BR24S256FVM-WTR
BR24S256FVM-WTR
    ROHM(罗姆)
    BR24S256FVM-WTR - High Reliability Series EEPROMs I2C BUS - Rohm
BR24S256FVM-WTR 数据手册
Serial EEPROM Series High Reliability Series EEPROMs I2C BUS BR24L□□-W Series,BR24S□□□-W Series No.09001EDT04 ROHM's series of serial EEPROMs represent the highest level of reliability on the market. A double cell structure provides a failsafe method of data reliability, while a double reset function prevents data miswriting. In addition, gold pads and gold wires are used for internal connections, pushing the boundaries of reliability to the limit. BR24L□□-W Series assort 1Kbit~64Kbit. BR24S□□□-W Series are possible to operate at high speed in low voltage and assort 8Kbit~256Kbit. Contents BR24L□□-W Series BR24L01A-W, BR24L02-W, BR24L04-W, BR24L08-W, BR24L16-W, BR24L32-W, BR24L64-W ・・・・P2 BR24S□□□-W Series BR24S08-W, BR24S16-W, BR24S32-W, BR24S64-W, BR24S128-W, BR24S256-W ・・・P20 www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 1/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Serial EEPROM Series Technical Note High Reliability Series EEPROMs I2C BUS BR24L□□-W Series ●Description 2 BR24L□□-W series is a serial EEPROM of I C BUS interface method. ●Features 2 1) Completely conforming to the world standard I C BUS. All controls available by 2 ports of serial clock(SCL) and serial data(SDA) 2) Other devices than EEPROM can be connected to the same port, saving microcontroller port *1 3) 1.8V~5.5V single power source action most suitable for battery use 4) Page write mode useful for initial value write at factory shipment 5) Highly reliable connection by Au pad and Au wire 6) Auto erase and auto end function at data rewrite 7) Low current consumption *2 At write operation (5V) : 1.2mA (Typ.) At read operation (5V) : 0.2mA (Typ.) At standby operation (5V) : 0.1μA (Typ.) 8) Write mistake prevention function Write (write protect) function added 9) Write mistake prevention function at low voltage 10) SOP8/SOP-J8/SSOP-B8/TSSOP-B8/MSOP8/TSSOP-B8J/VSON008X2030 compact package *3 11) Data rewrite up to 1,000,000 times 12) Data kept for 40 years 13) Noise filter built in SCL / SDA terminal 14) Shipment data all address FFh *1 BR24L02-W, BR24L16-W, BR24L32-W : 1.7~5.5V *2 BR24L32-W, BR24L64-W : 1.5mA *3 Refer to following list ●Page write Number of Pages Product number ●BR24L series Capacity 1Kbit 2Kbit 4Kbit 8Kbit 16Kbit 32Kbit 64Kbit Bit format 128×8 256×8 512×8 1K×8 2K×8 4K×8 8K×8 8Byte BR24L01A-W BR24L02-W 16Byte BR24L04-W BR24L08-W BR24L16-W 32Byte BR24L32-W BR24L64-W Type BR24L01A-W BR24L02-W BR24L04-W BR24L08-W BR24L16-W BR24L32-W BR24L64-W Power source Voltage 1.8~5.5V 1.7~5.5V 1.8~5.5V 1.8~5.5V 1.7~5.5V 1.7~5.5V 1.8~5.5V SOP8 ● ● ● ● ● ● ● SOP-J8 ● ● ● ● ● ● ● SSOP-B8 TSSOP-B8 ● ● ● ● ● ● ● ● ● ● ● ● MSOP8 ● ● ● ● ● TSSOP-B8J ● ● ● ● ● VSON008 X2030 ● ● ● ● www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 2/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Absolute maximum ratings (Ta=25℃) Parameter Impressed voltage symbol VCC Limits -0.3~+6.5 *1 450 (SOP8) 450 (SOP-J8) *2 300 (SSOP-B8) *3 330 (TSSOP-B8) *4 310 (MSOP8) *5 310 (TSSOP-B8J) *6 300 (VSON008X2030) *7 -65~+125 -40~+85 -0.3~Vcc+1.0 Unit V Technical Note Permissible dissipation Pd mW Storage temperature range Action temperature range Terminal voltage Tstg Topr - ℃ ℃ V When using at Ta=25℃ or higher, 4.5mW(*1,*2), 3.0mW(*3,*7) 3.3mW(*4),3.1mW(*5,*6) to be reduced per 1℃ ●Memory cell characteristics (Ta=25℃, Vcc=1.8~5.5V)*1 Limits Parameter Min. Typ. Number of data rewrite times *2 1,000,000 Data hold years *2 40 ○Shipment data all address FFh *1 BR24L02/16/32-W : 1.7~5.5V *2 Not 100% TESTED Max. - Unit Times Years ●Recommended operating conditions Parameter Power source voltage Input voltage *1 BR24L02/16/32-W : 1.7~5.5V Symbol Vcc VIN Limits 1.8~5.5 *1 0~Vcc Unit V ●Electrical characteristics (Unless otherwise specified, Ta=-40~+85℃, VCC=1.8~5.5V) *1 Limits Parameter Symbol Unit Min. Typ. Max. “HIGH” input voltage 1 “LOW” input voltage 1 “HIGH” input voltage 2 “LOW” input voltage 2 “HIGH” input voltage 3 “HIGH” input voltage 3 *3 *4 Conditions VIH1 VIL1 VIH2 VIL2 VIH3 VIH3 VIL3 VOL1 VOL2 ILI ILO ICC1 ICC2 ISB 0.7Vcc -0.3 *2 - Vcc +1.0 *2 0.3 Vcc Vcc +1.0 0.2 Vcc Vcc +1.0 Vcc +1.0 0.1 Vcc 0.4 0.2 1 1 2.0 *5 *2 V V V V V V V V V μA μA mA mA μA 2.5≦Vcc≦5.5V 2.5≦Vcc≦5.5V 1.8≦Vcc<2.5V 1.8≦Vcc<2.5V 1.7≦Vcc<1.8V 1.7≦Vcc<1.8V 1.7≦Vcc<1.8V IOL=3.0mA, 2.5V≦Vcc≦5.5V, (SDA) IOL=0.7mA, 1.7V≦Vcc<2.5V, (SDA) VIN=0V~Vcc VOUT=0V~Vcc, (SDA) Vcc=5.5V,fSCL=400kHz, tWR=5ms, Byte write, Page write Vcc=5.5V,fSCL=400kHz Random read, current read,sequential read Vcc=5.5V, SDA・SCL=Vcc A0, A1, A2=GND, WP=GND 0.8Vcc -0.3 *2 0.8Vcc 0.9Vcc -0.3 -1 -1 - “LOW” input voltage 3 *2 “LOW” output voltage 1 “LOW” output voltage 2 Input leak current Output leak current Current consumption at action Standby current 3.0 *6 0.5 2.0 ◎Radiation resistance design is not made. *1 BR24L02/16/32-W : 1.7~5.5V, *2 BR24L16/32-W, *3 BR24L02/16-W, *4 BR24L32-W *5 BR24L01A/02/04/08/16-W, *6 BR24L32/64-W www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 3/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●Action timing characteristics (Unless otherwise specified, Ta=-40~+85℃, VCC=1.8~5.5V)*1 FAST-MODE STANDARD-MODE 2.5V≦Vcc≦5.5V 1.8V≦Vcc≦5.5V Parameter Symbol Min. SCL frequency Data clock “HIGH“ time Data clock “LOW“ time SDA, SCL rise time *2 SDA, SCL fall time *2 Unit kHz μs μs μs μs μs μs ns ns μs μs μs μs ms μs ns μs μs Typ. - Max. 400 0.3 0.3 0.9 5 0.1 -- Min. 4.0 4.7 4.0 4.7 0 250 0.2 0.2 4.7 4.7 0 0.1 1.0 Typ. - Max. 100 1.0 0.3 3.5 5 0.1 - fSCL tHIGH tLOW tR tF tHD:STA tSU:STA tHD:DAT tSU:DAT tPD tDH tSU:STO tBUF tWR tI tHD:WP tSU:WP tHIGH:W P 0.6 1.2 0.6 0.6 0 100 0.1 0.1 0.6 1.2 0 0.1 1.0 Start condition hold time Start condition setup time Input data hold time Input data setup time Output data delay time Output data hold time Stop condition setup time Bus release time before transfer start Internal write cycle time Noise removal valid period (SDA, SCL terminal) WP hold time WP setup time WP valid time *1 BR24L02/16/32-W : 1.7~5.5V *2 Not 100% tested ●FAST-MODE and STANDARD-MODE FAST-MODE and STANDARD-MODE are of same actions, and mode is changed. They are distinguished by action speeds. 100kHz action is called STANDARD-MODE, and 400kHz action is called FAST-MODE. This action frequency is the maximum action frequency, so 100kHz clock may be used in FAST-MODE. When power source voltage goes down, action at high speed is not carried out, therefore, at Vcc=2.5V~5.5V , 400kHz, namely, action is made in FASTMODE. (Action is made also in STANDARD-MODE) Vcc=1.8V~2.5V is only action in 100kHz STANDARD-MODE. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 4/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Sync data input / output timing tR SCL tHD:STA S DA (入力) (input) tBUF (出力) (output) SDA tPD tDH tSU:DAT tLOW tHD:DAT tF tHIGH Technical Note SCL tSU:STA SDA tHD:STA tSU:STO START BIT STOP BIT ○Input read at the rise edge of SCL ○Data output in sync with the fall of SCL Fig.1-(a) Sync data input / output timing Fig.1-(b) Start-stop bit timing SCL S CL SDA DATA(1) D1 D0 ACK DATA(n) ACK tWR S DA D0 Write data ACK tW R Stop condition Start condition WP Stop condition ストップコンディション (n-th address) tSU:WP tHD:WP Fig.1-(c) Write cycle timing SCL DATA(1) SDA D1 D0 ACK tHIGH:WP WP DATA(n) ACK tWR Fig.1-(d) WP timing at write execution ○At write execution, in the area from the D0 taken clock rise of the first DATA(1), to tWR, set WP=“LOW”. ○By setting WP “HIGH” in the area, write can be cancelled. When it is set WP=“HIGH” during tWR, write is forcibly ended, and data of address under access is not guaranteed, therefore write it once again. Fig.1-(e) WP timing at write cance www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 5/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Block diagram Technical Note *2 A0 1 *1 1Kbit~64Kbit EEPROM array 7bit 11bit 8bit 12bit 9bit 13bit 10bit 8 8bit Vcc *2 A1 2 Address decoder *1 7bit 11bit 8bit 12bit 9bit 13bit 10bit Slave - word address register Data register 7 WP *2 A2 3 START STOP Control circuit ACK 6 SCL GND 4 * High voltage generating circuit 1 7bit : BR24L01A-W 10bit : BR24L08-W 8bit : BR24L02-W 11bit : BR24L16-W 9bit : BR24L04-W 12bit : BR24L32-W 13bit : BR24L64-W Power source voltage detection * 5 : BR24L04-W : BR24L08-W : BR24L16-W SDA 2 A0=N.C. A0, A1=N.C. A0, A1= N.C. A2=Don’t Use Fig.2 Block diagram ●Pin assignment and description A0 A1 A2 GND 1 2 3 4 1 1 1 1 8 BR24L01A-W BR24L02-W BR24L04-W BR24L08-W BR24L16-W BR24L32-W BR24L64-W 7 1 1 1 1 Vcc WP SCL SDA 6 5 Terminal name A0 A1 A2 GND SDA SCL WP Vcc Input / output Input Input Input Input / output Input Input - Function BR24L01A-W BR24L02-W BR24L04-W BR24L08-W BR24L16-W BR24L32-W BR24L64-W Slave address setting Not connected Slave address setting Not connected Slave address setting Not used Reference voltage of all input / output, 0V Slave address setting Slave address setting Slave address setting Slave and word address, Serial data input serial data output Serial clock input Write protect terminal Connect the power source. