BR24L01AFV-WE2
BR24L01AFV-WE2
    ROHM(罗姆)
    LSSOP8
    1KBIT I²C接口EEPROM
BR24L01AFV-WE2 数据手册
Datasheet Serial EEPROM Series Standard EEPROM I2C BUS EEPROM (2-Wire) BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●General Description 2 BR24Lxxx-W series is a serial EEPROM of I C BUS interface method ●Features 2 „ Completely conforming to the world standard I C BUS. All controls available by 2 ports of serial clock (SCL) and serial data (SDA) „ Other devices than EEPROM can be connected to the same port, saving microcontroller port „ 1.8V to 5.5V *1 single power source action most suitable for battery use „ Page write mode useful for initial value write at factory shipment „ Highly reliable connection by Au pad and Au wire „ Auto erase and auto end function at data write „ Low current consumption *2 ¾ At write operation (5V) : 1.2mA (Typ.) ¾ At read operation (5V) : 0.2mA (Typ.) ¾ At standby operation (5V) : 0.1μA (Typ.) „ Write mistake prevention function ¾ Write (write protect) function added „ Write mistake prevention function at low voltage „ Data rewrite up to 1,000,000 times „ Data kept for 40 years „ Noise filter built in SCL / SDA terminal „ Shipment data all address FFh *1 *2 ●Packages W(Typ.) x D(Typ.) x H(Max.) SOP8 TSSOP-B8 5.00mm x 6.20mm x 1.71mm 3.00mm x 6.40mm x 1.20mm SOP- J8 TSSOP-B8J 4.90mm x 6.00mm x 1.65mm 3.00mm x 4.90mm x 1.10mm SSOP-B8 MSOP8 3.00mm x 6.40mm x 1.35mm 2.90mm x 4.00mm x 0.90mm VSON008X2030 BR24L02-W, BR24L16-W, BR24L32-W : 1.7V to 5.5V BR24L32-W, BR24L64-W : 1.5mA 2.00mm x 3.00mm x 0.60mm ●Page write Number of Pages Product number 8Byte 16Byte 32Byte BR24L01A-W BR24L02-W BR24L04-W BR24L08-W BR24L16-W BR24L32-W BR24L64-W ●BR24Lxxx-W Series Capacity Bit format Type Power source Voltage SOP8 SOP-J8 SSOP-B8 TSSOP-B8 MSOP8 TSSOP-B8J VSON008 X2030 1Kbit 128×8 BR24L01A-W 1.8V to 5.5V ● ● ● ● ● ● ● 2Kbit 256×8 BR24L02-W 1.7V to 5.5V ● ● ● ● ● ● ● 4Kbit 512×8 BR24L04-W 1.8V to 5.5V ● ● ● ● ● ● ● ● 8Kbit 1K×8 BR24L08-W 1.8V to 5.5V ● ● ● ● ● ● 16Kbit 2K×8 BR24L16-W 1.7V to 5.5V ● ● ● ● ● ● 32Kbit 4K×8 BR24L32-W 1.7V to 5.5V ● ● ● ● 64Kbit 8K×8 BR24L64-W 1.8V to 5.5V ● ● ○Product structure:Silicon monolithic integrated circuit www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・14・001 ○This product is not designed protection against radioactive rays 1/36 TSZ02201-0R2R0G100290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Supply Voltage VCC Ratings Unit -0.3 to +6.5 V Remarks 450 (SOP8) When using at Ta=25℃ or higher 4.5mW to be reduced per 1℃. 450 (SOP-J8) When using at Ta=25℃ or higher 4.5mW to be reduced per 1℃. 300 (SSOP-B8) Power Dissipation Pd When using at Ta=25℃ or higher 3.0mW to be reduced per 1℃. mW 330 (TSSOP-B8) 310 (TSSOP-B8J) When using at Ta=25℃ or higher 3.1mW to be reduced per 1℃. 310 (MSOP8) When using at Ta=25℃ or higher 3.1mW to be reduced per 1℃. 300 (VSON008X2030) When using at Ta=25℃ or higher 3.0mW to be reduced per 1℃. Storage Temperature Tstg -65 to +125 ℃ Operating Temperature Topr -40 to +85 ℃ ‐ -0.3 to Vcc+1.0 V Terminal Voltage When using at Ta=25℃ or higher 3.3mW to be reduced per 1℃. ●Memory cell characteristics (Ta=25℃, Vcc=1.8V to 5.5V)*1 Limits Parameter Min. Typ. Number of data rewrite times *2 1,000,000 Data hold years *2 40 - Unit Max. - Times Years ○Shipment data all address FFh *1 BR24L02/16/32-W : 1.7V to 5.5V *2 Not 100% TESTED ●Recommended Operating Ratings Parameter Symbol Power source voltage Vcc Input voltage VIN Ratings 1.8 to 5.5 *1 0 to Vcc Unit V *1 BR24L02/16/32-W : 1.7V to 5.5V ●Electrical Characteristics Parameter “HIGH” input voltage 1 (Unless otherwise specified, Ta=-40℃ to +85℃, VCC=1.8V to 5.5V) *1 Limits Symbol Unit Conditions Min. Typ. Max. VIH1 0.7Vcc *2 - Vcc +1.0 *2 V 2.5≦Vcc≦5.5V “LOW” input voltage 1 VIL1 -0.3 - 0.3 Vcc V 2.5≦Vcc≦5.5V “HIGH” input voltage 2 VIH2 0.8Vcc - Vcc +1.0 *2 V 1.8≦Vcc<2.5V VIL2 -0.3 *2 - 0.2 Vcc V 1.8≦Vcc<2.5V “HIGH” input voltage 3 *3 VIH3 0.8Vcc - Vcc +1.0 V 1.7≦Vcc<1.8V “HIGH” input voltage 3 *4 VIH3 0.9Vcc - Vcc +1.0 V 1.7≦Vcc<1.8V “LOW” input voltage 2 “LOW” input voltage 3 *2 VIL3 -0.3 - 0.1 Vcc V 1.7≦Vcc<1.8V “LOW” output voltage 1 VOL1 - - 0.4 V IOL=3.0mA, 2.5V≦Vcc≦5.5V, (SDA) “LOW” output voltage 2 VOL2 - - 0.2 V IOL=0.7mA, 1.7V≦Vcc<2.5V, (SDA) Input leak current ILI -1 - 1 μA VIN=0V to Vcc Output leak current ILO -1 - 1 μA VOUT=0V to Vcc, (SDA) mA Vcc=5.5V,fSCL=400kHz, tWR=5ms, Byte write, Page write Current consumption at action Standby current 2.0 *5 ICC1 - - ICC2 - - 0.5 mA ISB - - 2.0 μA 3.0 *6 Vcc=5.5V,fSCL=400kHz Random read, current read,sequential read Vcc=5.5V, SDA・SCL=Vcc A0, A1, A2=GND, WP=GND *1 BR24L02/16/32-W : 1.7V to 5.5V, *2 BR24L16/32-W, *3 BR24L02/16-W, *4 BR24L32-W *5 BR24L01A/02/04/08/16-W, *6 BR24L32/64-W www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 2/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Action timing characteristics (Unless otherwise specified, Ta=-40℃ to +85℃, VCC=1.8V to 5.5V)*1 FAST-MODE STANDARD-MODE 2.5V≦Vcc≦5.5V 1.8V≦Vcc≦5.5V Parameter Symbol Min. Typ. Max. Min. Typ. Max. - - 400 - - 100 kHz - - μs - - μs - 1.0 μs SCL frequency fSCL Data clock “HIGH“ time tHIGH 0.6 - - 4.0 Data clock “LOW“ time tLOW 1.2 - - 4.7 tR - - 0.3 - SDA, SCL rise time *2 *2 Unit tF - - 0.3 - - 0.3 μs tHD:STA 0.6 - - 4.0 - - μs Start condition setup time tSU:STA 0.6 - - 4.7 - - μs Input data hold time tHD:DAT 0 - - 0 - - ns Input data setup time tSU:DAT 100 - - 250 - - ns Output data delay time tPD 0.1 - 0.9 0.2 - 3.5 μs Output data hold time tDH 0.1 - - 0.2 - - μs SDA, SCL fall time Start condition hold time tSU:STO 0.6 - - 4.7 - - μs Bus release time before transfer start tBUF 1.2 - - 4.7 - - μs Internal write cycle time tWR - - 5 - - 5 ms Stop condition setup time tI - - 0.1 - - 0.1 μs tHD:WP 0 - - 0 - - ns WP setup time tSU:WP 0.1 - - 0.1 - - μs WP valid time tHIGH:WP 1.0 - -- 1.0 - - μs Noise removal valid period (SDA, SCL terminal) WP hold time *1 BR24L02/16/32-W : 1.7V to 5.5V *2 Not 100% tested ●FAST-MODE and STANDARD-MODE FAST-MODE and STANDARD-MODE are of same actions, and mode is changed. They are distinguished by action speeds. 