BD95513MUV_10
BD95513MUV_10
    ROHM(罗姆)
    BD95513MUV_10 - Switching Regulator with MOS FET for DDR-SDRAM Cores - Rohm
BD95513MUV_10 数据手册
High-Performance Regulators for PCs Switching Regulator with MOS FET for DDR-SDRAM Cores BD95513MUV No.10030EAT37 ●Description BD95513MUV is a switching regulator capable of supplying high current output (up to 3A) at low output voltages (0.7V~5.0V) over a broad range of input voltages (4.5V~28V). The regulator features an internal N-MOSFET power transistor for high 3 TM efficiency and low space consumption, while incorporating ROHM’s proprietary H Reg control mode technology, yielding the industry’s fastest transient response time against load changes. SLLMTM (Simple Light Load Mode) technology is also integrated to improve efficiency when powering lighter loads, as well as soft start, variable frequency, short-circuit protection with timer latch, over-voltage protection, and REF functions. This regulator is suited for PC applications. ●Features 1) Internal low ON-resistance power N-MOSFET 2) Internal 5V linear voltage regulator 3 TM 3) Integrated H Reg DC/DC converter controller 4) Selectable Simple Light Load Mode (SLLMTM), Quiet Light Load Mode (QLLM) and forced continuous mode 5) Built-in thermal shutdown, low input, current overload, output over- and under-voltage protection circuitry 6) Soft start function to minimize rush current during startup 7) Adjustable switching frequency (f = 200 kHz ~ 1000 kHz) 8) Built-in output discharge function 9) VQFN032V5050 package size 10) Tracking function 11) Internal bootstrap diode ●Applications Mobile PCs, desktop PCs, LCD-TV, digital household electronics www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 1/17 2010.10- Rev.A BD95513MUV ●Absolute Maximum Ratings (Ta = 25℃) Parameter Input Voltage 1 Input Voltage 2 Input Voltage 3 External VCC Voltage BOOT Voltage BOOT-SW Voltage Output Feedback Voltage SS/FS/MODE Voltage VREG Voltage EN/CTL Input Voltage PGOOD Voltage Output Current (Average) Power Dissipation 1 Power Dissipation 2 Power Dissipation 3 Power Dissipation 4 Operating Temperature Range Storage Temperature Range Junction Temperature Symbol VCC VDD VIN EXTVCC BOOT BOOT-SW FB SS/FS/MODE VREG EN/CTL PGOOD ISW Pd1 Pd2 Pd3 Pd4 Topr Tstg Tjmax Ratings 7 *1 7 *1 30 7 *1 *1 Technical Note Unit V V V V V V V V V V V A 35 7 *1 VCC VCC VCC 7 7 *1 *1 3 *1 0.38 0.88 *2 W W W W ℃ ℃ ℃ *3 *6 2.06 *4 *6 4.56 *5 *6 -10 ~ +100 -55 ~ +150 +150 *1 Do not exceed Pd. *2 Ta ≧ 25 ℃ (IC only), power dissipated at 3.0 mW/℃. *3 Ta ≧ 25 ℃ (single-layer board, 20.2 mm2 copper heat dissipation pad), power dissipated at 7.0 mW/℃. *4 Ta ≧ 25 ℃ (4-layer board, 10.29 mm2 copper heat dissipation pad on top layer, 5505 mm2 pad on 2nd and 3rd layer), power dissipated at 16.5 mW/℃. *5 Ta ≧ 25 ℃ (4-layer board, all layers with 5505 mm2 copper heat dissipation pads), power dissipated at 36.5 mW/℃. *6 Values observed with chip backside soldered. When unsoldered, power dissipation is lower. ●Operating Conditions (Ta = 25℃) Parameter Input Voltage 1 Input Voltage 2 Input Voltage 3 External VCC Voltage BOOT Voltage SW Voltage BOOT-SW Voltage MODE Input Voltage EN/CTL Input Voltage PGOOD Voltage Minimum On Time Symbol VCC VDD VIN EXTVCC BOOT SW BOOT-SW MODE EN/CTL PGOOD tonmin Ratings Min 4.5 4.5 4.5 4.5 4.5 -0.7 4.5 0 0 0 Max 5.5 5.5 28 5.5 33 28 5.5 5.5 5.5 5.5 100 Unit V V V V V V V V V V ns ★This product is not designed for use in a radioactive environment. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 2/17 2010.10- Rev.A BD95513MUV Technical Note ●Electrical Characteristics (Unless otherwise noted, Ta =25℃, AVIN =12V, VCC =VDD =VREG, EN/CTL=5V, MODE=0V, RFS =180kΩ) Limits Parameter Symbol Unit Condition Min. Typ. Max. [Whole Device] AVIN Bias Current 1 AVIN Bias Current 2 AVIN Standby Current EN Low Voltage EN High Voltage EN Bias Voltage CTL Low Voltage CTL High Voltage CTL Bias Current [5V Regulator] VREG Input Voltage Maximum Current [5V Switch] EXTVCC Input Threshold Voltage Switch Resistance [Under-Voltage Lockout Protection] AVIN Threshold Voltage AVIN Hysteresis Voltage VREG Threshold Voltage VREG Hysteresis Voltage [H REG 3 TM IIN1 IIN2 IINstb ENlow ENhigh IEN CTLlow CTLhigh ICTL GND 2.3 GND 2.3 - 1200 150 0 12 1 1800 250 10 0.8 5.5 20 0.8 5.5 6 µA µA µA V V µA V V µA VIN=6.0 to 25V IREG=0 to 100mA EXTVCC=5V CTL=EN=0V VREG IREG 4.90 100 5.00 - 5.10 - V mA EVCC_UVLO REVCC 4.2 - 4.4 1.0 4.6 2.0 V Ω EXTVCC:Sweep up AVIN _ UVLO dAVIN _ UVLO VREG_ UVLO dVREG_ UVLO 4.1 100 4.1 100 4.3 160 4.3 160 4.5 220 4.5 220 V mV V mV VCC:Sweep up VCC:Sweep down VREG:Sweep up VREG:Sweep down Control Block] ton tonmax toffmin 400 10.0 500 22.0 450 600 40.0 550 nsec µsec nsec ON Time MAX ON Time MIN OFF Time [FET Block] High-side ON Resistance Low-side ON Resistance [SCP Block] SCP Startup Voltage Delay Ron_high Ron_low - 120 120 200 200 mΩ mΩ VSCP tSCP 0.420 - 0.490 1 0.560 - V ms When VFB: 30% down www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 3/17 2010.10- Rev.A BD95513MUV Technical Note Parameter [Over-Voltage Protection Block] OVP Detect Voltage [Soft Start Block] Charge Current Standby Voltage [Current Regulation Block] Maximum Output Current [Voltage Detection Block] Feedback Terminal Voltage 1 Feedback Terminal Voltage 2 Feedback Terminal Bias Current [MODE Block] SLLMTM Condition Forced Continuous Mode [Power Good Block] VFB Power Good Low Voltage VFB Power Good High Voltage Symbol Limits Min. Typ. Max. Unit Condition VOVP 0.812 0.840 0.868 V When VFB: 20% up Iss Vss_stb 1.4 - 2.2 - 3.0 100 µA mV IOCP 3 - - A VFB1 VFB2 IFB 0.693 0.690 -100 0.700 0.700 0 0.707 0.710 100 V V nA SLLMTM Longest low-gate off time: ∞ Continuous mode Ta =-10℃ to 100℃ Iout = 0A to 3A VthSLLM VthCONT VCC-0.5 GND - VCC 0.5 V V VFB PL VFB PH 0.605 0.745 0.63 0.77 0.655 0.795 V V When VFB: 10% down When VFB: 10% up www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 4/17 2010.10- Rev.A BD95513MUV ●Reference Data 100 100 Technical Note SLLMTM 80 100 SLLMTM 80 80 SLLMTM 60 η [%] η [%] η [%] Continuous Mode 60 Continuous Mode 60 Continuous Mode 40 QLLM 40 40 QLLM 20 20 QLLM 20 0 0.01 0 0 0.1 1 10 0.1 Io [A] 1 10 0.01 0.01 0.1 1 10 Io [A] Io [A] Fig.1 Io-Efficiency (VIN=7V,VOUT=2.5V) Fig.2 Io-Efficiency (VIN=12V,VOUT=2.5V) Fig.3 Io-Efficiency (VIN=19V,VOUT=2.5V) VOUT (50mV/div) 2µsec/div VOUT (50mV/div) 2µsec/div VOUT (50mV/div) 2µsec/div SW (10V/div) IOUT (2A/div) SW (10V/div) IOUT (2A/div) SW (10V/div) IOUT (2A/div) Fig.4 Transient Response (VIN=7V, VOUT=2.5V) Fig.5 Transient Response (VIN=12V, VOUT=2.5V) Fig.6 Transient Response (VIN=19V, VOUT=2.5V) 2µsec/div VOUT (50mV/div) VOUT (50mV/div) 2µsec/div VOUT (50mV/div) 2µsec/div SW (10V/div) IOUT (2A/div) SW (10V/div) IOUT (2A/div) SW (10V/div) IOUT (2A/div) Fig.7 Transient Response (VIN=7V, VOUT=2.5V) Fig.8 Transient Response (VIN=12V, VOUT=2.5V) Fig.9 Transient Response (VIN=19V, VOUT=2.5V) 2µsec/div VOUT IL VOUT IL 2µsec/div VOUT IL 2µsec/div HG LG HG