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 6/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Characteristic data (The following values are Typ. ones.) 6 5 VIH1,2[V] 4 3 2 1 0 0 1 3 4 5 Vcc[V] Fig.3 H input voltage VIH1,2 2 6 SPEC Technical Note 6 5 4 VIL1,2[V] 3 2 1 0 0 3 4 5 6 Vcc[V] Fig.4 L input voltageVIL1,2 (SCL,SDA,WP) 1 2 SPEC Ta=85℃ Ta=-40℃ Ta=25℃ 1 0.8 VOL1[V] 0.6 SPEC Ta=85℃ Ta=25℃ 0.4 0.2 Ta=85℃ Ta=-40℃ Ta=25℃ Ta=-40℃ 0 0 3 4 5 6 IOL1[mA] Fig.5 L output voltage VOL1-IOL1 (VCC=2.5V) 1 2 1 0.8 0.6 VOL2[V] ILI[μA] Ta=85℃ Ta=25℃ 1.2 SPEC 1.2 SPEC 1 0.8 ILO[μA] 0.6 0.4 0.2 6 0 0 1 2 3 Vcc[V] 4 5 6 Ta=85℃ Ta=25℃ Ta=-40℃ 1 0.8 0.6 0.4 0.2 0 0 1 2 3 Vcc[V] 4 5 6 Ta=85℃ Ta=25℃ Ta=-40℃ 0.4 SPEC 0.2 Ta=-40℃ 0 0 1 2 3 4 IOL2[mA] 5 Fig.6 L output voltage VOL2-IOL2 (VCC=1.8V) Fig.7 Input leak current ILI (SCL,WP) 3.5 0.6 [BR24L32/64 series] Fig.8 Output leak current ILO(SDA) 2.5 [BR24L01/02/04/08/16 series] SPEC 2 ICC1[mA] 1.5 1 0.5 0 0 3 fSCL=400kHz DATA=AAh SPEC 2.5 ICC1[mA] 2 1.5 1 0.5 0 0 fSCL=400kHz DATA=AAh SPEC 0.5 ICC2[mA] 0.4 0.3 0.2 0.1 0 fSCL=400kHz DATA=AAh Ta=85℃ Ta=25℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=-40℃ 3 4 5 6 Vcc[V] Fig.9 Current consumption at WRITE action ICC1 (fscl=400kHz) 3.5 [BR24L01/02/04/08/16 series] 1 2 1 2 3 Vcc[V] 4 5 6 0 Fig.10 Current consumption at WRITE action ICC1 (fSCL=400kHz) 0.6 [BR24L32/64 series] 1 2 3 4 5 6 Vcc[V] Fig.11 Current consumption at READ action ICC2 (fSCL=400kHz) SPEC 2.5 2 ICC1[mA] 1.5 1 0.5 0 0 1 2 3 Vcc[V] 4 5 6 Ta=25℃ Ta=85℃ Ta=-40℃ 3 fSCL=100kHz DATA=AAh SPEC 2.5 ICC1[mA] 2 1.5 1 0.5 0 0 fSCL=100kHz DATA=AAh SPEC 0.5 ICC2[mA] 0.4 0.3 0.2 Ta=25℃ Ta=85℃ fSCL=100kHz DATA=AAh Ta=25℃ Ta=85℃ Ta=-40℃ 0.1 0 Ta=-40℃ 1 2 3 Vcc[V] 4 5 6 0 Fig.12 Current consumption at WRITE action ICC1 (fSCL=100kHz) 2.5 SPEC Fig.13 Current consumption at WRITE action ICC1 (fSCL=100kHz) 10000 5 1 2 3 4 5 6 Vcc[V] Fig.14 Current consumption at READ action ICC2 (fSCL=100kHz) SPEC2 2 ISB[μA] 1.5 1 0.5 0 0 1 2 3 Vcc[V] 4 5 6 Ta=85℃ Ta=-40℃ Ta=25℃ 1000 fSCL[kHz] 4 tHIGH [μs] Ta=85℃ Ta=25℃ Ta=-40℃ SPEC1 SPEC2 3 2 1 0 Ta=-40℃ Ta=25℃ Ta=85℃ SPEC1 100 10 1 0 1 2 3 Vcc[V] 4 5 6 0 1 2 3 Vcc[V] 4 5 6 Fig.15 Standby current ISB 5 SPEC2 Fig.16 SCL frequency fSCL 5 SPEC2 Fig.17 Data clock "H" time tHIGH 6 5 tSU:STA[μs] 4 3 2 1 0 Ta=-40℃ Ta=25℃ Ta=85℃ SPEC1 SPEC2 4 tHD:STA[μs] tLOW[μs] 3 2 1 0 0 3 4 5 Vcc[V] Fig.18 Data clock "L" time tLOW 1 2 6 Ta=85℃ Ta=25℃ Ta=-40℃ SPEC1 4 3 2 1 0 0 1 2 3 Vcc[V] 4 5 6 Ta=85℃ Ta=25℃ Ta=-40℃ SPEC1 0 1 2 3 Vcc[V] 4 5 6 Fig.19 Start condition hold time tHD:STA Fig.20 Start condition setup time tSU:STA www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 7/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Characteristic data (The following values are Typ. ones). 50 SPEC1,2 Technical Note 50 SPEC1,2 300 200 tSU:DAT(HIGH)[ns] 100 0 Ta=85℃ Ta=25℃ Ta=-40℃ SPEC2 SPEC1 tHD:DAT(HIGH)[ns] 0 -50 Ta=-40℃ Ta=25℃ Ta=85℃ 0 tHD:DAT(LOW)[ns] -50 Ta=85℃ Ta=25℃ -100 -150 -200 0 1 2 3 Vcc[V] 4 5 6 -100 -150 -200 0 3 4 5 6 Vcc[V] Fig.22 Input data hold time tHD:DAT(LOW) 1 2 Ta=-40℃ -100 -200 0 1 2 3 Vcc[V] 4 5 6 Fig.21 Input data hold time tHD:DAT(HIGH) 300 200 tSU:DAT(LOW)[ns] 100 0 Ta=85℃ SPEC2 SPEC1 Fig.23 Input data setup time tSU:DAT(HIGH) 4 4 SPEC2 3 tPD0[μs] 3 tPD1[μs] SPEC2 2 2 Ta=-40℃ Ta=25℃ Ta=85℃ SPEC1 Ta=85℃ Ta=25℃ Ta=-40℃ SPEC2 SPEC1 -100 -200 0 Ta=-40℃ Ta=25℃ 1 SPEC1 1 SPEC2 SPEC1 0 1 2 0 0 1 2 3 Vcc[V] 4 5 6 0 Vcc[V] 3 4 5 6 1 2 3 Vcc[V] 4 5 6 Fig.24 Input data setup time tSU:DAT(LOW) 5 SPEC2 Fig.25 Output data delay time tPD0 6 SPEC1,2 Fig.26 Output data delay time tPD1 0.6 0.5 4 tBUF[μs] tWR[ms] 3 2 1 0 0 1 2 3 Vcc[V] 4 5 6 Ta=-40℃ Ta=25℃ Ta=85℃ SPEC1 5 Ta=25℃ 3 2 1 0 0 1 2 tI(SCL H)[μs] 4 Ta=-40℃ 0.4 0.3 Ta=25℃ Ta=-40℃ Ta=85℃ Ta=85℃ 0.2 SPEC1,2 0.1 0 3 Vcc[V] 4 5 6 0 1 2 3 Vcc[V] 4 5 6 Fig.27 Bus release time before transfer start tBUF 0.6 0.5 0.4 0.3 0.2 0.1 SPEC1 Ta=25℃ Ta=85℃ Ta=-40℃ Fig.28 Internal write cycle time tWR 0.6 0.5 tI(SDA H)[μs] Ta=25℃ Fig.29 Noise removal valid time tI(SCL H) 0.6 0.5 tI(SDA L)[μs] 0.4 Ta=-40℃ tI(SCL L)[μs] 0.4 0.3 Ta=-40℃ Ta=85℃ 0.3 0.2 Ta=25℃ Ta=85℃ SPEC1 0.2 SPEC1,2 0.1 0 0 1 2 3 Vcc[V] 4 5 6 0 1 2 3 Vcc[V] 4 5 6 0.1 0 0 3 4 5 6 Vcc[V] Fig.32 Noise removal valid time tI(SDA L) 1 2 0 Fig.30 Noise removal valid time tI(SCL L) 0.2 SPEC1,2 Fig.31 Noise removal valid time tI(SDA H) 1.2 1 SPEC1,2 0 tSU:WP[μs] tHIGH:WP[μs] 0.8 0.6 0.4 0.2 0 Ta=-40℃ Ta=25℃ Ta=85℃ -0.2 Ta=85℃ -0.4 Ta=25℃ Ta=-40℃ -0.6 0 1 2 3 Vcc[V] 4 5 6 0 1 2 3 Vcc[V] 4 5 6 Fig.33 WP setup time tSU:WP Fig.34 WP valid time tHIGH:WP www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 8/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●I2C BUS communication 2 ○I C BUS data communication 2 I C BUS data communication starts by start condition input, and ends by stop condition input. Data is always 8bit long, 2 and acknowledge is always required after each byte. I C BUS carries out data transmission with plural devices connected by 2 communication lines of serial data (SDA) and serial clock (SCL). Among devices, there are “master” that generates clock and control communication start and end, and “slave” that is controlled by address peculiar to devices. EEPROM becomes “slave”. And the device that outputs data to bus during data communication is called “transmitter”, and the device that receives data is called “receiver”. SDA SCL 1-7 S START ADDRESS condition 8 9 1-7 8 9 1-7 8 9 P STOP condition R/W ACK DATA ACK DATA ACK Fig.35 Data transfer timing ○Start condition (Start bit recognition) ・Before executing each command, start condition (start bit) where SDA goes from 'HIGH' down to 'LOW' when SCL is 'HIGH' is necessary. ・This IC always detects whether SDA and SCL are in start condition (start bit) or not, therefore, unless this confdition is satisfied, any command is executed. ○Stop condition (stop bit recongnition) ・Each command can be ended by SDA rising from 'LOW' to 'HIGH' when stop condition (stop bit), namely, SCL is 'HIGH' ○Acknowledge (ACK) signal ・This acknowledge (ACK) signal is a software rule to show whether data transfer has been made normally or not. In master and slave, the device (μ-COM at slave address input of write command, read command, and this IC at data output of read command) at the transmitter (sending) side releases the bus after output of 8bit data. ・The device (this IC at slave address input of write command, read command, and μ-COM at data output of read command) at the receiver (receiving) side sets SDA 'LOW' during 9 clock cycles, and outputs acknowledge signal (ACK signal) showing that it has received the 8bit data. ・This IC, after recognizing start condition and slave address (8bit), outputs acknowledge signal (ACK signal) 'LOW'. ・Each write action outputs acknowledge signal (ACK signal) 'LOW', at receiving 8bit data (word address and write data). ・Each read action outputs 8bit data (read data), and detects acknowledge signal (ACK signal) 'LOW'. ・When acknowledge signal (ACK signal) is detected, and stop condition is not sent from the master (μ-COM) side, this IC continues data output. When acknowledge signal (ACK signal) is not detected, this IC stops data transfer, and recognizes stop cindition (stop bit), and ends read action. And this IC gets in status. ○Device addressing ・Output slave address after start condition from master. ・The significant 4 bits of slave address are used for recognizing a device type. The device code of this IC is fixed to '1010'. ・Next slave addresses (A2 A1 A0 --- device address) are for selecting devices, and plural ones can be used on a same bus according to the number of device addresses. ・The most insignificant bit (R/W --- READ / WRITE) of slave address is used for designating write or read action, and is as shown below. Setting R / W to 0 ------- write (setting 0 to word address setting of random read) Setting R / W to 1 ------- read Type BR24L01A-W BR24L02-W BR24L04-W BR24L08-W BR24L16-W BR24L32-W BR24L64-W 101 101 101 101 101 101 101 Slave address 0 0 0 0 0 0 0 A2 A1 A0 A2 A1 A0 A2 A1 PS A2 P1 P0 P2 P1 P0 A2 A1 A0 A2 A1 A0 R/W R/W R/W R/W R/W R/W R/W ― ― ― ― ― ― ― Maximum number of connected buses 8 8 4 2 1 8 8 PS, P0~P2 are page select bits. Note) Up to 4 units BR24L04-W, up to 2 units of BR24L08-W, and one unit of BR24L16-W can be connected. Device address is set by 'H' and 'L' of each pin of A0, A1, and A2. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 9/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●Write Command ○Write cycle ・Arbitrary data is written to EEPROM. When to write only 1 byte, byte write is normally used, and when to write continuous data of 2 bytes or more, simultaneous write is possible by page write cycle. The maximum number of write bytes is specified per device of each capacity. Up to 32 arbitrary bytes can be written. (In the case of BR24L32 / L64-W) S T A R T SDA LINE W R I T E WA 7 R A *1 /C WK S T O P SLAVE ADDRESS 1 0 1 0 A2 A1 A0 WORD ADDRESS WA 0 A C K D7 DATA *1 As for WA7, BR24L01A-W becomes Don’t care. D0 A C K Note) Fig.36 Byte write cycle (BR24L01A/02/04/08/16-W) S T A R T SDA LINE W R I T E S T O P D0 A C K SLAVE ADDRESS 1 0 1 0 A2 A1 A0 1st WORD ADDRESS W AWA 12 11 2nd WORD ADDRESS WA 0 DATA * * * D7 A C K *1 As for WA12, BR24L32-W becomes Don’t care. Note) RA /C WK *1 A C K Fig.37 Byte write cycle (BR24L32/64-W) S T A R T SDA L IN E W R I T E WA 7 RA / C *1 WK S T O P SLAVE ADDRESS 1 0 1 0 A 2A 1A 0 W ORD A D D R E S S (n ) WA 0 A C K D7 D A T A (n ) D0 A C K D A TA (n +1 5 ) *2 D0 A C K *1 As for WA7, BR24L01A-W becomes Don’t care. *2 As for BR24L01A/02-W becomes (n+7). N o te ) Fig.38 Page write cycle (BR24L01A/02/04/08/16-W) S T A R T SDA L IN E W R I T E * SLAVE ADDRESS 1 0 1 0 A 2A 1A 0 1 st W O R D A D D R E S S (n ) WA WA 1 2 11 2nd W ORD A D D R E S S (n ) WA 0 D A T A (n ) D7 A C K D0 A C K D A TA (n + 3 1 ) D0 A C K S T O P *1 As for WA12, BR24L32-W becomes Don’t care. * * N ote ) RA /C WK *1 A C K Fig.39 Page write cycle (BR24L32/64-W) ・Data is written to the address designated by word address (n-th address) ・By issuing stop bit after 8bit data input, write to memory cell inside starts. ・When internal write is started, command is not accepted for tWR (5ms at maximum). ・By page write cycle, the following can be written in bulk : Up to 8 bytes ( BR24L01A-W, BR24L02-W) : Up to 16bytes (BR24L04-W, BR24L08-W,BR24L16-W) : Up to 32bytes (BR24L32-W, BR24L64-W) And when data of the maximum bytes or higher is sent, data from the first byte is overwritten. (Refer to "Internal address increment" of "Notes on page write cycle" in P9/32.) ・As for page write cycle of BR24L01A-W and BR24L02-W, after the significant 5 bits (4 significant bits in BR24L01-W) of word address are designated arbitrarily, and as for page write command of BR24L04-W, BR24L08-W, and BR24L16-W, after page select bit (PS) of slave address is designated arbitrarily, by continuing data input of 2 bytes or more, the address of insignificant 4 bits (insignificant 3 bit in BR24L01A-W, and BR24L02-W) is incremented internally, and data up to 16 bytes (up to 8 bytes in BR24L01A-W and BR24L02-W) can be written. ・As for page write cycle of BR24L32-W and BR24L64-W, after the significant 7 bits (in the case of BR24L32-W) of word address, or the significant 8 bits (in the case of BR24L64-W) of word address are designated arbitrarily, by continuing data input of 2 byte or more, the address of insignificant 5 bits is incremented internally, and data up to 32 bytes can be written. Note) *1 *2 *3 *1 In BR24L16-W, A2 becomes P2. *2 In BR24L08-W, BR24L16-W, A1 becomes P1. *3 In BR24L04-W, A0 becomes PS, and in BR24L08-W and BR24L16-W, A0 becomes P0. 