BD9673AEFJ_EVK
BD9673AEFJ_EVK
    ROHM(罗姆)
    KIT EVAL BD9673AEFJ BUCK REG
BD9673AEFJ_EVK 数据手册
Datasheet Single-chip Type with Built-in FET Switching Regulators Flexible Step-down Switching Regulators with Built-in Power MOSFET BD9673AEFJ ●General Description Output 1.5A and below High Efficiency Rate Step-down Switching Regulator Power MOSFET Internal Type BD9673AEFJ mainly used as secondary side Power supply, for example from fixed Power supply of 12V, 24V etc, Step-down Output of 1.2V/1.8V/3.3V/5V, etc, can be produced. This IC has external Coil/Capacitor down-sizing through 300kHz Frequency operation, inside Nch-FET SW for 45V “withstand-pressure” commutation and also, high speed load response through Current Mode Control is a simple external setting phase compensation system, through a wide range external constant, a compact Power supply can be produced easily. ●Features ■ Internal 200 mΩ Nch MOSFET ■ Output Current 1.5A ■ Oscillation Frequency 300kHz ■ Synchronizes to External Clock ( 200kHz~ 500kHz ) ■ Feedback Voltage 1.0V±1.0% ■ Internal Soft Start Function ■ Internal Over Current Protect Circuit, Low Input Error Prevention Circuit, Heat Protect Circuit ■ ON/OFF Control through EN Pin (Standby Current 0 A Typ.) ■ Package: HTSOP-J8 Package ●Key Specifications ■ Input Voltage ■ Ref. Precision (Ta=25℃) ■ Max Output Current ■ Operating Temperature ■ Max Junction Temperature ●Packages HTSOP-J8 7V to 42V ±1.0% 1.5A (Max.) -40℃ to 105℃ -55℃ to 150℃ 4.90mm x 6.00mm x 1.00mm HTSOP-J8 ●Applications ■ For Household machines in general that have 12V/24V Lines, etc. 0.01µF ●Typical Application Circuits 15µH CDRH105R (SUMIDA) Lx 5V/1.0A VOUT VCC RB056L-40 (ROHM) 47µF/15V GRM32EB31C476KE15 (murata) BST GND R1 120kΩ R2 30kΩ C1 open C2 R3 VC EN FB SYNC VCC 24V 10µF/35V GRM31EB3YA106KA12L (murata) EN ON/OFF control 6800pF SYNC 10kΩ Figure 1. Typical Application Circuit ○Structure:Silicon Monolithic Integrated Circuit www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・14・001 ○This product is not designed for normal operation with in a radioactive. 1/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Pin Configuration 8 7 6 5 Thermal Pad 1 2 3 4 Figure 2. Pin Configuration (TOP VIEW) ●Pin Description Pin No. Pin Name Description 1 Lx 2 GND 3 VC Error amplifier output 4 FB Inverting node of the trans conductance error amplifier 5 SYNC 6 EN Stand-by ON/OFF pin 7 BST Voltage Supply pin for High Side FET Driver 8 VCC Voltage input pin Terminal for inductor Ground pin Input pin of an external signal for the device synchronized by external signal ●Block Diagram ON/OF E VC TSD UVLO Reference REG VREF Current Sense AMP Shutdown F 1.0V + + Error Σ BS Current Comparator R Q + S 200mΩ LX Soft Start 10Ω Oscillator 300kH V VOU T GN SYN Figure 3. Block Diagram www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 2/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Description of Blocks 1. Reference This Block generates Error Amp Standard Voltage. Standard Voltage is 1.0V. 2. REG This is a Gate Drive Voltage Generator and 5V Low Saturation regulator for internal Circuit Power supply. 3. OSC This is a precise wave Oscillation Circuit with Operation Frequency fixed to 300 kHz fixed (self-running mode). To implement the synchronization feature connect a square wave (Hi Level: higher than 2V Low Level: lower than 0.8V ) to the SYNC pin. The synchronization frequency range is 200 kHz to 500 kHz. After connecting the rising edge of LX will be synchronized to the falling edge of SYNC pin signal after 3 count. At the synchronization remove the external clock, the device transitions self-running mode after 7 microseconds. 4. Soft Start A Circuit that does Soft Start to the Output Voltage of DC/DC Comparator, and prevents Rush Current during Start-up. Soft Start Time is set at IC internal, after 10ms from starting-up EN Pin, Standard Voltage comes to 1.0V, and Output Voltage becomes set Voltage. 5. ERROR AMP This is an Error amplifier what detects Output Signal, and outputs PWM Control Signal. Internal Standard Voltage is set to 1.0V. Also, C and R are connected between the Output (VC) Pin GND of Error Amp as Phase compensation elements. (See P.11) 6. ICOMP This is a Voltage-Pulse Width Converter that controls Output Voltage in response to Input Voltage. This compares the Voltage added to the internal SLOPE waveform in response to the FET WS Current with Error amplifier Output Voltage, controls the width of Output Pulse and outputs to Driver. 