RPM841-H16
Photo Link Module
IrDA Infrared Communication Module
RPM841-H16
RPM841-H16 is an infrared communication module for IrDA Ver. 1.2 (Low Power). The infrared LED, PIN photo diode,
LSI are all integrated into a single package. This module is designed with power down function and low current
consumption at stand-by mode. The ultra small package makes it a perfect fit for mobile devices.
zFeatures
1) Infrared LED, PIN photo diode, LED driver & Receiver frequency formation circuit built in. Improvement of EMI noise
protection because of Shield Case.
2) Applied to SIR (2.4 to 115.2kbps)
3) Surface mount type.
4) Power down function built in.
5) Super small package (W=6.8mm, D=1.7mm, H=2.28mm).
6) Infrared remote control transmission driver built-in.
zApplications
Mobile phone, PDA, DVC, Digital Still Camera, Printer, Handy Terminal etc.
zAbsolute maximum ratings (Ta=25°C)
Parameter
Supply voltage
Input voltage
Symbol
Unit
Limits
Vmax
7.0
Vin (3, 4, 5pin)
V
−0.3 to VCC+0.3
V
Operation temperature
Topr
−30 to +85
°C
Storage temperature
Tstg
−40 to +100
°C
∗ This applies to all pins basis ground pins (7pin)
zRecommended operating conditions (Ta=25°C)
Parameter
Supply voltage
LED supply voltage
Symbol
Min.
Typ.
Max.
Unit
VCC
2.4
3.0
3.6
V
VLEDVCC
2.6
3.0
5.5
V
Rev.B
1/9
RPM841-H16
Photo Link Module
1
zBlock diagram and application circuit
LEDA
(LEDVCC)
2
3
TXD
4
RXD
5
PWDOWN
6
POWER
DOWN
TX-RC
VCC
7
AMP
TX-RC
TXD
RXD
PWDOWN
AMP
AMP
AMP
R1
GND
VCC
GND
C1
VCC (6pin) and LEDVCC (1pin)
can be used on either common power source
or different one
Rev.B
2/9
RPM841-H16
Photo Link Module
zTerminal description
Pin No
Terminal
Circuit
LEDA
LED
Function
1
1
LED ANODE Terminal
Other power source can be used
difference between LEDVCC and VCC.
VCC
2
RC Transmitting Data Input Terminal
H : LED Emitting (Remote Control Mode)
CMOS Logic Level Input
Holding TX-RC='H' status, LED will be
turn off approximately 48µs.
TX-RC
240k
VCC
3
TXD input at PWDOWN=L
H : LED Emitting
Holding TXD="H" status, LED will be
TXD
240k
VCC
PWDOWN
4
RXD
300k
VCC
5
PWDOWN
6
VCC
7
GND
Shield Case
Receiving Data Output Terminal
CMOS Logic Level Output
When PWDOWN (5pin)= 'H', the RXD
output will be pulled up to VCC at
approximately 300kΩ.
Power-down Control Terminal
H : POWERDOWN
L : OPERATION
When input is 'H', it will stop the receiving
circuit and Pin-PD current.
Power Supply Terminal
For preventing from infection, connect
a capacitor between VCC (6pin) and
GND (7pin).
Ground Termianl
Connect to Ground.
Rev.B
3/9
RPM841-H16
Photo Link Module
zElectrical characteristics (Unless otherwise noted, VCC= 3.0V, VLEDVCC=3.0V, Ta=25°C)
Parameter
Symbol
Min.
Typ.
Max.