1 0 1 0 A 2A 1 0 A Fig.40 Difference of slave address of each type www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 10/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ○Notes on write cycle continuous input At STOP (stop bit), write starts. Technical Note S T A R T SDA LINE SLAVE ADDRESS W R I T E WORD ADDRESS(n) *1 WA 7 WA 0 DATA(n) DATA(n+7)*3 *2 S T O P S T A R T 10 10 1 0 1 0 A2A1A0 D7 D0 D0 Note) RA /C WK A C K A C K A C K Next command tWR(maximum : 5ms) Command is not accepted for this period. *1 BR24L01A-W becomes Don’t care. *2 BR24L04-W, BR24L08-W, and BR24L16-W become (n+15). *3 BR24L32-W and BR24L64-W become (n+31). Fig.41 Page write cycle Note) *1 *2 *3 1 0 1 0 A 2A 1 0 A *1 In BR24L16-W, A2 becomes P2. *2 In BR24L08-W, BR24L16-W, A1 becomes P1. *3 In BR24L04-W, A0 becomes PS, and in BR24L08-W and in BR24L16-W, A0 becomes P0. Fig.42 Difference of each type of slave address ○Notes on page write cycle List of numbers of page write Number of Pages Product number 8Byte BR24L01A-W BR24L02-W 16Byte BR24L04-W BR24L08-W BR24L16-W 32Byte BR24L32-W BR24L64-W The above numbers are maximum bytes for respective types. Any bytes below these can be written. In the case BR24L02-W, 1 page=8bytes, but the page write cycle write time is 5ms at maximum for 8byte bulk write. It does not stand 5ms at maximum × 8byte=40ms(Max.). www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 11/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ○Internal address increment Page write mode (in the case of BR24L02-W) WA7 ----0 ----0 ----0 ------------WA4 0 0 0 WA3 0 0 0 --------WA2 0 0 0 WA1 0 0 1 --------WA0 0 1 0 Technical Note Increment 06h 0 0 0 ------------- 0 0 0 0 0 0 1 1 0 1 1 0 0 1 0 Significant bit is fixed. No digit up For example, when it is started from address 06h,therefore, increment is made as below, 06h → 07h → 00h → 01h ---, which please note. * 06h・・・06 in hexadecimal, therefore, 00000110 becomes a binary number. ○Write protect (WP) terminal ・Write protect (WP) function When WP terminal is set Vcc (H level), data rewrite of all addresses is prohibited. When it is set GND (L level), data rewrite of all address is enabled. Be sure to connect this terminal to Vcc or GND, or control it to H level or L level. Do not use it open. At extremely low voltage at power ON / OFF, by setting the WP terminal 'H', mistake write can be prevented. During tWR, set the WP terminal always to 'L'. If it is set 'H', write is forcibly terminated. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 12/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●Read Command ○Read cycle Data of EEPROM is read. In read cycle, there are random read cycle and current read cycle. Random read cycle is a command to read data by designating address, and is used generally. Current read cycle is a command to read data of internal address register without designating address, and is used when to verify just after write cycle. In both the read cycles, sequential read cycle is available, and the next address data can be read in succession. S T A R T SDA L IN E W R I T E WA 7 R A *1 /C WK S T A R T R E A D D7 RA /C WK S T O P D0 A C K It is necessary to input 'H' to the last ACK. SLAVE ADDRESS 1 0 1 0 A 2 A 1A 0 N o te ) W ORD A D D R E S S (n ) WA 0 A C K SLAVE ADDRESS 1 0 1 0 A 2 A 1A 0 D A TA (n ) *1 As for WA7, BR24L01A-W become Don’t care. Fig.43 Random read cycle (BR24L01A/02/04/08/16-W) S T A R T SDA LINE W R I T E S T A R T R E A D S T O P SLAVE ADDRESS 1st WORD ADDRESS(n) 2nd WORD ADDRESS(n) WA 0 SLAVE ADDRESS DATA(n) 1 0 1 0 A2A1A0 *** RA /C WK WAWA 12 11 1 0 1 0 A2 A1A0 D7 D0 Note) *1 A C K A C K RA /C WK A C K *1 As for WA12, BR24L32-W become Don’t care. Fig.44 Random read cycle (BR24L32/64 -W) S T A R T SDA L IN E R E A D D7 RA /C WK S T O P D0 A C K S LA V E ADDRESS 1 0 1 0 A 2 A 1A 0 D A TA (n ) It is necessary to input 'H' to the last ACK. N o te) Fig.45 Current read cycle S T A R T SDA LINE SLAVE ADDRESS R E A D S T O P D0 A C K DATA(n) DATA(n+x) 1 0 1 0 A2 A1A0 RA /C WK D7 D0 A C K A C K D7 Note) Fig.46 Sequential read cycle (in the case of current read cycle) ・In random read cycle, data of designated word address can be read. ・When the command just before current read cycle is random read cycle, current read cycle (each including sequential read cycle), data of incremented last read address (n)-th address, i.e., data of the (n+1)-th address is output. ・When ACK signal 'LOW' after D0 is detected, and stop condition is not sent from master (μ-COM) side, the next address data can be read in succession. ・Read cycle is ended by stop condition where 'H' is input to ACK signal after D0 and SDA signal is started at SCL signal 'H' . ・When 'H' is not input to ACK signal after D0, sequential read gets in, and the next data is output. Therefore, read command cycle cannot be ended. When to end read command cycle, be sure input stop condition to input 'H' to ACK signal after D0, and to start SDA at SCL signal 'H'. ・Sequential read is ended by stop condition where 'H' is input to ACK signal after arbitrary D0 and SDA is started at SCL signal 'H'. Note) *1 *2 *3 *1 In BR24L16-W, A2 becomes P2. *2 In BR24L08-W, BR24L16-W, A1 becomes P1. *3 In BR24L04-W, A0 becomes PS, and in BR24L08-W and BR24L16-W, A0 becomes P0. 1 0 1 0 A 2A 1 0 A Fig.47 Difference of slave address of each type www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 13/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●Software reset Software reset is executed when to avoid malfunction after power on, and to reset during command input. Software reset has several kinds, and 3 kinds of them are shown in the figure below. (Refer to Fig.48(a), Fig.48(b), and Fig.48(c).) In dummy clock input area, release the SDA bus ('H' by pull up). In dummy clock area, ACK output and read data '0' (both 'L' level) may be output from EEPROM, therefore, if 'H' is input forcibly, output may conflict and over current may flow, leading to instantaneous power failure of system power source or influence upon devices. Dummy clock×14 Start×2 SCL SDA 1 2 13 14 Normal command Normal command Fig.48-(a) The case of dummy clock +START+START+ command input Start Dummy clock×9 Start SCL SDA 1 2 8 9 Normal command Normal command Fig.48-(b) The case of START +9 dummy clocks +START+ command input Start×9 SCL SDA 1 2 3 7 8 9 Normal command Normal command * Start command from START input. Fig.48-(c) START×9+ command input ●Acknowledge polling During internal write execution, all input commands are ignored, therefore ACK is not sent back. During internal automatic write execution after write cycle input, next command (slave address) is sent, and if the first ACK signal sends back 'L', then it means end of write action, while if it sends back 'H', it means now in writing. By use of acknowledge polling, next command can be executed without waiting for tWR = 5ms. When to write continuously, R/W = 0, when to carry out current read cycle after write, slave address R/W = 1 is sent, and if ACK signal sends back 'L', then execute word address input and data output and so forth. First write command S T A R T Write command S T O P S T Slave A R address T A C K H During internal write, ACK = HIGH is sent back. S T Slave A R address T A C K H tWR Second write command S T Slave A R address T A C K H S T Slave A R address T A C Word K address L A C K L A C K L S T O P … Data tWR After completion of internal write, ACK=LOW is sent back, so input next word address and data in succession. Fig.49 Case to continuously write by acknowledge polling www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 14/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●WP valid timing (write cancel) WP is usually fixed to 'H' or 'L', but when WP is used to cancel write cycle and so forth, pay attention to the following WP valid timing. During write cycle execution, in cancel valid area, by setting WP='H', write cycle can be cancelled. In both byte write cycle and page write cycle, the area from the first start condition of command to the rise of clock to taken in D0 of data(in page write cycle, the first byte data) is cancel invalid area. WP input in this area becomes Don't care. Set the setup time to rise of D0 taken SCL 100ns or more. The area from the rise of SCL to take in D0 to the end of internal automatic write (tWR) is cancel valid area. And, when it is set WP='H' during tWR, write is ended forcibly, data of address under access is not guaranteed, therefore, write it once again. (Refer to Fig.50.) After execution of forced end by WP, standby status gets in, so there is no need to wait for tWR (5ms at maximum). ・Rise of D0 taken clock SCL SCL SDA D1 D0 ACK ・Rise of SDA SDA ACK D0 Enlarged view Enlarged view SDA S T Slave A address R T A C Word K address L A C D7 D6 D5 D4 D3 D2 D1 D0 K L A C K L Data A C K L S T O P tWR WP cancel invalid area WP cancel valid area Write forced end WP Data is not written. Data not guaranteed Fig.50 WP valid timing ●Command cancel by start condition and stop condition During command input, by continuously inputting start condition and stop condition, command can be cancelled. (Refer to Fig. 51) However, in ACK output area and during data read, SDA bus may output 'L', and in this case, start condition and stop condition cannot be input, so reset is not available. Therefore, execute software reset. And when command is cancelled by start, stop condition, during random read cycle, sequential read cycle, or current read cycle, internal setting address is not determined, therefore, it is not possible to carry out current read cycle in succession. When to carry out read cycle in succession, carry out random read cycle. SCL SDA 1 0 1 0 Start condition Stop condition Fig.51 Case of cancel by start, stop condition during slave address input www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 15/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●I/O peripheral circuit ○Pull up resistance of SDA terminal SDA is NMOS open drain, so requires pull up resistance. As for this resistance value (RPU), select an appropriate value to this resistance value from microcontroller VIL, IL, and VOL-IOL characteristics of this IC. If RPU is large, action frequency is limited. The smaller the RPU, the larger the consumption current at action. ○Maximum value of RPU The maximum value of RPU is determined by the following factors. (1)SDA rise time to be determined by the capacitance (CBUS) of bus line of RPU and SDA should be tR or below. And AC timing should be satisfied even when SDA rise time is late. A (2)The bus electric potential ○ to be determined