7. Nch FET SW This is an internal commutation SW that converts Coil Current of DC/DC Comparator. It contains 45V” with stand pressure” 200mΩ SW. Because the Current Rating of this FET is 2.0A included ripple current, please use at within 2.0A. The device has the circuit of over current protection for protecting the FET from over current. To detect OCP 2 times sequentially, the device will stop and after 13 msec restart. 8. UVLO This is a Low Voltage Error Prevention Circuit. This prevents internal circuit error during increase of Power supply Voltage and during decline of Power supply Voltage. It monitors VCC Pin Voltage and internal REG Voltage, And when VCC Voltage becomes 6.4V and below, it turns OFF all Output FET and turns OFF DC/DC Comparator Output, and Soft Start Circuit resets. Now this Threshold has Hysteresis of 200mV. 9. TSD This is a Heat Protect (Temperature Protect) Circuit. When it detects an abnormal temperature exceeding Maximum Junction Temperature (Tj=150℃), it turns OFF all Output FET, and turns OFF DC/DC Comparator Output. When Temperature falls, it has/with Hysteresis and automatically returns. 10. EN With the Voltage applied to EN Pin(6pin), IC ON/OFF can be controlled. When a Voltage of 2.0V or more is applied, it turns ON, at Open or 0V application, it turns OFF. About 550kΩ Pull-down Resistance is contained within the Pin. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 3/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Absolute Maximum Ratings Item VCC-GND Supply Voltage BST-GND Voltage BST-Lx Voltage Symbol Ratings Unit VCC 45 V VBST 50 V ⊿VBST 7 V EN-GND Voltage VEN 45 V Lx-GND Voltage VLX 45 V FB-GND Voltage VFB 7 V VC 7 V SYNC 7 V VC-GND Voltage SYNC-GND Voltage High-side FET Drain Current IDH 3.5 A Power Dissipation Pd 3.76(*1) W Topr -40~+105 ℃ Storage Temperature Tstg -55~+150 ℃ Junction Temperature Tjmax +150 ℃ Operating Temperature (*1)During mounting of 70×70×1.6t mm 4layer board (Copper area: 70mm×70mm).Reduce by 30.08mW for every 1℃ increase. (Above 25℃) ●Electrical Characteristics (Unless otherwise specified Ta=25℃, VCC=24V, Vo=5V,EN=3V ) Parameter Symbol Limits Min. Typ. Max. Unit Conditions Circuit Current Stand-by current of VCC Ist - 0 10 µA VEN=0V Circuit current of VCC Icc - 1 2 mA FB=1.2V Vuv 6.1 6.4 6.7 V Vuvhy - 200 300 mV fosc 270 300 330 kHz Dmax 85 91 97 % FB threshold voltage VFB 0.990 1.000 1.010 V Input bias current IFB -1.0 0 1.0 µA Error amplifier DC gain AVEA 700 7000 70000 V/V Trans Conductance GEA 110 220 440 µA/V Soft Start Time Tsoft 7 10 13 ms GCS 5 10 20 A/V Lx NMOS ON resistance RonH - 200 340 mΩ Lx pre-charge NMOS ON resistance RonL - 10 17 Ω Under Voltage Lock Out (UVLO) Detect Voltage Hysteresis width Oscillator Oscillating frequency Max Duty Cycle Error Amp VFB=0V IVC=±10µA, VC=1.5V Current Sense Amp VC to switch current transconductance Output www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 4/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ Over Current Detect Current Iocp 2 3.3 - A CTL ON VENON 2 - VCC V OFF VENOFF -0.3 - 0.8 V REN 2.7 5.5 11 µA High VSYNCH 2.0 - 5.5 V Low VSYNCL -0.3 - 0.8 V SYNC Pin input current REN 6 12 24 µA SYNC falling edge to LX rising edge delay tdelay 200 400 600 ns EN Pin Control voltage EN Pin input current VEN=3V SYNC SYNC Pin Control voltage VSYNC=3V ◎Not designed to withstand radiation. ●Operating Ratings(Ta=25℃) Item Power Supply Voltage Output Voltage Symbol Ratings Typ Max 7 - 42 V - VCC×0.7 V VCC VOUT Unit Min (*2) 1.0 (*2)Restricted by minimum on pulse typ. 200ns ●Detailed Description ◇Synchronizes to External Clock The SYNC pin can be used to synchronize the regulator to an external system clock. To implement the synchronization feature connect a square wave to SYNC pin. The square wave amplitude must transition lower than 0.8V and higher than 2.0V on the SYNC pin and have an on time greater than 100ns and an off time greater than 100ns. The synchronization frequency