BV1HAL45EFJ-E2
BV1HAL45EFJ-E2
    ROHM(罗姆)
    SOIC8_150MIL_EP
    电源开关/驱动器 1:2 N 通道 10A 8-HTSOP-J
BV1HAL45EFJ-E2 数据手册
Datasheet Load Switch IC 34 V Breakdown Voltage Variable Overcurrent Detection 1ch Load Switch BV1HAL45EFJ General Description Key Specifications BV1HAL45EFJ is a single Nch MOSFET high side load switch applicable to 8.0 V to 32.0 V input. It has a built-in overcurrent protection, Thermal shutdown protection, soft-start function and low power output OFF function. It is equipped with error flag notification pin to indicate thermal shutdown and overcurrent. Single chip power supply management is possible. ◼ ◼ ◼ ◼ ◼ Package W (Typ) x D (Typ) x H (Max) 4.9 mm x 6.0 mm x 1.0 mm HTSOP-J8 Features ◼ ◼ ◼ ◼ ◼ ◼ ◼ Input Voltage Range: 8.0 V to 32.0 V Output ON Resistance: 45mΩ (Typ) Variable Overcurrent Detection: 3.4 A to 10.0 A (Typ) Standby Current: 0.5 μA (Max) Operating Temperature Range: -40 °C to +85 °C Dual TSD(Note 1) Low On-Resistance Single Nch MOSFET Switch Variable Output Soft-Start Time Overcurrent Protection Function (Latch-Off) Thermal Shutdown Protection Function (TSD) Low Voltage Output OFF Function (UVLO) Error Flag Notification Pin (Note 1) This IC has thermal shutdown function (Junction temperature detect) and ΔTj Protection function (Power-MOS steep temperature rising detect). Applications ◼ Multifunction Machine and TV ◼ Overcurrent Monitoring of Various Power Lines and Power Management Application Circuit 12 V / 24 V C IN = 1 µF IN SS OUT ILIM OUT GND N.C. R SS C OUT Load RLIM 10 kΩ to 100 kΩ EN FLAG 〇Product structure : Silicon integrated circuit www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 14 • 001 〇This product has no designed protection against radioactive rays. 1/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Table of Contents General Description ........................................................................................................................................................................ 1 Features.......................................................................................................................................................................................... 1 Applications .................................................................................................................................................................................... 1 Key Specifications .......................................................................................................................................................................... 1 Package .......................................................................................................................................................................................... 1 Application Circuit ........................................................................................................................................................................... 1 Table of Contents ........................................................................................................................................................................... 2 Pin Configuration ............................................................................................................................................................................ 3 Pin Description................................................................................................................................................................................ 3 Block Diagram ................................................................................................................................................................................ 3 Definition ......................................................................................................................................................................................... 4 Absolute Maximum Ratings ............................................................................................................................................................ 5 Thermal Resistance ........................................................................................................................................................................ 6 Recommended Operating Conditions ........................................................................................................................................... 10 Electrical Characteristics............................................................................................................................................................... 10 Typical Performance Curves......................................................................................................................................................... 11 Measurement Setup ..................................................................................................................................................................... 17 Timing Chart ................................................................................................................................................................................. 19 Function Description ..................................................................................................................................................................... 20 1. Truth Table ............................................................................................................................................................................ 20 2. Overcurrent Protection .......................................................................................................................................................... 21 2.1 Latch-off due to Fixed Overcurrent Limit (IOCD1)............................................................................................................... 21 2.2 Duration of Fixed Overcurrent Limit (IOCD1) is less than tBLANK ......................................................................................... 23 2.3 Latch-off due to Variable Overcurrent Detection (IOCD2) ................................................................................................... 25 2.4 Duration of Variable Overcurrent Detection (IOCD2) is less than tBLANK .............................................................................. 