by input leak total (IL) of device connected to bus at output of 'H' to SDA bus and RPU should sufficiently secure the input 'H' level (VIH) of microcontroller and EEPROM including recommended noise margin 0.2Vcc. Microcontroller VCC - ILRPU - 0.2Vcc ≧ VIH ∴ RPU = 0.8Vcc-VIH IL RPU BR24LXX Ex. ) When VCC =3V, IL=10μA, VIH=0.7 VCC, from (2) RPU 0.8×3-0.7×3 ≦ 10×10-6 ≦ 300 [kΩ] A IL IL Bus line capacity CBUS SDA terminal Fig.52 I/O circuit diagram ○Minimum value of RPU The minimum value of RPU is determined by the following factors. (1)When IC outputs LOW, it should be satisfied that VOLMAX=0.4V and IOLMAX=3mA. VCC-VOL ≦ IOL RPU ∴ RPU ≦ VC-VOL IOL (2)VOLMAX=0.4V should secure the input 'L' level (VIL) of microcontroller and EEPROM including recommended noise margin 0.1Vcc. VOLMAX ≦ VIL-0.1 VCC Ex. ) When VCC =3V, VOL=0.4V, IOL=3mA, microcontroller, EEPROM VIL=0.3VCC from (1) 3-0.4 RPU ≧ 3×10 -3 ≧ And VOL = 0.4 [V] VIL = 0.3×3 = 0.9 [V] Therefore, the condition (2) is satisfied. ○Pull up resistance of SCL terminal When SCL control is made at CMOS output port, there is no need, but in the case there is timing where SCL becomes 'Hi-Z', add a pull up resistance. As for the pull up resistance, one of several kΩ ~ several ten kΩ is recommended in consideration of drive performance of output port of microcontroller. ●A0, A1, A2, WP process ○Process of device address terminals (A0,A1,A2) Check whether the set device address coincides with device address input sent from the master side or not, and select one among plural devices connected to a same bus. Connect this terminal to pull up or pull down, or Vcc or GND. And, pins (N, C, PIN) not used as device address may be set to any of 'H' , 'L', and 'Hi-Z'. Types with N.C.PIN BR24L16/F/FJ/FV/FVT/FVM/FVJ-W A0, A1, A2 BR24L08/F/FJ/FV/FVT/FVM/FVJ/NUX-W A0, A1 BR24L04/F/FJ/FV/FVT/FVM/FVJ/NUX-W A0 ○Process of WP terminal WP terminal is the terminal that prohibits and permits write in hardware manner. In 'H' status, only READ is available and WRITE of all address is prohibited. In the case of 'L', both are available. In the case of use it as an ROM, it is recommended to connect it to pull up or Vcc. In the case to use both READ and WRITE, control WP terminal or connect it to pull down or GND. 867 [Ω] www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 16/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●Cautions on microcontroller connection ○Rs 2 In I C BUS, it is recommended that SDA port is of open drain input/output. However, when to use CMOS input / output of tri state to SDA port, insert a series resistance Rs between the pull up resistance Rpu and the SDA terminal of EEPROM. This is controls over current that occurs when PMOS of the microcontroller and NMOS of EEPROM are turned ON simultaneously. Rs also plays the role of protection of SDA terminal against surge. Therefore, even when SDA port is open drain input/output, Rs can be used. ACK SCL RPU RS SDA 'H' output of microcontroller 'L' output of EEPROM Microcontroller EEPROM Over current flows to SDA line by 'H' output of microcontroller and 'L' output of EEPROM. Fig.53 I/O circuit diagram Fig.54 Input / output collision timing ○Maximum value of Rs The maximum value of Rs is determined by the following relations. (1)SDA rise time to be determined by the capacity (CBUS) of bus line of Rpu and SDA should be tR or below. And AC timing should be satisfied even when SDA rise time is late. A (2)The bus electric potential ○to be determined by Rpu and Rs the moment when EEPROM outputs 'L' to SDA bus should sufficiently secure the input 'L' level (VIL) of microcontroller including recommended noise margin 0.1Vcc. VCC RPU A RS IOL Bus line capacity CBUS (VCC-VOL)×RS RPU+RS VOL + VOL+0.1VCC≦VIL × RPU ∴ RS ≦ VIL-VOL-0.1VCC 1.1VCC-VIL Example) When VCC=3V, VIL=0.3VCC, VOL=0.4V, RPU=20kΩ from(2), RS ≦ ≦ 0.3×3-0.4-0.1×3 1.1×3-0.3×3 1.67[kΩ] × 20×103 VIL Microcontroller EEPROM Fig.55 I/O circuit diagram ○Minimum value of Rs The minimum value of Rs is determined by over current at bus collision. When over current flows, noises in power source line, and instantaneous power failure of power source may occur. When allowable over current is defined as I, the following relation must be satisfied. Determine the allowable current in consideration of impedance of power source line in set and so forth. Set the over current to EEPROM 10mA or below. VCC RS ∴ RS RPU RS ≦ ≧ I VCC I 3 -3 10×10 300[Ω] 'L' output Over currentⅠ 'H' output Example)When VCC=3V, I=10mA RS ≧ Microcontroller EEPROM ≧ Fig.56 I/O circuit diagram www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 17/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●I2C BUS input / output circuit ○Input (A0,A2,SCL) Technical Note Fig.57 Input pin circuit diagram ○Input / output (SDA) Fig.58 Input / output pin circuit diagram ○Input (A1, WP) Fig.59 Input pin circuit diagram ●Notes on power ON At power on, in IC internal circuit and set, Vcc rises through unstable low voltage area, and IC inside is not completely reset, and malfunction may occur. To prevent this, functions of POR circuit and LVCC circuit are equipped. To assure the action, observe the following conditions at power on. 1. Set SDA = 'H' and SCL ='L' or 'H' 2. Start power source so as to satisfy the recommended conditions of tR, tOFF, and Vbot for operating POR circuit. VCC tR Recommended conditions of tR, tOFF,Vbot tR tOFF tOFF Vbot 0.3V or below 0.2V or below 10ms or below Vbot 10ms or longer 10ms or longer 100ms or below 0 Fig.60 Rise waveform diagram www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 18/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note 3. Set SDA and SCL so as not to become 'Hi-Z'. When the above conditions 1 and 2 cannot be observed, take the following countermeasures. a) In the case when the above condition 1 cannot be observed. When SDA becomes 'L' at power on . →Control SCL and SDA as shown below, to make SCL and SDA, 'H' and 'H'. VCC SCL tLOW SDA After Vcc becomes stable After Vcc becomes stable tDH tSU:DAT tSU:DAT Fig.61 When SCL= 'H' and SDA= 'L' Fig.62 When SCL='L' and SDA='L' b) In the case when the above condition 2 cannot be observed. →After power source becomes stable, execute software reset(P11). c) In the case when the above conditions 1 and 2 cannot be observed. →Carry out a), and then carry out b). ●Low voltage malfunction prevention function LVCC circuit prevents data rewrite action at low power, and prevents wrong write. At LVCC voltage (Typ. =1.2V) or below, it prevent data rewrite. ●Vcc noise countermeasures ○Bypass capacitor When noise or surge gets in the power source line, malfunction may occur, therefore, for removing these, it is recommended to attach a by pass capacitor (0.1μF) between IC Vcc and GND. At that moment, attach it as close to IC as possible. And, it is also recommended to attach a bypass capacitor between board Vcc and GND. ●Notes for use (1) Described numeric values and data are design representative values, and the values are not guaranteed. (2) We believe that application circuit examples are recommendable, however, in actual use, confirm characteristics further sufficiently. In the case of use by changing the fixed number of external parts, make your decision with sufficient margin in consideration of static characteristics and transition characteristics and fluctuations of external parts and our LSI. (3) Absolute maximum ratings If the absolute maximum ratings such as impressed voltage and action temperature range and so forth are exceeded, LSI may be destructed. Do not impress voltage and temperature exceeding the absolute maximum ratings. In the case of fear exceeding the absolute maximum ratings, take physical safety countermeasures such as fuses, and see to it that conditions exceeding the absolute maximum ratings should not be impressed to LSI. (4) GND electric potential Set the voltage of GND terminal lowest at any action condition. Make sure that each terminal voltage is lower than that of GND terminal. (5) Terminal design In consideration of permissible loss in actual use condition, carry out heat design with sufficient margin. (6) Terminal to terminal shortcircuit and wrong packaging When to package LSI onto a board, pay sufficient attention to LSI direction and displacement. Wrong packaging may destruct LSI. And in the case of shortcircuit between LSI terminals and terminals and power source, terminal and GND owing to foreign matter, LSI may be destructed. (7) Use in a strong electromagnetic field may cause malfunction, therefore, evaluate design sufficiently. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 19/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Serial EEPROM Series Technical Note High Reliability Series EEPROMs I2C BUS BR24S□□□-W Series ●Description BR24S□□□-W series is a serial EEPROM of I2C BUS interface method. ●Features 2 1) Completely conforming to the world standard I C BUS. All controls available by 2 ports of serial clock (SCL) and serial data (SDA) 2) Other devices than EEPROM can be connected to the same port, saving microcontroller port. 3) 1.7~5.5V single power source action most suitable for battery use. 4) FAST MODE 400kHz at 1.7~5.5V 5) Page write mode useful for initial value write at factory shipment. 6) Highly reliable connection by Au pad and Au wire. 7) Auto erase and auto end function at data rewrite. 