LMR324F-GE2
LMR324F-GE2
    ROHM(罗姆)
    SOIC14_208MIL
    LMR324F-GE2
LMR324F-GE2 数据手册
Datasheet Operational Amplifiers Series Ground Sense Low Power General Purpose Operational Amplifiers LMR321G, LMR358xxx, LMR324xxx ●General Description LMR321, LMR358 and LMR324 are single, dual and quad low voltage operational amplifier with output full swing. LMR321, LMR358 and LMR324 are the most effective solutions for applications where low supply current consumption and low voltage operation. ●Applications  Portable equipment  Low voltage application  Active filter ●Key Specifications  Operable with low voltage (single supply): +2.7V to +5.5V  Low Supply Current: LMR321 130µA(Typ.) LMR358 210µA(Typ.) LMR324 410µA(Typ.)  High Slew Rate: 1.0V/µs(Typ.)  Wide Temperature Range: -40°C to +85°C  Low Input Offset Current: 5nA (Typ.)  Low Input Bias Current: 15nA (Typ.) ●Features  Operable with low voltage  Input Ground Sense, Output Full Swing  High open loop voltage gain  Low supply current  Low input offset voltage ●Packages SSOP5 SOP8 SOP-J8 SSOP-B8 TSSOP-B8 MSOP8 TSSOP-B8J SOP14 SOP-J14 SSOP-B14 TSSOP-B14J W(Typ.) x D(Typ.) x H(Max.) 2.90mm x 2.80mm x 1.25mm 5.00mm x 6.20mm x 1.71mm 4.90mm x 6.00mm x 1.65mm 3.00mm x 6.40mm x 1.35mm 3.00mm x 6.40mm x 1.20mm 2.90mm x 4.00mm x 0.90mm 3.00mm x 4.90mm x 1.10mm 8.70mm x 6.20mm x 1.71mm 8.65mm x 6.00mm x 1.65mm 5.00mm x 6.40mm x 1.35mm 5.00mm x 6.40mm x 1.20mm ●Simplified schematic VDD IN+ class AB control IN- OUT VSS Figure 1. Simplified schematic ○Product structure:Silicon monolithic integrated circuit www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・14・001 ○This product is not designed protection against radioactive rays. 1/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Pin Configuration SSOP5 Pin No. +IN 1 5 VDD + - VSS 2 -IN 3 Symbol 1 +IN 2 VSS 3 -IN 4 OUT 5 VDD Pin No. Symbol 1 OUT1 4 OUT SOP8, SOP-J8, SSOP-B8, TSSOP-B8, MSOP8, TSSOP-B8J OUT1 1 -IN1 2 +IN1 3 CH1 - + CH2 8 VDD 2 -IN1 7 OUT2 3 +IN1 4 VSS 6 -IN2 5 +IN2 5 +IN2 6 -IN2 7 OUT2 8 VDD Pin No. Symbol 1 OUT1 + - 4 VSS SOP14, SOP-J14, SSOP-B14, TSSOP-B14J OUT1 1 14 OUT4 2 -IN1 13 -IN4 3 +IN1 -IN1 2 +IN1 3 12 +IN4 4 VDD VDD 4 11 VSS 5 +IN2 10 +IN3 6 -IN2 7 OUT2 8 OUT3 9 -IN3 10 +IN3 +IN2 5 -IN2 6 CH1 - + - + CH2 CH4 + - + - CH3 OUT2 7 9 -IN3 8 OUT3 11 VSS 12 +IN4 13 -IN4 14 OUT4 Package SSOP5 SOP8 SOP-J8 SSOP-B8 TSSOP-B8 MSOP8 LMR321G LMR358F LMR358FJ LMR358FV LMR358FVT LMR358FVM Package TSSOP-B8J SOP14 SOP-J14 SSOP-B14 TSSOP-B14J - LMR358FVJ LMR324F LMR324FJ LMR324FV LMR324FVJ - www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 2/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Ordering Information L M R 3 x x x x x - Package G : SSOP5 F : SOP8, SOP14 FV : SSOP-B8 SSOP-B14 FVM : MSOP8 FJ : SOP-J8 SOP-J14 FVJ : TSSOP-B8J TSSOP-B14J FVT : TSSOP-B8 Part Number LMR321G LMR358xxx LMR324xxx xx Packaging and forming specification E2: Embossed tape and reel (SOP8/SOP-J8/SSOP-B8/TSSOP-B8/ TSSOP-B8J/SOP14/SOP-J14/SSOP-B14 TSSOP-B14J) TR: Embossed tape and reel (SSOP5/MSOP8) ●Line-up Topr -40°C to + 85°C Input type Ground Sense VDD (Min.) Input Offset Voltage (Max.) ±4mV 210µA ±5mV 410µA ±9mV 2.7V www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Supply Current (Typ.) 130µA 3/38 Orderable Part Number Package SSOP5 SOP8 MSOP8 SOP-J8 SSOP-B8 TSSOP-B8 TSSOP-B8J SOP14 SOP-J14 SSOP-B14 TSSOP-B14J Reel of 3000 Reel of 2500 Reel of 3000 Reel of 2500 Reel of 2500 Reel of 3000 Reel of 2500 Reel of 2500 Reel of 2500 Reel of 2500 Reel of 2500 LMR321G-TR LMR358F-E2 LMR358FVM-TR LMR358FJ-E2 LMR358FV-E2 LMR358FVT-E2 LMR358FVJ-E2 LMR324F-E2 LMR324FJ-E2 LMR324FV-E2 LMR324FVJ-E2 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Absolute Maximum Ratings(Ta=25℃) Rating Parameter Symbol Supply Voltage LMR321G VDD-VSS 675 Differential Input Voltage*10 Unit V - *1*9 SOP-J8 - 675 - SOP8 - 690*2*9 - - *3*9 - *3*9 SSOP-B8 Pd LMR324 +7 *1*9 SSOP5 Power dissipation LMR358 625 TSSOP-B8 - 625 - MSOP8 - 587*4*9 - TSSOP-B8J - *4*9 587 SOP-J14 - - 1025*5*9 SSOP-B14 - - 875*6*9 TSSOP-B14J - - 850*7*9 SOP14 - - 562*8*9 mW - Vid VDD - VSS V Input Common-mode Voltage Range Vicm (VSS-0.3) to (VDD+0.3) V Operable with low voltage Vopr +2.7 to +5.5 V Operating Temperature Topr -40 to +85 ℃ Storage Temperature Tstg -55 to +150 ℃ Maximum Junction Temperature Tjmax +150 ℃ Note: Absolute maximum rating item indicates the condition which must not be exceeded. Application of voltage in excess of absolute maximum rating or use out absolute maximum rated temperature environment may cause deterioration of characteristics. *1 To use at temperature above Ta=25℃ reduce 5.4mW/℃. *2 To use at temperature above Ta=25℃ reduce 5.52mW/℃. *3 To use at temperature above Ta=25℃ reduce 5mW/℃. *4 To use at temperature above Ta=25℃ reduce 4.7mW/℃. *5 To use at temperature above Ta=25℃ reduce 8.2mW/℃. *6 To use at temperature above Ta=25℃ reduce 7mW/℃. *7 To use at temperature above Ta=25℃ reduce 6.8mW/℃. *8 To use at temperature above Ta=25℃ reduce 4.5mW/℃. *9 Mounted on a glass epoxy PCB(70mm×70mm×1.6mm). *10 The voltage difference between inverting input and non-inverting input is the differential input voltage. Then input terminal voltage is set to more than VSS. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 4/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Electrical Characteristics ○LMR321 (Unless otherwise specified VDD=+5V, VSS=0V) Parameter Symbol Temperature Range Limits Min. Typ. Unit Condition mV VDD=2.7V to 5V Max. 25℃ - 0.1 4 Full range - - 5 △Vio/△T 25℃ - 3 - µV/℃ - Input Offset Current *11 Iio 25℃ - 5 50 nA - Input Bias Current *11 Ib 25℃ - 15 100 nA - 25℃ - 107 180 Full range - - 260 25℃ - 130 200 Full range - - 280 Input Offset Voltage *11 Input Offset Voltage drift Supply Current *12 Vio IDD Maximum Output Voltage(High) VOH 25℃ Maximum Output Voltage(Low) VOL 25℃ - Av 25℃ 78 110 Vicm 25℃ 0 Common-mode Rejection Ratio CMRR 25℃ Power Supply Rejection Ratio PSRR 25℃ Output Source Current *13 Isource 25℃ Large Signal Voltage Gain Input Common-mode Voltage Range Output Sink Current *13 VDD-0.1 VDD-0.04 - μA VDD=2.7V, Av=0dB VIN=0.95V VDD=5V, Av=0dB VIN=2.1V V RL=2kΩ to 2.5V V RL=2kΩ to 2.5V - dB RL=2kΩ - 4.2 V VSS to VDD-0.8V 65 90 - dB - 65 90 - dB - 6 13 - VSS+0.08 VSS+0.16 - 70 - 30 60 - - 180 - - 1.0 - - 2 - - 1 - mA OUT=0V, short current OUT=VSS+0.4V Isink 25℃ SR 25℃ Unity Band width fT 25℃ Gain Band Width GBW 25℃ - 3 - MHz f=100kHz θ 25℃ - 45 - deg CL=25pF, Av=40dB Gain Margin GM 25℃ - 10 - dB Input Referred Noise Voltage Vn 25℃ - 5.5 - - 39 - THD+N 25℃ - 0.0015 - Slew Rate Phase Margin Total Harmonic Distortion + Noise *11 *12 *13 mA OUT=VDD-0.4V V/μs MHz µVrms OUT=5V, short current CL=25pF CL=25pF, Av=40dB CL=200pF Av=40dB nV/(Hz)1/2 Av=40dB, f=1kHz % OUT=0.4VP-P f=1kHz Absolute value Full range: LMR321: Ta=-40℃ to +85℃ Under the high temperature environment, consider the power dissipation of IC when selecting the output current. When the terminal short circuits are continuously output, the output current is reduced to climb to the temperature inside IC. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 5/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR358 (Unless otherwise specified VDD=+5V, VSS=0V) Parameter Symbol Temperature Range Limits Unit Min. Typ. Max. Condition 25℃ - 0.1 5 Full range - - 5 △Vio/△T 25℃ - 3 - µV/℃ - Input Offset Current *14 Iio 25℃ - 5 50 nA - Input Bias Current *14 Ib 25℃ - 15 100 nA - 25℃ - 210 360 Full range - - 520 25℃ - 210 380 Full range - - 540 VDD-0.04 - Input Offset Voltage *14 Input Offset Voltage drift Supply Current *15 Vio IDD Maximum Output Voltage(High) VOH 25℃ VDD-0.1 Maximum Output Voltage(Low) VOL 25℃ - Av 25℃ 78 110 Vicm 25℃ 0 Common-mode Rejection Ratio CMRR 25℃ Power Supply Rejection Ratio PSRR 25℃ Output Source Current *16 Isource 25℃ Isink 25℃ SR 25℃ Unity Band Width fT 25℃ Gain Band Width GBW Large Signal Voltage Gain Input Common-mode Voltage Range mV VDD=2.7V to 5.0V VDD=2.7V, Av=0dB VIN=0.95V μA VDD=5V, Av=0dB VIN=2.1V V RL=2kΩ to 2.5V V RL=2kΩ to 2.5V - dB RL=2kΩ - 4.2 V VSS to VDD-0.8V 65 90 - dB - 65 90 - dB - VSS+0.08 VSS+0.16 6 13 - - 70 - 30 60 - - 180 - - 1.0 - - 2 - - 1 - 25℃ - 3 - MHz θ 25℃ - 45 - ° Gain Margin GM 25℃ - 10 - dB Input Referred Noise Voltage Vn 25℃ - 5.5 - µVrms THD+N CS Output Sink Current *16 Slew Rate Phase Margin Total Harmonic Distortion + Noise Channel Separation *14 *15 *16 OUT=VDD-0.4V mA OUT=0V, short current OUT=VSS+0.4V mA OUT=5V, short current V/μs CL=25pF CL=25F, Av=40dB MHz nV/(Hz) CL=200pF f=100kHz CL=25pF, Av=40dB - 1/2 Av=40dB - 39 - Av=40dB, f=1kHz 25℃ - 0.0015 - % OUT=0.4VP-P f=1kHz 25℃ - 100 - dB Av=40dB Absolute value Full range: LMR358: Ta=-40℃ to +85℃ Under the high temperature environment, consider the power dissipation of IC when selecting the output current. When the terminal short circuits are continuously output, the output current is reduced to climb to the temperature inside IC. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 6/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR324 (Unless otherwise specified VDD=+5V, VSS=0V) Parameter Symbol Temperature Range Limits Unit Min. Typ. Max. Condition 25℃ - 1.0 9 Full range - - 9 △Vio/△T 25℃ - 3 - µV/℃ - Input Offset Current *17 Iio 25℃ - 5 50 nA - Input Bias Current *17 Ib 25℃ - 15 100 nA - 25℃ - 410 720 Full range - - 880 25℃ - 410 800 Full range - - 900 Input Offset Voltage *17 Input Offset Voltage drift Supply Current *18 Vio IDD Maximum Output Voltage(High) VOH 25℃ Maximum Output Voltage(Low) VOL 25℃ - Av 25℃ 78 110 Vicm 25℃ 0 Common-mode Rejection Ratio CMRR 25℃ Power Supply Rejection Ratio PSRR 25℃ Output Source Current *19 Isource 25℃ Isink 25℃ SR 25℃ fT 25℃ GBW Large Signal Voltage Gain Input Common-mode Voltage Range VDD-0.1 VDD-0.04 - mV VDD=2.7V to 5.0V VDD=2.7V, Av=0dB VIN=0.95V μA VDD=5V, Av=0dB VIN=2.1V V RL=2kΩ to 2.5V V RL=2kΩ to 2.5V - dB RL=2kΩ - 4.2 V VSS to VDD-0.8V 65 90 - dB - 65 90 - dB - VSS+0.08 VSS+0.16 6 13 - - 70 - 30 60 - - 180 - - 1.0 - - 2 - - 1 - 25℃ - 3 - MHz f=100kHz θ 25℃ - 45 - deg CL=25pF, Av=40dB Gain Margin GM 25℃ - 10 - dB Input Referred Noise Voltage Vn 25℃ - 5.5 - µVrms THD+N CS Output Sink Current *19 Slew Rate Unity Gain Frequency Gain Band width Phase Margin Total Harmonic Distortion + Noise Channel Separation *17 *18 *19 OUT=VDD-0.4V mA OUT=0V, short current OUT=VSS+0.4V mA OUT=5V, short current V/μs CL=25pF CL=25pF, Av=40dB MHz CL=200pF - 1/2 nV/(Hz) Av=40dB - 39 - Av=40dB, f=1kHz 25℃ - 0.0015 - % OUT=0.4VP-P f=1kHz 25℃ - 100 - dB Av=40dB Absolute value Full range: LMR324: Ta=-40℃ to +85℃ Under the high temperature environment, consider the power dissipation of IC when selecting the output current. When the terminal short circuits are continuously output, the output current is reduced to climb to the temperature inside IC. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 7/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx Description of electrical characteristics Described here are the terms of electric characteristics used in this datasheet. Items and symbols used are also shown. Note that item name and symbol and their meaning may differ from those on another manufacture’s document or general document. 1. Absolute maximum ratings Absolute maximum rating item indicates the condition which must not be exceeded. Application of voltage in excess of absolute maximum rating or use out of absolute maximum rated temperature environment may cause deterioration of characteristics. 1.1 Power supply voltage (VDD/VSS) Indicates the maximum voltage that can be applied between the positive power supply terminal and negative power supply terminal without deterioration or destruction of characteristics of internal circuit. 1.2 Differential input voltage (Vid) Indicates the maximum voltage that can be applied between non-inverting terminal and inverting terminal without deterioration and destruction of characteristics of IC. 1.3 Input common-mode voltage range (Vicm) Indicates the maximum voltage that can be applied to non-inverting terminal and inverting terminal without deterioration or destruction of characteristics. Input common-mode voltage range of the maximum ratings not assures normal operation of IC. When normal Operation of IC is desired, the input common-mode voltage of characteristics item must be followed. 1.4 Power dissipation (Pd) Indicates the power that can be consumed by specified mounted board at the ambient temperature 25℃(normal temperature). As for package product, Pd is determined by the temperature that can be permitted by IC chip in the package (maximum junction temperature) and thermal resistance of the package. 