KD2002-DC72A
KD2002-DC72A
    ROHM(罗姆)
    KD2002-DC72A - Thick film thermal printhead(with thermal historical control) - Rohm
KD2002-DC72A 数据手册
Thick film thermal printhead (with thermal historical control) KD2002-DC72A DC72 series has our own internally developed heat-history control function. This product is best suited for applications which require 24 hours operation like factory production lines. Applications High speed label printer High speed bar code printer High speed ticket printer Various high speed terminal printers Features 1) Newly developed thick-film fast response thermal element and driver LSI with the function of thermal history control which is added the future history control are employed for this series. It is possible to print with super high speed of 10 inches / s or 250mm / s. 2) 150km life realized by attributing durable new protection film. 3) New partial glaze construction makes it compatible with the thermal transfer application. Dimensions (Unit : mm) LABEL 65 (4.5) 6.1±0.4 (5) f3H10 Length 4 (Effective Depth 3) 3-M3(Effective Depth 3) 0±0.2 55.5±0.3 55±0.3 DOT #448 56 (Effective Print Width) Dot #448 Dot #1 25±0.5 Max.36 Max.45 Ma x.φ 20 (20.8) (3) 15.3±0.3 7.3±0.3 Max.12 28±0.3 56±0.3 Max.5.5 φ3H10 (Effective Depth 3) #2 #20 #4 #1 #1 CONNECTOR A #19 CONNECTOR B www.rohm.com c ○ 2009 ROHM Co., Ltd. All rights reserved. 1/3 2009.01 - Rev.A 17.8±0.2 KD2002-DC72A Equivalent circuit VH 220µF 35V DOT #448 DOT #1 GND 0.1µF 50V #448 #193 #192 #1 VDD / STB2 / STB1 / RESET LATCH REGISTER CLK DI SHIFT REGISTER DO / LOAD START INC TO EACH IC SEL2 SEL1 TM TM THERMISTOR 30kΩ B: 3950K CONNECTOR DI No. DI DOT No. 448 to 1 / STB No. / STB2 / STB1 DOT No. 448 to 193 192 to 1 Pin assignments CONNECTOR A No. 1 2 3 4 5 6 7 8 9 10 Circuit No. Circuit CONNECTOR B No. 1 2 3 4 Circuit VH (COM) VH (COM) VDD VDD SEL2 SEL1 CLK (CP) NC DI NC INC / LOAD 11 12 13 14 15 16 17 18 19 20 / RESET START DO NC TM TM / STB 2 / STB 1 NC NC GND GND www.rohm.com c ○ 2009 ROHM Co., Ltd. All rights reserved. 2/3 2009.01 - Rev.A KD2002-DC72A Characteristics Parameter Effective printing width Dot pitch Total dot number Average resistance value Applied voltage Applied power Print cycle Maximum number of dots energized simultaneously Maximum clock frequency Maximum roller diameter Running life / pulse life Operating temperature Symbol − − − Rave VH PO SLT − − − − − Typical 56 0.125 448 550 24 0.83 0.490 448 8 φ20.0 150/(1×108) 5 to 45 Unit mm mm dots Ω V W/dot ms dots MHz mm km/pulses °C Data sheets 1.6 1.4 MAXIMUM ENERGY (mJ/dot) SLT : 0.82ms / line 1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 0 OPTICAL DENSITY 1.2 1.0 0.8 0.6 0.4 0.2 0 0.00 0.05 0.10 0.15 0.20 0.25 0.30 0.35 0.40 ENERGY (mJ/dot) Level1 Level2 Level3 Level4 Level5 Level6 0.2 0.4 0.6 0.8 1.0 1.2 1.4 SCANNING LINE TIME (ms/line) Fig.2 Representative density curve Fig.3 Maximum energy curve www.rohm.com c ○ 2009 ROHM Co., Ltd. All rights reserved. 3/3 2009.01 - Rev.A Appendix Notes No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM CO.,LTD. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuel-controller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact your nearest sales office. ROHM Customer Support System www.rohm.com Copyright © 2009 ROHM Co.,Ltd. THE AMERICAS / EUROPE / ASIA / JAPAN Contact us : webmaster @ rohm.co. jp 21 Saiin Mizosaki-cho, Ukyo-ku, Kyoto 615-8585, Japan TEL : +81-75-311-2121 FAX : +81-75-315-0172 Appendix-Rev4.0
KD2002-DC72A
1. 物料型号: - 型号:KD2002-DC72A - 系列:DC72系列
2. 器件简介: - KD2002-DC72A是专为需要24小时连续运行的应用设计的,如工厂生产线。它采用了新开发的厚膜快速响应热敏元件和带有热历史控制功能的驱动LSI,可以实现10英寸/秒或250毫米/秒的超高速打印。
3. 引脚分配: - CONNECTOR A: - 11号引脚:VDD/RESET - 12号引脚:START - 13号引脚:SEL2 - 14号引脚:DO - 15号引脚:SEL1/TM - 16号引脚:CLK (CP) - 17号引脚:STB2 - 18号引脚:DI/STB1 - 19号引脚:INC - 20号引脚:LOAD - CONNECTOR B: - 2号引脚:VH (COM) - 3号引脚:GND - 4号引脚:GND
4. 参数特性: - 有效打印宽度:56毫米 - 点间距:0.125毫米 - 总点数:448点 - 平均电阻值:550欧姆 - 应用电压:24伏 - 应用功率:0.83瓦/点 - 打印周期:0.490毫秒 - 同时激发的最大点数:448点 - 最大时钟频率:8兆赫兹 - 最大辊径:20.0毫米 - 运行寿命/脉冲寿命:150公里/(1×10^8)脉冲 - 操作温度:5至45摄氏度
5. 功能详解: - KD2002-DC72A具有热历史控制功能,可以实现超高速打印,适用于高速标签打印机、条码打印机、票据打印机和各种高速终端打印机。
6. 应用信息: - 适用于需要24小时连续运行的应用,如工厂生产线、高速标签打印机、高速条码打印机、高速票据打印机和各种高速终端打印机。
7. 封装信息: - 文档中提供了尺寸图,单位为毫米,但具体数值未在文本中详细列出,需要查看图形部分以获取详细信息。
KD2002-DC72A 价格&库存
很抱歉,暂时无法提供与“KD2002-DC72A”相匹配的价格&库存,您可以联系我们找货
