ML610Q408P-NNNTB0AAL
    ROHM(罗姆)
    TQFP100
ML610Q408P-NNNTB0AAL 数据手册
Dear customer LAPIS Semiconductor Co., Ltd. ("LAPIS Semiconductor"), on the 1st day of October, 2020, implemented the incorporation-type company split (shinsetsu-bunkatsu) in which LAPIS established a new company, LAPIS Technology Co., Ltd. (“LAPIS Technology”) and LAPIS Technology succeeded LAPIS Semiconductor’s LSI business. Therefore, all references to "LAPIS Semiconductor Co., Ltd.", "LAPIS Semiconductor" and/or "LAPIS" in this document shall be replaced with "LAPIS Technology Co., Ltd." Furthermore, there are no changes to the documents relating to our products other than the company name, the company trademark, logo, etc. Thank you for your understanding. LAPIS Technology Co., Ltd. October 1, 2020 FEDL610Q409-05 Issue Date: May.23, 2014 ML610Q407/ML610Q408/ML61Q0409 8-bit Microcontroller with a Built-in LCD driver GENERAL DESCRIPTION ML610Q407/ML610Q408/ML610Q409 is a high-performance 8-bit CMOS microcontroller into which peripheral circuits, such as synchronous serial port, UART, melody driver, RC oscillation type A/D converter, and LCD driver, are incorporated around LAPIS Semiconductor-original 8-bit CPU nX-U8/100. ML610Q407/ML610Q408/ML610Q409 operates in both high/low-speed mode and power-saving mode, it is most suitable for battery operated products. The short TAT are entertained by offering MTP version ML610Q407(P)/ML610Q408(P)/ML610Q409(P). ML610Q407P/ ML610Q408P/ML610Q409P support industrial temperature -40°C to +85°C, are added to the product lineup. FEATURES • CPU − 8-bit RISC CPU (CPU name: nX-U8/100) − Instruction system: 16-bit instructions − Instruction set: Transfer, arithmetic operations, comparison, logic operations, multiplication/division, bit manipulations, bit logic operations, jump, conditional jump, call return stack manipulations, arithmetic shift, and so on − On-Chip debug function (MTP version only) − Minimum instruction execution time 30.5 µs (@32.768 kHz system clock) 2µs (@500kHz system clock) 0.5µs(@2MHz system clock) • Internal memory − Internal 16KByte Flash ROM (8K×16 bits) (including unusable 1K Byte TEST area) − Internal 1KByte Data RAM (1024×8 bits) • Interrupt controller − 1 non-maskable interrupt sources Internal source: 1 (Watch dog timer) − 27 maskable interrupt sources Internal sources: 14 (SSIO0, SSIO1, Timer0, Timer1, Timer2, Timer3, UART0, Melody0, RC-A/D converter, PWM0, TBC128Hz, TBC32Hz, TBC16Hz, TBC2Hz) External sources: 13 (P00, P01, P02, P03, P04, P50, P51, P52, P53, P54, P55, P56, P57) (One interrupt request is generated from P50 to P57 interrupt sources.) • Time base counter − Low-speed time base counter ×1 channel Frequency compensation (Compensation range: Approx. −488ppm to +488ppm. Compensation accuracy: Approx. 0.48ppm) − High-speed time base counter ×1 channel • Watchdog timer − Non-maskable interrupt and reset − Free running − Overflow period: 4 types selectable (125ms, 500ms, 2s, and 8s) • Timers − 8 bits × 4 channels (Timer0-3: 16-bit x 2 configuration available by using Timer0-1 or Timer2-3) − Clock frequency measurement mode (in one channel of 16-bit configuration using Timer2-3) 1/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 • Capture − Time base capture × 2 channels (4096 Hz to 32 Hz) • PWM − Resolution 16 bits × 1 channel • Synchronous serial port − Master/slave selectable × 2 channel − LSB first/MSB first selectable − 8-bit length/16-bit length selectable • UART − Half-Duplex Communication − TXD/RXD × 1 channel − Bit length, parity/no parity, odd parity/even parity, 1 stop bit/2 stop bits − Positive logic/negative logic selectable − Built-in baud rate generator • Melody driver − Scale: 29 types (Melody sound frequency: 508 Hz to 32.768 kHz) − Tone length: 63 types −Tempo: 15 types − Buzzer output mode (4 output modes, 8 frequencies, 16 duty levels) • RC oscillation type A/D converter − 16-bit counter − Time division × 2 channels • General-purpose ports − Input-only port × 5 channels (including secondary functions) − Output-only port ML610Q407: × 12 channels (including secondary functions) ML610Q408: × 8 channels (including secondary functions) ML610Q409: × 4 channels (including secondary functions) − Input/output port × 22 channels (including secondary functions) • LCD driver − The number of segments ML610Q407: 145 dots max. (29seg×5com, 30seg×4com, 31seg×3com, and 32seg×2com selectable) ML610Q408: 165 dots max. (33seg×5com, 34seg×4com, 35seg×3com, and 36seg×2com selectable) ML610Q409: 185 dots max. (37seg×5com, 38seg×4com, 39seg×3com, and 40seg×2com selectable) − 1/1 to 1/5 duty − 1/2(*), 1/3 bias (built-in bias generation circuit) − Frame frequency selecable: approx. 64Hz, 73Hz, 85Hz, and 102Hz − Bias voltage multiplying clock selectable (8 types) − LCD drive stop mode, LCD display mode, all LCDs on mode, and all LCDs off mode selectable − Programmable display allocation function (*) 1/2 bias is supported by A version and D version • Reset − Reset through the RESET_N pin − Power-on reset generation when powered on − Reset when oscillation stop of the low-speed clock is detected (Not supported in A version) − Reset by the watchdog timer (WDT) overflow 2/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 • Clock − Low-speed clock: Crystal oscillation (32.768 kHz) (This LSI can not guarantee the operation withoug low-speed crystal oscillation clock) − High-speed clock: Built-in RC oscillation (500 kHz, 2MHz) • Power management − HALT mode: Instruction execution by CPU is suspended (peripheral circuits are in operating states). − STOP mode: Stop of low-speed oscillation and high-speed oscillation (Operations of CPU and peripheral circuits are stopped.) − High-speed Clock gear: The frequency of high-speed system clock can be changed by software (1/1, 1/2, 1/4, 1/8 of the oscillation clock) − Block Control Function: Resets and completely turns circuits of unused peripherals off. • Guaranteed operating range − Operating temperature: −20°C to +70°C (P version: −40°C to +85°C) − Operating voltage: VDD = 1.25V to 3.6V 3/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 • Product name – Supported Function 1/2 1/3 Low-speed oscillation