LG HG LG Fig.10 SLLMTM Mode (IOUT=0A) www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. Fig.11 SLLMTM Mode (IOUT=0.4A) Fig.12 1 SLLMTM Mode (IOUT=1A) 5/17 2010.10- Rev.A BD95513MUV ●Reference Data 10µsec/div VOUT EN 10µsec/div Technical Note 200µsec/div VOUT 2[V/div] SW PGOOD Fig.13 QLLM Mode (IOUT=0A) Fig.14 QLLM Mode (IOUT=1A) Fig.15 PGOOD Rising Waveform 2msec/div EN VOUT 2[V/div] 200µsec/div VIN VOUT 2[V/div] SW IL 5[A/div] HG/LG PGOOD VOUT Fig.16 PGOOD Falling Waveform Fig.17 SCP Timer Latch Waveform Fig.18 VIN change (5→19V) VIN EN HG/LG VREG 2[V/div] VOUT 2[V/div] VOUT SW 400µsec/div Fig.19 VIN change (19→5V) Fig.20 EN wake up www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 6/17 2010.10- Rev.A BD95513MUV ●Block Diagram Technical Note VREG VCC VIN AVIN SS VDD Soft Start SS 5 1 2 3 VREF×0.85 VSS×0.85 VOUT ILIM OCP HG R Q MODE 4 26 SW BOOT VIN VIN(4.5~28V) 13 EN 10 8 CTL 7 VREG AVIN UVLO 16 Reference Block VREG REF(0.7V) 17 6 PGOOD FB 18 Delay SCP 27 MODE EN SS REF×1.2 FB OVP H3RegTM Controller Block 28 29 MODE S VOUT Power Good Driver Circuit LG 30 31 21 22 23 24 25 32 VREG VDD PGND EXTVCC 14 AVIN UVLO ILIM SCP TSD 5V Reg Thermal Protection TSD EN/UVLO 20 19 CE MODE 15 11 9 12 VOUT VREG FS MODE GND www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 7/17 2010.10- Rev.A BD95513MUV ●Pin Configuration PGND PGND PGND 24 PGND 25 SW 26 SW 27 SW 28 SW 29 SW 30 SW 31 PGND 32 1 VIN 2 VIN 3 VIN 4 VIN 5 6 7 8 23 22 VDD 21 CE 20 VOUT 19 FB 18 REF 17 16 SS 15 VREG 14 EXTVcc 13 VCC 12 GND 11 FS 10 EN 9 MODE Technical Note BOOT PGOOD AVIN CTL *Connect the underside (FIN) to the ground terminal ●Pin Function Table PIN No. 1-4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22-25 26-31 32 Underside PIN Name VIN BOOT PGOOD AVIN CTL MODE EN FS GND VCC EXTVCC VREG SS REF FB VOUT N.C. VDD PGND SW PGND FIN Power supply input (5 V) Power ground Output to inductor Power ground Substrate connection Battery voltage input (4.5 ~ 28 V) HG driver power supply Power good output (high when output ±10% of regulation) Battery voltage sense Linear regulator on/off (high = 5.0V, low = off) Control mode selection GND : Continuous Mode 3.0V : QLLM VCC : SLLMTM Enable output (high when VOUT ON) Switching frequency adjustment(RFS = 30 k ~ 100 kΩ) Sense ground Power supply input External power supply input IC reference voltage (5.0V / 200mA) Soft start condenser input Output reference voltage (0.7 V) Feedback input (0.7 V) Voltage discharge output PIN Function www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 8/17 2010.10- Rev.A BD95513MUV Technical Note ●Pin Descriptions ・VCC This pin supplies power to the IC’s internal circuitry, excluding the FET driver. The input supply voltage range is 4.5 to 5.5V, with a maximum current draw of 900µA. This pin should be bypassed with a capacitance of approximately 0.1µF. ・EN Enables or disables the switching regulator. When the voltage on this pin reaches 2.3 V or higher, the internal switching regulator is turned on. At voltages less than 0.8 V, the regulator is turned off. ・VDD This pin supplies power to the low side of the FET driver, as well as to the bootstrap diode. As the diode draws its peak current when switching on or off, this pin should be bypassed with a capacitance of approximately 1 µF. ・VREG Output pin from the 5 V linear regulator. This pin also supplies power to the internal driver and control circuitry. VREG standby function is controlled by the CTL pin. The output supplies 