Data Sheet
220VAC Input/−5VDC (200mA) Output
Non-Isolated AC/DC Converter
BP5045A5
Absolute Maximum Ratings
Parameter Input voltage Output voltage ESD endurance Operating temperature range Storage temperature range Symbol Vi Io Vsurge Topr Tstg Limits −390 200 2 −20 to +80 −25 to +105 Unit V mApk kV C C
Dimensions (Unit : mm)
28.2MAX. 10.1MAX.
4.0 + 1.0 −
17.9MAX.
0.25+ 0.05 − 1 4 6 0.5+ 0.1 − + 1 . 3− 0 . 2 2.54 9=22.86(Typ.)
8
10 P=5.08+ 0.2 −
3.25MAX
(4.55)
Mark Side
(5.55)
Electrical Characteristics
Parameter Symbol Min. Input voltage range Vi −113 Output voltage Vo −4.7 Output current Io − Line regulation Vr − Load regulation Vl − Output ripple voltage Vp − Power conversion efficiency η 60 Typ. −311 −5.0 − 0.10 0.10 0.10 65 Max. −390 −5.3 200 0.15 0.15 0.20 − Unit V V mA V V Vp-p % Conditions DC Vi= −311V, Io=200mA ∗1 Vi= −311V Vi= −113 to −390V, Io=200mA Vi= −311V, Io=0 to 200mA Vi= −311V, Io=200mA ∗2 Vi= −311V, Io=200mA
250 200 150 100 50
Derating Curve
Derating Curve Output Current Io(mA)
Operation Range
0 -20-10 0 10 20 30 40 50 60 70 80 Ambient Temperature Ta( C)
90
∗1 Maximum output current must be reduced by ambient temperature. ∗2 An output ripple voltage sometimes changes in capacitor to use, the measurement environment.
Conversion Efficiency
Pin No. 1 2 3 4 5 6 7 8 9 10 Function Input Skip Skip Common Skip Power inductor Skip Power inductor Skip Output
Conversion Efficiency (%)
Application Circuit
BP5045A5
1
D1 R1
− C1 +
70 60 50 40 30 20 10
Conversion Efficiency (Ta=25 C, Vi=-311V)
4
6
L1
8
10
FUSE C3
0 0 20 40 60 80 100 120 140 160 180 200 Output Current Io(mA)
Vi
ZNR
Be sure to use fuse for safety.
C2 Vo
Load Regulation
Load Regulation (Ta=25 C, Vi=-311V) Output Voltage -Vo(V) 6.00 5.00 4.00 3.00 2.00 1.00 0.00 0 50 100 150 200 250 300 350 Output Current Io(mA)
Please verify operation and characteristics in the customer's circuit before actual usage. Ensure that the load current does not exceed the maximum rating. External Component Specifications FUSE: FUSE C1: Input Capacitor C2: Output Capacitor Use a fast-acting fuse of 1.0A. Rated voltage : More than 450V Capacitance : 22 to 100µF Rated voltage : More than 25V Capacitance : 100 to 1000µF, low impedance type ESR : Less than 0.18Ω Rated ripple current : More than 0.62Arms Evaluate under actual operating conditions. Rated voltage : More than 450V Film or ceramic capacitor Capacitance : 0.1 to 0.22µF ; Inductance : 1mH Rated Current : More than 0.41A The winding direction will affect the electrical characteristics. Resistance : 10 to 22Ω Power : More than 1/4W Peak reverse voltage : More than 800V Mean rectifying current : More than 1.0A Peak forward surge current : More than 20A Full-wave rectification can be used. If the input capacitance is large please use a rectifier diode with ample peak forward surge current. A varistor is required to protect against lightning surges and static electricity.
Surface Temperature Increase
Surface Temperature Increase (Ta=25 C, Vi=-311V) 40 35 30 25 20 15 10 5 0 0 20 40 60 80 100 120 140 160 180 200 Output Current Io(mA) Temperature Rising∆T( C)
C3: Noise Removal Capacitor L1: Power Inductor R1: Noise Removal Resistor D1: Rectifier Diode
Switching Frequency
Switching Frequency fSW(kHz)
ZNR: Varistor
20 18 16 14 12 10 8 6 4 2 0
Switching Frequency (Ta=25 C, Vi=-311V)
100 150 200 Output Current Io(mA)
250
www.rohm.com ©2010 ROHM Co., Ltd. All rights reserved.
1/1
2010.01 - Rev.A
Notice
Notes
No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuelcontroller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law.
Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us.
ROHM Customer Support System
http://www.rohm.com/contact/
www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved.
R1010A
很抱歉,暂时无法提供与“BP5045A5_10”相匹配的价格&库存,您可以联系我们找货
