BH6717NUV-E2
BH6717NUV-E2
    ROHM(罗姆)
    TDFN10
    IC MOTOR DRIVER 1.8V-5.5V 10VSON
BH6717NUV-E2 数据手册
DC Brushless Motor Drivers for Cooling Fans Three-Phase Full-Wave Fan Motor Driver for Note PC No.12010EAT18 BH6717NUV ●Description BH6717NUV is a three-phase sensorless fan motor driver used to cool off notebook PCs. It is controlled by a variable speed provided through the PWM input signal. Its feature is sensorless drive which doesn’t require a hall device as a location detection sensor and motor downsizing can be achieved by limiting the number of external components as much as possible. Furthermore, introducing a direct PWM soft switched driving mechanism achieves silent operations and low vibrations. ●Features 1) Speed controllable by PWM input signal 2) Sensorless drive 3) Soft switched drive 4) Power save function ●Applications small fan motor notebook PCs etc ●Absolute maximum ratings(Ta=25C) Parameter Symbol Ratings Unit VCC −0.3~6.5 V Pd 560 * mW Operating temperature Topr -25~+95 C Storage temperature Tstg -55~+125 C Iomax 700 ** mA FG signal output voltage VFG 6.5 V FG signal output current IFG 6 mA Tjmax 125 C Supply voltage Power dissipation Output current Junction temperature * ** Reduce by 5.6mW/C over 25/C. (On 70mm×70mm×1.6mm glass epoxy board) This value is not to exceed Pd. ●Operating conditions Parameter Operating supply voltage range Symbol Ratings Unit VCC 1.8 ~ 5.5 V *These specifications might change for their improvement etc. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. 1/10 2012.03 - Rev.A Technical Note BH6717NUV ●Electrical characteristics(Unless otherwise specified VCC=5V, Ta=25C) Parameter Symbol Limits Min. Typ. Max. - 20 50 Unit Conditions Circuit current STB ICST Circuit current ICC PWM input H level VPH 2.5 - VCC V PWM input L level VPL 0 - 0.7 V PWM input current H IPH - 0 1 μA PWM=VCC PWM input current L IPL -50 -20 - μA PWM=GND Input frequency FP 20 - 50 kHz FR input H level VFRH 4.5 - VCC V FR=H : Reverse drive FR input L level VFRL 0 - 0.5 V FR=L : Forward drive PWM off time TPO 500 1000 2000 μs Limit voltage VLM 0.2 0.25 0.3 V Output voltage VO - 0.25 0.325 V Io=250mA (H.L. total) FG low voltage VFGL - - 0.4 V IFG=5mA Lock protection det.time LDT - 0.5 - s Lock protection rel.time LRT 2.5 5 10 s Lock protection ratio RLT - 10 - - ●Package outlines 4 μA mA rel.time/det.time ratio (Unit:mm) Package : VSON010V3030 www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. 2/10 2012.03 - Rev.A Technical Note BH6717NUV ●Block diagram *1 *2 *3 *4 OSC : Oscillation circuit TSD : Thermal shutdowm(heat rejection circuit) Pre : Pre driver UVLO : Under voltage lock out circuit BEMF Det : Induced electromotive voltage detection circuit Det Level : Offset circuit Open collector output. A pull-up resistances of 10kΩ should be inserted. The wiring patterns from the VCC terminal and GND terminal to the bypass capacitor must be routed as short as possible. With respect to the wiring pattern, It has been confirmed that 0.03Ω for 1uF at the bypass capacitor doesn’t cause problems under our operation environment. This can be used as a reference value to check for validity. Be careful with the wattage because a large current may pass through the output current detection resistance. The current limit value is determined by the internal limit voltage value (typ.0.25V) and the output current detection resistance (See Description of Functional Operation 3.). Accordingly, the resistance of the wiring pattern routed from the RNF terminal and GND terminal to the output current detection resistance also affects to the current limit value, and therefore the resistance of the wiring pattern should be as small as possible. When it is noisy, Capacitance should be inserted between U,V,and W,. ●Pin assignment Pin No. Terminal name 1 FG 2 COM Coil midpoint terminal 3 VCC Power supply terminal 4 U 5 RNF 6 W W phase output terminal 7 V V phase output terminal 8 GND 9 FR 10 PWM www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. Function FG output terminal U phase output terminal Current limit detection terminal GND terminal Forward/Reverse switch terminal PWM signal input terminal 3/10 2012.03 - Rev.A Technical Note BH6717NUV ●Description of Function Operation 1. Sensorless Drive BH6717NUV is a motor driver IC for driving a three-phase brushless DC motor without a hall sensor.Detecting a rotor location firstly at startup, an appropriate logic for the rotation direction is obtained using this information and given to each phase to rotate the motor. Then, the rotation of the motor induces electromotive voltage in each phase wiring and the logic based on the induced electromotive voltage is applied to the each phase to continue rotating. 