range is 200 kHz to 500 kHz. The rising edge of the LX will be synchronized to the falling edge of SYNC pin signal after SYNC input pulse 3 count. At the synchronization, the external clock is removed, the device transitions self-running mode after 7 microseconds. SYNC Set the latch for synchronization SYNC_LATCH 400nsec about 7µsec Lx Figure 4. Timing chart at Synchronization www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 5/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ◇The case of not using the function of synchronization Although the SYNC pin is pulled down by resistor in this device, if the function of the synchronization is not used, it is recommended to connect SYNC pin to ground. Figure 5. the method to disposal the SYNC pin without synchronization ◇SOFT START The soft start time of BD9673AEFJ is determined by the DCDC operating frequency (self-run mode 300 kHz ⇒10ms). If synchronization is used at the time of EN=ON, The soft start time is restricted by SYNC pin input pulse frequency. SYNC pin input pulse frequency is fosc_ex kHz, the soft start time is expressed by below equation. 300 Tss = fosc_ex × 10 [ms] ◇OCP operation The device has the circuit of over current protection for protecting the FET from over current. To detect OCP 2 times sequentially, the device will stop and after 13 msec restart. OCP threshold VC VC voltage discharged by OCP latch VC voltage rising by output connect to GND force the High side FET OFF by detecting OCP current (pulse by pulse protection) Lx output connect to GND VOUT OCP set the OCP latch by detecting the OCP current 2 times sequencially OCP latch reset after 13 msec (300kHz 4000 counts) OCP_LATCH Figure 6. Timing chart at OCP operation www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 6/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Reference Data (Unless otherwise specified, Ta=25℃, VCC=24V, Vo=5V, EN=3V) 2 1 0.9 0.8 1.5 VCC=42V 0.6 0.5 0.4 0.3 ICC[mA] ICC[uA] 0.7 VCC=36 V VCC=24V VCC=12V 1 Temp=105℃ Temp=25℃ 0.5 0.2 0.1 Temp=‐40℃ 0 0 Temp[℃ ] VCC[V] Figure 8. Standby Current Temperature Characteristics Figure 9. Circuit Current Power supply Voltage Characteristics 8 2 7 UVLO threshold[V] ICC[mA] 1.5 1 VCC=12V VCC=24V 0.5 6 5 detect voltage 4 reset voltage 3 2 VCC=36V 1 VCC=42V 0 0 Temp[℃ ] Temp[℃ ] Figure 11.. UVLO Threshold Temperature Characteristics 350 100 340 90 330 80 320 70 MAXDUTY[%] FREQUENCY[kHz] Figure 10.. Circuit Current Temperature Characteristics 310 300 290 280 60 50 40 30 270 20 260 10 250 0 Temp[℃ ] Temp[℃ ] Figure 12. Oscillation Frequency Temperature Characteristics www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 13. Max Duty Temperature Characteristics 7/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ 1.010  1.010  1.008  1.008  1.006  VCC=36V 1.004  VFB threshold[V] VFB threshold[V] 1.006  VCC=42V 1.002  1.000  0.998  0.996  0.994  VCC=12V VCC=24V 1.004  1.002  1.000  0.998  0.996  0.994  0.992  0.992  0.990  0.990  Temp[℃ ] VCC[V] Figure 15. FB Threshold Power supply Characteristics 16 14 Soft Start Time[ms] VC terminal current[uA] Figure 14. FB Threshold Voltage Temperature Characteristics 60 50 40 30 20 10 0 ‐10 ‐20 ‐30 ‐40 ‐50 ‐60 Temp=105℃ Temp=25℃ Temp=‐40℃ 12 10 8 6 4 2 VCC=12V VCC=24V VCC=36V VCC=42V 0 Temp[℃ ] VFB[V] Figure 16. FB Voltage - IVC Current Characteristics Figure 17. Soft Start Time Temperature Characteristics 20 PRECHARGE  FET RON [Ω] 300 HIGHSIDE  FET RON [mΩ] Temp=‐40℃ Temp=25℃ Temp=105℃ 250 200 150 100 50 15 10 5 0 0 Temp[℃ ] Temp[℃ ] Figure 18. Nch FET ON Resistance Temperature Characteristics www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 19. Pre-charge FET ON Resistance Temperature Characteristics 8/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ 6 VC to SW Current  transconductance[A/V] OCP_peak_current[A] 5 4 3 2 VCC=12V VCC=24V VCC=36V VCC=42V 1 0 Temp[℃ ] 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Temp[℃ ] Figure21. VC to SW current transconductance Temperature characteristics Figure 20. OCP Detect Current Temperature Characteristics 2 EN Threshold[V] 1.5 1 0.5 0 Temp[℃ ] Figure 22. EN Threshold Temperature Characteristics www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 