
SI
I/O
(SPI)
SO
SPI
Control
OLD
OFD
SGD
Diagnosis
Register
Gate
Driver
Active
Clamp
COUT1
COUT2
COUT3
COUT4
COUT5
COUT6
COUT7
COUT8
GND
〇Product structure : Silicon integrated circuit
www.rohm.com
© 2022 ROHM Co., Ltd. All rights reserved.
TSZ22111 • 14 • 001
〇This product has no designed protection against radioactive rays.
1/48
TSZ02201-0G5G1G400140-1-2
03.Aug.2023 Rev.002
BD8LD650EFV-C
Contents
General Description ........................................................................................................................................................................ 1
Features.......................................................................................................................................................................................... 1
Application ...................................................................................................................................................................................... 1
Key Specifications .......................................................................................................................................................................... 1
Package .......................................................................................................................................................................................... 1
Typical Application Circuit ............................................................................................................................................................... 1
Contents ......................................................................................................................................................................................... 2
Pin Configuration ............................................................................................................................................................................ 3
Pin Descriptions .............................................................................................................................................................................. 3
Definition ......................................................................................................................................................................................... 4
Block Diagram ................................................................................................................................................................................ 4
Absolute Maximum Ratings ............................................................................................................................................................ 5
Thermal Resistance ........................................................................................................................................................................ 6
Recommended Operating Conditions ........................................................................................................................................... 10
Electrical Characteristics............................................................................................................................................................... 10
Typical Performance Curves ......................................................................................................................................................... 12
Measurement Circuit ..................................................................................................................................................................... 23
Timing Chart ................................................................................................................................................................................. 25
Synchro Mode............................................................................................................................................................................... 27
Limp Home Mode ......................................................................................................................................................................... 28
SPI Specification........................................................................................................................................................................... 29
Register Map ................................................................................................................................................................................ 33
Over Current Protection Function ................................................................................................................................................. 35
Thermal Shutdown Function ......................................................................................................................................................... 36
Open Load Detection (OLD) ......................................................................................................................................................... 37
Output Overhead Fault Detection Function (OFD) ........................................................................................................................ 38
Short Ground Detection (SGD) ..................................................................................................................................................... 39
Application Example ..................................................................................................................................................................... 41
Selection of Components Externally Connected ........................................................................................................................... 41
I/O Equivalence Circuits................................................................................................................................................................ 42
Operational Notes ......................................................................................................................................................................... 43
Ordering Information ..................................................................................................................................................................... 46
Marking Diagram .......................................................................................................................................................................... 46
Physical Dimension and Packing Information ............................................................................................................................... 47
Revision History ............................................................................................................................................................................ 48
www.rohm.com
TSZ22111 • 15 • 001
2/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Pin Configuration
(TOP VIEW)
IDLE
1
VDDIO
CSB
2
19
VDD
SCLK
3
18
IN21
SI
4
17
IN43
SO
5
16
IN65
GND
6
15
GND
OUT1
7
14
OUT3
OUT2
8
13
OUT4
OUT5
9
12
OUT7
OUT6
10
11
OUT8
EXP-PAD
Pin Descriptions
Pin No.
Pin Name
1
IDLE
2
CSB
3
SCLK
4
SI
5
SO
Function
Limp home mode control
This pin is connected to GND via an internal pull-down resistor.
SPI enable
This pin is connected to VDDIO via an internal pull-up resistor.
Serial clock input
Serial data input
Serial data output
6
GND
GND
7
OUT1
ch1 output
8
OUT2
ch2 output
9
OUT5
ch5 output
10
OUT6
ch6 output
11
OUT8
ch8 output
12
OUT7
ch7 output
13
OUT4
ch4 output
14
OUT3
ch3 output
15
GND
16
IN65
17
IN43
18
IN21
GND
ch5, ch6 control(Note 1)
ch3, ch4 control(Note 1)
ch1, ch2 control(Note 1)
Analog power supply
19
VDD
VDDIO
EXP-PAD
Digital power supply
Be sure to connect EXP-PAD to GND.
(Note 1) Controlled channels can be changed by accessing DIRCTRL register from the SPI.
www.rohm.com
TSZ22111 • 15 • 001
3/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Definition
IVDDIO
VDDIO
IVDD
VDD
IIDLE
VIDLE
ICSB
VCSB
ISCLK
VSCLK
ISI
VSI
ISO
VSO
IIN21
VIN21
IIN43
VIN43
IIN65
VIN65
VDDIO
OUT1
VDD
OUT2
IOUT1
IOUT6
OUT6
SI
IOUT7
OUT7
SO
OUT8
IN21
VOUT4
IOUT5
OUT5
SCLK
VOUT3
IOUT4
OUT4
CSB
VOUT2
IOUT3
OUT3
IDLE
VOUT1
IOUT2
VOUT5
VOUT6
VOUT7
IOUT8
VOUT8
IN43
IN65
GND
Block Diagram
VDDIO
VDD
OUT1
I/O
Control Logic
OUT2
IN21
OUT3
IN43
IN65
UVLO
I/O
(IDLE, IN,
Limp Home)
IDLE
Limp
Home
CSB
SCLK
SI
OUT4
Mode
Control
UVLO
I/O
(SPI)
SO
Input
Register
OUT5
Control,
Diagnostic
and
protective
Functions
OUT6
OCD
OUT7
TSD
OUT8
SPI
Control
OLD
Diagnosis
Register
Gate
Driver
Active
Clamp
GND
www.rohm.com
TSZ22111 • 15 • 001
4/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Absolute Maximum Ratings (Tj = 25 °C)
Parameter
VDDIO, VDD Power Supply Voltage
Symbol
Rating
Unit
VDDIO, VDD
-0.3 to +7
V
Output Voltage (Power MOS Output)
VOUT1-8
Output Current (Power MOS Output)
IOUT1-8
(Internal Limit)(Note 2)
A
VSO
-0.3 to +7
V
Output Voltage (SPI)
Input Voltage (IDLE)
-0.3 to (Internal
Limit)(Note 1)
V
VIDLE
-0.3 to +7
V
Input Voltage (SPI)
VCSB, VSCLK, VSI
-0.3 to +7
V
Input Voltage (IN65, IN43, IN21)
VIN65, VIN43, VIN21
-0.3 to +7
V
Tstg
-55 to +150
°C
Tjmax
150
°C
EAS1-8(25 °C)
125
mJ
EAS1-8(150 °C)
25
mJ
ES, AS1-8(25 °C)
57
mJ
ES, AS1-8(150 °C)
19
mJ
EAR(125 °C)
12
mJ
ES, AR(125 °C)
9
mJ
Storage Temperature Range
Maximum Junction Temperature
Active Clamp Energy (Single Pulse)
Tj(START) = 25 °C, IOUT1-8(START) = 0.4 A
Active Clamp Energy (Single Pulse)(Note 3)
Tj(START) = 150 °C, IOUT1-8(START) = 0.4 A
Tj(START) = 25 °C, IOUT1-8(START) = 0.8 A, Synchro Mode
Tj(START) = 150 °C, IOUT1-8(START) = 0.8 A, Synchro Mode
Active Clamp Energy (Repetitive)(Note 3)(Note 4)
Tj(START) = 125 °C, IOUT(START) = 0.2 A
Tj(START) = 125 °C, IOUT(START) = 0.4 A, Synchro Mode
(Note 1) Limited by the active clamp function.
(Note 2) Limited by the over current protection function. The over current detection value can be adjusted in two levels.
(Note 3) Not 100 % are tested.
(Note 4) 2M cycles, All channel input.
Caution 1: Operating the IC over the absolute maximum ratings may damage the IC. The damage can either be a short circuit between pins or an open circuit
between pins and the internal circuitry. Therefore, it is important to consider circuit protection measures, such as adding a fuse, in case the IC is
operated over the absolute maximum ratings.
Caution 2: Should by any chance the maximum junction temperature rating be exceeded the rise in temperature of the chip may result in deterioration of the
properties of the chip. In case of exceeding this absolute maximum rating, design a PCB with thermal resistance taken into consideration by
increasing board size and copper area so as not to exceed the maximum junction temperature rating.
Caution 3: When IC is turned off with an inductive load, reverse energy has to be dissipated in the IC. This energy can be calculated by the following equation:
1
𝑉𝐵𝐴𝑇
𝐸𝐿 = 𝐿𝐼𝑂𝑈𝑇(𝑆𝑇𝐴𝑅𝑇) 2 × (1 −
2
𝑉𝐵𝐴𝑇 − 𝑉𝑂𝑈𝑇(𝐶𝐿)
Where:
L is the inductance of the inductive load.
IOUT(START) is the output current at the time of turning off.
VOUT(CL) is the output clamp voltage.
The IC integrates the active clamp function to internally absorb the reverse energy EL which is generated when the inductive load is turned off.
When the active clamp operates, the thermal shutdown function does not work. Decide a load so that the reverse energy E L is active clamp
energy EAS (Figure 1.), ES,AS (Figure 2.) or under when inductive load is used.
