RPM872-H12
RPM872-H12
    ROHM(罗姆)
    RPM872-H12 - IrDA Infrared communication Module - Rohm
RPM872-H12 数据手册
RPM872-H12 Photo Link Module IrDA Infrared communication Module RPM872-H12 RPM872-H12 is an infrared communication module for IrDA Ver. 1.2 (Low Power). The infrared LED, PIN photo diode, LSI are all integrated into a single package. This module is designed with power down function and low current consumption at stand-by mode. The ultra small package makes it a perfect fit for mobile devices. Features 1) Infrared LED, PIN photo diode, LED driver & Receiver frequency formation circuit built in. Improvement of EMI noise protection because of Shield Case. 2) Applied to SIR (2.4 to 115.2kbps) 3) Surface mount type. 4) Power down function built in. 5) Low voltage operation as 1.5V of interface terminals to controller (TXD, RXD, Power down). Applications Mobile phone, PDA, DVC, Digital Still Camera, Printer, Handy Terminal etc. Absolute maximum ratings (Ta=25°C) Parameter Supply voltage Input voltage Operation temperature Storage temperature Power dissipation Symbol Vmax Vin (5, 6, 7pin) Topr Tstg Pd Limits 7.0∗1 −0.3 to VIO+0.3 −30 to +85 −30 to +100 100∗2 Unit V V °C °C mW ∗1 This applies to all pins basis ground pins (1.4pin) ∗2 In case operating environment is over 25°C, 1.33mW would be reduced per each 1°C stepping up. Recommended operating conditions (Ta=25°C) Parameter Symbol VCC Supply voltage VLEDA VIO Min. 2.0 2.6 1.5 Typ. 3.0 3.0 3.0 Max. 3.6 5.5 VCC Unit V V V Rev.A 1/6 RPM872-H12 Photo Link Module Block diagram and application circuit AMP GND 1 AMP 2 VIO VIO VCC + GND VCC AMP 3 GND C1 4 POWER DOWN PWDOWN PWDOWN 5 6 RXD RXD 7 TXD TXD LEDA 8 (LEDVCC) VCC (3pin) and VLEDA (8pin) can be used on either common power source or different one Rev.A 2/6 RPM872-H12 Photo Link Module Terminal description Pin No 1, 4 Terminal GND Circuit Function GND Pin1 and Pin4 must be connected to the ground. VIO Supply voltage for I/O pins. (PWDOWN, RXD, TXD) VCC Supply voltage for Transceiver circuits. For preventing from infection, connect a capacitor between VCC (3pin) and GND (4pin). 2 VIO 3 VCC VIO 5 PWDOWN Power-down Control Terminal H : POWERDOWN L : OPERATION CMOS Logic Level Input When input is H, it will stop the receiving circuit, Pin-PD current and transmitting LED operation. VIO PWDOWN VIO 300k 6 RXD Receiving Data Output Terminal CMOS Logic Level Input When PWDOWN (5pin)=H, the RXD output will be pulled up to VIO at approximately 300kΩ. VIO 7 TXD 600k Transmitting Data Input Terminal H : LED (PWDOWN=L) CMOS Logic Level Output Holding TXD="H" status, LED will be turn off approximately 48µs. 8 LEDA LED LED ANODE Terminal Other power source can be used difference between LEDVCC and VCC. This can be connected to battery kinds of unegulated constant source by internal constant current driver. − Shield Case Connect to Ground. Rev.A 3/6 RPM872-H12 Photo Link Module Electrical characteristics (Unless otherwise noted, VCC=3V, VLEDA=3V, VIO=3V, Ta=25°C) Parameter Consumption current1 Consumption current2 Transmission rate PWDOWN input high voltage PWDOWN input low voltage PWDOWN input high current PWDOWN input low current TXD input high voltage TXD input low voltage TXD input high current TXD input low current LED anode current RXD output high voltage RXD output low voltage RXD output rise time RXD output fall time RXD output pulse width Receiver latency time VRXH VRXL tRR tFR twRXD tRT VIO−0.4 0 − − 1.5 − − − 35 35 2.3 100 VIO 0.4 − − 4.2 200 V V ns ns µs µs IRXH= −200µA IRXL=200µA CL=15pF CL=15pF CL=15pF, 2.4 to 115.2kbps VTXH VTXL ITXH ITXL ILEDA 2/3∗VIO 1.2 0 2.5 −1.0 − − − 5 0 30.5 − 1/3∗VIO VIO−1.2 10 1.0 − V V µA µA mA VIO=1.8 to 3.6 [V] VIO=1.5 to 1.8 [V] VIO=1.8 to 3.6 [V] VIO=1.5 to 1.8 [V] TXD=VIO [V] TXD=0 [V] VPDH VPDL IPDH IPDL Symbol ICC1 ICC2 Min. − − 2.4 2/3∗VIO 1.2 0 −1.0 −1.0 Typ. 75 0.01 − − − 0 0 Max. 99 0.2 115.2 VIO 1/3∗VIO VIO−1.2 1.0 1.0 Unit µA µA kbps V V µA µA VIO=1.8 to 3.6 [V] VIO=1.5 to 1.8 [V] VIO=1.8 to 3.6 [V] VIO=1.5 to 1.8 [V] PWDOWN=VIO [V] PWDOWN=0 [V] Conditions PWDOWN=0V At no input light PWDOWN=VIO At no input light Optical characteristics (Unless otherwise noted, VCC=3V, VLEDA=3V, VIO=3V, Ta=25°C) Parameter Peak wave length Intensity1 Half-angle Optical pulse width Symbol λP IE1 θL/2 TWLED Min. 850 4.0 − 1.42 Typ. 870 10 ±18 1.63 Max. 900 26 ±30 2.02 Unit nm mW/Sr deg µs Conditions −15°≤θL≤15° TXD=1.63µs pulse input 10% to 90% Rise time / Fall time Optical over shoot Edge jitter Irradiance in angular Input half-angle Maximum emitting time Tr/Tf − − −40 0.0068 ±15 10 − − − − − 48 100 25 40 500 − 120 ns % ns Tj Ee θD/2 TLEDmax mW/cm2 −15deg ≤ θL ≤ +15deg deg µs TXD=VIO 1. This product is not designed for protection against radioactive rays. 2. This product dose not include laser transmitter. 