5V at 100 mA and should be bypassed to ground using a 10 µF capacitor with a rating of X5R or X7R. ・EXTVCC External power supply input for the linear regulator. When the voltage on the EXTVCC pin exceeds 4.4 V, the regulator uses it in conjunction with other power sources to supply VREG. Leave the EXTVCC pin floating when not in use. ・REF Reference voltage output pin. The reference voltage is set internally by the IC to 0.7 V, and the IC works to keep VREF approximately equal to VFB. Variations in voltage levels on this pin affect the output voltage, so the pin should be bypassed with a 100 pF ~ 0.1 µF ceramic capacitor. ・SS Soft start/stop pin. When EN is set high, the capacitor between the internal current source and SS-GND controls the startup time of the IC. When the voltage on the SS pin is lower than the REF output voltage (0.7 V), the output voltage is held at the same voltage as the SS pin. ・AVIN The BD95513MUV controls the duty cycle and output voltage based upon the input voltage at this pin, so voltage variations or oscillations on this line can cause operation to become unstable. This pin also acts as the voltage input for the switching block, so insufficient coupling impedance can also cause operation to become unstable. Therefore, this line should be bypassed with either a power capacitor or RC filter. ・FS Frequency-adjusting resistance input pin. Attaching a resistance of 30 k ~ 100 kΩ adjusts the switching frequency from 200 kHz ~ 1 MHz. ・BOOT This pin serves as the power source for the high side of the FET driver. A bootstrap diode is integrated within the IC. The maximum voltage on this pin should not exceed +30 V vs. GND or +7 V vs. SW. When operating the switching regulator, the operation of the bootstrap circuitry causes the BOOT voltage to swing from (VIN + VDD) ~ VDD. ・PGOOD Power good indicator. This open-drain output should be connected via a 100 kΩ pull-up resistor. ・MODE Mode selection pin. When low, the IC functions in forced-continuous mode; at voltages from 0V ~ 3V, QLLM mode; when TM high, SLLM mode. ・CTL Linear regulator control pin. When voltage is 2.3 V or higher, a logic HIGH is recognized and the internal regulator (VREG = 5 V) is switched on. At voltages of 0.8 V or lower, a logic LOW is recognized and the regulator is switched off. However, even if EN is logic HIGH, the switching regulator will not operate if CTL is logic LOW. ・FB Output voltage feedback input. VFB is held at 0.7 V by the IC. ・SW Output from the switching regulator to the inductor. This output swings from VIN ~ GND. The trace from the output to the inductor should be as short and wide as possible. ・VOUT Voltage output discharge pin. When EN is off, this output is pulled low. ・VIN Power supply input. The IC can accept any input from 4.5 V to 28 V. This pin should be bypassed directly to ground by a power capacitor. ・PGND Power ground terminal. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 9/17 2010.10- Rev.A BD95513MUV Technical Note ●Operation 3 TM CONTROLLA control system. The BD95513MUV is a switching regulator incorporating ROHM’s proprietary H Reg When VOUT drops suddenly due to changes in load, the system quickly restores the output voltage by extending the ton time interval. This improves the regulator’s transient response. When light-load mode is activated, the IC employs the Simple TM Light Load Mode (SLLM ) controller, further improving system efficiency. H3RegTM Control (Normal Operation) VFB VREF HG