9/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Example of Reference Application Circuit (Input 24V, Output 5.0V) 0.01µF 15µH CDRH105R (SUMIDA) Lx 5V/1.0A VOUT VCC RB056L-40 (ROHM) 47µF/15V GRM32EB31C476KE15 (murata) GND R1 120kΩ R2 30kΩ C2 C1 open R3 BST VC EN FB SYNC VCC 24V 10µF/35V GRM31EB3YA106KA12L (murata) EN ON/OFF control 6800pF SYNC 10kΩ Figure 23. Reference Application Circuit ●Reference Application Data (Example of Reference Application Circuit) Transformation Efficiency  η[%] 100 90 80 70 60 20 Phase Gain Gain VCC=24V 40 30 Phase VCC=12V 50 VCC=36V VCC=42V 10 0 LOAD CURRENT[mA] Figure 25. Frequency Response Characteristics (Io=0.5A) Figure 24. Electric Power Conversion Rate Figure 26. Frequency Response Characteristics (Io=1.0A) VOUT:200mV/div (AC) VOUT:200mV/div (AC) IL:1A/div (DC) IL:1A/div (DC) Figure 28. Load Response Characteristics (Io=1.5A→0A) Figure 27. Load Response Characteristics (Io=0A→1.5A) EN:5V/div (DC) LX:10V/div (DC EN:5V/div (DC) LX:10V/div (DC IL:0.5A/div (DC) VOUT:2V./div (DC) IL:0.5A/div (DC) VOUT:2V./div (DC) Figure 29. startup Waveform www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 30. Stop Waveform 10/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Example of Reference Application Circuit (Input 24V, Output 12V) Figure 31. Reference Application Circuit Transformation Efficiency  η[%] ●Reference Application Data (Example of Reference Application Circuit) 100 90 80 70 60 50 40 30 20 10 0 VCC=7V VCC=12V VCC=24V VCC=42V LOAD CURRENT[mA] Figure 32. Electric Power Conversion Rate Figure 33. Frequency Response Characteristics (Io=0.5A) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 34. Frequency Response Characteristics (Io=1.0A) 11/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Example of Reference Application Circuit (Input 24V, Output 3.3V) Figure 35. Reference Application Circuit Transformation Efficiency  η[%] ●Reference Application Data (Example of Reference Application Circuit) 100 90 80 70 60 50 40 30 20 10 0 VCC=24V VCC=36V VCC=42V LOAD CURRENT[mA] Figure 36. Electric Power Conversion Rate Figure 37. Frequency Response Characteristics (Io=0.5A) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 38. Frequency Response Characteristics (Io=3.0A) 12/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Example of Reference Application Circuit (Input 24V, Output -12V) Figure 39. Reference Application Circuit Transformation Efficiency  η[%] ●Reference Application Data (Example of Reference Application Circuit) 100 90 80 70 60 50 40 30 20 10 0 VCC=12V VCC=24V LOAD CURRENT[mA] Figure 40. Electric Power Conversion Rate Figure 41. Frequency Response Characteristics (Io=0.5A) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 42. Frequency Response Characteristics (Io=3.0A) 13/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Evaluation Board Pattern (Reference) Layout is a critical portion of good power supply design. There are several signals paths that conduct fast changing currents or voltages that can interact with stray inductance or parasitic capacitance to generate noise or degrade the power supplies performance. To help eliminate these problems, the VCC pin should be bypassed to ground with a low ESR ceramic bypass capacitor with B dielectric. Care should be taken to minimize the loop area formed by the bypass capacitor connections, the VCC pin, and the anode of the catch diode. See Fig.28 for a PCB layout example. The GND pin should be tied directly to the thermal pad under the IC and the thermal pad. The thermal pad should be connected to any internal PCB ground planes using multiple VIAs directly under the IC. The LX pin should be routed to the cathode of the catch diode and to the output inductor. Since the LX connection is the switching node, the catch diode and output inductor should be located close to the LX pins, and the area of the PCB conductor minimized to prevent excessive capacitive coupling. For operation at full rated load, the top side ground area must provide adequate heat dissipating area. The additional external components can be placed approximately as shown. It may be possible to obtain acceptable performance with alternate PCB layouts, however this layout has been shown to produce good results and is meant as a guideline. Figure 43. Evaluation Board Pattern Figure 44. Reference Board Pattern www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 14/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Power Dissipation It is shown below reducing characteristics of power dissipation to mount 70mm×70mm×1.6mmt PCB Junction temperature must be designed not to exceed 150℃. 