10000
10000
Tj = 25 °C
Tj = 150 °C
Tj = 25 °C
Tj = 150 °C
1000
ES, AS1~8 [mJ]
EAS1~8 [mJ]
1000
100
10
100
10
1
1
0.2
0.3
0.4
0.5
0.6
Output Current (Start): IOUT(START) [A]
Figure 1. Active Clamp Energy (Single Pulse) vs
Output Current
www.rohm.com
TSZ22111 • 15 • 001
0.2
0.4
0.6
0.8
1.0
1.2
Figure 2. Active Clamp Energy (Single Pulse)
Synchro Mode vs Output Current
5/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Thermal Resistance (Note 1)
Parameter
Symbol
Typ
Unit
Condition
96.6
°C/W
1s(Note 2)
35.1
°C/W
2s(Note 3)
24.5
°C/W
2s2p(Note 4)
HTSSOP-B20
Between Junction and Surroundings Temperature
Thermal Resistance
θJA
(Note 1) The thermal impedance is based on JESD51-2A(Still-Air) standard.
(Note 2) JESD51-3 standard FR4 114.3 mm x 76.2 mm x 1.57 mm 1-layer (1s)
(Top copper foil: ROHM recommended Footprint + wiring to measure, 2 oz. copper. )
(Note 3) JESD51-5 standard FR4 114.3 mm x 76.2 mm x 1.60 mm 2-layers (2s).
(Top copper foil: ROHM recommended Footprint + wiring to measure/
Copper foil area on the reverse side of PCB: 74.2 mm × 74.2 mm, copper (top & reverse side) 2 oz )
(Note 4) JESD51-5/-7 standard FR4 114.3 mm x 76.2 mm x 1.60 mm 4-layers (2s2p)
2 inner layers and copper foil area on the reverse side of PCB: 74.2 mm × 74.2 mm, copper (top & reverse side/inner layers) 2 oz./1 oz.)
■ PCB Layout 1 layer (1s)
Footprint
600 mm2
100 mm2
1200 mm2
Figure 3. PCB Layout 1 Layer (1s)
Dimension
Value
Board Finish Thickness
1.57 mm ± 10 %
Board Dimension
76.2 mm x 114.3 mm
Board Material
FR4
Copper Thickness (Top Layer)
0.070 mm (Cu: 2 oz)
Copper Foil Area Dimension
Footprint/100 mm2/600 mm2/1200 mm2
www.rohm.com
TSZ22111 • 15 • 001
6/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Thermal Resistance – continued
■ PCB Layout 2 layers (2s)
Top Layer
Bottom Layer
Top Layer
Bottom Layer
Via
Isolation Clearance Diameter: ≥0.6 mm
Cross Section
Figure 4. PCB-layout 2-layer (2s)
Dimension
Value
1.60 mm ± 10 %
Board Dimension
76.2 mm x 114.3 mm
Board Material
FR4
Copper Thickness (Top/Bottom Layers)
0.070 mm (Cu +Plating)
Thermal Vias Separation/Diameter
1.2 mm/0.3 mm
www.rohm.com
TSZ22111 • 15 • 001
7/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
■ PCB Layout 4 layers (2s2p)
TOP Layer
2nd/Bottom Layers
3rd Layer
Top Layer
2nd Layer
3rd Layer
Bottom Layer
Via
Cross Section
Figure 5. PCB-layout 4-layer (2s2p)
Dimension
Value
1.60 mm ± 10 %
Board Dimension
76.2 mm x 114.3 mm
Board Material
FR4
Copper Thickness (Inner Layers)
0.035 mm
1.2 mm/0.3 mm
www.rohm.com
TSZ22111 • 15 • 001
8/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
■ Transient Thermal Resistance (Single Pulse)
1000
θJA [ºC/W]
100
10
1
1s footprint
2s
2s2p
0.1
0.0001 0.001
0.01
0.1
1
Pulse Time [s]
10
100
1000
Figure 6. Transient Thermal Resistance
■ Thermal Resistance (θJA vs Copper Foil area 1s)
120
100
θJA [ºC/W]
80
60
40
400
600
800
1000
2
Copper Fiol Area 1s [mm ]
1200
Figure 7. Thermal Resistance
www.rohm.com
TSZ22111 • 15 • 001
9/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Parameter
Symbol
Min
Typ
Max
Unit
VDD
4.0
5.0
5.5
V
VDDIO Power Supply Voltage
VDDIO
3.0
5.0
5.5
V
Topr
-40
+25
+150
°C
(Unless otherwise specified VDD = 4.0 V to 5.5 V, VDDIO = 3.0 V to 5.5 V, Tj = -40 °C to +150 °C)
Parameter
Symbol
Min
Typ
Max
Unit
IVDDS
µA
VDDIO Standby Current
IVDDIOS
µA
VDD Operating Current
IVDD
1.2
2.4
mA
VDDIO Operating Current
IVDDIO
30
150
µA
VDD Power On Reset Voltage
VPORA
4.0
V
VDDIO Power On Reset Voltage
VPORD
2.7
V
VDDIO
× 0.2
V
Conditions
[Power Supply]
VDD Standby Current
VIDLE = 0 V
VIN21, VIN43, VIN65 = 0 V
VIDLE = 0 V
VIDLE = 5 V
VIN21, VIN43, VIN65 = 5 V
OUTCTRLn[7:0] = FF(Note 1)
VIDLE = 5 V
[Input (IDLE, CSB, SCLK, SI, IN21, IN43, IN65)]
Low Level Input Voltage
VIL
High Level Input Voltage
VIH
Input Hysteresis Voltage
VDDIO
V
VHYS
VDDIO
× 0.7
0.25
0.45
0.65
V
IIL1
-10
µA
IIL2
-100
-50
-25
µA
IIH1
25
50
100
µA
IIH2
-10
µA
VIDLE, VSCLK, VSI, VIN21, VIN43,
VIN65 = 0 V
VCSB = 0 V
VIN65 = 5 V
VCSB = 5 V
Low Level Output Voltage
VOL
V
ISO = 1 mA
VOH
V
ISO = -1 mA
Serial Out Output Leakage Current
ISO
0.15
VDDIO –
0.15
High Level Output Voltage
VDDIO –
0.45
-5
+5
µA
VSO = 0 V / 5.5 V
650
800
mΩ
1200
1500
mΩ
µA
VDD = 5 V
IOUT = 0.2 A, Tj = 25 °C
VDD = 5 V
IOUT = 0.2 A, Tj = 150 °C
VOUT = 30 V, Tj = 25 °C
0.15
2.00
µA
VOUT = 30 V, Tj = 150 °C
37
41
45
V
IOUT = 1 mA, Output Off
Low Level Input Current 1
(except CSB)
Low Level Input Current 2 (CSB)
High Level Input Current 1
(except CSB)
High Level Input Current 2 (CSB)
[Output (SO)]
[Power MOS Output]
Output On Resistance
Output Clamp Voltage
RDS(ON)
IOUT(L)
VCL
(Note 1) Set by SPI control. Details are given in "Register Map". n represents the channel number.
www.rohm.com
TSZ22111 • 15 • 001
10/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Electrical Characteristics – continued
(Unless otherwise specified, VDD = 4.0 V to 5.5 V, VDDIO = 3.0 V to 5.5 V, Tj = -40 °C to +150 °C)
Parameter
Symbol
Min
Typ
Max
Unit
Conditions
Turn-On Time 1
tON1
50
µs
Turn-Off Time 1
tOFF1
50
µs
RL = 60 Ω, VIDLE = 5 V, VBAT =
12 V, SRCTRLn[1:0] = 00(Note 1)
Turn-On Time 2
tON2
200
µs
Turn-Off Time 2
tOFF2
200
µs
Turn-On Time 3
tON3
25
µs
Turn-Off Time 3
tOFF3
25
µs
Slew Rate (On) 1
SRON1
0.50
1.00
1.50
V/µs
Slew Rate (Off) 1
SROFF1
0.50
1.00
1.50
V/µs
Slew Rate (On) 2
SRON2
0.10
0.30
0.50
V/µs
Slew Rate (Off) 2
SROFF2
0.10
0.30
0.50
V/µs
Slew Rate (On) 3
SRON3
1.35
2.25
3.15
V/µs
Slew Rate (Off) 3
SROFF3
1.35
2.25
3.15
V/µs
fPWM
5
kHz
Over Current Threshold Value 1
IOCP1
0.50
0.85
1.30
A
OCPCTRLn = '0'(Note 1)
Over Current Threshold Value 2
IOCP2
1.00
1.70
2.40
A
OCPCTRLn = '1'(Note 1)
Output Stop Time at OCP Detection
tOCP_OFF
0.4
1.0
1.9
ms
OCPCTRLn = '0' / '1'(Note 1)
Over Current Detection Time
tOCP_DET
2.3
µs
Open Load Detect Voltage
VOLD_DET
1.2
2.2
3.2
V
Open Load Release Voltage
VOLD_REL
1.6
2.6
3.6
V
DIAG_OLD/OFDn = '1'(Note 1)
Output Off
IOLD
15
40
90
µA
VOUT = 12 V
Output On
[Power MOS Output]
PWM Output Range
12 V, SRCTRLn[1:0] = 10(Note 1)
12 V, SRCTRLn[1:0] = 01(Note 1)
[Over Current Protection Function]
[Open Load Detection Function]
Output Sink Current
[Output Overhead Fault Detection Function]
Output Overhead Detect Voltage
VOFD_DET
1.6
2.6
3.6
V
Output Overhead Release Voltage
VOFD_REL
1.2
2.2
3.2
V
Short Ground Detect Voltage
VSGD_DET
0.3
1.0
1.5
V
Short Ground Release Voltage
VSGD_REL
0.5
1.4
1.9
V
DIAG_SGDn = '1'(Note 1)
Output Off
ISGD
-40
-25
-10
µA
VOUT = 0 V
TTSD_DET
150
175
200
°C
TTSD_HYS
15
°C
[Short Ground Detection Function]
Output Source Current
[Thermal Shutdown Function]
Detect Temperature(Note 2)
Hysteresis
Temperature(Note 2)
(Note 2) Not 100 % are tested.