100kHz action is called STANDARD-MODE, and 400kHz action is called FAST-MODE. This action frequency is the maximum action frequency, so 100kHz clock may be used in FAST-MODE. When power source voltage goes down, action at high speed is not carried out, therefore, at Vcc=2.5V to 5.5V , 400kHz, namely, action is made in FASTMODE. (Action is made also in STANDARD-MODE) Vcc=1.8V to 2.5V is only action in 100kHz STANDARD-MODE. www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 3/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Sync data input / output timing tR tF tHIGH SCL SCL tSU:DAT tHD:STA tLOW tHD:DAT tSU:STA SDA (入力) (input) tHD:STA tSU:STO SDA tBUF tPD tDH SDA START BIT (出力) (output) STOP BIT ○Input read at the rise edge of SCL ○Data output in sync with the fall of SCL Figure 1-(a) Sync data input / output timing Figure 1-(b) Start-stop bit timing SCL DATA(1) SCL SDA SDA D0 D1 D0 Stop condition Stop condition ストップコンディション WP tW R (n-th address) ACK tWR ACK Write data DATA(n) ACK Start condition tSU:WP Figure 1-(c) Write cycle timing tHD:WP Figure 1-(d) WP timing at write execution SCL DATA(n) DATA(1) SDA D1 D0 ACK ACK tHIGH:WP tWR WP ○At write execution, in the area from the D0 taken clock rise of the first DATA(1), to tWR, set WP=“LOW”. ○By setting WP “HIGH” in the area, write can be cancelled. When it is set WP=“HIGH” during tWR, write is forcibly ended, and data of address under access is not guaranteed, therefore write it once again. Figure 1-(e) WP timing at write cancel www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 4/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Block Diagram *2 A0 1Kbit to 64Kbit EEPROM array 1 8 Vcc 7 WP 6 SCL 5 SDA *1 7bit 11bit 8bit 12bit 9bit 13bit 10bit *2 A1 2 A2 3 8bit Address decoder *1 7bit 11bit 8bit 12bit 9bit 13bit 10bit START *2 Data register Slave - word address register STOP Control circuit ACK GND High voltage generating circuit 4 * 1 Power source voltage detection 7bit : BR24L01A-W 10bit : BR24L08-W 8bit : BR24L02-W 11bit : BR24L16-W 9bit : BR24L04-W 12bit : BR24L32-W 13bit : BR24L64-W * 2 A0=N.C. A0, A1=N.C. A0, A1= N.C. A2=Don’t Use : BR24L04-W : BR24L08-W : BR24L16-W ●Pin Configuration (TOP VIEW) A0 1 1 A1 2 A2 3 GND 4 1 1 BR24L01A-W BR24L02-W BR24L04-W BR24L08-W BR24L16-W BR24L32-W BR24L64-W 1 8 Vcc 7 WP 6 SCL 5 SDA 1 1 1 1 ●Pin Descriptions Terminal name Input / output A0 A1 A2 GND Input Input Input Input / output Input Input - SDA SCL WP Vcc Function BR24L01A-W BR24L02-W BR24L04-W BR24L08-W BR24L16-W Slave address setting Not connected Slave address setting Not connected Slave address setting Not used Reference voltage of all input / output, 0V www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 BR24L32-W BR24L64-W Slave address setting Slave address setting Slave address setting Slave and word address, Serial data input serial data output Serial clock input Write protect terminal Connect the power source. 5/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) Datasheet ●Typical Performance Curves (The following values are Typ. ones.) Figure 3. "L" Input Voltage VIL1,2 (SCL, SDA, WP) Figure 2. "H" Input Voltage VIH1,2 Figure 4. "L" Output Voltage1 VOL1-IOL1 (Vcc=2.5V) www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 5. "L" Output Voltage VOL2-IOL2 (Vcc=1.8V) 6/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) Datasheet ●Typical Performance Curves‐Continued Figure 7. Output Leak Current ILO (SDA) ICC1[mA] Figure 6. Input Leak Current ILI (SCL, WP) Figure 8. Current consumption at WRITE action ICC1 (fscl=400kHz) www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 7/36 Figure 9. Current consumption at WRITE action ICC1 (fscl=400kHz) TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Typical Performance Curves‐Continued 1PIN MARK LOT Number LOT Number Figure 10. Current consumption at READ action ICC2 (fscl=400kHz) Figure 11. Current consumption at WRITE action ICC1 (fscl=100kHz) 1PIN MARK Figure 12. Current consumption at WRITE action ICC1 (fscl=100kHz) www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 8/36 Figure 13. Current consumption at READ action ICC2 (fscl=100kHz) TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) Datasheet ●Typical Performance Curves‐Continued Figure 14. Standby current ISB Figure 15. SCL frequency fSCL Figure 16. Data clock “H” time tHIGH Figure 17. Data clock “L” time tLOW www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 9/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) Datasheet ●Typical Performance Curves‐Continued Figure 18. Start condition hold time tHD:STA Figure 19. Start condition setup time tHD:STA Figure 20. Input data hold time tHD :DAT(HIGH) www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 21. Input data hold time tHD :DAT(LOW) 10/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) Datasheet ●Typical Performance Curves‐Continued Figure 22. Input data setup time tSU:DAT(HIGH) Figure 23. Input data setup time tSU:DAT(LOW) Figure 25. Output data delay time tPD1 Figure 24. Output data delay time tPD0 www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 11/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) Datasheet ●Typical Performance Curves‐Continued Figure 26. Bus release time before transfer start tBUF Figure 27. Internal write cycle time tWR Figure 28. Noise removal valid time tl (SCL H) www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Figure 