8) Low current consumption At write operation (5V) : 0.5mA (Typ.) At read operation (5V) : 0.2mA (Typ.) At standby operation (5V) : 0.1μA (Typ.) 9) Write mistake prevention function Write (write protect) function added Write mistake prevention function at low voltage 10) SOP8/SOP-J8/SSOP-B8/TSSOP-B8/MSOP8/TSSOP-B8J/VSON008X2030 compact package 11) Data rewrite up to 1,000,000 times 12) Data kept for 40 years 13) Noise filter built in SCL / SDA terminal 14) Shipment data all address FFh ●Page write Number of pages Product number ●BR24S series Capacity 8Kbit 16Kbit 32Kbit 64Kbit 128Kbit 256Kbit Bit format 1K×8 2K×8 4K×8 8K×8 16K×8 32K×8 Type BR24S08-W BR24S16-W BR24S32-W BR24S64-W BR24S128-W BR24S256-W Power source voltage 1.7~5.5V 1.7~5.5V 1.7~5.5V 1.7~5.5V 1.7~5.5V 1.7~5.5V SOP8 ● ● ● ● ● ● 16Byte BR24S08-W BR24S16-W 32Byte BR24S32-W BR24S64-W 64Byte BR24S128-W BR24S256-W SOP-J8 ● ● ● ● ● ● SSOP-B8 TSSOP-B8 ● ● ● ● ● ● ● ● ● ● MSOP8 ● ● ● ● TSSOP-B8J ● ● ● ● VSON008 X2030 ● ● ● www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 20/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Absolute maximum ratings (Ta=25℃) Parameter Impressed voltage Technical Note symbol VCC Limits -0.3~+6.5 450 (SOP8) *1 450 (SOP-J8) *2 300 (SSOP-B8) *3 Unit V Permissible dissipation Pd 330 (TSSOP-B8) *4 310 (MSOP8) *5 mW 310 (TSSOP-B8J) *6 300 (VSON008X2030) *7 Storage temperature range Action temperature range Terminal voltage Tstg Topr -65~+125 -40~+85 -0.3~Vcc+1.0 ℃ ℃ V *When using at Ta=25℃ or higher, 4.5mW(*1,*2), 3.0mW(*3,*7) 3.3mW(*4),3.1mW(*5,*6) to be reduced per 1℃ ●Memory cell characteristics (Ta=25℃, Vcc=1.7~5.5V) Parameter Number of data rewrite times *1 Data hold years *1 Not 100% TESTED *1 Limits Min. 1,000,000 40 Typ. Max. - Unit Times Years ●Recommended operating conditions Parameter Power source voltage Input voltage Symbol Vcc VIN Limits 1.7~5.5 0~Vcc Unit V ●Electrical characteristics (Unless otherwise specified, T=-40~+85℃, Vcc=1.7~5.5V) Limits Parameter Symbol Min Typ. Max. "H" Input Voltage1 "L" Input Voltage1 "L" Output Voltage1 "L" Output Voltage2 Input Leakage Current Output Leakage Current VIH1 VIL1 VOL1 VOL2 ILI ILO 0.7Vcc -0.3 -1 -1 Current consumption at action ICC1 ICC2 Standby Current ISB 2.5 0.5 2.0 Vcc+1.0 0.3Vcc 0.4 0.2 1 1 2.0 Unit V V V V μA μA Condition IOL=3.0mA , 2.5V≦Vcc≦5.5V (SDA) IOL=0.7mA , 1.7V≦Vcc≦2.5V (SDA) VIN=0~Vcc VOUT=0~Vcc (SDA) Vcc=5.5V , fSCL =400kHz, tWR=5ms Byte Write, Page Write BR24S08/16/32/64-W Vcc=5.5V , fSCL =400kHz, tWR=5ms Byte Write, Page Write BR24S128/256-W Vcc=5.5V , fSCL =400kHz Random read, Current read, Sequential read Vcc=5.5V , SDA・SCL=Vcc A0, A1, A2=GND, WP=GND mA mA μA ○Radiation resistance design is not made. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 21/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Action timing characteristics (Unless otherwise specified, T=-40~+85℃, Vcc=1.7~5.5V) Parameter SCL Frequency Data clock "High" time Data clock "Low" time SDA, SCL rise time SDA, SCL fall time *1 *1 Symbol fSCL tHIGH tLOW tR tF tHD:STA tSU:STA tHD:DAT tSU:DAT tPD tDH tSU:STO tBUF tWR tI tHD:WP tSU:WP tHIGH:WP Limits Min. 0.6 1.2 0.6 0.6 0 100 0.1 0.1 0.6 1.2 0 0.1 1.0 Typ. - Technical Note Max. 400 0.3 0.3 0.9 5 0.1 - Unit kHz μs μs μs μs μs μs ns ns μs μs μs μs ms μs ns μs μs Start condition hold time Start condition setup time Input data hold time Input data setup time Output data delay time Output data hold time Stop condition data setup time Bus release time before transfer start Internal write cycle time Noise removal valid period (SDA,SCL terminal) WP hold time WP setup time WP valid time *1 : Not 100% TESTED www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 22/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Sync data input/output timing tR SCL tHD:STA (入力) (Input) tBUF SDA (出力) (Output) tPD tDH S DA tSU:DAT tLOW tHD:DAT tF tHIGH Technical Note SCL tSU:STA SDA tHD:STA tSU:STO START BIT STOP BIT ○Input read at the rise edge of SCL ○Data output in sync with the fall of SCL Fig.1-(a) Sync data input / output timing Fig.1-(b) Start - stop bit timing SCL SCL DATA(1) DATA(n) ACK ACK tWR WP ストップコンディション Stop condition SDA D0 ACK WRITE DATA (n) STOP CONDITION tWR START CONDITION SDA D1 D0 tSU:WP tHD:WP Fig.1-(c) Write cycle timing Fig.1-(d) WP timing at write execution SCL DATA(1) SDA D1 D0 ACK tHIGH:WP WP DATA(n) ACK tWR tWR ○At write execution, in the area from the D0 taken clock rise of the first DATA(1), to tWR, set WP= 'LOW'. ○By setting WP "HIGH" in the area, write can be cancelled. When it is set WP = 'HIGH' during tWR, write is forcibly ended, and data of address under access is not guaranteed, therefore write it once again. Fig.1-(e) WP timing at write cancel ●Block diagram *2 A0 1 *1 10bit 11bi t 12bit 13bit 14bit 15bit 8Kbit ~256Kbit EEPROM array 8bit 8 Vcc *2 A1 2 A dddress decoder *1 1 0bit 11bit 12bit 13bit 14bit 15bit S lave - word address register Data register 7 WP *2 START STOP A2 3 Control circuit ACK 6 SCL GND 4 * High voltage generating circuit 1 10bit: BR24S08-W 11bit: BR24S16-W 12bit: BR24S32-W 13bit: BR24S64-W 14bit: BR24S128-W 15bit: BR24S256-W * Power source voltage detection 2 A0, A1= Don’t use: BR24S08-W A0, A1, A2= Don’t use: BR24S16-W 5 SDA Fig.2 Block diagram www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 23/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Pin assignment and description A0 1 BR24S08-W BR24S16-W BR24S32-W BR24S64-W BR24S128-W BR24S256-W 8 Vcc Technical Note A1 2 7 WP A2 3 6 SCL GND 4 5 SDA Terminal name A0 A1 A2 GND SDA SCL WP Vcc Input/ Output Input Input Input Input / Output Input Input - Function BR24S08-W Don't use Don't use Slave address setting BR24S16-W Don't use Don't use Don't use Reference voltage of all input / output, 0V. Slave and word address, Serial data input serial data output Serial clock input Write protect terminal Connect the power source. BR24S32/64/128/256-W Slave address setting Slave address setting Slave address setting ●Characteristic data (The following values are Typ. ones.) 6 H INPUT VOLTAGE : VIH[V] 5 4 3 6 5 4 3 2 1 1 L INPUT VOLTAGE : VIL[V] Ta=-40℃ Ta=25℃ Ta=85℃ L OUTPUT VOLTAGE : VOL[V] Ta=-40℃ Ta=25℃ Ta=85℃ 0.8 0.6 0.4 Ta=-40℃ Ta=25℃ Ta=85℃ SPEC 2 1 0 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 SPEC 0.2 0 SPEC 0 0 1 2 3 4 5 6 SUPPLY VOLTAGE : Vcc[V] 0 1 2 3 4 5 6 7 L OUTPUT CURRENT : IOL[mA] 8 Fig.3 'H' input voltage VIH (A0,A1,A2,SCL,SDA,WP) 1 INPUT LEAK CURRENT : ILI[uA] L OUTPUT VOLTAGE : VOL[V] 0.8 0.6 0.4 0.2 0 0 1 2 3 4 5 L OUTPUT CURRENT : IOL[mA] 6 1.2 Fig.4 'L' input voltage VIL (A0,A1,A2,SCL,SDA,WP) 1.2 OUTPUT LEAK CURRENT : ILO[uA] Fig.5 'L' output voltage VOL-IOL(Vcc=1.7V) SPEC 1 0.8 0.6 0.4 0.2 0 0 1 2 3 4 5 SUPPLYVOLTAGE : Vcc[V] 6 1 0.8 0.6 0.4 0.2 0 0 1 SPEC Ta=-40℃ Ta=25℃ Ta=85℃ SPEC Ta=-40℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=25℃ Ta=85℃ 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 Fig.6 'L' output voltage VOL-IOL(Vcc=2.5V) Fig.7 Input leak current ILI (A0,A,A2,SCL,WP) Fig.8 Output leak current ILO(SDA) www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 24/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Characteristic data (The following values are Typ. ones.) 2.5 Technical Note 3.5 0.6 CURRENT CONSUMPTION AT WRITING : Icc1[mA] CURRENT CONSUMPTION AT WRITING : Icc1[mA] 2 SPEC 2.5 2 1.5 1 0.5 0 CURRENT CONSUMPTION AT READING : Icc2[mA] SPEC 3 SPEC 0.5 0.4 0.3 0.2 0.1 0 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 1.5 1 Ta=-40℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=25℃ Ta=85℃ 0.5 0 0 1 2 3 4 5 6 SUPPLY VOLTAGE : Vcc[V] Fig.9 Current consumption at WRITE operation ICC1 (fSCL=400kHz BR24S16/32/64-W) 2.5 SCL FREQUENCY : fscl[kHZ] STANBY CURRENT : ISB[uA] Fig.10 Current consumption at WRITE operation Icc1 (fSCL=400kHz BR24S128/256-W) 10000 1000 Fig.11 Current consumption at READ operation ICC2 (fSCL=400kHz) 1 DATA CLK H TIME : tHIGH[us] 0.8 0.6 0.4 0.2 0 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 Ta=-40℃ Ta=25℃ Ta=85℃ SPEC 2 1.5 1 0.5 0 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 SPEC 100 10 1 0.1 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 SPEC Ta=-40℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=25℃ Ta=85℃ Fig.12 Stanby operation ISB START CONDITION HOLD TIME : tHD : STA[us] Fig.13 SCL frequency fSCL 5 4 3 2 1 0 0 1 2 3 4 5 6 SUPPLY VOLTAGE : Vcc[V] Fig.14 Data clock High Period tHIGH 0.8 START CONDITION SET UP TIME : tSU:STA[us] 5 DATA CLK L TIME : tLOW[us] SPEC 4 3 2 1 0 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 SPEC 0.6 0.4 0.2 0 -0.2 0 1 SPEC Ta=-40℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=25℃ Ta=85℃ 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 Fig.15 Data clock Low Period tLOW Fig.16 Start Condition Hold Time tHD : STA Fig.17 Start Condition Setup Time tSU : STA SPEC 0 -50 -100 -150 -200 0 1 2 3 4 5 6 SUPPLY VOLTAGE : Vcc[V] SPEC 0 -50 INPUT DATA SET UP TIME : tSU: DAT[ns] INPUT DATA HOLD TIME : tHD :DAT[ns] 50 INPUT DATA HOLD TIME : tHD: STA[ns] 50 300 200 SPEC 100 0 -100 -200 0 1 2 3 4 5 6 SUPPLY VOLTAGE : Vcc[V] Ta=-40℃ Ta=25℃ Ta=85℃ -100 -150 -200 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 Ta=-40℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=25℃ Ta=85℃ Fig.18 Input Data Hold Time tHD : DAT(HIGH) Fig.19 Input Data Hold Time tHD : DAT(LOW) Fig.20 Input Data Setup Time tSU: DAT(HIGH) INPUT DATA SET UP TIME : tSU : DAT[ns] OUTPUT DATA DELAY TIME : tPD[us] 200 3 Ta=-40℃ Ta=25℃ Ta=85℃ SPEC OUTPUT DATA DELAY TIME : tPD[us] 300 4 4 3 SPEC 100 0 -100 -200 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 Ta=-40℃ Ta=25℃ Ta=85℃ SPEC 2 2 Ta=-40℃ Ta=25℃ Ta=85℃ 1 1 0 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 0 0 1 2 3 4 5 6 SUPPLY VOLTAGE : Vcc[V] Fig.21 Input Data setup time tSU : DAT(LOW) Fig.22 'L' Data output delay time tPD0 Fig.23 'H' Data output delay time tPD1 www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 25/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Characteristic data (The following values are Typ. ones.) 5 BUS OPEN TIME BEFORE TRANSMISSION : tBUF[us] INTERNAL WRITING CYCLE TIME : tWR[ms] 4 3 2 1 0 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 6 Technical Note 1 Ta=-40℃ Ta=25℃ Ta=85℃ 5 4 3 2 1 0 0 1 SPEC NOISE REDUCTION EFECTIVE TIME : tl(SCL H) [us] SPEC 0.8 0.6 0.4 0.2 0 Ta=-40℃ Ta=25℃ Ta=85℃ SPEC Ta=-40℃ Ta=25℃ Ta=85℃ 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 Fig.24 BUS open time before transmission tBUF 0.6 NOISE REDUCTION EFECTIVE TIME : tl(SDA H)[us] NOISE REDUCTION EFECTIVE TIME : tl(SCL L)[us] 0.5 0.4 0.3 0.2 0.1 0 0 1 2 3 4 5 6 SUPPLY VOLTAGE : Vcc[V] 0.6 Fig.25 Internal writing cycle time tWR Fig.26 Noise reduction efection time tl(SCL H) 0.6 NOISE REDUCTION EFFECTIVE TIME : tl(SAD L)[us] Ta=-40℃ Ta=25℃ Ta=85℃ 0.5 0.4 0.3 0.2 Ta=-40℃ Ta=25℃ Ta=85℃ 0.5 0.4 0.3 0.2 0.1 0 SPEC Ta=-40℃ Ta=25℃ Ta=85℃ SPEC SPEC 0.1 0 0 2 4 6 SUPPLY VOLATGE : Vcc[V] 0 1 2 3 4 5 6 SUPPLY VOLTAGE : Vcc[V] Fig.27 Noise reduction efective time tl(SCL L) Fig.28 Noise resuction efecctive time tl(SDA H) Fig.29 Noise reduction efective time tl(SDA L) 0.2 WP SET UP TIME : tSU : WP[us] 0.1 0 -0.1 -0.2 -0.3 -0.4 -0.5 -0.6 0 1 2 3 4 5 SUPPLY VOLTAGE : Vcc[V] 6 1.2 SPEC WP EFFECTIVE TIME : tHIGH : WP[us] SPEC 1 0.8 0.6 0.4 0.2 0 0 1 2 3 4 5 SUPPLYVOLTAGE : Vcc[V] 6 Ta=-40℃ Ta=25℃ Ta=85℃ Ta=-40℃ Ta=25℃ Ta=85℃ Fig.30 WP setup time tSU : WP Fig.31 WP efective time tHIGH : WP www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 26/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●I2C BUS communication 