Switching Time Measurement Waveform
Control by IN21 / IN43/ IN65
Control by SPI
SRON = (VBAT * 0.8) / TFALL
SROFF = (VBAT * 0.8) / TRISE
[V]
[V]
IN21 / IN43
IN65
CSB
for SPI
[t]
tONn
[V]
tOFFn
tONn
[V]
VBAT
tOFFn
VBAT
VBAT *0.9
OUTn
[t]
VBAT *0.9
OUTn
VBAT *0.1
VBAT*0.1
[t]
tFALLn
www.rohm.com
TSZ22111 • 15 • 001
tRISEn
[t]
tFALLn
11/48
tRISEn
03.Aug.2023 Rev.002
BD8LD650EFV-C
(Reference data) (Unless otherwise specified, VDD = 5 V, VDDIO = 5 V, Tj = 25 °C)
VDD Standby Current: IVDDS [μA]
10
5
2
3
4
5
Power Supply Voltage: VDD [V]
6
5
100
Junction Temperature: Tj [ºC]
150
Figure 9. VDD Standby Current vs Junction Temperature
VDDIO Standby Current: IVDDIOS [μA]
10
7
Figure 8. VDD Standby Current vs Power Supply Voltage
15
15
10
5
2
3
4
5
6
Power Supply Voltage: VDDIO [V]
7
Figure 10. VDDIO Standby Current vs Power Supply Voltage
www.rohm.com
TSZ22111 • 15 • 001
12/48
15
10
5
100
150
Figure 11. VDDIO Standby Current vs Junction Temperature
03.Aug.2023 Rev.002
BD8LD650EFV-C
Typical Performance Curves – continued
2.0
2.0
VDD Operating Current: IVDD [mA]
2.4
VDD Operating Current : IVDD [mA]
2.4
Sweep
1.6
1.6
1.2
1.2
0.8
0.8
0.4
0.4
0.0
0.0
2
3
4
5
6
7
-50
Figure 12. VDD Operating Current vs Power Supply Voltage
150
Figure 13. VDD Operating Current vs Junction Temperature
150
VDDIO Operating Current: IVDDIO [μA]
150
120
VDDIO Operating Current : IVDDIO [μA]
100
120
Sweep
90
60
30
60
30
2
3
4
5
6
7
Figure 14. VDDIO Operating Current vs Power Supply
Voltage
www.rohm.com
TSZ22111 • 15 • 001
-50
100
150
Figure 15. VDDIO Operating Current vs Junction
Temperature
13/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
4.0
5
VPORA
High/Low Level Input Voltage: VIH ,VIL [V]
VDD/VDDIO Power on Reset Voltage: VPORA, VPORD [V]
3.5
3.0
2.5
VPORD
2.0
1.5
1.0
-50
100
3
VIH
VIL
2
1
150
Figure 16. VDD/VDDIO Power On Reset Voltage vs Junction
Temperature
100
150
Figure 17. High/Low Level Input Voltage vs Junction
Temperature
IIH2
High/Low Level Input Current 2: IIH2, IIL2 [μA]
100
High/Low Level Input Current 1: IIH1, IIL1 [μA]
4
-20
80
-40
60
IIH1
IIL2
-60
40
-80
IIL1
-100
100
150
Figure 18. High/Low Level Input Current 1 vs Junction
Temperature
www.rohm.com
TSZ22111 • 15 • 001
-50
100
150
Figure 19. High/Low Level Input Current 2 vs Junction
Temperature
14/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
5.0
SO High Level Output Voltage: VOH [V]
0.5
4.9
SO Low Level Output Voltage: VOL [V]
0.4
4.8
0.3
4.7
0.2
4.6
0.1
4.5
0.0
-50
100
-50
150
Figure 20. SO Low Level Output Voltage vs Junction
Temperature
100
150
Figure 21. SO High Level Output Voltage vs Junction
Temperature
5
1.4
Tj = 150 °C
1.2
Output On Resistance: RDS(ON) [Ω]
Serial Out Output Leakage Current: ISO [μA]
Tj = 25 °C
4
3
2
1
-2
-3
1.0
0.8
0.6
0.4
0.2
-4
-5
-50
0.0
100
150
Figure 22. Serial Out Output Leakage Current vs Junction
Temperature
www.rohm.com
TSZ22111 • 15 • 001
3
4
5
Figure 23. Output On Resistance vs Power Supply Voltage
15/48
03.Aug.2023 Rev.002
6
BD8LD650EFV-C
2.0
1.4
Tj = 25 ºC
Output Leakage Current: IOUT(L) [μA]
1.2
1.0
0.8
0.6
0.4
Tj = 150 ºC
1.6
1.2
0.8
0.4
0.2
0.0
0.0
-50
100
Figure 24. Output On Resistance vs Junction Temperature
4
8
12 16 20 24 28
Output Voltage: VOUT [V]
32
36
Figure 25. Output Leakage Current vs Output Voltage
45
2.0
Output Clamp Voltage: VCL [V]
1.6
1.2
0.8
0.4
0.0
-50
100
150
Figure 26. Output Leakage Current vs Junction Temperature
www.rohm.com
TSZ22111 • 15 • 001
43
41
39
37
-50
100
150
Figure 27. Output Clamp Voltage vs Junction Temperature
16/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
50
Turn-On/Off Time 1: tON1 ,tOFF1 [µs]
50
40
30
tOFF1
tON1
10
4
5
Power Supplay Voltage: VDD [V]
tOFF1
tON1
10
100
150
Figure 29. Turn-On/Off Time 1 vs Junction Temperature
1.5
Slew Rate (On/Off) 1: SRON1 ,SROFF1 [V/µs]
1.5
30
6
Figure 28. Turn-On/Off Time 1 vs Power Supply Voltage
40
1.3
1.3
SROFF1
1.1
SROFF1
1.1
SRON1
0.9
SRON1
0.9
0.7
0.7
0.5
0.5
3
4
5
6
Figure 30. Slew Rate (On/Off) 1 vs Power Supply Voltage
www.rohm.com
TSZ22111 • 15 • 001
-50
100
150
Figure 31. Slew Rate (On/Off) 1 vs Junction Temperature
17/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
200
200
160
160
Turn-On/Off Time 2: tON2 ,tOFF2 [µs]
120
120
tOFF2
80
tON2
40
4
5
40
100
150
Figure 33. Turn-On/Off Time 2 vs Junction Temperature
0.5
Slew Rate (On/Off) 2: SRON2 ,SROFF2 [V/µs]
0.5
tOFF2
tON2
6
Figure 32. Turn-On/Off Time 2 vs Power Supply Voltage
80
0.4
SROFF2
0.3
SRON2
0.2
0.1
3
4
5
6
Figure 34. Slew Rate (On/Off) 2 vs Power Supply Voltage
www.rohm.com
TSZ22111 • 15 • 001
0.4
SROFF2
0.3
SRON2
0.2
0.1
-50
100
150
Figure 35. Slew Rate (On/Off) 2 vs Junction Temperature
18/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
25
Turn-On/Off Time 3: tON3 ,tOFF3 [µs]
25
tOFF3
10
tON3
5
4
5
tOFF3
10
tON3
5
100
150
Figure 37. Turn-On/Off Time 3 vs Junction Temperature
3.2
Slew Rate (On/Off) 3: SRON3 ,SROFF3 [V/µs]
3.2
15
6
Figure 36. Turn-On/Off Time 3 vs Power Supply Voltage
2.4
SROFF3
SRON3
2.0
1.6
1.2
3
4
5
Power Suppy Voltage: VDD [V]
6
Figure 38. Slew Rate (On/Off) 3 vs Power Supply Voltage
www.rohm.com
TSZ22111 • 15 • 001
2.8
2.4
SROFF3
SRON3
2
1.6
1.2
-50
100
150
Figure 39. Slew Rate (On/Off) 3 vs Junction Temperature
19/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
2.0
IOCP2
1.6
1.2
IOCP1
0.8
0.4
0.0
-50
100
150
Figure 40. Over Current Threshold Value 1,2 vs Junction
Temperature
Output Stop Time at OCP Detection: tOCP_OFF [ms]
1.9
Over Current Threshold Value 1,2 : IOCP1,IOCP2 [A]
2.4
1.6
1.3
1
0.7
0.4
-50
100
150
Figure 41. Output Stop Time at OCP Detection vs Junction
Temperature
3.5
Open Load Detect Voltage: VOLD_DET [V]
Open Load Release Voltage: VOLD_REL [V]
3.5
3.0
3.0
2.5
2.5
2.0
2.0
1.5
1.5
1.0
1.0
-50
100
150
Figure 42. Open Load Detect Voltage vs Junction
Temperature
www.rohm.com
TSZ22111 • 15 • 001
-50
100
150
Figure 43. Open Load Release Voltage vs Junction
Temperature
20/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
3.5
Output Overhead Detect Voltage: VOFD_DET [V]
Output Sink Current: IOLD [µA]
90
75
3.0
60
2.5
45
2.0
30
15
-50
1.5
1.0
100
150
Figure 44. Output Sink Current vs Junction Temperature
-50
100
150
Figure 45. Output Overhead Detect Voltage vs Junction
Temperature
1.9
Short Ground Detect Voltage: VSGD_DET [V]
Output Overhead Release Voltage: VOFD_REL [V]
3.5
3.0
2.5
2.0
1.5
1.0
-50
100
150
Figure 46. Output Overhead Release Voltage vs Junction
Temperature
www.rohm.com
TSZ22111 • 15 • 001
1.7
1.5
1.3
1.1
0.9
0.7
0.5
-50
100
150
Figure 47. Short Ground Detect Voltage vs Junction
Temperature
21/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
-10
1.7
-15
Output Source Current: ISGD [µA]
Short Ground Release Voltage: VSGD_REL [V]
1.9
1.5
1.3
1.1
0.9
