RPM7157-H13R
RPM7157-H13R
    ROHM(罗姆)
    RPM7157-H13R - IR Receiver Module - Rohm
RPM7157-H13R 数据手册
RPM7157-R series Photo Link Module IR Receiver Module RPM7157-R series RPM7157-R series are remote control receiver modules. Small-sized, light-weight, and low current consumption modules have been achieved by using resin mold. Center frequency 56.9kHz Applications All household electric appliances such as TV, DVD, air conditioner and audio equipment. Features 1) Low current consumption. (1.0mA Typ.) 2) High ripple rejection. 3) 5 types of holders available for each set. RPM7157-R series Straight type RSIP-A3 Height to lens Products No. 5.5mm RPM7157-R L forming RSIP-A3 V4 4.8mm ∗RPM7157-V4R with holders SIDE VIEW RSIP-A3 (H13) 15.0mm ∗RPM7157-H13R SIDE VIEW RSIP-A3 (H5) 9.6mm ∗RPM7157-H5R TOP VIEW RSIP-A3 (H4) 15.9mm ∗RPM7157-H4R TOP VIEW RSIP-A3 (H8) 7.2mm RPM7157-H8R TOP VIEW RSIP-A3 (H9) 12.0mm ∗RPM7157-H9R ∗Under development Absolute maximum ratings (Ta = 25°C) Parameter Supply Voltage Output Current Storage temperature Operating temperature Symbol VCC lo Tstg Topr Limits −0.3 to +7.0 2.0 −30 to +100 −10 to +75 Unit V mA ˚C ˚C Recommended operating conditions (Ta = 25°C) Parameter Supply Voltage Symbol VCC Min. 4.5 Typ. 5.0 Max. 5.5 Unit V Rev.A 1/7 RPM7157-R series Photo Link Module Block diagram VCC 22k AMP LIMITER Comparator ROUT I/V BPF Detector Terminal description Pin No. 1 2 3 Pin name ROUT GND VCC Function OUTPUT TERMINAL GROUND POWER SUPPLY Electrical characteristics (Unless otherwise noted, Ta = 25°C VCC=5V) Parameter Consumption Current Effective Distance High Level Output Voltage Low Level Output Voltage ON Pulse Width OFF Pulse Width Center frequency Horizontal half angle Vertical half angle Symbol ICC L VH VL TON TOFF fo θ 1/2 θ 1/2 Min. − 8 4.5 − 400 400 − − − Typ. 1.0 15 − − 600 600 56.9 45 35 Max. 1.6 − − 0.5 800 800 − − − Unit mA m V V µs µs kHz deg deg ∗2 ∗2 Isink=200µA Outer light condition Ee < 10 (Ix) Outer light condition Ee < 10 (Ix) Conditions No outside light, No signal input Outer light condition Ee < 10 (Ix) ∗1 ∗1 ∗1 ∗1 ∗1 ∗1 600/600µs burst wave is transmitted by standard transmitter. However, it must be measured after the initial transmission pulse is 100 pulse. ∗2 It is an angle when the linear arrival distance become half. Measurement Conditions (1) Transmit signal 600µs 600µs Carrier frequency=fo, Duty=50% Fig.1 Transmit signal Rev.A 2/7 RPM7157-R series Photo Link Module (2) Standard transmitter λ peak=940nm λ ∆=40nm 20cm Io=VOUT / R RPM-302B Standard transmitter R VOUT Fig.2 Measurement of standard transmitter proofreading When standard transmitter output the signal at Fig.1 standard photodiode output become Io=5µAp-p under the measurement condition Fig.2. (The radiant intensity of standard transmitter : 50mW / sr) RPM-302B : standard photodiode has short current Isc=27µA at E=1000(lx) (using CIE standard light source A) (3) Measurement effective distance, horizontal & vertical half angle RPM7157-R series θ θ Standard transmitter Light detector face illuminance : Ee Effective distance : L (θ ; Indicates horizontal and vertical directions) Fig.3 Measurement condition for effective distance Effective distance L Horizontal & vertical half angle θ : Effective distance at θ=0° Fig.3 : The angle which effective distance became 50% of L. Rev.A 3/7 RPM7157-R series Photo Link Module (4) Output signal 600µs 600µs Transmit signal Carrier frequency=f0 Carrier Duty=50% VCC Output signal VH 1/2 VCC VL GND TON TOFF