2.Electrical characteristics item 2.1 Input offset voltage (Vio) Indicates the voltage difference between non-inverting terminal and inverting terminal. It can be translated into the input voltage difference required for setting the output voltage at 0 V. 2.2 Input offset voltage drift (△Vio/△T) Denotes the ratio of the input offset voltage fluctuation to the ambient temperature fluctuation. 2.3 Input offset current (Iio) Indicates the difference of input bias current between non-inverting terminal and inverting terminal. 2.4 Input bias current (Ib) Indicates the current that flows into or out of the input terminal. It is defined by the average of input bias current at non-inverting terminal and input bias current at inverting terminal. 2.5 Circuit current (IDD) Indicates the IC current that flows under specified conditions and no-load steady status. 2.6 Maximum Output Voltage(High) / Maximum Output Voltage(Low) (VOH/VOL) Indicates the voltage range that can be output by the IC under specified load condition. It is typically divided into maximum output voltage High and low. Maximum output voltage high indicates the upper limit of output voltage. Maximum output voltage low indicates the lower limit. 2.7 Large signal voltage gain (Av) Indicates the amplifying rate (gain) of output voltage against the voltage difference between non-inverting terminal and inverting terminal. It is normally the amplifying rate (gain) with reference to DC voltage. Av = (Output voltage fluctuation) / (Input offset fluctuation) 2.8 Input common-mode voltage range (Vicm) Indicates the input voltage range where IC operates normally. 2.9 Common-mode rejection ratio (CMRR) Indicates the ratio of fluctuation of input offset voltage when in-phase input voltage is changed. It is normally the fluctuation of DC. CMRR = (Change of Input common-mode voltage)/(Input offset fluctuation) 2.10 Power supply rejection ratio (PSRR) Indicates the ratio of fluctuation of input offset voltage when supply voltage is changed. It is normally the fluctuation of DC. PSRR= (Change of power supply voltage)/(Input offset fluctuation) 2.11 Output source current/ output sink current (Isource/Isink) The maximum current that can be output under specific output conditions, it is divided into output source current and output sink current. The output source current indicates the current flowing out of the IC, and the output sink current the current flowing into the IC. 2.12 Channel separation (CS) Indicates the fluctuation of output voltage with reference to the change of output voltage of driven channel. 2.13 Slew Rate (SR) SR is a parameter that shows movement speed of operational amplifier. It indicates rate of variable output voltage as unit time. 2.14 Unity gain frequency (fT) Indicates a frequency where the voltage gain of Op-Amp is 1. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 8/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx 2.15 Gain Band Width (GBW) Indicates to multiply by the frequency and the gain where the voltage gain decreases 6dB/octave. 2.16 Phase Margin (θ) Indicates the margin of phase from 180 degree phase lag at unity gain frequency. 2.17 Gain Margin (GM) Indicates the difference between 0dB and the gain where operational amplifier has 180 degree phase delay. 2.18 Total harmonic distortion + Noise (THD+N) Indicates the fluctuation of input offset voltage or that of output voltage with reference to the change of output voltage of driven channel. 2.19 Input referred noise voltage (Vn) Indicates a noise voltage generated inside the operational amplifier equivalent by ideal voltage source connected in series with input terminal. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 9/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Typical Performance Curves ○LMR321 160 85℃ 140 1000 800 SUPPLY CURRENT [μA] POWER DISSIPATION [mW] . 1200 LMR321G 600 400 120 100 200 25℃ -40℃ 80 60 40 20 0 85 0 25 50 75 100 AMBIENT TEMPERATURE [℃] 0 2 125 Figure 2. Derating curve 3 4 5 SUPPLY VOLTAGE [V] 6 Figure 3. Supply Current – Supply Voltage 6 160 5.5V OUTPUT VOLTAGE HIGH [V] SUPPLY CURRENT [uA] 140 120 5.0V 100 2.7V 80 60 40 20 0 -50 5 85℃ 4 25℃ 3 -40℃ 2 1 0 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 100 2 3 4 5 SUPPLY VOLTAGE [V] 6 Figure 5. Maximum Output Voltage(High) – Supply Voltage (RL=2kΩ) Figure 4. Supply Current – Ambient Temperature (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 10/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR321 80 8 OUTPUT VOLTAGE LOW [mV] OUTPUT VOLTAGE HIGH [V] 70 5.5V 6 5.0V 4 2 2.7V 85℃ 60 50 40 25℃ 30 -40℃ 20 10 0 0 -5 0 -2 5 0 25 50 75 AM BIE NT TE MP ERA TURE [℃ ] 2 1 00 3 4 5 SUPPLY VOLTAGE [V] Figure 6. Maximum Output Voltage(High) – Ambient Temperature (RL=2kΩ) Figure 7. Maximum Output Voltage(Low) – Supply Voltage (RL=2kΩ) 80 100 OUTPUT VOLTAGE LOW [mV] OUTPUT SOURCE CURRENT [mA] 5.5V 70 60 50 5.0V 40 2.7V 30 20 10 0 -50 6 -40℃ 80 25℃ 60 85℃ 40 20 0 -25 0 25 50 75 A MB IENT TEMPE RATURE [℃ ] 0 100 1 2 3 4 5 OUTPUT VOLTAGE [V] Figure 8. Maximum Output Voltage(Low) – Ambient Temperature (RL=2kΩ) Figure 9. Output Source Current – Output Voltage (VDD=5V) (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 11/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx 18 2 00 16 1 80 OUTPUT SINK CURRENT [mA] OUTPUT SOURCE CURRENT [ mA] ○LMR321 14 12 5.0V 5.5V 10 8 6 2.7V 4 1 60 85℃ 1 40 1 20 1 00 80 60 40 20 2 0 -50 0 -25 0 25 50 75 A MB IENT TEMPE RATURE [℃] 0 100 1 2 3 4 OUTPUT VO LTAG E [V ] 5 Figure 11. Output Sink Current – Output Voltage (VDD=5V) Figure 10. Output Source Current – Ambient Temperature (OUT=VDD-0.4V) 10.0 INPUT OFFSET VOLTAGE [mV] 1 00 OUTPUT SINK CURRENT [mA] 25℃ -40℃ 80 5.5V 5.0V 60 40 2.7V 20 0 7.5 5.0 -40℃ 25℃ 2.5 0.0 85℃ -2.5 -5.0 -7.5 -10.0 -50 -2 5 0 25 50 75 2 100 3 AMBI ENT TEMPERA TURE [℃ ] 4 5 6 SUPPLY VOLTAGE [V] Figure 13. Input Offset Voltage – Supply Voltage (Vicm= VDD, OUT= 0.1V) Figure 12. Output Sink Current – Ambient Temperature (OUT=VSS+0.4V) (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 12/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR321 10.0 6 INPUT OFFSET VOLTAGE [mV] INPUT OFFSET VOLTAGE [mV] 7.5 5.0 5.5V 2.5 0.0 2.7V 5.0V -2.5 -5.0 -7.5 4 -40℃ 2 0 85℃ -2 -4 -6 -10.0 -50 -25 0 25 50 75 AMBIENT TE MPERATURE [℃] -1 100 Figure 14. Input Offset Voltage – Ambient Temperature (Vicm= VDD, OUT= 0.1V) 0 1 2 3 INPUT VOLTAGE [V] 4 5 Figure 15. Input Offset Voltage – Input Voltage (VDD=5V) 160 LARGE SIGNAL VOLTAGE GAIN [dB] 160 LARGE SIGNAL VOLTAGE GAIN [dB] 25℃ 140 120 85℃ 100 25℃ -40℃ 80 60 140 120 5.5V 100 2.7V 3.0V 80 60 2 3 4 5 6 SUPPLY VOLTAGE [V] -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 100 Figure 16. Large Signal Voltage Gain – Supply Voltage Figure 17. Large Signal Voltage Gain – Ambient Temperature (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 13/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx COMMON MODE REJECTION RATIO [dB] . . COMMON MODE REJECTION RATIO [dB] ○LMR321 120 85℃ 100 80 25℃ 60 -40℃ 40 20 0 2 3 4 5 SUPPLY VOLTAGE [V] 5.0V 80 5.5V 60 2.7V 40 20 0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 100 Figure 19. Common Mode Rejection Ratio – Ambient Temperature (VDD=3V) 2.0 140 120 SLEW RATE L-H [V/µs] . 