stop detect reset ML610Q407-xxxWA - Yes Yes -20°C to +70°C Yes ML610Q408-xxxWA - Yes Yes -20°C to +70°C Yes ML610Q409-xxxWA - Yes Yes -20°C to +70°C Yes ML610Q407P-xxxWA - Yes Yes -40°C to +85°C Yes ML610Q408P-xxxWA - Yes Yes -40°C to +85°C Yes LCD bias - Chip (Die) - Operating temperature Product availability ML610Q409P-xxxWA ML610Q407A- x x x WA - Yes Yes -40°C to +85°C Yes Yes Yes - -20°C to +70°C Yes ML610Q408A-xxxWA Yes Yes - -20°C to +70°C - ML610Q409A-xxxWA Yes Yes - -20°C to +70°C Yes ML610Q407D-xxxWA Yes Yes Yes -20°C to +70°C Yes ML610Q408D-xxxWA Yes Yes Yes -20°C to +70°C - ML610Q409D-xxxWA Yes Yes Yes -20°C to +70°C - ML610Q407PA-xxxWA Yes Yes - -40°C to +85°C Yes ML610Q408PA-xxxWA Yes Yes - -40°C to +85°C - ML610Q409PA-xxxWA Yes Yes - -40°C to +85°C - ML610Q407PD-xxxWA Yes Yes Yes -40°C to +85°C - ML610Q408PD-xxxWA Yes Yes Yes -40°C to +85°C - ML610Q409PD-xxxWA Yes Yes Yes -40°C to +85°C - Operating temperature Product availability 1/2 1/3 Low-speed oscillation stop detect reset ML610Q407-xxxTB - Yes Yes -20°C to +70°C Yes ML610Q408-xxxTB - Yes Yes -20°C to +70°C Yes ML610Q409-xxxTB - Yes Yes -20°C to +70°C Yes ML610Q407P-xxxTB - Yes Yes -40°C to +85°C Yes ML610Q408P-xxxTB - Yes Yes -40°C to +85°C Yes -100-pin plastic TQFP - LCD bias ML610Q409P-xxxTB - Yes Yes -40°C to +85°C Yes ML610Q407A-xxxTB Yes Yes - -20°C to +70°C - ML610Q408A-xxxTB Yes Yes - -20°C to +70°C - ML610Q409A-xxxTB Yes Yes - -20°C to +70°C - ML610Q407D-xxxTB Yes Yes Yes -20°C to +70°C - ML610Q408D-xxxTB Yes Yes Yes -20°C to +70°C - ML610Q409D-xxxTB Yes Yes Yes -20°C to +70°C - ML610Q407PAxxxTB Yes Yes - -40°C to +85°C - ML610Q408PAxxxTB Yes Yes - -40°C to +85°C - ML610Q409PAxxxTB Yes Yes - -40°C to +85°C - ML610Q407PDxxxTB Yes Yes Yes -40°C to +85°C - ML610Q408PDxxxTB Yes Yes Yes -40°C to +85°C - ML610Q409PDxxxTB Yes Yes Yes -40°C to +85°C - xxx: ROM code number (xxx of the blank product is NNN) Q: MTP version P: Wide range temperature version (P version) A: Low-speed clock oscillation stop detection reset is disabled always and LCD 1/2 bias supported version.(A version) D: LCD 1/2 bias supported version (D version) WA: Chip (Die), TB: TQFP 4/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 BLOCK DIAGRAM ML610Q407/ML610Q408/ML610Q409 Block Diagram Figure 1 show the block diagram of the ML610Q407/ML610Q408/ML610Q409. “*” indicates the secondary function of each port. “(*1)”: 29seg×5com, 30seg×4com, 31seg×3com, and 32seg×2com selectable “(*2)”: 33seg×5com, 34seg×4com, 35seg×3com, and 36seg×2com selectable “(*3)”: 37seg×5com, 38seg×4com, 39seg×3com, and 40seg×2com selectable CPU (nX-U8/100) EPSW1~3 GREG 0~15 PSW Timing Controller ALU LR DSR/CSR EA PC Instruction Register Data-bus VDD VSS RESET_N TEST0 TEST1_N ECSR1~3 SP Instruction Decoder On-Chip ICE ELR1~3 Program Memory (MTP) 16Kbyte BUS Controller INT 2 RAM 1Kbyte RESET & TEST SSIO ×2 Interrupt Controller XT0 XT1 INT 1 OSC LSCLK* OUTCLK* VDDL IN0* CS0* RS0* RT0* CRT0* RCM* IN1* CS1* RS1* RT1* INT 4 WDT TBC RC-ADC ×2 INT 4 8bit Timer ×4 Display Allocation RAM Display register 320bit SCK1* SIN1* SOUT1* UART RXD0* TXD0* PWM PWM0* INT 1 INT 1 Capture ×2 SCK0* SIN0* SOUT0* INT 1 Power INT 1 VPP Melody INT 6 GPIO MD0* P00 to P04 P20 to P22, P24 P30 to P35 P40 to P47 P50 to P57 P60 to P67 (ML610Q407) P60 to P63 (ML610Q408) LCD Driver LCD BIAS (*1)(*2)(*3) COM0 to COM4 SEG0 to SEG31 (ML610Q407) (*1) SEG0 to SEG35 (ML610Q408) (*2) SEG0 to SEG39 (ML610Q409) (*3) VL1, VL2, VL3 C1, C2 Figure 1 ML610Q407/ML610Q408/ML610Q409 Block Diagram 5/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 PIN CONFIGURATION 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 (NC) (NC) SEG17 SEG16 SEG15 SEG14 SEG13 SEG12 SEG11 SEG10 SEG9 SEG8 SEG7 SEG6 SEG5 SEG4 SEG3 COM4/SEG2 COM3/SEG1 COM2/SEG0 COM1 COM0 C2 C1 (NC) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 (NC) P52 P51 P50 P40 P41 P42 P43 P44 P45 P46 P47 VDD VSS VDDL (NC XT0 XT1 RESET_N TEST0 TEST1_N VL1 VL2 VL3 (NC) (NC) VSS P20 P21 P22 P24 P00 P01 P02 P03 P04 P30 P31 P34 P32 P33 P35 P57 P56 P55 P54 P53 VPP (NC) (NC) 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 (NC) (NC) P60 P61 P62 P63 P64 P65 P66 P67 SEG31 SEG30 SEG29 SEG28 SEG27 SEG26 SEG25 SEG24 SEG23 SEG22 SEG21 SEG20 SEG19 SEG18 (NC) ML610Q407 TQFP100 Pin Layout Note: The assignment of the P30 to P35 are not in order. Figure 2 ML610Q407 TQFP100 Pin Configuration 6/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 (NC) (NC) SEG17 SEG16 SEG15 SEG14 SEG13 SEG12 SEG11 SEG10 SEG9 SEG8 SEG7 SEG6 SEG5 SEG4 SEG3 COM4/SEG2 COM3/SEG1 COM2/SEG0 COM1 COM0 C2 C1 (NC) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 (NC) P52 P51 P50 P40 P41 P42 P43 P44 P45 P46 P47 VDD VSS VDDL (NC) XT0 XT1 RESET_N TEST0 TEST1_N VL1 VL2 VL3 (NC) (NC) VSS P20 P21 P22 P24 P00 P01 P02 P03 P04 P30 P31 P34 P32 P33 P35 P57 P56 P55 P54 P53 VPP (NC) (NC) 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 (NC) (NC) P60 P61 P62 P63 SEG35 SEG34 SEG33 SEG32 SEG31 SEG30 SEG29 SEG28 SEG27 SEG26 SEG25 SEG24 SEG23 SEG22 SEG21 SEG20 SEG19 SEG18 (NC) ML610Q408 TQFP100 Pin Layout Note: The assignment of the P30 to P35 are not in order. Figure 3 ML610Q408 TQFP100 Pin Configuration 7/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 (NC) (NC) SEG17 SEG16 SEG15 SEG14 SEG13 SEG12 SEG11 SEG10 SEG9 SEG8 SEG7 SEG6 SEG5 SEG4 SEG3 COM4/SEG2 COM3/SEG1 COM2/SEG0 COM1 COM0 C2 C1 (NC) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 (NC) P52 P51 P50 P40 P41 P42 P43 P44 P45 P46 P47 VDD VSS VDDL (NC) XT0 XT1 RESET_N TEST0 TEST1_N VL1 VL2 VL3 (NC) (NC) VSS P20 P21 P22 P24 P00 P01 P02 P03 P04 P30 P31 P34 P32 P33 P35 P57 P56 P55 P54 P53 VPP (NC) (NC) 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 (NC) (NC) SEG39 SEG38 SEG37 SEG36 SEG35 SEG34 SEG33 SEG32 SEG31 SEG30 SEG29 SEG28 SEG27 SEG26 SEG25 SEG24 SEG23 SEG22 SEG21 SEG20 SEG19 SEG18 (NC) ML610Q409 TQFP100 Pin Layout Note: The assignment of the P30 to P35 are not in order. Figure 4 ML610Q409 TQFP100 Pin Configuration 8/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 P60 P61 P62 P63 P64 P65 P66 P67 SEG31 SEG30 SEG29 SEG28 SEG27 SEG26 SEG25 SEG24 SEG23 SEG22 SEG21 SEG20 SEG19 SEG18 ML610Q407 Chip Pin Layout & Dimension 