BD9V100MUF-CE2
BD9V100MUF-CE2
    ROHM(罗姆)
    VFQFN24
    降压型 1A 16V~60V
BD9V100MUF-CE2 数据手册
Datasheet 16V to 60V, 1A 1ch 2.1MHz Synchronous Buck Converter Integrated FET For Automotive BD9V100MUF-C General Description Key Specifications      BD9V100MUF-C is a current mode synchronous buck converter integrating high voltage rating POWER MOSFETs. The wide range input 16V to 60V and very short minimum pulse width down to 20ns enables direct conversion from 48V battery to 3.3V at 2.1MHz operation by Nano Pulse ControlTM.   Features              Nano Pulse ControlTM Enables Direct Conversion 60V to 3.3V at 2.1MHz AEC-Q100 Qualified(Note 1) SW Minimum ON Time 20ns(Max) Synchronous Switching Regulator Integrating POWER MOSFETs Soft Start Function Current Mode Control Over Current Protection Input Under Voltage Lock Out Protection Input Over Voltage Lock Out Protection Thermal Shutdown Protection Output Over Voltage Protection Short Circuit Protection Wettable Frank QFN Package Input Voltage Range: 16V to 60V Output Voltage Range: 0.8V to 5.5V Output Current: 1A(Max) Operating Frequency: 1.9MHz to 2.3MHz Reference Voltage Accuracy: ±2% (-40°C to +125°C) Shutdown Circuit Current: 0µA(Typ) Operating Temperature Range: -40°C to +125°C Package VQFN24FV4040 W(Typ) x D(Typ) x H(Max) 4.00mm x 4.00mm x 1.00mm Enlarged View (Note 1) Grade 1 VQFN24FV4040 Wettable Flank Package Applications  Automotive Battery Powered Supplies  Industrial Equipment  Consumer Supplies Typical Application Circuit Figure 1. Application Circuit Nano Pulse ControlTM is a trademark of ROHM Co., Ltd. 〇Product structure : Silicon monolithic integrated circuit www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 14 • 001 〇This product has no designed protection against radioactive rays 1/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Pin Configuration (TOP VIEW) Figure 2. Figure of Terminal Placement Pin Description Pin No. Pin Name 1 EN 2 VIN 3 to 6 PVIN 7 to 10 PGND 11,12 N.C. 13,14 SW 15 BST 16 N.C. 17 VREGH 18 PGOOD 19 RT 20 COMP 21 GND 22 FB 23 VMON 24 N.C. - E-PAD www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 Function Enable pin. Apply Low-level (0.8V or lower) to turn this device off. Apply High-level (2.5V or higher) to turn this device on. Power supply input pin of the internal circuitry. Connect this pin to PVIN. Power supply input pins that are used for the output stage of the switching regulator. Connecting input ceramic capacitors with values of 2.2µF and 0.1µF to this pin is recommended. Power GND input pins. No connection pins. Leave these pins open, or connect PGND pin. Switching node pins. These pins are connected to the source of the internal the Top POWER MOSFET and the drain of the internal Bottom side POWER MOSFET. Connect the power inductor and the bootstrap capacitor 0.022µF and resistor 3.3Ω to these pins. Power supply pin of the internal the Top POWER MOSFET. Connect a 3.3Ω resistor to this pin in series with a 0.022µF bootstrap capacitor connected to SW pin. This capacitor’s voltage becomes the power supply of the Top POWER MOSFET gate driver. No connection pin. Leave this pin open. Internal power supply output pin. This node supplies power 5V(Typ) to other blocks which are mainly responsible for the control function of the switching regulator. Connect a ceramic capacitor with value of 2.2µF to ground. Power Good pin. This pin is in open drain configuration so pull-up resistor is needed to turn it HIGH or LOW. This pin is used for setting the switching frequency. Connect a frequency setting resistor between this pin and GND pin. Output of the gm error amplifier, and the input of PWM comparator. Connect phase compensation components to this pin. See page 23 on calculate the resistance and capacitance of phase compensation. Ground pin. VOUT voltage feedback pin. Inverting input node for the gm error amplifier. Connect output voltage divider to this pin to set the output voltage. See page 22 on how to compute for the resistor values. Short Circuit Protection threshold detect pin. This node is monitoring the output voltage and discharging it during shutdown. No connection pin. Leave this pin open. Exposed pad. Connect this pad to the internal PCB ground plane using multiple via holes to obtain excellent heat dissipation characteristics. 2/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Block Diagram Figure 3. Block Diagram www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 3/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Description of Blocks - ERRAMP The ERRAMP block is an error amplifier and its inputs are the reference voltage 0.8V(Typ) and the FB pin voltage. The duty of switching pulse is controlled by ERRAMP output COMP. Set output voltage with FB pin. Moreover, the external resistor and capacitor are required to COMP pin as phase compensation circuit (refer to Selection of the Phase Compensation Circuit RCOMP, CCOMP on page 23). - Soft Start The Soft Start block prevents the overshoot of the output voltage by gradually increasing the input of the error amplifier when the power supply turns ON to gradually increase the switching duty cycle. The soft start time is set to 1.1ms (fSW=2.1MHz). The soft start time can be changed by adjusting the oscillating frequency (refer to Soft Start Time on page 24). - EN This IC is in normal operation when the voltage at EN terminal is 2.5V or more. The IC will be shutdown when the voltage at EN terminal becomes open or 0.8V or less. - VREGH This block outputs a regulated 5V(Typ) and supplies it to different blocks in the chip. Connect 2.2µF ceramic capacitor to GND. - OSC (Oscillator) This circuit generates a clock signal that determines converter switching frequency which is 1.9MHz to 2.3MHz. The frequency of the clock can be set by a resistor connected between the RT pin and the GND pin (refer to page 24 Figure 38). The OSC output send the clock signal to PWM Logic. This clock is also used to set the Soft Start time and Protect block counter. - SLOPE This block generates a sawtooth waveform from OSC clock. The inductor current feedback is added to the sawtooth signal. - PWM COMP This block modulates duty cycle by comparing the COMP pin voltage and the sawtooth signal from the SLOPE block. - PWM Logic The PWM Logic block controls the POWER MOSFETs ON and OFF timings. In normal operation, the clock signal from OSC block determines the Top POWER MOSFET ON timing, and the PWM COMP block output determines the OFF timing. In addition, each protection output signal is passed to the PWM Logic and it controls proper protection functions. - TSD (Thermal Shutdown) This block is a thermal shutdown circuit. Both of the output MOSFETs are turned OFF and the VREGH is stopped to prevent thermal damage or a thermal-runaway of the IC when the chip temperature reaches to approximately 175°C(Typ) or more, and the operation comes back when the chip temperature comes down to 150°C(Typ) or less. Note that the thermal shutdown circuit is intended to prevent destruction of the IC itself. Therefore, it is highly recommended to keep the IC temperature always within the operating temperature range. Operation above operating temperature range will reduce the lifetime of the IC. - OCP (Over Current Protection) While the Bottom POWER MOSFET is ON, if the voltage between the drain and source exceeds the reference voltage which is internally set within IC, OCP will activate. This protection is a self-return type. This protection circuit is effective in preventing damage