Unit
Consumption current1
ICC1
90
120
µA
PWDOWN=0V At no input light
Consumption current2
ICC2
PWDOWN=VCC At no input light
Data rate
0.01
0.2
µA
2.4
115.2
kbps
Conditions
PWDOWN input high voltage
VPDH
2/3∗VCC
VCC
V
VCC=2.4 to 3.6V
PWDOWN input low voltage
VPDL
1/3∗VCC
V
VCC=2.4 to 3.6V
PWDOWN input high current
IPDH
−1.0
µA
PWDOWN=VCC
PWDOWN input low current
IPDL
−1.0
µA
PWDOWN=0V
TXD input high voltage
VTXH
2/3∗VCC
VCC=2.4 to 3.6V
VTXL
VCC
1/3∗VCC
V
TXD input low voltage
V
VCC=2.4 to 3.6V
TX-RC input high voltage
VTX-RCH
1.5
VCC
V
VCC=2.4 to 3.6V
TX-RC input low voltage
VTX-RCL
V
VCC=2.4 to 3.6V
TXD/TX-RC input high current
ITXH
6.2
12.5
25
µA
TXD=VCC or TX-RC=VCC
TXD/TX-RC input low current
ITXL
−1.0
µA
TXD=0V or TX-RC=0V
LED anode current (IrDA Mode)
ILEDA1
50
70
mA
TXD=VCC
LED anode current (RC Mode)
ILEDA2
211
245
mA
TX-RC=VCC, R1=2.2Ω
RXD output high voltage
VRXH
VCC−0.4
VCC
V
IRXH= −200µA
RXD output low voltage
VRXL
V
IRXL=200µA
tRR
25
100
ns
CL=15pF
RXD output rise Time
RXD output fall Time
RXD output pulse width
Receiver latency time
tFR
25
100
ns
CL=15pF
twRXD
1.7
2.6
3.5
µs
CL=15pF, 2.4 to 115.2kbps
tRT
40
200
µs
zOptical characteristics (Unless otherwise noted, VCC= 3.0V, VLEDVCC=3.0V, Ta=25°C)
Parameter
Symbol
Min.
Typ.
Max.
Unit
880
888
892
nm
ILED=50mA, Duty20%
ILED=50mA, Duty20%, −20 to 60°C
Conditions
Peak wave length1 (IrDA Mode)
λP1
850
900
nm
Peak wave length2 (RC Mode)
λP2
880
890
920
nm
Intensity1 (IrDA Mode)
IE1
4
12
28
mW/sr
−15°
θL
15°
R1=2.2Ω
−15°
θL
15°
R1=2.2Ω
ILED=200mA, Duty20%
Intensity2 (RC Mode)
IE2
25
50
120
mW/sr
Half-angle
θL/2
±15
deg
Optical pulse width1 (IrDA Mode)
TWLED1
1.42
1.63
2.02
µs
TXD=1.63µs pulse input
R1=2.2Ω
Optical pulse width2 (RC Mode)
TWLED2
9.5
10
10.5
µs
TX-RC=10µs pulse input
R1=2.2Ω
Tr/Tf
ns
10% to 90%
25
Rise time / Fall time
Optical over shoot
Tj
−40
40
ns
Minimum Irradiance in angular
Eemin
4.0
8.1
µW/cm2
−15°
θL
+15°
Maximum Irradiance in angular
Eemax
500
mW/cm2
−15°
θL
+15°
θD/2
±15
deg
TLEDmax
20.5
48
96
µs
Edge jitter
Input half-angle
Maximum emitting time
TXD=0
VCC or TX-RC=0
VCC
1. This product is not designed for protection against radioactive rays.
2. This product dose not include laser transmitter.
3. This product includes one PIN photo diode.
4. This product dose not include optical load.
Rev.B
4/9
RPM841-H16
Photo Link Module
zLED Operation Mode Table
PWDOWN
(5pin)
TX-RC
(4pin)
TXD
(7pin)
LED
Emitting Mode
IrDA Receiver
Operation Condition
L
L
L
OFF
ON
L
L
IrDA
ON
L
RC
ON
L
OFF
OFF
OFF
OFF
RC
OFF
L
H
L
H
L
H
L
Notes) Please be sure to set up the TX-RC (2pin) and the TXD (3pin) input to be ''L'' (under 0.3V)
except transmitting data (for < 90µs. ON Duty 50%).
of TX-RC (2pin) and TXD (3pin) in the table above is supposed to be the pulse input.