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 XT1 RESET_N TEST0 TEST1_N VL1 VL2 VL3 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 P52 P51 P50 P40 P41 P42 P43 P44 P45 P46 P47 VDD VSS VDDL XT0 VSS P20 P21 P22 P24 P00 P01 P02 P03 P04 P30 P31 P34 P32 P33 P35 P57 P56 P55 P54 P53 VPP SEG17 SEG16 SEG15 SEG14 SEG13 SEG12 SEG11 SEG10 SEG9 SEG8 SEG7 2.23mm SEG6 SEG5 SEG4 SEG3 COM4/SEG2 COM3/SEG1 COM2/SEG0 COM1 COM0 C2 C1 2.27mm Y X Note: The assignment of the pads P30 to P35 are not in order. Chip size: 2.27 mm × 2.23 mm PAD count: 88 pins Minimum PAD pitch: 80µm PAD aperture: 70µm×70µm Chip thickness: 350µm Voltage of the rear side of chip: VSS level. Figure 5 ML610Q407 Chip Layout & Dimension 9/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 P60 P61 P62 P63 SEG35 SEG34 SEG33 SEG32 SEG31 SEG30 SEG29 SEG28 SEG27 SEG26 SEG25 SEG24 SEG23 SEG22 SEG21 SEG20 SEG19 SEG18 ML610Q408 Chip Pin Layout & Dimension 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 XT1 RESET_N TEST0 TEST1_N VL1 VL2 VL3 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 P52 P51 P50 P40 P41 P42 P43 P44 P45 P46 P47 VDD VSS VDDL XT0 VSS P20 P21 P22 P24 P00 P01 P02 P03 P04 P30 P31 P34 P32 P33 P35 P57 P56 P55 P54 P53 VPP SEG17 SEG16 SEG15 SEG14 SEG13 SEG12 SEG11 SEG10 SEG9 SEG8 SEG7 2.23mm SEG6 SEG5 SEG4 SEG3 COM4/SEG2 COM3/SEG1 COM2/SEG0 COM1 COM0 C2 C1 2.27mm Y X Note: The assignment of the pads P30 to P35 are not in order. Chip size: 2.27 mm × 2.23 mm PAD count: 88 pins Minimum PAD pitch: 80µm PAD aperture: 70µm×70µm Chip thickness: 350µm Voltage of the rear side of chip: VSS level. Figure 6 ML610Q408 Chip Layout & Dimension 10/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 SEG39 SEG38 SEG37 SEG36 SEG35 SEG34 SEG33 SEG32 SEG31 SEG30 SEG29 SEG28 SEG27 SEG26 SEG25 SEG24 SEG23 SEG22 SEG21 SEG20 SEG19 SEG18 ML610Q409 Chip Pin Layout & Dimension 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 XT1 RESET_N TEST0 TEST1_N VL1 VL2 VL3 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 P52 P51 P50 P40 P41 P42 P43 P44 P45 P46 P47 VDD VSS VDDL XT0 VSS P20 P21 P22 P24 P00 P01 P02 P03 P04 P30 P31 P34 P32 P33 P35 P57 P56 P55 P54 P53 VPP SEG17 SEG16 SEG15 SEG14 SEG13 SEG12 SEG11 SEG10 SEG9 SEG8 SEG7 2.23mm SEG6 SEG5 SEG4 SEG3 COM4/SEG2 COM3/SEG1 COM2/SEG0 COM1 COM0 C2 C1 2.27mm Y X Note: The assignment of the pads P30 to P35 are not in order. Chip size: 2.27 mm × 2.23 mm PAD count: 88 pins Minimum PAD pitch: 80 µm PAD aperture: 70 µm×70 µm Chip thickness: 350 µm Voltage of the rear side of chip: VSS level. Figure 7 ML610Q409 Chip Layout & Dimension 11/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 ML610Q407/ML610Q408/ML610Q409 Pad Coordinates Table 1 ML610Q407/ML610Q408/ML610Q409 Pad Coordinates Chip Center: X=0,Y=0 (*1) PAD No. Pad Name 1 P52 2 P51 3 P50 4 P40 5 P41 6 P42 7 P43 8 P44 9 P45 10 P46 11 P47 12 VDD 13 VSS 14 VDDL 15 XT0 16 XT1 17 RESET_N 18 TEST0 19 TEST1_N 20 VL1 21 VL2 22 VL3 23 C0 24 C1 25 COM0 26 COM1 27 COM2/SEG0 28 COM3/SEG1 29 COM4/SEG2 30 SEG3 31 SEG4 32 SEG5 33 SEG6 34 35 SEG7 SEG8 36 SEG9 37 SEG10 38 SEG11 39 SEG12 40 SEG13 41 SEG14 42 SEG15 43 SEG16 44 SEG17 45 SEG18 46 SEG19 47 SEG20 48 SEG21 ML610Q407/8/9 X (µm) Y (µm) -853 -1009 -773 -1009 -693 -1009 -613 -1009 -533 -1009 -453 -1009 -373 -1009 -293 -1009 -213 -1009 -133 -1009 -53 -1009 27 -1009 107 -1009 187 -1009 267 -1009 427 -1009 507 -1009 587 -1009 667 -1009 747 -1009 827 -1009 907 -1009 1029 -840 1029 -760 1029 -680 1029 -600 1029 -520 1029 -440 1029 -360 1029 -280 1029 -200 1029 -120 1029 -40 1029 40 1029 120 1029 200 1029 280 1029 360 1029 440 1029 520 1029 600 1029 680 1029 760 1029 840 855 1009 775 1009 695 1009 615 1009 PAD No. Pad Name 49 SEG22 50 SEG23 51 SEG24 52 SEG25 53 SEG26 54 SEG27 55 SEG28 56 SEG29 57 SEG30 58 SEG31 59 60 61 62 63 64 65 66 P67 (*1) SEG32 (*2)(*3) P66 P65 (*1) SEG34 (*2)(*3) P64 (*1) SEG35 (*2)(*3) P63 (*1)(*2) SEG36 (*3) P62 (*1)(*2) SEG37 (*3) 1009 1009 1009 1009 1009 1009 1009 1009 1009 1009 -295 1009 -375 1009 -455 1009 -535 1009 -615 1009 -695 1009 -775 1009 -885 1009 -1029 -1029 --1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 -1029 850 770 690 610 530 430 350 270 190 110 30 -50 -130 -210 -290 -370 -450 -530 -610 -690 -770 -850 (*1)(*2) SEG38 (*3) P60 535 455 375 295 215 135 55 -25 -105 -185 (*1) SEG33 (*2)(*3) P61 ML610Q407/8/9 X (µm) Y (µm) (*1)(*2) SEG39 (*3) 67 VSS 68 P20 69 P21 70 P22 71 P24 72 P00 73 P01 74 75 P02 P03 76 P04 77 P30 78 P31 79 P34 80 P32 81 P33 82 P35 83 P57 84 P56 85 P55 86 P54 87 P53 88 VPP ML610Q407 pad name, (*2) ML610Q408 pad name, (*3) ML610Q409 pad name 12/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 PIN LIST Primary function PIN No. PAD No. Pin name I/O Function 14,77 13 13,67 12 Vss VDD ⎯ ⎯ 15 14 VDDL ⎯ 98 88 VPP ⎯ 22 20 VL1 ⎯ 23 21 VL2 ⎯ 24 22 VL3 ⎯ 27 23 C1 ⎯ 28 24 C2 ⎯ Negative power supply pin Positive power supply pin Power supply pin for internal logic (internally generated) Power supply pin for Flash ROM Power supply pin for LCD bias (internally generated or connected to positive power supply pin)(*2) Power supply pin for LCD bias (internally generated or connected to positive power supply pin)(*2) Power supply pin for LCD bias (internally generated) Capacitor connection pin for LCD bias generation Capacitor connection pin for LCD bias generation Test pin 20 18 TEST0 I/O 21 19 17 18 19 17 15 16 TEST1_N RESET_N XT0 XT1 I I I O 82 72 P00/EXI0/ CAP0 I 83 73 P01/EXI1/ CAP1 I 84 74 P02/EXI2/ RXD0 I 85 75 P03/EXI3 I 86 76 P04/EXI4/ T02P0CK I 78 79 80 81 68 69 70 71 P20/LED0 P21/LED1 P22/LED2 P24/LED4 87 77 88 Secondary function or Tertiary function Secondary /Tertiary ⎯ ⎯ Pin name I/O Function ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ O O O O Test pin Reset input pin Low-speed clock oscillation pin Low-speed clock oscillation pin Input port, External interrupt, Capture 0 input Input port, External interrupt, Capture 1 input Input port, External interrupt, UART0 received data Input port, External interrupt Input port, Timer 0/Timer 2/PWM0 external clock input External interrupt Output port Output port Output port Output port Secondary Secondary Secondary Secondary LSCLK OUTCLK MD0 PWM0 O O O O P30 I/O Input/output port Secondary IN0 