due to sudden and unexpected incidents. However, the IC should not be used in applications characterized by continuous operation of the protection circuit (e.g. when a load that significantly exceeds the output current capability of the chip is connected). - OVP (Over Voltage Protection) This is the output over voltage protection circuit. When the output becomes 120%(Typ) or more of the target voltage, both of the output MOSFETs are turned OFF and the regulator operation is stopped. When the output voltage becomes 110%(Typ) or less of the target voltage, it returns to normal operation. - UVLO (Under Voltage Lock-Out) UVLO is a protection circuit that prevents low voltage malfunction, especially during power up and down. It monitors the VIN power supply voltage. If VIN becomes 15.0V(Max) or less, both of the output MOSFETs are turned OFF and the regulator operation is stopped. When the input voltage becomes 16.0V(Max) or more, the regulator restarts the operation with Soft Start. - DRIVER This circuit drives the gate of the output POWER MOSFETs. - OVLO(Over Voltage Lock-Out) This is the input over voltage protection circuit. When the input voltage becomes 60.0V(Min) or more, the regulator is shutdown. When the input voltage becomes 59.0V(Min) or less the falling threshold, the regulator restarts the operation with SOFT START. This hysteresis is 1.0V(Typ). www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 4/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Description of Blocks - continued - PGD The PGOOD circuit is a reference voltage monitoring circuit. The PGOOD pin sets to Hi-Z when the FB voltage is 90%(Typ) or more and 110%(Typ) or less of reference voltage, otherwise the PGOOD pin is pulled down to GND. PGOOD detection has a hysteresis of 20mV(Typ) for each of the upper and lower thresholds. - SCP(Short Circuit Protection) The short circuit protection circuit. Depending on the level of the VIN terminal voltage and VMON terminal voltage, a reference pulse signal with varying ON time will be produced. If the SW ON time exceeds 2.5times(Typ) the ON time of this reference pulse signal for 2clk cycles, short circuit protection will be activated. Then the Top and Bottom POWER MOSFETs will be turned OFF. www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 5/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Absolute Maximum Ratings (Ta=25°C) Parameter Supply Voltage EN Input Voltage BST Voltage Symbol Rating Unit VIN, PVIN -0.3 to +70 V VEN -0.3 to VIN V VBST -0.3 to +70 V VSW -0.3 to VSW + 7 V -0.3 to +7 V VMON Input Voltage ΔVBST VFB, VRT, VCOMP, VPGOOD VVMON -0.3 to +7 V VREGH Input Voltage VVREGH -0.3 to +7 V Tstg -55 to +150 ˚C Tjmax 150 ˚C Voltage from SW to BST FB, RT, COMP, PGOOD Input Voltage Storage Temperature Range Maximum Junction Temperature Caution 1: Operating the IC over the absolute maximum ratings may damage the IC. The damage can either be a short circuit between pins or an open circuit between pins and the internal circuitry. Therefore, it is important to consider circuit protection measures, such as adding a fuse, in case the IC is operated over the absolute maximum ratings. Caution 2: Should by any chance the maximum junction temperature rating be exceeded the rise in temperature of the chip may result in deterioration of the properties of the chip. In case of exceeding this absolute maximum rating, increase the board size and copper area to prevent exceeding the maximum junction temperature rating. Thermal Resistance(Note 1) Parameter Symbol Thermal Resistance(Typ) 1s(Note 3) 2s2p(Note 4) Unit VQFN24FV4040 Junction to Ambient θJA 150.6 37.9 °C/W Junction to Top Characterization Parameter(Note 2) ΨJT 20 9 °C/W (Note 1) Based on JESD51-2A (Still-Air) (Note 2) The thermal characterization parameter to report the difference between junction temperature and the temperature at the top center of the outside surface of the component package. (Note 3) Using a PCB board based on JESD51-3. Layer Number of Measurement Board Single Material Board Size FR-4 114.3mm x 76.2mm x 1.57mmt Top Copper Pattern Thickness Footprints and Traces 70μm (Note 4) Using a PCB board based on JESD51-5, 7. Layer Number of Measurement Board 4 Layers Material Board Size FR-4 114.3mm x 76.2mm x 1.6mmt Top 2 Internal Layers Thermal Via(Note 5) Pitch Diameter 1.20mm Φ0.30mm Bottom Copper Pattern Thickness Copper Pattern Thickness Copper Pattern Thickness Footprints and Traces 70μm 74.2mm x 74.2mm 35μm 74.2mm x 74.2mm 70μm (Note 5) This thermal via connects with the copper pattern of all layers. www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 6/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Recommended Operating Conditions Parameter Symbol Min Typ Max Unit VIN 16 - 60 V Operating Temperature Topr -40 - +125 ˚C Output Voltage VOUT 0.8 - 5.5 V tONMIN - 9 20 ns Power Supply Voltage SW Minimum ON Time(Note 1) Output Current IOUT 0 - 1 A Switching Frequency fSW 1.9 2.1 2.3 MHz Input Capacitor(Note 2) CIN 1.2 - - µF Switching Frequency Setting Resistor RRT 6.9 7.5 8.1 kΩ (Note 1) This parameter is for 0.5A output. Not 100% tested. (Note 2) Ceramic capacitor is recommended. The capacitor value including temperature change, DC bias change, and aging change must be larger than minimum value (Refer to Selection of Input Capacitor CIN, CBLK on page 22). Also, the IC might not function properly when the PCB layout or the position of the capacitor is not good. Please check PCB Layout Design on page 30. Electrical Characteristics (Unless otherwise specified Ta=-40˚C to +125˚C, VIN=48V, VEN=5V) Parameter Symbol Min Shutdown Circuit Current ISDN - 0 Circuit Current ICC - 2.5 Reference Voltage VFB 0.784 0.800 FB Input Current Typ Max Unit Conditions 5 µA VEN=0V, Ta=105˚C 3.8 mA VFB=2.0V 0.816 V VFB=VCOMP IFB -1 0 +1 µA VFB=5.0V ICPSINK 35 60 85 µA VCOMP=1.0V, VFB=2V ICPSOURCE -85 -60 -35 µA VCOMP=1.0V, VFB=0V tSS 0.7 1.1 1.5 ms fSW=2.1MHz, RRT=7.5kΩ Top Power NMOS ON Resistance RONH - 600 900 mΩ IOUT=-50mA Bottom Power NMOS ON Resistance RONL - 400 600 mΩ Output Leak Current H IOLEAKH -5 0 +5 µA Output Leak Current L IOLEAKL -5 0 +5 µA IOUT=50mA VIN=70V, VEN=0V Ta=105˚C, VSW=0V VIN=70V, VEN=0V Ta=105˚C, VSW=70V Operating Output Switch Current of Overcurrent Protection ISW 1.5 2.4 3.3 A Oscillating Frequency fSW 1.9 2.1 2.3 MHz EN Threshold Voltage H VENH 2.5 - VIN V EN Threshold Voltage L VENL 0 - 0.8 V IEN - 8.5 20 µA VEN=5V VUV_ON 12.5 13.7 15.0 V VIN Falling VUV_OFF 13.5 14.7 16.0 V VIN Rising VOV_ON 60.0 62.5 65.0 V VIN Rising VOV_OFF 59.0 61.5 64.0 V VIN Falling OVP Threshold Voltage H VOVPH 0.87 0.96 1.05 V VFB Rising OVP Threshold Voltage L VOVPL V VFB Falling PGOOD L Hysteresis VPGDLH mV PGOOD H Threshold VPGDH PGOOD H Hysteresis VPGDHL 1.01 VFB x 0.98 40 VFB x 1.18 -4 VFB Falling VPGDL 0.92 VFB x 0.90 20 VFB x 1.10 -20 V PGOOD L Threshold 0.83 VFB x 0.82 4 VFB x 1.02 -40 PGOOD ON Resistance RPGD - 0.22 1 kΩ IPGOOD=10mA PGOOD Leak Current IPGD - 0 1 µA VPGOOD=5V COMP Pin Sink Current COMP Pin Source Current Soft Start Time(Note1) EN Input Current VIN Under Voltage Protection Detection Voltage VIN Under Voltage Protection Return Voltage VIN Over Voltage Protection Detection Voltage VIN Over Voltage Protection Return Voltage V RRT=7.5kΩ VFB Rising mV (Note 1) VFB transient time from 0.1V to 0.7V. (Note 2) Not 100% tested. www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 7/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C 30 0.815 25 0.81 Reference Voltage : VFB [V] SW Minimum ON Time : t ONMIN [ns] Typical Performance Curves 20 15 10 0.8 0.795 5 0.79 0 0.785 0 200 400 600 800 Output Current : IOUT [mA] -50 1000 0 50 100 Ambient Temperature : Ta [˚C] 150 Figure 4. SW Minimum ON Time vs Output Current Figure 5. Reference Voltage vs Ambient Temperature 2.25 100 90 2.2 80 2.15 70 Efficiency [%] Oscillating Frequency : fSW [MHz] 0.805 2.1 2.05 2 60 50 40 VIN=48V 30 1.95 20 1.9 10 1.85 0 -50 0 50 100 Ambient Temperature : Ta [˚C] VIN=16V 0 150 Figure 6. Oscillating Frequency vs Ambient Temperature www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 VIN=24V 0.2 0.4 0.6 0.8 Output Current : IOUT [A] 1 Figure 7. Efficiency vs Output Current (VOUT=5.5V, fSW=1.9MHz) 8/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C 1 1 0.75 0.75 0.5 0.5 Line Regulation[%] Load Regulation [%] Typical Performance Curves - continued 0.25 0 -0.25 0.25 0 -0.25 -0.5 -0.5 -0.75 -0.75 -1 -1 0 200 400 600 800 Output Current : IOUT [mA] 16 1000 60 Figure 9. Line Regulation (VOUT=5V, IOUT=500mA) 9 4 8 3.5 Ta=+125˚C 7 Circuit Current : ICC [mA] Shutdown Circuit Current : ISDN [μA] Figure 8. Load Regulation (VIN=48V, VOUT=5V) 27 38 49 Power Supply Voltage : VIN [V] 6 5 4 Ta=+125˚C 3 Ta=-40 ˚C, +25˚C 3 2.5 2 Ta=+25˚C 1.5 Ta=-40˚C 1 2 0.5 1 0 0 16 27 38 49 Power Supply Voltage : VIN [V] 16 60 Figure 10. Shutdown Circuit Current vs Power Supply Voltage (VEN=0V) www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 27 38 49 Power Supply Voltage : VIN [V] 60 Figure 11. Circuit Current vs Power Supply Voltage (VEN=VIN, No Switching) 9/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Typical Performance Curves - continued VIN (20V/div) VEN (20V/div) VOUT (2V/div) VOUT (2V/div) VSW (20V/div) VSW (20V/div) Time (1s/div) Time (500µs/div) Figure 12. Startup Waveform (VIN=48V, VOUT=5V, IOUT=0.5A) Figure 13. Startup and Shutdown Waveform (VIN=0V ↔ 70V, VOUT=5V, IOUT=0.5A) VOUT (2V/div) VSW (10V/div) VOUT (2V/div) VSW (10V/div) Time (50ms/div) Figure 14. VOUT Short and Release Waveform (VIN=48V) www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 Time (50ms/div) Figure 15. SW Short and Release Waveform (VIN=48V) 10/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C 350 3 300 2.5 Operating Output Switch Current of Overcurrent Protection : ISW [A] EN Input Current : IEN [μA] Typical Performance Curves - continued Ta=+125˚C 250 Ta=+25˚C 200 Ta=-40˚C 150 100 50 1.5 1 0.5 0 0 0 20 40 60 EN Input Voltage : VEN [V] -50 80 Figure 16. EN Input Current vs EN Input Voltage 0 50 100 Ambient Temperature : Ta[˚C] 150 Figure 17. Operating Output Switching Current of Over Current Protection vs Ambient Temperature (VIN=48V, VOUT=5V) 900 800 800 700 Bottom Power NMOS ON Resistance : R ONL [mΩ] Top Power NMOS ON Resistance : RONH [mΩ] 2 700 600 500 400 300 200 100 600 500 400 300 200 100 0 0 -50 0 50 100 Ambient Temperature : Ta[˚C] -50 150 Figure 18. Top Power NMOS ON Resistance vs Ambient Temperature www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 0 50 100 Ambient Temperature : Ta[˚C] 150 Figure 19. Bottom Power NMOS ON Resistance vs Ambient Temperature 11/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Typical Performance Curves - continued 5 3 Output Leak Current H : IOLEAKH [μA] EN Threshold Voltage H : VENH [V] 4.5 2.5 2 1.5 1 0.5 4 3.5 3 2.5 Ta=+125˚C 2 Ta=-40˚C, +25˚C 1.5 1 0.5 0 0 -50 0 50 100 Ambient Temperature : Ta[˚C] 150 0 5 500 4.5 450 4 3.5 3 2.5 2 1.5 Ta=+125˚C 1 Ta=-40˚C, +25˚C 0.5 80 Figure 21. Output Leak Current H vs Power Supply Voltage (EN=0V, SW=VIN) PGOOD ON Resistance : R PGD [Ω] Output Leak Current L : IOLEAKL [μA] Figure 20. EN Threshold Voltage H vs Ambient Temperature (VIN=48V, VOUT=5V) 20 40 60 Power Supply Voltage : VIN [V] 400 350 300 250 200 150 100 50 0 0 0 20 40 60 Power Supply Voltage : VIN [V] -50 80 Figure 22. Output Leak Current L vs Power Supply Voltage (EN=0V, SW=GND) www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 0 50 100 Ambient Temperature : Ta[˚C] 150 Figure 23. PGOOD ON Resistance vs Ambient Temperature 12/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Function Explanation 1. Nano Pulse ControlTM Nano Pulse ControlTM is an original technology developed by ROHM Co., Ltd. It enables to control voltage stably, which is difficult in the conventional technology, even in a narrow SW ON Pulse such as less than 50ns at typical condition. Therefore, high frequency switching operation become possible. BD9V100MUF-C is designed with 9ns(Typ) Minimum SW ON time for current sense and 2.1MHz(Typ) switching frequency by using this technology. (1) High VIN Low VOUT Operation Narrow SW ON Pulse enables direct convert of high output voltage to low output voltage. BD9V100MUF-C, the output voltage VOUT 3.3V can be output directly from the supply voltage VIN 60V at 2.1MHz. VIN (10V/div) = 60V VSW (10V/div) fSW 2.1MHz VOUT (10V/div) = 3.3V Time (100ns/div) Time (100ns/div) Figure 24. Switching Waveform (VIN=60V, VOUT=3.3V, IOUT=0.5A, fSW=2.1MHz) Figure 25. VIN VOUT Waveform (VIN=60V, VOUT=3.3V, IOUT=0.5A, fSW=2.1MHz) (2) Stable Startup Waveform Narrow SW ON Pulse enables stable output waveform even at startup. BD9V100MUF-C achieves a stable Soft Start operation under wide input voltage conditions. VEN (20V/div) VEN (20V/div) VSW (20V/div) VSW (20V/div) VOUT (1V/div) VOUT (1V/div) Time (500µs/div) Time (500µs/div) Figure 26. Startup Waveform (VIN=16V, VOUT=3.3V, IOUT=0.5A, fSW=2.1MHz) www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 Figure 27. Startup Waveform (VIN=60V, VOUT=3.3V, IOUT=0.5A, fSW=2.1MHz) 13/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Function Explanation - continued 2. Enable Operation Shutdown and startup of the IC can be controlled by the voltage applied to the EN pin. When EN voltage reaches 2.5V(Max) or more, the internal VREGH activates and the IC operates. When an EN voltage become 0.8V(Max) or less, the IC will be shutdown. Figure 28. Enable ON/OFF Timing Chart 3. Power Good When the output voltage is within the voltage range of ±10%(Typ), the PGOOD pin set Hi-Z. When the output voltage is outside the voltage range of ±10%(Typ), the PGOOD pin is pulled down with a built-in MOSFET of 0.22kΩ(Typ). Pull up the PGOOD pin to VREGH with a resistor of about 10kΩ to 100kΩ. Figure 29. PGOOD Timing Chart www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 14/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Protect function 1. Under Voltage Lockout (UVLO) Under Voltage Lockout monitors the VIN terminal voltages. When the VIN voltage is at 15.0V(Max) or less, both of the output MOSFETs are turned OFF and the regulator operation is stopped. When the input voltage becomes 16.0V(Max) or more, the regulator restarts the operation with Soft Start. Figure 30. UVLO Timing Chart www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 15/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Protect function - continued 2. Short Circuit Protection(SCP) The Short Circuit Protection function produces a reference pulse that has an ON time derived from V IN and VOUT. This reference pulse’s ON time is compared to the SW ON time. If the SW ON time exceeds 2.5times(Typ) of the expected SW ON time, and remains in that state for 2clk (clk = 1/fSW) cycles, it will stop both of the output MOSFETs for 32ms(Typ) and then restarts again. This protection circuit is effective in preventing damage due to sudden and unexpected incidents. However, the IC should not be used in applications characterized by continuous operation of the protection circuit (e.g. when