RPM870-H14E2A
RPM870-H14E2A
    ROHM(罗姆)
    Module
    RPM870-H14是一款支持IrDA Ver. 1.2 (Low Power)的红外无线通信收发模块,适用于移动设备。集成红外LED、PIN光电二极管和LSI,具有低功耗和关断功能。
RPM870-H14E2A 数据手册
RPM870-H14 RPM870-H14 Photo Link Module IrDA wireless communication transceiver IC (supports Ver. 1.2 Low Power) RPM870-H14 The RPM870-H14 is an Module that supports IrDA Ver. 1.2 (Low Power), and is ideal for wireless communications. An infrared LED, a pin-photo diode, and LSI are all contained in a very small single package. It is also equipped with low power consumption and power down functions making this IC perfect for mobile sets. zFeatures 1) Applied to IrDA Ver. 1.2. (Low Power) 2) Low power consumption while waiting mode. (90µA Typ.). 3) A power-down function is perfect for battery applications. 4) Supports a board power supply voltage range from 2.6V to 3.6V. 5) Only 1 external capacitor required. zApplications Mobile phones, PDAs, and others zAbsolute maximum ratings (Ta = 25°C) Parameter Supply voltage Symbol Limits Unit VCC 7.0 V Vin −0.3 to VCC+0.3 V Operating temperature Topr −20 to +85 °C Storage temperature Tstg −30 to +100 °C Pd 100 mW Input voltage Power dissipation zRecommended operating conditions (Ta = 25°C) Parameter Supply voltage Symbol Min. Typ. Max. Unit VCC 2.6 3.0 3.6 V VLEDA 2.6 3.0 5.5 V 1/6 RPM870-H14 Photo Link Module zBlock diagram and application circuit AMP 2 1 AMP GND NC VCC 3 VCC AMP C1 GND 4 GND PWDOWN PWDOWN 5 POWER DOWN RXD 6 RXD TXD 7 TXD LEDA 8 (LEDVCC) Recommended values Part symbol C1 Recommended value 1µF, tantalum Ex.) TCFGA1A105M8R (ROHM) Notice Bigger capacitance is recommended with much noise from power supply 2/6 RPM870-H14 Photo Link Module zTerminal description Circuit Function Pin No Terminal 1, 4 GND 2 NC This terminal must be left open. VCC VCC For preventing from ripple noise. connect a capacitor between VCC (3pin) and GND (4pin). 3 GND VCC 5 Power-down control terminal H : POWERDOWN L : OPERATION CMOS logic level input When input is H, it will stop the receiving circuit, Pin-PD current and transmitting LED operation. PWDOWN VCC PWDOWN 6 VCC 300k RXD Receiving data output terminal CMOS logic level input When PWDOWN (5pin) = H, the RXD output will be pulled up to VCC at approximately 300kΩ. VCC Transmitting data input terminal 7 TXD 200K H : LED Drive (PWDOWN = L) CMOS logic level output Holding TXD = "H"status, LED will be turn off approximately 48µsec. LED ANODE terminal 8 LEDA LED Other power source can be used difference between LEDVCC and VCC. 3/6 RPM870-H14 Photo Link Module zElectrical characteristics (Unless otherwise noted, VCC=3V, VLEDVCC=3V, Ta=25°C) Symbol Min. Typ. Max. Unit Consumption Current 1 Parameter ICC1 − 90 120 µA Waiting mode, no input light. Consumption Current 2 ICC2 PWDOWN = VCC [V] , no input light. Transmission rate − 0.01 0.2 µA 2.4 − 115.2 kbps V Conditions PWDOWN INPUT High Voltage VPDH VCC−0.5 − − PWDOWN INPUT Low Voltage VPDL − − 0.55 V PWDOWN INPUT High Current IPDH −1.0 0 1.0 µA PWDOWN = VCC [V] PWDOWN INPUT Low Current IPDL −1.0 0 1.0 µA PWDOWN = 0 [V] TXD INPUT High Voltage VTXH VCC−0.55 − − V TXD INPUT Low Voltage VTXL − − 0.55 V TXD INPUT High Current ITXH 7.5 15 30 µA TXD = VCC [V] TXD = 0 [V] ITXL −1.0 0 1.0 µA LED ANODE Current ILEDA − 50 − mA RXD OUTPUT High Voltage VRXH VCC−0.5 − − V IRXH = −50µA RXD OUTPUT Low Voltage VRXL − − 0.4 V IRXL = 200µA tRR − 70 − nsec TXD INPUT Low Current RXD OUTPUT Rise Time RXD OUTPUT Fall Time RXD OUTPUT Pulse Width Receiver Latency Time CL = 15pF tFR − 30 − nsec CL = 15pF twRXD 1.5 2.3 3.6 µsec CL = 15pF, 2.4 to 115.2Kbps tRT − 100 200 µsec zOptical characteristics (Unless otherwise noted, VCC=3V, VLEDVCC=3V, Ta=25°C) Parameter Symbol Min. Typ. Max. Unit Peak wave length λP 850 870 900 nm Intensity IE1 4.0 10 26 mW / sr Half-Angle θL / 2 ±15 − − deg Rise time / Fall time Tr / Tf − − 100 nsec − − 25 % Edge jitter Tj −40 − 40 nsec Irradiance in angular Ee 0.0068 − 500 θD / 2 ±15 − − deg TLEDmax 16 48 96 µsec Optical over shoot INPUT Half-Angular Maximum Emitting Time Conditions −15˚ ≤ θL ≤ 15˚ 10% to 90% mW / cm2 −15˚ ≤ θL ≤ 15˚ TXD=VCC 1.This product is not designed for protection against radioactive rays. 2.This product dose not include laser transmitter. 