RPM7236-H8
RPM7236-H8
    ROHM(罗姆)
    RSIP-A3
    RECEIVER REMOTE CTRL 36.0KHZ TOP
RPM7236-H8 数据手册
RPM7236-H5R RPM7236-R series Photo Link Module IR Receiver Module RPM7236-R series RPM7236-R series are remote control receiver module. Small-sized, light-weight, and low voltage operated (from 2.7V) modules have been achieved by using resin mold. zCenter frequency 36.0kHz zApplications All household electric appliances such as TV, DVD, air conditioner and audio equipment zFeatures 1) Low voltage operation. (VCC=2.7 to 3.6V) 2) Low current consumption. (ICC=0.3mA, VCC=3V) 3) Superior anti VCC noise characteristics. 4) 5 types of holders available to each set. zRPM7236-R series SIDE VIEW TOP VIEW RSIP-A3 (H13) RSIP-A3 (H5) RSIP-A3 (H4) RSIP-A3 (H8) RSIP-A3 (H9) Height of lens 15.0mm 9.6mm 15.9mm 7.2mm 12.0mm Products No. ∗RPM7236-H13R RPM7236-H5R RPM7236-H4R ∗RPM7236-H8R ∗RPM7236-H9R ∗Under development zAbsolute maximum ratings (Ta=25°C) Parameter Symbol Limits Unit Supply voltage VCC 6.3 V Output current IO 2.0 mA Storage temperature Tstg −30 to +100 °C Operating temperature Topr −10 to +75 °C zRecommended operating conditions (Ta=25°C) Parameter Supply voltage Symbol Min. Typ. Max. Unit VCC 2.7 3.0 3.6 V Rev.C 1/6 RPM7236-R series Photo Link Module zBlock diagram VCC 100kΩ AMP Limiter Comparator ROUT BPF I/V GND Demodulator and integrator zTerminal description Pin No. Pin name 1 VOUT OUTPUT TERMINAL Function 2 GND GROUND 3 VCC POWER SUPPLY zElectrical, Optical characteristics (Unless otherwise noted Ta=25°C, VCC=3V) Parameter Symbol Min. Typ. Max. Unit ICC − 300 500 µA No outside light, no signal input. Consumption current Conditions Effective distance L 8 15 − m ∗1 Outer light condition Ee < 10 (Ix) High level output voltage VH 2.5 − − V ∗1 Low level output voltage VL − − 0.5 V ∗1 Isink < 200µA ON pulse width TON 400 600 800 µs ∗1 Outer light condition Ee < 10 (Ix) OFF pulse width TOFF 400 600 800 µs ∗1 Outer light condition Ee < 10 (Ix) fo − 36.0 − kHz Horizontal half angle θ 1/2 − 45 − deg ∗2 Vertical half angle θ 1/2 − 35 − deg ∗2 Central frequency ∗1 The burst wave form mentioned in Fig.1 is to be transmitted from standard transmitter(Fig.2) Measure 10th or later pulse width after beginning of transmission. ∗2 The angle which effective distance become 50% of L. (effective distance at θ=0°) z Measurement Conditions (1) Transmit signal 600µs 600µs Carrier frequency=fo, Duty=50% Fig.1 Transmit signal. Rev.C 2/6 RPM7236-R series Photo Link Module (2) Standard transmitter λ peak=940nm ∆ λ =40nm io=VOUT / R 20cm RPM−302B Standard transmitter R VOUT Fig.2 Measurement of standard transmitter proof reading. When standard transmitter output the signal at Fig.1 standard photodiode output become io=5µAp-p under the measurement condition Fig.2. (The radiant intensity of standard transmitter : 50mW / sr) RPM-302B: standard photodiode has short current Isc=27µA at Ee=1000(lx) (using CIE standard light source A) (3) Measurement effective distance, horizontal & vertical half angle RPM7236-R series θ θ Standard transmitter Light detector face illuminance : Ee Effective distance : L (θ ; Indicates horizontal and vertical directions) Fig.3 Measurement condition for effective distance. Effective distance L Horizontal & vertical half angle θ : Effective distance at θ=0° Fig.3 : The angle which effective distance became 50% of L. Rev.C 3/6 RPM7236-R series Photo Link Module (4) Output signal 600µs 600µs Transmit signal Carrier frequency=fo Carrier Duty=50% Output signal VCC VH 1/2 VCC VL GND TOFF TON Fig.4 (5) Measurement circuit for the output voltage and the consumption current ICC VCC A ROUT VCC RPM7236-R GND V VH, VL Fig.5 Rev.C 4/6 RPM7236-R series Photo Link Module zNotes (1) All characteristics of the receiver in this specification are specified by supplying burst wave form with ROHM standard transmitter (Shown as 8 (2) ). If in case of other burst wave form will be used, please check these spec. carefully under the evaluations. (2) When the receiver will be used as the wire-less remote controller, please use the signal method the signal method the signal format which refer to “Measures to prevent malfunctioning of IR remote-controlled electric home appliances”. (Published July 1987 by Association of Electric Home Appliances) Other examples for suitable signal format are RC5 