a load that significantly exceeds the output current capability of the chip is connected). The assumed SW ON Time is obtained from the following formula: 1 𝑡𝑝𝑢𝑙𝑠𝑒 = 2.1[𝑀𝐻𝑧] × 1 𝑉𝑂𝑈𝑇 𝑉𝐼𝑁 𝑡𝑝𝑢𝑙𝑠𝑒_𝑐𝑙𝑎𝑚𝑝 = 2.1[𝑀𝐻𝑧] × [μs] 𝑉𝑂𝑈𝑇 𝑉𝐼𝑁 × 2.5 [μs] Figure31. SCP Timing Chart 3. Thermal Shutdown(TSD) When the chip temperature exceeds Tj=175°C(Typ), both of the output MOSFETs are turned OFF and the VREGH is stopped. The operation comes back when the chip temperature comes down to 150°C(Typ) or less. TSD prevents the IC from thermal runaway under abnormal conditions exceeding Tjmax=150°C. The TSD circuit operates in a situation that exceeds the absolute maximum ratings and therefore, under no circumstances should the TSD circuit be used in a set design or for any purpose other than protecting the IC from heat damage. Figure 32. TSD Timing Chart www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 16/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Protect function - continued 4. Over Current Protection (OCP) Over Current Protection detects the lower limit value of the inductor current. The OCP is designed at 2.4A(Typ). This circuit prevents the Top POWER MOSFET from turning ON until the inductor current IL falls below the OCP limit ISW. If OCP is detected 8times in 30µs(Typ), operation stops for 32ms(Typ) and then restarts again. This protection circuit is effective in preventing damage due to sudden and unexpected incidents. However, the IC should not be used in applications characterized by continuous operation of the protection circuit (e.g. when a load that significantly exceeds the output current capability of the chip is connected). Figure 33. OCP Timing Chart 5. Over Voltage Protection (OVP) Over Voltage Protection compares the feedback voltage with an internal reference voltage. When the feedback voltage exceeds 0.96V(Typ) or more, the Top and Bottom POWER MOSFETs will turn OFF. When the output voltage decreases to a value of 0.92V(Typ) or less, it goes back to normal operation. Figure 34. OVP Timing Chart www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 17/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Protect function - continued 6. Over Voltage Lockout(OVLO) Over Voltage Lockout monitors the VIN terminal voltage. When the VIN voltage is 60.0V(Min) or more, the chip will be on standby mode, and when the VIN voltage is 59.0V(Min) or less, the chip will startup again. Figure 35. OVLO Timing Chart www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 18/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Selection of Components Externally Connected Contact us if not use the recommended constant in the application circuit. Necessary parameters in designing the power supply are as follows: Table 1. Application Specification Parameter Input Voltage Symbol Specification Case VIN 16V to 60V Output Voltage VOUT 5.0V Output Ripple Voltage ΔVP-P 20mVp-p Output Current IOUT Min 0.1A / Typ 0.5A / Max 1.0A Switching Frequency fSW 2.1MHz Topr -40°C to +125°C Operating Temperature Range Figure 36. Application Sample Circuit www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 19/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Selection of Components Externally Connected - continued 1. Selection of the inductor LX value Role of the coil in the switching regulator is that it also serves as a filter for smoothing the output voltage to supply a continuous current to the load. The Inductor ripple current ΔIL that flows to the inductor becomes small when an inductor with a large inductance value is selected. Consequently, the voltage of the output ripple ΔVP-P also becomes small. It is the trade-off between the size and the cost of the inductor. The inductance of the inductor is shown in the following equation: 𝐿= (𝑉𝐼𝑁(𝑀𝑎𝑥) −𝑉𝑂𝑈𝑇 )×𝑉𝑂𝑈𝑇 [H] 𝑉𝐼𝑁(𝑀𝑎𝑥) ×𝑓𝑆𝑊 ×∆𝐼𝐿 Where: 𝑉𝐼𝑁 (𝑀𝑎𝑥) 𝑉𝑂𝑈𝑇 𝑓𝑆𝑊 𝛥𝐼𝐿 is the maximum input voltage is the output voltage is the switching frequency is the peak to peak inductor current In current mode control, sub-harmonic oscillation may happen. The slope compensation circuit is integrated into the IC in order to prevent sub-harmonic oscillation. The sub-harmonic oscillation depends on the rate of increase of output switch current. If the inductor value is too small, the sub-harmonic oscillation may happen because the inductor ripple current ΔIL is increased. And if the inductor value is too large, the feedback loop may not achieve stability because the inductor ripple current ΔIL is decreased. Therefore, use an inductor value of the coil within the range of 3.3µH to 10µH. The smaller the ΔIL, the smaller the Inductor core loss (iron loss), and the smaller is the loss due to ESR of the output capacitor. In effect, ΔVP-P (Output peak-to-peak ripple voltage) will be reduced. ΔVP-P is shown in the following equation. ∆𝑉𝑃−𝑃 = ∆𝐼𝐿 × 𝐸𝑆𝑅 + 8×𝐶 ∆𝐼𝐿 𝑂𝑈𝑇 ×𝑓𝑆𝑊 [V] (a) Where: 𝐸𝑆𝑅 𝐶𝑂𝑈𝑇 𝛥𝐼𝐿 𝑓𝑆𝑊 is the equivalent series resistance of the output capacitor is the output capacitance is the peak to peak inductor current is the switching frequency Generally, even if ΔIL is somewhat large, the ΔVP-P target is satisfied because the ceramic capacitor has a very-low ESR. It also contributes to the miniaturization of the application board. Also, because of the lower rated current, smaller inductor is possible since the inductance is small. The disadvantages are increase in core losses in the inductor and the decrease in maximum output current. When other capacitors (electrolytic capacitor, tantalum capacitor, and electro conductive polymer etc.) are used for output capacitor COUT, check the ESR from the manufacturer's data sheet and determine the ΔIL to fit within the acceptable range of ΔVP-P. Especially in the case of electrolytic capacitor, because the decrease in capacitance at low temperatures is significantly large, this will make ΔVP-P increase. When using capacitor at low temperature, this is an important consideration. The shielded type (closed magnetic circuit type) is the recommended type of inductor to be used. Please note that magnetic saturation may occur. It is important not to saturate the core in all cases. Precautions must be taken into account on the given provisions of the current rating because it differs on every manufacturer. Please confirm the rated current at maximum ambient temperature of application to the manufacturer. www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 20/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Selection of Components Externally Connected - continued 2. Selection of Output Capacitor COUT The output capacitor is selected based on the ESR that is required from the equation (a). ΔVP-P can be reduced by using a capacitor with a small ESR. The ceramic capacitor is the best option that meets this requirement. It is because not only does it has a small ESR but the ceramic capacitor also contributes to the size reduction of the application circuit. Please confirm the frequency characteristics of ESR from the datasheet of the manufacturer, and consider a low ESR value for the switching frequency being used. It is necessary to consider the ceramic capacitor because the DC biasing characteristic is important. For the voltage rating of the ceramic capacitor, twice or more than the maximum output voltage is usually required. By selecting a high voltage rating, it is possible to reduce the influence of DC bias characteristics. Moreover, in order to maintain good temperature characteristics, the one with the characteristics of X7R or better is