100 6 Figure 18. Common Mode Rejection Ratio – Supply Voltage (VDD=5V) POWER SUPPLY R EJECTION RATIO [dB] 120 100 80 60 40 1.5 5.5V 5.0V 1.0 2.7V 0.5 20 0 -50 0.0 -25 0 25 50 75 100 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] AMBIENT TEMPERATURE [℃] Figure 20. Power Supply Rejection Ratio – Ambient Temperature 100 Figure 21. Slew Rate L-H – Ambient Temperature (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 14/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR321 60 2.0 180 Phase 150 40 5.5V 1.0 5.0V 2.7V 30 90 20 60 10 30 0.5 0.0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃ ] 0 0 1.E+02 1.E+04 1.E+05 1.E+06 1.E+07 102 1.E+03 103 104 105 106 107 100 FREQUENCY [Hz] Figure 23. Voltage Gain・Phase – Frequency Figure 22. Slew Rate H-L – Ambient Temperature 1 800 EQUIVALENT INPUT NOISE VOLTAGE . [nV/√Hz] TOTAL HARMONIC DISTORTION [%] 120 Gain PHASE [deg] 1.5 GAIN[dB] SLEW RATE H-L [V/µs] 50 0.1 20Hz 0.01 20kHz 0.001 1kHz 0.0001 0.01 700 600 500 400 300 200 100 0 0.1 1 OUTPUT VOLTAGE [Vrms] 1 10 Figure 24. Total Harmonic Distortion-Output Voltage (VDD/VSS=+2.5V/-2.5V, Av=0dB, RL=2kΩ, DIN-AUDIO, Ta=25℃) 10 100 1000 FREQUENCY [Hz] 10000 Figure 25. Input Referred Noise Voltage-Frequency (VDD/VSS=+2.5V/-2.5V, Av=0dB, Ta=25℃) (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 15/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR358 400 350 1000 SUPPLY CURRENT [µA] POWER DISSIPATION [mW] . 1200 LMR358F 800 LMR358FJ LMR358FV/FVT 600 LMR358FVM/FVJ 400 85℃ 300 250 200 25℃ -40℃ 150 100 200 50 0 0 85 25 50 75 100 AMBIENT TEMPERATURE [℃] 0 2 125 Figure 26. Derating curve 6 Figure 27. Supply Current – Supply Voltage 6 400 350 5.5V OUTPUT VOLTAGE HIGH [V] SUPPLY CURRENT [µA] 3 4 5 SUPPLY VOLTAGE [V] 300 250 5.0V 200 2.7V 150 100 50 5 85℃ 4 25℃ 3 -40℃ 2 1 0 0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 2 100 3 4 5 6 SUPPLY VOLTAGE [V] Figure 29. Maximum Output Voltage(High) – Supply Voltage (RL=2kΩ) Figure 28. Supply Current – Ambient Temperature (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 16/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR358 120 OUTPUT VOLTAGE LOW [mV] OUTPUT VOLTAGE HIGH [V] 6 5 5.5V 4 5.0V 3 2 2.7V 1 100 85℃ 80 25℃ 60 -40℃ 40 20 0 0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 2 100 3 4 5 SUPPLY VOLTAGE [V] Figure 30. Maximum Output Voltage(High) – Ambient Temperature (RL=2kΩ) Figure 31. Maximum Output Voltage(Low) – Supply Voltage (RL=2kΩ) 100 OUTPUT SOURCE CURRENT [mA] OUTPUT VOLTAGE LOW [mV] 120 100 2.7V 80 5.0V 5.5V 60 40 20 0 -50 6 25℃ -40℃ 80 60 85℃ 40 20 0 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 0 100 1 2 3 4 5 OUTPUT VOLTAGE [V] Figure 32. Maximum Output Voltage(Low) – Ambient Temperature (RL=2kΩ) Figure 33. Output Source Current – Output Voltage (VDD=5V) (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 17/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR358 180 18 OUTPUT SINK CURRENT [mA] OUTPUT SOURCE CURRENT [mA] 20 5.5V 16 14 12 5.0V 10 8 6 2.7V 4 2 0 -50 160 25℃ -40℃ 140 120 85℃ 100 80 60 40 20 0 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 100 0 80 5 2.0 70 INPUT OFFSET VOLTAGE [mV] OUTPUT SINK CURRENT [mA] 2 3 4 OUTPUT VOLTAGE [V] Figure 35. Output Sink Current – Output Voltage (VDD=5V) Figure 34. Output Source Current – Ambient Temperature (OUT=VDD-0.4V) 5.5V 5.0V 60 50 40 30 2.7V 20 10 0 -50 1 1.8 1.6 1.4 -40℃ 1.2 25℃ 1.0 85℃ 0.8 0.6 0.4 0.2 0.0 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 2 100 3 4 5 6 SUPPLY VOLTAGE [V] Figure 37. Input Offset Voltage – Supply Voltage (Vicm= VDD, OUT= 0.1V) Figure 36. Output Sink Current – Ambient Temperature (OUT=VSS+0.4V) (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 18/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR358 6 1.8 INPUT OFFSET VOLTAGE [mV] INPUT OFFSET VOLTAGE [mV] 2.0 1.6 1.4 5.0V 1.2 5.5V 1.0 0.8 2.7V 0.6 0.4 0.2 4 -40℃ 2 0 85℃ -2 -4 -6 0.0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] -1 100 Figure 38. Input Offset Voltage – Ambient Temperature (Vicm= VDD, OUT= 0.1V) 160 140 85℃ 25℃ 120 100 -40℃ 80 60 0 1 2 3 INPUT VOLTAGE [V] 4 5 Figure 39. Input Offset Voltage – Input Voltage (VDD=5V) LARGE SIGNAL VOLTAGE GAIN [dB] . LARGE SIGNAL VOLTAGE GAIN [dB] . 25℃ 160 140 5.5V 120 100 2.7V 5.0V 80 60 2 3 4 5 SUPPLY VOLTAGE [V] 6 -50 Figure 40. Large Signal Voltage Gain – Supply Voltage -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 100 Figure 41. Large Signal Voltage Gain – Ambient Temperature (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 19/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx 120 COMMON MODE REJECTION RATIO [dB] . COMMON MODE REJECTION RATIO [dB] . ○LMR358 120 -40℃ 100 100 85℃ 25℃ 80 60 40 20 0 2 3 4 5 SUPPLY VOLTAGE [V] 5.0V 80 2.7V 60 40 20 0 6 -50 Figure 42. Common Mode Rejection Ratio – Supply Voltage (VDD=5V) -25 0 25 50 75 AMBIENT TEMPERATURE [ ℃] 100 Figure 43. Common Mode Rejection Ratio – Ambient Temperature (VDD=3V) 2.0 140 120 SLEW RATE L-H [V/µs] POWER SUPPLY REJECTION RATIO [dB] 5.5V 100 80 60 40 1.5 5.5V 5.0V 1.0 2.7V 0.5 20 0 -50 0.0 -25 0 25 50 75 -50 100 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] AMBIENT TEMPERATURE [℃] Figure 44. Power Supply Rejection Ratio – Ambient Temperature 100 Figure 45. Slew Rate L-H – Ambient Temperature (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 20/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR358 60 2.0 180 Phase 