25 2.5 Setting Variable Overcurrent Detection ............................................................................................................................ 26 3. Setting Soft Start Function .................................................................................................................................................... 27 4. Thermal Shutdown Function, ΔTj Protection Function .......................................................................................................... 30 4.1 Thermal Shutdown Function ............................................................................................................................................ 30 4.2 ΔTj Protection Function.................................................................................................................................................... 30 4.3 The case of connecting the capacitance load .................................................................................................................. 31 5. Output Load is Open ............................................................................................................................................................. 37 I/O Equivalence Circuit ................................................................................................................................................................. 37 Operational Notes ......................................................................................................................................................................... 38 Ordering Information ..................................................................................................................................................................... 40 Marking Diagram .......................................................................................................................................................................... 40 Physical Dimension and Packing Information ............................................................................................................................... 41 Revision History ............................................................................................................................................................................ 42 www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 2/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Pin Configuration HTSOP-J8 (TOP VIEW) Pin Description Pin No. Pin Name 1 SS Function Variable soft-start time setting pin 2 ILIM Variable overcurrent detection setting pin 3 GND Ground pin 4 FLAG 5 EN 6 N.C. Error flag output pin (Active low when TSD and OCD is detected.) Enable pin (Pull-down resistor is connected internally.) Active High to turn on the switch Not connected pin(Note 1) 7,8 OUT Switch output pin EXP-PAD IN Power input pin, switch input pin (Note 1) GND short connection is recommended for the N.C. pin. It can also be open since the N.C. pin is not connected inside the IC. Block Diagram IN Control Gate Control Clamp CLK Charge Pump Power MOS FET Gate Driver OUT EN lnternal supply SS Protect Control Logic TSD FLAG UVLO for TSD,OCP ILIM OCD GND www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 3/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Definition IN IEN IIN VDS EN VIN IOUT OUT VOUT ISS IFLAG FLAG SS VFLAG IILIM VILIM VSS VEN ILIM GND IGND Figure 1. Voltage and Current Definition www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 4/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Absolute Maximum Ratings (Ta = 25 °C) Item Symbol Power Supply Output Voltage VDS Rating -0.3 to Internal unit limit(Note 1) V Power Supply Voltage (IN) VIN -0.3 to +34 V Storage Temperature Range Tstg -55 to +150 °C Tjmax 150 °C VEN -0.3 to +7.0 V VFLAG -0.3 to +7.0 V Maximum Junction Temperature EN Input Voltage FLAG Output Voltage Internal limit(Note 2) Output Current IOUT FLAG Output Current IFLAG 10 mA A Active Clamp Capability (single pulse) Tj(START) = 25 °C, IOUT(START) = 1 A(Note 3)(Note 4) EAS 53.2 mJ Caution 1: Operating the IC over the absolute maximum ratings may damage the IC. The damage can either be a short circuit between pins or an open circuit between pins and the internal circuitry. Therefore, it is important to consider circuit protection measures, such as adding a fuse, in case the IC is operated over the absolute maximum ratings. Caution 2: Should by any chance the maximum junction temperature rating be exceeded the rise in temperature of the chip may result in deterioration of the properties of the chip. In case of exceeding this absolute maximum rating, design a PCB with thermal resistance taken into consideration by increasing board size and copper area so as not to exceed the maximum junction temperature rating. (Note 1) Internal limit according to output clamp voltage (Note 2) Internal limit according to fixed overcurrent limit (Note 3) This is the maximum value of active clamp tolerance (single pulse) under the conditions of IOUT(START) = 1 A, VIN = 24 V. The OUT pin potential drops less than 0 V during turned off when L load is connected in the OUT pin. The energy at this time is consumed in BV1HAL45EFJ. This energy is expressed in the equation below. 𝐸𝐴𝑆 = 𝑉𝐷𝑆 × 𝑅𝐿 × 𝐼𝑂𝑈𝑇(𝑆𝑇𝐴𝑅𝑇) 𝐿 𝑉𝐼𝑁 − 𝑉𝐷𝑆 ×[ × 𝑙𝑛 (1 − ) + 𝐼𝑂𝑈𝑇(𝑆𝑇𝐴𝑅𝑇) ] 𝑅𝐿 𝑅𝐿 𝑉𝐼𝑁 − 𝑉𝐷𝑆 Following equation simplifies under the assumption of RL = 0 Ω. 𝐸𝐴𝑆 = 1 𝑉𝐼𝑁 × 𝐿 × 𝐼𝑂𝑈𝑇(𝑆𝑇𝐴𝑅𝑇) 2 × ( 1 − ) 2 𝑉𝐼𝑁 − 𝑉𝐷𝑆 (Note 4) Not 100 % tested. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 5/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Thermal Resistance(Note 1) Parameter Symbol Typ Unit Condition 121.2 °C/W 1s (Note 2) 37.2 °C/W 2s (Note 3) 25.3 °C/W 2s2p (Note 4) HTSOP-J8 Between Junction and Surroundings Temperature Thermal Resistance θJA (Note 1) The thermal impedance is based on JESD51-2A (Still-Air) standard. It is used in the chip of BV1HAL45EFJ. (Note 2) JESD51-3 standard FR4 114.3 mm x 76.2 mm x 1.57 mm 1-layer (1s) (Top copper foil: ROHM recommended Footprint + wiring to measure, 2 oz. copper.) (Note 3) JESD51-5 standard FR4 114.3 mm x 76.2 mm x 1.60 mm 2-layers (2s) (Top copper foil: ROHM recommended Footprint + wiring to measure / Copper foil area on the reverse side of PCB: 74.2 mm x 74.2 mm, copper (top & reverse side) 2 oz.) (Note 4) JESD51-5/- 7 standard FR4 114.3 mm x 76.2 mm x 1.60 mm 4-layers (2s2p) (Top copper foil: ROHM recommended Footprint + wiring to measure / 2 inner layers and copper foil area on the reverse side of PCB: 74.2 mm x 74.2 mm, copper (top & reverse side/inner layers) 2 oz./1 oz.) ■ PCB Layout 1 Layer (1s) Figure 2. PCB Layout 1 Layer (1s) Dimension Value Board Finish Thickness 1.57 mm ± 10 % Board Dimension 76.2 mm x 114.3 mm Board Material FR4 Copper Thickness (Top/Bottom Layers) 0.070 mm (Cu : 2 oz) 2 Copper Foil Area Dimension www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 2 Footprint / 100 mm / 600 mm / 1200 mm 6/42 2 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Thermal Resistance – continued ■ PCB Layout 2 Layers (2s) Figure 3. PCB Layout 2 Layers (2s) Dimension Value Board Finish Thickness 1.60 mm ± 10 % Board Dimension 76.2 mm x 114.3 mm Board Material FR4 Copper Thickness (Top/Bottom Layers) 0.070 mm (Cu +Plating) Thermal Vias Separation / Diameter 1.2 mm / 0.3 mm www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 7/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Thermal Resistance – continued ■ PCB Layout 4 Layers (2s2p) Figure 4. PCB Layout 4 Layers (2s2p) Dimension Value Board Finish Thickness 1.60 mm ± 10 % Board Dimension 76.2 mm x 114.3 mm Board Material FR4 Copper Thickness (Top/Bottom Layers) 0.070 mm (Cu +Plating) Copper Thickness (Inner Layers) 0.035 mm Thermal Vias Separation / Diameter 1.2 mm / 0.3 mm www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 8/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Thermal Resistance – continued ■ Transient Thermal Resistance (Single Pulse) 1000 θJA [ °C/W] 100 10 1s footprint 1 2s 2s2p 0 0.0001 0.001 0.01 0.1 1 Pulse Time [s] 10 100 1000 Figure 5. θJA vs Pulse Time ■ Thermal Resistance (θJA vs Copper foil area - 1s) 140 120 θJA [ °C/W] 100 80 60 40 20 0 0 200 400 600 800 Copper Foil Area (1s) [mm2] 1000 1200 Figure 6. θJA vs Copper Foil Area (1s) www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 9/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Recommended Operating Conditions Parameter Power Supply(Note 1) Operating Temperature Symbol Min Typ Max Unit VIN 8.0 - 32.0 V Topr -40 - +85 °C (Note 1) Do not exceed the maximum junction temperature. Electrical Characteristics (Unless otherwise specified VIN = 8.0 V to 32.0 V, Tj = -40 °C to +85 °C, RLIM = 100 kΩ) Parameter Symbol Min Typ Max Unit Standby Current ISTB - - 0.5 µA Operating Current ICC - 2.00 3.50 mA Condition [Power Supply] VIN = 24 V, VEN = 0 V, Tj = 25 °C VIN = 24 V, VEN = 5 V, Tj = 25 °C UVLO Detection Voltage VUVLO - - 6.0 V UVLO Hysteresis Voltage VUVHYS 0.5 0.9 1.3 V EN High Voltage VENH 2.1 - - V EN Low Voltage VENL - - 0.9 V EN Hysteresis Voltage VENHYS 0.10 0.45 0.80 V EN High Input Current IENH - 50 100 μA VEN = 5 V EN Low Input Current IENL -1 - +1 μA VEN = 0 V Output ON Resistance RON - 45 60 mΩ Output Leakage Current ILSW - - 0.5 µA Output ON Slew Rate SRON 0.24 0.40 0.56 V/ms Output OFF Slew Rate SROFF - 0.10 0.30 V/μs Output ON Delay Time tON 36 60 84 ms Output OFF Delay Time tOFF - 360 900 μs VDSCLP 45 50 55 V VEN = 5 V, Tj = 25 °C VEN = 0 V, VOUT = 0 V, Tj = 25 °C VIN = 24 V, Tj = 25 °C RSS = 100 kΩ, RL = 100 Ω, VOUT:20 %→80 % VIN = 24 V, Tj = 25 °C RSS = 100 kΩ, RL = 100 Ω, VOUT:80 %→20 % VIN = 24 V, Tj = 25 °C RSS = 100 kΩ, RL = 100 Ω, VEN:50 %→VOUT:80 % VIN = 24 V, Tj = 25 °C RSS = 100 kΩ, RL = 100 Ω, VEN:50 %→VOUT:20 % VEN = 0 V, IOUT = 10 mA FLAG Low Output Voltage VFLAG - - 0.5 V IFLAG = 1 mA FLAG Pin Leakage Current ILFLAG - - 1 µA VFLAG = 5 V FLAG Output Delay Time tBLANK 15 30 45 ms The time from overcurrent detection to VFLAG = Low. Thermal Shutdown Detection(Note 1) TTSD 150 175 200 °C Thermal Shutdown Hysteresis(Note 1) TTSDHYS - 15 - °C TDTJ - 105 - °C [Input (VEN)] [Power MOS Output] Output Clamp Voltage [FLAG] [Diagnostic Functions] ΔTj Protection(Note 1) ΔTj Protection Hysteresis(Note 1) TDTJHYS - 30 - °C Fixed Overcurrent Limit IOCD1 17.4 26.0 34.6 A Tj = 25 °C Variable Overcurrent Detection IOCD2 3.7 5.8 7.9 A RLIM = 100 kΩ, Tj = 25 °C (Note 1) Not 100 % tested. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 10/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Typical Performance Curves 0.6 0.6 0.4 0.4 Standby Current: ISTB [μA] Standby Current: ISTB [μA] (Unless otherwise specified VIN = 24 V, VEN = 5 V, Tj = 25 °C) 0.2 0 -0.2 0 -0.2 -0.4 -0.4 VEN = 0 V -0.6 VEN = 0 V -0.6 0 5 10 15 20 25 Supply Voltage: VIN [V] 30 35 -50 Figure 7. Standby Current vs Supply Voltage -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 8. Standby Current vs Junction Temperature 3.5 3.5 3.0 3.0 Operating Current: ICC [mA] Operating Current: ICC [mA] 0.2 2.5 2.0 1.5 1.0 VEN = 5 V 0.5 2.5 2.0 1.5 1.0 VEN = 5 V 0.5 0.0 0.0 0 5 10 15 20 25 Supply Voltage: VIN [V] 30 35 -50 Figure 9. Operating Current vs Supply Voltage www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 10. Operating Current vs Junction Temperature 11/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Typical Performance Curves – continued (Unless otherwise specified VIN = 24 V, VEN = 5 V, Tj = 25 °C) 1.4 1.2 UVLO Hysteresis Voltage: VUVHYS [V] UVLO Detection Voltage: VUVLO [V] 5 4 3 2 1 0 0.8 0.6 0.4 0.2 0.0 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 11. UVLO Detection Voltage vs Junction Temperature -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 12. UVLO Hysteresis Voltage vs Junction Temperature 4.0 150 3.5 125 3.0 EN Input Current: IENH,IENL [μA] EN Voltage: VENH, VENL [V] 1.0 100 2.5 VENH 2.0 1.5 1.0 VENL 0.5 75 IENH 50 25 IENL 0.0 0 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 13. EN Voltage vs Junction Temperature www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 14. EN Input Current vs Junction Temperature 12/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Typical Performance Curves – continued 0.8 80 0.7 70 Output ON Resistance: RON [mΩ] EN Hysteresis Voltage: VENHYS [V] (Unless otherwise specified VIN = 24 V, VEN = 5 V, Tj = 25 °C) 0.6 0.5 0.4 0.3 0.2 0.1 60 50 40 30 20 10 0 0 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 0 Figure 15. EN Hysteresis Voltage vs Junction Temperature 10 15 20 25 Supply Voltage: VIN [V] 30 35 Figure 16. Output ON Resistance vs Supply Voltage 0.6 100 0.4 Output Leakage Current: ILSW [μA] 120 Output ON Resistance: RON [mΩ] 5 80 60 40 0.2 0 -0.2 20 -0.4 0 -0.6 -80 -40 0 40 80 120 160 Junction Temperature: Tj [°C] 200 