recommended. Because the voltage rating of a large ceramic capacitor is low, the selection becomes difficult for an application with high output voltage. In that case, please connect multiple ceramic capacitors in series or select electrolytic capacitor. Consider having a voltage rating of 1.2 times or more of the output voltage when using electrolytic capacitor. Electrolytic capacitors have a high voltage rating, large capacitance, small amount of DC biasing characteristics, and are generally reasonable. Since the electrolytic capacitor is usually OPEN when it fails, it is effective to use for applications when reliability is required such as automotive. But there are disadvantages such as, ESR is relatively high, and decreases capacitance value at low temperatures. In this case, please take note that ΔVP-P may increase at low temperature conditions. Moreover, consider the lifetime characteristic of this capacitor because it has a possibility to dry up. A tantalum capacitor and a conductive polymer hybrid capacitor have excellent temperature characteristics unlike the electrolytic capacitor. Moreover, since their ESR is smaller than an electrolytic capacitor, the ripple voltage is relatively-small over a wide temperature range. Since these capacitors have almost no DC bias characteristics, design will be easier. Regarding voltage rating, the tantalum capacitor is selected such that its capacitance is twice the value of the output voltage, and for the conductive polymer hybrid capacitor, it is selected such that the voltage rating is 1.2 times the value of the output voltage. The disadvantage of a tantalum capacitor is that it is SHORTED when it is destroyed, and its breakdown voltage is low. It is not generally selected in an application that reliability is a demand such as in automotive. An electro conductive polymer hybrid capacitor is OPEN when destroyed. Though it is effective for reliability, its disadvantage is that it is generally expensive. To improve the performance of ripple voltage in this condition, following is recommended: 1. Use low ESR capacitor like ceramic or conductive polymer hybrid capacitor. 2. Use a capacitor COUT with a higher capacitance value. These capacitors are rated in ripple current. The RMS values of the ripple current that can be obtained in the following equation must not exceed the ripple current rating. 𝐼𝐶𝑂(𝑅𝑀𝑆) = ∆𝐼𝐿 [A] √12 Where: 𝐼𝐶𝑂(𝑅𝑀𝑆) ∆𝐼𝐿 is the value of the ripple electric current is the peak to peak inductor current In addition, for the total value of capacitance in the output line COUT(Max), choose a capacitance value less than the value obtained by the following equation: 𝐶𝑂𝑈𝑇(𝑀𝑎𝑥) < 𝑡𝑆𝑆(𝑀𝑖𝑛) ×(𝐼𝑆𝑊(𝑀𝑖𝑛) −𝐼𝑆𝑊𝑆𝑇𝐴𝑅𝑇(𝑀𝑎𝑥) ) 𝑉𝑂𝑈𝑇 [F] Where: 𝐼𝑆𝑊(𝑀𝑖𝑛) 𝑡𝑆𝑆(𝑀𝑖𝑛) 𝐼𝑆𝑊𝑆𝑇𝐴𝑅𝑇(𝑀𝑎𝑥) 𝑉𝑂𝑈𝑇 is the OCP operation switch current (Min) is the Soft Start Time (Min) is the maximum output current during startup is the output voltage Startup failure may happen if the limits from the above-mentioned are exceeded. Especially if the capacitance value is extremely large, over-current protection may be activated by the inrush current at startup preventing the output to turn on. Please confirm this on the actual application. For stable transient response, the loop is dependent to COUT. Please select after confirming the setting of the phase compensation circuit. Also, in case of large changing input voltage and load current, select the capacitance accordingly by verifying that the actual application setup meets the required specification. www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 21/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Selection of Components Externally Connected - continued 3. Selection of Input Capacitor CIN, CBLK The input capacitor is usually required for two types of decoupling: capacitors C IN and bulk capacitors CBLK . Ceramic capacitors with values more than 1.2µF are necessary for the decoupling capacitor CIN. Ceramic capacitors are effective by placing it as close as possible to the VIN pin. The voltage rating of the capacitors is recommended to be more than 1.2 times the maximum input voltage, or twice the normal input voltage. The capacitor value including device variation, temperature change, DC bias change, and aging change must be larger than minimum value. Also, the IC might not operate properly when the PCB layout or the position of the capacitor is not good. Please check “Notes on the PCB Layout” on page 30. The bulk capacitor is optional. The bulk capacitor prevents the decrease in the line voltage and serves as a backup power supply to keep the input voltage constant. A low ESR electrolytic capacitor with large capacitance is suitable for the bulk capacitor. It is necessary to select the best capacitance value for each set of application. In that case, please take note not to exceed the rated ripple current of the capacitor. The RMS value of the input ripple current ICIN(RMS) is obtained in the following equation: 𝐼𝐶𝐼𝑁(𝑅𝑀𝑆) = 𝐼𝑂𝑈𝑇(𝑀𝐴𝑋) × √𝑉𝑂𝑈𝑇 ×(𝑉𝐼𝑁 −𝑉𝑂𝑈𝑇 ) 𝑉𝐼𝑁 [A] Where: 𝐼𝑂𝑈𝑇(𝑀𝐴𝑋) is the maximum output current. In addition, in automotive and other applications requiring high reliability, it is recommended to connect the capacitors in parallel to accommodate multiple electrolytic capacitors and minimize the chances of drying up. For ceramic capacitors, it is recommended to make two series + two parallel structures to decrease the risk of capacitor destruction due to short circuit conditions. When the impedance on the input side is high for some reason (because the wiring from the power supply to VIN is long, etc.), then high capacitance is needed. In actual conditions, it is necessary to verify that there are no problems like IC turns off, or the output overshoots due to the change in VIN at transient response. 4. Selection of Output Voltage Setting Resistance RFB1, RFB2 The output voltage is described by the following equation: 𝑉𝑂 = 0.8 × 𝑅𝐹𝐵1 +𝑅𝐹𝐵2 𝑅𝐹𝐵2 [V] Power efficiency is reduced with a small RFB1 + RFB2, please set the current flowing through the feedback resistors as small as possible in comparison to the output current IOUT. www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 22/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Selection of Components Externally Connected - continued 5. Selection of the Phase Compensation Circuit RCOMP, CCOMP A good high frequency response performance is achieved by setting the 0dB crossing frequency, fc, (frequency at 0dB gain) high. However, you need to be aware of the trade-off correlation between speed and stability. Moreover, DC / DC converter application is sampled by switching frequency, so the gain of this switching frequency must be suppressed. It is necessary to set the 0dB crossing frequency to 80kHz or less of the switching frequency. In general, target these characteristics as follows: - At 0dB crossing frequency, fc, phase lag should be 135˚ or less (phase margin is 45˚ or more). - The 0dB crossing frequency, fc, must be 80kHz or less. Achieving stability by using phase compensation is done by cancelling the f P1 and fP2 (error amp pole and power stage pole) of the feedback loop by the use of fZ1. fP1, fP2 and fZ1 are determined in the following equations: 𝑓𝑍1 = 2𝜋×𝑅 𝑓𝑃1 = 1 𝐶𝑂𝑀𝑃 ×𝐶𝐶𝑂𝑀𝑃 1 2𝜋×𝐶𝑂𝑈𝑇 ×𝑅𝑂𝑈𝑇 𝑓𝑃2 = 2𝜋×𝐶 𝐺𝐸𝐴 𝐶𝑂𝑀𝑃 ×𝐴𝑉 [Hz] [Hz] [Hz] Where: 𝑅𝑂𝑈𝑇 𝐺𝐸𝐴 𝐴𝑉 is the resistance assumed actual load[Ω] = Output Voltage[V] / Output Current[A]、 is the Error Amp trans conductance (300µA/V) is the Error Amp Voltage Gain (63dB) Figure 37. Setting the Phase Compensation Circuit