MSM5412222B-25TK-MTL
    ROHM(罗姆)
    TSOPII-44
MSM5412222B-25TK-MTL 数据手册
FEDS5412222B-02 Issue Date: Nov 01, 2012 MSM5412222B 262,214-Word  12-Bit Field Memory GENERAL DESCRIPTION The LAPIS Semiconductor MSM5412222B is a high performance 3-Mbit, 256K  12-bit, Field Memory. It is especially designed for high-speed serial access applications such as HDTVs, conventional NTSC TVs, VTRs, digital movies and Multi-media systems. MSM5412222B is a FRAM for wide or low end use in general commodity TVs and VTRs exclusively. MSM5412222B is not designed for the other use or high end use in medical systems, professional graphics systems which require long term picture storage, data storage systems and others. More than two MSM5412222Bs can be cascaded directly without any delay devices among the MSM5412222Bs. (Cascading of MSM5412222B provides larger storage depth or a longer delay). Each of the 12-bit planes has separate serial write and read ports. These employ independent control clocks to support asynchronous read and write operations. Different clock rates are also supported that allow alternate data rates between write and read data streams. The MSM5412222B provides high speed FIFO, First-In First-Out, operation without external refreshing: MSM5412222B refreshes its DRAM storage cells automatically, so that it appears fully static to the users. Moreover, fully static type memory cells and decoders for serial access enable the refresh free serial access operation, so that serial read and/or write control clock can be halted high or low for any duration as long as the power is on. Internal conflicts of memory access and refreshing operations are prevented by special arbitration logic. The MSM5412222B’s function is simple, and similar to a digital delay device whose delay-bit-length is easily set by reset timing. The delay length, number of read delay clocks between write and read, is determined by externally controlled write and read reset timings. Additional SRAM serial registers, or line buffers for the initial access of 256  12-bit enable high speed first-bit-access with no clock delay just after the write or read reset timings. Additionally, the MSM5412222B has write mask function or input enable function (IE), and read-data skipping function or output enable function (OE) . The differences between write enable (WE) and input enable (IE), and between read enable (RE) and output enable (OE) are that WE and RE can stop serial write/read address increments, but IE and OE cannot stop the increment, when write/read clocking is continuously applied to MSM5412222B. The input enable (IE) function allows the user to write into selected locations of the memory only, leaving the rest of the memory contents unchanged. This facilitates data processing to display a “picture in picture” on a TV screen. The MSM5412222B is similar in operation and functionality to LAPIS Semiconductor 1-Mbit Field Memory MSM514222C and 2-Mbit Field Memory MSM518222A. Three MSM514222Cs or one MSM514222C plus one MSM518222A can be replaced simply by one MSM5412222B. 1/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B FEATURES          Single power supply: 5.0 V ±0.5 V 262,214 words  12 bits Fast FIFO (First-In First-Out) operation High speed asynchronous serial access Read/write cycle time 20 ns/25 ns Access time 18 ns/23 ns Direct cascading capability Write mask function (Input enable control) Data skipping function (Output enable control) Self refresh (No refresh control is required) Package options: 44-pin 400 mil plastic TSOP (Type 2) (TSOP(2)44-P-400-0.80-K) (Product:MSM5412222B-xxT3-K) xx indicates speed rank. PRODUCT FAMILY Family Access Time (Max.) Cycle Time (Min.) MSM5412222B-25 23 ns 25 ns MSM5412222B-30 25 ns 30 ns Package 400 mil 44-pin TSOP (2) 2/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B PIN CONFIGURATION (TOP VIEW) VSS DIN11 DIN10 NC DIN9 DIN8 DIN7 DIN6 NC DIN5 DIN4 DIN3 DIN2 NC DIN1 DIN0 SWCK RSTW NC WE IE VCC 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 VSS DOUT11 DOUT10 NC DOUT9 DOUT8 DOUT7 DOUT6 VCC DOUT5 DOUT4 DOUT3 DOUT2 VSS DOUT1 DOUT0 SRCK RSTR NC RE OE VCC 44-Pin Plastic TSOP (2) (K Type) Pin Name SWCK SRCK WE Function Serial Write Clock Serial Read Clock Write Enable RE Read Enable IE Input Enable OE Output Enable RSTW Write Reset Clock RSTR Read Reset Clock DIN0 to 11 DOUT0 to 11 Data Input Data Output VCC Power Supply (5.0 V) VSS Ground (0 V) NC No Connection Note: The same power supply voltage must be provided to every VCC pin, and the same GND voltage level must be provided to every VSS pin. 3/16 IE RSTR Write Line Buffer (  12) Array Memory 262,144  12 (  12) Read Line Buffer WE RSTW SWCK Serial Write Controller X Decoder SRCK Serial Read