29. Noise removal valid time tl (SCL L) 12/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) Datasheet ●Typical Performance Curves‐Continued Figure 30. Noise removal valid time tl (SDA H) Figure 31. Noise removal valid time tl (SDA L) Figure 33. WP valid time tHIGH:WP Figure 32. WP setup time tSU:WP www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 13/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) 2 ●I C BUS Communication 2 ○I C BUS data communication 2 I C BUS data communication starts by start condition input, and ends by stop condition input. Data is always 8bit long, and acknowledge is always required after each byte. I2C BUS carries out data transmission with plural devices connected by 2 communication lines of serial data (SDA) and serial clock (SCL). Among devices, there are “master” that generates clock and control communication start and end, and “slave” that is controlled by address peculiar to devices. EEPROM becomes “slave”. And the device that outputs data to bus during data communication is called “transmitter”, and the device that receives data is called “receiver”. SDA 1-7 SCL S START ADDRESS condition 8 9 R/W ACK 1-7 DATA 8 9 1-7 ACK DATA 8 9 ACK P STOP condition Figure 34. Data transfer timing ○Start condition (Start bit recognition) ・Before executing each command, start condition (start bit) where SDA goes from 'HIGH' down to 'LOW' when SCL is 'HIGH' is necessary. ・This IC always detects whether SDA and SCL are in start condition (start bit) or not, therefore, unless this confdition is satisfied, any command is executed. ○Stop condition (stop bit recongnition) ・Each command can be ended by SDA rising from 'LOW' to 'HIGH' when stop condition (stop bit), namely, SCL is 'HIGH' ○Acknowledge (ACK) signal ・This acknowledge (ACK) signal is a software rule to show whether data transfer has been made normally or not. In master and slave, the device (μ-COM at slave address input of write command, read command, and this IC at data output of read command) at the transmitter (sending) side releases the bus after output of 8bit data. ・The device (this IC at slave address input of write command, read command, and μ-COM at data output of read command) at the receiver (receiving) side sets SDA 'LOW' during 9 clock cycles, and outputs acknowledge signal (ACK signal) showing that it has received the 8bit data. ・This IC, after recognizing start condition and slave address (8bit), outputs acknowledge signal (ACK signal) 'LOW'. ・Each write action outputs acknowledge signal (ACK signal) 'LOW', at receiving 8bit data (word address and write data). ・Each read action outputs 8bit data (read data), and detects acknowledge signal (ACK signal) 'LOW'. ・When acknowledge signal (ACK signal) is detected, and stop condition is not sent from the master (μ-COM) side, this IC continues data output. When acknowledge signal (ACK signal) is not detected, this IC stops data transfer, and recognizes stop cindition (stop bit), and ends read action. And this IC gets in status. www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 14/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ○Device addressing ・Output slave address after start condition from master. ・The significant 4 bits of slave address are used for recognizing a device type. The device code of this IC is fixed to '1010'. ・Next slave addresses (A2 A1 A0 --- device address) are for selecting devices, and plural ones can be used on a same bus according to the number of device addresses. ・The most insignificant bit (R/W --- READ / WRITE) of slave address is used for designating write or read action, and is as shown below. Setting R / W to 0 ------- write (setting 0 to word address setting of random read) Setting R / W to 1 ------- read Type BR24L01A-W BR24L02-W BR24L04-W BR24L08-W BR24L16-W BR24L32-W BR24L64-W Maximum number of connected buses Slave address ― 1 0 1 0 A2 A1 A0 R/W ― 1 0 1 0 A2 A1 A0 R/W ― 1 0 1 0 A2 A1 PS R/W ― 1 0 1 0 A2 P1 P0 R/W ― 1 0 1 0 P2 P1 P0 R/W ― 1 0 1 0 A2 A1 A0 R/W ― 1 0 1 0 A2 A1 A0 R/W 8 8 4 2 1 8 8 PS, P0 to P2 are page select bits. Note) Up to 4 units BR24L04-W, up to 2 units of BR24L08-W, and one unit of BR24L16-W can be connected. Device address is set by 'H' and 'L' of each pin of A0, A1, and A2. www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 15/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Write Command ○Write cycle ・Arbitrary data is written to EEPROM. When to write only 1 byte, byte write is normally used, and when to write continuous data of 2 bytes or more, simultaneous write is possible by page write cycle. The maximum number of write bytes is specified per device of each capacity. Up to 32 arbitrary bytes can be written. (In the case of BR24L32 / L64-W) S T A R T W R I T E SLAVE ADDRESS SDA LINE WORD ADDRESS Note) DATA *1 As for WA7, BR24L01A-W becomes Don’t care. WA 7 1 0 1 0 A2 A1 A0 S T O P WA 0 D7 D0 A C K R A *1 / C W K A C K Figure 35. Byte write cycle (BR24L01A/02/04/08/16-W) S T A R T SLAVE ADDRESS SDA LINE W R I T E 1 0 1 0 A2 A1 A0 Note) 2nd WORD ADDRESS 1st WORD ADDRESS * * * WAWA 12 11 R A / C W K WA 0 *1 As for WA12, BR24L32-W becomes Don’t care. D0 D7 A C K A C K *1 S T O P DATA A C K Figure 36. Byte write cycle (BR24L32/64-W) S T A R T SDA L IN E W R I T E SLAVE ADDRESS W ORD A D D R E S S (n ) WA 7 1 0 1 0 A 2A 1A 0 WA 0 R A / C *1 W K N o te ) SDA L IN E SLAVE ADDRESS W R I T E N ote ) 1 st W O R D A D D R E S S (n ) * R A / C W K * * A C K Figure 38. Page write cycle *1 As for WA7, BR24L01A-W becomes Don’t care. *2 As for BR24L01A/02-W becomes (n+7). D0 A C K A C K (BR24L01A/02/04/08/16-W) D A T A (n ) WA 0 1 2 11 *1 D0 2nd W ORD A D D R E S S (n ) WA WA 1 0 1 0 A 2A 1A 0 D7 D A TA (n +1 5 ) A C K Figure 37. Page write