I 78 P31 I/O Input/output port Secondary CS0 O 89 79 P34 I/O Input/output port Secondary RCT0 O 90 80 P32 I/O Input/output port Secondary RS0 O 91 81 P33 I/O Input/output port Secondary RT0 O 92 82 P35 I/O Input/output port Secondary RCM O Low-speed clock output High-speed clock output Melody 0 output PWM0 output RC type ADC0 oscillation input pin RC type ADC0 reference capacitor connection pin RC type ADC0 resistor/capacitor sensor connection pin RC type ADC0 reference resistor connection pin RC type ADC0 measurement resistor sensor connection pin RC type ADC oscillation monitor 13/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 Primary function PIN No. PAD No. Pin name I/O 5 4 P40 I/O Input/output port 6 5 P41 I/O Input/output port 7 6 P42 I/O Input/output port 8 7 P43 I/O Input/output port 9 8 P44/ T02P0CK I/O Input/output port, Timer 0/Timer 2/PWM0 external clock input P45/T13CK I/O 10 11 9 10 P46 I/O Function Input/output port, Timer 1/Timer 3 external clock input Input/output port Secondary function or Tertiary function Secondary /Tertiary Secondary Tertiary Secondary Pin name I/O Function ⎯ SIN0 ⎯ ⎯ I ⎯ Tertiary SCK0 I/O Secondary Tertiary Secondary Tertiary RXD0 SOUT0 TXD0 PWM0 I O O O Secondary IN1 I Tertiary SIN0 I Secondary CS1 O ⎯ SSIO0 data input ⎯ SSIO0 synchronous clock input/output UART data input SSIO0 data output UART data output PWM0 output RC type ADC1 oscillation input pin SSIO0 data input RC type ADC1 reference capacitor connection pin Tertiary SCK0 I/O Secondary RS1 O Tertiary SOUT0 O 12 11 P47 I/O Input/output port Secondary RT1 O 4 3 P50/EXI8 I/O Input/output port, External interrupt 3 2 P51/EXI8 I/O Input/output port, External interrupt Secondary Tertiary Secondary MD0 SIN1 ⎯ O I ⎯ Tertiary SCK1 I/O 2 1 P52/EXI8 I/O Secondary Tertiary ⎯ SOUT1 ⎯ O 97 87 P53/EXI8 I/O ⎯ ⎯ ⎯ 96 86 P54/EXI8 I/O Secondary Tertiary Secondary 95 85 P55/EXI8 I/O ⎯ SIN1 ⎯ ⎯ I ⎯ Tertiary SCK1 I/O 94 84 P56/EXI8 I/O Secondary Tertiary ⎯ SOUT1 ⎯ O 93 83 P57/EXI8 I/O ⎯ ⎯ ⎯ Input/output port, External interrupt Input/output port, External interrupt Input/output port, External interrupt Input/output port, External interrupt Input/output port, External interrupt Input/output port, External interrupt SSIO0 synchronous clock input/output RC type ADC1 reference resistor connection pin SSIO0 data output RC type ADC1 measurement resistor sensor connection pin Melody 0 output SSIO1 data input ⎯ SSIO1 synchronous clock input/output ⎯ SSIO1 data output ⎯ ⎯ SSIO1 data input ⎯ SSIO1 synchronous clock input/output ⎯ SSIO1 data output ⎯ 14/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 PIN No. PAD No. 29 30 25 26 31 27 32 28 33 29 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 52 53 54 55 56 57 58 59 60 61 62 63 64 65 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 66 59 67 60 68 61 69 62 70 63 71 64 72 65 73 66 Primary function Secondary function or Tertiary function Secondary/ Tertiary ⎯ ⎯ Pin name ⎯ ⎯ I/O Function ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ LCD common/segment pin ⎯ ⎯ ⎯ ⎯ LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin LCD segment pin Output port LCD segment pin Output port LCD segment pin Output port LCD segment pin Output port LCD segment pin Output port LCD segment pin Output port LCD segment pin Output port LCD segment pin Output port LCD segment pin ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ Pin name I/O Function COM0 COM1 COM2/ SEG0 COM3/ SEG1 COM4/ SEG2 SEG3 SEG4 SEG5 SEG6 SEG7 SEG8 SEG9 SEG10 SEG11 SEG12 SEG13 SEG14 SEG15 SEG16 SEG17 SEG18 SEG19 SEG20 SEG21 SEG22 SEG23 SEG24 SEG25 SEG26 SEG27 SEG28 SEG29 SEG30 SEG31 P67(*2) SEG32(*3) P66(*2) SEG33(*3) P65(*2) SEG34(*3) P64(*2) SEG35(*3) P63(*4) SEG36(*5) P62(*4) SEG37(*5) P61(*4) SEG38(*5) P60(*4) SEG39(*5) O O LCD common pin LCD common pin O LCD common/segment pin ⎯ O LCD common/segment pin O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O 1 (* ) Internally generated, or connect to either positive power supply pin (VDD) or power supply pin for internal logic (VDDL). For details, see “Chapter 22 LCD Drivers. In the user’s manual” 2 (* ) Pin for ML610Q407/ML610Q408. 3 (* ) Pin for ML610Q409. 4 (* ) Pin for ML610Q407. 5 (* ) Pin for ML610Q408/ML610Q409. 15/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 PIN DESCRIPTION Pin name I/O Description Primary/ Secondary/ Tertiary Logic System Reset input pin. When this pin is set to a “L” level, system reset mode is — Negative set and the internal section is initialized. When this pin is set to a “H” level subsequently, program execution starts. A pull-up resistor is internally connected. XT0 I Crystal connection pin for low-speed clock. — — XT1 O A 32.768 kHz crystal oscillator (see measuring circuit 1) is connected to — — this pin. Capacitors CDL and CGL are connected across this pin and VSS . LSCLK O Low-speed clock output pin. This pin is used as the secondary function of Secondary — the P20 pin. OUTCLK O High-speed clock output pin. This pin is used as the secondary function of Secondary — the P21 pin. General-purpose input port RESET_N I General-purpose input port. Since these pins have secondary functions, the pins cannot be used as a port when the secondary functions are used. General-purpose output port P20-P22,P24 O General-purpose output port. Since these pins have secondary functions, the pins cannot be used as a port when the secondary functions are used. General-purpose input/output port P30-P35 I/O General-purpose input/output port. Since these pins have secondary functions, the pins cannot be used as a port when the secondary functions are used. P40-P47 I/O General-purpose input/output port. Since these pins have secondary functions, the pins cannot be used as a port when the secondary functions are used. P50-P57 I/O General-purpose input/output port. Since these pins have secondary functions, the pins cannot be used as a port when the secondary functions are used. P60-P63 O General-purpose input/output port. These pins are for the ML610Q407/ ML610Q408, but are not provided in the ML610Q409. P64-P67 O General-purpose input/output port. These pins are for the ML610Q407, but are not provided in the