Register (  12) Serial Read Controller RE Serial Write Register (  12) OE VBB Generator Clock Oscillator Read/Write and Refresh Controller LAPIS Semiconductor DIN (  12) Data-In Buffer (  12) 71-Word Sub-Register (  12) 71-Word Sub-Register (  12) Data-Out Buffer (  12) DOUT (  12) FEDS5412222B-02 MSM5412222B BLOCK DIAGRAM 4/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B OPERATION Write Operation The write operation is controlled by three clocks, SWCK, RSTW, and WE. Write operation is accomplished by cycling SWCK, and holding WE high after the write address pointer reset operation or RSTW. Each write operation, which begins after RSTW, must contain at least 150 active write cycles, i.e. SWCK cycles while WE is high. To transfer the last data to the DRAM array, which at that time is stored in the serial data registers attached to the DRAM array, an RSTW operation is required after the last SWCK cycle. Note that every write timing of MSM5412222B is delayed by one clock compared with read timings for easy cascading without any interface delay devices. Write Reset: RSTW The first positive transition of SWCK after RSTW becomes high resets the write address counters to zero. RSTW setup and hold times are referenced to the rising edge of SWCK. Because the write reset function is solely controlled by the SWCK rising edge after the high level of RSTW, the states of WE and IE are ignored in the write reset cycle. Before RSTW may be brought high again for a further reset operation, it must be low for at least two SWCK cycles. Data Inputs: DIN0 to 11 Write Clock: SWCK The SWCK latches the input data on chip when WE is high, and also increments the internal write address pointer. Data-in setup time tDS, and hold time tDH are referenced to the rising edge of SWCK. Write Enable: WE WE is used for data write enable/disable control. WE high level enables the input, and WE low level disables the input and holds the internal write address pointer. There are no WE disable time (low) and WE enable time (high) restrictions, because the MSM5412222B is in fully static operation as long as the power is on. Note that WE setup and hold times are referenced to the rising edge of SWCK. Input Enable: IE IE is used to enable/disable writing into memory. IE high level enables writing. The internal write address pointer is always incremented by cycling SWCK regardless of the IE level. Note that IE setup and hold times are referenced to the rising edge of SWCK. 5/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B Read Operation The read operation is controlled by three clocks, SRCK, RSTR, and RE. Read operation is accomplished by cycling SRCK, and holding RE high after the read address pointer reset operation or RSTR. Each read operation, which begins after RSTR, must contain at least 150 active read cycles, i.e. SRCK cycles while RE is high. Read Reset: RSTR The first positive transition of SRCK after RSTR becomes high resets the read address counters to zero. RSTR setup and hold times are referenced to the rising edge of SRCK. Because the read reset function is solely controlled by the SRCK rising edge after the high level of RSTR, the states of RE and OE are ignored in the read reset cycle. Before RSTR may be brought high again for a further reset operation, it must be low for at least *two SRCK cycles. Data Out: DOUT0 to 11 Read Clock: SRCK Data is shifted out of the data registers. It is triggered by the rising edge of SRCK when RE is high during a read operation. The SRCK input increments the internal read address pointer when RE is high. The three-state output buffer provides direct TTL compatibility (no pullup resistor required). Data out is the same polarity as data in. The output becomes valid after the access time interval tAC that begins with the rising edge of SRCK. *There are no output valid time restriction on MSM5412222B. Read Enable: RE The function of RE is to gate of the SRCK clock for incrementing the read pointer. When RE is high before the rising edge of SRCK, the read pointer is incremented. When RE is low, the read pointer is not incremented. RE setup times (tRENS and tRDSS) and RE hold times (tRENH and tRDSH) are referenced to the rising edge of the SRCK clock. Output Enable: OE OE is used to enable/disable the outputs. OE high level enables the outputs. The internal read address pointer is always incremented by cycling SRCK regardless of the OE level. Note that OE setup and hold times are referenced to the rising edge of SRCK. 6/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B Power-up and Initialization On power-up, the device is designed to begin proper operation after at least 100 s after VCC has stabilized to a value within the range of