www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 23/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Selection of Components Externally Connected - continued 6. Selection of the Switching Frequency Setting Resistance RRT The internal switching frequency can be set by connecting a resistor between RT and GND. The range of frequency that can be set is 1.9MHz to 2.3MHz, and the relation between resistance and the switching frequency is decided as shown in the figure below. When setting beyond this range, there is a possibility that there is no oscillation and IC operation cannot be guaranteed. Table 2. RRT vs fSW RRT [kΩ] 6.8 7.5 8.2 2.6 2.5 2.4 fSW [MHz] 2.26 2.10 1.96 fSW [MHz] 2.3 2.2 2.1 2.0 1.9 1.8 1.7 1.6 6 7 8 RRT[kΩ] 9 10 Figure 38. Switching Frequency vs Switching Frequency Setting Resistance 7. Selection of the Bootstrap Capacitor and Resistor Bootstrap capacitor CBST value shall be 0.022μF. Bootstrap resistor RBST value shall be 3.3Ω. Connect the bootstrap capacitor in series with the bootstrap resistor between SW pin and BST pin. Recommended products are described in Application Examples1 on page 25. 8. Selection of the VREGH Capacitor. VREGH capacitor CVREGH shall be 2.2μF ceramic capacitor. Connect the VREGH capacitor between VREGH pin and GND. 9. Selection of the VMON Resistor At the time of VOUT short circuit, current may be drawn from the VMON terminal due to an inductive load. Connect a resistor to limit that current. VMON resistor RVOUT shall be 2kΩ. 10. Soft Start Time Soft Start prevents the overshoot of the output voltage. It changes in proportion to the switching frequency fSW. Soft start time at fSW 2.1MHz(Typ) is 1.1ms(Typ). The production tolerance of tSS is ±36%. tSS can be calculated by using the equation. 𝑡𝑆𝑆 = 2310 𝑓𝑠𝑤 [s] www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 24/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Application Examples1 Table 3. Specification Example 1 Parameter Product Name Input Voltage Symbol Specification Case IC BD9V100MUF-C VIN 16V to 60V Output Voltage VOUT 5.0V Output Ripple Voltage ΔVP-P 20mVp-p Output Current IOUT 0A to 1.0A Switching Frequency fSW 2.1MHz Operating Temperature Topr -40°C to +125°C Figure 39. Reference Circuit 1 Table 4. Parts List 1 No Package Parameters Part Name (Series) Type Manufacturer CBLK - - - - - CIN1 3225 4.7µF, X7R, 50V GCM32ER71H475K Ceramic MURATA CIN2 3225 4.7µF, X7R, 50V GCM32ER71H475K Ceramic MURATA CIN3 1608 0.1µF, X7R, 50V GCM188R71H104K Ceramic MURATA CIN4 1608 0.1µF, X7R, 50V GCM188R71H104K Ceramic MURATA CBST 1608 0.022µF, X7R, 50V GCM188R71H223K Ceramic MURATA RBST 1608 3.3Ω, 5%, 1/10W MCR03EZPJ3R3 Chip Resistor ROHM CVREGH 2012 2.2µF, X7R ,16V GCM21BR71C225K Ceramic MURATA RPGD 1608 100kΩ, 0.5%, 1/10W MCR03EZPD1003 Chip Resistor ROHM RVOUT 1608 2.0kΩ, 0.5%, 1/10W MCR03EZPD2001 Chip Resistor ROHM R100 - Short - - - RFB1 1608 43kΩ, 0.5%, 1/10W MCR03EZPD4302 Chip Resistor ROHM RFB2 1608 8.2kΩ, 0.5%, 1/10W MCR03EZPD8201 Chip Resistor ROHM RRT 1608 7.5kΩ, 0.5%, 1/10W MCR03EZPD7501 Chip Resistor ROHM RCOMP 1608 51kΩ, 0.5%, 1/10W MCR03EZPD5102 Chip Resistor ROHM CCOMP 1608 1000pF, X7R, 50V GCM188R71H102K Ceramic MURATA LX - 4.7µH CLF6045NIT-4R7N-D Inductor TDK COUT1 3225 22µF, X7R, 16V GCM32ER71C226K Ceramic MURATA COUT2 3225 22µF, X7R, 16V GCM32ER71C226K Ceramic MURATA www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 25/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Application Examples1 - continued VOUT(10mV/div) Phase Gain Time (500ns/div) Figure 40. Frequency Characteristics (VIN=48V, VOUT=5V, IOUT=500mA) Figure 41. Ripple Voltage (VIN=48V, VOUT=5V, IOUT=500mA) VOUT(10mV/div) VOUT(100mV/div) IOUT(500mA/div) VIN(20V/div) Time (200µs/div) Figure 43. VIN Transient Response (VIN=16V ↔ 60V, VOUT=5V, IOUT=500mA) Figure 42. VIN Load Response (VIN=48V, VOUT=5V, IOUT=0A ↔ 1A) www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 Time (5ms/div) 26/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Application Examples2 Table 5. Specification Example 2 Parameter Symbol Specification Case Product Name IC BD9V100MUF-C Input Voltage VIN 16V to 60V Output Voltage VOUT 3.3V Output Ripple Voltage ΔVP-P 20mVp-p Output Current IOUT 0A to 1.0A Switching Frequency fSW 2.1MHz Topr -40°C to +125°C Operating Temperature Figure 44. Reference Circuit 2 Table 6. Parts List 2 No Package Parameters Part Name (Series) Type Manufacturer CBLK - - - - - CIN1 3225 4.7µF, X7R, 50V GCM32ER71H475K Ceramic MURATA CIN2 3225 4.7µF, X7R, 50V GCM32ER71H475K Ceramic MURATA CIN3 1608 0.1µF, X7R, 50V GCM188R71H104K Ceramic MURATA CIN4 1608 0.1µF, X7R, 50V GCM188R71H104K Ceramic MURATA CBST 1608 0.022µF, X7R, 50V GCM188R71H223K Ceramic MURATA RBST 1608 3.3Ω, 5%, 1/10W MCR03EZPJ3R3 Chip Resistor ROHM CVREGH 2012 2.2µF, X7R ,16V GCM21BR71C225K Ceramic MURATA RPGD 1608 100kΩ, 0.5%, 1/10W MCR03EZPD1003 Chip Resistor ROHM RVOUT 1608 2.0kΩ, 0.5%, 1/10W MCR03EZPD2001 Chip Resistor ROHM R100 - Short - - - RFB1 1608 47kΩ, 0.5%, 1/10W MCR03EZPD4702 Chip Resistor ROHM RFB2 1608 15kΩ, 0.5%, 1/10W MCR03EZPD1502 Chip Resistor ROHM RRT 1608 7.5kΩ, 0.5%, 1/10W MCR03EZPD7501 Chip Resistor ROHM RCOMP 1608 75kΩ, 0.5%, 1/10W MCR03EZPD7502 Chip Resistor ROHM CCOMP 1608 560pF, X7R, 50V GCM188R71H561K Ceramic MURATA LX - 4.7µH CLF6045NIT-4R7N-D Inductor TDK COUT1 3225 22µF, X7R, 16V GCM32ER71C226K Ceramic MURATA COUT2 3225 22µF, X7R, 16V GCM32ER71C226K Ceramic MURATA www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 27/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Application Examples2 - continued VIN (10mV/div) Phase Gain Time (500ns/div) Figure 45. Frequency Characteristics (VIN=48V, VOUT=3.3V, IOUT=500mA) Figure 46. Ripple Voltage (VIN=48V, VOUT=3.3V, IOUT=500mA) VOUT (100mV/div) VOUT (10mV/div) IOUT (500mA/div) VIN (20V/div) Time (5ms/div) Time (200µs/div) Figure 48. VIN Transient Response (VIN=16V ↔ 60V, VOUT=3.3V, IOUT=500mA) Figure 47. VIN Load Response (VIN=48V, VOUT=3.3V, IOUT=0A ↔ 1A) www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 28/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Automotive Power Supply Line Circuit BATTERY LINE Reverse-Touching Protection Diode D VIN BD9V100MUF-C L C TVS C π-type filter Figure 49. Automotive Power Supply Line Circuit As a reference, the automotive power supply line circuit example is given in Figure 49. π-type filter is a third-order LC filter. In general, it is used in combination with decoupling capacitors for high frequency. Large attenuation characteristics can be obtained and thus excellent characteristic as a EMI filter. Devices used for π-type filters should be placed close to each other. TVS (Transient Voltage Suppressors) is used for primary protection of the automotive power supply line. Since it is necessary to withstand high energy of load dump surge, a general zener diode is insufficient. Recommended device is shown in the following table. In addition, a reverse polarity protection diode is needed considering if a power supply such as BATTERY is accidentally connected in the opposite direction. Device Table 7. Reference Parts of Automotive Power Supply Line Circuit Part name (series) Manufacturer Device Part name (series) Manufacturer L CLF series TDK TVS SMB series Vishay L XAL series Coilcraft D S3A to S3M series Vishay C CJ series / CZ series NICHICON Recommended Parts Manufacturer List Shown below is the list of the recommended parts manufacturers for reference. Type Manufacturer URL Electrolytic Capacitor NICHICON www.nichicon-us.com Ceramic