LSH1208-BA50A
LSH1208-BA50A
    ROHM(罗姆)
    LSH1208-BA50A - Color Multi Line Sensor Heads for High-speed Scanner - Rohm
LSH1208-BA50A 数据手册
Color Multi Line Sensor Heads for High-speed Scanner LSH1208-BA50A Multi Line Sensor Head with 3 times higher scanning speed due to 3ch outputs. Newly developed resolution change-over IC is employed which has improved noise resistance. Applications High speed reading equipment (i.e. document scanners, wide format scanners). Features 1) High speed reading capability due to 3 analog output. 2) Signal amplifier is built into the sensor IC in order to increase immunity to external noise. 3) ROHM’s newly developed sensor IC reduces failures due to ESD (based on the IEC61000-4-2 standard). 4) With the proprietary prism, the output signal is maintained uniformly. 5) The ceramic substrate is used for excellent dimensional accuracy and thermal stability. Dimensions (Unit : mm) 236 ±0.5 2-φ1.5×2 Oval Hole D4MIN Scanning Line 216 (Effective Reading Width) Effective 1st bit 9.4 0.324±0.1 14 ±0.2 2-φ1.5 D4MIN 15 2.0±0.8 2- 3 +0/-0.1 MAX.3.15 1mm Pitch 15pin 6.9 6.9 max.1 max.1 max.1 max.1 No.1 Center of FCC 13.8 No.15 Characteristics Parameter Effective scanning width Primary scan dot density Total dot number Power supply voltage Reference voltage Scanning speed Clock frequency Maximum dynamic range Minimum dynamic range Dark output Operating temperature Symbol − − − VDD VREF SLT CLK VRMax VRMin. Vod − Typ. 216 1200 10368 3.3 0.8 1.0 x 3 4 0.5 0.25 VREF + 0.1 − 5 to 45 Unit mm dpi dots V V ms / line MHz V V V °C www.rohm.com c ○ 2009 ROHM Co., Ltd. All rights reserved. 17.5 1/5 2009.11 - Rev.A LSH1208-BA50A Pin assignments No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Circuit AO3 GND AO2 GND AO1 MODE GND VDD VREF SP CLK V-LED B-GND G-GND R-GND I/O O I O I O I I I I I I I I I I Function Data Sheet Analog output Ground Analog output Ground Analog output Mode select Ground Power supply Reference voltage Start pulse Clock LED power supply BLUE LED ground GREEN LED ground RED LED ground Timing chart (a) CLK Timing Chart 1/fCLK twH twL C LK 50% 50% SP tSETUP tHOLD ts Ao 1pixel 2pixel www.rohm.com c ○ 2009 ROHM Co., Ltd. All rights reserved. 2/5 2009.11 - Rev.A LSH1208-BA50A (b-1) Data Output Timing Chart (1200dpi mode) After turning on the SP pulse, the analog output starts from the setting up point of 82 clock pulse. 1200dpi mode Data Sheet 1 2 82 C LK SP A O1 to 3 VREF output period Vdummy Analog output period Vdummy A O1 : A O2 : A O3 : 1 to 82clock 1 to 82clock 1 to 82clock 1 to 100pixels − − 101 to 3456pixels 3457 to 6912pixels 6913 to 10312pixels − − 10313 to 10368pixels Note)The CLK section area which is over the effective pixel numbers (Output blank part) cannot be used as the analog Output standard level. (b-2) Data Output Timing Chart (600dpi mode) After turning on the SP pulse, the analog output starts from the setting up point of 82 clock pulse. 