BR25S320FVM-WTR
BR25S320FVM-WTR
    ROHM(罗姆)
    MSOP8_2.9X2.8MM
    BR25S320FVM WTR
BR25S320FVM-WTR 数据手册
Datasheet Serial EEPROM Series Standard EEPROM SPI BUS EEPROM BR25Sxxx-W Series (32K 64K 128K 256K) ●General Description BR25Sxxx-W series is a serial EEPROM of SPI BUS interface method ●Features „ High speed clock action up to 20MHz (Max.) „ Wait function by HOLDB terminal „ Part or whole of memory arrays settable as read only memory area by program „ 1.7V to 5.5V single power source action most suitable for battery use „ Page write mode useful for initial value write at factory shipment „ Highly reliable connection by Au pad and Au wire „ For SPI bus interface (CPOL, CPHA) = (0, 0), (1, 1) „ Auto erase and auto end function at data rewrite „ Low current consumption ¾ At write action (5V) : 1.5mA (Typ.) ¾ At read action (5V) : 1.0mA (Typ.) ¾ At standby action (5V) : 0.1μA (Typ.) „ Address auto increment function at read action „ Write mistake prevention function ¾ Write prohibition at power on ¾ Write prohibition by command code (WRDI) ¾ Write prohibition by WP pin ¾ Write prohibition block setting by status registers (BP1, BP0) ¾ Write mistake prevention function at low voltage „ Data kept for 40 years „ Data rewrite up to 1,000,000 times „ Data at shipment Memory array: FFh Status register: WPEN, BP1, BP0 : 0 ●Page write Page Part Number ●Packages W(Typ.) x D(Typ.) x H(Max.) SOP8 TSSOP-B8 5.00mm x 6.20mm x 1.71mm 3.00mm x 6.40mm x 1.20mm SOP- J8 TSSOP-B8J 4.90mm x 6.00mm x 1.65mm 3.00mm x 4.90mm x 1.10mm SSOP-B8 MSOP8 3.00mm x 6.40mm x 1.35mm 2.90mm x 4.00mm x 0.90mm VSON008X2030 2.00mm x 3.00mm x 0.60mm 32Byte 64Byte BR25S320-W BR25S640-W BR25S128-W BR25S256-W ●BR25Sxxx-W Series Capacity Bit format 32Kbit 4K×8 Power source voltage SOP8 SOP-J8 1.7V to 5.5V ● ● SSOP-B8 TSSOP-B8 MSOP8 ● ● ● ● ● ● 64Kbit 8K×8 1.7V to 5.5V ● ● ● ● 16K×8 1.7V to 5.5V ● ● ● ● 256Kbit 32K×8 1.7V to 5.5V ● ● www.rohm.com ©2012 ROHM Co., Ltd. All rights reserved. TSZ22111・14・001 VSON008 X2030 ● 128Kbit ○Product structure:Silicon monolithic integrated circuit TSSOP-B8J ○This product is not designed protection against radioactive rays 1/31 TSZ02201-0R2R0G100330-1-2 21.AUG.2012 Rev.001 Datasheet BR25Sxxx-W Series (32K 64K 128K 256K) ●Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Ratings Supply Voltage VCC -0.3 to +6.5 450 (SOP8) 450 (SOP-J8) 300 (SSOP-B8) Power Dissipation Pd 330 (TSSOP-B8) 310 (TSSOP-B8J) 310 (MSOP8) 300 (VSON008X2030) Storage Temperature Tstg -65 to +125 Operating Temperature Topr -40 to +85 Terminal Voltage ‐ -0.3 to Vcc+0.3 Unit V mW Remarks When using at Ta=25℃ When using at Ta=25℃ When using at Ta=25℃ When using at