150 40 1.0 5.0V 2.7V 0.5 120 Gain 30 90 20 60 10 30 PHASE [deg] 5.5V GAIN[dB] SLEW RATE H-L [V/µs] 50 1.5 0.0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 0 0 1.E+02 1.E+07 102 1.E+03 103 1.E+04 104 1.E+05 105 1.E+06 106 107 100 FREQUENCY [Hz] Figure 47. Voltage Gain・Phase – Frequency Figure 46. Slew Rate H-L – Ambient Temperature 800 EQUIVALENT INPUT NOISE VOLTAGE . [nV/√Hz] TOTAL HARMONIC DISTORTION [%] 1 0.1 20Hz 0.01 20kHz 0.001 1kHz 700 600 500 400 300 200 100 0 0.0001 0.01 0.1 1 OUTPUT VOLTAGE [Vrms] 1 10 Figure 48. Total Harmonic Distortion-Output Voltage (VDD/VSS=+2.5V/-2.5V, Av=0dB, RL=2kΩ, DIN-AUDIO, Ta=25℃) 10 100 1000 FREQUENCY [Hz] 10000 Figure 49. Input Referred Noise Voltage-Frequency (VDD/VSS=+2.5V/-2.5V, Av=0dB, Ta=25℃) (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 21/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR324 600 1200 1000 SUPPLY CURRENT [µA] POWER DISSIPATION [mW] . LMR324FJ LMR324FV LMR324FVJ 800 600 400 LMR324F 500 400 85℃ 25℃ -40℃ 300 200 100 200 0 0 85 0 25 50 75 100 AMBIENT TEMPERATURE [℃] 2 125 600 6 500 5 5.5V 400 5.0V 2.7V 300 6 Figure 51. Supply Current – Supply Voltage OUTPUT VOLTAGE HIGH [V] SUPPLY CURRENT [µA] Figure 50. Derating curve 3 4 5 SUPPLY VOLTAGE [V] 200 100 85℃ 4 3 25℃ -40℃ 2 1 0 0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 2 100 3 4 5 SUPPLY VOLTAGE [V] 6 Figure 53. Maximum Output Voltage(High) – Supply Voltage (RL=2 kΩ) Figure 52. Supply Current – Ambient Temperature (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 22/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR324 120 OUTPUT VOLTAGE LOW [mV] OUTPUT VOLTAGE HIGH [V] 6 5 5.5V 5.0V 4 3 2 2.7V 1 100 85℃ 80 25℃ 60 -40℃ 40 20 0 0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 2 100 3 4 5 SUPPLY VOLTAGE [V] Figure 54. Maximum Output Voltage(High) – Ambient Temperature (RL=2kΩ) Figure 55. Maximum Output Voltage(Low) – Supply Voltage (RL=2kΩ) 100 100 OUTPUT SOURCE CURRENT [mA] OUTPUT VOLTAGE LOW [mV] 120 2.7V 80 5.5V 5.0V 60 40 20 0 -50 6 25℃ -40℃ 80 60 40 85℃ 20 0 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 0 100 1 2 3 4 5 OUTPUT VOLTAGE [V] Figure 56. Maximum Output Voltage(Low) – Ambient Temperature (RL=2kΩ) Figure 57. Output Source Current – Output Voltage (VDD=5V) (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 23/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR324 200 180 16 OUTPUT SINK CURRENT [mA] OUTPUT SOURCE CURRENT [mA] 18 5.5V 14 12 10 5.0V 8 6 2.7V 4 2 0 -50 25℃ 160 -40℃ 140 120 85℃ 100 80 60 40 20 0 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 0 100 3 4 5 Figure 59. Output Sink Current – Output Voltage (VDD=5V) 1.0 80 0.8 70 INPUT OFFSET VOLTAGE [mV] OUTPUT SINK CURRENT [mA] 2 OUTPUT VOLTAGE [V] Figure 58. Output Source Current – Ambient Temperature (OUT=VDD-0.4V) 5.5V 60 5.0V 50 40 30 2.7V 20 10 0 -50 1 0.6 0.4 0.2 85℃ 25℃ 0.0 -0.2 -0.4 -40℃ -0.6 -0.8 -1.0 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 2 100 3 4 5 6 SUPPLY VOLTAGE [V] Figure 61. Input Offset Voltage – Supply Voltage (Vicm= VDD, OUT= 0.1V) Figure 60. Output Sink Current – Ambient Temperature (OUT=VSS+0.4V) (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 24/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR324 6.0 0.8 INPUT OFFSET VOLTAGE [mV] INPUT OFFSET VOLTAGE [mV] 1.0 0.6 0.4 0.2 0.0 2.7V -0.2 -0.4 5.5V 5.0V -0.6 -0.8 4.0 85℃ 25℃ 2.0 0.0 -40℃ -2.0 -4.0 -6.0 -1.0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] -1 100 160 140 25℃ 120 100 -40℃ 85℃ 80 60 2 3 4 5 SUPPLY VOLTAGE [V] 1 2 3 INPUT VOLTAGE [V] 4 5 Figure 63. Input Offset Voltage – Input Voltage (VDD=5V) LARGE SIGNAL VOLTAGE GAIN [dB] . LARGE SIGNAL VOLTAGE GAIN [dB] . Figure 62. Input Offset Voltage – Ambient Temperature (Vicm= VDD, OUT= 0.1V) 0 6 160 140 5.5V 120 100 2.7V 80 60 -50 Figure 64. Large Signal Voltage Gain – Supply Voltage 5.0V -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 100 Figure 65. Large Signal Voltage Gain – Ambient Temperature (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 25/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR324 120 COMMON MODE REJECTION RATIO [dB] . COMMON MODE REJECTION RATIO [dB] . 120 100 100 85℃ 80 25℃ -40℃ 60 40 20 0 2 3 4 5 SUPPLY VOLTAGE [V] 5.0V 80 2.7V 60 40 20 0 6 -50 Figure 66. Common Mode Rejection Ratio – Supply Voltage (VDD=5V) -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 100 Figure 67. Common Mode Rejection Ratio – Ambient Temperature (VDD=3V) 2.0 140 120 SLEW RATE L-H [V/µs] POWER SUPPLY REJECTION RATIO [dB] 5.5V 100 80 60 40 5.5V 1.5 5.0V 1.0 2.7V 0.5 20 0 -50 0.0 -25 0 25 50 75 100 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] AMBIENT TEMPERATURE [℃] Figure 68. Power Supply Rejection Ratio – Ambient Temperature 100 Figure 69. Slew Rate L-H – Ambient Temperature (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 26/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○LMR324 60 2.0 180 Phase 150 40 1.0 5.0V 2.7V 0.5 120 Gain 30 90 20 60 10 30 PHASE [deg] 5.5V GAIN[dB] SLEW RATE H-L [V/µs] 50 1.5 0.0 -50 -25 0 25 50 75 AMBIENT TEMPERATURE [℃] 0 0 103 104 105 106 107 102 1.E+02 1.E+03 1.E+04 1.E+05 1.E+06 1.E+07 100 FREQUENCY [Hz] Figure 71. Voltage Gain・Phase – Frequency Figure 70. Slew Rate H-L – Ambient Temperature 800 EQUIVALENT INPUT NOISE VOLTAGE . [nV/√Hz] TOTAL HARMONIC DISTORTION [%] 1 0.1 20Hz 0.01 20kHz 0.001 1kHz 0.0001 0.01 700 600 500 400 300 200 100 0 0.1 1 OUTPUT VOLTAGE [Vrms] 1 10 Figure 72. Total Harmonic Distortion-Output Voltage (VDD/VSS=+2.5V/-2.5V, Av=0dB, RL=2kΩ, DIN-AUDIO, Ta=25℃) 10 100 1000 FREQUENCY [Hz] 10000 Figure 73. Input Referred Noise Voltage-Frequency (VDD/VSS=+2.5V/-2.5V, Av=0dB, Ta=25℃) (*)The data above is measurement value of typical sample, it is not guaranteed. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 27/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Application Information NULL method condition for Test Circuit 1 VDD, VSS, EK, Vicm Unit:V Parameter Input Offset Voltage VF S1 S2 S3 VDD VSS EK Vicm Calculation VF1 ON ON OFF 5 0 -2.5 2.1 1 ON ON ON 5 0 2.1 2 ON ON OFF 5 0 -1.5 ON ON OFF 0 -2.9 VF2 Large Signal Voltage Gain VF3 Common-mode Rejection Ratio (Input Common-mode Voltage Range) Power Supply Rejection Ratio - Calculation- 1. Input Offset Voltage (Vio) VF4 VF5 VF6 VF7 Vio = |VF1| 3 5 -1.5 -3.5 0 1.8 4 3 4 [V] 1+RF/RS 2. Large Signal Voltage Gain(Av) 2 × (1+RF/RS) Av = 20Log [dB] |VF2-VF3| 3. Common-mode Rejection Ratio (CMRR) CMRR= 20Log 1.8 × (1+RF/RS) [dB] |VF4 - VF5| 4. Power Supply Rejection Ratio (PSRR) PSRR = 20Log 3.8 × (1+ RF/RS) [dB] |VF6 - VF7| 0.1µF RF=50kΩ 0.01µF 500kΩ SW1 VDD EK RS=50Ω 15V Vo Ri=1MΩ 500kΩ 0.015µF 0.015µF DUT NULL SW3 RS=50Ω 1000pF Ri=1MΩ VF RL Vicm SW2 50kΩ VRL VSS -15V Figure 74. Test circuit 1 (one channel only) www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 28/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx Switch Condition for Test Circuit 2 SW No. SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW8 SW9 SW10 SW11 SW12 SW13 SW14 Supply Current OFF OFF OFF ON OFF ON OFF OFF OFF OFF OFF OFF OFF OFF Maximum Output Voltage(High) OFF OFF ON OFF OFF ON OFF OFF OFF OFF OFF ON OFF Maximum Output Voltage(Low) OFF OFF ON OFF OFF ON OFF OFF OFF OFF OFF OFF ON OFF Output Source Current OFF OFF ON OFF OFF ON OFF OFF OFF OFF OFF OFF OFF ON Output Sink Current OFF OFF ON OFF OFF ON OFF OFF OFF OFF OFF OFF OFF ON Slew Rate OFF OFF OFF Gain Bandwidth Product OFF ON OFF OFF ON Equivalent Input Noise Voltage ON OFF OFF OFF ON ON OFF OFF OFF ON ON ON ON OFF OFF OFF OFF ON OFF OFF ON ON OFF OFF OFF OFF ON OFF OFF OFF OFF ON OFF OFF OFF Input voltage VH VL t Input wave Output voltage 90% SR=ΔV/Δt VH C ΔV 10% VL Δt t Output wave Figure 75. Test Circuit 2 (each Op-Amp) Figure 76. Slew Rate Input Waveform R2=100kΩ R2=100kΩ VDD VDD R1=1kΩ R1=1kΩ V R1//R2 VIN ~ VSS OUT1 =1Vrms V OUT2 R1//R2 ~ VSS CS=20Log 100×OUT1 OUT2 Figure 77. Test circuit 3(Channel Separation) www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 29/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx Application example ○Voltage Follower Voltage gain is 0 dB. This circuit controls output voltage (OUT) equal input voltage (IN), and keeps OUT with stable because of high input impedance and low output impedance. OUT is shown next expression. OUT=IN VDD OUT IN VSS Figure 78. Voltage follower ○Inverting amplifier R2 VDD R1 IN OUT R1//R2 Figure 79. For inverting amplifier, IN is amplified by voltage gain decided R1 and R2, and phase reversed voltage is output. OUT is shown next expression. OUT=-(R2/R1)・IN Input impedance is R1. VSS Inverting amplifier ○Non-inverting amplifier R1 R2 VDD OUT IN For non-inverting amplifier, IN is amplified by voltage gain decided R1 and R2, and phase is same with Vin. OUT is shown next expression. OUT=(1+R2/R1)・IN This circuit performes high input impedance because Input impedance is operational amplifier’s input Impedance. VSS Figure 80. Non-inverting amplifier www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 30/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ○Adder circuit R3 VDD R1 IN1 IN2 OUT R2 Adder circuit output the voltage that added up Input voltage. A phase of the output voltage turns over, because non-inverting circuit is used. OUT is shown next formula. OUT = -R3(IN1/R1+IN2/R2) When three input voltage is as above, it connects with input through resistance like R1 and R2. VSS Figure 81. Adder circuit ○Differential amplifier R2 VDD R1 IN1 OUT R3 Differential amplifier output the voltage that amplified a difference of input voltage. In the case of R1=R3=Ra, R2=R4=Rb OUT is shown next formula. OUT = -Rb/Ra(IN1-IN2) IN2 R4 VSS Figure 82. Differential amplifier www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 31/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Power Dissipation Power dissipation (total loss) indicates the power that can be consumed by IC at Ta=25℃(normal temperature). IC is heated when it consumed power, and the temperature of IC ship becomes higher than ambient temperature. The temperature that can be accepted by IC chip depends on circuit configuration, manufacturing process, and consumable power is limited. Power dissipation is determined by the temperature allowed in IC chip (maximum junction temperature) and thermal resistance of package (heat dissipation capability).The maximum junction temperature is typically equal to the maximum value in the storage package (heat dissipation capability).The maximum junction temperature is typically equal to the maximum value in the storage temperature range. Heat generated by consumed power of IC radiates from the mold resin or lead frame of the package. The parameter which indicates this heat dissipation capability (hardness of heat release) is called thermal resistance, represented by the symbol θja℃/W. The temperature of IC inside the package can be estimated by this thermal resistance. Figure 83. (a) shows the model of thermal resistance of the package. Thermal resistance θja, ambient temperature Ta, maximum junction temperature Tjmax, and power dissipation Pd can be calculated by the equation below: θja = (Tjmax-Ta) / Pd ℃/W ・・・・・ (Ⅰ) Derating curve in Figure 83. (b) indicates power that can be consumed by IC with reference to ambient temperature. Power that can be consumed by IC begins to attenuate at certain ambient temperature. This gradient iis determined by thermal resistance θja. Thermal resistance θja depends on chip size, power consumption, package, ambient temperature, package condition, wind velocity, etc even when the same of package is used. Thermal reduction curve indicates a reference value measured at a specified condition. Figure 84 (c)-(e) show a derating curve for an example LMR321, LMR358, LMR324. PowerLSIの dissipation LSI [W] 消 費 電 力of[W] Pd (max) θja=(Tjmax-Ta)/Pd ℃/W θja2 < θja1 P2 Ta [℃] Ta [℃] 周囲温度 Ambient temperature θ' ja2 P1 θ ja2 Tj ' (max) Tj (max) θ' ja1 Chip surface temperature Tj [℃] チップ 表面温度 Tj [℃] Power dissipation Pd [W] 0 消費電力 P [W] 25 50 θ ja1 75 100 125 150 ] [℃] 囲 温 度 Ta [℃Ta Ambient 周 temperature (a) Thermal resistance (b) Derating curve Figure 83. Thermal resistance and derating 800 LMR321G(*20) 600 400 200 POWER DISSIPATION [mW] 1000 . . POWER DISSIPATION [mW] . POWER DISSIPATION [mW] 1200 1200 1200 1000 0 LMR358F(*21) LMR358FJ(*22) 800 LMR358FV /FVT(*23) LMR358FVM/ FVJ(*24) 600 400 200 0 0 25 50 75 100 125 LMR324FV(*26) LMR324FVJ(*27) 800 LMR324F (*28) 600 400 200 0 0 AMBIENT TEMPERATURE [℃] LMR324FJ(*25) 1000 25 50 75 100 125 0 AMBIENT TEMPERATURE [℃] 25 75 100 125 (e) LMR324 (d) LMR358 (c) LMR321 50 AMBIENT TEMPERATURE [℃] (*20) (*21) (*22) (*23) (*24) (*25) (*26) (*27) (*28) Unit 