0.7
0.5
-50
100
150
Figure 48. Short Ground Release Voltage vs Junction
Temperature
-20
-25
-30
-35
-40
-50
100
150
Figure 49. Output Source Current vs Junction Temperature
TSD Detect Temperature: TTSD_DET [ºC]
200
190
180
170
160
150
3
4
5
6
Figure 50. Thermal Shutdown Detect Temperature vs Power
Supply Voltage
www.rohm.com
TSZ22111 • 15 • 001
22/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Measurement Circuit
VBAT
VDD
VDD
RL
0V
IDLE VDD
INxx
CSB
SCLK
SI
VDDIO OUTn
IDLE
INxx
VDD
VDDIO OUTn
VDD
VOUT
CSB
SCLK
MCU
SI
SO
SO
GND
GND
*ALL ch On
VSO
Figure 51. VDD Standby Current
Low Level Input Current 1, 2
Figure 52. VDD Operating Current
Thermal Shutdown Hysteresis Temperature
VDD
VDD
IDLE
INxx
VDD
VDDIO OUTn
IDLE
INxx
VDDIO OUTn
VDD
VDD
CSB
CSB
MCU
SCLK
MCU
VDD
SCLK
SI
SI
SO
SO
GND
GND
*ALL ch On/Off
Figure 53. Output On Resistance
www.rohm.com
TSZ22111 • 15 • 001
Figure 54. SO High/Low Level Output Voltage
23/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Measurement Circuit – continued
VBAT
VDD
VDD
RL
IDLE
INxx
VDD
VDDIO OUTn
IDLE
INxx
Monitor
VDDIO OUTn
VDD
VDD
CSB
CSB
SCLK
SCLK
MCU
VDD
MCU
SI
SI
SO
SO
GND
GND
*ALL ch On / Off
*ALL ch On / Off
Figure 55. Slew Rate (On/Off) 1, 2, 3
Turn-On/Off Time 1, 2, 3
Figure 56. Open Load Detect/Release Voltage
Output Sink Current
Output Overhead Detect/Release Voltage
Short Ground Detect/Release Voltage
Over Current Threshold Value 1, 2
VBAT
VDD
RL
VDD
IDLE VDD
INxx
CSB
SCLK
SI
VDDIO OUTn
SO
GND
Figure 57. Low Level Input Voltage
High Level Input Current 1, 2
www.rohm.com
TSZ22111 • 15 • 001
24/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Timing Chart
The following shows the sequence when H is input to the IDLE pin after the power is supplied.
“xx” denotes each input (21, 43, 65), and n denotes the channel number.
[V]
VDDIO
3.0 V (Max)
[t]
[V]
4.0 V (Max)
VDD
[t]
[V]
t SETUP ≥ 0.1 µs
IDLE
tSHUTDOWN ≥ 0.1 µs
When IDLE is set High, you can send command by SPI.
[t]
[V]
tSPI_START ≥ 10 µs
t SPI_END ≥ 0.1 µs
CSB
[t]
[V]
tINxx_ON ≥ 10 µs
tIDLE_OFF ≥ tOFFn_Max
INxx
[t]
[V]
tONn
tOFFn
VBAT
VBAT *0.9
OUTn
VBAT*0.1
[t]
(Supplement) About Each Symbol
tSETUP: Time from VDDIO and VDD reaches operating voltage until H can be input to IDLE.
tSPI_START: Time from H is input to IDLE until SPI communication is available.
tINxx_ON: Time from H is input to IDLE until control by INxx is available.
tSPI_END: Time from completion of SPI communication until L is input L to IDLE (Note 1).
tIDLE_OFF: Time from end of control by INxx until input L to IDLE.
tONn: Turn-On time
tOFFn: Turn-Off time
tOFFn_Max: Turn-Off Time (Max)
tSHUTDOWN: Time from input L to IDLE until VDDIO and VDD are turned off.
(Note 1) If using SPI control to turn off low side SW, wait tIDLE_OFF before inputting L to IDLE.
www.rohm.com
TSZ22111 • 15 • 001
25/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Timing Chart – continued
The following shows the sequence when the VDDIO and IDLE pins are simultaneously turned on/off.
[V]
VDDIO
3.0 V (Max)
[t]
[V]
4.0 V (Max)
VDD
[t]
[V]
IDLE
*short to
VDDIO
[t]
[V]
tSPI_START ≥ 10 µs
tSPI_END ≥ 0.1 µs
CSB
[t]
[V]
tINxx_ON ≥ 10 µs
tVDD_OFF ≥ t OFFn_Max
INxx
[t]
[V]
tONn
tOFFn
VBAT
VBAT *0.9
OUTn
VBAT *0.1
[t]
tINxx_ON: Time from VDD reaches operating voltage until control by INxx is available.
tSPI_END: Time from completion of SPI communication until lowering VDD(Note 1).
tVDD_OFF: Time from end of control by INxx until lowering VDD.
tONn: Turn-On time
tOFFn_Max: Turn-Off time (Max)
(Note 1) If using SPI control to turn off low side SW, wait tVDD_OFF before lowering VDD.
Inductive Load Operation
[V]
INxx
[t]
VCL
[V]
VOUT
VBAT
I OUT x RDS(ON)
[t]
[A]
VBAT
RL + R DS(ON)
IOUT
[t]
www.rohm.com
TSZ22111 • 15 • 001
26/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Synchro Mode
Two adjacent output pins can be connected in parallel. Parallel connection is available by combining OUT1/OUT2, OUT3/OUT4,
OUT5/OUT6, OUT7/OUT8. The synchro mode can be set by SPI. For details, refer to "Register Map".
When controlling by IN21/IN43/IN65, channels connected in parallel are driven simultaneously.
All control by SPI is set from the odd number channel, and the even number channel setting is ignored. For example, to turn on
OUT1/OUT2, write "1" to OUTCTRL1 bit of OUTCTRL register. Writing to OUTCTRL2 bit is ignored.
Over current protection and thermal shutdown is active on each channel connected in parallel, and both channels are turned off
when protection is detected in either channel.
The detection of protection can be read from SPI by accessing DIAG_OUT4321 or DIAG_OUT8765 registers.
The error flag is output from the odd number channel and the error flag of the even number channel is fixed to "0". For example,
if over current protection is detected in OUT1/OUT2, "1" is output from DIAG_OCP1 bit of DIAG_OUT4321 register, and
DIAG_OCP2 bit outputs "0".
VDDIO
VDD
CVDDIO
VBAT
Load4
Load3
VDD
Load2
VDDIO
Load1
CVDD
OUT1
RIDLE
IDLE
RIN21
IN21
RIN43
IN43
I/O
OUT2
Control Logic
OUT3
RIN65
IN65
OUT4
UVLO
I/O
(IDLE, IN,
Limp Home)
OUT5
Mode
Control
OUT6
Limp
Home
MCU
RCSB
Input
Register
CSB
Control,
Diagnostic
and
protective
Functions
OUT7
OCD
OUT8
TSD
UVLO
RSCLK
RSI
RSO
SCLK
SI
I/O
(SPI)
SO
OLD
OFD
SGD
SPI
Control
Active
Clamp
Gate
Driver
Diagnosis
Register
COUT1
COUT2
COUT3
COUT4
GND
Caution: Differences in wire impedance between two neighboring outputs may affect characteristics such as turn-On/Off, slew rate, over current threshold value, and
active clamp energy. To avoid this, it is recommended to short output pin with near the IC as possible.
www.rohm.com
TSZ22111 • 15 • 001
27/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Limp Home Mode
When IDLE is set to L, the IC enters Limp Home mode. This mode enables operation with low current consumption. Control by
SPI is not possible in this mode, but on/off control by IN21/IN43/IN65 is available. Controllable channels are limited to odd
number channels (1ch, 3ch, 5ch). When IDLE becomes L, the register is cleared and returns to the default setting.
The timing chart in Limp Home mode is shown below.
[V]
VDDIO
[t]
[V]
VDD
[t]
[V]
IDLE
[t]
[V]
t SETUP(Limp) ≥ 10 µs
tSHUTDOWN(Limp) ≥ tOFF_Max1,3.5
INxx
[t]
[V]
tON1,3,5
t OFF1,3,5
VBAT
VBAT *0.9
OUT1
OUT3
OUT5
VBAT *0.1
[t]
tSETUP(Limp): Time from VDDIO and VDD reaches operating voltage until control by INxx is available.
tON1,3,5: Turn-On time
tOFF1,3,5: Turn-Off time
tOFF_Max1,3,5: Turn-Off time (Max)
tSHUTDOWN(Limp): Time from all INxx is set to L until VDDIO and VDD are turned off.
www.rohm.com
TSZ22111 • 15 • 001
28/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
SPI Specification
SPI overview
When CSB = H
SO is High-Z.