Figure 17. Output ON Resistance vs Junction Temperature www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 18. Output Leakage Current vs Junction Temperature 13/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Typical Performance Curves – continued (Unless otherwise specified VIN = 24 V, VEN = 5 V, Tj = 25 °C) 1.20 0.2 Output ON Slew Rate: SRON [V/ms] RSS = 100 kΩ RL = 100 Ω Output OFF Slew Rate: SROFF [V/us] RSS = 100 kΩ RL = 100 Ω 1.05 0.90 0.15 0.75 0.60 0.45 0.30 0.1 0.05 0.15 0.00 0 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 19. Output ON Slew Rate vs Junction Temperature -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 20. Output OFF Slew Rate vs Junction Temperature 100 500 450 Output OFF Delay Time: tOFF [μs] Output ON Delay Time: tON [ms] 90 80 70 400 60 50 350 40 300 30 20 RSS = 100 kΩ RL = 100 Ω 250 10 0 200 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] Figure 21. Output ON Delay Time vs Junction Temperature www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 100 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 22. Output OFF Delay Time vs Junction Temperature 14/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Typical Performance Curves – continued (Unless otherwise specified VIN = 24 V, VEN = 5 V, Tj = 25 °C) 0.5 70 FLAG Low Output Voltage: VFLAG [V] Output Clamp Voltage: VDSCLP [V] 80 60 50 40 30 20 IOUT = 10 mA VEN = 0 V 10 0 0.4 0.3 0.2 0.1 0.0 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 -50 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 24. FLAG Low Output Voltage vs Junction Temperature 45 30 40 29 Fixed Overcurrent Detection: IOCD1 [A] FLAG Output Delay TIme: tBLANK [ms] Figure 23. Output Clamp Voltage vs Junction Temperature -25 35 30 25 20 15 10 5 0 28 27 26 25 24 23 22 21 20 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 25. FLAG Output Delay Time vs Junction Temperature www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 26. Fixed Overcurrent Limit vs Junction Temperature 15/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Typical Performance Curves – continued (Unless otherwise specified VIN = 24 V, VEN = 5 V, Tj = 25 °C) 1000 10 8 Active Clamp Energy: EAS [mJ] Variable Overcurrent Detection: IOCD2 [A] 9 7 6 5 4 3 2 100 Tj(START) = 25 ºC Tj(START) = 150 ºC 10 1 1 0 -50 -25 0 25 50 75 Junction Temperature: Tj [°C] 100 Figure 27. Variable Overcurrent Detection vs Junction Temperature www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 0.1 1.0 Output Current: IOUT [A] 10.0 Figure 28. Active Clamp Energy vs Output Current 16/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Measurement Setup VIN VIN IN IN SS SS OUT OUT ILIM ILIM EN FLAG 5.1 kΩ EN FLAG GND GND VEN VEN VFLAG Figure 29. Standby Current EN Low Input Current Output Leakage Current FLAG Pin Leakage Current Figure 30. Operating Current VIN VIN IN SS IN SS OUT OUT IOUT ILIM ILIM 1 kΩ EN EN FLAG FLAG GND VEN GND Figure 31. UVLO Detection Voltage UVLO Hysteresis Voltage EN High Voltage EN Low Voltage EN Hysteresis Voltage EN High Input Current EN Low Input Current Thermal Shutdown Detection Thermal Shutdown Hysteresis www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 VEN Figure 32. Output ON Resistance Output Clamp Voltage 17/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Measurement Setup – continued VIN VIN IN IN SS SS 100 Ω RSS ILIM Monitor 5.1 kΩ VFLAG VEN VFLAG EN FLAG Monitor GND 5.1 kΩ I OUT ILIM EN FLAG Monitor OUT OUT Figure 33. Output ON Slew Rate Output OFF Slew Rate Output ON Delay Time Output OFF Delay Time FLAG Output Delay Time GND VEN Figure 34. FLAG Low Output Voltage VIN IN SS OUT IOUT ILIM RLIM EN FLAG Monitor 5.1 kΩ GND VEN VFLAG Figure 35. Fixed Overcurrent Limit Variable Overcurrent Detection www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 18/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Timing Chart Input Voltage VIN t EN Voltage VEN 50 % 50 % t tOFF tON 80 % Output Voltage VOUT 80 % 20 % 20 % t SRON SROFF Error Flag VFLAG t Figure 36. Output ON / OFF Timing Chart www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 19/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Function Description 1. Truth Table Control Logic EN Input Voltage VIN Table 1. Protection Detection and Error FLAG Output Junction Output Output State Error Flag Output Temperature Current OUT VFLAG Tj IOUT Mode IOUT < IOCD2 ON H Normal IOUT > IOCD2 ON H Overcurrent Detection IOUT > IOCD2 tBLANK after Latch Off L Latch Off (Note 1) IOUT > IOCD1 Output Limited H Overcurrent Limitation Tj > TTSD - OFF L TSD protection ΔTj(Note 2 ) > TDTJ - OFF L ΔTj protection VIN < VUVLO - - OFF H Stand-by - - - OFF H Stand-by Tj < TTSD VIN > VUVLO H L (Note 1) When thermal shutdown protection is triggered while overcurrent protection is active, output is Latch Off even if t < tBLANK. The condition of Latch Off release is switching of EN voltage (VEN) or IN voltage (VIN). (Note 2) The temperature difference of Power MOS FET and control in the IC. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 20/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Function Description – continued 2. Overcurrent Protection This IC has two overcurrent detection functions: Fixed Overcurrent Limit (IOCD1) to protect the IC and Variable Overcurrent Detection (IOCD2) to protect the load. Variable Overcurrent Detection (IOCD2) is set by an external resistor RLIM at the ILIM Pin. 2.1 Latch-off due to Fixed Overcurrent Limit (IOCD1) Figure 37 and Figure 38 show the timing chart of the Latch-off function when Fixed Overcurrent Limit (IOCD1) is detected. ④ EN Voltage VEN t ③ Output Voltage VOUT t ① Output Current IOUT ② IOCD1 IOCD2 Latch-off Normal Current tSS t tBLANK Error FLAG VFLAG t Figure 37. The timing chart with Latch-off when IOUT after Fixed Overcurrent Limit (IOCD1) detection is equal to IOCD2 or higher ① ② ③ ④ When IOUT exceeds the Fixed Overcurrent Limit (IOCD1), IOUT decreases momentarily then becomes IOUT ≥ IOCD2. IOUT increases until it reaches IOCD1. The time it takes for IOUT = IOCD1 (tSS) depends on the setting of Soft Start Function by external resistor R SS (Table 3, 4). When IOUT = IOCD1, Output voltage (VOUT) = Load resistance (RL) × Fixed Overcurrent Limit (IOCD1) When IOUT exceeds the Variable Overcurrent Detection (IOCD2) and the duration exceeds tBLANK, output is latched off and Error FLAG VFLAG is set to Low. When EN is turned OFF, Latch-Off function is released and Error FLAG VFLAG is set to High. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 21/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 2.1 Latch-off due to Fixed Overcurrent Limit (IOCD1) – continued ④ EN Voltage VEN t ③ Output Voltage VOUT t ① Output Current IOUT Latch-off ② IOCD1 IOCD2 Normal Current t tSS tBLANK Error FLAG VFLAG t Figure 38. The timing chart with Latch-off when IOUT after Fixed Overcurrent Limit (IOCD1) detection is less than IOCD2 ① ② ③ ④ When IOUT exceeds the Fixed Overcurrent Limit (IOCD1), IOUT decreases momentarily then becomes IOUT < IOCD2. IOUT increases until it reaches IOCD1. The time it takes for IOUT = IOCD1 (tSS) depends on the setting of Soft Start Function by external resistor R SS (Table 3, 4). When IOUT = IOCD1, Output voltage (VOUT) = Load resistance (RL) × Fixed Overcurrent Limit (IOCD1) When IOUT exceeds the Variable Overcurrent Detection (IOCD2) and the duration exceeds tBLANK, output is latched off and Error FLAG VFLAG is set to Low. When EN is turned OFF, Latch-Off function is released and Error FLAG VFLAG is set to High. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 22/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 2. Overcurrent Protection – continued 2.2 Duration of Fixed Overcurrent Limit (IOCD1) is less than tBLANK Figure 39 and Figure 40 show the timing chart without the Latch-off function when Fixed Overcurrent Limit (IOCD1) is detected. EN Voltage VEN t ③ ④ Output Voltage VOUT t ① Output Current IOUT ② IOCD1 IOCD2 Normal Current tSS t tBLANK Error FLAG VFLAG t Figure 39. The timing chart without Latch-off when IOUT after Fixed Overcurrent Limit (IOCD1) detection is equal to IOCD2 or higher ① ② ③ ④ When IOUT exceeds the Fixed Overcurrent Limit (IOCD1), IOUT decreases momentarily then becomes IOUT ≥ IOCD2. IOUT increases until it reaches IOCD1. The time it takes for IOUT = IOCD1 (tSS) depends on the setting of Soft Start Function by external resistor RSS (Table 3, 4). When IOUT = IOCD1, Output voltage (VOUT) = Load resistance (RL) × Fixed Overcurrent Limit (IOCD1) When the duration where IOUT exceeds the Variable Overcurrent Detection (IOCD2) is less than tBLANK, the output does not latch off. Indicates tBLANK. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 23/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 2.2 Duration of Fixed Overcurrent Limit (IOCD1) is less than tBLANK – continued EN Voltage VEN t ③ ④ Output Voltage VOUT t ① Output Current IOUT ② IOCD1 IOCD2 Normal Current t tSS tBLANK Error FLAG VFLAG t Figure 40. The timing chart without Latch-off when IOUT after Fixed Overcurrent Limit (IOCD1) detection is less than IOCD2 ① ② ③ ④ When IOUT exceeds the Fixed Overcurrent Limit (IOCD1), IOUT decreases momentarily then becomes IOUT < IOCD2. IOUT increases until it reaches IOCD1. The time it takes for IOUT = IOCD1 (tSS) depends on the setting of Soft Start Function by external resistor RSS (Table 3, 4). When IOUT = IOCD1, Output voltage (VOUT) = Load resistance (RL) × Fixed Overcurrent Limit (IOCD1) When the duration where IOUT exceeds the Variable Overcurrent Detection (IOCD2) is less than tBLANK, the output does not latch off. Indicates tBLANK. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 24/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 2. Overcurrent Protection – continued 2.3 Latch-off due to Variable Overcurrent Detection (IOCD2) Figure 41 shows the timing chart of the Latch-off function when Variable Overcurrent Detection (IOCD2) is detected. ③ EN Voltage VEN t ① ② Output Voltage VOUT t Latch-off Output Current IOUT IOCD1 IOCD2 Normal Current t tBLANK Error FLAG VFLAG Figure 41. The timing chart of Latch-off function due to Variable Overcurrent Detection (IOCD2) ① ② ③ t When IOUT exceeds the Variable Overcurrent Detection (IOCD2) but is the Fixed Overcurrent Limit (IOCD1) or less, IOUT is not limited. When IOUT exceeds the Variable Overcurrent Detection (IOCD2) and the duration exceeds tBLANK, output is latched off and Error FLAG is set to Low. When EN is turned OFF, Latch-Off function is released and Error FLAG is set to High. 2.4 Duration of Variable Overcurrent Detection (IOCD2) is less than tBLANK Figure 42 shows the timing chart without the Latch-off function when Variable Overcurrent Detection (IOCD2) is detected. EN Voltage VEN t ① Output Voltage VOUT ② ③ t Output Current IOUT IOCD1 IOCD2 Normal Current t tBLANK Error FLAG VFLAG t Figure 42. The timing chart of Variable Overcurrent Detection (IOCD2) without latch-off function ① ② ③ When IOUT exceeds the Variable Overcurrent Detection (IOCD2) but is the Fixed Overcurrent Limit (IOCD1) or less, IOUT is not limited. When the duration where IOUT exceeds the Variable Overcurrent Detection (IOCD2) is less than tBLANK, the output does not latch off. Indicates tBLANK. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 25/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 2. Overcurrent Protection – continued 2.5 Setting Variable Overcurrent Detection This IC has a Variable Overcurrent Detection (IOCD2) that can be set by an external resistor RLIM. The Variable Overcurrent Detection (IOCD2) value is set by RLIM value as shown below. RLIM should be set from 50 kΩ to 200 kΩ. Table 2. Variable Overcurrent Detection against RLIM Value Variable Overcurrent Detection (IOCD2) [A] RLIM [kΩ] Min Typ Max 50 6.48 9.94 13.42 70 5.53 8.51 11.49 100 3.77 5.80 7.83 120 3.26 5.01 6.77 130 3.01 4.63 6.25 170 2.21 3.41 4.60 200 2.18 3.35 4.52 16 Variable Overcurernt Detection: IOCD2 [A] Max 14 Typ Min 12 10 8 6 4 2 0 0 50 100 150 200 250 RLIM [kΩ] Figure 43. Variable Overcurrent Detection vs RLIM www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 26/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Function Description – continued 3. Setting Soft Start Function This IC has a soft start function that can be set by an external resistor R SS. The output on delay time (tON) and output on slew rate (SRON) set against RSS value at VIN = 12 V and VIN = 24 V is shown below. Set RSS within 15 kΩ to 120 kΩ range. (Note 1) (Note 2) 15 Table 3. Output On Delay Time against RSS Value (Tj = 25 °C) Output ON Delay Time (tON) [ms] VIN = 12 V VIN = 24 V Min Typ Max Min Typ 7.08 11.79 16.51 8.26 13.77 Max 19.27 20 8.48 14.14 19.79 9.98 16.63 23.28 30 11.51 19.18 26.85 13.20 21.99 30.79 40 14.38 23.97 33.56 15.83 26.39 36.95 50 17.14 28.57 40.00 19.74 32.90 46.06 60 19.93 33.21 46.49 23.00 38.34 53.67 100 31.80 53.00 74.20 36.00 60.00 84.00 120 38.43 64.05 89.67 42.78 71.30 99.82 RSS [kΩ] 120 Max Output ON Delay Time: tON [ms] VIN = 12 V, Tj = 25 °C Typ 100 Min 80 60 40 20 0 0 20 40 60 RSS [kΩ] 80 100 120 140 Figure 44. Output ON Delay Time vs RSS (VIN = 12 V, Tj = 25 °C) (Note 1) In the case that VIN is 12 V, the Approximate expression for the output rising edge delay time (tON) set against RSS value is expressed in the equation below. 