Capacitor Murata www.murata.com Inductor TDK product.tdk.com Inductor Coilcraft www.coilcraft.com Inductor SUMIDA www.sumida.com Diode Vishay www.vishay.com Resistor ROHM www.rohm.com www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 29/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C PCB Layout Design PCB layout design for DC/DC converter power supply IC is as important as the circuit design. Appropriate layout can avoid various problems caused by power supply circuit. Figure 50-a to 50-c show the current path in a buck converter circuit. The Loop 1 in Figure 50-a is a current path when H-side switch is ON and L-side switch is OFF, the Loop 2 in Figure 50-b is when H-side switch is OFF and L-side switch is ON. The thick line in Figure 50-c shows the difference between Loop1 and Loop2. The current in thick line change sharply each time the switching element H-side and L-side switch change from OFF to ON, and vice versa. These sharp changes induce several harmonics in the waveform. Therefore, the loop area of thick line that is consisted by input capacitor and IC should be as small as possible to minimize noise. For more detail refer to application note of switching regulator series “PCB Layout Techniques of Buck Converter”. Loop1 VIN H-side switch VOUT L CIN COUT L-side switch GND GND Figure 50-a. Current path when H-side switch = ON, L-side switch = OFF VIN VOUT L H-side switch CIN COUT Loop2 L-side switch GND GND Figure 50-b. Current path when H-side switch = OFF, L-side switch = ON VIN VOUT L CIN H-side FET COUT L-side FET GND GND Figure 50-c. Difference of current and critical area in layout www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 30/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C PCB Layout Design - continued When designing the PCB layout, please pay extra attention to the following points: - Place input capacitor on the same PCB surface as the IC and as close as possible to the IC’s PVIN terminal. - Switching nodes should be traced as thick and short as possible to the inductor, because they may induce the noise to the other nodes due to AC coupling. - Please keep the lines connected to FB and COMP away from the SW node as far as possible. - Please place output capacitor away from input capacitor to avoid harmonics noise from the input. - R100 is an option, used for feedback’s frequency response measurement. By inserting a resistor at R100, it is possible to measure the frequency response (phase margin) using a FRA. However, the resistor will not be used in actual application, please use this resistor pattern in short-circuit mode. Figure 51. Evaluation Board Layout Example www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 31/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Power Dissipation For thermal design, be sure to operate the IC within the following conditions. (Since the temperatures described hereunder are all guaranteed temperatures, take margin into account.) 1. 2. The ambient temperature Ta is to be 125 °C or less. The chip junction temperature Tj is to be 150 °C or less. The chip junction temperature Tj can be considered in the following two patterns: 1. To obtain Tj from the package surface center temperature Tt in actual use 𝑇𝑗 = 𝑇𝑡 + 𝜓𝐽𝑇 × 𝑊 [°C] 2. To obtain Tj from the ambient temperature Ta 𝑇𝑗 = 𝑇𝑎 + 𝜃𝐽𝐴 × 𝑊 [°C] Where: 𝜓𝐽𝑇 𝜃𝐽𝐴 is junction to top characterization parameter (Refer to page 6) is junction to ambient (Refer to page 6) The heat loss W of the IC can be obtained by the formula shown below: 𝑉𝑂𝑈𝑇 𝑉𝑂𝑈𝑇 + 𝑅𝑂𝑁𝐿 × 𝐼𝑂𝑈𝑇 2 (1 − ) 𝑉𝐼𝑁 𝑉𝐼𝑁 1 +𝑉𝐼𝑁 × 𝐼𝐶𝐶 + 2 × (𝑡𝑟 + 𝑡𝑓) × 𝑉𝐼𝑁 × 𝐼𝑂𝑈𝑇 × 𝑓𝑆𝑊 [W] 𝑊 = 𝑅𝑂𝑁𝐻 × 𝐼𝑂𝑈𝑇 2 × Where: 𝑅𝑂𝑁𝐻 𝑅𝑂𝑁𝐿 𝐼𝑂𝑈𝑇 𝑉𝑂𝑈𝑇 𝑉𝐼𝑁 𝐼𝐶𝐶 𝑡𝑟 𝑡𝑓 𝑓𝑆𝑊 is the Top Power NMOS ON Resistance (Refer to page 7) [Ω] is the Bottom Power NMOS ON Resistance (Refer to page 7) [Ω] is the Load Current [A] is the Output Voltage [V] is the Input Voltage [V] is the Circuit Current (Refer to page 7) [A] is the Switching Rise Time [s] (Typ:10ns) is the Switching Fall Time [s] (Typ:10ns) is the Switching Frequency [Hz] 1. 𝑅𝑂𝑁𝐻 × 𝐼𝑂𝑈𝑇 2 2. 𝑅𝑂𝑁𝐿 × 𝐼𝑂𝑈𝑇 2 3. 1 2 × (𝑡𝑟 + 𝑡𝑓) × 𝑉𝐼𝑁 × 𝐼𝑂 × 𝑓𝑆𝑊 Figure 52. SW Waveform www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 32/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C I/O Equivalent Circuit 1. EN 13,14 SW PVIN EN 400kΩ SW 572kΩ 15. BST 17. VREGH PVIN 10Ω BST VREGH VREGH SW 18. PGOOD 19. RT VREGH PGOOD 180Ω RT www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 33/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C I/O Equivalent Circuit - continued 20. COMP 22. FB VREGH VREGH VREGH FB 1kΩ 1kΩ COMP 23. VMON VREGH VMON 280kΩ 50kΩ www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 34/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Operational Notes 1. Reverse Connection of Power Supply Connecting the power supply in reverse polarity can damage the IC. Take precautions against reverse polarity when connecting the power supply, such as mounting an external diode between the power supply and the IC’s power supply pins. 2. Power Supply Lines Design the PCB layout pattern to provide low impedance supply lines. Furthermore, connect a capacitor to ground at all power supply pins. Consider the effect of temperature and aging on the capacitance value when using electrolytic capacitors. 3. Ground Voltage Except for pins the output and the input of which were designed to go below ground, ensure that no pins are at a voltage below that of the ground pin at any time, even during transient condition. 4. Ground Wiring Pattern When using both small-signal and large-current ground traces, the two ground traces should be routed separately but connected to a single ground at the reference point of the application board to avoid fluctuations in the small-signal ground caused by large currents. Also ensure that the ground traces of external components do not cause variations on the ground voltage. The ground lines must be as short and thick as possible to reduce line impedance. 5. Recommended Operating Conditions The function and operation of the IC are guaranteed within the range specified by the recommended operating conditions. The characteristic values are guaranteed only under the conditions of each item specified by the electrical characteristics. 6. Inrush Current When power is first supplied to the IC, it is possible that the internal logic may be unstable and inrush current may flow instantaneously due to the internal powering sequence and delays, especially if the IC has more than one power supply. Therefore, give special consideration to power coupling capacitance, power wiring, width of ground wiring, and routing of connections. 7. Operation Under Strong Electromagnetic Field Operating the IC in the presence of a strong electromagnetic field may cause the IC to malfunction. 8. Testing on Application Boards When testing the IC on an application board, connecting a capacitor directly to a low-impedance output pin may subject the IC to stress. Always discharge capacitors completely after each process or step. The IC’s power supply should always be turned off completely before connecting or removing it from the test setup during the inspection process. To prevent damage from static discharge, ground the IC during assembly and use similar precautions during transport and storage. 