When CSB = L
Outputs to SO at the rising edge of SCLK.
SI is loaded into the register at the falling edge of SCLK.
SO
SI
X
MSB
14
13
12
11
10
9
8
7
6
5
4
3
2
1
LSB
MSB
14
13
12
11
10
9
8
7
6
5
4
3
2
1
LSB
CSB
SCLK
SPI protocol
The SO response to SPI access is returned at the next SPI access as shown in the following figure.
SI
frame A
frame B
frame C
SO
(previous
response)
response to
frame A
response to
frame B
·Response when accessing with RE = 0 and with RE = 1
When accessing with RE = 0, respond “Standard diagnostic”.
When accessing with RE = 1, respond the value of the specified register.
SI
RE = 0
RE = 1 (register A)
(new command)
SO
(previous
response)
Standard
diagnostic
register A
content
www.rohm.com
TSZ22111 • 15 • 001
29/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
SPI Specification – continued
Serial Daisy Chain
Multiple devices can be connected in series as shown below.
For CSB signal and SCLK signal, connect a common signal. About SI / SO line, SO of Device 1 can be connected to SI of Device 2 as
shown below.
Device 1
SI
MO
SO
SPI
CSB
Device 2
SI
SCLK
CSB
SPI
Device 7
Device 8
SPI
SPI
SO
SCLK
CSB
SCLK
CSB
SCLK
MI
MCSB
MCLK
The timing chart when eight devices are connected is shown below.
MI
MO
X SO Device 8
SO Device 7
SO Device 2
SO Device 1
X SI Device 8
SI Device 7
SI Device 2
SI Device 1
MCSB
MCLK
OUTn
Parallel Connection
Multiple devices can be connected in parallel as shown below.
For SI signal, SCLK signal, and SO signal, connect a common signal. Separate signals are required for the CSB signal for each
device.
SI
SCLK
MCSB1
MCSB2
SO
SPI
CSB
SI
MO
MCLK
Device 1
SCLK
Device 2
SO
SPI
CSB
MI
The timing chart when two devices are connected is shown below.
MI
MO
SO Device 1
SO Device 2
SI Device 1
SI Device 2
MCSB1
MCSB2
MCLK
www.rohm.com
TSZ22111 • 15 • 001
30/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
SPI Timing chart
t CSB(lead)
tCSB(lag)
t CSB(td)
0.7VDD
tSCLK(P)
CSB
0.2VDD
tSCLK(su)
tSCLK(H)
tSCLK(hd)
tSCLK(L)
0.7VDD
SCLK
0.2VDD
tSI(su)
tSI(hd)
0.7VDD
SI
Don't care
SI
MSB
14
1
LSB
Don't care
0.2VDD
tSO(td)
tSO(dd)
tSO(en)
SO
Hi-Z
x
SI
tSO(dis)
MSB
14
1
0.7VDD
Hi-Z
LSB
x
0.2VDD
Parameter
Symbol
Min
Typ
Max
Unit
SCLK Frequency
SCLK Period
SCLK High Time
SCLK Low Time
SCLK Setup Time
SCLK Hold Time
CSB Lead Time
CSB Lag Time
Transfer Delay Time
Data Setup Time
Data Hold Time
SPI Output Enable Time(Note 1)
SPI Output Disable Time(Note 1)
SPI Output Data Delay Time(Note 1)(Note 2)
ERR Output Through Delay Time(Note 1)
fSCLK
50
50
50
50
250
250
250
200
250
100
200
MHz
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
tSCLK(P)
tSCLK(H)
tSCLK(L)
tSCLK(su)
tSCLK(hd)
tCSB(lead)
tCSB(lag)
tCSB(td)
tSI(su)
tSI(hd)
tSO(en)
tSO(dis)
tSO(dd)
tSO(td)
(Note 1) Not 100 % tested.
(Note 2) SO capacitance = 20 pF
www.rohm.com
TSZ22111 • 15 • 001
31/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
SI data structure
Bit[15]
Bit[14]
Bit[13]
RE
WE
Address
Bit[12]
Bit[11]
Bit[10]
Bit[9]
Bit[8]
Bit[7]
TEST
Data
Bit[6]
Bit[5]
Bit[4]
Bit[3]
Bit[2]
Bit[1]
Bit[0]
RE
0: SO outputs "Standard diagnostic" at the next SPI access.
1: SO outputs the register specified by Address at the next SPI access.
WE
0: Not Write.
1: Write.
TEST
Be sure to set 0.
Data
When WE = 1, various settings are enabled by writing '0' or '1' to Data.
"Standard diagnostic" (when RE = 0 in the previous SPI access)
Initial Value 0x4000
Bit[15]
Bit[14]
Bit[13]
Bit[12]
Bit[11]
Bit[10]
Bit[9]
Bit[8]
Bit[7]
Bit[6]
Bit[5]
Bit[4]
Bit[3]
Bit[2]
Bit[1]
Bit[0]
INIT
TER
ERR8
ERR7
ERR6
ERR5
ERR4
ERR3
ERR2
ERR1
INIT
0: Normal (after power on or IDLE = 'L'->'H', from the second time SPI access).
1: After power on or IDLE = 'L'->'H', first time SPI access.
TER
0: Normal
1: SPI communication error
When High pulse input of SCLK is other than (16 times + 8 x m, m is an integer 0 or above) in the low level section of CSB, a
communication error is judged.
ERRn (n is the channel number)
0: Normal
1: The value is latched and output when over current protection or thermal shutdown of the corresponding channel is detected.
This bit is cleared by reading DIAG register (DIAG_OUT4321 or DIAG_OUT8765) of the channel on which protection is detected.
SO output data structure (when RE = 1 in the previous SPI access)
Bit[15]
Bit[14]
Bit[13]
1
WE
Address
Bit[12]
Bit[11]
Bit[10]
Bit[9]
Bit[8]
Bit[7]
ERRALL
Data
Bit[6]
Bit[5]
Bit[4]
Bit[3]
Bit[2]
Bit[1]
Bit[0]
WE, Address
Outputs WE and Address values that were set during the previous SPI access.
ERRALL
Outputs 1 when either over current protection or thermal shutdown of OUT is detected on at least one channel.
Data
Outputs the register value of Address that were set during the previous SPI access.
www.rohm.com
TSZ22111 • 15 • 001
32/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Register Map
Register Name
Register
Access
Address
TEST
Bit[13:9]
Bit[8]
Bit[7]
Bit[6]
Bit[5]
Bit[4]
Bit[3]
Bit[2]
Bit[1]
Bit[0]
0x00
OUTCTRL8
OUTCTRL7
OUTCTRL6
OUTCTRL5
OUTCTRL4
OUTCTRL3
OUTCTRL2
OUTCTRL1
Data
Initial
OUTCTRL
R/W
SRCTRL0
R/W
0x01
SRCTRL4[1:0]
SRCTRL3[1:0]
SRCTRL2[1:0]
SRCTRL1[1:0]
0x00
SRCTRL1
R/W
0x02
SRCTRL8[1:0]
SRCTRL7[1:0]
SRCTRL6[1:0]
SRCTRL5[1:0]
0x00
OCPCTRL
R/W
0x03
OCPCTRL8
OCPCTRL7
OCPCTRL6
OCPCTRL5
OCPCTRL4
OCPCTRL3
OCPCTRL2
OCPCTRL1
0x00
DIRCTRL
R/W
0x04
DIRCTRL6
DIRCTRL5
DIRCTRL4
DIRCTRL3
DIRCTRL2
DIRCTRL1
0x55
SYNC
R/W
0x05
SYNC87
SYNC65
SYNC43
SYNC21
0x00
STATUS_IN
RO
0x06
STATUS_IN65
STATUS_IN43
STATUS_IN21
0x00
DIAG_OLD/OFD
R/W
0x08
DIAG_OLD/OFD8 DIAG_OLD/OFD7 DIAG_OLD/OFD 6 DIAG_OLD/OFD5 DIAG_OLD/OFD4 DIAG_OLD/OFD 3 DIAG_OLD/OFD2 DIAG_OLD/OFD1
0x00
0x00
DIAG_SGD
R/W
0x09
DIAG_SGD8
DIAG_SGD7
DIAG_SGD6
DIAG_SGD5
DIAG_SGD4
DIAG_SGD3
DIAG_SGD2
DIAG_SGD1
0x00
DIAG_OUT4321
RO
0x0A
DIAG_OCP4
DIAG_TSD4
DIAG_OCP3
DIAG_TSD3
DIAG_OCP2
DIAG_TSD2
DIAG_OCP1
DIAG_TSD1
0x00
DIAG_OUT8765
RO
0x0B
DIAG_OCP8
DIAG_TSD8
DIAG_OCP7
DIAG_TSD7
DIAG_OCP6
DIAG_TSD6
DIAG_OCP5
DIAG_TSD5
0x00
HWCR
WO
0x0C
RST
0x00
T_TESTMODE
WO
0x1E
1
TESTMODE
0x00
Register Name
Register Access
Address
OUTCTRL
Read / Write
0x00h
SRCTRL0
SRCTRL1
Read / Write
0x01h
0x02h
OCPCTRL
Read / Write
0x03h
DIRCTRL
Read / Write
0x04h
SYNC
Read / Write
0x05h
Read Only
0x06h
STATUS_IN
Explanation of Data
OUTCTRLn bit (n represents the channel number)
'0': OUTn off setting
'1': OUTn on setting
SRCTRLn[1:0] bit
'00': Slew Rate Setting 1.0 V/μs (Typ)
'01': Slew Rate Setting 2.25 V/μs (Typ)
'10': Slew Rate Setting 0.30 V/μs (Typ)
'11': Same setting as '00'
OCPCTRLn bit
'0': Over Current Threshold Value 1 0.85 A (Typ)
'1': Over Current Threshold Value 2 1.7 A (Typ)
DIRCTRLn bit
'0': IN control disabled
'1': IN control enabled
SYNC21/SYNC43/SYNC65/SYNC87 bit
'0': Synchro mode disabled
'1': Synchro mode enabled
STATUS_IN65/STATUS_IN43/STATUS_IN21 bit
'0': IN87/IN65/IN43/IN21 L input
'1': IN87/IN65/IN43/IN21 H input
DIAG_OLD/OFDn bit
'0': OLD/OFD disabled
'1': OLD/OFD enabled
OLD is enabled when OUTn is off. OFD is enabled when OUTn is
on. When SPI access is performed again, it automatically returns
to '0' (disabled).