ML610Q409. P00-P04 I Primary Positive Primary Positive Primary Positive Primary Positive Primary Positive Primary Positive Primary Positive 16/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 Pin name Primary/ Secondary/ Tertiary Logic Secondary Positive Primary/ Secondary Positive Tertiary — Tertiary Positive Tertiary Positive Secondary — Secondary Positive Secondary Positive Tertiary Positive Primary — External maskable interrupt input pins. Interrupt enable and edge selection can be performed for each bit by software. These pins are used as the primary functions of the P00-P04 pins. External maskable interrupt input pins. Interrupt enable and edge selection can be performed for each bit by software. These pins are used as the primary functions of the P50-P57 pins. Primary Positive/ negative Primary Positive/ negative Capture trigger input pins. The value of the time base counter is captured in the register synchronously with the interrupt edge selected by software. These pins are used as the primary functions of the P00 pin(CAP0) and P01 pin(CAP1). Primary Positive/ negative Positive/ negative I/O UART TXD0 O RXD0 I Description UART data output pin. This pin is used as the secondary function of the P43 pin. UART data input pin. This pin is used as the secondary function of the P42 or the primary function of the P02 pin. Synchronous serial (SSIO) SCK0 SIN0 SOUT0 SCK1 SIN1 SOUT1 PWM PWM0 T02P0CK I/O Synchronous serial clock input/output pin. This pin is used as the tertiary function of the P41 or P45 pin. I Synchronous serial data input pin. This pin is used as the tertiary function of the P40 or P44 pin. O Synchronous serial data output pin. This pin is used as the tertiary function of the P42 or P46 pin. I/O Synchronous serial clock input/output pin. This pin is used as the secondary function of the P51 or P55 pin. I Synchronous serial data input pin. This pin is used as the secondary function of the P50 or P54. O Synchronous serial data output pin. This pin is used as the secondary function of the P52 or P56pin. O I External interrupt EXI0-4 I EXI8 I Capture CAP0 I CAP1 I Timer T02P0CK T13CK I I PWM0 output pin. This pin is used as the tertiary function of the P43 or P34 pin. PWM0 external clock input pin. This pin is used as the primary function of the P44 pin. External clock input pin used for Timer 0 and Timer 2. The clock for this timer is selected by software. This pin is used as the primary function of the P44 pin. External clock input pin used both Timer 1 and Timer 3. The clock for this timer is selected by software. This pin is used as the primary function of the P45 pin. Melody MD0 O Melody/Buzzer signal output pin. This pin is used as the secondary function of the P22 pin and P50 pin. LED drive LED0-2,4 O Nch open drain output pins to drive LED. Primary Primary — Primary — Secondary Positive/ negative Primary Positive/ negative 17/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 Pin name I/O Description RC oscillation type A/D converter IN0 I Channel 0 oscillation input pin. This pin is used as the secondary function of the P30 pin. CS0 O Channel 0 reference capacitor connection pin. This pin is used as the secondary function of the P31 pin. RCT0 O Resistor/capacitor sensor connection pin of Channel 0 for measurement. This pin is used as the secondary function of the P33 pin. RS0 O This pin is used as the secondary function of the P32 pin which is the reference resistor connection pin of Channel 0. RT0 O Resistor sensor connection pin of Channel 0 for measurement. This pin is used as the secondary function of the P34 pin. RCM O RC oscillation monitor pin. This pin is used as the secondary function of the P35 pin. IN1 I Oscillation input pin of Channel 1. This pin is used as the secondary function of the P44 pin. CS1 O Reference capacitor connection pin of Channel 1. This pin is used as the secondary function of the P45 pin. RS1 O Reference resistor connection pin of Channel 1. This pin is used as the secondary function of the P46 pin. RT1 O Resistor sensor connection pin for measurement of Channel 1. This pin is used as the secondary function of the P47 pin. LCD drive signal COM0-4 O Common output pins. SEG0-31 O Segment output pins. Segment output pin. These pins are for the ML610Q408/ML610Q409, but are not provided in the ML610Q407. SEG36-39 O Segment output pin. These pins are for the ML610Q409, but are not provided in the ML610Q407/ML610Q408. LCD driver power supply VL1 — Power supply pins for LCD bias (internally generated or positive power VL2 — supply pin connected ). Depending on LCD Bias setting and VDD voltage level, VDD or VDDL or capacitor is connected. For details of the connection VL3 — method, see user’s manual. C1 — Power supply pins for LCD bias (internally generated). Capacitors C12 is connected between C1 and C2. C2 — For testing TEST I/O Input/output pin for testing. A pull-down resistor is internally connected. SEG32-35 O Power supply VSS — VDD — VDDL — VPP — Negative power supply pin. Positive power supply pin for I/O, internal regulator, battery low detector, and power-on reset. Positive power supply pin (internally generated) for internal logic. Capacitor CL (see Appendix C measuring circuit 1) is connected between this pin and VSS. Power supply pin for programming Flash ROM. A pull-down resistor is internally connected. Primary/ Secondary/ Tertiary Secondary Secondary Secondary Secondary Secondary Secondary Secondary Secondary Secondary Secondary Logic — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — 18/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 TERMINATION OF UNUSED PINS Table 2 shows methods of terminating the unused pins. Table 2 Pin VPP VL1, VL2, VL3 C1, C2 RESET_N TEST0 TEST1_N P00 to P04 P20 to P22, P24 P30 to P35 P40 to P47 P50 to P57 P60 to P67 COM0 to 4 SEG0 to 39 Termination of Unused Pins Recommended pin termination Open Open Open Open Open Open VDD or VSS Open Open Open Open Open Open Open Note: It is recommended to set the unused input ports and input/output ports to the inputs with pull-down resistors/pull-up resistors or the output mode since the supply current may become excessively large if the pins are left open in the high impedance input setting. 