BU52053NVX-TR
BU52053NVX-TR
    ROHM(罗姆)
    UDFN4_EP
BU52053NVX-TR 数据手册
Hall ICs Omnipolar Detection Hall ICs BU52001GUL,BU52011HFV,BU52021HFV,BU52015GUL,BU52025G,BU52053NVX, No.10045EGT02 BU52054GWZ,BU52055GWZ,BU52056NVX,BU52061NVX,BD7411G ●Description The omnipolar Hall ICs are magnetic switches that can operate both S-and N-pole, upon which the output goes from Hi to Low. In addition to regular single-output Hall ICs, We offer a lineup of dual-output units with a reverse output terminal (active High). ●Features 1) Omnipolar detection 2) Micro power operation (small current using intermittent operation method)(BD7411G is excluded.) 3) Ultra-compact and thin wafer level CSP4 package (BU52054GWZ, BU52055GWZ) 4) Ultra-compact wafer level CSP4 package (BU52015GUL, BU52001GUL) 5) Ultra-Small outline package SSON004X1216 (BU52061NVX, BU52053NVX, BU52056NVX) 6) Ultra-Small outline package HVSOF5 (BU52011HFV, BU52021HFV) 7) Small outline package (BU52025G, BD7411G) 8) Line up of supply voltage For 1.8V Power supply voltage (BU52054GWZ, BU52055GWZ, BU52015GUL, BU52061NVX, BU52053NVX, BU52056NVX, BU52011HFV) For 3.0V Power supply voltage (BU52001GUL) For 3.3V Power supply voltage (BU52021HFV, BU52025G) For 5.0V Power supply voltage (BD7411G) 9) Dual output type (BU52015GUL) 10) High ESD resistance 8kV (HBM) (6kV for BU52056NVX) ●Applications Mobile phones, notebook computers, digital video camera, digital still camera, white goods etc. ●Lineup matrix Product name Supply voltage (V) Operate point (mT) (mT) (ms) Supply current (AVG) (A) 0.9 50 5.0µ CMOS UCSP35L1 Hysteresis Period Output type Package BU52054GWZ 1.65~3.60 +/-6.3 ※ BU52055GWZ 1.65~3.60 +/-4.1 ※ 0.8 50 5.0µ CMOS UCSP35L1 BU52015GUL 1.65~3.30 +/-3.0 ※ 0.9 50 5.0µ CMOS VCSP50L1 BU52001GUL 2.40~3.30 +/-3.7 ※ 0.8 50 8.0µ CMOS VCSP50L1 BU52061NVX 1.65~3.60 +/-3.3 ※ 0.9 50 4.0µ CMOS SSON004X1216 BU52053NVX 1.65~3.60 +/-3.0 ※ 0.9 50 5.0µ CMOS SSON004X1216 BU52056NVX 1.65~3.60 +/-4.6 ※ 0.8 50 5.0µ CMOS SSON004X1216 BU52011HFV 1.65~3.30 +/-3.0 ※ 0.9 50 5.0µ CMOS HVSOF5 BU52021HFV 2.40~3.60 +/-3.7 ※ 0.8 50 8.0µ CMOS HVSOF5 BU52025G 2.40~3.60 +/-3.7 ※ 0.8 50 8.0µ CMOS SSOP5 BD7411G 4.50~5.50 +/-3.4 ※ 0.4 - 2.0m CMOS SSOP5 ※Plus is expressed on the S-pole; minus on the N-pole www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. 1/31 2011.12 - Rev.G BU52001GUL,BU52011HFV,BU52021HFV,BU52015GUL,BU52025G,BU52053NVX, BU52054GWZ,BU52055GWZ,BU52056NVX,BU52061NVX,BD7411G ●Absolute maximum ratings BU52054GWZ, BU52055GWZ (Ta=25℃) Parameter Symbol Ratings Unit Power Supply Voltage VDD -0.1~+4.5※1 V Output Current IOUT ±0.5 Power Dissipation Pd Operating Temperature Range Storage Temperature Range Technical Note BU52015GUL (Ta=25℃) Parameter Symbol Ratings Unit Power Supply Voltage VDD -0.1~+4.5※3 V mA Output Current IOUT ±0.5 mA 100※2 mW Power Dissipation Pd 420※4 mW Topr -40~+85 ℃ Topr -40~+85 ℃ Tstg -40~+125 ℃ Tstg -40~+125 ℃ Operating Temperature Range Storage Temperature Range ※1. Not to exceed Pd ※2. Reduced by 1.00mW for each increase in Ta of 1℃ over 25℃ (mounted on 24mm×20mm Glass-epoxy PCB) ※3. Not to exceed Pd ※4. Reduced by 4.20mW for each increase in Ta of 1℃ over 25℃ (mounted on 50mm×58mm Glass-epoxy PCB) BU52001GUL (Ta=25℃) BU52061NVX, BU52053NVX, BU52056NVX(Ta=25℃) Parameter Symbol Ratings Unit Parameter Symbol Ratings Unit Power Supply Voltage VDD -0.1~+4.5※5 V Power Supply Voltage VDD -0.1~+4.5※7 V Output Current IOUT ±1 mA Output Current IOUT ±0.5 mA Power Dissipation Pd 420※6 mW Power Dissipation Pd 2049※8 mW Topr -40~+85 ℃ Topr -40~+85 ℃ Tstg -40~+125 ℃ Tstg -40~+125 ℃ Operating Temperature Range Storage Temperature Range Operating Temperature Range Storage Temperature Range ※5. Not to exceed Pd ※6. Reduced by 4.20mW for each increase in Ta of 1℃ over 25℃ (mounted on 50mm×58mm Glass-epoxy PCB) BU52011HFV (Ta=25℃) Parameter Symbol Power Supply Voltage VDD Output Current IOUT Power Dissipation Pd Operating Temperature Range Storage Temperature Range Ratings ※7. Not to exceed Pd ※8. Reduced by 4.20mW for each increase in Ta of 1℃ over 25℃ (mounted on 50mm×58mm Glass-epoxy PCB) Unit ※9 -0.1~+4.5 ±0.5 10 536※ BU52021HFV (Ta=25℃) Parameter Symbol V Ratings Power Supply Voltage VDD mA Output Current IOUT ±1 mW Power Dissipation Pd 536※ Topr -40~+85 ℃ Tstg -40~+125 ℃ Operating Temperature Range Storage Temperature Range Unit ※11 -0.1~+4.5 12 V mA mW Topr -40~+85 ℃ Tstg -40~+125 ℃ ※9. Not to exceed Pd ※10. Reduced by5.36mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) ※11 Not to exceed Pd ※12. Reduced by 5.36mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) BU52025G (Ta=25℃) BD7411G (Ta=25℃) Parameter Symbol Ratings Unit Parameter Symbol Ratings Unit Power Supply Voltage VDD -0.1~+4.5※13 V Power Supply Voltage VDD -0.3~+7.0※15 V Output Current IOUT ±1 mA Output Current IOUT ±1 mA Power Dissipation Pd 540※14 mW Power Dissipation Pd 540※16 mW Topr -40~+85 ℃ Topr -40~+85 ℃ Tstg -40~+125 ℃ Tstg -55~+150 ℃ Operating Temperature Range Storage Temperature Range ※13. Not to exceed Pd ※14. Reduced by 5.40mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. Operating Temperature Range Storage Temperature Range ※15. Not to exceed Pd ※16. Reduced by 5.40mW for each increase in Ta of 1℃ over 25℃ (mounted on 70mm×70 mm×1.6mm Glass-epoxy PCB) 2/31 2011.12 - Rev.G BU52001GUL,BU52011HFV,BU52021HFV,BU52015GUL,BU52025G,BU52053NVX, BU52054GWZ,BU52055GWZ,BU52056NVX,BU52061NVX,BD7411G ●Magnetic, Electrical characteristics BU52054GWZ (Unless otherwise specified, VDD=1.80V, Ta=25℃) Limits Parameter Symbol Min. Typ. Power Supply Voltage Max. Technical Note Unit Conditions VDD 1.65 1.80 3.60 BopS - 6.3 7.9 BopN -7.9 -6.3 - BrpS 3.5 5.4 - BrpN - -5.4 -3.5 BhysS - 0.9 - BhysN - 0.9 - Tp - 50 100 ms Output High Voltage VOH VDD-0.2 - - V BrpN
BU52053NVX-TR
文档中的物料型号为:TPS54360RHLR。
器件简介:TPS54360 是一款同步整流降压/升压 DC-DC 转换器,具有 3A 连续输出电流能力。
引脚分配:1-GND, 2-EN, 3-Vin, 4-Vout, 5-Ilim, 6-Pgood, 7-SW, 8-NC。
参数特性:输入电压范围为 4.5V 至 23V,输出电压可调,最大占空比为 95%。
功能详解:TPS54360 支持多种反馈引脚配置,可实现精准的输出电压控制,并有软启动功能。
应用信息:适用于需要高效率和高输出电流的应用,如锂电池充电管理。
封装信息:采用 8 引脚的 R-HLR 封装。
BU52053NVX-TR 价格&库存
很抱歉,暂时无法提供与“BU52053NVX-TR”相匹配的价格&库存,您可以联系我们找货
BU52053NVX-TR
  • 1+6.912691+0.86774
  • 5+6.040405+0.75824
  • 10+5.7164710+0.71758
  • 25+5.3506125+0.67165
  • 50+5.0965550+0.63976
  • 100+4.86461100+0.61064
  • 500+4.39929500+0.55223
  • 1000+4.226391000+0.53053
库存:4818
BU52053NVX-TR
  • 5000+3.878795000+0.48690
  • 10000+3.7493810000+0.47065
  • 15000+3.6787315000+0.46178
库存:4818
BU52053NVX-TR
    • 1+6.27480
    • 10+6.12360
    • 30+6.01560
    库存:49
    BU52053NVX-TR
      • 1+1.282791+0.16103
      • 10+1.2485810+0.15674
      • 50+1.2229350+0.15351
      • 100+1.19727100+0.15029
      • 500+1.19727500+0.15029
      • 1000+1.188721000+0.14922
      • 2000+1.188722000+0.14922
      库存:45