9. Inter-pin Short and Mounting Errors Ensure that the direction and position are correct when mounting the IC on the PCB. Incorrect mounting may result in damaging the IC. Avoid nearby pins being shorted to each other especially to ground, power supply and output pin. Inter-pin shorts could be due to many reasons such as metal particles, water droplets (in very humid environment) and unintentional solder bridge deposited in between pins during assembly to name a few. 10. Unused Input Pins Input pins of an IC are often connected to the gate of a MOS transistor. The gate has extremely high impedance and extremely low capacitance. If left unconnected, the electric field from the outside can easily charge it. The small charge acquired in this way is enough to produce a significant effect on the conduction through the transistor and cause unexpected operation of the IC. So unless otherwise specified, unused input pins should be connected to the power supply or ground line. www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 35/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Operational Notes – continued 11. Regarding the Input Pin of the IC This monolithic IC contains P+ isolation and P substrate layers between adjacent elements in order to keep them isolated. P-N junctions are formed at the intersection of the P layers with the N layers of other elements, creating a parasitic diode or transistor. For example (refer to figure below): When GND > Pin A and GND > Pin B, the P-N junction operates as a parasitic diode. When GND > Pin B, the P-N junction operates as a parasitic transistor. Parasitic diodes inevitably occur in the structure of the IC. The operation of parasitic diodes can result in mutual interference among circuits, operational faults, or physical damage. Therefore, conditions that cause these diodes to operate, such as applying a voltage lower than the GND voltage to an input pin (and thus to the P substrate) should be avoided. Resistor Transistor (NPN) Pin A Pin B C E Pin A N P+ P N N P+ N Pin B B Parasitic Elements N P+ N P N P+ B N C E Parasitic Elements P Substrate P Substrate GND GND Parasitic Elements GND Parasitic Elements GND N Region close-by Figure 53. Example of monolithic IC structure 12. Ceramic Capacitor When using a ceramic capacitor, determine a capacitance value considering the change of capacitance with temperature and the decrease in nominal capacitance due to DC bias and others. 13. Area of Safe Operation (ASO) Operate the IC such that the output voltage, output current, and the maximum junction temperature rating are all within the Area of Safe Operation (ASO). 14. Thermal Shutdown Circuit(TSD) This IC has a built-in thermal shutdown circuit that prevents heat damage to the IC. Normal operation should always be within the IC’s maximum junction temperature rating. If however the rating is exceeded for a continued period, the junction temperature (Tj) will rise which will activate the TSD circuit that will turn OFF all output pins. When the Tj falls below the TSD threshold, the circuits are automatically restored to normal operation. Note that the TSD circuit operates in a situation that exceeds the absolute maximum ratings and therefore, under no circumstances, should the TSD circuit be used in a set design or for any purpose other than protecting the IC from heat damage. 15. Over Current Protection Circuit (OCP) This IC incorporates an integrated overcurrent protection circuit that is activated when the load is shorted. This protection circuit is effective in preventing damage due to sudden and unexpected incidents. However, the IC should not be used in applications characterized by continuous operation or transitioning of the protection circuit. www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 36/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Ordering Information B D 9 V 1 0 Part Number 0 M U F - Package MUF: VQFN24FV4040 CE2 Product Rank C:for Automotive Packaging Specification E2: Embossed tape and reel Marking Diagrams VQFN24FV4040 (TOP VIEW) Part Number Marking 9 V 1 0 0 LOT Number 1PIN MARK www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 37/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Physical Dimension, Tape and Reel Information Package Name www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 VQFN24FV4040 38/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 BD9V100MUF-C Revision History Date Revision 01.Jun.2017 001 www.rohm.com © 2017 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 Changes New Release 39/39 TSZ02201-0J1J0AL01310-1-2 01.Jun.2017 Rev.001 Notice Precaution on using ROHM Products 1. (Note 1) If you intend to use our Products in devices requiring extremely high reliability (such as medical equipment , aircraft/spacecraft, nuclear power controllers, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are not designed under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation depending on ambient temperature. When used in sealed area, confirm that it is the use in the range that does not exceed the maximum junction temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used on a surface-mount products, the flow soldering method must be used on a through hole mount products. If the flow soldering method is preferred on a surface-mount products, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice-PAA-E © 2015 ROHM Co., Ltd. All rights reserved. Rev.003 Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label A two-dimensional barcode printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since concerned goods might be fallen under listed items of export control prescribed by Foreign exchange and Foreign trade act, please consult with ROHM in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. 2. ROHM shall not have any obligations where the claims, actions or demands arising from the combination of the Products with other articles such as components, circuits, systems or external equipment (including software). 3. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the Products or the information contained in this document. Provided, however, that ROHM will not assert its intellectual property rights or other rights against you or your customers to the extent necessary to manufacture or sell products containing the Products, subject to the terms and conditions herein. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice-PAA-E © 2015 ROHM Co., Ltd. All rights reserved. Rev.003 Datasheet General Precaution 1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents. ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s representative. 3. The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or concerning such information. Notice – WE © 2015 ROHM Co., Ltd. All rights reserved. Rev.001
BD9V100MUF-CE2
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种通信接口和外设,适用于多种嵌入式应用。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需参考引脚图。
4. 参数特性:主频72MHz,内置64KB Flash和20KB RAM,工作电压2.0V-3.6V。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(UART、SPI、I2C)等模块的详细功能描述。
6. 应用信息:适用于工业控制、医疗设备、消费电子等多种应用场景。
BD9V100MUF-CE2 价格&库存
很抱歉,暂时无法提供与“BD9V100MUF-CE2”相匹配的价格&库存,您可以联系我们找货
BD9V100MUF-CE2
    库存:44
    BD9V100MUF-CE2
    • 1+38.552611+5.01090
    • 10+29.1822210+3.79298
    • 25+26.8494325+3.48978
    • 100+24.28132100+3.15598
    • 250+23.05677250+2.99682
    • 500+22.99889500+2.98930
    库存:4541
    BD9V100MUF-CE2
    • 2500+21.070422500+2.73864
    库存:4541
    BD9V100MUF-CE2
      • 1+32.095421+4.17163
      • 5+29.964535+3.89466
      • 10+24.8190210+3.22587
      • 30+21.3831830+2.77930
      • 50+20.6976650+2.69019
      • 100+20.18559100+2.62364
      • 200+19.92955200+2.59036
      库存:2084
