LVDS Interface ICs
4bit LVDS Driver
BU90LV047A
No.12057EAT02
●Description
LVDS Interface IC of ROHM "Serializer" "Deserializer" operate from 8MHz to 150MHz wide clock range, and number of bits
range is from 35 to 70. Data is transmitted seven times (7X) stream and reduce cable number by 3(1/3) or less. The
ROHM's LVDS has low swing mode to be able to expect further low EMI.
Driver and Receiver of 4 bits operate to 250MHz. It can be used for a variety of purposes, home appliances such as
LCD-TV, business machines such as decoders, instruments, and medical equipment.
●Features
1) >500 Mbps (250 MHz) switching rates
2) Flow-through pinout simplifies PCB layout.
3) 300 ps typical differential skew
4) 400 ps maximum differential skew
5) 2.8 ns maximum propagation delay
6) 3.3V power supply design
7) ±200mV and ±350mV Selectable differential signaling
8) Interoperable with existing 5V LVDS receivers
9) High impedance on LVDS outputs on power down
10) Conforms to TIA/EIA-644 LVDS Standard
11) Industrial operating temperature range (-40℃ to +85℃)
●Applications
Car Navigation System
Copier
Digital TV (Signal System)
FA equipment
Medical equipment
Vending machine, Ticket vending machine
●Precaution
■This chip is not designed to protect from radioactivity.
■This document may be used as strategic technical data
which subjects to COCOM regulations.
www.rohm.com
© 2011 ROHM Co., Ltd. All rights reserved.
1/11
2011.12 - Rev.A
Technical Note
BU90LV047A
●Block Diagram
SL
DOUT1+
DIN1
D1
DOUT1-
DOUT2+
DIN2
D2
DOUT2-
DOUT3+
DIN3
D3
DOUT3-
DOUT4+
DIN4
D4
DOUT4-
EN
Fig.1. Block Diagram
www.rohm.com
2/11
2011.12 - Rev.A
Technical Note
BU90LV047A
●SSOP-B16 Package Outline and Specification
Product No.
5.0±0.2
16
9
4.4±0.2
Lot No.
0.3MIN
6.4±0.3
LV47A
1PIN MARK
1
8
0.10
1.15±0.1
0.15±0.1
0.65
0.10
0.22±0.1
(UNIT:mm)
Fig.2. SSOP-B16 Package Outline and Specification
www.rohm.com
3/11
2011.12 - Rev.A
Technical Note
BU90LV047A
●Pin Configuration
EN
1
16
DOUT1-
DIN1
2
15
DOUT1+
DIN2
3
14
DOUT2+
VCC
4
13
DOUT2-
GND
5
12
DOUT3-
DIN3
6
11
DOUT3+
DIN4
7
10
DOUT4+
SL
8
9
DOUT4-
Fig.3. Pin Diagram (Top View)
www.rohm.com
4/11
2011.12 - Rev.A
Technical Note
BU90LV047A
●Pin Description
Table 1 : Pin Description
Pin Name
Pin No.
Type
Descriptions
DIN
2, 3, 6, 7
LVCMOS In
DOUT+
10, 11, 14, 15
LVDS Out
Non-inverting driver output pin,
LVDS levels
DOUT-
9, 12, 13, 16
LVDS Out
Inverting driver output pin, LVDS levels
SL
8
LVCMOS In
EN
1
LVCMOS In
VCC
4
Power
GND
5
GND
Driver input pin, LVCMOS compatible
Swing Level select pin : When SL is high, the driver is reduce swing
level (200mV). When SL is low or open, the driver is normal swing
level (350mV).
Driver enable pin: When EN is low or open, the driver is disabled.
When EN is high, the driver is enabled.