19/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS (VSS = 0V) Parameter Power supply voltage 1 Symbol Condition Rating Unit VDD Ta = 25°C −0.3 to +4.6 V Power supply voltage 2 VPP Ta = 25°C −0.3 to +9.5 V Power supply voltage 3 VDDL Ta = 25°C −0.3 to +3.6 V Power supply voltage 4 VL1 Ta = 25°C −0.3 to +2.0 V Power supply voltage 5 VL2 Ta = 25°C −0.3 to +4.0 V Power supply voltage 6 VL3 Ta = 25°C −0.3 to +6.0 V Input voltage VIN Ta = 25°C −0.3 to VDD+0.3 V Output voltage VOUT Ta = 25°C −0.3 to VDD+0.3 V Output current 1 IOUT1 Port3–6, Ta = 25°C −12 to +11 mA Output current 2 IOUT2 Port2, Ta = 25°C −12 to +20 mA Power dissipation PD Ta = 25°C 0.9 W Storage temperature TSTG ⎯ −55 to +150 °C RECOMMENDED OPERATING CONDITIONS (VSS = 0V) Parameter Symbol Condition Range non-P version P version fOP = 30k to 625kHz −20 to +70 −40 to +85 1.25 to 3.6 fOP = 30k to 2.5MHz VDD = 1.25 to 3.6V VDD = 1.8 to 3.6V 1.8 to 3.6 30k to 625k 30k to 2.5M CL ⎯ 0.47±30% µF Ca, b, c ⎯ 0.1±30% µF C12 ⎯ 0.47±30% µF Operating temperature TOP Operating voltage VDD Operating frequency (CPU) fOP Capacitor externally connected to VDDL pin Capacitors externally connected to VL1, 2, 3 pins Capacitors externally connected across C1 and C2 pins Unit °C V Hz CLOCK GENERATION CIRCUIT OPERATING CONDITIONS (VSS = 0V) Parameter Low-speed crystal oscillation frequency Recommended equivalent series resistance value of low-speed crystal oscillation Low-speed crystal oscillation external capacitor Symbol Condition fXTL Rating Unit Min. Typ. Max. ⎯ ⎯ 32.768k ⎯ Hz RL ⎯ ⎯ ⎯ 40k Ω ⎯ 12 ⎯ CDL/CGL CL=6pF of crystal oscillation CL=9pF of crystal oscillation CL=12pF of crystal oscillation ⎯ 18 ⎯ ⎯ 24 ⎯ pF 20/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 OPERATING CONDITIONS OF FLASH ROM Parameter Operating temperature Symbol TOP VDD VDDL VPP CEP YDR Operating voltage erase/program cycles Data retention *1 Condition At write/erase *1 At write/erase *1 At write/erase *1 At write/erase ⎯ ⎯ Range 0 to +40 2.75 to 3.6 2.5 to 2.75 7.7 to 8.3 80 10 (VSS = 0V) Unit °C V cycles years : Those voltages must be supplied to VDDL pin and VPP pin when programming and eraseing Flash ROM. VPP pin has an internal pulldown resister. DC CHARACTERISTICS (1/5) (VDD = 1.25 to 3.6V, VSS = 0V, Ta = −20 to +70°C, Ta = −40 to +85°C for P version, unless otherwise specified) Measuring Rating Parameter Symbol Condition Unit circuit Min. Typ. Max. Typ. Typ. 500 Ta = 25°C +10% −10% VDD = 1.25 kHz to 3.6V Typ. Typ. 3 500 * +25% −25% 500kHz/2MHz RC oscillation fRC frequency Typ. Typ. 2.0 Ta = 25°C +10% −10% VDD = 1.80 MHz to 3.6V Typ. Typ. 3 2.0 * +25% −25% Low-speed crystal oscillation ⎯ ⎯ 0.6 2 s TXTL 2 1 start time* 500kHz/2MHz RC oscillation ⎯ ⎯ ⎯ 0.3 µs TRC start time Low-speed oscillation stop TSTOP ⎯ 12 16.4 41 ms *1 detect time Reset pulse width PRST ⎯ 200 ⎯ ⎯ µs Reset noise elimination ⎯ ⎯ ⎯ 0.3 PNRST pulse width Power-on reset activation ⎯ ⎯ ⎯ 10 ms TPOR power rise time 1 * : When low-speed crystal oscillation stops for a duration more than the low-speed oscillation stop detect time, the system is reset to shift to system reset mode. 2 * : 32.768KHz Crystal resonator DT-26 (Load capacitance 6pF) (made by KDS:DAISHINKU CORP.) is used (CGL=CDL=6pF). 3 * : Recommended operating temperature (Ta = −20 to +70°C, Ta = −40 to +85°C for P version) VIL1 RESET_N VIL1 PRST Reset pulse width (PRST) 0.9xVDD VDD 0.1xVDD TPOR Power-on reset activation power rise time (TPOR ) 21/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 DC CHARACTERISTICS (2/5) (VDD = 1.25 to 3.6V, VSS = 0V, Ta = −20 to +70°C, Ta = −40 to +85°C for P version, unless otherwise specified) Measuring Rating Parameter Symbol Condition Unit circuit Min. Typ. Max. VDDL voltage VDDL fOP = 30k to 625kHz fOP = 30k to 2.5MHz 1.1 1.35 1.2 1.5 1.3 1.65 VDDL temperature 1 VDD = 3.0V ⎯ -1 ⎯ mV/°C ∆VDDL 1 deviation * VDDL voltage ∆VDDL ⎯ ⎯ 5 20 mV/V 1 dependency * 1 * :VDDL can not exceed VDD level. The maximum VDDL becomes VDD level when the VDDL calculated by the temperature deviation and voltage dependency is going to exceed the VDD level. 22/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 DC CHARACTERISTICS (3/5) Parameter Supply current 1 Supply current 2 Supply current 3 Supply current 4-1 Supply current 4-2 Symbol IDD1 IDD2 IDD3 IDD4-1 IDD4-2 (VDD = 3.0V, VSS = 0V, Ta = −20 to +70°C, Ta = −40 to +85°C for P version) Measuring Rating Condition Unit circuit Min. Typ. Max. CPU: In STOP state. Low-speed/high-speed RC500kHz/2MHz oscillation: stopped. CPU: In HALT state (LTBC and WDT 3 4 are Operating).* * High-speed 500kHz/2MHz oscillation: Stopped. 6 LCD and BIAS circuits: Operating. * CPU: In 32.768kHz operating 1 3 state.* * High-speed 500kHz/2MHz oscillation: Stopped. 2 LCD and BIAS circuits: Operating. * CPU: In RC 500kHz operating state. 2 LCD and BIAS circuits: Operating. * CPU: In RC 2MHz operating state. 2 LCD and BIAS circuits: Operating. * Ta= 25°C ⎯ 0.4 0.8 µA 5 * ⎯ ⎯ 8 Ta= 25°C ⎯ 0.9 1.8 µA 5 * ⎯ ⎯ 9 Ta= 25°C ⎯ 5 8 µA 5 * ⎯ ⎯ 15 Ta= 25°C ⎯ 70 100 * ⎯ ⎯ 120 Ta= 25°C ⎯ 280 350 1 µA 5 µA 5 * ⎯ ⎯ 400 1 * : When the CPU operating rate is 100% (No HALT state). 2 * : All SEGs: off waveform, No LCD panel load, 1/3 bias, 1/3 duty, Frame frequency: Approx. 64 Hz, Bias voltage multiplying clock: 1/128 LSCLK (256Hz) 3 * : 32.768KHz Crystal resonator DT-26 (Load capacitance 6pF) (made by KDS:DAISHINKU CORP.) is used (CGL=CDL=6pF) 4 * : Significant bits of BLKCON0~BLKCON4 registers except DLCD bit on BLKCON4 are all “1”. 