2. Lock Protection Feature, Automatic Recovery Circuit To prevent passing a coil current on any phase when a motor is locked, it is provided with a function which can turn OFF the output for a certain period of time and then automatically restore itself to the normal operation. During the motor rotation, an appropriate logic based on the induced electromotive voltage can be continuously given to each phase ; on the other hand, when the motor is locked, no induced electromotive voltage is obtained. Utilizing this phenomenon to take a protective against locking, when the induced electromotive voltage is not detected for a predetermined period of time (TON), it is judged that the motor is locked and the output is turned OFF for a predetermined period of time (TOFF).In Fig.1, the timing chart is shown. Motor unlock Motor lock Induced electromotive voltage detection Not Detecting Detecting TON Output ON Detecting TOFF Recover to the normal operation OFF ON FG Fig.1 3. Current limit circuit A current passing through the motor coil can be detected on the output current detection resistance to prohibit a current flow larger than a current limit value. The current limit value is determined by settings of the IC internal limit voltage: 0.25V (typ.) and the output current detection resistance value using the following equation: Internal limit voltage(0.25V ) Current limit value(mA) = Output current detection resistance(Ω) For example the RNF resistance is 0.5Ω, the current limit is activated at 500mA by calculation. 4. UVLO(Under voltage lock out circuit) In the operation area under the guaranteed operating power supply voltage of 1.8V (typ.), the transistor on the output can be turned OFF at a power supply voltage of 1.58V (typ.). A hysteresis width of 100mV is provided and a normal operation can be performed at 1.68V. This function is installed to prevent unpredictable operations, such as a large amount of current passing through the output, by means of intentionally turning OFF the output during an operation at a very low power supply voltage which may cause an abnormal function in the internal circuit. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. 4/10 2012.03 - Rev.A Technical Note BH6717NUV 5. Power saving function / Speed control by PWM input The power saving function is controlled by an input logic of the PWM terminal. (a) Operate mode when the PWM terminal is High. (b) Standby mode when the PWM terminal is Low for a time period of 1ms (typ.). When the PWM terminal is open, High logic is set. Input logic of the PWM terminal is set at Low and then the Standby mode becomes effective 1ms (typ.) (Fig.2). In the Standby mode, the lock protection function is deactivated and the lock protection is not effective. Therefore, this device can start up instantly even from the stop state when the input logic of the PWM terminal is set at High. PWM 1ms Power saving function normal mode standby mode Output ON OFF ON Lock protection function active inactive active normal mode Fig.2 ・Speed Control by PWM input Depending on the Duty value of the input signal on the PWM terminal, the output is controlled by switching between ON and OFF. The higher Duty value results in the higher motor rotation speed, while the lower Duty value the lower speed. 6. U,V,W phase and FG output signals In Fig.3, the timing charts of the output signals from the U, V and W phases as well as the FG terminal is shown. Assuming that a three-slot tetrode motor is used, two pulse outputs of FG are produced for one motorcycle. The three phases are excited in the order of U, V and W phases. U phase voltage V phase voltage W phase voltage FG Fig.3 www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. 5/10 2012.03 - Rev.A Technical Note BH6717NUV ●Equivalent circuit FG FR VCC 20 Ω 12 kΩ 30 k Ω COM PWM VCC VCC 2 kΩ 2 kΩ 2 kΩ 2 kΩ 2 kΩ 2 kΩ VCC 250k Ω 2 kΩ 10 kΩ GND U, V, W, RNF VCC U V W GND GND GND VCC 10 kΩ 12 kΩ 10 k Ω 10 kΩ 12 kΩ RNF 12 kΩ 2 kΩ 2 kΩ 2 kΩ 2 kΩ 2 kΩ 2 kΩ 12 kΩ 12 kΩ GND www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. 