Power supply pin, 3.3V±0.3V
Ground pin
●Function Description
INPUT
OUTPUTS
Swing Level
EN
SL
H
L or Open
H
DIN
DOUT+
DOUT-
L
L
H
H
H
L
L
L
H
H
H
L
X
Z
Z
350mV
200mV
H
All other combinations of
EN, SL inputs
www.rohm.com
5/11
2011.12 - Rev.A
Technical Note
BU90LV047A
●Absolute Maximum Ratings
Item
Value
Symbol
Min.
Max.
Unit
Supply voltage
VCC
-0.3
4.0
V
Input voltage
VIN
-0.3
VCC+0.3
V
VOUT
-0.3
VCC+0.3
V
Tstg
-55
125
Output voltage
Storage temperature range
●Package Power
Package
PD(mW)
DERATING(mW/℃)
400
4.0
450*2
4.5※
※1
SSOP-B16
2
※1 At temperature Ta > 25℃
※2 Package power when mounting on the PCB board.
The size of PCB board
:70×70×1.6(mm3)
The material of PCB board :The FR4 glass epoxy board.(3% or less copper foil area)
●Recommended Operating Conditions
Item
Symbol
Value
Min.
Typ.
Max.
Unit
Supply voltage
VCC
3.0
3.3
3.6
V
Operating temperature range
Topr
-40
85
www.rohm.com
6/11
Condition
2011.12 - Rev.A
Technical Note
BU90LV047A
●DC Characteristics
Parameter
Symbol
Conditions
Pin
Min
Typ
Max
Units
250
350
450
mV
1.42
1.6
V
Differential Output Voltage
VOD1
Output High Voltage
VOH1
Output Low Voltage
VOL1
0.90
1.08
V
VOD2
120
200
300
mV
Output High Voltage
VOH2
1.35
1.50
V
Output Low Voltage
VOL2
1.00
1.15
V
△VOD
1
35
|mV|
1.125
1.25
1.375
V
1
25
|mV|
Change in Magnitude of VOD for
Complementary Output States
Offset Voltage
Change in Magnitude of Vos for
VOS
SL= GND, RL = 100Ω (Fig.4)
SL= VCC , RL = 100Ω (Fig.4)
DOUTDOUT+
SL = VCC or GND,
RL = 100Ω (Fig.4)
△VOS
Input High Voltage
VIH
DIN,
VCC
×0.8
VCC
V
Input Low Voltage
VIL
SL
GND
VCC
×0.2
V
EN
-10
+10
μA
-1.5
-0.8
V
-5.4
-9.0
mA
-5.4
-9.0
mA
Input Current
II
VIN = 0V or VCC,
Other Input = VCC or GND
Input Clamp Voltage
VCL
ICL = -18mA
Output Short Circuit Current
IOS
ENABLED,
DIN = VCC, DOUT+ = 0V or
DIN = GND, DOUT- = 0V
Differential Output Short Circuit
Current
IOSD
ENABLED, VOD = 0V
Power-off Leakage
IOFF
VOUT = 0V or 3.6V,
VCC =0V or Open
-20
±1
+20
μA
ICC
DIN = VCC or GND
mA
mA
3
mA
No Load Supply Current Drivers
Enabled
Enabled
Disabled
www.rohm.com
ICCL
ICCZ
RL = 100Ω All Channels,
DIN = VCC or GND (all outputs)
DIN = VCC or GND,
EN = GND, SL = GND
7/11
DOUTDOUT+
VCC
2011.12 - Rev.A
Technical Note
BU90LV047A
●Switching Characteristics
VCC = +3.3V ±0.3V, Topr = -40℃ to +85℃
Parameter
Symbol
Differential Propagation Delay
High to Low
Low to High
Differential Pulse Skew
|tPHLD – tPLHD|
Conditions
Min
Typ
Max
Units
tPHLD
0.5
1.7
2.8
ns
tPLHD
0.5
1.7
2.8
ns
tSKD1
0.4
ns
0.5
ns
ns
Channel-to-Channel Skew
tSKD2
Differential Part to Part Skew
tSKD3
tSKD4
ns
Rise Time
tTLH
0.5
1.5
ns
Fall Time
tTHL
0.5
1.5
ns
Disable Time High to Z
tPHZ
2
5
ns
Disable Time Low to Z