When either TX-RC (2pin) input TXD (3pin) input keeps the state of ''H'' (more than appproximately 48µs),
LED will be turned off due to LED pulse width limiting circuit if the pulse is input from the other terminal.
Therefore, don't use as the normal transmitting is impossible.
Please input the pulse when both TX-RC (2pin) and TXD (3pin) are ''L''.
Even if RPM841-H16 input H pulse into TXD in the state of a power down, LED does not emanate.
zInterface operating timing
(Emitting side)
(1) When TXD output for IrDA and TXD output for controller are different lines.
1
LEDA
LEDVCC
RC Transmitting
Controller
(BU787X etc)
TX-RC
TXD
IrDA
RXD
Controller
PWDOWN
VCC
VCC
GND
7
Rev.B
5/9
RPM841-H16
Photo Link Module
(2-a) RC transmitting mode at IrDA receiver active condition.
Input
Condition
PWDOWN
TX-RC
TXD
LED Mode
Recriver circuit
L
L
L
OFF
ON
L
L
IrDA
ON
L
RC
ON
L
OFF
OFF
L
H
L
TX-RC
(2pin)
Min 1µs
Min 1µs
TXD
(3pin)
PWDOWN
(5pin)
LED Emitting
Emitting Mode
RC
IrDA
IrDA
RC
∗If TX-RC or TXD input pulse width is wider than 48µs, output LED emitting pulse will be turn off approximately 48µs.
Rev.B
6/9
RPM841-H16
Photo Link Module
(2-b) RC transmit mode at IrDA receiver power down condition.
Input
Condition
PWDOWN
TX-RC
TXD
LED Mode
Recriver circuit
L
L
L
OFF
ON
IrDA
ON
L
RC
OFF
L
OFF
OFF
L
L
H
H
L
Min 1µs
TX-RC
(2pin)
Min 1µs
Min 1µs
Min 1µs
TXD
(3pin)
PWDOWN
(5pin)
LED Emitting
Emitting Mode
IrDA
RC
RC
IrDA
(Receiving side)
Light input
Min 200µs
PWDOWN
(5pin)
RXD
(4pin)
Pull up to VCC at
approximately 300kΩ
∗RXD output width is fixed approximately 2.6µs.
Note RXD output become stable after 200µs since PWDOWN is changed from H to L.
RXD output could be unstable at H to L within 200µs.
Rev.B
7/9
RPM841-H16
Photo Link Module
zAttached components
Recommended values
Part symbol
Recommended value
Notice
C1
1µF, tantalum or ceramic
Ex.) TCFGA1A105M8R (ROHM)
Bigger capacitance is recommended with much noise from power supply
R1
2.2Ω±5%, 1/8W
(VLEDVCC=3V)
At LED Emitting Duty=25%
[LED current set-up method for Remote control mode]
In case of using R1 with different condition from the above, formula is as follows :
LED resistance value : R1[Ω], LED average consumption current : ILED[mA], Supply voltage : VLEDVCC[V],
minimum necessary of irradiant intensity le1 [mW / sr]
(Including LED’s distribution within ±15deg)
R1=166 × (VLEDVCC−1.31) / le1−7.2
ILED=Duty × (VLEDVCC−1.31) / (R1+5.8)
Duty : LED duty at emitting
∗ Please set up to be ILED / Duty < 250[mA] (Duty ≤ 25%)
∗ At IrDA Mode, LED current is constantly approximately 50mA.
(Reference) In case of using R1, typical intensity (le1typ) and maximum intensity (le1max) on
axis are described as below.
le1typ=280 × (VLEDVCC−1.31) / (R1+5.8)
le1max=560 × (VLEDVCC−1.31) / (R1+5.8)
zNotes
1) LEDVCC (1pin), VCC (6pin)
Other power source can be used difference between LEDVCC and VCC.