3. This product includes one PIN photo diode. 4. This product dose not include optical load. Rev.A 4/6 RPM872-H12 Photo Link Module Timing chart (Emitting side) TXD (7pin) less than 48µs more than 48µs (emitting) (emitting) (emitting) Internal LED (Light output) approximately 48µs (Detecting side) Light input less than 2.3µs more than 2.3µs RXD (6pin) pull up to VIO at approximately 300kΩ approximately 2.3µs approximately 2.3µs PWDOWN (5pin) Attached components Recommended values Part symbol C1 Recommended value 1µF, tantalum or ceramic Ex.) TCFGA1A105M8R (ROHM) Notice Bigger capacitance is recommended with much noise from power supply Rev.A 5/6 RPM872-H12 Photo Link Module Notes 1) VLEDA (8pin), VCC (3pin) and VIO (2pin) • Other power source can be used difference between VLEDA and VCC and VIO. (VIO < VCC + 0.3V) 2) Caution in designing board lay-out To get maximum potential from RPM872-H12, please keep in mind following instruction. • The line of RXD (6pin) should be connected at backside via through hole close to RPM872-H12 pin lead. Better not to be close to photo diode side (1pin). ⇒This is to minimize feedback supplied to photo diode from RXD. • As for C1 between 3-4 pin should be placed close to RPM872-H12. • Better to be placed more than 1.0cm in radius from photo diode (pin1 side) and also away from the parts which generates noise, such as DC / DC converter. 3) Others • Please be sure to set up the TXD (7pin) input to be “L” (under 0.3V) except transmitting data (for < 90µs, on duty < 20%). • Power down current might increase if exposed by strong light (ex. direct sunlight) at powerdown mode. • Please use by the signal format which is specified by IrDA Ver1.2 (Low Power). • There might be on error if used by different signal format. • Please pay attention to the lens carefully. Dusts of scratch on the lens may effect the characteristics of product. Please handle it with care. 4) Eye safe • IEC825-1 (EN60825-1) Class 1 Eye Safe. External dimensions (Unit : mm) 3.0 0.6 3.0 2.4 PinPD 8.0 LED 0.84±0.1 1.75 5.6 2.8 2.72 0.56 2.49 A Part Size (Shield Case underside size) 1 P0.95×7=6.65 8 7.6 3.0 0.6±0.1 0.68±0.1 NOTE 0.6±0.1 TOLERANCE±0.2mm COPLANARITY:0.1mmMAX UNIT:mm A ETH450 0.75 0.37±0.1 2.0 0.15±0.1 Rev.A 6/6 Appendix Notes No technical content pages of this document may be reproduced in any form or transmitted by any means without prior permission of ROHM CO.,LTD. The contents described herein are subject to change without notice. The specifications for the product described in this document are for reference only. Upon actual use, therefore, please request that specifications to be separately delivered. Application circuit diagrams and circuit constants contained herein are shown as examples of standard use and operation. Please pay careful attention to the peripheral conditions when designing circuits and deciding upon circuit constants in the set. Any data, including, but not limited to application circuit diagrams information, described herein are intended only as illustrations of such devices and not as the specifications for such devices. ROHM CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any third party's intellectual property rights or other proprietary rights, and further, assumes no liability of whatsoever nature in the event of any such infringement, or arising from or connected with or related to the use of such devices. Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or otherwise dispose of the same, no express or implied right or license to practice or commercially exploit any intellectual property rights or other proprietary rights owned or controlled by ROHM CO., LTD. is granted to any such buyer. Products listed in this document are no antiradiation design. The products listed in this document are designed to be used with ordinary electronic equipment or devices (such as audio visual equipment, office-automation equipment, communications devices, electrical appliances and electronic toys). Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. About Export Control Order in Japan Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control Order in Japan. In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause) on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction. Appendix1-Rev1.1
RPM872-H12 价格&库存
很抱歉,暂时无法提供与“RPM872-H12”相匹配的价格&库存,您可以联系我们找货