5.4 5.52 5.4 5.0 4.7 8.2 7.0 6.8 4.5 mW/℃ When using the unit above Ta=25℃, subtract the value above per degree℃. Permissible dissipation is the value. When FR4 glass epoxy board 70mm×70mm×1.6mm (cooper foil area below 3%) is mounted. Figure 84. Thermal resistance and derating www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 32/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Operational Notes 1) Processing of unused circuit It is recommended to apply connection (see the Figure 85.) and set the non inverting input terminal at the potential within input common-mode voltage range (Vicm), for any unused circuit. VDD VCC + Connect to Vicm 2) Applied voltage to the input terminal For normal circuit operation of voltage comparator, please input voltage for its input terminal within input common mode voltage VDD + 0.3V. Then, regardless of power supply voltage, VSS-0.3V can be applied to input terminals without deterioration or destruction of its characteristics. - Vicm VEE VSS Figure 85. The example of application circuit for unused op-amp 3) Short-circuit of output terminal When output terminal and VDD or VSS terminal are shorted, excessive Output current may flow under some conditions, and heating may destroy IC. It is necessary to connect a resistor as shown in Figure 86, thereby protecting against load shorting. VCC VDD + protection resistor - 4) Operating power supply (split power supply/single power supply) The voltage comparator operates if a given level of voltage is applied between VDD and VSS. Therefore, the operational amplifier can be operated under single power supply or split power supply. VSS VEE 5) Power dissipation (pd) If the IC is used under excessive power dissipation. An increase in the chip temperature will cause deterioration of the radical characteristics of IC. For example, reduction of current capability. Take consideration of the effective power dissipation and thermal design with a sufficient margin. Pd is reference to the provided power dissipation curve. Figure 86. The example of output short protection 6) Short circuits between pins and incorrect mounting Short circuits between pins and incorrect mounting when mounting the IC on a printed circuits board, take notice of the direction and positioning of the IC. If IC is mounted erroneously, It may be damaged. Also, when a foreign object is inserted between output, between output and VDD terminal and VSS terminal which causes short circuit, the IC may be damaged. 7) Using under strong electromagnetic field Be careful when using the IC under strong electromagnetic field because it may malfunction. 8) Usage of IC When stress is applied to the IC through warp of the printed circuit board, The characteristics may fluctuate due to the piezo effect. Be careful of the warp of the printed circuit board. 9) Testing IC on the set board When testing IC on the set board, in cases where the capacitor is connected to the low impedance, make sure to discharge per fabrication because there is a possibility that IC may be damaged by stress. When removing IC from the set board, it is essential to cut supply voltage. As a countermeasure against the static electricity, observe proper grounding during fabrication process and take due care when carrying and storage it. 10) The IC destruction caused by capacitive load The transistors in circuits may be damaged when VDD terminal and VSS terminal is shorted with the charged output terminal capacitor.When IC is used as a operational amplifier or as an application circuit, where oscillation is not activated by an output capacitor, the output capacitor must be kept below 0.1μF in order to prevent the damage mentioned above. 11) Latch up Be careful of input voltage that exceed the VDD and VSS. When CMOS device have sometimes occur latch up operation. And protect the IC from abnormaly noise 12) Decupling capacitor Insert the decupling capacitance between VDD and VSS, for stable operation of operational amplifier. Status of this document The Japanese version of this document is formal specification. A customer may use this translation version only for a reference to help reading the formal version. If there are any differences in translation version of this document formal version takes priority. www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 33/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Physical Dimensions Tape and Reel Information SSOP5 5 4 1 2 3 Tape Embossed carrier tape Quantity 3000pcs Direction of feed 0.2Min. +0.2 1.6 −0.1 2.8±0.2 +6° 4° −4° 2.9±0.2 TR The direction is the 1pin of product is at the upper right when you hold ( reel on the left hand and you pull out the tape on the right hand 1pin +0.05 0.13 −0.03 1.25Max. ) +0.05 0.42 −0.04 0.05±0.05 1.1±0.05 S 0.95 0.1 S Direction of feed Reel (Unit : mm) ∗ Order quantity needs to be multiple of the minimum quantity. SOP8 5.0±0.2 (MAX 5.35 include BURR) 6 5 4.4±0.2 6.2±0.3 1 2 3 0.9±0.15 7 0.3MIN 8 +6° 4° −4° Tape Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 4 0.595 1.5±0.1 +0.1 0.17 -0.05 S S 0.11 0.1 1.27 1pin 0.42±0.1 Reel (Unit : mm) Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. SOP-J8 4.9±0.2 (MAX 5.25 include BURR) +6° 4° −4° 6 5 0.45MIN 7 3.9±0.2 6.0±0.3 8 1 2 3 Tape Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 4 0.545 0.2±0.1 1.375±0.1 S 0.175 1.27 0.42±0.1 0.1 S 1pin Reel (Unit : mm) Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. SSOP-B8 3.0±0.2 (MAX 3.35 include BURR) 8 7 6 5 Tape Embossed carrier tape Quantity 2500pcs E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 0.3MIN 6.4 ± 0.3 4.4 ± 0.2 Direction of feed 2 3 4 0.1 1.15±0.1 1 0.15±0.1 S (0.52) 0.65 0.1 S +0.06 0.22 −0.04 0.08 1pin M (Unit : mm) www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Reel 34/38 Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx TSSOP-B8 3.0±0.1 (MAX 3.35 include BURR) 8 7 6 4±4 3000pcs 2 3 4 1PIN MARK E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 1.0±0.2 0.5± 0.15 6.4± 0.2 4.4± 0.1 1 +0.05 0.145 −0.03 S 0.1± 0.05 1.2MAX Embossed carrier tape Quantity Direction of feed 0.525 1.0± 0.05 Tape 5 0.08 S +0.05 0.245 −0.04 0.08 M Direction of feed 1pin 0.65 Reel (Unit : mm) ∗ Order quantity needs to be multiple of the minimum quantity. MSOP8 4.0±0.2 2.8±0.1 8 7 6 5 0.6±0.2 +6° 4° −4° 