6/10 2012.03 - Rev.A Technical Note BH6717NUV ●Thermal derating curve Permissible dissipation (total loss) indicates the power that can be consumed by IC at Ta = 25ºC (normal temperature). IC is heated when it consumes power, and the temperature of IC chip becomes higher than ambient temperature. The temperature that can be accepted by IC chip depends on circuit configuration, manufacturing process, etc, and consumable power is limited. Permissible dissipation is determined by the temperature allowed in IC chip (maximum junction temperature) and thermal resistance of package (heat dissipation capability). The maximum junction temperature is in general equal to the maximum value in the storage temperature range. Heat generated by consumed power of IC is radiated from the mold resin or lead frame of package. The parameter which indicates this heat dissipation capability (hardness of heat release) is called heat resistance, represented by the symbol θja [C/W]. The temperature of IC inside the package can be estimated by this heat resistance. Below Figure shows the model of heat resistance of the package. Heat resistance θja, ambient temperature Ta, junction temperature Tj, and power consumption P can be calculated by the equation below: θja = (Tj-Ta) / P [℃/W] Thermal derating curve indicates power that can be consumed by IC with reference to ambient temperature. Power that can be consumed by IC begins to attenuate at certain ambient temperature. This gradient is determined by thermal resistance θja. Thermal resistance θja depends on chip size, power consumption, package ambient temperature, packaging condition, wind velocity, etc even when the same package is used. Thermal derating curve indicates a reference value measured at a specified condition. Below Figure shows a thermal derating curve. (Value when mounting FR4 glass epoxy board 70 [mm] x 70 [mm] x 1.6 [mm] (copper foil area below 3 [%])) θja = (Tj-Ta) / P [℃/W] Ambient temperature Ta [ºC] Chip surface temperature Tj [ºC]] Power consumption P[W] Thermal resistance Pd(mW) 750 600 560 450 300 150 0 * 25 50 75 95 100 125 150 Ta(℃) Above Ta = 25ºC, derating by 5.6 mW/ºC (When glass epoxy board of 70.0 mm x 70.0 mm x 1.6 mm is mounted) Thermal derating curve www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. 7/10 2012.03 - Rev.A Technical Note BH6717NUV ●Note for contents 1) To explain about function of operation, timing charts might be partly omitted. ●Location of IC 1) 2) (Generally three-phase sensorless driver IC) Generally, three-phase sensorless driver is rotated motor by detecting the induced electromotive voltage.Line noise, line resistance is influenced for detecting the induced electromotive voltage.From motor to IC line should be shorted, its suggest that location of IC is on the board of Motor in below Fig.4. In three-phase sensorless and variable speed driver, It is necessary to tuning motor and IC (each motor units). (Usually Motor maker does it to tuning motor and IC.) Motor Motor IC IC Board Board Fig.4 www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. 8/10 2012.03 - Rev.A Technical Note BH6717NUV ●Cautions on use 1) Absolute maximum ratings An excess in the absolute maximum rations, such as supply voltage, temperature range of operating conditions, etc., can break down the devices, thus making impossible to identify breaking mode, such as a short circuit or an open circuit. If any over rated values will expect to exceed the absolute maximum ratings, consider adding circuit protection devices, such as fuses. 2) Connecting the power supply connector backward Connecting of the power supply in reverse polarity can damage IC. Take precautions when connecting the power supply lines. An external direction diode can be added. 