Fig.4 (5) Measurement circuit for the output voltage and the consumption current ICC A ROUT RPM7157-R GND V VH, VL VCC VCC Fig.5 Rev.A 4/7 RPM7157-R series Photo Link Module How to use the receiver without holder Please use the receiver with shield case or shield plate as an EMI noise measures. (Shield case and shield plate are required to be grounded.) Because internal or external noise (CRT, fluorescent tube, motor, LCD backlight) of the receiver may cause malfunction like a reduced effective distance. (In the case of internal and external noise are strong, please use RPM7157-HxR series with holder.) Notes (1) All characteristics of the receiver in this specification are specified by supplying burst wave form with ROHM standard transmitter (Shown as 8 (2) ). If in case of other burst wave form will be used, please check these spec. Carefully under the evaluations. (2) When the receiver will be used as the wire-less remote controller, please use the signal method the signal format which refer to “Measures to prevent malfunctioning of IR remote-controlled electric home appliances”. (Published July 1987 by Association of Electric Home Appliances) If using other signal method, signal format, (ex: signal format which not including the leader signal) the receiver might have chances to miss-function. (3) Please set up transmitter’s carrier frequency as same as the receiver’s f0 frequency. Otherwise error might be occurred. (4) If transmission signal has non-continues carrier, error might be occurred. Continuous carrier is necessary. T1 T1≠T2 T2 (5) The receiver was designed to use as in-door use only. Therefore, please understand that the receiver cannot cover all characteristics, in case of using it out-door. (6) Noise environment (Light noise from inverter Lamp, and other kind of Lamps, Power ripple, electromagnetic noise from power circuit, and etc) may cause a reduced effective distance. (7) Emitting unit (remote control transmitter) has to be considered about its emitting device function, characteristics and characteristics of the receiver. (8) Please connect “Holder” on to the “Ground (GND)” of PCB. If the holder is not connected to the GND, there is a possibility of worsening the characteristics of product. (9) Do not supply unnecessary stress to lead. (10) Please pay careful attention to the lens. It might have a chance to miss-function when the lens get dust or dirty. And also please do not touch the lens. (11) In order to prevent IC from ESD, human body and solder iron, etc. are required to be grounded. Rev.A 5/7 RPM7157-R series Photo Link Module Electrical and optical characteristics curves 120 0.00 100 −2.00 −4.00 Rerative sensitivity : (%) 80 Gain : (dB) 60 −6.00 40 20 −8.00 0 700 750 800 850 900 950 1000 1050 1100 1150 1200 −10.00 −4 −3 −2 −1 fo +1 +2 +3 +4 Wave length : λ (nm) Frequency : (kHz) Fig.6 RPM7157 Series BPF Characteristics Fig.7 Optical bandwidth of the photo-diode encapsulation 100 100 Relative effective distance : (%) 60 Relative effective distance : (%) −80 −60 −40 −20 80 80 60 40 40 20 20 0 0 20 40 60 80 0 −80 −60 −40 −20 0 20 40 60 80 Angle : (˚) Angle : (˚) Fig.8 Direction characteristic (Horizontal direction) Fig.9 Direction characteristic (Vertical direction) Rev.A 6/7 RPM7157-R series Photo Link Module Dimensions (Unit : mm) 9.0 6.0 1.8 7.3 7.30 7.20 3.60 0.65 15.0 17.95 2.95 2.35 6.0 9.0Max. 6.5 4.0 4.8 3.2 0.8 7.95 7.00 3.6 9.25 0.4 1.40 1.40 3.6 123 0.40 0.50 2.54 1 22Min. 2 3 3.60 0.5 1.5 0.4 2.5 1.4 1.4 