DIAG_OLD/OFD
Read / Write
0x08h
Read OLD/OFD result by read access (RE = 1).
When OLD is active, the judgement is made as below.
'0': OLD detection
'1': Normal
When OFD is active, the judgement is made as below.
'0': Normal
'1': OFD detection
For details, refer to "Open Load Detection" and "Output Overhead
Fault Detection Function".
www.rohm.com
TSZ22111 • 15 • 001
33/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Register Map – continued
Register Name
DIAG_SGD
Register Access
Address
Read / Write
0x09h
Explanation of Data
DIAG_SGDn bit
'0': SGD disabled
'1': SGD enabled
This function is used when OUTn is off. When SPI access is
performed again, it automatically returns to '0' (disabled).
Read SGD result by read access (RE = 1).
'0': SGD detection
'1': Normal
For details, refer to " Short Ground Detection".
Read the error flag of ch1/ch2/ch3/ch4.
DIAG_TSDn bit
'0': Normal
'1': TSD detection
DIAG_OUT4321
Read Only
0x0Ah
DIAG_OCPn bit
'0': Normal
'1': OCP detection
It automatically returns to '0' when DIAG_OUT4321 is accessed.
Read the error flag of ch5/ch6/ch7/ch8.
DIAG_TSDn bit
'0': Normal
'1': TSD detection
DIAG_OUT8765
Read Only
0x0Bh
HWCR
Write Only
0x0Ch
T_TESTMODE
Write Only
0x1Eh
www.rohm.com
TSZ22111 • 15 • 001
DIAG_OCPn bit
'0': Normal
'1': OCP detection
It automatically returns to '0' when DIAG_OUT8765 is accessed.
RST
'0': Normal
'1': Hardware reset (auto clear)
TESTMODE
'0': Normal
'1': Test Mode
If IDLE is 5.6 V (Min) or more and "1" is written to this register, IC
enters test mode. For this reason, do not access to this register.
34/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Turns off the output when an over current error occurs in the output (A in the figure). The output returns to on when the output
stop time of 1 ms (Typ) has passed. However, if an over current error still continue at this time, the output will be turned off again
(B in the figure). When an over current error is improved, the output recovers after the output stop time from over current error is
lastly detected has passed (C in the figure).
If an over current error is detected, the internal over current detection flag outputs '1' (A' in the figure). This flag can be read from
SPI read access or from Standard diagnostic. When the flag is read by SPI read access, it is cleared by the next SPI access after
read access (D in the figure).
*n shows ch number [V]
OUT Enable (Note 1)
[t]
[V]
A
C
VBAT
OUTn
[t]
tOCP_DET
= 2.3 μs (Min)
[A]
IOCP1
IOCP2
IOUTn
B
1 ms (Typ)
1 ms (Typ)
[t]
D
A'
DIAG_OCPn
'0'
in DIAG_OUT Register
'1'
'0'
[t]
DIAG_OUT
Read Access
[V]
Return
Response
CSB
for SPI
[t]
(Note 1) Output on/off control signal. This signal is controlled by IN65, IN43, IN21 or OUT_CTRL register.
When an over current error is detected in multiple channels, the output off time is measured starting from the channel that over
current error was detected lastly.
For example, if an over current error is detected in ch2 after an over current error is detected in ch1 before the output off time of
ch1 passes, the time tSHORT from ch1 detects an error until an error is detected in ch2 will be added to the output off time of ch1.
[A]
IOUT1
tSHORT
< 1 ms (Typ)
1 ms (Typ)
1 ms (Typ)
1 ms (Typ)
[t]
[A]
IOUT2
1 ms (Typ)
1 ms (Typ)
[t]
www.rohm.com
TSZ22111 • 15 • 001
1 ms (Typ)
35/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Turns off the output when the junction temperature rises 175 °C (Typ) or above (A in the figure). After that, the output automatically
returns to on when the junction temperature falls 160 °C (Typ) or below (B in the figure).
When thermal shutdown is detected, the internal thermal shutdown flag outputs '1' (A in the figure). This flag can be read from SPI
read access or Standard diagnostic. When the flag is read by SPI read access, it is cleared by the next SPI access after read
access (C in the figure).
OUT Enable (Note 1)
[t]
[V]
A
B
VBAT
OUTn
[t]
[°C]
TTSD_DET
TTSD_HYS
Tj
[t]
C
DIAG_TSDn
'0'
'1'
'0'
[t]
DIAG_TSD
Read Access
[V]
Return
Response
CSB
for SPI
www.rohm.com
TSZ22111 • 15 • 001
36/48
[t]
03.Aug.2023 Rev.002
BD8LD650EFV-C
Load
VBAT
RL
OUT
Power
MOS
DIAG_
OLD/OFDn
IOLD
SO
GND
When OLD is enabled, output sink current IOLD flows from OUT. The output voltage VOUT drops when the load RL increases, and
it is detected as OLD when it becomes VOLD_DET or less.
RL for detecting OLDs is given by the following equation:
𝑅𝐿 ≥
𝑉𝐵𝐴𝑇 − 𝑉𝑂𝐿𝐷_𝐷𝐸𝑇
𝐼𝑂𝐿𝐷
VBAT: Battery voltage
VOLD_DET: Open load detection voltage 3.2 V (Max)
IOLD: Output sink current when OLD function is active 90 μA (Max)
When the output is off, OLD can be enabled and diagnosed by one SPI access of write and read access (RE = 1, WE = 1) to
DIAG_OLD/OFD register (B, F in the figure). Diagnostic is output to SO at the next SPI access (D, H in the figure).
At this time, OLD returns to inactive (D, H in the figure). When OUTn voltage is V OLD_DET or less, OLD is diagnosed as detected
and the error flag inside the IC outputs "0" (C in the figure). If OUTn voltage is V OLD_REL or more, OLD is diagnosed as undetected
and the error flag output '1' (G in the figure).
*n shows ch number
[V]
OUT Enable (Note 1)
[t]
[V]
DIAG_OLD/OFD
R/W Access
Return
Response
DIAG_OLD/OFD
R/W Access
Return
Response
B
D
F
H
CSB
for SPI
[t]
OLD Enable (Note 2)
'0'
'1'
'0'
A. Occur
[V] "Open Load"
'1'
'0'
[t]
E. Improve
"Open Load"
VBAT
VOLD_REL
OUTn
Hi-Z
Hi-Z
VOLD_DET
[t]
C
OLD Error(Note 3)
'1'
G
'0'
(Detect)
'1'
'1'
(No Detect)
'1'
[t]
(Note 2) Internal enable signal. High and Low indicates enabled and disabled, respectively. This signal is controlled by write access to DIAG_OLD/OFD register.
(Note 3) Internal error flag. High and Low indicates error undetected and detected, respectively. Also the flag outputs High during disable. This signal can be retrieved
to SO by read access to DIAG_OLD/OFD register.
www.rohm.com
TSZ22111 • 15 • 001
37/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Load
VBAT
RL
OUT
Power
MOS
DIAG_
OLD/OFDn
SO
GND
When the output is on, OFD can be enabled and diagnosed by one SPI access by write and read access (RE = 1, WE = 1) to
At this time, OFD returns to be inactive (D, H in the figure). When OUTn voltage is V OFD_DET or more, OFD is diagnosed as detected
and the error flag inside the IC outputs "1" (C in the figure). If OUTn voltage is V OFD_REL or less, OFD is diagnosed as undetected
and the error flag output '0' (G in the figure).
*n shows ch number
[V]
OUT Enable (Note 1)
[t]
[V]
DIAG_OLD/OFD
R/W Access
Return
Response
DIAG_OLD/OFD
R/W Access
Return
Response
B
D
F
H
CSB
for SPI
[t]
OFD Enable (Note 2)
'0'
'1'
'0'
A. Occur
[V] "VDD Short"
'1'
'0'
[t]
E. Improve
"VDD Short"
VBAT
OUTn
VOFD_DET
VOFD_REL
[t]
C
OFD Error(Note 3)
'1'
G
'1'
(Detect)
'1'
'0'
(No Detect)
'1'
[t]
(Note 1) Output on/off control signal. High and Low indicates on and off, respectively. This signal is controlled by IN65, IN43, IN21 or OUT_CTRL register.