0.29±0.15 2.9±0.1 (MAX 3.25 include BURR) Tape Embossed carrier tape Quantity 3000pcs Direction of feed TR The direction is the 1pin of product is at the upper right when you hold ( reel on the left hand and you pull out the tape on the right hand ) 1 2 3 4 1PIN MARK 1pin +0.05 0.145 −0.03 0.475 +0.05 0.22 −0.04 0.08±0.05 0.75±0.05 0.9MAX S 0.08 S Direction of feed 0.65 Reel (Unit : mm) ∗ Order quantity needs to be multiple of the minimum quantity. TSSOP-B8J 3.0±0.1 (MAX 3.35 include BURR) 6 5 Embossed carrier tape Quantity 2500pcs 0.45 ± 0.15 3 4 1PIN MARK E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 0.95 ± 0.2 2 +0.05 0.145 −0.03 0.525 S 0.1±0.05 0.85±0.05 Tape Direction of feed 1 1.1MAX 7 3.0 ± 0.1 4.9± 0.2 8 4±4 0.08 S +0.05 0.32 −0.04 0.08 M Direction of feed 1pin 0.65 Reel (Unit : mm) ∗ Order quantity needs to be multiple of the minimum quantity. SOP14 8.7 ± 0.2 (MAX 9.05 include BURR) 8 Tape Embossed carrier tape Quantity 2500pcs Direction of feed 0.3MIN 4.4±0.2 6.2±0.3 14 1 E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 7 0.11 1.5±0.1 0.15 ± 0.1 1.27 0.4 ± 0.1 0.1 1pin (Unit : mm) www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Reel 35/38 Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx SOP-J14 8.65±0.1 (Max 9.0 include BURR) 0.65± 0.15 1 Tape Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 7 1PIN MARK S +0.05 0.22 −0.03 0.175 ± 0.075 1.65MAX 1.375 ± 0.075 0.515 1.05± 0.2 4° +6° −4° 8 6.0 ± 0.2 3.9 ± 0.1 14 +0.05 0.42 −0.04 1.27 0.08 S 0.08 M 1pin Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. Reel (Unit : mm) SSOP-B14 5.0 ± 0.2 8 0.3Min. 4.4 ± 0.2 6.4 ± 0.3 14 1 Tape Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 7 0.10 1.15 ± 0.1 0.15 ± 0.1 0.1 0.65 0.22 ± 0.1 1pin Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. Reel (Unit : mm) TSSOP-B14J 5.0±0.1 (Max 5.35 include BURR) 14 4 ±4 1.0±0.2 0.5±0.15 6.4±0.2 4.4±0.1 1 Embossed carrier tape Quantity 2500pcs Direction of feed E2 The direction is the 1pin of product is at the upper left when you hold ( reel on the left hand and you pull out the tape on the right hand ) 7 1PIN MARK +0.05 0.145 −0.03 1.0±0.05 S 0.1±0.05 1.2MAX 0.55 Tape 8 0.08 S 0.65 +0.05 0.245 −0.04 0.08 M 1pin (Unit : mm) www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Reel 36/38 Direction of feed ∗ Order quantity needs to be multiple of the minimum quantity. TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx ●Marking Diagrams SSOP5(TOP VIEW) SOP8(TOP VIEW) Part Number Marking Part Number Marking LOT Number 1PIN MARK LOT Number SSOP-B8(TOP VIEW) MSOP8(TOP VIEW) Part Number Marking Part Number Marking LOT Number LOT Number 1PIN MARK 1PIN MARK SOP-J8(TOP VIEW) Part Number Marking TSSOP-B8(TOP VIEW) Part Number Marking LOT Number LOT Number 1PIN MARK 1PIN MARK TSSOP-B8J(TOP VIEW) SOP14(TOP VIEW) Part Number Marking Part Number Marking LOT Number LOT Number 1PIN MARK SOP-J14(TOP VIEW) Part Number Marking 1PIN MARK SSOP-B14(TOP VIEW) Part Number Marking LOT Number LOT Number 1PIN MARK 1PIN MARK www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 37/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet LMR321G, LMR358xxx, LMR324xxx TSSOP-B14J (TOP VIEW) Part Number Marking Product Name LOT Number Package Type LMR321 LMR358 1PIN MARK Product Name Marking G SSOP5 F SOP8 L358 L2 FJ SOP-J8 R358 FV SSOP-B8 L358 FVT TSSOP-B8 R358 FVM MSOP8 L358 FVJ TSSOP-B8J R358 F SOP14 LMR324F LMR324FJ FJ SOP-J14 FV SSOP-B14 L324 FVJ TSSOP-B14J R324 LMR324 ●Land pattern data SOP8, SOP14, SOP-J8, SOP-J14, SSOP-B8 SSOP-B14, MSOP8, TSSOP-B8, TSSOP-B8J, TSSOP-B14J SSOP5 0.95 0.95 1.0 2.4 e MIE b2 0.6 ℓ2 all dimensions in mm Land length Land width ≧ℓ 2 b2 Land pitch e Land space MIE 0.95 2.4 1.0 0.6 1.27 4.60 1.10 0.76 1.27 3.90 1.35 0.76 0.65 4.60 1.20 0.35 MSOP8 0.65 2.62 0.99 0.35 TSSOP-B8 0.65 4.60 1.20 0.35 TSSOP-B8J 0.65 3.20 1.15 0.35 TSSOP-B14J 0.65 4.60 1.20 0.35 PKG SSOP5 SOP8 SOP14 SOP-J8 SOP-J14 SSOP-B8 SSOP-B14 ●Revision History Date Revision 30.NOV.2012 001 Changes New Release www.rohm.com © 2012 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 38/38 TSZ02201-0RAR1G200560-1-2 30.NOV.2012 Rev.001 Datasheet Notice Precaution on using ROHM Products 1. Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you (Note 1) , transport intend to use our Products in devices requiring extremely high reliability (such as medical equipment equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation (Pd) depending on Ambient temperature (Ta). When used in sealed area, confirm the actual ambient temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label QR code printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act, please consult with ROHM representative in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. ROHM shall not be in any way responsible or liable for infringement of any intellectual property rights or other damages arising from use of such information or data.: 2. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the information contained in this document. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice - GE © 2014 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet General Precaution 1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents. ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s representative. 3. The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or concerning such information. Notice – WE © 2014 ROHM Co., Ltd. All rights reserved. Rev.001
LMR324F-GE2 价格&库存
很抱歉,暂时无法提供与“LMR324F-GE2”相匹配的价格&库存,您可以联系我们找货
LMR324F-GE2
  • 2500+3.880392500+0.50444
LMR324F-GE2
  • 4+18.905894+2.45771
  • 10+12.6188910+1.64042
  • 25+10.8240525+1.40710
  • 100+8.39726100+1.09162
  • 250+7.30396250+0.94950
  • 500+4.84012500+0.62920
  • 1000+4.345961000+0.56496
  • 2500+3.513322500+0.45672
  • 5000+3.435475000+0.44660
库存:100
LMR324F-GE2
  • 144+6.37904144+0.82926
  • 250+6.12312250+0.79599
  • 500+4.44919500+0.57838
  • 1000+4.303651000+0.55946
  • 2500+4.176722500+0.54296
库存:2500
LMR324F-GE2
    • 1+4.409721+0.57325
    • 50+3.7325750+0.48523
    • 100+3.22058100+0.41867
    • 300+2.87375300+0.37358
    • 500+2.80769500+0.36499
    • 1000+2.758141000+0.35855
    • 4000+2.716854000+0.35319
    库存:2500
    LMR324F-GE2
      • 1+1.87650
      • 200+0.72620
      • 500+0.70071
      • 1000+0.68807
      LMR324F-GE2
      库存:100