5 * : Recommended operating temperature (Ta = −20 to +70°C, Ta = −40 to +85°C for P version) 6 * : LCD Stop mode, 1/3 bias, Bias voltage multiplying clock: 1/128 LSCLK (256Hz) 23/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 DC CHARACTERISTICS (4/5) (VDD = 1.25 to 3.6V, VSS = 0V, Ta = −20 to +70°C, Ta = −40 to +85°C for P version, unless otherwise specified) Rating Measuring Parameter Symbol Condition Unit circuit Min. Typ. Max. Output voltage 1 (P20–P22,P24/ nd 2 function is selected) (P30–P36) (P40–P47) (P50–P57) *1 *2 (P60-P63) *1 (P64-P67) Output voltage 2 (P20–P22,P24/ nd 2 function is Not selected) Output voltage 3 (COM0–4) *1 (SEG0–31) *2 (SEG0–35) *3 (SEG0–39) Output leakage (P20–P22, P24) (P30–P35) (P40–P47) (P50–P57) *1 *2 (P60-P63) *1 (P64-P67) Input current 1 (RESET_N, TEST1_N) Input current 2 (TEST0) IOL1 = +0.1mA, VDD = 1.25 to 3.6V ⎯ ⎯ ⎯ ⎯ ⎯ 0.5 ⎯ ⎯ 0.3 IOL2 = +5mA, VDD = 1.8 to 3.6V ⎯ ⎯ 0.5 VOH3 IOH4 = −0.05mA, VL1=1.2V VL3 −0.2 ⎯ ⎯ VOML3 IOMH4 = +0.05mA, VL1=1.2V ⎯ ⎯ VL2 +0.2 VOML3S IOM4S = −0.05mA, VL1=1.2V VL2 −0.2 ⎯ ⎯ VOLM3 IOML4 = +0.05mA, VL1=1.2V ⎯ ⎯ VL1 +0.2 VOLM3S IOML4S = −0.05mA, VL1=1.2V VL1 −0.2 ⎯ ⎯ VOL3 IOL4 = +0.05mA, VL1=1.2V ⎯ ⎯ 0.2 IOOH VOH = VDD (in high-impedance state) ⎯ ⎯ 1 VOH1 IOH1 = -0.03mA, VDD = 1.25 to 3.6V VOL1 VOL2 IOOL VOL = VSS (in high-impedance state) −1 ⎯ ⎯ IIH1 VIH1 = VDD 0 ⎯ 1 IIL1 VIL1 = VSS -600 -300 -2 IIH2 IIL2 VIH1 = VDD VIL1 = Vss VIH3 = VDD ,VDD = 1.8 to 3.6V (when pulled-down) VIH3 = VDD ,VDD = 1.25 to 3.6V (when pulled-down) VIL3 = VSS , VDD = 1.8 to 3.6V (when pulled-up) VIL3 = VSS , VDD = 1.25 to 3.6V (when pulled-up) 2 -1 300 ⎯ 600 ⎯ 2 30 200 IIH3 Input current 3 (P00-P04) (P30-P35) (P40-P47) (P50-P57) IOL1 = +0.5mA, VDD = 1.8 to 3.6V VDD −0.5 VDD −0.3 ⎯ IOH1 = −0.5mA, VDD = 1.8 to 3.6V IIL3 -200 -30 -2 -200 -30 -0.01 IIH3Z VIH3 = VDD (in high-impedance state) ⎯ ⎯ 1 IIL3Z VIL3 = VSS (in high-impedance state) −1 ⎯ ⎯ V 2 µA 3 µA 4 1 * : pins for ML610Q407 2 * : pins for ML610Q408 3 * : pins for ML610Q409 24/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 DC CHARACTERISTICS (5/5)) (VDD = 1.25 to 3.6V, VSS = 0V, Ta = −20 to +70°C, Ta = −40 to +85°C for P version, unless otherwise specified) Rating Measuring Parameter Symbol Condition Unit circuit Min. Typ. Max. Input voltage 1 (RESET_N) (TEST0, TEST1_N) (P00–P04) (P30–P35) (P40–P47) (P50–P57) Input pin capacitance (P00–P04) (P30–P35) (P40–P47) (P50–P57) VIH1 ⎯ 0.7 ×VDD ⎯ VDD = 1.8 to 3.6V 0 ⎯ VDD = 1.25 to 3.6V 0 ⎯ f = 10kHz Vrms = 50mV Ta = 25°C ⎯ ⎯ VIL1 CIN VDD 0.3 ×VDD 0.2 ×VDD 5 V 5 pF ⎯ 25/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 MEASURING CIRCUITS MEASURING CIRCUIT 1 CGL XT0 32.768kHz crystal XT1 C2 CDL C12 C1 VDD VDDL VL1 VL2 VL3 VSS CV: CL: Ca,Cb,Cc: C12: 32.768kHz crystal: A CV CL Ca Cc 1µF 0.47µF 0.1µF 0.47µF DT-26 (Load capacitance 6pF) (made by KDS:DAISHINKU CORP.) CGL, CDL: 6pF MEASURING CIRCUIT 2 (*2) VIL Input pins (*1) Output pins VIH VDD VDDL VL1 VL2 VL3 V VSS (*1) Input logic circuit to determine the specified measuring conditions. (*2) Measured at the specified output pins. 26/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 MEASURING CIRCUIT 3 (*2) VIL Input pins RS1 Output pins VIH VDD VDDL VL1 VL2 VL3 A VSS *1: Input logic circuit to determine the specified measuring conditions. *2: Measured at the specified output pins. MEASURING CIRCUIT 4 Input pins Output pins (*3) A VDD VDDL VL1 VL2 VL3 VSS *3: Measured at the specified output pins. VIL Input pins (*1) Output pins VIH VDD VDDL VL1 VL2 VL3 Waveform monitoring MEASURING CIRCUIT 5 VSS *1: Input logic circuit to determine the specified measuring conditions. 27/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 AC CHARACTERISTICS (External Interrupt) (VDD = 1.25 to 3.6V, VSS = 0V, Ta = −20 to +70°C, Ta = −40 to +85°C for P version, unless otherwise specified) Rating Parameter Symbol Condition Unit Min. Typ. Max. External interrupt disable period TNUL Interrupt: Enabled (MIE = 1), CPU: NOP operation System clock: 32.768kHz ⎯ 76.8 106.8 µs P00–P04 (Rising-edge interrupt) tNUL P00–P04 (Falling-edge interrupt) tNUL P00–P04 (Both-edge interrupt) tNUL AC CHARACTERISTICS (Serial Port) (VDD = 1.25 to 3.6V, VSS = 0V, Ta = −20 to +70°C, Ta = −40 to +85°C for P version, unless otherwise specified) Rating Parameter Symbol Condition Unit Min. Typ. Max. Transmit baud rate ⎯ tTBRT 1 ⎯ BRT* 1 ⎯ s 1 BRT* BRT* 1 BRT* −3% +3% *1: Baud rate period (including the error of the clock frequency selected) set with the serial port baud rate register (SIOBRTL,H) and the serial port mode register 0 (SIOMOD0). Receive baud rate ⎯ tRBRT s tTBRT TXD0* tRBRT RXD0* *: Indicates the secondary function of the port. 28/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 AC CHARACTERISTICS (Synchronous Serial Port) (VDD = 1.25 to 3.6V, VSS = 0V, Ta = −20 to +70°C, Ta = −40 to +85°C for P version, unless otherwise specified) Rating Parameter Symbol Condition Unit Min. Typ. Max. When RC oscillation is 500kHz 10 ⎯ ⎯ 2 * (VDD = 1.25 to 3.6V) SCLKn input cycle µs tSCYC (slave mode) When RC oscillation is 2MHz 2 ⎯ ⎯ 3 * (VDD = 1.8 to 3.6V) SCLKn output cycle 1 ⎯ ⎯ SCLKn* ⎯ s tSCYC (master mode) When RC oscillation is 500kHz 4 ⎯ ⎯ 2 * (VDD = 1.25 to 3.6V) SCLKn input pulse width µs tSW (slave mode) When RC oscillation is 2MHz 04 ⎯ ⎯ 3 * (VDD = 1.8 to 3.6V) 1 1 1 SCLKn* SCLKn* SCLKn* SCLKn output pulse width s ⎯ tSW (master mode) ×0.5 ×0.4 ×0.6 When RC oscillation is 500kHz 2 * (VDD = 1.25 to 3.6V) ⎯ ⎯ 500 output load 10pF SOUTn output delay time ns tSD (slave mode) When RC oscillation is 2MHz 3 * (VDD = 1.8 to 3.6V) ⎯ ⎯ 240 output load 10pF When RC oscillation is 500kHz 2 * (VDD = 1.25 to 3.6V) ⎯ ⎯ 500 output load 10pF SOUTn output delay time tSD ns (master mode) When RC oscillation is 2MHz 3 * (VDD = 1.8 to 3.6V) ⎯ ⎯ 240 output load 10pF SINn input setup time tSS ⎯ 80 ⎯ ⎯ ns (slave mode) When RC oscillation is 500kHz 500 ⎯ ⎯ 2 * (VDD = 1.25 to 3.6V) SINn input setup time ns tSS (master mode) When RC oscillation is 2MHz 240 ⎯ ⎯ 3 * (VDD = 1.8 to 3.6V) When RC oscillation is 500kHz 300 ⎯ ⎯ 2 * (VDD = 1.25 to 3.6V) SINn input hold time ns tSH When RC oscillation is 2MHz 80 ⎯ ⎯ 3 * (VDD = 1.8 to 3.6V) n= 0,1 *1: Clock period selected with SnCK3–0 of the serial port n mode register (SIOnMOD1) 2 * : When 500kHz RC oscillation is selected by OSCM2 of the frequency control register (FCON0) 3 * : When 2MHz RC oscillation is selected by OSCM2 of the frequency control register (FCON0) tSW tSCYC tSW SCLKn* tSD tSD SOUTn* tSS tSH SINn* *: Indicates the secondary function of the port (n= 0,1) 29/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 AC CHARACTERISTICS (RC Oscillation A/D Converter) Condition for VDD=1.8 to 3.6V (VDD=1.8 to 3.6V, VSS=0V, Ta=-20 to +70°C, Ta=-40 to +85°C for P version, unless otherwise specified) Rating Parameter Symbol Condition