4000 3760mW × × POWER DISSIPATION - mW 3500 i i i i 3000 i i i i × × × × 2500 2210mW 2000 1100mW 1500 1000 820mW 500 0 0 25 50 75 100 125 150 Ambient Temperature - ℃ t Figure 45. Power Dissipation ( 70mm×70mm×1.6mm 1layer PCB) ●Power Dissipation Estimate The following formulas show how to estimate the device power dissipation under continuous mode operations. They should not be used if the device is working in the discontinuous conduction mode. The device power dissipation includes: 2 1) Conduction loss: Pcon = IOUT × RonH × VOUT/VCC –9 2) Switching loss: Psw = 1.25 × 10 × VCC2 × IOUT × fsw 3) Gate charge loss: Pgc = 22.8 × 10–9 × fsw 4) Quiescent current loss: Pq = 1.0 × 10–3 × VCC Where: IOUT is the output current (A , RonH is the on-resistance of the high-side MOSFET Ω , VOUT is the output voltage (V). VCC is the input voltage (V), fsw is the switching frequency (Hz). Therefore Power dissipation of IC is the sum of above dissipation. Pd = Pcon + Psw + Pgc + Pq For given Tj, Tj =Ta + ja × Pd Where: Pd is the total device power dissipation (W), Ta is the ambient temperature (℃) Tj is the junction temperature (℃), ja is the thermal resistance of the package (℃) ●Application Components Selection Method (1) Inductor Something of the shield Type that Fulfills the Current Rating (Current value Ipecac below), with low DCR (Direct Current Resistance element) is recommended. Value of Inductor influences Inductor Ripple Current and becomes the cause of Output Ripple. In the same way as the formula below, this Ripple Current can be made small for as big as the L value of Coil or as high as the Switching Frequency. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 15/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ Ipeak =Iout + ⊿IL/2 [A] (1) ⊿IL= 1 Vout Vin-Vout × Vin L × f Δ [A] L (2) Figure 46. Inductor Current ( : Efficiency, ⊿IL: Output Ripple Current, f: Switching Frequency) For design value of Inductor Ripple Current, please carry out design tentatively with about 20%~50% of Maximum Input Current. ※When current that exceeds Coil rating flows to the coil, the Coil causes a Magnetic Saturation, and there are cases wherein a decline in efficiency, oscillation of output happens. Please have sufficient margin and select so that Peak Current does not exceed Rating Current of Coil. (2) Output Capacitor In order for Capacitor to be used in Output to reduce Output Ripple, Low Ceramic Capacitor of ESR is recommended. Also, for Capacitor Rating, on top of putting into consideration DC Bias Characteristics, please use something whose Maximum Rating has sufficient margin with respect to the Output Voltage. Output Ripple Voltage is looked for using the following formula. 1 Vpp=⊿IL× + 2π×f×Co ⊿IL×RESR [V] ・・・ (3) Please design in a way that it is held within Capacity Ripple Voltage. (3) Output Voltage Setting ERROR AMP internal Standard Voltage is 1.0V. Output Voltage is determined as seen in (4) formula. VOUT ERROR AMP R1 (R1+R2) FB Vo= R2 ×1.0 [V] ・・・ (4) R2 VREF 1.0V Figure 47.Voltage Return Resistance Setting Method (4) Bootstrap Capacitor Please connect from 0.01µF (Laminate Ceramic Capacitor) between BST Pin and Lx Pins. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 16/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ (5) Schottky diode Recommend selecting a diode which is satisfied with maximum input voltage of the application, and which is larger than maximum current rating. If Vf of Schottky diode is large, there is a possibility that Vf of internal parasitic diode and Vf of Schottky diode reverse and might cause IC error operation when increasing a difference in temperature with IC. Recommend using a diode with smaller Vf as possible, and location is recommended to be nearest to the pin. BD9673EFJ use below diode is recommended. 