2 ○I C BUS data communication 2 I C BUS data communication starts by start condition input, and ends by stop condition input. Data is always 8bit long, and acknowledge is always required after each byte. I2C BUS carries out data transmission with plural devices connected by 2 communication lines of serial data (SDA) and serial clock (SCL). Among devices, there are “master” that generates clock and control communication start and end, and “slave” that is controlled by addresses peculiar to devices. EEPROM becomes “slave”. And the device that outputs data to bus during data communication is called “transmitter”, and the device that receives data is called “receiver”. SDA SCL 1-7 S START ADDRESS condition 8 9 1-7 8 9 1-7 8 9 P STOP condition R/W ACK DATA ACK DATA ACK Fig.32 Data transfer timing ○Start condition (start bit recognition) ・Before executing each command, start condition (start bit) where SDA goes from 'HIGH' down to 'LOW' when SCL is 'HIGH' is necessary. ・This IC always detects whether SDA and SCL are in start condition (start bit) or not, therefore, unless this condition is satisfied, any command is executed. ○Stop condition (stop bit recognition) ・Each command can be ended by SDA rising from 'LOW' to 'HIGH' when stop condition (stop bit), namely, SCL is 'HIGH' ○Acknowledge (ACK) signal ・This acknowledge (ACK) signal is a software rule to show whether data transfer has been made normally or not. In master and slave, the device (μ-COM at slave address input of write command, read command, and this IC at data output of read command) at the transmitter (sending) side releases the bus after output of 8bit data. ・The device (this IC at slave address input of write command, read command, and μ-COM at data output of read command) at the receiver (receiving) side sets SDA 'LOW' during 9 clock cycles, and outputs acknowledge signal (ACK signal) showing that it has received the 8bit data. ・This IC, after recognizing start condition and slave address (8bit), outputs acknowledge signal (ACK signal) 'LOW'. ・Each write action outputs acknowledge signal) (ACK signal) 'LOW', at receiving 8bit data (word address and write data). ・Each read action outputs 8bit data (read data), and detects acknowledge signal (ACK signal) 'LOW'. ・When acknowledge signal (ACK signal) is detected, and stop condition is not sent from the master (μ-COM) side, this IC continues data output. When acknowledge signal (ACK signal) is not detected, this IC stops data transfer, and recognizes stop condition (stop bit), and ends read action. And this IC gets in standby status. ○Device addressing ・Output slave address after start condition from master. ・The significant 4 bits of slave address are used for recognizing a device type. The device code of this IC is fixed to '1010'. ・Next slave addresses (A2 A1 A0 --- device address) are for selecting devices, and plural ones can be used on a same bus according to the number of device addresses. ・The most insignificant bit (R/W --- READ/WRITE) of slave address is used for designating write or read action, and is as shown below. Setting R/W to 0 --- write (setting 0 to word address setting of random read) Setting R/W to 1 --- read Type BR24S08-W BR24S16-W BR24S32-W, BR24S64-W BR24S128-W, BR24S256-W 101 101 101 Slave address 0 0 0 A2 P1 P0 P2 P1 P0 A2 A1 A0 R/W R/W R/W ― ― ― A0 1 BR24S08-W BR24S16-W BR24S32-W BR24S64-W BR24S128-W BR24S256-W 8 Vcc Maximum number of connected buses 2 1 8 A1 2 7 WP A2 3 6 SCL GND 4 5 SDA P0~P2 are page select bits. Note) Up to 2 units of BR24S08-W, up to 1 units of BR24S16-W, and up to 8 units of BR24S32/64/128/256-W can be connected. Device address is set by 'H' and 'L' of each pin of A0, A1, and A2. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 27/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●Write Command ○Write cycle ・Arbitrary data is written to EEPROM. When to write only 1 byte, byte write normally used, and when to write continuous data of 2 bytes or more, simultaneous write is possible by page write cycle. The maximum number of write bytes is specified per device of each capacity. Up to 64 arbitrary bytes can be written. (In the case of BR24S128/256-W) S T A R T SDA LINE W R I T E WA 7 RA /C WK S T O P D0 A C K SLAVE ADDRESS 1 0 1 0 A2 A1 A0 WORD ADDRESS WA 0 A C K D7 DATA Note) Fig.33 Byte write cycle (BR24S08/16-W) S T A R T SDA LINE SLAVE ADDRESS 1 0 1 0 A2 A1 A0 RA /C WK W R I T E 1st WORD ADDRESS * W A W A WAWA 14 13 12 11 2nd WORD ADDRESS WA 0 DATA S T O P D0 A C K *1 D7 A C K As for WA12, BR24S32-W becomes Don't care. As for WA13, BR24S32/64-W becomes Don't care. As for WA14, BR24S32/64/128-W becomes Don't care. Note) *1 A C K Fig.34 Byte write cycle (BR24S32/64/128/256-W) S T A R T SDA L IN E W R I T E WA 7 RA / C *1 WK S T O P SLAVE ADDRESS 1 0 1 0 A 2A 1A 0 W ORD A D D R E S S (n ) WA 0 A C K D7 D A T A (n ) D0 A C K D A T A (n + 1 5 ) *2 D0 A C K 注 Note) ) Fig.35 Page write cycle (BR24S08/16-W) S T A R T SDA L IN E W R I T E S T O P SLAVE ADDRESS 1 0 1 0 A 2A 1A 0 1 st W O R D A D D R E S S (n ) * W A W AW A W A 1 4 13 1 2 11 2nd W ORD A D D R E S S (n ) WA 0 *2 D A T A (n ) D7 A C K D0 A C K D A TA (n + 3 1 ) D0 A C K *1 As for WA12, BR24S32-W becomes Don't care. As for WA13, BR24S32/64-W becomes Don't care. As for WA14, BR24S32/64/128-W becomes Don't care. N o te ) RA /C WK *1 A C K *2 As for BR24S128/256-W becomes (n+63). Fig.36 Page write cycle (BR24S32/64/128/256-W) ・Data is written to the address designated by word address (n-th address). ・By issuing stop bit after 8bit data input, write to memory cell inside starts. ・When internal write is started, command is not accepted for tWR (5ms at maximum). ・By page write cycle, the following can be written in bulk: Up to 16 bytes (BR24S08-W, BR24S16-W) : Up to 32 bytes (BR24S32-W, BR24S64-W) : Up to 64 bytes (BR24S128-W, BR24S256-W) And when data of the maximum bytes or higher is sent, data from the first byte is overwritten. (Refer to "Internal address increment of "Notes on page write cycle" in P24/32.) ・As for page write command of BR24S08-W and, BR24S16-W, after page select bit(PS) of slave address is designated arbitrarily, by continuing data input of 2 bytes or more, the address of insignificant 4 bits is incremented internally, and data up to 16 bytes can be written. ・As for page write cycle of BR24S32-W and BR24S64-W , after the significant 7 bits (in the case of BR24S32-W) of word address, or the significant 8 bits (in the case of BR24S64-W) of word address are designated arbitrarily, by continuing data input of 2 bytes or more, the address of insignificant 5 bits is incremented internally, and data up to 32 bytes can be written. ・As for page write cycle of BR24S128-W and BR24S256-W, after the significant 9 bit (in the case of BR24S128-W) of word address, or the significant 10bit (in the case of BR24S256-W) of word address are designated arbitrarily, by continuing data input of 64 bytes or more. Note) *1 *2 *3 1 0 1 0 A 2A 1 0 A *1 *2 *3 In BR24S16-W, A2 becomes P2 In BR24S08/16-W, A1 becomes P1 In BR24S08/16-W, A0 becomes P0 Fig.37 Difference of slave address each type www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 28/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ○Notes on write cycle continuous input At STOP (stop bit) write starts. Technical Note S T A R T SDA LINE SLAVE ADDRESS W R I T E WORD ADDRESS(n) WA 0 DATA(n) DATA(n+15) S T O P S T A R T 1 0 10 1 0 1 0 P2 P1 P0 WA 7 D7 D0 D0 note) RA /C WK A C K A C K A C K Next command tWR(maximum:5ms) Command is not accepted for this period. Fig.38 Page write cycle(BR24S08/16-W) A t S TO P (stop bit) w rite starts. SDA L IN E S T A R T SLAVE ADDRESS 1 0 1 0 A 2A 1A 0 W R I T E * 1 st W O R D A D D R E S S (n ) W A W AW A W A 14 13 12 11 2nd W ORD A D D R E S S (n ) WA 0 D A T A (n ) D7 A C K D0 A C K *2 D A TA (n+ 31 ) D0 A C K S T O P S T A R T 1010 *1 As for WA12, BR24S32-W becomes Don't care. As for WA13, BR24S32/64-W becomes Don't care. As for WA14, BR24S32/64/128-W becomes Don't care. n ote ) RA /C WK *1 A C K *2 As for BR24S128/256-W becomes (n+63). N e xt co m m a n d tW R (ma ximu m : 5 m s) C o m m an d is n ot a ccep te d for th is period . Fig.39 Page write cycle(BR24S32/64/128/256-W) ○Notes on page write cycle List of numbers of page write Number of pages Product number 16Byte BR24S08-W BR24S16-W 32Byte BR24S32-W BR24S64-W 64Byte BR24S128-W BR24S256-W The above numbers are maximum bytes for respective types. Any bytes below these can be written. In the case of BR24S256-W, 1 page = 64bytes, but the page write cycle write time is 5ms at maximum for 64byte bulk write. It does not stand 5ms at maximum × 64byte = 320ms(Max.). www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 29/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ○Internal address increment Page write mode (in the case of BR24S16-W) Technical Note WA7 ----0 ----0 ----0 ------------- WA4 0 0 0 WA3 0 0 0 WA2 WA1 0 0 0 0 0 1 --------- WA0 0 1 0 0Eh 0 0 0 ------------- 0 0 0 1 1 0 1 1 0 1 1 0 0 1 0 Significant bit is fixed. No digit up For example, when it is started from address 0Eh, therefore, increment is made as below, 0Eh→0Fh→00h→01h・・・, which please note. * 0Eh・・・16 in hexadecimal, therefore, 00001110 becomes a binary number. ○Write protect (WP) terminal ・Write protect (WP) function When WP terminal is set Vcc (H level), data rewrite of all address is prohibited. When it is set GND (L level), data rewrite of all address is enabled. Be sure to connect this terminal to Vcc or GND, or control it to H level or L level. Do not use it open. At extremely low voltage at power ON/OFF, by setting the WP terminal 'H', mistake write can be prevented. During tWR, set the WP terminal always to 'L'. If it is set 'H', write is forcibly terminated. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 30/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●Read Command ○Read cycle Data of EEPROM is read. In read cycle, there are random read cycle and current read cycle. Random read cycle is a command to read data by designating address, and is used generally. Current read cycle is a command to read data of internal address register without designating address, and is used when to verify just after write cycle. In both the read cycles, sequential read cycle is available, and the next address data can be read in succession. S T A R T SDA L IN E W R I T E WA 7 RA /C WK S T A R T R E A D D7 RA /C WK S T O P D0 A C K SLAVE ADDRESS 1 0 1 0 A 2 A 1A 0 W ORD A D D R E S S (n) WA 0 A C K S LA V E ADDRESS 1 0 1 0 A 2 A 1A 0 D A TA (n) It is necessary to input 'H' to the last ACK. N o te) Fig.40 Random read cycle (BR24S08/16-W) S T A R T SDA LINE SLAVE ADDRESS W R I T E 1st WORD ADDRESS(n) 2nd WORD ADDRESS(n) WA 0 S T A R T SLAVE ADDRESS R E A D DATA(n) S T O P *1 1 0 1 0 A2A1A0 D7 D0 1 0 1 0 A2A1A0 * WA WA WAWA 14 13 12 11 As for WA12, BR24S32-W become Don't care. As for WA13, BR24S32/64-W become Don't care. As for WA14, BR24S32/64/128-W become Don't care. Note) RA /C WK *1 A C K A C K RA /C WK A C K Fig.41 Random read cycle (BR24S32/64/128/256-W) S T A R T SDA L IN E R E A D D7 RA /C WK S T O P D0 A C K S LA V E ADDRESS 1 0 1 0 A 2 A 1A 0 It is necessary to input 'H' to the last ACK. D A TA (n ) N ote ) Fig.42 Current read cycle S T A R T SDA LINE SLAVE ADDRESS R E A D DATA(n) DATA(n+x) S T O P D0 A C K 1 0 1 0 A2 A1A0 RA /C WK D7 D0 A C K A C K D7 Note) Fig.43 Sequential read cycle (in the case of current read cycle) ・In random read cycle, data of designated word address can be read. ・When the command just before current read cycle is random read cycle, current read cycle (each including sequential read cycle), data of incremented last read address (n)-th address, i.e., data of the (n+1)-th address is output. ・When ACK signal 'LOW' after D0 is detected, and stop condition is not sent from master (μ-COM) side, the next address data can be read in succession. ・Read cycle is ended by stop condition where 'H' is input to ACK signal after D0 and SDA signal is started at SCL signal 'H'. ・When 'H' is not input to ACK signal after D0, sequential read gets in, and the next data is output. Therefore, read command cycle cannot be ended. When to end read command cycle, be sure input stop condition to input 'H' to ACK signal after D0, and to start SDA at SCL signal 'H'. ・Sequential read is ended by stop condition where 'H' is input to ACK signal after arbitrary D0 and SDA is started at SCL signal 'H'. Note) *1 *2 *3 1 0 1 0 A2 A1A0 *1 *2 *3 BR24S16-W A2 becomes P2. BR24S08/16-W A1 becomes P1. BR24S08/16-W A0 becomes P0. Fig.44 Difference of slave address of each type www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 31/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●Software reset Software reset is executed when to avoid malfunction after power on, and to reset during command input. Software reset has several kinds, and 3 kids of them are shown in the figure below. (Refer to Fig.45(a), Fig.45(b), Fig.45(c).) In dummy clock input area, release the SDA bus ('H' by pull up). In dummy clock area, ACK output and read data '0' (both 'L' level) may be output from EEPROM, therefore, if 'H' is input forcibly, output may conflict and over current may flow, leading to instantaneous power failure of system power source or influence upon devices. Dummy clock×14 Start×2 SCL SDA 1 2 13 14 Normal command Normal command Fig.45-(a) The case of 14 Dummy clock + START + START+ command input Start Dummy clock×9 Start SCL SDA 1 2 8 9 Normal command Normal command Fig.45-(b) The case of START+9 Dummy clock + START + command input Start×9 SCL SDA 1 2 3 7 8 9 Normal command Normal command * Start command from START input. Fig.45-(c) START × 9 + command input ●Acknowledge polling During internal write, all input commands are ignored, therefore ACK is not sent back. During internal automatic write execution after write cycle input, next command (slave address) is sent, and if the first ACK signal sends back 'L', then it means end of write action, while if it sends back 'H', it means now in writing. By use of acknowledge polling, next command can be executed without waiting for tWR = 5ms. When to write continuously, R/W = 0, when to carry out current read cycle after write, slave address R/W = 1 is sent, and if ACK signal sends back 'L', then execute word address input and data so forth. During internal write, ACK = HIGH is sent back. S T A R T First write command S T A R T S T O P A C K H Write command Slave address S T A Slave R address T A C K H … tWR Second write command S T Slave A R address T A C K H S T Slave A R address T A C K L Word address A C K L A C K L S T O P … Data tWR After completion of internal write, ACK=LOW is sent back, so input next word address and data in succession. Fig.46 Case to continuously write by acknowledge polling www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 32/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●WP valid timing (write cancel) WP is usually fixed to 'H' or 'L', but when WP is used to cancel write cycle and so forth, pay attention to the following WP valid timing. During write cycle execution, in cancel valid area, by setting WP='H', write cycle can be cancelled. In both byte write cycle and page write cycle, the area from the first start condition of command to the rise of clock to taken in D0 of data(in page write cycle, the first byte data) is cancel invalid area. WP input in this area becomes Don't care. Set the setup time to rise of D0 taken 100ns or more. The area from the rise of SCL to take in D0 to the end of internal automatic write (tWR) is cancel valid area. And, when it is set WP='H' during tWR, write is ended forcibly, data of address under access is not guaranteed, therefore, write it once again.(Refer to Fig.47.) After execution of forced end by WP standby status gets in, so there is no need to wait for tWR (5ms at maximum). ・Rise of D0 taken clock SCL SDA D1 D0 SCL ・Rise of SDA ACK SDA Enlarged view S T Slave A R address T A A C Word C K address K D7 D6 D5 D4 D3 D2 D1 D0 L L A C K L D0 ACK Enlarged view A C K L S T O P SDA Data tWR WP cancel invalid area WP cancel valid area Write forced end WP Data is not written. Data not guaranteed Fig.47 WP valid timing ●Command cancel by start condition and stop condition During command input, by continuously inputting start condition and stop condition, command can be cancelled. (Refer to Fig. 48.) However, in ACK output area and during data read, SDA bus may output 'L', and in this case, start condition and stop condition cannot be input, so reset is not available. Therefore, execute software reset. And when command is cancelled by start, stop condition, during random read cycle, sequential read cycle, or current read cycle, internal setting address is not determined, therefore, it is not possible to carry out current read cycle in succession. When to carry out read cycle in succession, carry out random read cycle. SCL SDA 1 0 1 0 Start condition Fig.48 Case of cancel by start, stop condition during slave address input www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 33/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●I/O peripheral circuit ○Pull up resistance of SDA terminal SDA is NMOS open drain, so requires pull up resistance. As for this resistance value (RPU), select an appropriate value to this resistance value from microcontroller VIL, IL, and VOL-IOL characteristics of this IC. If RPU is large, action frequency is limited. The smaller the RPU, the larger the consumption current at action. ○Maximum value of RPU The maximum value of RPU is determined by the following factors. (1)SDA rise time to be determined by the capacitance (CBUS) of bus line of RPU and SDA should be tR or below. And AC timing should be satisfied even when SDA rise time is late. (2)The bus electric potential○ to be determined by input leak total (IL) of device connected to bus output of 'H' to SDA A bus and RPU should sufficiently secure the input 'H' level (VIH) of microcontroller and EEPROM including recommended noise margin 0.2Vcc. Microcontroller BR24SXX Vcc - ILRPU - 0.2Vcc ≧ VIH 0.8VCC - VIH ∴ RPU ≦ IL Ex.) When Vcc = 3V, IL=10μA, VIH = 0.7Vcc from(2) 0.8×3 - 0.7×3 RPU ≦ -6 10×10 ≦ 300 [kΩ] ○Minimum value of RPU The minimum value of RPU is determined by the following factors. (1)When IC outputs LOW, it should be satisfied that VOLMAX=0.4V and IOLMAX=3mA. VCC - VOL ≦ IOL RPU ∴ RPU ≧ VCC - VOL IOL Bus line capacity CBUS Fig.49 I/O circuit diagram (2)VOLMAX =0.4V should secure the input 'L' level (VIL) of microcontroller and EEPROM including recommended noise margin 0.1Vcc. VOLMAX ≦ VIL-0.1 Vcc Ex.) When Vcc= 3V, VOL0.4V, IOL=3mA, microcontroller, EEPROM VIL=0.3Vcc from(1), 3-0.4 RPU ≧ 3×10 ≧ And VOL=0.4[V] VIL=0.3×3 =0.9[V] Therefore, the condition (2) is satisfied. ○Pull up resistance of SCL terminal When SCL control is made at CMOS output port, there is no need, but in the case there is timing where SCL becomes 'Hi-Z', add a pull up resistance. As for the pull up resistance, one of several kΩ ~ several ten kΩ is recommended in consideration of drive performance of output port of microcontroller. ●A0, A1, A2, WP process ○Process of device address terminals (A0,A1,A2) Check whether the set device address coincides with device address input sent from the master side or not, and select one among plural devices connected to a same bus. Connect this terminal to pull up or pull down, or Vcc or GND. And, pins(Don't use PIN) not used as device address may be set to any of 'H' , 'L', and 'Hi-Z'. Types with Don't use PIN BR24S08F/FJ/FV/FVT/FVM/FVJ/NUX-W A0, A1 BR24S16F/FJ/FV/FVT/FVM/FVJ/NUX-W A0, A1, A2 ○Process of WP terminal WP terminal is the terminal that prohibits and permits write in hardware manner. In 'H' status, only READ is available and WRITE of all address is prohibited. In the case of 'L', both are available. In the case of use it as an ROM, it is recommended to connect it to pull up or Vcc. In the case to use both READ and WRITE, control WP terminal or connect it to pull down or GND. 867 [Ω] www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 34/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note ●Cautions on microcontroller connection ○Rs 2 In I C BUS, it is recommended that SDA port is of open drain input/output. However, when to use CMOS input / output of tri state to SDA port, insert a series resistance Rs between the pull up resistance Rpu and the SDA terminal of EEPROM. This is controls over current that occurs when PMOS of the microcontroller and NMOS of EEPROM are turned ON simultaneously. Rs also plays the role of protection of SDA terminal against surge. Therefore, even when SDA port is open drain input/output, Rs can be used. ACK SCL RPU RS SDA 'H' output of microcontroller 'L' output of EEPROM Microcontre EEPROM Over current flows to SDA line by 'H' output of microcontroller and 'L' output of EEPROM. Fig.50 I/O circuit diagram ○Maximum value of Rs The