LG When VFB falls below the reference voltage (0.7V), 3 TM the H Reg CONTROLLA is activated; tON = VREF VIN × 1 [sec]・・・(1) f High gate output is determined by the above formula. (Rapid Changes in Load) VFB VREF When VOUT drops due to a sudden change in load and the voltage remains below VREF after the preprogrammed tON time interval has elapsed, the system quickly restores VOUT by extending the tON time, thereby improving transient response. tON+α Io HG LG Light Load Control TM (SLLM Mode) VFB VREF HG TM SLLM mode is enabled by setting the MODE pin to logic high. When the low gate is off and the current through the inductor is 0 TM function is (current flowing from VOUT to SW), the SLLM activated, disabling high gate output. If VFB falls below VREF again, the high gate is switched back on, lowering the switching frequency of the regulator and yielding higher efficiency when powering light loads. LG 0A (QLLM Mode) VFB VREF HG LG QLLM mode is enabled by setting the MODE pin to HiZ or middle voltage. When the lower gate is off and the current through the inductor is 0 (current flowing from VOUT to SW), QLLM mode is activated, disabling high gate output. If VFB falls below VREF within a programmed time interval (typ. 40 µs), the high gate is switched on, but if VFB does not fall below VREF, the lower gate is forced on, dropping VFB and switching the high gate back on. The minimum switching frequency is set to 25 kHz (T = 40 µs), which keeps the regulator’s frequency from entering the audible spectrum but yields less efficient results than SLLMTM mode. 0A www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 10/17 2010.10- Rev.A BD95513MUV ●Timing Chart ・Soft Start Function EN tSS SS Technical Note The soft start function is enabled when the EN pin is set high. Current control circuitry takes effect at startup, yielding a moderate “ramping start” in output voltage. Soft start timing and incoming current are given by equation (2) and (3) below: Soft start period: tSS = VREF×Css [sec] ・・・(2) 2µA(typ) VOUT Rush current: IIN(ON)= Co×VOUT tss [A] ・・・(3) IIN (Css: soft start capacitor; Co: output capacitor) ・Timer Latch-type Short Circuit Protection VREF×0.70 VOUT 1ms SCP When output voltage falls to VREF x 0.70 or less, the output short circuit protection engages, turning the IC off after a set period of time to prevent internal damage. When EN is switched back on or when UVLO is cleared, output continues. The time period before shutting off is set internally at 1ms. EN/UVLO ・Output Over-Voltage Protection VOUT VREF×1.2 HG When output reaches or exceeds VREF x 1.2, the output over-voltage protection is engaged, turning the low-side FET completely on to reduce the output (low gate on, high gate off). When the output falls, it returns to standard mode. LG Switching www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 11/17 2010.10- Rev.A BD95513MUV ●External Component Selection 1. Inductor (L) Selection Technical Note The inductor’s value directly influences the output ripple current. As formula (4) indicates below, the greater the inductance or switching frequency, the lower the ripple current: ΔIL VIN IL VOUT L Co [A]・・・(4) L×VIN×f The proper output ripple current setting is about 30% of maximum output current. ΔIL=0.3×IOUTmax. [A]・・・(5) L= (VIN-VOUT)×VOUT ΔIL×VIN×f [H]・・・(6) ΔIL= (VIN-VOUT)×VOUT (ΔIL: output ripple current, f: switching frequency) Output ripple current * Passing a current larger than the inductor’s rated current will cause magnetic saturation in the inductor and decrease system efficiency. In selecting the inductor, be sure to allow enough margin to assure that peak current does not exceed the inductor’s rated current value. * To minimize possible inductor damage and maximize efficiency, choose an inductor with a low DCR and ACR resistance. 