Schottky barrier diode
RB085T-40
Applications Switching power supply Dimensions (Unit : mm) Structure
Features 1) Cathode common type. (TO-220) 2) Low IR 3) High reliability Construction Silicon epitaxial planer
(1) (2) (3)
8
Absolute maximum ratings (Ta=25°C) Parameter Reverse voltage (repetitive peak) Reverse voltage (DC) Average rectified forward current (*1) Forward current surge peak (60Hz / 1cyc) (*1) Junction temperature Storage temperature
Symbol VRM VR Io IFSM Tj Tstg
Limits 45 40 10 100 150 -40 to +150
Unit V V A A C C
(*1)Business frequencies, Rating of R-load, 1/2 Io per diode, Tc=132C Electrical characteristic (Ta=25°C) Parameter Forward voltage Reverse current Thermal impedance
Symbol VF IR jc
Min. -
Typ. -
Max. 0.55 200 2.5
Unit V A C/W
Conditions IF=5A VR=40V junction to case
www.rohm.com ©2010 ROHM Co., Ltd. All rights reserved.
1/3
2010.02 - Rev.D
RB085T-40
Electrical characteristic curves
10 Ta=150C REVERSE CURRENT:IR(uA) FORWARD CURRENT:IF(A) Ta=125C 1 Ta=75C Ta=25°C 0.1 Ta=-25°C
Data Sheet
Ta=150°C 100000 10000 1000 100 10 1 0.1
Ta=125°C 1000 f=1MHz Ta=75°C CAPACITANCE BETWEEN TERMINALS:Ct(pF)
100
Ta=25°C
Ta=-25°
10
0.01 0 100 200 300 400 500 600 FORWARD VOLTAGE : V F(mV) VF-IF CHARACTERISTICS
0.01 0 10 20 30 REVERSE VOLTAGE : VR(V) VR-IR CHARACTERISTICS 40
1 0 5 10 15 20 25 30 REVERSE VOLTAGE:VR(V) VR-Ct CHARACTERISTICS
530 FORWARD VOLTAGE:VF(mV) Ta=25°C IF=5A n=30pcs
300 REVERSE CURRENT:IR(uA) 250 200 150 100 AVE:20.3uA 50 0 VF DISPERSION MAP IR DISPERSION MAP Ta=25°C VR=40V n=30pcs
800 790 CAPACITANCE BETWEEN TERMINALS:Ct(pF) 780 770 760 750 740 730 720 710 AVE:728.1pF Ta=25°C f=1MHz VR=0V n=10pcs
520
510
500 AVE:504.0mV 490
480
700 Ct DISPERSION MAP
300 RESERVE RECOVERY TIME:trr(ns) 250 200 150 100 50 0 AVE:156.0A Ifsm 1cyc 8.3ms
30 25 20 15 10 5 0 trr DISPERSION MAP AVE:12.30ns Ta=25°C IF=0.5A IR=1A Irr=0.25*IR n=10pcs
1000 Ifsm PEAK SURGE FORWARD CURRENT:IFSM(A) 8.3ms 8.3ms
1cyc 100
10 1 10 NUMBER OF CYCLES IFSM-CYCLE CHARACTERISTICS 100
IFSM DISPERSION MAP
1000 TRANSIENT ℃ THAERMAL IMPEDANCE:Rth ( /W)
100 Ifsm t
Mounted on epoxy board
IM=100mA
15
IF=1A FORWARD POWER DISSIPATION:Pf(W) Rth(j-a) D=1/2 10 Sin(θ=180) DC
10
1ms
tim
300us
100
1
Rth(j-c)
5
10 1 10 TIME:t(ms) IFSM-t CHARACTERISTICS 100
0.1 0.001
0 0.1 10 1000 0 TIME:t(s) Rth-t CHARACTERISTICS 5 10 15 AVERAGE RECTIFIED FORWARD CURRENT : Io(A) Io-Pf CHARACTERISTICS 20
2/3
2010.02 - Rev.D
RB085T-40
Data Sheet
5
30 0A 0V 20 Io AVERAGE RECTIFIED FORWARD CURRENT:Io(A) t T VR D=t/T VR=20V Tj=150°C
30 0A 0V 20 Io t T VR D=t/T VR=20V Tj=150°C
4 REVERSE POWER DISSIPATION:PR (W)
3 D=1/2 2 DC 1
Sin(θ=180)
DC D=1/2
DC D=1/2
10 Sin(θ=180)
10 Sin(θ=180)
0 0 10 20 30 40 REVERSE VOLTAGE : V R(V) VR-PR CHARACTERISTICS
0 0 25 50 75 100 125 150
0 0 25 50 75 100 125 150 CASE TEMPARATURE:Tc(°C) Derating Curve"(Io-Tc)
AMBIENT TEMPERATURE:Ta(°C) Derating Curve"(Io-Ta)
30 ELECTROSTATIC DISCHARGE TEST ESD(KV) No break at 30kV 25 20 AVE:11.5k 15 10 5 0 C=200pF R=0Ω ESD DISPERSION MAP C=100pF R=1.5kΩ
3/3
2010.02 - Rev.D
Notice
Notes
No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuelcontroller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law.
Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us.
ROHM Customer Support System
http://www.rohm.com/contact/
www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved.
R1010A
很抱歉,暂时无法提供与“RB085T-40_10”相匹配的价格&库存,您可以联系我们找货