tPLZ
2
5
ns
Enable Time Z to High
tPZH
3
7
ns
Enable Time Z to Low
tPZL
3
7
ns
Maximum Operating Frequency
fMax
250
MHz
RL = 100Ω, CL = 15pF
(Fig.5 and Fig.6)
(Fig.7 and Fig.8)
DOUT+
RL/2
Vcc
GND
DIN
VOS
D
S1
VOD
RL/2
Driver ENABLED
DOUT-
Fig.4. Driver VOD and VOS Test Circuit
www.rohm.com
8/11
2011.12 - Rev.A
Technical Note
BU90LV047A
CL
DOUT+
DIN
Generator
D
RL
50Ω
DOUTDriver ENABLED
CL
Fig.5. Driver Propagation Delay and Transition Time Test Circuit
3V
DIN
1.5V
1.5V
0V
tPLHD
tPHLD
VOH
DOUT0V(Differential)
0V
DOUT+
VOL
80%
VDIFF
0V
80%
VDIFF = DOUT+ - DOUT-
0V
20%
20%
tTLH
tTHL
Fig.6. Driver Propagation Delay and Transition Time Waveforms
CL
D OUT+
VCC
50Ω
DIN
D
GND
50Ω
+1.2V
D OUT-
CL
EN
Generator
50Ω
1/ 4 BU90LV 047A
Fig.7. Driver 3-STATE Delay Test Circuit
www.rohm.com
9/11
2011.12 - Rev.A
Technical Note
BU90LV047A
Parameter Measurement Information (Continued)
3V
EN
WHEN SL = L or Open
1.5V
1.5V
0V
tPHZ
tPZH
VOH
DOUT+ WHEN DIN = Vcc
DOUT- WHEN DIN = GND
50%
50%
1.2V
1.2V
DOUT+ WHEN DIN = GND
DOUT- WHEN DIN = Vcc
50%
50%
VOL
tPLZ
tPZL
Fig.8. Driver 3-STATE Delay Waveform
Typical Application
ENABLE
1/4 BU90LV048
DATA
INPUT
RT
DATA
OUTPUT
100Ω
1/4 BU90LV047A
Fig.9. Point-to-Point Application
Typical Application (Continued)
3V
DIN
0V
VOH
DOUTSINGLE-ENDED
DOUT+
DOUT+ - DOUTDIFFERENTIAL OUTPUT
|VOD|
VOS (1.25V typical)
VOL
+VOD
0V
0V(DIFF.)
+VSS
-VOD
Fig.10. Driver Output Levels
www.rohm.com
10/11
2011.12 - Rev.A
Technical Note
BU90LV047A
●Ordering part number
B
U
9
Part No.
L
V
7
A
Part No.
90LV047A (Package: SSOP-B16)
E
2
Packaging and forming specification
E2: Embossed tape and reel
SSOP-B16
5.0±0.2
9
0.3Min.
4.4±0.2
6.4±0.3
16
1
Tape
Embossed carrier tape
Quantity
2500pcs
Direction
of feed
E2
The direction is the 1pin of product is at the upper left when you hold
( reel on the left hand and you pull out the tape on the right hand
8
0.10
1.15±0.1
0.15±0.1
0.1
0.65
1pin
0.22±0.1
Reel
(Unit : mm)
www.rohm.com
11/11
Direction of feed
∗ Order quantity needs to be multiple of the minimum quantity.
2011.12 - Rev.A
Datasheet
Notice
Precaution on using ROHM Products
1.
Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment,
OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you
(Note 1)
, transport
intend to use our Products in devices requiring extremely high reliability (such as medical equipment
equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car
accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or
serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance.
Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any
damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific
Applications.
