SERIES CATALOG
Photo Link Modules
Remote Control Receiver Module
IrDA Infrared Communication Module
■Contents
Remote Control Receiver Module Selection Guide ...................................................
1
RPM7200 Series .............................................................................................................
3
RPM7100 Series .............................................................................................................
5
External Dimensions .......................................................................................................
7
Basic Knowledge of Remote Control ...........................................................................
9
Remote Control Receiver Module and Data Communication ..................................
10
11
13
Precautions for Designing Transmitter Side ...............................................................
15
17
Receiving Discrimination Method to Expand Effective Distance .............................
21
22
Block Diagram and Work of Remote Control Receiver Module
Remote Control Transmission Signal
Precautions for Designing Receiver Side
Measures for Preventing Malfunctions
■Remote Control Receiver Module Selection Guide
Remote Control Receiver Module (at 3.0 to 3.3V)
R
36.0kHz
9.6mm
36.7kHz
Carrier
frequency
37.9kHz
40.0kHz
Distance
from PCB
to lens
36.0kHz
15.0mm
36.7kHz
SIDE VIEW
Carrier
frequency
37.9kHz
40.0kHz
36.0kHz
Shape
7.2mm
36.7kHz
Carrier
frequency
37.9kHz
40.0kHz
RPM7236-H5
RPM7237-H5
RPM7238-H5
RPM7240-H5
RPM7236-H13
RPM7237-H13
RPM7238-H13
RPM7240-H13
RPM7236-H8
RPM7237-H8
RPM7238-H8
RPM7240-H8
TOP VIEW
36.0kHz
12.0mm
36.7kHz
Distance
from PCB
to lens
Carrier
frequency
37.9kHz
40.0kHz
36.0kHz
15.9mm
36.7kHz
Carrier
frequency
37.9kHz
40.0kHz
1
RPM7236-H9
RPM7237-H9
RPM7238-H9
RPM7240-H9
RPM7236-H4
RPM7237-H4
RPM7238-H4
RPM7240-H4
Remote Control Receiver Module (at 5.0V)
36.0kHz
5.5mm
36.7kHz
Carrier
frequency
37.9kHz
40.0kHz
56.9kHz
36.0kHz
9.6mm
Distance
from PCB
to lens
36.7kHz
Carrier
frequency
37.9kHz
40.0kHz
56.9kHz
3
3
36.0kHz
SIDE VIEW
15.0mm
3
36.7kHz
Carrier
frequency
3
37.9kHz
40.0kHz
56.9kHz
Shape
36.0kHz
4.8mm
36.7kHz
Carrier
frequency
37.9kHz
40.0kHz
56.9kHz
36.0kHz
7.2mm
36.7kHz
TOP VIEW
Carrier
frequency
Distance
from PCB
to lens
37.9kHz
40.0kHz
56.9kHz
36.0kHz
12.0mm
36.7kHz
Carrier
frequency
37.9kHz
40.0kHz
56.9kHz
36.0kHz
15.9mm
36.7kHz
Carrier
frequency
37.9kHz
40.0kHz
56.9kHz
2
RPM7136
RPM7137
RPM7138
RPM7140
RPM7157
RPM7136-H5
RPM7137-H5
RPM7138-H5
RPM7140-H5
RPM7157-H5
RPM7136-H13
RPM7137-H13
RPM7138-H13
RPM7140-H13
RPM7157-H13
RPM7136-V4
RPM7137-V4
RPM7138-V4
RPM7140-V4
RPM7157-V4
RPM7136-H8
RPM7137-H8
RPM7138-H8
RPM7140-H8
RPM7157-H8
RPM7136-H9
RPM7137-H9
RPM7138-H9
RPM7140-H9
RPM7157-H9
RPM7136-H4
RPM7137-H4
RPM7138-H4
RPM7140-H4
RPM7157-H4
■Electrical and Optical Characteristics of RPM7200 Series
■T
Parameter
Symbol
Limits
Unit
VCC
6.3
V
Storage Temperature Range
Tstg
-30~+100
°C
Operating Temperature Range
Topr
-10~+75
°C
Solder Temperature
Tsol
Supply Voltage
Gain (dB)
Absolute Maximum Ratings (Ta=25°C)
°C
260*
* Within 5s and 3mm of the route of the lead.
Parameter
Symbol
Min.
Typ.
Max.
Unit
VCC
2.7
3.0
3.6
V
Supply Voltage
Electrical Characteristics (Ta=25°C and Vcc=3V unless otherwise specified)
Parameter
Symbol
Min.
Current Consumption
Icc
Effective Distance on Axis
L
8
High Level Output Voltage
VH
2.5
Typ.
Max.
Unit
0.3
0.5
mA
With no external light or input
m
*1 External light condition Ee
很抱歉,暂时无法提供与“RPM7240-H4R”相匹配的价格&库存,您可以联系我们找货