2. Output Capacitor Selection (CO) VIN When determining the proper output capacitor, be sure to factor in the equivalent series resistance (ESR) and equivalent series inductance (ESL) required to set the output ripple voltage at 20 mV or more. VOUT L ESL ESR When selecting the limit of the inductor, be sure to allow enough margin for the output voltage. Output ripple voltage is determined by formula (7) below: ΔVOUT=ΔIL×ESR+ESL×ΔIL / TON・・・(7) (ΔIL: Ouput ripple current, ESR: equivalent series resistance, ESL: equivalent series inductance) Co Output Capacitor Give special consideration to the conditions of formula (7) for output capacitance. Also, keep in mind that the output rise time must be established within the soft start timeframe. Co≦ tss×(Ilimit-IOUT) VOUT ・・・(8) tss: Soft start timeframe (see p. 10, equation (2)) Ilimit: Maximum output current Choosing a capacitance that is too large can cause startup malfunctions, or in some cases, may engage the short circuit protection. 3. Input Capacitor Selection (CIN) VIN CIN In order to prevent extreme over-current conditions, the input capacitor must have a low enough ESR to fully support a large ripple in the output. The formula for RMS ripple current (IRMS) is given by equation (9) below: VOUT L IRMS=IOUT× Co VIN(VIN-VOUT) VIN IOUT 2 [A]・・・(9) When VIN=2×VOUT, IRMS= Input Capacitor A low-ESR capacitor is recommended to reduce ESR loss and maximize efficiency. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 12/17 2010.10- Rev.A BD95513MUV 4. Frequency Adjustment 500 450 Technical Note From top: VIN= 400 350 Frequency [kHz] 300 250 200 150 100 50 0 50 100 150 200 250 5V 7V 12V 19V 25V The resistance connected to the FS terminal adjusts the on-time (tON) during normal operation as illustrated to the left. When tON, input voltage and VREF voltage are known, the switching frequency can be determined by the following formula: VREF F= ・・・(10) VIN×tON However, real-life considerations (such as external MOSFET gate capacitance and switching time) must be factored in as they affect the overall switching rise and fall time. This leads to an increase in tON, lowering the total frequency slightly. Additionally, when output current lingers around 0A in continuous mode, this “dead time” also has an effect upon tON, further lowering the switching frequency. Confirm the switching frequency by measuring the current through the coil (at the point where current does not flow backwards) during normal operation. 300 RFS[kΩ] The BD95513MUV operates by feeding the output voltage back through a resistive voltage divider. The output voltage is set by the following equation (see schematic below): 1 R1+R2 Output Voltage = × VREF (0.7V) + 2 ×ΔIL×ESR・・・(11) R2 The switching frequency is also amplified by the same resistive voltage divider network: R1+R2 ×(frequency set by RFS) [Hz]・・・(12) fsw = R2 VIN REF(0.7V) H3RegTM CONTROLLA R S SLLM R1 VIN Q SLLMTM Driver Circuit Output Voltage ESR FB R2 www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 13/17 2010.10- Rev.A BD95513MUV ●Evaluation Board Circuit (Frequency=300kHz Continuous Mode/QLLM/SLLMTM Example Circuit) 12V