recommended operating conditions. After this 100 s stabilization interval, the following initialization sequence must be performed. Because the read and write address counters are not valid after power-up, a minimum of 80 dummy write operations (SWCK cycles) and read operations (SRCK cycles) must be performed, followed by an RSTW operation and an RSTR operation, to properly initialize the write and the read address pointer. Dummy write cycles/RSTW and dummy read cycles/RSTR may occur simultaneously. If these dummy read and write operations start while VCC and/or the substrate voltage has not stabilized, it is necessary to perform an RSTR operation plus a minimum of 80 SRCK cycles plus another RSTR operation, and an RSTW operation plus a minimum of 80 SRCK cycles plus another RSTW operation to properly initialize read and write address pointers. Old/New Data Access There must be a minimum delay of 150 SWCK cycles between writing into memory and reading out from memory. If reading from the first field starts with an RSTR operation, before the start of writing the second field (before the next RSTW operation), then the data just written will be read out. The start of reading out the first field of data may be delayed past the beginning of writing in the second field of data for as many as 20 SWCK cycles. If the RSTR operation for the first field read-out occurs less than 20 SWCK cycles after the RSTW operation for the second field write-in, then the internal buffering of the device assures that the first field will still be read out. The first field of data that is read out while the second field of data is written is called “old data”. In order to read out “new data”, i.e., the second field written in, the delay between an RSTW operation and an RSTR operation must be at least 150 SRCK cycles. If the delay between RSTW and RSTR operations is more than 21 but less than 150 cycles, then the data read out will be undetermined. It may be “old data” or “new” data, or a combination of old and new data. Such a timing should be avoided. Cascade Operation The MSM5412222B is designed to allow easy cascading of multiple memory devices. This provides higher storage depth, or a longer delay than can be achieved with only one memory device. 7/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B ELECTRICAL CHARACTERISTICS Absolute Maximum Ratings Parameter Symbol Conditon Rating Unit Input Output Voltage VT at Ta = 25C, VSS –1.0 to +7.0 V Output Current IOS Ta = 25C 50 mA Power Dissipation PD Ta = 25C 1 W Operating Temperature Topr — 0 to 70 C Storage Temperature Tstg — –55 to +150 C Recommended Operating Conditions Parameter Symbol Min. Typ Max. Unit Power Supply Voltage VCC 4.5 5.0 5.5 V Input High Voltage VIH 2.4 VCC VCC +1 V Input Low Voltage VIL –0.1 0 +0.8 V DC Characteristics Parameter Symbol Condition Min. Max. Unit ILI 0 < VI < VCC + 1 V, Other Pins Tested at V = 0 V –10 +10 µA Output Leakage Current ILO 0 < VO < VCC –10 +10 µA Output “H” Level Voltage VOH IOH = –1 mA 2.4 — V Output “L” Level Voltage VOL IOL = 2 mA — 0.4 V Operating Current ICC1 Minimum Cycle Time, Output Open — 60 mA Standby Current ICC2 Input Pin = VIH/VIL — 5 mA Input Leakage Current Capacitance (Ta = 25°C, f = 1 MHz) Parameter Symbol Max. Unit Input Capacitance (DIN, SWCK, SRCK, RSTW, RSTR, WE, RE, IE, OE) CI 6 pF Output Capacitance (DOUT) CO 7 pF 8/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B AC Characteristics (VCC = 5.0 V ±0.5 V, Ta = 0 to 70°C) Parameter Symbol Access Time from SRCK DOUT Hold Time from SRCK DOUT Enable Time from SRCK SWCK “H” Pulse Width SWCK “L” Pulse Width Input Data Setup Time Input Data Hold Time WE Enable Setup Time WE Enable Hold Time WE Disable Setup Time WE Disable Hold Time IE Enable Setup Time IE Enable Hold Time IE Disable Setup Time IE Disable Hold Time WE “H” Pulse Width WE “L” Pulse Width IE “H” Pulse Width IE “L” Pulse Width RSTW Setup Time RSTW Hold Time SRCK “H” Pulse Width SRCK “L” Pulse Width RE Enable Setup Time RE Enable Hold Time RE Disable SetupTime RE Disable Hold Time OE Enable Setup Time OE Enable Hold Time OE Disable SetupTime OE Disable Hold Time Output Buffer Turn-off Delay Time from OE RE “H” Pulse Width RE “L” Pulse Width OE “H” Pulse Width OE “L” Pulse Width RSTR Setup Time RSTR Hold Time SWCK Cycle Time SRCK Cycle Time Transition Time (Rise and Fall) MSM5412222B-25 MSM5412222B-30 Unit Min. Max. Min. Max. tAC tDDCK tDECK tWSWH tWSWL tDS tDH tWENS tWENH tWDSS tWDSH tIENS tIENH tIDSS tIDSH tWWEH tWWEL tWIEH tWIEL tRSTWS tRSTWH tWSRH tWSRL tRENS tRENH tRDSS tRDSH tOENS tOENH tODSS tODSH tOEZ tWREH tWREL — 6 6 9 10 2 4 0 3 0 3 0 3 0 3 5 5 5 5 0 3 9 10 0 3 0 3 0 3 0 3 17 5 5 23 — 23 — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — 6 6 12 12 2 4 0 3 0 3 0 3 0 3 10 10 10 10 0 3 12 12 0 3 0 3 0 3 0 3 17 10 10 25 — 25 — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns tWOEH tWOEL tRSTRS tRSTRH tSWC tSRC tT 5 5 0 3 25 25 3 — — — — — — 30 10 10 0 3 30 30 3 — — — — — — 30 ns ns ns ns ns ns ns 9/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B Notes: 1. Input signal reference levels for the parameter measurement are VIH = 3.0 V and VIL = 0 V. The transition time tT is defined to be a transition time that signal transfers between VIH = 3.0 V and VIL = 0 V. 2. AC measurements assume tT = 3 ns. 3. Read address must have more than a 150 address delay than write address in every cycle when asynchronous read/write is performed. 4. Read must have more than a 150 address delay than write in order to read the data written in a current series of write cycles which has been started at last write reset cycle: this is called “new data read”. When read has less than a 20 address delay than write, the read data are the data written in a previous series of write cycles which had been written before at last write reset cycle: this is called “old data read”. 5. When the read address delay is between more than 21 and less than 149, read data will be undetermined. However, normal write is achieved in this address condition. 6. Outputs are measured with a load equivalent to 1 TTL load and 30 pF. Output reference levels are VOH = 2.0 V and VOL = 0.8 V. 10/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B TIMING WAVEFORM Write Cycle Timing (Write Reset) n cycle 0 cycle 2 cycle 1 cycle –VIH –VIL SWCK tT tWSWH tRSTWH tRSTWS tWSWL tSWC –VIH –VIL RSTW tDH tDS DIN n–1 n 0 1 –VIH –VIL 2 WE –VIH –VIL IE –VIH –VIL Write Cycle Timing (Write Enable) n cycle Disable cycle Disable cycle n + 1 cycle –VIH –VIL SWCK tWDSH tWENH tWDSS tWENS –VIH –VIL WE tWWEL DIN IE RSTW n–1 tWWEH n n+1 –VIH –VIL –VIH –VIL –VIH –VIL 11/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B Write Cycle Timing (Input Enable) n cycle n + 1 cycle n + 2 cycle n + 3 cycle –VIH –VIL SWCK tIENH tIENS tIDSS tIDSH –VIH –VIL IE tWIEL DIN tWIEH n n–1 n+3 –VIH –VIL WE –VIH –VIL RSTW –VIH –VIL Read Cycle Timing (Read Reset) n cycle 0 cycle 2 cycle 1 cycle –VIH –VIL SRCK tT tWSRH tRSTRH tRSTRS tWSRL tSRC –VIH –VIL RSTR tAC DOUT n–1 tDDCK n 0 1 2 –VOH –VOL RE –VIH –VIL OE –VIH –VIL 12/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B Read Cycle Timing (Read Enable) n cycle Disable cycle Disable cycle n + 1 cycle –VIH –VIL SRCK tRDSH tRENH tRDSS tRENS –VIH –VIL RE tWREL DOUT tWREH n–1 n+1 n –VOH –VOL OE –VIH –VIL RSTR –VIH –VIL Read Cycle Timing (Output Enable) n cycle n + 1 cycle n + 2 cycle n + 3 cycle –VIH –VIL SRCK tODSH tOENH tODSS tOENS –VIH –VIL OE tWOEH tWOEL DOUT n–1 n tDECK Hi-Z n+3 –VOH –VOL tOEZ RE RSTR –VIH –VIL –VIH –VIL 13/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B NOTES FOR MOUNTING THE SURFACE MOUNT TYPE PACKAGES The surface mount type packages are very susceptible to heat in reflow mounting and humidity absorbed in storage. Therefore, before you perform reflow mounting, contact LAPIS Semiconductor’s responsible sales person for the product name, package name, pin number, package code and desired mounting conditions (reflow method, temperature and times). 14/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B REVISION HISTORY Document No. Date Page Previous Current Edition Edition PEDS5412222B-01 Aug 16, 2002 – – PEDS5412222B-02 Jan. 13, 2012 1 2,3, 14,15 1 2,3, 14 FPEDS5412222B-02 Nov. 01, 2012 – – Description First edition Changed Company name and logo Deleted the 40-pin SOJ package information and PACKAGE DIMENSION Released formal edition 02 15/16 FEDS5412222B-02 LAPIS Semiconductor MSM5412222B NOTICE No copying or reproduction of this document, in part or in whole, is permitted without the consent of LAPIS Semiconductor Co., Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing LAPIS Semiconductor's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from LAPIS Semiconductor upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, LAPIS Semiconductor shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. LAPIS Semiconductor does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by LAPIS Semiconductor and other parties. LAPIS Semiconductor shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While LAPIS Semiconductor always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. LAPIS Semiconductor shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuel-controller or other safety device). LAPIS Semiconductor shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Copyright 2012 LAPIS Semiconductor Co., Ltd. 16/16
MSM5412222B-25TK-MTL 价格&库存
很抱歉,暂时无法提供与“MSM5412222B-25TK-MTL”相匹配的价格&库存,您可以联系我们找货