Ta=25℃ When using at Ta=25℃ When using at Ta=25℃ When using at Ta=25℃ or higher 4.5mW to be reduced per 1℃. or higher 4.5mW to be reduced per 1℃. or higher 3.0mW to be reduced per 1℃. or higher 3.3mW to be reduced per 1℃. or higher 3.1mW to be reduced per 1℃. or higher 3.1mW to be reduced per 1℃. or higher 3.0mW to be reduced per 1℃. ℃ ℃ V ●Memory cell characteristics (Ta=25°C , Vcc=1.7V to 5.5V) Limits Parameter Min. Typ. Number of data rewrite times *1 1,000,000 Data hold years *1 40 - Max. - Unit Times Years *1 Not 100% TESTED ●Recommended Operating Ratings Parameter Symbol Power source voltage Vcc Input voltage VIN ●Input / output capacity (Ta=25°C, frequency=5MHz) Parameter Symbol Min. Input capacity *1 CIN - Output capacity *1 COUT - *1 Unit Ratings 1.7 to 5.5 0 to Vcc V Max. 8 8 Unit pF Conditions VIN=GND VOUT=GND Not 100% TESTED. ●Electrical characteristics (Unless otherwise specified, Ta=-40°C to +85°C, Vcc=1.7V to 5.5V) Limits Parameter Symbol Unit Conditions Min. Typ. Max. “H” Input Voltage1 VIH1 0.7xVcc - Vcc+0.3 V 1.7≦Vcc≦5.5V “L” Input Voltage1 VIL1 -0.3 - 0.3xVcc V 1.7≦Vcc≦5.5V “L” Output Voltage1 VOL1 0 - 0.4 V IOL=2.1mA, 2.5≦Vcc
BR25S320FVM-WTR
物料型号: - BR25S320-W - BR25S640-W - BR25S128-W - BR25S256-W
器件简介: BR25Sxxx-W系列是采用SPI总线接口的串行EEPROM,具有高速时钟操作(最高达20MHz)、通过HOLDB端子的等待功能、可编程只读存储区、适用于电池使用的1.7V至5.5V单电源操作、多种封装选项、写入错误防止功能、上电写入禁止、命令代码写入禁止(WRDI)、WP引脚写入禁止、状态寄存器写入禁止块设置(BP1, BP0)等特点。
引脚分配: - Vcc:电源连接 - GND:所有输入/输出的参考电压,0V - CSB:芯片选择输入 - SCK:串行时钟输入 - SI:起始位、操作码、地址和串行数据输入 - SO:串行数据输出 - HOLDB:保持输入,可暂时挂起命令通信 - WP:写保护输入,禁止写入命令
参数特性: - 工作电压:1.7V至5.5V - 存储温度:-65°C至+125°C - 工作温度:-40°C至+85°C - 数据保持时间:40年 - 数据重写次数:1,000,000次 - 低功耗:写入时(5V)典型值为1.5mA,读取时(5V)典型值为1.0mA,待机时(5V)典型值为0.1μA
功能详解: - 页写入模式:适用于出厂时的初始值写入 - 自动擦除和自动结束功能:在数据重写时自动进行 - 地址自动增量功能:在读取操作时 - 写入禁止功能:可通过命令代码、WP引脚或状态寄存器设置
应用信息: 该产品适用于需要可编程非易失性存储的应用,如工业控制、消费电子、医疗设备等领域。
封装信息: - SOP8 - SOP-J8 - SSOP-B8 - TSSOP-B8 - TSSOP-B8J - MSOP8 - VSON008X2030
BR25S320FVM-WTR 价格&库存
很抱歉,暂时无法提供与“BR25S320FVM-WTR”相匹配的价格&库存,您可以联系我们找货
BR25S320FVM-WTR
    • 1+2.370181+0.30702
    • 10+2.3038810+0.29844
    • 50+2.2624550+0.29307
    • 100+2.22101100+0.28770
    • 500+2.20444500+0.28556
    • 1000+2.204441000+0.28556
    • 2000+2.196152000+0.28448
    库存:452
    BR25S320FVM-WTR
      • 1+3.85560
      • 200+1.50120
      • 500+1.44720
      • 1000+1.41480
      BR25S320FVM-WTR
      • 3000+5.334773000+0.69104
      库存:2690
      BR25S320FVM-WTR
      • 1+6.878651+0.89103
      • 10+6.4407210+0.83430
      • 25+6.2685425+0.81200
      • 50+6.1365350+0.79490
      • 100+6.00087100+0.77733
      • 250+5.82088250+0.75401
      • 500+5.68444500+0.73634
      • 1000+5.548451000+0.71872
      库存:2690