600dpi mode 1 2 82 C LK SP A O1 to 3 VREF output period Vdummy Analog output period Vdummy A O1 : A O2 : A O3 : 1 to 82clock 1 to 82clock 1 to 82clock 1 to 50pixels − − 51 to 1728pixels 1729 to 3456pixels 3457 to 5156pixels − − 5157 to 5184pixels Note)The CLK section area which is over the effective pixel numbers (Output blank part) cannot be used as the analog Output standard level. www.rohm.com c ○ 2009 ROHM Co., Ltd. All rights reserved. 3/5 2009.11 - Rev.A LSH1208-BA50A (b-3) Data Output Timing Chart (300dpi mode) After turning on the SP pulse, the analog output starts from the setting up point of 82 clock pulse. 300dpi mode Data Sheet 1 2 82 C LK SP A O1 to 3 VREF output period Vdummy Analog output period Vdummy A O1 : A O2 : A O3 : 1 to 82clock 1 to 82clock 1 to 82clock 1 to 25pixels − − 26 to 864pixels 865 to 1728pixels 1729 to 2578pixels − − 2579 to 2592pixels Note)The CLK section area which is over the effective pixel numbers (Output blank part) cannot be used as the analog Output standard level. Circuit diagram VDD GND 1µF×6 1 10368 SP VDD ANALOG MEMORY CIRCUIT CLK VREF MODE 1 AO1 AO2 AO3 MODE VREF VLED 3456 3457 6912 6913 10368 RGND GGND BGND www.rohm.com c ○ 2009 ROHM Co., Ltd. All rights reserved. 4/5 2009.11 - Rev.A LSH1208-BA50A Peripheral circuit Data Sheet SENSOR UNIT 13 14 15 12 1 3 5 9 8 10 11 2, 4, 7 6 R3 R3 R2 B G R R3 C1 C3 A3 A2 A1 VDD C2 SP CLK C5 R1 LED GND C4 VLED VREF GND MODE R1=R2=100Ω, R3=100KΩ C1=C2=47µF C3=100µF, C4=0.1µF, C5=100pF www.rohm.com c ○ 2009 ROHM Co., Ltd. All rights reserved. 5/5 2009.11 - Rev.A Notice Notes No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuel-controller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 2009 ROHM Co., Ltd. All rights reserved. R0039A
LSH1208-BA50A
物料型号: - LSH1208-BA50A
器件简介: - LSH1208-BA50A是一款高速扫描仪的多线传感器头,具有3个通道输出,扫描速度是普通传感器头的3倍。采用了新开发的分辨率切换IC,提高了抗噪声能力。
引脚分配: | 引脚编号 | 电路 | 1/0 | 功能 | | --- | --- | --- | --- | | 1 | Ao3 | 0 | 模拟输出 | | 2 | GND | I | 地线 | | 3 | Ao2 | 0 | 模拟输出 | | 4 | GND | I | 地线 | | 5 | Ao1 | O | 模拟输出 | | 6 | MODE | I | 模式选择 | | 7 | GND | 一 | 地线 | | 8 | VDD | I | 电源供电 | | 9 | VREF | I | 参考电压 | | 10 | SP | | 开始脉冲 | | 11 | CLK | I | 时钟 | | 12 | V-LED | 1 | LED电源供电 | | 13 | B-GND | | 蓝色LED地线 | | 14 | G-GND | I | 绿色LED地线 | | 15 | R-GND | I | 红色LED地线 |
参数特性: | 参数 | 符号 | 典型值 | 单位 | | --- | --- | --- | --- | | 有效扫描宽度 | | 216 | mm | | 主扫描点密度 | 1 | 1200 | dpi | | 总点数 | | 10368 | 点 | | 电源电压 | VDD | 3.3 | V | | 参考电压 | VREF | 0.8 | V | | 扫描速度 | SLT | 1.0x3 | ms/线 | | 时钟频率 | CLK | 4 | MHz | | 最大动态范围 | VRMax | 0.5 | V | | 最小动态范围 | VRMin. | 0.25 | V | | 暗输出 | Vod | VREF±0.1 | V | | 工作温度 | | 5至45 | ℃ |
功能详解: - 该传感器头具有高速阅读能力,由于3个模拟输出而实现。 - 传感器IC内置信号放大器,增强了对外部噪声的抗干扰能力。 - ROHM新开发的传感器IC减少了因ESD导致的故障(基于IEC61000-4-2标准)。 - 使用专有的棱镜,保持输出信号均匀。 - 使用陶瓷基板,具有出色的尺寸精度和热稳定性。
应用信息: - 适用于高速阅读设备(如文档扫描仪、宽幅面扫描仪)。
封装信息: - 尺寸图已提供,单位为毫米。
LSH1208-BA50A 价格&库存
很抱歉,暂时无法提供与“LSH1208-BA50A”相匹配的价格&库存,您可以联系我们找货