品番 VRM[V] IO[A] VF[V] IR[mA] RB050L-40 40 3 0.55 1 RB055L-30 30 3 0.55 3 (6) About Adjustment of DC/DC Comparator Frequency Characteristics Role of Phase compensation element C1, C2, R3 (See P.7. Example of Reference Application Circuit) Stability and Responsiveness of Loop are controlled through VC Pin which is the output of Error Amp. The combination of zero and pole that determines Stability and Responsiveness is adjusted by the combination of resistor and capacitor that are connected in series to the VC Pin. DC Gain of Voltage Return Loop can be calculated for using the following formula. Adc = Rl × Gcs × A EA × V FB Vout Here, VFB is Feedback Voltage (1.0V).AEA is Voltage Gain of Error amplifier (typ: 77dB), Gcs is the Trans-conductance of Current Detect (typ: 10A/V), and Rl is the Output Load Resistance value. There are 2 important poles in the Control Loop of this DC/DC. The first occurs with/ through the output resistance of Phase compensation Capacitor (C1) and Error amplifier. The other one occurs with/through the Output Capacitor and Load Resistor. These poles appear in the frequency written below. fp1 = GEA π×C1×AEA 1 fp2 = π×COUT×Rl Here, GEA is the trans-conductance of Error amplifier (typ: 220 µA/V). Here, in this Control Loop, one zero becomes important. With the zero which occurs because of Phase compensation Capacitor C1 and Phase compensation Resistor R3, the Frequency below appears. 1 fz 1 = 2 π × C1 × R3 Also, if Output Capacitor is big, and that ESR (RESR) is big, in this Control Loop, there are cases when it has an important, separate zero (ESR zero). This ESR zero occurs due to ESR of Output Capacitor and Capacitance, and exists in the Frequency below. fzESR = 1 2π× COUT × RESR (ESR zero) In this case, the 3rd pole determined with the 2nd Phase compensation Capacitor (C2) and Phase Correction Resistor (R3) is used in order to correct the ESR zero results in Loop Gain. This pole exists in the frequency shown below. 1 fp 3 = www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 2 π × C2 × R3 17/22 (Pole that corrects ESR zero) TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ The target of Phase compensation design is to create a communication function in order to acquire necessary band and Phase margin. Cross-over Frequency (band) at which Loop gain of Return Loop becomes “0” is important. When Cross-over Frequency becomes low, Power supply Fluctuation Response, Load Response, etc worsens. On the other hand, when Cross-over Frequency is too high, instability of the Loop can occur. Tentatively, Cross-over Frequency is targeted to be made 1/20 or below of Switching Frequency. Selection method of Phase Compensation constant is shown below. 1. Phase Compensation Resistor (R3) is selected in order to set to the desired Cross-over Frequency. Calculation of RC is done using the formula below. R3 = 2 π × COUT × fc GEA × GCS × Vout VFB Here, fc is the desired Cross-over Frequency. It is made about 1/20 and below of the Normal Switching Frequency (fs). 2. Phase compensation Capacitor (C1) is selected in order to achieve the desired phase margin. In an application that has a representative Inductance value (about several µH~20µH), by matching zero of compensation to 1/4 and below of the Cross-over Frequency, sufficient Phase margin can be acquired. C1 can be calculated using the following formula. C1 > 4 2π × R3 × fc RC is Phase compensation Resistor. 3. Examination whether the second Phase compensation Capacitor C2 is necessary or not is done. If the ESR zero of Output Capacitor exists in a place that is smaller than half of the Switching Frequency, a second Phase compensation Capacitor is necessary. In other words, it is the case wherein the formula below happens. 