Code, RC6 Code, RCMM Code. If using other signal method, signal format, (ex: signal format which not including the leader signal) the receiver might have chances to miss-function. (3) Please set up transmitter’s carrier frequency as same as the receiver’s f0 frequency. Otherwise error might be occurred. (4) If transmission signal has non-continues carrier, error might be occurred. Continuous carrier is necessary. T1 T1≠T2 T2 (5) The receiver was designed to use as in-door use only. Therefore, please understand that the receiver cannot cover all characteristics, in case of using it out-door. (6) Noise environment (Light noise from inverter Lamp, and other kind of Lamps, Power ripple, electromagnetic noise from power circuit, and etc) may cause a reduced effective distance. (7) The receiver may not work properly if the receiving signal judgment is done by single pulse due to the surrounding / environmental noises. To prevent such misjudgment, please make sure that the receiver is set up to work only when receiving series of the coded signal. (8) Emitting unit (remote control transmitter) has to be considered about its emitting device function, characteristics and characteristics of the receiver. (9) Attach holder on PCB pattern. (Holder do not conduct to GND) (10) Do not supply unnecessary stress to lead and holder. (11) Please pay attention to the lens carefully. It might have a chance to miss-function when the lens get dust or dirty. Also, please do not touch the lens. (12) In order to protect the products from ESD, human body, solder iron and etc. are required to be grounded. Rev.C 5/6 RPM7236-R series Photo Link Module zDimensions (Unit : mm) 7.30 2.95 12.65 3.60 2.54 2.54 1 2 3 0.60 0.4 1 2 3 1.80 0.30 0.60 0.6 0.5 0.6 0.50 0.40 2.54 7.00 3.60 1.40 1.40 2.54 4.2 2.35 0.65 2.95 7.0 12.65 2.35 7.3 1.8 1.4 1.4 0.65 15.9 3.6 12.00 RSIP-A3(H4) RSIP-A3(H9) 9.0 1.8 2.5 4.6 2.5 0.5 0.6 3.6 7.95 3.6 1.0 3.6 0.4 0.4 1.4 0.6 1.4 1 2 3 4.6 0.6 6.3 0.5 0.6 1 2 3 6.3 2.54 2.54 2.54 2.54 1.4 7.3 15.0 17.95 12.55 3.6 6.0 1.4 1.8 6.0 7.3 2.95 9.0 RSIP-A3(H13) RSIP-A3(H5) 2.95 7.20 7.00 0.65 3.60 9.25 2.35 1.40 1.40 7.30 0.40 0.60 2.54 1.80 2.54 1 ROUT 2 GND 3 VCC 0.30 0.60 PIN No. 0.50 3.60 RSIP-A3(H8) Rev.C 6/6 Appendix Notes No technical content pages of this document may be reproduced in any form or transmitted by any means without prior permission of ROHM CO.,LTD. The contents described herein are subject to change without notice. The specifications for the product described in this document are for reference only. Upon actual use, therefore, please request that specifications to be separately delivered. Application circuit diagrams and circuit constants contained herein are shown as examples of standard use and operation. Please pay careful attention to the peripheral conditions when designing circuits and deciding upon circuit constants in the set. Any data, including, but not limited to application circuit diagrams information, described herein are intended only as illustrations of such devices and not as the specifications for such devices. ROHM CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any third party's intellectual property rights or other proprietary rights, and further, assumes no liability of whatsoever nature in the event of any such infringement, or arising from or connected with or related to the use of such devices. Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or otherwise dispose of the same, no express or implied right or license to practice or commercially exploit any intellectual property rights or other proprietary rights owned or controlled by ROHM CO., LTD. is granted to any such buyer. Products listed in this document are no antiradiation design. The products listed in this document are designed to be used with ordinary electronic equipment or devices (such as audio visual equipment, office-automation equipment, communications devices, electrical appliances and electronic toys). Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. About Export Control Order in Japan Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control Order in Japan. In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause) on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction. Appendix1-Rev1.1
RPM7236-H8 价格&库存
很抱歉,暂时无法提供与“RPM7236-H8”相匹配的价格&库存,您可以联系我们找货