2) Caution in designing board lay-out
To get maximum potential from RPM841-H16, please keep in mind following instruction.
The line of RXD (4pin) should be connected at backside via through hole close to RPM841-H16 pin lead. Better not to
be close to photo diode side (7pin).
⇒This is to minimize feedback supplied to photo diode from RXD.
As for C1 between 6-7 pin should be placed close to RPM841-H16.
Better to be placed more than 1.0cm in radius from photo diode (pin7 side) and also away from the parts which
generates noise, such as DC / DC converter.
3) Notes
Please be sure to set up the TX-RC (2pin) and the TXD (3pin) input to be “L” (under 0.3V) except transmitting data
(for < 90µs, ON duty ≤ 50%).
Power down current might increase if exposed by strong light (ex. direct sunlight) at powerdown mode.
Please use by the signal format at IrDA operating mode which is specified by IrDA Ver1.2 (2.4k to 115.2kbps). There
might be on error if used by different signal format.
Please pay attention to the lens carefully.
Dusts of scratch on the lens may effect the characteristics of product. Please handle it with care.
Rev.B
8/9
RPM841-H16
Photo Link Module
4) Eye safe
IEC60825-1 (IEC60825-1 amendment2), Class 1 Eye Safe.
5) LED current derating and amdient temperature
The relation between LED peak current and maximum ambient temperature is shown below.
We recommend you to use within the range as indicated in below.
MAXIMUM LED PEAK CURRENT : Iledp (mA)
When glass-epoxy board (50×50×1.6mm) mounted.
300
250
200
Duty:25%
Duty:20%
150
Duty:15%
100
Duty:10%
50
−20
60
80
100
AMBIENT TEMPERATURE : Ta (°C)
zDimensions (Unit : mm)
RPM841-H16
6.8
MOUNTING CENTER
2.3
1.7
1.54
0.35
0.88
0.8
1pin
0.37±0.1
0.95
P0.95x6=5.7
7pin
2.13
0.08MAX
COPLANARITY
1.95
1.08
1.0
R0.9
PD
4-φ0.3
LED
STAND OFF
0.05±0.05
0.4
3.4
2.38
0.35
R0.83
NOTE
1.TOLERANCE:±0.2
UNIT:mm
ETH949
Rev.B
9/9
Appendix
Notes
No technical content pages of this document may be reproduced in any form or transmitted by any
means without prior permission of ROHM CO.,LTD.
The contents described herein are subject to change without notice. The specifications for the
product described in this document are for reference only. Upon actual use, therefore, please request
that specifications to be separately delivered.
Application circuit diagrams and circuit constants contained herein are shown as examples of standard
use and operation. Please pay careful attention to the peripheral conditions when designing circuits
and deciding upon circuit constants in the set.
Any data, including, but not limited to application circuit diagrams information, described herein
are intended only as illustrations of such devices and not as the specifications for such devices. ROHM
CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any
third party's intellectual property rights or other proprietary rights, and further, assumes no liability of
whatsoever nature in the event of any such infringement, or arising from or connected with or related
to the use of such devices.
Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or
otherwise dispose of the same, no express or implied right or license to practice or commercially
exploit any intellectual property rights or other proprietary rights owned or controlled by
ROHM CO., LTD. is granted to any such buyer.
Products listed in this document are no antiradiation design.
The products listed in this document are designed to be used with ordinary electronic equipment or devices
(such as audio visual equipment, office-automation equipment, communications devices, electrical
appliances and electronic toys).
Should you intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical instruments,
transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other
safety devices), please be sure to consult with our sales representative in advance.
About Export Control Order in Japan
Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control
Order in Japan.
In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause)
on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction.
Appendix1-Rev1.1
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
ROHM Semiconductor:
RPM841-H16E4A1 RPM841-H16E4A2 RPM841-H16E4A3
