RPM7138-V4R
RPM7138-V4R
    ROHM(罗姆)
    SIP-3-2.54mm
    接收距离15M 45°@水平 35°@垂直
RPM7138-V4R 数据手册
SERIES CATALOG Photo Link Modules Remote Control Receiver Module IrDA Infrared Communication Module Remote Control Receiver Module ■Contents Remote Control Receiver Module Selection Guide ................................................... 1 RPM7200 Series ............................................................................................................. 3 RPM7100 Series ............................................................................................................. 5 External Dimensions ....................................................................................................... 7 Basic Knowledge of Remote Control ........................................................................... 9 Remote Control Receiver Module and Data Communication .................................. 10 .............................. 11 .......................................................................... 13 Precautions for Designing Transmitter Side ............................................................... 15 ................................................................... 17 Receiving Discrimination Method to Expand Effective Distance ............................. 21 ........................................................................ 22 Block Diagram and Work of Remote Control Receiver Module Remote Control Transmission Signal Precautions for Designing Receiver Side Measures for Preventing Malfunctions Remote Control Receiver Module Remote Control Receiver Module Remote Control Receiver Module ■Remote Control Receiver Module Selection Guide Remote Control Receiver Module (at 3.0 to 3.3V) R 36.0kHz 9.6mm 36.7kHz Carrier frequency 37.9kHz 40.0kHz Distance from PCB to lens 36.0kHz 15.0mm 36.7kHz SIDE VIEW Carrier frequency 37.9kHz 40.0kHz 36.0kHz Shape 7.2mm 36.7kHz Carrier frequency 37.9kHz 40.0kHz RPM7236-H5 RPM7237-H5 RPM7238-H5 RPM7240-H5 RPM7236-H13 RPM7237-H13 RPM7238-H13 RPM7240-H13 RPM7236-H8 RPM7237-H8 RPM7238-H8 RPM7240-H8 TOP VIEW 36.0kHz 12.0mm 36.7kHz Distance from PCB to lens Carrier frequency 37.9kHz 40.0kHz 36.0kHz 15.9mm 36.7kHz Carrier frequency 37.9kHz 40.0kHz 1 RPM7236-H9 RPM7237-H9 RPM7238-H9 RPM7240-H9 RPM7236-H4 RPM7237-H4 RPM7238-H4 RPM7240-H4 Remote Control Receiver Module (at 5.0V) 36.0kHz 5.5mm 36.7kHz Carrier frequency 37.9kHz 40.0kHz 56.9kHz 36.0kHz 9.6mm Distance from PCB to lens 36.7kHz Carrier frequency 37.9kHz 40.0kHz 56.9kHz 3 3 36.0kHz SIDE VIEW 15.0mm 3 36.7kHz Carrier frequency 3 37.9kHz 40.0kHz 56.9kHz Shape 36.0kHz 4.8mm 36.7kHz Carrier frequency 37.9kHz 40.0kHz 56.9kHz 36.0kHz 7.2mm 36.7kHz TOP VIEW Carrier frequency Distance from PCB to lens 37.9kHz 40.0kHz 56.9kHz 36.0kHz 12.0mm 36.7kHz Carrier frequency 37.9kHz 40.0kHz 56.9kHz 36.0kHz 15.9mm 36.7kHz Carrier frequency 37.9kHz 40.0kHz 56.9kHz 2 RPM7136 RPM7137 RPM7138 RPM7140 RPM7157 RPM7136-H5 RPM7137-H5 RPM7138-H5 RPM7140-H5 RPM7157-H5 RPM7136-H13 RPM7137-H13 RPM7138-H13 RPM7140-H13 RPM7157-H13 RPM7136-V4 RPM7137-V4 RPM7138-V4 RPM7140-V4 RPM7157-V4 RPM7136-H8 RPM7137-H8 RPM7138-H8 RPM7140-H8 RPM7157-H8 RPM7136-H9 RPM7137-H9 RPM7138-H9 RPM7140-H9 RPM7157-H9 RPM7136-H4 RPM7137-H4 RPM7138-H4 RPM7140-H4 RPM7157-H4 Remote Control Receiver Module Remote Control Receiver Module Selection Guide Remote Control Receiver Module ■Electrical and Optical Characteristics of RPM7200 Series ■T Parameter Symbol Limits Unit VCC 6.3 V Storage Temperature Range Tstg -30~+100 °C Operating Temperature Range Topr -10~+75 °C Solder Temperature Tsol Supply Voltage Gain (dB) Absolute Maximum Ratings (Ta=25°C) °C 260* * Within 5s and 3mm of the route of the lead. - Parameter Symbol Min. Typ. Max. Unit VCC 2.7 3.0 3.6 V Supply Voltage Electrical Characteristics (Ta=25°C and Vcc=3V unless otherwise specified) Parameter Symbol Min. Current Consumption Icc Effective Distance on Axis L 8 High Level Output Voltage VH 2.5 Typ. Max. Unit 0.3 0.5 mA With no external light or input m *1 External light condition Ee
RPM7138-V4R 价格&库存
很抱歉,暂时无法提供与“RPM7138-V4R”相匹配的价格&库存,您可以联系我们找货
RPM7138-V4R
    • 1+3.560351+0.46054
    • 50+3.2947850+0.42618
    • 100+2.78023100+0.35963
    • 300+2.43167300+0.31454
    • 500+2.36527500+0.30595
    • 1000+2.315481000+0.29951
    • 4000+2.273984000+0.29414
    库存:2970
    RPM7138-V4R
    • 1+6.96140
    • 10+5.91720
    • 30+4.87300
    • 100+4.35090
    • 500+4.00280
    • 1000+3.48070
