RPM-22PB_10
RPM-22PB_10
    ROHM(罗姆)
    RPM-22PB_10 - Phototransistor, side view type - Rohm
RPM-22PB_10 数据手册
Phototransistor, side view type RPM-22PB The RPM-22PB is a silicon phototransistor in a side-facing package. High sensitivity with 1.5 lens. Applications Optical control equipment Receiver for sensors Dimensions (Units : mm) Notes: 1. Unspecified tolerance shall be ±0.2 . 2. Value in parentheses is size at base of leads. 1.0 1.8±0.05 2−C 0.7 4.1 4.6±0.1 2.54±0.1 1.9 Min. 12.0 Features 1) High sensitivity. 2) Molded in plastic with a visible light filter. (Filter out light 750nm or less) 3) Side-facing detector. R 0.75 2.8 R0.5 1.0 1.5 4.7±0.1 2−0.65 2−0.45 R0.5 2−0.40 1 (2.54) 2 0.64 1 Emitter 2 Collector Absolute maximum ratings (Ta=25C) Parameter Collector-emitter voltage Emitter-collector voltage Collector current Collector power dissipation Operating temperature Storage temperature Symbol VCEO VECO IC PC Topr Tstg Limits 32 5 30 100 −25~+85 −30~+100 Unit V V mA mW °C °C Electrical and optical characteristics (Ta=25C) Parameter Light current Dark current Peak sensitivity wavelength Collector-emitter saturation voltage Half-angle Response time Symbol IC ICEO Min. 0.48 − − − − − Typ. − − 800 − ±32 10 Max. 1.94 0.5 − 0.4 − − Unit mA μA nm V deg μs Conditions VCE=5V, E=500LX VCE=10V (Black box) − IC=0.1mA, E=500LX − VCE=5V, IC=1mA, RL=100Ω λP VCE(sat) θ1 / 2 tr·tf www.rohm.com c ○ 2010 ROHM Co., Ltd. All rights reserved. 1/2 2010.06 - Rev.A RPM-22PB Electrical and optical characteristic curves 4 COLLECTOR CURRENT : IC (mA) Data Sheet RELATIVE COLLECTOR CURRENT : IC (%) VCE=5V COLLECTOR CURRENT : IC (mA) 2.4 2.0 1.6 Ee=0.4mW/cm 1.2 0.8 0.4 0 0 Ee=0.3mW/cm 2 500 3 200 100 50 2 2 Ee=0.2mW/cm2 Ee=0.1mW/cm2 1 20 10 −25 0 25 50 75 100 0 250 500 750 1000 1250 4 8 12 16 ILLUMINANCE : E (Lx) COLLECTOR-EMITTER VOLTAGE : VCE (V) AMBIENT TEMPERATURE : Ta (°C) Fig.1 Collector current vs. emitting strength Fig.2 Output characteristics Fig.3 Relative output vs. ambient temperature 100 120 RELATIVE SENSITIVITY : IC (%) 1000 DARK CURRENT : ICEO (nA) COLLECTOR DISSIPATION : PC (mW) 80 100 80 60 40 20 0 −25 100 VCE=10V VCE=20V VCE=30V 60 10 40 1 20 0.1 −25 0 25 50 75 100 0 400 500 600 700 800 900 1000 1100 0 25 50 75 100 AMBIENT TEMPERATURE : Ta (°C) OPTICAL WAVELENGTH : λ (nm) AMBIENT TEMPERATURE : Ta (°C) Fig.4 Dark current vs. ambient temperature Fig.5 Spectral sensitivity Fig.6 Collector dissipation vs. ambient temperature 1000 30° 40° 80 100 RL=1kΩ RL=500Ω 10 RL=100Ω 80° 70° 60° 50° 60 40 20 1 0.1 1 10 100 90° 100 80 60 40 20 0 10° 20° 30° 40° 50° 60° 70° 80° 90° ANGULAR DISPLACEMENT (deg) COLLECTOR CURRENT : IC (mA) RELATIVE LUMINOUS INTENSITY (%) Fig.7 Response time vs. collector current Fig.8 Directional pattern www.rohm.com c ○ 2010 ROHM Co., Ltd. All rights reserved. 2/2 2010.06 - Rev.A RELATIVE LUMINOUS INTENSITY (%) Ta=25°C VCC=10V 20° 10° 0° 100 RESPONSE TIME : tr (μs) Notice Notes No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuelcontroller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved. R1010A
RPM-22PB_10 价格&库存
很抱歉,暂时无法提供与“RPM-22PB_10”相匹配的价格&库存,您可以联系我们找货
RPM-075PTT86
  • 1+1.71324
  • 10+1.39591
  • 50+1.17786
  • 150+1.07692
库存:192
