SIR-505STA47_07
SIR-505STA47_07
    ROHM(罗姆)
    SIR-505STA47_07 - Infrared light emitting diode, top view type - Rohm
SIR-505STA47_07 数据手册
SIR-505STA47 Sensors Infrared light emitting diode, top view type SIR-505STA47 The SIR-505STA47 is optimal for tape-end sensors in VTR's and other equipment. It can be directly mounted on a printed circuit board. Applications VCR's, Optical control equipment Features 1) φ5 mm plastic package. 2) Direct-mount type. 3) Long life and high reliability. Dimensions (Unit : mm) φ6.0±0.3 φ5.0 5.1 (2.2) 7.3±0.3 Max. 1.0 2 1 (5.0) 2.5±0.3 (2.0) Min. 18.0 1 Anode Notes: 1. Unspecified tolerance shall be ±0.2 . 2. Dimension in parenthesis are show for reference. 2−0.5 +0.2 −0.1 2− 0.4±0.1 (C 0. 2) 2 Cathode Absolute maximum ratings (Ta = 25°C) Parameter Forward current Reverse voltage Power dissipation Pulse forward current Operating temperature Storage temperature Symbol IF VR PD IFP∗ Topr Tstg Limits 100 5 160 0.5 −25 to +85 −40 to +85 Unit mA V mW A °C °C ∗ Pulse width = 0.1 ms, duty ratio 1% Electrical and optical characteristics (Ta = 25°C) Parameter Optical output Emitting strength Forward voltage Reverse current Peak light emitting wavelength Spectral line half width Half-viewing angle Response time Cut-off frequency Symbol PO IE VF IR λP ∆λ θ1/2 tr tf fc Min. − 5.6 − − − − − − − Typ. 8.0 10.0 1.38 − 950 40 Max. − 25.7 1.6 10 − − − − − Unit mW mW/sr V µA nm nm deg µs MHz IF=50mA IF=50mA IF=100mA VR=3V IF=50mA IF=50mA IF=50mA IF=50mA IF=50mA Conditions ±15 1.0 1.0 Rev.A 1/2 SIR-505STA47 Sensors Electrical and optical characteristic curves 100 FORWARD CURRENT : IF (mA) 100 FORWARD CURRENT : IF (mA) 100 80 80 60 40 20 0 −25°C 0°C 25°C 50°C 75°C RELATIVE OPTICAL OUTPUT : PO (%) 80 60 60 40 40 20 0 0 20 −20 0 20 40 60 80 100 AMBIENT TEMPERATURE : Ta (°C) 1 FORWARD VOLTAGE : VF(V) 2 0 900 920 940 960 980 1000 OPTICAL WAVELENGTH : λ (nm) Fig.1 Forward current falloff Fig.2 Forward current vs. forward voltage Fig.3 Wavelength characteristics RELATIVE EMITING STRENGT H : IE(%) 20 EMITTING STRENGTH : IE (mW / sr) 200 16 100 12 50 8 20 4 10 −25 0 25 50 75 100 0 0 10 20 30 40 50 60 70 80 90 100 FORWARD CURRENT : IF (mA) AMBIENT TEMPERATURE : Ta (°C) Fig.4 Emitting strength vs. forward current Fig. 5 Relative emitting strength vs. ambient temperature 30° 40° 50° 60 60° 70° 80° 90° 100 40 80 20 80 60 40 20 0 10 20 30 40 50 60 70 80 0 90 RELATIVE EMITTING STRENGTH (%) ANGULAR DISPLACEMENT : θ (deg) Fig. 6 Directional pattern RELATIVE EMITTING STRENGTH (%) 20° 10° 0° 100 Rev.A 2/2 Appendix Notes No technical content pages of this document may be reproduced in any form or transmitted by any means without prior permission of ROHM CO.,LTD. The contents described herein are subject to change without notice. The specifications for the product described in this document are for reference only. Upon actual use, therefore, please request that specifications to be separately delivered. Application circuit diagrams and circuit constants contained herein are shown as examples of standard use and operation. Please pay careful attention to the peripheral conditions when designing circuits and deciding upon circuit constants in the set. Any data, including, but not limited to application circuit diagrams information, described herein are intended only as illustrations of such devices and not as the specifications for such devices. ROHM CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any third party's intellectual property rights or other proprietary rights, and further, assumes no liability of whatsoever nature in the event of any such infringement, or arising from or connected with or related to the use of such devices. Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or otherwise dispose of the same, no express or implied right or license to practice or commercially exploit any intellectual property rights or other proprietary rights owned or controlled by ROHM CO., LTD. is granted to any such buyer. Products listed in this document are no antiradiation design. The products listed in this document are designed to be used with ordinary electronic equipment or devices (such as audio visual equipment, office-automation equipment, communications devices, electrical appliances and electronic toys). Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. About Export Control Order in Japan Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control Order in Japan. In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause) on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction. Appendix1-Rev1.1
SIR-505STA47_07 价格&库存
很抱歉,暂时无法提供与“SIR-505STA47_07”相匹配的价格&库存,您可以联系我们找货