cycle S T A R T D A TA (n ) S T O P *2 D7 D A TA (n + 3 1 ) D0 A C K S T O P *1 As for WA12, BR24L32-W becomes Don’t care. D0 A C K A C K (BR24L32/64-W) ・Data is written to the address designated by word address (n-th address) ・By issuing stop bit after 8bit data input, write to memory cell inside starts. ・When internal write is started, command is not accepted for tWR (5ms at maximum). ・By page write cycle, the following can be written in bulk : Up to 8 bytes ( BR24L01A-W, BR24L02-W) : Up to 16bytes (BR24L04-W, BR24L08-W,BR24L16-W) : Up to 32bytes (BR24L32-W, BR24L64-W) And when data of the maximum bytes or higher is sent, data from the first byte is overwritten. (Refer to "Internal address increment" in Page 17.) ・As for page write cycle of BR24L01A-W and BR24L02-W, after the significant 5 bits (4 significant bits in BR24L01-W) of word address are designated arbitrarily, and as for page write command of BR24L04-W, BR24L08-W, and BR24L16-W, after page select bit (PS) of slave address is designated arbitrarily, by continuing data input of 2 bytes or more, the address of insignificant 4 bits (insignificant 3 bit in BR24L01A-W, and BR24L02-W) is incremented internally, and data up to 16 bytes (up to 8 bytes in BR24L01A-W and BR24L02-W) can be written. ・As for page write cycle of BR24L32-W and BR24L64-W, after the significant 7 bits (in the case of BR24L32-W) of word address, or the significant 8 bits (in the case of BR24L64-W) of word address are designated arbitrarily, by continuing data input of 2 byte or more, the address of insignificant 5 bits is incremented internally, and data up to 32 bytes can be written. Note) *1 *2 *3 1 0 1 0 A 2A 1A 0 *1 In BR24L16-W, A2 becomes P2. *2 In BR24L08-W, BR24L16-W, A1 becomes P1. *3 In BR24L04-W, A0 becomes PS, and in BR24L08-W and BR24L16-W, A0 becomes P0. Figure 39. Difference of slave address of each type www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 16/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ○Notes on write cycle continuous input At STOP (stop bit), write starts. S T A R T SDA LINE W R I T E SLAVE ADDRESS *1 WA 7 1 0 1 0 A2A1A0 Note) WORD ADDRESS(n) WA 0 R A / C W K *2 DATA(n) D7 DATA(n+7)*3 D0 A C K S T A R T S T O P D0 A C K 1 0 1 0 A C K Next command tWR(maximum : 5ms) Command is not accepted for this period. *1 BR24L01A-W becomes Don’t care. *2 BR24L04-W, BR24L08-W, and BR24L16-W become (n+15). *3 BR24L32-W and BR24L64-W become (n+31). Figure 40. Page write cycle Note) *1 *2 *3 1 0 1 0 A 2A 1A 0 *1 In BR24L16-W, A2 becomes P2. *2 In BR24L08-W, BR24L16-W, A1 becomes P1. *3 In BR24L04-W, A0 becomes PS, and in BR24L08-W and in BR24L16-W, A0 becomes P0. Figure 41. Difference of each type of slave address ○Notes on page write cycle List of numbers of page write Number of Pages 8Byte Product number BR24L01A-W BR24L02-W 16Byte BR24L04-W BR24L08-W BR24L16-W 32Byte BR24L32-W BR24L64-W The above numbers are maximum bytes for respective types. Any bytes below these can be written. In the case BR24L02-W, 1 page=8bytes, but the page write cycle write time is 5ms at maximum for 8byte bulk write. It does not stand 5ms at maximum × 8byte=40ms(Max.). www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 17/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ○Internal address increment Page write mode (in the case of BR24L02-W) WA7 ----0 ----0 ----0 ----- WA4 0 0 0 ------------- 0 0 0 WA1 0 0 1 WA0 0 1 0 Increment --------- 0 0 0 WA2 0 0 0 --------- --------- 06h WA3 0 0 0 0 0 0 1 1 0 1 1 0 0 1 0 Significant bit is fixed. No digit up For example, when it is started from address 06h,therefore, increment is made as below, 06h → 07h → 00h → 01h ---, which please note. * 06h・・・06 in hexadecimal, therefore, 00000110 becomes a binary number. ○Write protect (WP) terminal ・Write protect (WP) function When WP terminal is set Vcc (H level), data rewrite of all addresses is prohibited. When it is set GND (L level), data rewrite of all address is enabled. Be sure to connect this terminal to Vcc or GND, or control it to H level or L level. Do not use it open. At extremely low voltage at power ON / OFF, by setting the WP terminal 'H', mistake write can be prevented. During tWR, set the WP terminal always to 'L'. If it is set 'H', write is forcibly terminated. www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 18/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Read Command ○Read cycle Data of EEPROM is read. In read cycle, there are random read cycle and current read cycle. Random read cycle is a command to read data by designating address, and is used generally. Current read cycle is a command to read data of internal address register without designating address, and is used when to verify just after write cycle. In both the read cycles, sequential read cycle is available, and the next address data can be read in succession. S T A R T W R I T E SLAVE ADDRESS SDA L IN E S T A R T W ORD A D D R E S S (n ) WA 7 1 0 1 0 A 2 A 1A 0 WA 0 R A *1 / C W K N o te ) R E A D SLAVE ADDRESS D A TA (n ) 1 0 1 0 A 2 A 1A 0 A C K It is necessary to input 'H' to the last ACK. S T O P D0 D7 A C K R A / C W K *1 As for WA7, BR24L01A-W become Don’t care. Figure 42. Random read cycle (BR24L01A/02/04/08/16-W) S T A R T SDA LINE SLAVE ADDRESS W R I T E * * * WA 0 WAWA 12 11 R A / C W K Note) 2nd WORD ADDRESS(n) 1st WORD ADDRESS(n) 1 0 1 0 A2A1A0 S T A R T A C K *1 R E A D SLAVE ADDRESS 1 0 1 0 A2 A1A0 A C K S T O P DATA(n) D7 D0 R A / C W K A C K *1 As for WA12, BR24L32-W become Don’t care. Figure 43. Random read cycle (BR24L32/64 -W) S T A R T SDA L IN E R E A D S LA V E ADDRESS S T O P D A TA (n ) 1 0 1 0 A 2 A 1A 0 D7 D0 A C K R A / C W K N o te) It is necessary to input 'H' to the last ACK. Figure 44. Current read cycle S T A R