RPMD-0132
RPMD-0132
    ROHM(罗姆)
    SMD3
    光电二极管 940nm 3-SMD,无引线
RPMD-0132 数据手册
Surface Mount Type Photo Diode RPMD-0132 Datasheet ●Applications ・Consumer electronics, Industrial electronics ・Wearables ・Other general-purpose applications ●Features ・Thickness 0.55mm ・Improved green wavelength sensitivity for the pulse wave sensing ・Infrared wavelength is also active sensor area ・High active area ratio to the package area ●Outline dimension(Unit:mm) Note) 1. Unspecified tolerance shall be ±0.1mm (unless otherwise noted) 2. (values) are reference 3. Dimensions do not include burrs (MAX burr size +0.1mm) 4. Detector active area(8.9mm2) 5. Terminal 3 does not need to solder www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. 1/3 2020.7 – Rev.001 RPMD-0132 Datasheet ●Absolute maximum ratings (Ta=25℃) Parameter Symbol Values Unit Reverse Voltage Vr 3 V Operating Temperature Topr -25 to +75 ℃ Storage Temperature Tstg -40 to +85 ℃ ●Electrical and Optical characteristics (Ta=25℃) Parameter Symbol Conditions 1mW/cm2 DC DC Sensitivity Re λ=940nm, Vr=1V 1mW/cm2 DC λ=525nm, Vr=1V Values Min. Typ. Max. 0.42 0.57 - Unit A/W 0.30 0.38 - Dark Current iLk Vr=1V - 1 20 nA Diode Capacitance Cd Vr=1V, f=1MHz - 30 - pF Breakdown Voltage Vbr Ir=2μA 15 - - V www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. 2/3 2020.7 – Rev.001 RPMD-0132 Datasheet ●Electrical and Optical characteristic curves Fig.1 Reverse Voltage vs. Dark Current Fig.2 Reverse Voltage vs. Relative Sensitivity Fig.3 Ambient Temperature vs. Relative Sensitivity Fig.4 Ambient Temperature vs. Dark Current (Vr=1V) (Vr=1V) Fig.5 Wavelength vs. Relative Sensitivity Fig.6 Angle vs. Relative Sensitivity www.rohm.com © 2020 ROHM Co., Ltd. All rights reserved. 3/3 2020.7 – Rev.001 Notice Notes 1) The information contained herein is subject to change without notice. 2) Before you use our Products, please contact our sales representative and verify the latest specifications : 3) Although ROHM is continuously working to improve product reliability and quality, semiconductors can break down and malfunction due to various factors. Therefore, in order to prevent personal injury or fire arising from failure, please take safety measures such as complying with the derating characteristics, implementing redundant and fire prevention designs, and utilizing backups and fail-safe procedures. ROHM shall have no responsibility for any damages arising out of the use of our Poducts beyond the rating specified by ROHM. 4) Examples of application circuits, circuit constants and any other information contained herein are provided only to illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. 5) The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM or any other parties. ROHM shall have no responsibility whatsoever for any dispute arising out of the use of such technical information. 6) The Products specified in this document are not designed to be radiation tolerant. 7) For use of our Products in applications requiring a high degree of reliability (as exemplified below), please contact and consult with a ROHM representative : transportation equipment (i.e. cars, ships, trains), primary communication equipment, traffic lights, fire/crime prevention, safety equipment, medical systems, servers, solar cells, and power transmission systems. 8) Do not use our Products in applications requiring extremely high reliability, such as aerospace equipment, nuclear power control systems, and submarine repeaters. 9) ROHM shall have no responsibility for any damages or injury arising from non-compliance with the recommended usage conditions and specifications contained herein. 10) ROHM has used reasonable care to ensur the accuracy of the information contained in this document. However, ROHM does not warrants that such information is error-free, and ROHM shall have no responsibility for any damages arising from any inaccuracy or misprint of such information. 11) Please use the Products in accordance with any applicable environmental laws and regulations, such as the RoHS Directive. For more details, including RoHS compatibility, please contact a ROHM sales office. ROHM shall have no responsibility for any damages or losses resulting non-compliance with any applicable laws or regulations. 12) When providing our Products and technologies contained in this document to other countries, you must abide by the procedures and provisions stipulated in all applicable export laws and regulations, including without limitation the US Export Administration Regulations and the Foreign Exchange and Foreign Trade Act. 13) This document, in part or in whole, may not be reprinted or reproduced without prior consent of ROHM. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 2014 ROHM Co., Ltd. All rights reserved. R1102B
RPMD-0132
物料型号为RPMD-0132,由ROHM公司生产。
以下是该物料的详细信息:
1. 器件简介:这是一款表面安装型光电二极管,适用于消费电子、工业电子、可穿戴设备以及其他通用应用。
2. 引脚分配:文档中未明确列出引脚分配,但提到了Terminal 3不需要焊接。
3. 参数特性: - 反向电压(Vr):3V - 工作温度范围(Topr):-25℃ 至 +75℃ - 存储温度范围(Tstg):-40℃ 至 +85℃
4. 功能详解: - 厚度为0.55mm - 改进了对绿光波长(用于脉搏波感测)的灵敏度 - 红外波长也是活跃的感测区域 - 高活跃区域与封装区域的比例
5. 应用信息:适用于消费电子、工业电子、可穿戴设备等。
6. 封装信息:提供了外形尺寸,但具体数值未在摘要中显示。
需要注意的是,尺寸不包括毛刺,最大毛刺尺寸为+0.1mm。
此外,文档还包含了电气和光学特性表,以及相关的图表,例如反向电压与暗电流的关系、环境温度与相对灵敏度的关系等。
还有关于ROHM客户支持系统、产品信息变更通知、安全措施、应用电路示例等的说明。
RPMD-0132 价格&库存
很抱歉,暂时无法提供与“RPMD-0132”相匹配的价格&库存,您可以联系我们找货
RPMD-0132
  • 1+49.079981+6.29550
  • 10+36.6434710+4.70026
  • 100+29.30666100+3.75917
  • 500+26.09851500+3.34766
  • 1000+25.256541000+3.23966
库存:1451
RPMD-0132
  • 1+16.94650
  • 200+14.12210
  • 500+11.29760
  • 1000+9.41470
RPMD-0132
    • 1+18.989401+2.43578
    • 10+16.8552910+2.16203
    • 30+13.3821330+1.71653
    • 50+12.6875050+1.62743
    • 100+12.16025100+1.55980
    • 300+11.81711300+1.51579
    • 500+11.74179500+1.50612
    库存:2000
    RPMD-0132
    • 2000+24.173792000+3.10078
    库存:1451
