Datasheet
Serial EEPROM series Standard EEPROM
I2C BUS EEPROM (2-Wire)
BR24G01-3A
●General Description
BR24G01-3A is a serial EEPROM of I2C BUS interface method
●Packages W(Typ.) x D(Typ.)x H(Max.)
●Features
All controls available by 2 ports of serial clock(SCL) and
serial data(SDA)
Other devices than EEPROM can be connected to the
same port, saving microcontroller port
1.6V to 5.5V single power source action most suitable
for battery use
1MHz action is possible (1.7V to 5.5V)
Up to 8 bytes in page write mode
Self-timed programming cycle
Low current consumption
Prevention of write mistake
Write (write protect) function added
Prevention of write mistake at low voltage
More than 1 million write cycles
More than 40 years data retention
Noise filter built in SCL / SDA terminal
Initial delivery state FFh
Not Recommended for
New Designs
DIP-T8
TSSOP-B8J
9.30mm x 6.50mm x 7.10mm
3.00mm x 4.90mm x 1.10mm
MSOP8
SOP8
5.00mm x 6.20mm x 1.71mm
2.90mm x 4.00mm x 0.90mm
SOP-J8
VSON008X2030
4.90mm x 6.00mm x 1.65mm
2.00mm x 3.00mm x 0.60mm
TSSOP-B8
3.00mm x 6.40mm x 1.20mm
Figure 1.
●BR24G01-3A
Capacity
Bit Format
Type
Power Source
Voltage
DIP-T8*1
BR24G01-3A
1Kbit
128×8
Package
BR24G01F-3A
SOP8
BR24G01FJ-3A
SOP-J8
BR24G01FVT-3A
1.6V to 5.5V
TSSOP-B8
BR24G01FVJ-3A
TSSOP-B8J
BR24G01FVM-3A
MSOP8
BR24G01NUX-3A
VSON008X2030
*1 Not Recommended for New Designs.
〇Product structure : Silicon monolithic integrated circuit
.www.rohm.com
© 2014 ROHM Co., Ltd. All rights reserved.
TSZ22111 • 14 • 001
〇This product is not designed protection against radioactive rays
1/33
TSZ02201-0R2R0G100580-1-2
11.Jun.2019 Rev.004
BR24G01-3A
●Absolute Maximum Ratings (Ta=25°C)
Parameter
Supply voltage
Power Dissipation
Symbol
Ratings
Unit
VCC
-0.3 to +6.5
V
Pd
Remarks
450 (SOP8)
When using at Ta=25°C or higher 4.5mW to be reduced per 1°C.
450 (SOP-J8)
330 (TSSOP-B8)
When using at Ta=25°C or higher 3.3mW to be reduced per 1°C.
310 (TSSOP-B8J)
mW
When using at Ta=25°C or higher 3.1mW to be reduced per 1°C.
310 (MSOP8)
300 (VSON008X2030)
When using at Ta=25°C or higher 3.0mW to be reduced per 1°C.
800 (DIP-T8*1)
When using at Ta=25°C or higher 8.0mW to be reduced per 1°C.
Storage Temperature
Tstg
-65 to +150
°C
Operation Temperature
Topr
-40 to +85
°C
-0.3 to Vcc+1.0
V
The Max value of input voltage / output voltage is not over 6.5V.
When the pulse width is 50ns or less, the Min value of input voltage
/ output voltage is not under -0.8V.
Junction Temperature
Tjmax
150
°C
Junction temperature at the storage condition
Electrostatic discharge
voltage
(human body model)
VESD
-4000 to +4000
V
Input Voltage /
Output Voltage
●Memory Cell Characteristics (Ta=25°C, Vcc=1.6V to 5.5V)
Limits
Parameter
Min.
Typ.
1,000,000
Write cycles *2
40
Data retention *2
Max
Unit
Times
Years
*2 Not 100% TESTED
●Recommended Operating Ratings
Parameter
Symbol
Supply voltage
Vcc
Input voltage
VIN
Ratings
1.6 to 5.5
0 to Vcc
Unit
V
●DC Characteristics
(Unless otherwise specified, Ta=-40 to +85°C, Vcc =1.6 to 5.5V)
Limits
Parameter
Symbol
Unit
Min.
Typ.
Max.
Input High Voltage1
VIH1
0.7Vcc
Input Low Voltage1
VIL1
-0.3*3
Input High Voltage2
VIH2
0.8Vcc
Input Low Voltage2
Output Low Voltage1
Output Low Voltage2
Conditions
Vcc+1.0
V
1.7V≤Vcc≤5.5V
0.3Vcc
V
1.7V≤Vcc≤5.5V
Vcc+1.0
V
1.6V≤Vcc
很抱歉,暂时无法提供与“BR24G01FVJ-3AGTE2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+2.72500
- 500+2.60194
- 1000+2.47887
- 国内价格 香港价格
- 1+0.793941+0.09604
- 10+0.7777410+0.09408
- 50+0.7615450+0.09212
- 100+0.74533100+0.09016
- 500+0.74533500+0.09016
- 1000+0.745331000+0.09016
- 2000+0.737232000+0.08918
- 4000+0.737234000+0.08918