(Note1) Medical Equipment Classification of the Specific Applications
JAPAN
USA
EU
CHINA
CLASSⅢ
CLASSⅡb
CLASSⅢ
CLASSⅢ
CLASSⅣ
CLASSⅢ
2.
ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor
products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate
safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which
a failure or malfunction of our Products may cause. The following are examples of safety measures:
[a] Installation of protection circuits or other protective devices to improve system safety
[b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure
3.
Our Products are designed and manufactured for use under standard conditions and not under any special or
extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way
responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any
special or extraordinary environments or conditions. If you intend to use our Products under any special or
extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of
product performance, reliability, etc, prior to use, must be necessary:
[a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents
[b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust
[c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2,
H2S, NH3, SO2, and NO2
[d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves
[e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items
[f] Sealing or coating our Products with resin or other coating materials
[g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of
flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning
residue after soldering
[h] Use of the Products in places subject to dew condensation
4.
The Products are not subject to radiation-proof design.
5.
Please verify and confirm characteristics of the final or mounted products in using the Products.
6.
In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied,
confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power
exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect
product performance and reliability.
7.
De-rate Power Dissipation (Pd) depending on Ambient temperature (Ta). When used in sealed area, confirm the actual
ambient temperature.
8.
Confirm that operation temperature is within the specified range described in the product specification.
9.
ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in
this document.
Precaution for Mounting / Circuit board design
1.
When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product
2.
In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the
ROHM representative in advance.
For details, please refer to ROHM Mounting specification
Notice - GE
© 2014 ROHM Co., Ltd. All rights reserved.
Rev.002
Datasheet
Precautions Regarding Application Examples and External Circuits
1.
If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the
characteristics of the Products and external components, including transient characteristics, as well as static
characteristics.
2.
You agree that application notes, reference designs, and associated data and information contained in this document
are presented only as guidance for Products use. Therefore, in case you use such information, you are solely
responsible for it and you must exercise your own independent verification and judgment in the use of such information
contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses
incurred by you or third parties arising from the use of such information.
Precaution for Electrostatic
This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper
caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be
applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron,
isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control).
Precaution for Storage / Transportation
1.
Product performance and soldered connections may deteriorate if the Products are stored in the places where:
[a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2
[b] the temperature or humidity exceeds those recommended by ROHM
[c] the Products are exposed to direct sunshine or condensation
[d] the Products are exposed to high Electrostatic
2.
Even under ROHM recommended storage condition, solderability of products out of recommended storage time period
may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is
exceeding the recommended storage time period.
3.
Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads
may occur due to excessive stress applied when dropping of a carton.
4.
Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of
which storage time is exceeding the recommended storage time period.
Precaution for Product Label
QR code printed on ROHM Products label is for ROHM’s internal use only.
Precaution for Disposition
When disposing Products please dispose them properly using an authorized industry waste company.
Precaution for Foreign Exchange and Foreign Trade act
Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act,
please consult with ROHM representative in case of export.
Precaution Regarding Intellectual Property Rights
1.
All information and data including but not limited to application example contained in this document is for reference
only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any
other rights of any third party regarding such information or data. ROHM shall not be in any way responsible or liable
for infringement of any intellectual property rights or other damages arising from use of such information or data.:
2.
No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any
third parties with respect to the information contained in this document.
Other Precaution
1.
This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM.
2.
The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written
consent of ROHM.
3.
In no event shall you use in any way whatsoever the Products and the related technical information contained in the
Products or this document for any military purposes, including but not limited to, the development of mass-destruction
weapons.
4.
The proper names of companies or products described in this document are trademarks or registered trademarks of
ROHM, its affiliated companies or third parties.
Notice - GE
Rev.002
Datasheet
General Precaution
1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents.
ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny
ROHM’s Products against warning, caution or note contained in this document.
2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior
notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s
representative.
3.
The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all
information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or
liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or
concerning such information.
Notice – WE
Rev.001