3.This product includes one pin photo diode. 4.This product dose not include optical load. 4/6 RPM870-H14 Photo Link Module zTiming chart (Emitting side) TXD (7pin) less than 48 µsec (emitting) more than 48 µsec (emitting) (emitting) Internal LED (Light output) approximately 48 µsec (Detecting side) Light input less than 2.3 µsec more than 2.3 µsec RXD (6pin) pull up to VCC at approximately 300kΩ approximately 2.3 µsec approximately 2.3 µsec PWDOWN (5pin) zNotes 1) LEDVCC (8pin) and VCC (3pin) • Other power source can be used difference between LEDVCC and VCC. 2) Caution in designing board lay-out To get maximum potential from RPM870-H14, please keep in mind following instruction. • The line of RXD (6pin) should be connected at backside via through hole close to RPM870-H14 pin lead. Better not to be close to photo diode side (1pin). ⇒This is to minimize feedback supplied to photo diode from RXD. • As for C1 between 3-4 pin should be placed close to RPM870-H14. • Better to be placed more than 1.0cm in radius from photo diode (pin1 side) and also away from the parts which generates noise, such as DC / DC converter. 3) Others • Please be sure to set up the TXD (7pin) input to be “L” (under 0.5V) except transmitting data (for < 90µsec. on duty < 20%). • Powerdown current might increase if exposed by strong light (ex. direct sunlight) at powerdown mode. • Please use by the signal format which is specified by IrDA Ver1.2 (Low Power). There might be on error if used by different signal format. • Please pay attention to the lens carefully. Dusts of scratch on the lens may effect the characteristics of product. Please handle it with care. 4) Eye Safe • IEC825-1 (EN60825-1) Class 1 Eye Safe. 5/6 RPM870-H14 Photo Link Module zDimensions (Unit : mm) R1.1 R1.0 8.0 2.2 2.2 0.78 2.67 2.9 0.15±0.1 2.59 1 A Part Size (Shield Case underside size) 8 2.2 0.37±0.1 0.75 1.1 1.4 2.8 4.0 A 1.0 0.15±0.1 0.76 LED PinPD 0.95 0.48 (0.13) 0.68±0.1 0.6 0.6±0.1 P0.95×7=6.65 NOTE 1.TOLERANCE : ±0.2mm 2.COPLANARITY : 0.1mmMAX UNIT : mm ETH839 6/6 Appendix Notes No technical content pages of this document may be reproduced in any form or transmitted by any means without prior permission of ROHM CO.,LTD. The contents described herein are subject to change without notice. The specifications for the product described in this document are for reference only. Upon actual use, therefore, please request that specifications to be separately delivered. Application circuit diagrams and circuit constants contained herein are shown as examples of standard use and operation. Please pay careful attention to the peripheral conditions when designing circuits and deciding upon circuit constants in the set. Any data, including, but not limited to application circuit diagrams information, described herein are intended only as illustrations of such devices and not as the specifications for such devices. ROHM CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any third party's intellectual property rights or other proprietary rights, and further, assumes no liability of whatsoever nature in the event of any such infringement, or arising from or connected with or related to the use of such devices. Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or otherwise dispose of the same, no express or implied right or license to practice or commercially exploit any intellectual property rights or other proprietary rights owned or controlled by ROHM CO., LTD. is granted to any such buyer. Products listed in this document are no antiradiation design. The products listed in this document are designed to be used with ordinary electronic equipment or devices (such as audio visual equipment, office-automation equipment, communications devices, electrical appliances and electronic toys). Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. About Export Control Order in Japan Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control Order in Japan. In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause) on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction. Appendix1-Rev1.1
RPM870-H14E2A 价格&库存
很抱歉,暂时无法提供与“RPM870-H14E2A”相匹配的价格&库存,您可以联系我们找货