𝑡𝑂𝑁 (𝑇𝑦𝑝) = 0.50 × 𝑅𝑆𝑆 + 4.32 www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 27/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 3. Setting Soft Start Function – continued 120 Max 100 Output ON Delay Time: tON [ms] VIN = 24 V, Tj = 25 °C Typ Min 80 60 40 20 0 0 20 40 60 RSS [kΩ] 80 100 120 140 Figure 45. Output ON Delay Time vs RSS (VIN = 24 V, Tj = 25 °C) (Note 2) In the case that VIN is 24 V, the Approximate expression for the output rising edge delay time (tON) set against RSS value is expressed in the equation below. 𝑡𝑂𝑁 (𝑇𝑦𝑝) = 0.55 × 𝑅𝑆𝑆 + 5.55 www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 28/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 3. Setting Soft Start Function – continued Table 4. Output ON Slew Rate against RSS Value (Tj = 25 °C) Output ON Slew Rate (SRON) [V/ms] RSS [kΩ] VIN = 12 V VIN = 24 V Min Typ Max Min Typ 0.72 1.21 1.69 1.09 1.82 15 0.61 1.01 1.42 0.94 1.57 20 Max 2.55 2.19 30 0.45 0.74 1.04 0.67 1.11 1.56 40 0.36 0.60 0.84 0.55 0.92 1.28 50 0.30 0.50 0.70 0.46 0.76 1.07 60 0.26 0.43 0.60 0.40 0.66 0.93 100 0.16 0.27 0.38 0.24 0.40 0.56 120 0.13 0.22 0.31 0.20 0.34 0.47 2 Output ON Slew Rate: SRON [V/ms] Max VIN = 12 V, Tj = 25 °C Typ Min 1 0 0 20 40 60 RSS [kΩ] 80 100 120 140 Figure 46. Output ON Slew Rate vs RSS (VIN = 12 V, Tj = 25 °C) Output ON Slew Rate: SRON [V/ms] 3 VIN = 24 V, Tj = 25 °C Max 2 Typ Min 1 0 0 20 40 60 RSS [kΩ] 80 100 120 140 Figure 47. Output ON Slew Rate vs RSS (VIN = 24 V, Tj = 25 °C) www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 29/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Function Description – continued 4. Thermal Shutdown Function, ΔTj Protection Function 4.1 Thermal Shutdown Function (Thermal Shutdown Detection TTSD, Thermal Shutdown Hysteresis TTSDHYS) This IC has a built-in TSD function. When the temperature of the IC reaches Thermal Shutdown Detection (TTSD) = 175 °C (Typ) or more, the output is turned off, and the FLAG outputs Low. Hysteresis (TTSDHYS) is installed for thermal shutdown function, and output automatically returns to normal when chip temperature become 160 °C (Typ) or less. The condition for Latch-Off is when Variable Overcurrent Detection (IOCD2) is reached and the temperature of IC reaches Thermal Shutdown Detection (TTSD) = 175 °C (Typ) or more. The condition for Latch-off Release is the switching of EN voltage (VEN) or IN voltage (VIN). 4.2 ΔTj Protection Function (ΔTj Protection TDTJ, ΔTj Protection Hysteresis TDTJHYS) This IC has a ΔTj protection function. The output is turned off when chip temperature difference (ΔTj) of Power MOS FET (TPOWER-MOS) and control (TAMB) in the IC rises to 105 °C (Typ) or more. Furthermore, hysteresis (TDTJHYS) is installed for ΔTj protection function, and returns to its normal state when ΔTj becomes 75 °C (Typ) or less. Figure 48 is shown that the timing chart of thermal shutdown function and ΔTj protection function with Latch-off function. The condition for Latch-off is when Thermal Shutdown Detection (TTSD) is operated and Variable Overcurrent Detection (IOCD2) is reached. EN I OCD1 I OCD2 I OUT T POWER-MOS Thermal Shutdown Detection T TSD Δ Tj Protection Detect T DTJ TAMB T DTJ - T DTJHYS Tj FLAG ΔTj Protection Operation Latch-off Latch-off Release Figure 48. Timing chart of thermal shutdown function and ΔTj protection function with Latch-off function www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 30/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 4.2 ΔTj Protection Function (ΔTj Protection TDTJ, ΔTj Protection Hysteresis TDTJHYS) – continued Figure 49 is shown that the timing chart of thermal shutdown function and ΔTj protection function without Latch-off function. The condition for without the activation of the Latch-off is when Thermal Shutdown Detection (TTSD) is operated and Variable Overcurrent Detection (IOCD2) is not reached. EN I OCD1 I OCD2 I OUT T POWER-MOS Thermal Shutdown Detection T TSD TTSDHYS Δ Tj Protection Detect TAMB TDTJ - T DTJHYS T DTJ Tj FLAG ΔTj Protection Operation TSD Operation Enable OFF Figure 49. Timing chart of thermal shutdown function and ΔTj protection function without Latch-off function 4.3 The case of connecting the capacitance load At startup, the load connected is used to detect ΔTj protection function. The RSS region where ΔTj protection function is detected versus the output current (IOUT)(Note 3) are shown in Figure 50 to Figure 55 (Note 4). Pay attention to detect ΔTj protection function. (Note 3) IOUT is not including the capacitance load current at startup. (Note 4) This results are used evaluation board of ROHM. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 31/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 4.3 The case of connecting the capacitance load – continued 120 VIN = 12 V, Tj = 25 °C, COUT = 0 ~ 330 μF 105 ΔTj Protection detected SRon(MIN) SRON(MIN) 90 SRon(TYP) SRON(TYP) RSS [kΩ] SRon(MAX) SRON(MAX) 75 60 45 30 15 0 1 2 3 4 5 IOUT [A] Figure 50. ΔTj protection function detection region at startup (VIN = 12 V, COUT = 0 to 330 μF) 120 VIN = 12 V, Tj = 25 °C, COUT = 470 μF 105 ΔTj Protection detected SRon(MIN) SRON(MIN) SRon(TYP) SR (TYP) 90 ON RSS [kΩ] SRon(MAX) SRON(MAX) 75 60 45 30 15 0 3 4 5 IOUT [A] Figure 51. ΔTj protection function detection region at startup (VIN = 12 V, COUT = 470 μF) www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 1 2 32/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 4.3 The case of connecting the capacitance load – continued 120 VIN = 12 V, Tj = 25 °C, COUT = 1000 μF 105 ΔTj Protection detected SRon(MIN) SRON(MIN) 90 SRon(TYP) SRON(TYP) RSS [kΩ] SRon(MAX) SRON(MAX) 75 60 45 30 15 0 1 2 3 4 5 IOUT [A] Figure 52. ΔTj protection function detection region at startup (VIN = 12 V, COUT = 1000 μF) 120 VIN = 24 V, Tj = 25 °C, COUT = 0 μF 105 ΔTj Protection detected SRON(MIN) SRON(MIN) 90 SRon(TYP) SRON(TYP) RSS [kΩ] SRON(MAX) SRon(MAX) 75 60 45 30 15 0 3 4 5 IOUT [A] Figure 53. ΔTj protection function detection region at startup (VIN = 24 V, COUT = 0 μF) www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 1 2 33/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 4.3 The case of connecting the capacitance load – continued 120 VIN = 24 V, Tj = 25 °C, COUT = 100 μF 105 ΔTj Protection detected SRON(MIN) SRon(MIN) 90 SRON(TYP) SRon(TYP) RSS [kΩ] SRON(MAX) SRon(MAX) 75 60 45 30 15 0 1 2 3 4 5 IOUT [A] Figure 54. ΔTj protection function detection region at startup (VIN = 24 V, COUT = 100 μF) 120 VIN = 24 V, Tj = 25 °C, COUT = 220 μF 105 ΔTj Protection detected SRon(MIN) SRON(MIN) 90 SRon(TYP) SRON(TYP) RSS [kΩ] SRon(MAX) SRON(MAX) 75 60 45 30 15 0 3 4 5 IOUT [A] Figure 55. ΔTj protection function detection region at startup (VIN = 24 V, COUT = 220 μF) www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 1 2 34/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 4.3 The case of connecting the capacitance load – continued 120 VIN = 24 V, Tj = 25 °C, COUT = 330 μF 105 ΔTj Protection detected SRon(MIN) SRON(MIN) 90 SRon(TYP) SRON(TYP) RSS [kΩ] SRON(MAX) SRon(MAX) 75 60 45 30 15 0 1 2 3 4 5 IOUT [A] Figure 56. ΔTj protection function detection region at startup (VIN = 24 V, COUT = 330 μF) 120 VIN = 24 V, Tj = 25 °C, COUT = 470 μF 105 ΔTj Protection detected SRON(MIN) SRon(MIN) SR ON(TYP) SRon(TYP) 90 RSS [kΩ] SRON(MAX) SRon(MAX) 75 60 45 30 15 0 3 4 5 IOUT [A] Figure 57. ΔTj protection function detection region at startup (VIN = 24 V, COUT = 470 μF) www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 1 2 35/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 4.3 The case of connecting the capacitance load – continued 120 VIN = 24 V, Tj = 25 °C, COUT = 1000 μF 105 ΔTj Protection detected SRon(MIN) SRON(MIN) SRon(TYP) SRON(TYP) 90 RSS [kΩ] SRON(MAX) SRon(MAX) 75 60 45 30 15 0 3 4 5 IOUT [A] Figure 58. ΔTj protection function detection region at startup (VIN = 24 V, COUT = 1000 μF) www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 1 2 36/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ 5. Output Load is Open When EN is OFF and no load is connected to OUT, output voltage does not fall to GND potential. I/O Equivalence Circuit SS 1 kΩ ILIM 10 kΩ 1 kΩ 12 kΩ SS ILIM 10 kΩ 10 kΩ FLAG 150 Ω EN EN FLAG 10 kΩ 100 kΩ OUT IN OUT Resistance in the figures are typical values. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 37/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Operational Notes 1. Reverse Connection of Power Supply Connecting the power supply in reverse polarity can damage the IC. Take precautions against reverse polarity when connecting the power supply, such as mounting an external diode between the power supply and the IC’s power supply pins. 2. Power Supply Lines Design the PCB layout pattern to provide low impedance supply lines. Furthermore, connect a capacitor to ground at all power supply pins. Consider the effect of temperature and aging on the capacitance value when using electrolytic capacitors. 3. Ground Voltage Ensure that no pins are at a voltage below that of the ground pin at any time, even during transient condition. 4. Ground Wiring Pattern When using both small-signal and large-current ground traces, the two ground traces should be routed separately but connected to a single ground at the reference point of the application board to avoid fluctuations in the small-signal ground caused by large currents. Also ensure that the ground traces of external components do not cause variations on the ground voltage. The ground lines must be as short and thick as possible to reduce line impedance. 5. Recommended Operating Conditions The function and operation of the IC are guaranteed within the range specified by the recommended operating conditions. The characteristic values are guaranteed only under the conditions of each item specified by the electrical characteristics. 6. Inrush Current When power is first supplied to the IC, it is possible that the internal logic may be unstable and inrush current may flow instantaneously due to the internal powering sequence and delays, especially if the IC has more than one power supply. Therefore, give special consideration to power coupling capacitance, power wiring, width of ground wiring, and routing of connections. 7. Testing on Application Boards When testing the IC on an application board, connecting a capacitor directly to a low-impedance output pin may subject the IC to stress. Always discharge capacitors completely after each process or step. The IC’s power supply should always be turned off completely before connecting or removing it from the test setup during the inspection process. To prevent damage from static discharge, ground the IC during assembly and use similar precautions during transport and storage. 8. Inter-pin Short and Mounting Errors Ensure that the direction and position are correct when mounting the IC on the PCB. Incorrect mounting may result in damaging the IC. Avoid nearby pins being shorted to each other especially to ground, power supply and output pin. Inter-pin shorts could be due to many reasons such as metal particles, water droplets (in very humid environment) and unintentional solder bridge deposited in between pins during assembly to name a few. 9. Unused Input Pins Input pins of an IC are often connected to the gate of a MOS transistor. The gate has extremely high impedance and extremely low capacitance. If left unconnected, the electric field from the outside can easily charge it. The small charge acquired in this way is enough to produce a significant effect on the conduction through the transistor and cause unexpected operation of the IC. So unless otherwise specified, unused input pins should be connected to the power supply or ground line. 10. Ceramic Capacitor When using a ceramic capacitor, determine a capacitance value considering the change of capacitance with temperature and the decrease in nominal capacitance due to DC bias and others. 11. Thermal Shutdown Function (TSD) This IC has a built-in thermal shutdown function that prevents heat damage to the IC. Normal operation should always be within the IC’s maximum junction temperature rating. If however the rating is exceeded for a continued period, the junction temperature (Tj) will rise which will activate the TSD function that will turn OFF power output pins. When the Tj falls below the TSD threshold, the circuits are automatically restored to normal operation. Note that the TSD function operates in a situation that exceeds the absolute maximum ratings and therefore, under no circumstances, should the TSD function be used in a set design or for any purpose other than protecting the IC from heat damage. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 38/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Operational Notes – continued 12. Over Current Protection Function (OCP) This IC incorporates an integrated overcurrent protection function that is activated when the load is shorted. This protection function is effective in preventing damage due to sudden and unexpected incidents. However, the IC should not be used in applications characterized by continuous operation or transitioning of the protection function. 13. Active Clamp Operation The IC integrates the active clamp function to internally absorb the reverse energy which is generated when the inductive load is turned off. When the active clamp operates, the thermal shutdown function does not work. Decide a load so that the reverse energy is active clamp tolerance (refer to Figure 28. Active Clamp Energy vs Output Current) or under when inductive load is used. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 39/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Ordering Information B V 1 H A L 4 5 E F J Package EFJ: HTSOP-J8 - E2 Packaging and forming specification E2: Embossed tape and reel Marking Diagram HTSOP-J8 (TOP VIEW) Part Number Marking 1 H A L 4 5 LOT Number Pin 1 Mark www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 40/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Physical Dimension and Packing Information Package Name www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 HTSOP-J8 41/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 BV1HAL45EFJ Revision History Date Revision 19.May.2020 001 28.Jun.2021 002 04.Sep.2023 003 Changes New Release About the title of Figure 50,51,52,53,54,55, correct COUT value. About the title of Figure 51,52, correct VIN value. About the correct value of pull-down resistance at EN Pin in I/O Equivalence Circuit. About the correct value of internal resistance at SS Pin in I/O Equivalence Circuit. www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. TSZ22111 • 15 • 001 42/42 TSZ02201-0G6G1G300060-1-2 04.Sep.2023 Rev.003 Notice Precaution on using ROHM Products 1. Our Products are designed and manufactured for application in ordinary electronic equipment (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you intend to use our Products in devices requiring extremely high reliability (such as medical equipment (Note 1), transport equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (Exclude cases where no-clean type fluxes is used. However, recommend sufficiently about the residue.) ; or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse, is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation depending on ambient temperature. When used in sealed area, confirm that it is the use in the range that does not exceed the maximum junction temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used on a surface-mount products, the flow soldering method must be used on a through hole mount products. If the flow soldering method is preferred on a surface-mount products, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice-PGA-E © 2015 ROHM Co., Ltd. All rights reserved. Rev.004 Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl 2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label A two-dimensional barcode printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since concerned goods might be fallen under listed items of export control prescribed by Foreign exchange and Foreign trade act, please consult with ROHM in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. 2. ROHM shall not have any obligations where the claims, actions or demands arising from the combination of the Products with other articles such as components, circuits, systems or external equipment (including software). 3. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the Products or the information contained in this document. Provided, however, that ROHM will not assert its intellectual property rights or other rights against you or your customers to the extent necessary to manufacture or sell products containing the Products, subject to the terms and conditions herein. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice-PGA-E © 2015 ROHM Co., Ltd. All rights reserved. Rev.004 Datasheet General Precaution 1. Before you use our Products, you are requested to carefully read this document and fully understand its contents. ROHM shall not be in any way responsible or liable for failure, malfunction or accident arising from the use of any ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this document is current as of the issuing date and subject to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the latest information with a ROHM sales representative. 3. The information contained in this document is provided on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate and/or error-free. ROHM shall not be in any way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccuracy or errors of or concerning such information. Notice – WE © 2015 ROHM Co., Ltd. All rights reserved. Rev.001
BV1HAL45EFJ-E2
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
BV1HAL45EFJ-E2 价格&库存
很抱歉,暂时无法提供与“BV1HAL45EFJ-E2”相匹配的价格&库存,您可以联系我们找货
BV1HAL45EFJ-E2
  • 2500+7.707542500+0.99709
  • 5000+7.537685000+0.97512
  • 7500+7.452627500+0.96411
库存:13046
BV1HAL45EFJ-E2
    • 1+9.13680
    • 10+7.88400
    • 30+7.20360
    • 100+6.42600
    • 500+6.08040
    • 1000+5.91840
    库存:2588
    BV1HAL45EFJ-E2
      • 1+8.422691+1.08961
      • 50+6.1987750+0.80191
      • 100+5.68428100+0.73535
      • 300+5.33575300+0.69026
      • 500+5.26937500+0.68168
      • 1000+5.211281000+0.67416
      • 2000+5.186382000+0.67094
      库存:1989
      BV1HAL45EFJ-E2
      • 1+15.344371+1.98503
      • 10+11.2699510+1.45794
      • 25+10.2469225+1.32560
      • 100+9.11886100+1.17967
      • 250+8.58082250+1.11006
      • 500+8.25649500+1.06811
      • 1000+8.216541000+1.06294
      库存:13046
      BV1HAL45EFJ-E2
      • 1+44.09860
      • 10+37.48380
      • 30+30.86900
      • 100+27.56160
      • 500+25.35670
      • 1000+22.04930