T SDA LINE R E A D SLAVE ADDRESS 1 0 1 0 A2 A1A0 Note) D7 S T O P DATA(n+x) DATA(n) D0 R A / C W K D7 A C K D0 A C K A C K Figure 45. Sequential read cycle (in the case of current read cycle) ・In random read cycle, data of designated word address can be read. ・When the command just before current read cycle is random read cycle, current read cycle (each including sequential read cycle), data of incremented last read address (n)-th address, i.e., data of the (n+1)-th address is output. ・When ACK signal 'LOW' after D0 is detected, and stop condition is not sent from master (μ-COM) side, the next address data can be read in succession. ・Read cycle is ended by stop condition where 'H' is input to ACK signal after D0 and SDA signal is started at SCL signal 'H' . ・When 'H' is not input to ACK signal after D0, sequential read gets in, and the next data is output. Therefore, read command cycle cannot be ended. When to end read command cycle, be sure input stop condition to input 'H' to ACK signal after D0, and to start SDA at SCL signal 'H'. ・Sequential read is ended by stop condition where 'H' is input to ACK signal after arbitrary D0 and SDA is started at SCL signal 'H'. Note) *1 *2 *3 1 0 1 0 A 2A 1A 0 *1 In BR24L16-W, A2 becomes P2. *2 In BR24L08-W, BR24L16-W, A1 becomes P1. *3 In BR24L04-W, A0 becomes PS, and in BR24L08-W and BR24L16-W, A0 becomes P0. Figure 46. Difference of slave address of each type www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 19/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Software reset Software reset is executed when to avoid malfunction after power on, and to reset during command input. Software reset has several kinds, and 3 kinds of them are shown in the figure below. (Refer to Figure 47(a), Figure 47(b), and Figure47(c).) In dummy clock input area, release the SDA bus ('H' by pull up). In dummy clock area, ACK output and read data '0' (both 'L' level) may be output from EEPROM, therefore, if 'H' is input forcibly, output may conflict and over current may flow, leading to instantaneous power failure of system power source or influence upon devices. Dummy clock×14 2 1 SCL Start×2 14 13 Normal command SDA Normal command Figure 47-(a) The case of dummy clock +START+START+ command input Dummy clock×9 Start SCL 1 2 Start 8 Normal command 9 SDA Normal command Figure 47-(b) The case of START +9 dummy clocks +START+ command input Start×9 SCL 1 2 3 7 8 9 Normal command SDA Normal command * Start command from START input. Figure 47-(c) START×9+ command input ●Acknowledge polling During internal write execution, all input commands are ignored, therefore ACK is not sent back. During internal automatic write execution after write cycle input, next command (slave address) is sent, and if the first ACK signal sends back 'L', then it means end of write action, while if it sends back 'H', it means now in writing. By use of acknowledge polling, next command can be executed without waiting for tWR = 5ms. When to write continuously, R/W = 0, when to carry out current read cycle after write, slave address R/W = 1 is sent, and if ACK signal sends back 'L', then execute word address input and data output and so forth. During internal write, ACK = HIGH is sent back. First write command S T A R T Write command S T O P S T Slave A R address T S T Slave A R address T A C K H A C K H tWR Second write command … S T Slave A R address T A C K H S T Slave A R address T A C Word K address L A C K L Data A C K L S T O P tWR After completion of internal write, ACK=LOW is sent back, so input next word address and data in succession. Figure 48. Case to continuously write by acknowledge polling www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 20/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●WP valid timing (write cancel) WP is usually fixed to 'H' or 'L', but when WP is used to cancel write cycle and so forth, pay attention to the following WP valid timing. During write cycle execution, in cancel valid area, by setting WP='H', write cycle can be cancelled. In both byte write cycle and page write cycle, the area from the first start condition of command to the rise of clock to taken in D0 of data(in page write cycle, the first byte data) is cancel invalid area. WP input in this area becomes Don't care. Set the setup time to rise of D0 taken SCL 100ns or more. The area from the rise of SCL to take in D0 to the end of internal automatic write (tWR) is cancel valid area. And, when it is set WP='H' during tWR, write is ended forcibly, data of address under access is not guaranteed, therefore, write it once again. (Refer to Figure 49.) After execution of forced end by WP, standby status gets in, so there is no need to wait for tWR (5ms at maximum). ・Rise of D0 taken clock SCL SCL SDA ・Rise of SDA D1 D0 ACK ACK D0 Enlarged view SDA Enlarged view SDA S T Slave A address R T A C Word K address L A C D7 D6 D5 D4 D3 D2 D1 D0 K L WP cancel invalid area A C K L Data A C K L S T O P tWR WP cancel valid area Write forced end Data is not written. Data not guaranteed WP Figure 49. WP valid timing ●Command cancel by start condition and stop condition During command input, by continuously inputting start condition and stop condition, command can be cancelled. (Refer to Figure 50.) However, in ACK output area and during data read, SDA bus may output 'L', and in this case, start condition and stop condition cannot be input, so reset is not available. Therefore, execute software reset. And when command is cancelled by start, stop condition, during random read cycle, sequential read cycle, or current read cycle, internal setting address is not determined, therefore, it is not possible to carry out current read cycle in succession. When to carry out read cycle in