VREG Technical Note VIN VREG EN 7 13 10 AVIN VCC EN BD95513MUV U1 VDD 21 C3 R4 MODE 9 MODE CTL VIN BOOT R1 C11 CTL 5V VREG(5V) VDD REF C4 8 C12 1~4 PGND L1 PGND 1.8V/3A C10 5 VOUT 14 EXTVCC 15 R9 VREG SW 26~31 D1 6 17 16 PGND PGOOD REF(0.7V) VOUT 22~25,32 PGND 19 C13 PGND R7 R6 C6 C7 C1 SS/ 11 TRACK FS C5 12 GND FB CE 20 18 GND ●Evaluation Board Parts List Part No U1 D1 C1 C3 C4 C5 C6 C7 C11 C12 C13 1µF 1µF 10µF 1000pF 0.1µF 1µF 10µF 0.1µF 220pF Value Company ROHM ROHM KYOCERA KYOCERA KYOCERA MURATA KYOCERA KYOCERA KYOCERA KYOCERA MURATA Part name BD95513MUV RB051L-40 CM105B105K06A CM105B105K16A CM316B106K06A GRM39X7R102K50 CM105B104K06A CM105B105K16A CM316B106M16A CM05B104K25A GRM39C0G221J50 Part No R1 R4 R6 R7 R8 R9 L1 C14 C15 C16 Value 10Ω 10Ω 180KΩ 31kΩ 20kΩ 100kΩ 1.8µH 470µF 1µF 1µF Company ROHM ROHM ROHM ROHM ROHM ROHM SUMIDA SANYO KYOCERA KYOCERA Part name MCR03 MCR03 MCR03 MCR03 MCR03 MCR03 CDEP104-1R8ML 2R5TPE470ML CM105B105K06A CM105B105K06A www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 14/17 R8 2010.10- Rev.A C14 BD95513MUV Technical Note ●Notes for use (1) Absolute maximum ratings Exceeding the absolute maximum ratings (such as supply voltage, temperature range, etc.) may result in damage to the device. In such cases, it may be impossible to identify problems such as open circuits or short circuits. If any operational values are expected to exceed the maximum ratings for the device, consider adding protective circuitry (such as fuses) to eliminate the risk of damaging the IC. (2) Power supply polarity Connecting the power supply in reverse polarity can cause damage to the IC. Take precautions when connecting the power supply lines. An external power diode can be added. (3) Power supply lines The PCB layout pattern should be designed to provide the IC with low-impedance GND and supply lines. To minimize noise on the supply and GND lines, ground and power supply lines of analog and digital blocks should be separated. For all power lines supplying ICs, connect a bypass capacitor between the power supply and the GND terminal. If using electrolytic capacitors, keep in mind that their capacitance is reduced at lower temperatures. (4) GND voltage The potential of the GND pin must be the minimum potential in the system in all operating conditions. (5) Thermal design Use thermal design techniques that allow for a sufficient margin for power dissipation in actual operating conditions. (6) Inter-pin shorts and mounting errors Use caution when positioning he IC for mounting on PCBs. The IC may be damaged if there are any connection errors or if pins are shorted together. (7) Operation in strong electromagnetic fields Exercise caution when using the IC in the presence of strong electromagnetic fields as doing so may cause the IC to malfunction. (8) ASO When using the IC, set the output transistor so that it does not exceed either absolute maximum ratings or ASO. (9) Thermal shutdown circuit The IC incorporates a built-in thermal shutdown circuit (TSD circuit), which is designed to shut down the IC only to prevent thermal overloading. It is not designed to protect the IC or guarantee its operation. Do not continue to use the IC if this circuit is activated, or in environments in which activation of this circuitry can be assumed. TSD ON Temp. [℃] (typ.) BD95513MUV 175 Hysteresis Temp. [℃] (typ.) 15 (10) Testing on application boards When testing the IC with application boards, connecting capacitors directly to low-impedance terminals can subject the IC to stress. Always discharge capacitors completely after each process or step. The IC’s power supply should be turned off completely before connecting it to or removing it from a jig or fixture during the evaluation process. To prevent damage from static discharge, ground the IC during assembly and use similar precautions during transport and storage. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 15/17 2010.10- Rev.A BD95513MUV Technical Note (11) Regarding IC input pins This monolithic IC contains P+ isolation and P substrate layers between adjacent elements in order to keep them isolated. PN junctions are formed at the intersection of these P layers with the N layers of other elements, creating parasitic diodes and/or transistors. For example (refer to the figure below): When GND > Pin A and GND > Pin B, the PN junction operates as a parasitic diode When GND > Pin B, the PN junction operates as a parasitic transistor Parasitic diodes occur inevitably in the structure of the IC, and the operation of these parasitic diodes can result in mutual interference among circuits, operational faults, or physical damage. Accordingly, conditions that cause these diodes to operate, such as applying a voltage lower than the GND voltage to an input pin (and thus to the P substrate) should be avoided. Resistance Pin A Pin A Transistor (NPN) Pin B C Pin B B E N B P P + N P + N P P+ N N P+ N C E Parasitic Elements GND N P Substrate Parasitic Element GND Parasitic Element Parasitic Elements GND P Substrate GND Example of IC Structure Other Adjacent Elements (12) Ground wiring traces When using both small-signal and large-current GND traces, the two ground traces should be routed separately but connected to a single ground potential within the application in order to avoid variations in the small-signal ground caused by large currents. Also ensure that the GND traces of external components do not cause variations on GND voltage. ●Power Dissipation 5.5 5.0 4.5 Power Dissipation : Pd (W) 4.0 3.5 3.0 2.5 ③2.06W ④ ③ ④4.56W ② ① IC Only Θj-a = 328.9 ℃/W IC mounted on 1-layer board 2 (with 20.2 mm copper thermal pad) Θj-a = 142.0 ℃/W IC mounted on 4-layer board 2 2 (with 20.2 mm pad on top layer, 5502 mm pad on layers 2,3) Θj-a = 60.7 ℃/W IC mounted on 4-layer board (with 5505mm pad on all layers) Θj-a = 27.4 ℃/W 2 2.0 1.5 1.0 0.5 0.0 0 25 50 75 100 125 150 ②0.88W ①0.38W Ambient Temperature: Ta(℃) VQFN032V5050 www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 16/17 2010.10- Rev.A BD95513MUV ●Ordering part number Technical Note B D 9 Part No. 5 5 1 3 M U V - E 2 Part No. Package MUV : VQFN032V5050 Packaging and forming specification E2: Embossed tape and reel VQFN032V5050 5.0 ± 0.1 5.0 ± 0.1 Tape Quantity Direction of feed Embossed carrier tape 2500pcs E2 The direction is the 1pin of product is at the upper left when you hold 1PIN MARK 1.0MAX S +0.03 0.02 -0.02 (0.22) ( reel on the left hand and you pull out the tape on the right hand ) 0.08 S C0.2 0.4 ± 0.1 32 3.4 ± 0.1 1 8 9 25 24 17 16 0.75 0.5 3.4 ± 0.1 +0.05 0.25 -0.04 1pin Direction of feed (Unit : mm) Reel ∗ Order quantity needs to be multiple of the minimum quantity. www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. 17/17 2010.10- Rev.A Notice Notes No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuelcontroller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. R1010A
BD95513MUV_10 价格&库存
很抱歉,暂时无法提供与“BD95513MUV_10”相匹配的价格&库存,您可以联系我们找货