3) Power supply line Back electromotive force causes regenerated current to power supply line, therefore take a measure such as placing a capacitor between power supply and GND for routing regenerated current. And fully ensure that the capacitor characteristics have no problem before determine a capacitor value. (when applying electrolytic capacitors, capacitance characteristic values are reduced at low temperatures) 4) GND potential The potential of GND pin must be minimum potential in all operating conditions. Also ensure that all terminals except GND terminal do not fall below GND voltage including transient characteristics. However, it is possible that the motor output terminal may deflect below GND because of influence by back electromotive force of motor. Malfunction may possibly occur depending on use condition, environment, and property of individual motor. Please make fully confirmation that no problem is found on operation of IC. 5) Thermal design Use a thermal design that allows for a sufficient margin in light of the power dissipation (Pd) in actual operating conditions. 6) Inter-pin shorts and mounting errors Use caution when positioning the IC for mounting on printed circuit boards. The IC may be damaged if there is any connection error or if pins are shorted together. 7) Actions in strong electromagnetic field Use caution when using the IC in the presence of a strong electromagnetic field as doing so may cause the IC to malfunction. 8) ASO When using the IC, set the output transistor so that it does not exceed absolute maximum rations or ASO. 9) Thermal shut down circuit The IC incorporates a built-in thermal shutdown circuit (TSD circuit). Operation temperature is 150℃(Typ.) and has a hysteresis width of 15℃(Typ.). When IC chip temperature rises and TSD circuit works, the output terminal becomes an open state. TSD circuit is designed only to shut the IC off to prevent thermal runaway. It is not designed to protect the IC or guarantee its operation. Do not continue to use the IC after operation this circuit or use the IC in an environment where the operation of this circuit is assumed. 10) Testing on application boards When testing the IC on an application board, connecting a capacitor to a pin with low impedance subjects the IC to stress. Always discharge capacitors after each process or step. Always turn the IC’s power supply off before connecting it to or removing it from a jig or fixture during the inspection process. Ground the IC during assembly steps as an antistatic measure. Use similar precaution when transporting or storing the IC. 11) GND wiring pattern When using both small signal and large current GND patterns, it is recommended to isolate the two ground patterns, placing a single ground point at the ground potential of application so that the pattern wiring resistance and voltage variations caused by large currents do not cause variations in the small signal ground voltage. Be careful not to change the GND wiring pattern of any external components, either. 12) IC terminal input When VCC voltage is not applied to IC, do not apply voltage to each input terminal. When voltage above VCC or below GND is applied to the input terminal, parasitic element is actuated due to the structure of IC. Operation of parasitic element causes mutual interference between circuits, resulting in malfunction as well as destruction in the last. Do not use in a manner where parasitic element is actuated. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. 9/10 2012.03 - Rev.A Technical Note BH6717NUV ●Physical Dimension VSON010V3030 3.0±0.1 3.0±0.1 0.08 S S Embossed carrier tape Quantity 3000pcs E2 Direction of feed (0.22) +0.03 0.02 -0.02 1.0MAX 1PIN MARK Tape The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 2.0±0.1 0.5 1 5 10 6 1.2±0.1 0.4±0.1 0.5 C0.25 +0.05 0.25 -0.04 1pin (Unit : mm) www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. Reel 10/10 Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. 2012.03 - Rev.A Notice Notes No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuelcontroller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. R1120A
BH6717NUV-E2
物料型号:BH6717NUV
器件简介: - 该驱动器用于冷却笔记本电脑,通过PWM输入信号控制速度。 - 特点是无传感器驱动,不需要霍尔器件作为位置检测传感器,通过减少外部组件数量实现电机小型化。 - 引入直接PWM软开关驱动机制,实现静音操作和低振动。
引脚分配: - FG:FG输出端子 - COM:线圈中点端子 - VCC:电源端子 - U:U相输出端子 - RNF:电流限制检测端子 - W:W相输出端子 - V:V相输出端子 - GND:地端子 - FR:正反转开关端子 - PWM:PWM信号输入端子
参数特性: - 供电电压:-0.3V至6.5V - 最大功耗:560mW - 工作温度:-25°C至+95°C - 存储温度:-55°C至+125°C - 输出电流:最大700mA(注意:此值不超过最大功耗) - FG信号输出电压:6.5V - FG信号输出电流:6mA - 结温:最高125°C
功能详解: 1. 通过PWM输入信号控制速度。 2. 无传感器驱动,无需霍尔传感器。 3. 软开关驱动,减少电磁干扰和振动。 4. 省电功能,通过PWM输入逻辑控制。 5. 欠压锁定(UVLO)电路,防止在低电压下不稳定操作。
应用信息: - 适用于小型风扇电机,如笔记本电脑等。
封装信息: - 封装类型:VSON010V3030 - 封装尺寸:3.0mm x 3.0mm x 0.8mm(典型值)
BH6717NUV-E2 价格&库存
很抱歉,暂时无法提供与“BH6717NUV-E2”相匹配的价格&库存,您可以联系我们找货