succession, carry out random read cycle. SCL SDA 1 0 1 0 Start condition Stop condition Figure 50. Case of cancel by start, stop condition during slave address input www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 21/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●I/O peripheral circuit ○Pull up resistance of SDA terminal SDA is NMOS open drain, so requires pull up resistance. As for this resistance value (RPU), select an appropriate value to this resistance value from microcontroller VIL, IL, and VOL-IOL characteristics of this IC. If RPU is large, action frequency is limited. The smaller the RPU, the larger the consumption current at action. ○Maximum value of RPU The maximum value of RPU is determined by the following factors. (1)SDA rise time to be determined by the capacitance (CBUS) of bus line of RPU and SDA should be tR or below. And AC timing should be satisfied even when SDA rise time is late. A to be determined by input leak total (IL) of device connected to bus at output of 'H' to (2)The bus electric potential ○ SDA bus and RPU should sufficiently secure the input 'H' level (VIH) of microcontroller and EEPROM including recommended noise margin 0.2Vcc. Microcontroller BR24LXX VCC - ILRPU - 0.2Vcc ≧ VIH ∴ RPU 0.8Vcc-VIH IL RPU Ex. ) When VCC =3V, IL=10μA, VIH=0.7 VCC, from (2) RPU ≦ SDA terminal A IL 0.8×3-0.7×3 -6 10×10 IL Bus line capacity CBUS ≦ 300 [kΩ] Figure 51. I/O circuit ○Minimum value of RPU The minimum value of RPU is determined by the following factors. (1)When IC outputs LOW, it should be satisfied that VOLMAX=0.4V and IOLMAX=3mA. VCC-VOL ≦ IOL RPU ∴ RPU ≦ VCC-VOL IOL (2)VOLMAX=0.4V should secure the input 'L' level (VIL) of microcontroller and EEPROM including recommended noise margin 0.1Vcc. VOLMAX ≦ VIL-0.1 VCC Ex. ) When VCC =3V, VOL=0.4V, IOL=3mA, microcontroller, EEPROM VIL=0.3VCC from (1) 3-0.4 RPU ≧ 3×10 -3 ≧ 867 [Ω] And VOL = 0.4 [V] VIL = 0.3×3 = 0.9 [V] Therefore, the condition (2) is satisfied. ○Pull up resistance of SCL terminal When SCL control is made at CMOS output port, there is no need, but in the case there is timing where SCL becomes 'Hi-Z', add a pull up resistance. As for the pull up resistance, one of several kΩ to several ten kΩ is recommended in consideration of drive performance of output port of microcontroller. ●A0, A1, A2, WP process ○Process of device address terminals (A0,A1,A2) Check whether the set device address coincides with device address input sent from the master side or not, and select one among plural devices connected to a same bus. Connect this terminal to pull up or pull down, or Vcc or GND. And, pins (N, C, PIN) not used as device address may be set to any of 'H' , 'L', and 'Hi-Z'. Types with N.C.PIN BR24L16/F/FJ/FV/FVT/FVM/FVJ-W A0, A1, A2 BR24L08/F/FJ/FV/FVT/FVM/FVJ/NUX-W A0, A1 BR24L04/F/FJ/FV/FVT/FVM/FVJ/NUX-W A0 ○Process of WP terminal WP terminal is the terminal that prohibits and permits write in hardware manner. In 'H' status, only READ is available and WRITE of all address is prohibited. In the case of 'L', both are available. In the case of use it as an ROM, it is recommended to connect it to pull up or Vcc. In the case to use both READ and WRITE, control WP terminal or connect it to pull down or GND. www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 22/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Cautions on microcontroller connection ○Rs 2 In I C BUS, it is recommended that SDA port is of open drain input/output. However, when to use CMOS input / output of tri state to SDA port, insert a series resistance Rs between the pull up resistance Rpu and the SDA terminal of EEPROM. This is controls over current that occurs when PMOS of the microcontroller and NMOS of EEPROM are turned ON simultaneously. Rs also plays the role of protection of SDA terminal against surge. Therefore, even when SDA port is open drain input/output, Rs can be used. ACK SCL RPU RS SDA 'H' output of microcontroller 'L' output of EEPROM Microcontroller Over current flows to SDA line by 'H' output of microcontroller and 'L' output of EEPROM. EEPROM Figure 52. I/O circuit diagram Figure 53. Input / output collision timing ○Maximum value of Rs The maximum value of Rs is determined by the following relations. (1)SDA rise time to be determined by the capacity (CBUS) of bus line of Rpu and SDA should be tR or below. And AC timing should be satisfied even when SDA rise time is late. A to be determined by Rpu and Rs the moment when EEPROM outputs 'L' to SDA bus (2)The bus electric potential ○ should sufficiently secure the input 'L' level (VIL) of microcontroller including recommended noise margin 0.1Vcc. VCC (VCC-VOL)×RS RPU+RS RPU A RS VOL ∴ 1.1VCC-VIL IOL from(2), 0.3×3-0.4-0.1×3 1.1×3-0.3×3 ≦ RS EEPROM Microcontroller × RPU Example) When VCC=3V, VIL=0.3VCC, VOL=0.4V, RPU=20kΩ Bus line capacity CBUS VIL VOL+0.1VCC≦VIL VIL-VOL-0.1VCC ≦ RS + ≦ × 20×103 1.67[kΩ] Figure 54. I/O circuit ○Minimum value of Rs The minimum value of Rs is determined by over current at bus collision. When over current flows, noises in power source line, and instantaneous power failure of power source may occur. When allowable over current is defined as I, the following relation must be satisfied. Determine the allowable current in consideration of impedance of power source line in set and so forth. Set the over current to EEPROM 10mA or below. RPU 'L' output VCC RS ≦ I RS ≧ VCC I RS ∴ Over currentⅠ Example)When VCC=3V, I=10mA 'H' output RS Microcontroller EEPROM ≧ ≧ 3 10×10-3 300[Ω] Figure 55. I/O circuit diagram www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 23/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●I2C BUS input / output circuit ○Input (A0,A2,SCL) Figure 56. Input pin circuit diagram ○Input / output (SDA) Figure 57. Input / output pin circuit diagram ○Input (A1, WP) Figure 58. Input pin circuit diagram ●Notes on power ON At power on, in IC internal circuit and set, Vcc rises through unstable low voltage area, and IC inside is not completely reset, and malfunction may occur. To prevent this, functions of POR circuit and LVCC circuit are equipped. To assure the action, observe the following conditions at power on. 1. Set SDA = 'H' and SCL ='L' or 'H' 2. Start power source so as to satisfy the recommended conditions of tR, tOFF, and Vbot for operating POR circuit. tR VCC Recommended conditions of tR, tOFF,Vbot tR tOFF tOFF Vbot Vbot 10ms or below 10ms or longer 0.3V or below 100ms or below 10ms or longer 0.2V or below 0 Figure 59. Rise waveform diagram www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 24/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) 3. Set SDA and SCL so as not to become 'Hi-Z'. When the above conditions 1 and 2 cannot be observed, take the following countermeasures. a) In the case when the above condition 1 cannot be observed. When SDA becomes 'L' at power on . →Control SCL and SDA as shown below, to make SCL and SDA, 'H' and 'H'. VCC tLOW SCL SDA After Vcc becomes stable After Vcc becomes stable tDH tSU:DAT tSU:DAT Figure 61. When SCL='L' and SDA='L' Figure 60. When SCL= 'H' and SDA= 'L' b) In the case when the above condition 2 cannot be observed. →After power source becomes stable, execute software reset(Page 20). c) In the case when the above conditions 1 and 2 cannot be observed. →Carry out a), and then carry out b). ●Low voltage malfunction prevention function LVCC circuit prevents data rewrite action at low power, and prevents wrong write. At LVCC voltage (Typ. =1.2V) or below, it prevent data rewrite. ●Vcc noise countermeasures ○Bypass capacitor When noise or surge gets in the power source line, malfunction may occur, therefore, for removing these, it is recommended to attach a by pass capacitor (0.1μF) between IC Vcc and GND. At that moment, attach it as close to IC as possible. And, it is also recommended to attach a bypass capacitor between board Vcc and GND. ●Notes for Use (1) Described numeric values and data are design representative values, and the values are not guaranteed. (2) We believe that application circuit examples are recommendable, however, in actual use, confirm characteristics further sufficiently. In the case of use by changing the fixed number of external parts, make your decision with sufficient margin in consideration of static characteristics and transition characteristics and fluctuations of external parts and our LSI. (3) Absolute maximum ratings If the absolute maximum ratings such as impressed voltage and action temperature range and so forth are exceeded, LSI may be destructed. Do not impress voltage and temperature exceeding the absolute maximum ratings. In the case of fear exceeding the absolute maximum ratings, take physical safety countermeasures such as fuses, and see to it that conditions exceeding the absolute maximum ratings should not be impressed to LSI. (4) GND electric potential Set the voltage of GND terminal lowest at any action condition. Make sure that each terminal voltage is lower than that of GND terminal. (5) Terminal design In consideration of permissible loss in actual use condition, carry out heat design with sufficient margin. (6) Terminal to terminal shortcircuit and wrong packaging When to package LSI onto a board, pay sufficient attention to LSI direction and displacement. Wrong packaging may destruct LSI. And in the case of shortcircuit between LSI terminals and terminals and power source, terminal and GND owing to foreign matter, LSI may be destructed. (7) Use in a strong electromagnetic field may cause malfunction, therefore, evaluate design sufficiently. Status of this document The Japanese version of this document is formal specification. A customer may use this translation version only for a reference to help reading the formal version. If there are any differences in translation version of this document formal version takes priority. www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 25/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Ordering Information Product Code Description B R 2 4 L x x x x x - W xx BUS type 2 24:I C Operating temperature/ Power source Voltage -40℃ to+85℃/ 1.8V to 5.5V Capacity 01=1K 02=2K 04=4K Package 08=8K 16=16K 32=32K F :SOP8 FJ :SOP-J8 FV : SSOP-B8 FVT : TSSOP-B8 FVJ : TSSOP-B8J FVM : MSOP8 64=64K NUX : VSON008X2030 Double Cell Packaging and forming specification E2 : Embossed tape and reel (SOP8,SOP-J8, SSOP-B8,TSSOP-B8, TSSOP-B8J) TR : Embossed tape and reel (MSOP8, VSON008X2030) ●Lineup Package Capacity Type Quantity SOP8 SOP-J8 Reel of 2500 Reel of 3000 TSSOP-B8J Reel of 2500 MSOP8 VSON008X2030 8K TSSOP-B8 Reel of 3000 TSSOP-B8J Reel of 2500 Reel of 3000 MSOP8 Reel of 3000 Reel of 4000 VSON008X2030 Reel of 4000 SOP8 Reel of 2500 SOP-J8 SSOP-B8 16K Reel of 2500 SSOP-B8 TSSOP-B8 Reel of 3000 TSSOP-B8 Reel of 3000 TSSOP-B8J Reel of 2500 TSSOP-B8J Reel of 2500 MSOP8 Reel of 3000 MSOP8 Reel of 3000 VSON008X2030 Reel of 4000 SOP8 SOP8 SOP-J8 32K Reel of 2500 SSOP-B8 4K Reel of 2500 SOP-J8 SOP8 2K Quantity SSOP-B8 TSSOP-B8 SOP-J8 Type SOP8 SSOP-B8 1K Package Capacity TSSOP-B8 TSSOP-B8 Reel of 3000 TSSOP-B8J Reel of 2500 MSOP8 Reel of 3000 VSON008X2030 Reel of 4000 www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 SOP-J8 64K 26/36 Reel of 2500 SSOP-B8 SOP8 SOP-J8 Reel of 3000 Reel of 2500 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Physical Dimension Tape and Reel Information SOP8 Tape Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand Direction of feed 1pin Reel www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 ) ∗ Order quantity needs to be multiple of the minimum quantity. 