maximum value of Rs is determined by following relations. Fig.51 Input/output collision timing (1)SDA rise time to be determined by the capacity (CBUS) of bus line of Rpu and SDA shoulder be tR or below. And AC timing should be satisfied even when SDA rise time is late. A (2)The bus electric potential○ to be determined by Rpu and Rs the moment when EEPROM outputs 'L' to SDA bus should sufficiently secure the input 'L' level (VIL) of microcontroller including recommended noise margin 0.1Vcc. VCC RPU RS IOL Bus line capacity CBUS A VOL (VCC-VOL)×RS RPU+RS ∴ RS ≦ + VOL+0.1VCC≦VIL × RPU RPU=20kΩ 20×103 VIL-VOL-0.1VCC 1.1VCC-VIL Example)When VCC=3V, VIL=0.3VCC, VOL=0.4V, from(2), RS ≦ ≦ 0.3×3-0.4-0.1×3 1.1×3-0.3×3 1.67[kΩ] × VIL Microcontroller EEPROM Fig.52 I/O circuit diagram ○Maximum value of Rs The minimum value of Rs is determined by over current at bus collision. When over current flows, noises in power source line, and instantaneous power failure of power source may occur. When allowable over current is defined as I, the following relation must be satisfied. Determine the allowable current in consideration of impedance of power source line in set and so forth. Set the over current to EEPROM 10mA or below. VCC RS 'L' output ≦ ≧ I VCC I 3 10×10-3 RPU RS ∴ RS Over currentⅠ 'H' output Example)When VCC=3V, I=10mA RS ≧ Microcontroller EEPROM Fig.53 I/O circuit diagram www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 35/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●I2C BUS input / output circuit ○Input (A0, A1, A2, SCL, WP) Technical Note Fig.54 Input pin circuit diagram ○Input/Output (SDA) Fig.55 Input /output pin circuit diagram ●Notes on power ON At power on, in IC internal circuit and set, Vcc rises through unstable low voltage area, and IC inside is not completely reset, and malfunction may occur. To prevent this, functions of POR circuit and LVCC circuit are equipped. To assure the action, observe the following condition at power on. 1. Set SDA = 'H' and SCL ='L' or 'H' 2. Start power source so as to satisfy the recommended conditions of tR, tOFF, and Vbot for operating POR circuit. VCC tR Recommended conditions of tR,tOFF,Vbot tR tOFF 10ms or longer 10ms or longer Vbot 0.3V or below 0.2V or below 10ms or below Vbot tOFF 0 100ms or below Fig.56 Rise waveform diagram 3. Set SDA and SCL so as not to become 'Hi-Z'. When the above conditions 1 and 2 cannot be observed, take the following countermeasures. a) In the case when the above conditions 1 cannot be observed. When SDA becomes 'L' at power on . →Control SCL and SDA as shown below, to make SCL and SDA, 'H' and 'H'. VCC SCL tLOW SDA After Vcc becomes stable After Vcc becomes stable tDH tSU:DAT tSU:DAT Fig.57 When SCL='H' and SDA='L' Fig.58 W hen SCL='H' and SDA='L' b) In the case when the above condition 2 cannot be observed. →After power source becomes stable, execute software reset(P26). c) In the case when the above conditions 1 and 2 cannot be observed. →Carry out a), and then carry out b). www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 36/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Low voltage malfunction prevention function LVCC circuit prevents data rewrite action at low power, and prevents wrong write. At LVCC voltage (Typ. =1.2V) or below, it prevent data rewrite. Technical Note ●Vcc noise countermeasures ○Bypass capacitor When noise or surge gets in the power source line, malfunction may occur, therefore, for removing these, it is recommended to attach a by pass capacitor (0.1μF) between IC Vcc and GND. At that moment, attach it as close to IC as possible. And, it is also recommended to attach a bypass capacitor between board Vcc and GND. ●Notes for use (1) Described numeric values and data are design representative values, and the values are not guaranteed. (2) We believe that application circuit examples are recommendable, however, in actual use, confirm characteristics further sufficiently. In the case of use by changing the fixed number of external parts, make your decision with sufficient margin in consideration of static characteristics and transition characteristics and fluctuations of external parts and our LSI. (3) Absolute maximum ratings If the absolute maximum ratings such as impressed voltage and action temperature range and so forth are exceeded, LSI may be destructed. Do not impress voltage and temperature exceeding the absolute maximum ratings. In the case of fear exceeding the absolute maximum ratings, take physical safety countermeasures such as fuses, and see to it that conditions exceeding the absolute maximum ratings should not be impressed to LSI. (4) GND electric potential Set the voltage of GND terminal lowest at any action condition. Make sure that each terminal voltage is lower than that of GND terminal. (5) Terminal design In consideration of permissible loss in actual use condition, carry out heat design with sufficient margin. (6) Terminal to terminal shortcircuit and wrong packaging When to package LSI onto a board, pay sufficient attention to LSI direction and displacement. Wrong packaging may destruct LSI. And in the case of shortcircuit between LSI terminals and terminals and power source, terminal and GND owing to foreign matter, LSI may be destructed. (7) Use in a strong electromagnetic field may cause malfunction, therefore, evaluate design sufficiently. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 37/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series ●Ordering part number Technical Note B Part No. R 2 24:I C 2 4 S Operating temperature/ Power source voltage 2 Capacity 5 6 F Package - W E 2 BUS type Double cell Packaging and 01=1K 02=2K 04=4K L: -40℃~+85℃/ 08=8K 1.8V ~ 5.5V S: -40℃~+85℃/ 1.7V ~ 5.5V 16=16K 32=32K 64=64K 128=128K 256=256K F : SOP8 FJ : SOP-J8 FV : SSOP-B8 FVM : MSOP8 FVT :TSSOP-B8 FVJ :TSSOP-B8J NUX : VSON008X2030 forming specification E2: Embossed tape and reel TR: Embossed tape and reel ●Package specifications SOP8 5.0±0.2 (MAX 5.35 include BURR) 8 7 6 5 +6° 4° −4° Tape Quantity 0.9±0.15 0.3MIN Embossed carrier tape 2500pcs E2 The direction is the 1pin of product is at the upper left when you hold 6.2±0.3 4.4±0.2 Direction of feed ( reel on the left hand and you pull out the tape on the right hand ) 12 3 4 0.595 1.5±0.1 +0.1 0.17 -0.05 S 0.11 1.27 0.42±0.1 1pin (Unit : mm) Direction of feed Reel ∗ Order quantity needs to be multiple of the minimum quantity. SOP-J8 4.9±0.2 (MAX 5.25 include BURR) +6° 4° −4° 8 7 6 5 Tape Quantity 0.45MIN Embossed carrier tape 2500pcs E2 The direction is the 1pin of product is at the upper left when you hold 6.0±0.3 3.9±0.2 Direction of feed ( reel on the left hand and you pull out the tape on the right hand ) 1 2 3 4 0.545 S 0.2±0.1 1.375±0.1 0.175 1.27 0.42±0.1 0.1 S 1pin (Unit : mm) Reel Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 38/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note SSOP-B8 3.0 ± 0.2 (MAX 3.35 include BURR) 876 5 Tape Quantity 0.3MIN Embossed carrier tape 2500pcs E2 The direction is the 1pin of product is at the upper left when you hold 6.4 ± 0.3 4.4 ± 0.2 Direction of feed ( reel on the left hand and you pull out the tape on the right hand ) 1234 1.15 ± 0.1 0.15 ± 0.1 S 0.1 +0.06 0.22 -0.04 0.08 M 0.1 (0.52) 0.65 1pin (Unit : mm) Direction of feed Reel ∗ Order quantity needs to be multiple of the minimum quantity. TSSOP-B8 3.0 ± 0.1 (MAX 3.35 include BURR) 8 7 6 5 4±4 Tape Quantity Embossed carrier tape 3000pcs E2 The direction is the 1pin of product is at the upper left when you hold 6.4 ± 0.2 4.4 ± 0.1 Direction of feed 0.5 ± 0.15 1.0 ± 0.2 ( reel on the left hand and you pull out the tape on the right hand ) 1 2 3 4 1.0 ± 0.05 1.2MAX 0.525 1PIN MARK S +0.05 0.145 –0.03 0.1 ± 0.05 0.08 S +0.05 0.245 –0.04 0.65 0.08 M 1pin (Unit : mm) Direction of feed Reel ∗ Order quantity needs to be multiple of the minimum quantity. TSSOP-B8J 3.0 ± 0.1 (MAX 3.35 include BURR) 8 7 6 5 4±4 Tape Quantity Embossed carrier tape 2500pcs E2 The direction is the 1pin of product is at the upper left when you hold 4.9 ± 0.2 3.0 ± 0.1 0.45 ± 0.15 Direction of feed 0.95 ± 0.2 ( reel on the left hand and you pull out the tape on the right hand ) 1 2 3 1PIN MARK S 4 0.85±0.05 1.1MAX 0.525 +0.05 0.145 – 0.03 0.1±0.05 0.08 S +0.05 0.32 –0.04 0.65 0.08 M 1pin (Unit : mm) Direction of feed Reel ∗ Order quantity needs to be multiple of the minimum quantity. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 39/40 2009.09 - Rev.D BR24L□□-W Series,BR24S□□□-W Series Technical Note MSOP8 2.9±0.1 (MAX 3.25 include BURR) 8765 Tape 0.29±0.15 0.6±0.2 +6° 4° −4° Embossed carrier tape 3000pcs TR The direction is the 1pin of product is at the upper right when you hold Quantity Direction of feed 4.0±0.2 2.8±0.1 ( reel on the left hand and you pull out the tape on the right hand 1pin ) 1 234 1PIN MARK 0.475 S +0.05 0.22 –0.04 0.08 S 0.65 +0.05 0.145 –0.03 0.9MAX 0.75±0.05 0.08±0.05 Direction of feed (Unit : mm) Reel ∗ Order quantity needs to be multiple of the minimum quantity. VSON008X2030 2.0±0.1 3.0±0.1 Tape Quantity S +0.03 0.02 –0.02 (0.12) Embossed carrier tape 4000pcs TR The direction is the 1pin of product is at the upper right when you hold 1PIN MARK 0.6MAX Direction of feed ( reel on the left hand and you pull out the tape on the right hand ) 0.08 S 1.5±0.1 0.5 C0.25 0.3±0.1 8 5 0.25 1.4±0.1 1 4 +0.05 0.25 –0.04 1pin Direction of feed (Unit : mm) Reel ∗ Order quantity needs to be multiple of the minimum quantity. www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. 40/40 2009.09 - Rev.D Notice Notes No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuel-controller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. R0039A
BR24S256FVM-WTR
1. 物料型号: - BR24L系列:BR24L01A-W, BR24L02-W, BR24L04-W, BR24L08-W, BR24L16-W, BR24L32-W, BR24L64-W - BR24S系列:BR24S08-W, BR24S16-W, BR24S32-W, BR24S64-W, BR24S128-W, BR24S256-W
2. 器件简介: - 这些系列的EEPROM具有I2C总线接口,提供高可靠性的数据存储。BR24L系列提供1Kbit到64Kbit的存储容量,而BR24S系列在低电压下也能高速运行,提供8Kbit到256Kbit的存储容量。
3. 引脚分配: - A0、A1、A2:用于设置从设备地址。 - GND:所有输入/输出的参考电压,0V。 - SDA:串行数据输入/输出。 - SCL:串行时钟输入。 - WP:写保护端。 - Vcc:电源连接。
4. 参数特性: - 工作电压:1.8V-5.5V。 - 写操作电流:1.2mA(典型值)。 - 读操作电流:0.2mA(典型值)。 - 待机电流:0.1μA(典型值)。 - 数据可擦写次数:1,000,000次。 - 数据保持时间:40年。
5. 功能详解: - 支持页写入模式,适用于工厂出货时的初始值写入。 - 具有自动擦除和自动结束功能。 - 内置噪声滤波器。
6. 应用信息: - 这些EEPROM适用于需要高可靠性数据存储的应用,如电池供电设备。
7. 封装信息: - 提供多种封装选项,包括SOP8、SOP-J8、SSOP-B8、TSSOP-B8、MSOP8、TSSOP-B8J和VSON008X2030。
BR24S256FVM-WTR 价格&库存
很抱歉,暂时无法提供与“BR24S256FVM-WTR”相匹配的价格&库存,您可以联系我们找货