4.6 6.3 0.6 0.5 0.6 2.54 2.54 0.60 1.80 2.54 2.54 2.54 0.30 RSIP-A3 (H13) RSIP-A3 (H8) 0.60 RSIP-A3 2.35 0.65 2.95 3.6 1.8 7.0 2.95 12.00 3.60 12.65 7.00 12.65 1.40 1.40 0.65 2.35 15.9 7.30 7.3 1.4 1.4 0.50 123 0.5 0.4 4.2 0.40 2.54 2.54 2.54 2.54 3.60 6.0 9.0Max. 6.5 4.0 4.8 3.2 0.8 0.6 1.80 0.60 123 2.54 2.54 2.5 1.5 0.5 0.6 0.30 0.60 RSIP-A3 (H4) RSIP-A3 (H9) RSIP-A3 V4 9.0 6.0 1.8 7.3 2.95 12.55 3.6 3.6 0.4 2.5 1.4 1.4 4.6 6.3 0.6 1.0 0.5 0.6 Pin No. Rout GND VCC 2.54 2.54 RSIP-A3 (H5) Rev.A 0.4 20.0min 7/7 Appendix Notes No technical content pages of this document may be reproduced in any form or transmitted by any means without prior permission of ROHM CO.,LTD. The contents described herein are subject to change without notice. The specifications for the product described in this document are for reference only. Upon actual use, therefore, please request that specifications to be separately delivered. Application circuit diagrams and circuit constants contained herein are shown as examples of standard use and operation. Please pay careful attention to the peripheral conditions when designing circuits and deciding upon circuit constants in the set. Any data, including, but not limited to application circuit diagrams information, described herein are intended only as illustrations of such devices and not as the specifications for such devices. ROHM CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any third party's intellectual property rights or other proprietary rights, and further, assumes no liability of whatsoever nature in the event of any such infringement, or arising from or connected with or related to the use of such devices. Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or otherwise dispose of the same, no express or implied right or license to practice or commercially exploit any intellectual property rights or other proprietary rights owned or controlled by ROHM CO., LTD. is granted to any such buyer. Products listed in this document are no antiradiation design. The products listed in this document are designed to be used with ordinary electronic equipment or devices (such as audio visual equipment, office-automation equipment, communications devices, electrical appliances and electronic toys). Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. About Export Control Order in Japan Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control Order in Japan. In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause) on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction. Appendix1-Rev1.1
RPM7157-H13R
### 物料型号 - RPM7157-R - RPM7157-V4R - RPM7157-H13R - RPM7157-H5R - RPM7157-H4R - RPM7157-HBR - RPM7157-H9R
### 器件简介 RPM7157-R系列是遥控接收模块,通过使用树脂封装实现了小型化、轻量化和低电流消耗。
### 引脚分配 | Pin No. | Pin name | Function | | --- | --- | --- | | 1 | ROUT | 输出端 | | 2 | GND | 地 | | 3 | Vcc | 电源 |
### 参数特性 绝对最大额定值: - 供电电压(Vcc): -0.3 to +7.0V - 输出电流(io): 2.0mA - 存储温度(Tstg): -30 to +100°C - 工作温度(Topr): -10 to +75°C
推荐工作条件: - 供电电压(Vcc): 4.5 to 5.5V
电气特性(在25°C,Vcc=5V条件下): - 消耗电流(Icc): 1.0mA(无外界光,无信号输入) - 有效距离(L): 8m到15m(外界光条件Ee < 10lx) - 高电平输出电压(VH): 4.5V - 低电平输出电压(VL): 0.5V(Isink=200μA) - ON脉冲宽度(TON): 400到800μs - OFF脉冲宽度(TOFF): 400到800μs - 中心频率(fo): 56.9kHz - 水平半角(θ1/2): 45°±1° - 垂直半角(θ1/2): 35°±1°
### 功能详解 该模块设计用于接收红外信号,具有低电流消耗、高抗干扰能力和多种安装支架可选。适用于所有家用电器,如电视、DVD、空调和音响设备。
### 应用信息 适用于各种家用电器,通过红外信号进行遥控操作。
### 封装信息 提供了多种封装类型,包括直插型RSIP-A3、L型RSIP-A3 V4以及带支架的RSIP-A3等不同高度和视图的封装选项。
RPM7157-H13R 价格&库存
很抱歉,暂时无法提供与“RPM7157-H13R”相匹配的价格&库存,您可以联系我们找货