27/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Physical Dimension Tape and Reel Information - continued SOP-J8 Tape Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand Direction of feed 1pin Reel www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 ) ∗ Order quantity needs to be multiple of the minimum quantity. 28/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Physical Dimension Tape and Reel Information - continued SSOP-B8 SSOP-B8 3.0±0.2 (MAX 3.35 include BURR) 7 6 5 1 2 3 4 0.1 1.15±0.1 0.3MIN 6.4 ± 0.3 4.4 ± 0.2 8 0.15±0.1 S (0.52) 0.65 0.1 S +0.06 0.22 −0.04 0.08 M (Unit : mm) Tape Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand Direction of feed 1pin Reel www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 ) ∗ Order quantity needs to be multiple of the minimum quantity. 29/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Physical Dimension Tape and Reel Information - continued TSSOP-B8 Tape Embossed carrier tape Quantity 3000pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand Direction of feed 1pin Reel www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 ) ∗ Order quantity needs to be multiple of the minimum quantity. 30/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Physical Dimension Tape and Reel Information - continued TSSOP-B8J Tape Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand Direction of feed 1pin Reel www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 ) ∗ Order quantity needs to be multiple of the minimum quantity. 31/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Physical Dimension Tape and Reel Information - continued MSOP8 Tape Embossed carrier tape Quantity 3000pcs Direction of feed TR The direction is the 1pin of product is at the upper right when you hold ( reel on the left hand and you pull out the tape on the right hand ) 1pin Direction of feed Reel www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 ∗ Order quantity needs to be multiple of the minimum quantity. 32/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Physical Dimension Tape and Reel Information - continued VSON008X2030 Tape Embossed carrier tape Quantity 4000pcs Direction of feed TR The direction is the 1pin of product is at the upper right when you hold ( reel on the left hand and you pull out the tape on the right hand Direction of feed 1pin Reel www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 ) ∗ Order quantity needs to be multiple of the minimum quantity. 33/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Marking Diagrams SOP8(TOP VIEW) SOP-J8(TOP VIEW) Part Number Marking Part Number Marking LOT Number LOT Number 1PIN MARK 1PIN MARK SSOP-B8(TOP VIEW) TSSOP-B8(TOP VIEW) Part Number Marking Part Number Marking LOT Number LOT Number 1PIN MARK 1PIN MARK MSOP8(TOP VIEW) TSSOP-B8J(TOP VIEW) Part Number Marking Part Number Marking LOT Number LOT Number 1PIN MARK 1PIN MARK VSON008X2030 (TOP VIEW) Part Number Marking LOT Number 1PIN MARK www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 34/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) Datasheet ●Marking Information Capacity 1K Product Name Marking L01A SOP8 L01A SOP-J8 L01A SSOP-B8 L01A TSSOP-B8 L01 TSSOP-B8J L01 MSOP8 L01A 2K 4K 8K 16K 32K 64K Package Type VSON008X2030 L02 SOP8 L02 SOP-J8 L02 SSOP-B8 L02 TSSOP-B8 L02 TSSOP-B8J L02 MSOP8 L02 VSON008X2030 L04 SOP8 L04 SOP-J8 L04 SSOP-B8 L04 TSSOP-B8 L04 TSSOP-B8J L04 MSOP8 L04 VSON008X2030 L08 SOP8 L08 SOP-J8 L08 SSOP-B8 L08 TSSOP-B8 L08 TSSOP-B8J L08 MSOP8 L08 VSON008X2030 L16 SOP8 L16 SOP-J8 L16 SSOP-B8 L16 TSSOP-B8 L16 TSSOP-B8J L16 MSOP8 L32 SOP8 L32 SOP-J8 L32 SSOP-B8 L32 TSSOP-B8 L64 SOP8 L64 SOP-J8 www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 35/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet BR24Lxxx-W Series (1K 2K 4K 8K 16K 32K 64K) ●Revision History Date Revision 21.Aug.2012 001 Changes New Release www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 36/36 TSZ02201-0R2R0G1000290-1-2 21.AUG.2012 Rev.001 Datasheet Notice Precaution on using ROHM Products 1. Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you (Note 1) , transport intend to use our Products in devices requiring extremely high reliability (such as medical equipment equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation (Pd) depending on Ambient temperature (Ta). When used in sealed area, confirm the actual ambient temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label QR code printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act, please consult with ROHM representative in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. ROHM shall not be in any way responsible or liable for infringement of any intellectual property rights or other damages arising from use of such information or data.: 2. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the information contained in this document. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet General Precaution 1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents. ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s representative. 3. The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or concerning such information. Notice – WE © 2014 ROHM Co., Ltd. All rights reserved. Rev.001
BR24L01AFV-WE2 价格&库存
很抱歉,暂时无法提供与“BR24L01AFV-WE2”相匹配的价格&库存,您可以联系我们找货
BR24L01AFV-WE2
  • 2500+3.717862500+0.48160
库存:7572
BR24L01AFV-WE2
  • 1+4.678341+0.60601
  • 10+4.4433510+0.57557
  • 25+4.3305625+0.56096
  • 50+4.2389250+0.54909
  • 100+4.14813100+0.53733
  • 250+4.02598250+0.52151
  • 500+3.93290500+0.50945
  • 1000+3.840101000+0.49743
库存:7572
BR24L01AFV-WE2
  • 1+9.97460
  • 100+5.76530
  • 1250+3.65520
  • 2500+2.64270
库存:95