Unit Min. Typ. Max. RS0,RS1,RT0, Oscillation resistor 1 ― ― CS0, CT0, CS1≥740pF kΩ RT0-1,RT1 fOSC1 457.3 525.2 575.1 kHz Resistor for oscillation=1kΩ Oscillation frequency fOSC2 53.48 58.18 62.43 kHz Resistor for oscillation=10kΩ VDD = 3.0V fOSC3 5.43 5.89 6.32 kHz Resistor for oscillation=100kΩ Kf1 7.972 9.028 9.782 RT0, RT0-1, RT1=1kΩ ⎯ RS to RT oscillation *1 frequency ratio Kf2 0.981 1 1.019 RT0, RT0-1, RT1=10kΩ ⎯ VDD = 3.0V Kf3 0.099 0.101 0.104 RT0, RT0-1, RT1=100kΩ ⎯ *1: Kfx is the ratio of the oscillation frequency by the sensor resistor to the oscillation frequency by the reference resistor on the same conditions. , fOSCX(RT0-1-CS0 oscillation) fOSCX(RS0-CS0 oscillation) IN0 CS0 RCT0 (Note 1) VIL VDDL fOSCX(RT1-CS1 oscillation) fOSCX(RS1-CS1 oscillation) RT0, RT0-1, RT1: 1kΩ/10kΩ/100kΩ RS0, RS1: 10kΩ CS0, CT0, CS1: 560pF CVR0, CVR1: 820pF IN1 CS1 RS1 RT1 RCM VDD CV RT1 RT0 RS0 RS0 RT0 Input pin VIH , CVR1 RT0-1 CT0 CS0 CVR0 RS1 fOSCX(RT0-CS0 oscillation) fOSCX(RS0-CS0 oscillation) ( x = 1, 2, 3 ) CS1 Kfx = Frequency measurement (fOSCX) VSS CL *1: Input logic circuit to determine the specified measuring conditions. 30/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 Condition for VDD=1.25 to 3.6V (VDD=1.25 to 3.6V, VSS=0V, Ta=-20 to +70°C, Ta=-40 to +85°C for P version, unless otherwise specified) Rating Parameter Symbol Condition Unit Min. Typ. Max. RS0,RS1,RT0, Oscillation resistor 1 ― ― CS0, CT0, CS1≥740pF kΩ RT0-1,RT1 fOSC1 81.93 93.16 101.2 kHz Resistor for oscillation=6kΩ Oscillation frequency fOSC2 35.32 38.75 41.48 kHz Resistor for oscillation=15kΩ VDD = 1.5V 5.22 5.65 6.03 kHz fOSC3 Resistor for oscillation=105kΩ Kf1 2.139 2.381 2.632 RT0, RT0-1, RT1=1kΩ ⎯ RS to RT oscillation *1 frequency ratio Kf2 0.973 1 1.028 RT0, RT0-1, RT1=10kΩ ⎯ VDD = 1.5V Kf3 0.142 0.147 0.152 RT0, RT0-1, RT1=100kΩ ⎯ fOSC1 85.28 94.58 103.3 kHz Resistor for oscillation=6kΩ Oscillation frequency fOSC2 35.72 38.87 41.78 kHz Resistor for oscillation=15kΩ VDD = 3.0V fOSC3 5.189 5.622 6.012 kHz Resistor for oscillation=105kΩ Kf1 2.227 2.432 2.626 RT0, RT0-1, RT1=1kΩ ⎯ RS to RT oscillation *1 frequency ratio Kf2 0.982 1 1.018 RT0, RT0-1, RT1=10kΩ ⎯ VDD = 3.0V Kf3 0.141 0.145 0.149 RT0, RT0-1, RT1=100kΩ ⎯ *1: Kfx is the ratio of the oscillation frequency by the sensor resistor to the oscillation frequency by the reference resistor on the same conditions. fOSCX(RT0-1-CS0 oscillation) fOSCX(RS0-CS0 oscillation) , IN0 CS0 RCT0 VIH , RA1 RT1 RA0 RT0 RS0 RS0 RT0 RT0, RT0-1, RT1: 1kΩ/10kΩ/100kΩ RA0, RA0-1, RA1: 5kΩ RS0, RS1: 15kΩ CS0, CT0, CS1: 560pF CVR0, CVR1: 820pF IN1 CS1 RS1 RT1 Frequency measurement (fOSCX) Input pin RCM (Note 1) fOSCX(RT1-CS1 oscillation) fOSCX(RS1-CS1 oscillation) CVR1 RT0-1 RA0-1 CT0 CS0 CVR0 RS1 fOSCX(RT0-CS0 oscillation) fOSCX(RS0-CS0 oscillation) ( x = 1, 2, 3 ) CS1 Kfx = VIL VDD CV VDDL VSS CL *1: Input logic circuit to determine the specified measuring conditions. Note: - Please have the shortest layout for the common node (wiring patterns which are connected to the external capacitors, resistors and IN0/IN1 pin), including CVR0/CVR1. Especially, do not have long wire between IN0/IN1 and RS0/RS1. The coupling capacitance on the wires may occur incorrect A/D conversion. Also, please do not have signals which may be a source of noise around the node. - When RT0/RT1 (Thermistor and etc.) requires long wiring due to the restricted placement, please have VSS(GND) trace next to the signal. - Please make wiring to components (capacitor, resisteor and etc.) necessory for objective measurement. Wiring to reserved components may affect to the A/D conversion operation by noise the components itself may have. 31/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 Package Dimensions (Unit : mm) Notes for Mounting the Surface Mount Type Package The surface mount type packages are very susceptible to heat in reflow mounting and humidity absorbed in storage. Therefore, before you perform reflow mounting, contact our responsible sales person for the product name, package name, pin number, package code and desired mounting conditions (reflow method, temperature and times). 32/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 Revision History Document No. Date FEDL610Q409-01 Nov.7,2010 FEDL610Q409-02 Jul.12,2011 FEDL610Q409-03 Jan.24,2014 FEDL610Q409-04 FEDL610Q409-05 Mar.20,2014 May.23,2014 Page Previous Current Edition Edition – 2 3 All 2 2 3 – 2 3 All 2 2 4 3 4 20 21 4 - 4 20 21 21 21 21 21 21 Description Formally edition 1 Add comment of uart half duplex communication Add “D” version in the supply form Change header and footer Add “A” version in the supply form Changed the description of LCD 1/2 bias supported version Change from "Shipment" to " Product name – Supported Function " Correct minimum time of Power-on reset generated power rise time Correct the “Product name – Supported Function” Add Clock Generation Circuit Operating Conditions Change "RESET" to " Reset pulse width (PRST)" and " Power-on reset activation power rise time (TPOR )". Correct minimum time of Power-on reset generated power rise time Correct the CGL’s value and the CDL’s value of DC CHARACTERISTICS (1/5)’s note No.2 33/34 FEDL610Q409-05 ML610Q407/ML610Q408/ML610Q409 NOTES No copying or reproduction of this document, in part or in whole, is permitted without the consent of LAPIS Semiconductor Co., Ltd. The content specified herein is subject to change for improvement without notice. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, LAPIS Semiconductor shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. LAPIS Semiconductor does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by LAPIS Semiconductor and other parties. LAPIS Semiconductor shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While LAPIS Semiconductor always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. LAPIS Semiconductor shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuel-controller or other safety device). LAPIS Semiconductor shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Copyright 2011-2014 LAPIS Semiconductor Co., Ltd. 34/34
ML610Q408P-NNNTB0AAL 价格&库存
很抱歉,暂时无法提供与“ML610Q408P-NNNTB0AAL”相匹配的价格&库存,您可以联系我们找货