1 fs < 2π× COUT × RESR 2 In this case, add the second Phase compensation Capacitor C2, and match the frequency of the third pole to the Frequency fp3 of ESR zero. C2 is looked for using the following formula. COUT × RESR C2 = R3 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 18/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●I/O Equivalent Schematic Pin. Pin. No Name 1 Lx Pin. No Pin Equivalent Schematic Pin. Name BST SYNC VC 2 GND 7 BST 8 VCC Pin Equivalent Schematic 5 SYNC Lx GND GND VC EN 3 VC 6 VC EN GND GND FB 4 FB GND www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 19/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Operational Notes 1. Reverse Connection of Power Supply Connecting the power supply in reverse polarity can damage the IC. Take precautions against reverse polarity when connecting the power supply, such as mounting an external diode between the power supply and the IC’s power supply pins. 2. Power Supply Lines Design the PCB layout pattern to provide low impedance supply lines. Separate the ground and supply lines of the digital and analog blocks to prevent noise in the ground and supply lines of the digital block from affecting the analog block. Furthermore, connect a capacitor to ground at all power supply pins. Consider the effect of temperature and aging on the capacitance value when using electrolytic capacitors. 3. Ground Voltage Ensure that no pins are at a voltage below that of the ground pin at any time, even during transient condition. 4. Ground Wiring Pattern When using both small-signal and large-current ground traces, the two ground traces should be routed separately but connected to a single ground at the reference point of the application board to avoid fluctuations in the small-signal ground caused by large currents. Also ensure that the ground traces of external components do not cause variations on the ground voltage. The ground lines must be as short and thick as possible to reduce line impedance. 5. Thermal Consideration Should by any chance the power dissipation rating be exceeded the rise in temperature of the chip may result in deterioration of the properties of the chip. The absolute maximum rating of the Pd stated in this specification is when the IC is mounted on a 70mm x 70mm x 1.6mm glass epoxy board. In case of exceeding this absolute maximum rating, increase the board size and copper area to prevent exceeding the Pd rating. 6. Recommended Operating Conditions These conditions represent a range within which the expected characteristics of the IC can be approximately obtained. The electrical characteristics are guaranteed under the conditions of each parameter. 7. Inrush Current When power is first supplied to the IC, it is possible that the internal logic may be unstable and inrush current may flow instantaneously due to the internal powering sequence and delays, especially if the IC has more than one power supply. Therefore, give special consideration to power coupling capacitance, power wiring, width of ground wiring, and routing of connections. 8. Operation Under Strong Electromagnetic Field Operating the IC in the presence of a strong electromagnetic field may cause the IC to malfunction. 9. Testing on Application Boards When testing the IC on an application board, connecting a capacitor directly to a low-impedance output pin may subject the IC to stress. Always discharge capacitors completely after each process or step. The IC’s power supply should always be turned off completely before connecting or removing it from the test setup during the inspection process. To prevent damage from static discharge, ground the IC during assembly and use similar precautions during transport and storage. 10. Inter-pin Short and Mounting Errors Ensure that the direction and position are correct when mounting the IC on the PCB. Incorrect mounting may result in damaging the IC. Avoid nearby pins being shorted to each other especially to ground, power supply and output pin. Inter-pin shorts could be due to many reasons such as metal particles, water droplets (in very humid environment) and unintentional solder bridge deposited in between pins during assembly to name a few. 11. Unused Input Pins Input pins of an IC are often connected to the gate of a MOS transistor. The gate has extremely high impedance and extremely low capacitance. If left unconnected, the electric field from the outside can easily charge it. The small charge acquired in this way is enough to produce a significant effect on the conduction through the transistor and cause unexpected operation of the IC. So unless otherwise specified, unused input pins should be connected to the power supply or ground line. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 20/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ 12. Regarding the Input Pin of the IC This monolithic IC contains P+ isolation and P substrate layers between adjacent elements in order to keep them isolated. P-N junctions are formed at the intersection of the P layers with the N layers of other elements, creating a parasitic diode or transistor. For example (refer to figure below): When GND > Pin A and GND > Pin B, the P-N junction operates as a parasitic diode. When GND > Pin B, the P-N junction operates as a parasitic transistor. Parasitic diodes inevitably occur in the structure of the IC. The operation of parasitic diodes can result in mutual interference among circuits, operational faults, or physical damage. Therefore, conditions that cause these diodes to operate, such as applying a voltage lower than the GND voltage to an input pin (and thus to the P substrate) should be avoided. Figure48. Example of monolithic IC structure 13. Ceramic Capacitor When using a ceramic capacitor, determine the dielectric constant considering the change of capacitance with temperature and the decrease in nominal capacitance due to DC bias and others. 14. Area of Safe Operation (ASO) Operate the IC such that the output voltage, output current, and power dissipation are all within the Area of Safe Operation (ASO). 15. Thermal Shutdown Circuit(TSD) This IC has a built-in thermal shutdown circuit that prevents heat damage to the IC. Normal operation should always be within the IC’s power dissipation rating. If however the rating is exceeded for a continued period, the junction temperature (Tj) will rise which will activate the TSD circuit that will turn OFF all output pins. When the Tj falls below the TSD threshold, the circuits are automatically restored to normal operation. Note that the TSD circuit operates in a situation that exceeds the absolute maximum ratings and therefore, under no circumstances, should the TSD circuit be used in a set design or for any purpose other than protecting the IC from heat damage. 16. Over Current Protection Circuit (OCP) This IC incorporates an integrated overcurrent protection circuit that is activated when the load is shorted. This protection circuit is effective in preventing damage due to sudden and unexpected incidents. However, the IC should not be used in applications characterized by continuous operation or transitioning of the protection circuit. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 21/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet BD9673AEFJ ●Ordering part number B D 9 6 7 Part Number 3 A E F J - package EFJ : HTSOP-J8 E2 Packaging and forming specification E2: Embossed tape and reel ●External information HTSOP-J8(TOP VIEW) Part Number Marking D 9 6 7 3 A LOT Number 1PIN MARK www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 22/22 TSZ02201-0Q1Q0AJ00190-1-2 04.MAR.2014 Rev.004 Datasheet Notice Precaution on using ROHM Products 1. Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you (Note 1) , transport intend to use our Products in devices requiring extremely high reliability (such as medical equipment equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation (Pd) depending on Ambient temperature (Ta). When used in sealed area, confirm the actual ambient temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label QR code printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act, please consult with ROHM representative in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. ROHM shall not be in any way responsible or liable for infringement of any intellectual property rights or other damages arising from use of such information or data.: 2. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the information contained in this document. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet General Precaution 1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents. ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s representative. 3. The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or concerning such information. Notice – WE © 2014 ROHM Co., Ltd. All rights reserved. Rev.001
BD9673AEFJ_EVK 价格&库存
很抱歉,暂时无法提供与“BD9673AEFJ_EVK”相匹配的价格&库存,您可以联系我们找货