(Note 3) Internal error flag. High and Low indicates error detected and undetected, respectively. Also the flag outputs High during disable. This signal can be retrieved
www.rohm.com
TSZ22111 • 15 • 001
38/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Load
VBAT
RL
ISGD
SW1
OUT
Power
MOS
RG
DIAG_
OLD/OFDn
SO
GND
·When normal load is connected (SW1 is on)
The output voltage VOUT is determined by the divided voltage between RL (normal load) and RG (OUT-GND impedance) and it is
detected as SGD when VOUT is VSGD_DET or less.
RG for detecting SGD is given roughly by the following equation.
𝑅𝐺 ≤
𝑉𝑆𝐺𝐷_𝐷𝐸𝑇
∗ 𝑅𝐿
𝑉𝐵𝐴𝑇 − 𝑉𝑆𝐺𝐷_𝐷𝐸𝑇
VSGD_DET: Short ground detection voltage 0.3 V (Min)
·When the load is open (SW1 is off)
The output voltage VOUT is obtained from output source current ISGD that flows into RG and it is detected as SGD when VOUT is
VSGD_DET or less.
RG for detecting SGD is given by the following equation.
𝑅𝐺 ≤
𝑉𝑆𝐺𝐷_𝐷𝐸𝑇
𝐼𝑆𝐺𝐷
ISGD: Output source current when SGD function is active 40 μA (Max)
www.rohm.com
TSZ22111 • 15 • 001
39/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Short Ground Detection (SGD) – continued
When the output is off, SGD can be enabled and diagnosed by one SPI access of write and read access (RE = 1, WE = 1) to
DIAG_SGD register (B, F in the figure). Diagnostic is output to SO at the next SPI access. At this time, SGD returns to be inactive
(D, H in the figure). When OUTn voltage is VSGD_DET or less, SGD is diagnosed as detected and the error flag inside the IC outputs
"0" (C in the figure). If OUTn voltage is V SGD_REL or more, SGD is diagnosed as undetected and the error flag output '1' (G in the
figure).
*n shows ch number
[V]
OUT Enable (Note 1)
[t]
[V]
DIAG_SGD
R/W Access
Return
Response
DIAG_SGD
R/W Access
Return
Response
B
D
F
H
CSB
for SPI
[t]
SGD Enable (Note 2)
'0'
'1'
'0'
A. Occur
[V] "GND Short"
'1'
'0'
[t]
E. Improve
"GND Short"
VBAT
OUTn
VSGD_REL
VSGD_DET
[t]
C
SGD Error(Note 3)
'1'
G
'0'
(Detect)
'1'
'1'
(No Detect)
'1'
[t]
(Note 2) Internal enable signal. High and Low indicates enabled and disabled, respectively. This signal is controlled by write access to DIAG_SGD register.
to SO by read access to DIAG_SGD register.
www.rohm.com
TSZ22111 • 15 • 001
40/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Application Example
VDDIO
VDD
CVDDIO
VBAT
Load8
Load7
Load6
Load5
Load4
Load3
VDD
Load2
VDDIO
Load1
CVDD
OUT1
RIDLE
IDLE
RIN21
IN21
I/O
OUT2
Control Logic
OUT3
RIN43
IN43
OUT4
UVLO
I/O
(IDLE, IN,
Limp Home)
OUT5
Mode
Control
OUT6
Limp
Home
MCU
RCSB
Input
Register
CSB
Control,
Diagnostic
and
protective
Functions
OUT7
OCD
OUT8
TSD
UVLO
RSCLK
SCLK
RSI
SI
RSO
SO
OLD
OFD
SGD
SPI
Control
I/O
(SPI)
Active
Clamp
Gate
Driver
Diagnosis
Register
COUT1
COUT2
COUT3
COUT4
COUT5
COUT6
COUT7
COUT8
GND
Symbol
RIDLE
RIN21, RIN43, RIN65
RCSB, RSCLK, RSI, RSO
CVDDIO, CVDD
COUT1 to COUT8
Value
1 kΩ
1 kΩ
1 kΩ
0.1 μF
0.1 μF
Purpose
Register for microcontroller protection against negative voltage surge
Capacitor for noise removal on the power supply line
Capacitor for ESD surge and BCI protection
As a precaution in selecting a COUT, current flows from the capacitor when the switch is turned on. Depending on the capacitance,
over current protection may be detected. This current depends on the slew rate setting, over current protection setting, and V BAT
voltage. As a reference, capacitance that can be used with VBAT = 18 V without over current protection when the switch is turned
on is shown in the below table.
VBAT = 18 V
Over Current Protection Capacitance value that over current protection
Slew Rate setting
setting
is not detected (Max)
OCPCTRLn = 0
0.22 μF
SRCTRLn[1:0] = 00
OCPCTRLn = 1
0.22 μF
OCPCTRLn = 0
0.47 μF
SRCTRLn[1:0] = 01
OCPCTRLn = 1
0.83 μF
OCPCTRLn = 0
0.68 μF
SRCTRLn[1:0] = 10
OCPCTRLn = 1
1.5 μF
www.rohm.com
TSZ22111 • 15 • 001
41/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Pin No.
Pin Name
VDDIO
1
IDLE
IDLE
100 kΩ
100 kΩ
GND
VDDIO
2
CSB
100 kΩ
1 kΩ
CSB
GND
VDDIO
3, 4
16 to 18
SCLK
SI
IN65
IN43
IN21
SCLK
SI
IN65
IN43
IN21
1 kΩ
100 kΩ
GND
VDDIO
50 Ω
5
SO
SO
GND
6, 15
GND
OUT1 to OUT8
7 to 14
OUT1 to OUT8
GND
19
VDD
VDDIO
www.rohm.com
TSZ22111 • 15 • 001
42/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Operational Notes
1.
Reverse Connection of Power Supply
Connecting the power supply in reverse polarity can damage the IC. Take precautions against reverse polarity when
connecting the power supply, such as mounting an external diode between the power supply and the IC’s power supply
pins.
2.
Power Supply Lines
Design the PCB layout pattern to provide low impedance supply lines. Separate the ground and supply lines of the
digital and analog blocks to prevent noise in the ground and supply lines of the digital block from affecting the analog
block. Furthermore, connect a capacitor to ground at all power supply pins. Consider the effect of temperature and
aging on the capacitance value when using electrolytic capacitors.
3.
Ground Voltage
Ensure that no pins are at a voltage below that of the ground pin at any time, even during transient condition.
4.
Ground Wiring Pattern
When using both small-signal and large-current ground traces, the two ground traces should be routed separately but
connected to a single ground at the reference point of the application board to avoid fluctuations in the small-signal
ground caused by large currents. Also ensure that the ground traces of external components do not cause variations
on the ground voltage. The ground lines must be as short and thick as possible to reduce line impedance.
5.
The function and operation of the IC are guaranteed within the range specified by the recommended operating
conditions. The characteristic values are guaranteed only under the conditions of each item specified by the electrical
characteristics.
6.
Inrush Current
When power is first supplied to the IC, it is possible that the internal logic may be unstable and inrush current may flow
instantaneously due to the internal powering sequence and delays, especially if the IC has more than one power supply.
Therefore, give special consideration to power coupling capacitance, power wiring, width of ground wiring, and routing
of connections.
7.
Testing on Application Boards
When testing the IC on an application board, connecting a capacitor directly to a low-impedance output pin may subject
the IC to stress. Always discharge capacitors completely after each process or step. The IC’s power supply should
always be turned off completely before connecting or removing it from the test setup during the inspection process. To
prevent damage from static discharge, ground the IC during assembly and use similar precautions during transport and
storage.
8.
Inter-pin Short and Mounting Errors
Ensure that the direction and position are correct when mounting the IC on the PCB. Incorrect mounting may result in
damaging the IC. Avoid nearby pins being shorted to each other especially to ground, power supply and output pin.
Inter-pin shorts could be due to many reasons such as metal particles, water droplets (in very humid environment) and
unintentional solder bridge deposited in between pins during assembly to name a few.
9.
Unused Input Pins
Input pins of an IC are often connected to the gate of a MOS transistor. The gate has extremely high impedance and
extremely low capacitance. If left unconnected, the electric field from the outside can easily charge it. The small charge
acquired in this way is enough to produce a significant effect on the conduction through the transistor and cause
unexpected operation of the IC. So unless otherwise specified, unused input pins should be connected to the power
supply or ground line.
www.rohm.com
TSZ22111 • 15 • 001
43/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Operational Notes – continued
10. Regarding the Input and Output Pins of the IC
This monolithic IC contains P+ isolation and P substrate layers between adjacent elements in order to keep them
isolated. P-N junctions are formed at the intersection of the P layers with the N layers of other elements, creating a
parasitic diode or transistor. For example (refer to figure below):
When GND > Pin A and GND > Pin B, the P-N junction operates as a parasitic diode.
When GND > Pin B, the P-N junction operates as a parasitic transistor.
Parasitic diodes inevitably occur in the structure of the IC. The operation of parasitic diodes can result in mutual
interference among circuits, operational faults, or physical damage. Therefore, conditions that cause these diodes to
operate, such as applying a voltage lower than the GND voltage to an input pin (and thus to the P substrate) should be
avoided.
Resistor
Transistor (NPN)
Pin A
Pin B
C
E
Pin A
N
P+
P
N
N
P+
N
Pin B
B
Parasitic
Elements
N
P+
N P
N
P+
B
N
C
E
Parasitic
Elements
P Substrate
P Substrate
GND
GND
Parasitic
Elements
GND
Parasitic
Elements
GND
N Region
close-by
Figure 58. Example of Monolithic IC Structure
11. Ceramic Capacitor
When using a ceramic capacitor, determine a capacitance value considering the change of capacitance with
temperature and the decrease in nominal capacitance due to DC bias and others.
12. Thermal Shutdown Function (TSD)
This IC has a built-in thermal shutdown function that prevents heat damage to the IC. Normal operation should always
be within the IC’s maximum junction temperature rating. If however the rating is exceeded for a continued period, the
junction temperature (Tj) will rise which will activate the TSD function that will turn OFF power output pins. When the
Tj falls below the TSD threshold, the circuits are automatically restored to normal operation.
Note that the TSD function operates in a situation that exceeds the absolute maximum ratings and therefore, under no
circumstances, should the TSD function be used in a set design or for any purpose other than protecting the IC from
heat damage.
13. Over Current Protection Function (OCP)
This IC incorporates an integrated overcurrent protection function that is activated when the load is shorted. This
protection function is effective in preventing damage due to sudden and unexpected incidents. However, the IC should
not be used in applications characterized by continuous operation or transitioning of the protection function.
14. Active Clamp Operation
The IC integrates the active clamp function to internally absorb the reverse energy E L which is generated when the
inductive load is turned off. When the active clamp operates, the thermal shutdown function does not work. Decide a
load so that the reverse energy EL is active clamp tolerance EAS (refer to Figure 1.), ES,AS (refer to Figure 2.) or under
www.rohm.com
TSZ22111 • 15 • 001
44/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
15. Power Supply Steep Fluctuation
If the voltage of the power supply pin (VDD) falls sharply, the output pin (OUT) may temporarily turn off as shown in
Figure 55. If the power supply pin is expected to fall sharply, take measures such as inserting a capacitor between
the power supply pin and the ground pin so that it falls within the recommended usage range shown in Figure 56.
2.5
VDD [V]
2.0
Deprecated use range
VDD(FALL )
VDD
VDD(FALL) [V]
tVDD(FALL)
t
VOUT[V]
0.5
VOUT
≈0V
1.0
Recommended use range
≈ VBAT
t
0.0
t VDD(FALL) [μs]
Figure 59. Output OFF operation when power supply
fluctuates sharply
Figure 60. Recommended use range
16. GND Pin Connection
Connect all ground pins to ground.
www.rohm.com
TSZ22111 • 15 • 001
45/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
B
D
8
L
D
6
5
8: 8ch
L: low side switch
E
F
V
Package
EFV: HTSSOP-B20
CE 2
Product Rank
C: For Automotive
Packaging Specification
E2: Embossed tape and reel
Marking Diagram
HTSSOP-B20 (TOP VIEW)
Part Number Marking
8 L D 6 5 0
LOT Number
Pin 1 Mark
www.rohm.com
TSZ22111 • 15 • 001
46/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Package Name
www.rohm.com
TSZ22111 • 15 • 001
HTSSOP-B20
47/48
03.Aug.2023 Rev.002
BD8LD650EFV-C
Revision History
Date
Revision
26.Aug.2022
001
03.Aug.2023
002
Changes
New Release
P11 Add Over Current Detection Time tOCP_DET
P35 Add tOCP_DET in OCP sequence chart
www.rohm.com
TSZ22111 • 15 • 001
48/48
03.Aug.2023 Rev.002
Notice
Precaution on using ROHM Products
1.
If you intend to use our Products in devices requiring extremely high reliability (such as medical equipment (Note 1),
aircraft/spacecraft, nuclear power controllers, etc.) and whose malfunction or failure may cause loss of human life,
bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales
representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way
responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any
ROHM’s Products for Specific Applications.
(Note1) Medical Equipment Classification of the Specific Applications
JAPAN
USA
EU
CHINA
CLASSⅢ
CLASSⅡb
CLASSⅢ
CLASSⅢ
CLASSⅣ
CLASSⅢ
2.
ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor
products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate
safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which
a failure or malfunction of our Products may cause. The following are examples of safety measures:
[a] Installation of protection circuits or other protective devices to improve system safety
[b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure
3.
Our Products are not designed under any special or extraordinary environments or conditions, as exemplified below.
Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the
use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our
Products under any special or extraordinary environments or conditions (as exemplified below), your independent
verification and confirmation of product performance, reliability, etc, prior to use, must be necessary:
[a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents
[b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust
[c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2,
H2S, NH3, SO2, and NO2
[d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves
[e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items
[f] Sealing or coating our Products with resin or other coating materials
[g] Use of our Products without cleaning residue of flux (Exclude cases where no-clean type fluxes is used.
However, recommend sufficiently about the residue.); or Washing our Products by using water or water-soluble
cleaning agents for cleaning residue after soldering
[h] Use of the Products in places subject to dew condensation
4.
The Products are not subject to radiation-proof design.
5.
Please verify and confirm characteristics of the final or mounted products in using the Products.
6.
In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse, is applied,
confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power
exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect
product performance and reliability.
7.
De-rate Power Dissipation depending on ambient temperature. When used in sealed area, confirm that it is the use in
the range that does not exceed the maximum junction temperature.
8.
Confirm that operation temperature is within the specified range described in the product specification.
9.
ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in
this document.
Precaution for Mounting / Circuit board design
1.
When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product
2.
In principle, the reflow soldering method must be used on a surface-mount products, the flow soldering method must
be used on a through hole mount products. If the flow soldering method is preferred on a surface-mount products,
please consult with the ROHM representative in advance.
For details, please refer to ROHM Mounting specification
Notice-PAA-E
© 2015 ROHM Co., Ltd. All rights reserved.
Rev.004
Precautions Regarding Application Examples and External Circuits
1.
If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the
characteristics of the Products and external components, including transient characteristics, as well as static
characteristics.
2.
You agree that application notes, reference designs, and associated data and information contained in this document
are presented only as guidance for Products use. Therefore, in case you use such information, you are solely
responsible for it and you must exercise your own independent verification and judgment in the use of such information
contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses
incurred by you or third parties arising from the use of such information.
Precaution for Electrostatic
This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper
caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be
applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron,
isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control).
Precaution for Storage / Transportation
1.
Product performance and soldered connections may deteriorate if the Products are stored in the places where:
[a] the Products are exposed to sea winds or corrosive gases, including Cl 2, H2S, NH3, SO2, and NO2
[b] the temperature or humidity exceeds those recommended by ROHM
[c] the Products are exposed to direct sunshine or condensation
[d] the Products are exposed to high Electrostatic
2.
Even under ROHM recommended storage condition, solderability of products out of recommended storage time period
may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is
exceeding the recommended storage time period.
3.
Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads
may occur due to excessive stress applied when dropping of a carton.
4.
Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of
which storage time is exceeding the recommended storage time period.
Precaution for Product Label
A two-dimensional barcode printed on ROHM Products label is for ROHM’s internal use only.
Precaution for Disposition
When disposing Products please dispose them properly using an authorized industry waste company.
Precaution for Foreign Exchange and Foreign Trade act
Since concerned goods might be fallen under listed items of export control prescribed by Foreign exchange and Foreign
trade act, please consult with ROHM in case of export.
Precaution Regarding Intellectual Property Rights
1.
All information and data including but not limited to application example contained in this document is for reference
only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any
other rights of any third party regarding such information or data.
2.
ROHM shall not have any obligations where the claims, actions or demands arising from the combination of the
Products with other articles such as components, circuits, systems or external equipment (including software).
3.
No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any
third parties with respect to the Products or the information contained in this document. Provided, however, that ROHM
will not assert its intellectual property rights or other rights against you or your customers to the extent necessary to
manufacture or sell products containing the Products, subject to the terms and conditions herein.
Other Precaution
1.
This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM.
2.
The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written
consent of ROHM.
3.
In no event shall you use in any way whatsoever the Products and the related technical information contained in the
Products or this document for any military purposes, including but not limited to, the development of mass-destruction
weapons.
4.
The proper names of companies or products described in this document are trademarks or registered trademarks of
ROHM, its affiliated companies or third parties.
Notice-PAA-E
Rev.004
Datasheet
General Precaution
1. Before you use our Products, you are requested to carefully read this document and fully understand its contents.
ROHM shall not be in any way responsible or liable for failure, malfunction or accident arising from the use of any
ROHM’s Products against warning, caution or note contained in this document.
2. All information contained in this document is current as of the issuing date and subject to change without any prior
notice. Before purchasing or using ROHM’s Products, please confirm the latest information with a ROHM sales
representative.
3.
The information contained in this document is provided on an “as is” basis and ROHM does not warrant that all
information contained in this document is accurate and/or error-free. ROHM shall not be in any way responsible or
liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccuracy or errors of or
concerning such information.
Notice – WE
Rev.001
